    4. (gelöst) npm error code EOVERRIDE
      Thomas Braun Most Active @Wolhem last edited by Thomas Braun
      @wolhem sagte in (gelöst) npm error code EOVERRIDE:
      /home/iobroker/.npm/_logs/2024-08-30T17_03_10_491Z-debug-0.log
      less /home/iobroker/.npm/_logs/2024-08-30T17_03_10_491Z-debug-0.log
      (seitenweise)
      oder
      cat /home/iobroker/.npm/_logs/2024-08-30T17_03_10_491Z-debug-0.log
      (Volltext)
      Du kannst aber auch mal
      iob diag
      laufen lassen. Oft klemmt es noch an anderen Stellen.
        Wolhem @Thomas Braun last edited by Homoran
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: pi4-iob
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model		: Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         19:42:52 up  1:01,  3 users,  load average: 0.38, 0.31, 0.31
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2024-08-30 19:42:53 CEST
                   Universal time: Fri 2024-08-30 17:42:53 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** Display-Server-Setup ***
        Display-Server: true
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           7.9G        1.2G        5.9G        119M        858M        6.3G
        Swap:           99M          0B         99M
        Total:         8.0G        1.2G        6.0G
        Active iob-Instances: 	22
                 7898 M total memory
                 1171 M used memory
                  461 M active memory
                 1227 M inactive memory
                 5869 M free memory
                  167 M buffer memory
                  690 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 19:42:53 up  1:01,  3 users,  load average: 0.38, 0.31, 0.31
        Tasks: 185 total,   1 running, 184 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7898.7 total,   5869.3 free,   1170.7 used,    858.8 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6335.2 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   12G   16G  42% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G   17M  3.9G   1% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
        [Fri Aug 30 18:41:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:3840x2160M@30,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:E7:9D:8C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7ebaa6f8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Fri Aug 30 18:41:23 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Fri Aug 30 18:41:23 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Aug 30 18:41:26 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems:
        TARGET                                SOURCE         FSTYPE          OPTIONS
        /                                     /dev/mmcblk0p2 ext4            rw,noatime
        |-/dev                                devtmpfs       devtmpfs        rw,relatime,size=3879288k,nr_inodes=74941,mode=755
        | |-/dev/shm                          tmpfs          tmpfs           rw,nosuid,nodev
        | |-/dev/pts                          devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                       mqueue         mqueue          rw,relatime
        |-/sys                                sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs          tmpfs           ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate
        | | |-/sys/fs/cgroup/systemd          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/blkio            cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,blkio
        | | |-/sys/fs/cgroup/devices          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,devices
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/pids             cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,pids
        | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpuset
        | | |-/sys/fs/cgroup/freezer          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,freezer
        | | `-/sys/fs/cgroup/perf_event       cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,perf_event
        | |-/sys/fs/bpf                       none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                 debugfs        debugfs         rw,relatime
        | |-/sys/kernel/config                configfs       configfs        rw,relatime
        | `-/sys/fs/fuse/connections          fusectl        fusectl         rw,relatime
        |-/proc                               proc           proc            rw,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/run                                tmpfs          tmpfs           rw,nosuid,nodev,mode=755
        | |-/run/lock                         tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs      rw,relatime
        | `-/run/user/1000                    tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=808828k,mode=700,uid=1000,gid=1000
        |   `-/run/user/1000/gvfs             gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot                               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.6G	/var/
        2.3G	/var/cache/apt/archives
        2.3G	/var/cache/apt
        2.3G	/var/cache
        125M	/var/lib
        Archived and active journals take up 16.0M in the file system.
        /opt/iobroker/backups:
        15M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        885M	/opt/iobroker/iobroker-data/
        706M	/opt/iobroker/iobroker-data/files
        441M	/opt/iobroker/iobroker-data/files/javascript.admin
        409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        27M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
        24M	/opt/iobroker/iobroker-data/objects.jsonl
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        9.7M	/opt/iobroker/iobroker-data/objects.json.migrated
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2492447-if00
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.20.4
        /usr/bin/node 		v18.20.4
        /usr/bin/npm 		10.7.0
        /usr/bin/npx 		10.7.0
        /usr/bin/corepack 	0.28.0
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 600
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.20.3-1nodesource1 600
             18.20.2-1nodesource1 600
             18.20.1-1nodesource1 600
             18.20.0-1nodesource1 600
             18.19.1-1nodesource1 600
             18.19.0-1nodesource1 600
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	6.0.9
        admin: 		7.0.22
        javascript: 	8.7.6
        nodejs modules from github: 	0
        Adapter State
          system.adapter.admin.0                  : admin                 : pi4-iob                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : pi4-iob                                  -  enabled
        + system.adapter.backitup.0               : backitup              : pi4-iob                                  -  enabled
        + system.adapter.ble.0                    : ble                   : pi4-iob                                  -  enabled
          system.adapter.bshb.0                   : bshb                  : pi4-iob                                  - disabled
        + system.adapter.cloud.0                  : cloud                 : pi4-iob                                  -  enabled
        + system.adapter.discovery.0              : discovery             : pi4-iob                                  -  enabled
        + system.adapter.email.0                  : email                 : pi4-iob                                  -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : pi4-iob                                  -  enabled
        + system.adapter.hue.0                    : hue                   : pi4-iob                                  -  enabled, port: 443
        + system.adapter.info.0                   : info                  : pi4-iob                                  -  enabled
        + system.adapter.iot.0                    : iot                   : pi4-iob                                  -  enabled
        + system.adapter.iqontrol.0               : iqontrol              : pi4-iob                                  -  enabled
          system.adapter.jarvis.0                 : jarvis                : pi4-iob                                  - disabled
        + system.adapter.javascript.0             : javascript            : pi4-iob                                  -  enabled
        + system.adapter.lovelace.0               : lovelace              : pi4-iob                                  -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
          system.adapter.mercedesme.0             : mercedesme            : pi4-iob                                  - disabled
          system.adapter.mqtt.0                   : mqtt                  : pi4-iob                                  - disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.rpi2.0                   : rpi2                  : pi4-iob                                  -  enabled
        + system.adapter.shelly.0                 : shelly                : pi4-iob                                  -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : pi4-iob                                  -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : pi4-iob                                  -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : pi4-iob                                  -  enabled
          system.adapter.tuya.0                   : tuya                  : pi4-iob                                  - disabled
          system.adapter.vis-bars.0               : vis-bars              : pi4-iob                                  -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pi4-iob                                  -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi4-iob                                  -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi4-iob                                  -  enabled
          system.adapter.vis-weather.0            : vis-weather           : pi4-iob                                  -  enabled
          system.adapter.vis.0                    : vis                   : pi4-iob                                  - disabled
        + system.adapter.web.0                    : web                   : pi4-iob                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : pi4-iob                                  -  enabled
        + system.adapter.zigbee.0                 : zigbee                : pi4-iob                                  -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2492447-if00
        + instance is alive
        ioBroker-Repositories
        │ (index) │   name   │                           url                           │ auto upgrade │
        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
        Adapter    "ble"          : 0.14.0   , installed 0.14.0
        Adapter    "bshb"         : 0.2.8    , installed 0.2.8
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "hue"          : 3.11.0   , installed 3.11.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.11   , installed 6.0.9  [Updatable]
        Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "telegram"     : 3.9.0    , installed 3.3.2  [Updatable]
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects: 	7772
        States: 	6367
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16303      551/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15749      388/cupsd
        tcp        0      0 0.0.0.0:44953           0.0.0.0:*               LISTEN      1001       44017      3896/io.yahka.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       43612      3669/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       43001      3717/io.sonoff.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42691      3498/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42684      3498/iobroker.js-co
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45655      3841/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16307      551/sshd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15748      388/cupsd
        tcp6       0      0 :::8091                 :::*                    LISTEN      1001       46387      4224/io.lovelace.0
        udp        0      0 0.0.0.0:51115           0.0.0.0:*                           108        15327      385/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17152      453/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17041      511/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15325      385/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          20570      453/dhcpcd
        udp6       0      0 :::35021                :::*                                108        15328      385/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        15326      385/avahi-daemon: r
        2024-08-30 19:18:19.947  - info: ble.0 (4024) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.20.4, js-controller: 6.0.9
        2024-08-30 19:18:20.072  - info: ble.0 (4024) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
        2024-08-30 19:18:20.074  - info: ble.0 (4024) enabled plugins: Xiaomi, _default
        2024-08-30 19:18:20.076  - info: ble.0 (4024) monitored services: fe95
        2024-08-30 19:18:20.153  - info: ble.0 (4024) starting scanner process...
        2024-08-30 19:18:20.347  - info: iqontrol.0 (4017) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v18.20.4, js-controller: 6.0.9
        2024-08-30 19:18:20.527  - info: iqontrol.0 (4017) systemLanguage = de
        2024-08-30 19:18:20.529  - info: iqontrol.0 (4017) Creating Passphrase...
        2024-08-30 19:18:20.575  - info: iqontrol.0 (4017) Creating Popup States...
        2024-08-30 19:18:21.103  - info: iqontrol.0 (4017) Creating Widget States...
        2024-08-30 19:18:21.341  - info: ble.0 (4024) starting scan for services ["fe95"]
        2024-08-30 19:18:21.689  - info: iqontrol.0 (4017) Lists deactivated.
        2024-08-30 19:18:21.689  - info: iqontrol.0 (4017) Deleting unused Objects...
        2024-08-30 19:18:21.691  - info: iqontrol.0 (4017) Subscribing to states...
        2024-08-30 19:18:21.694  - info: iqontrol.0 (4017) iQontrol ready.
        2024-08-30 19:18:23.740  - info: lovelace.0 (4224) starting. Version 4.1.10 in /opt/iobroker/node_modules/iobroker.lovelace, node: v18.20.4, js-controller: 6.0.9
        2024-08-30 19:18:23.944  - info: lovelace.0 (4224) http server listening on port 8091
        2024-08-30 19:18:32.071  - info: alexa2.0 (3565) Initialization Done ...
        2024-08-30 19:18:52.887  - info: sonoff.0 (3717) Client [Lampe] connected with secret 1725038332867_8253
        2024-08-30 19:18:53.051  - info: sonoff.0 (3717) Client [Stehlampe] connected with secret 1725038333048_5697
        2024-08-30 19:18:53.443  - info: sonoff.0 (3717) Client [Garderobe] connected with secret 1725038333441_310
        2024-08-30 19:23:00.430  - info: fritzdect.0 (3767) DECT ID: 099950467727 identified for command (setmodeauto) : true
        2024-08-30 19:23:00.567  - info: fritzdect.0 (3767) DECT ID: 099951009476 identified for command (setmodeauto) : true
        2024-08-30 19:23:00.568  - info: fritzdect.0 (3767) DECT ID: 099951009476 identified for command (setmodeauto) : true
        2024-08-30 19:23:00.765  - info: fritzdect.0 (3767) DECT ID: 139790962408 identified for command (setmodeauto) : true
        iob diag has finished.
        Press any key for a summary
          Brauch ich gar nicht weiterlesen als bis:
          Buster ist tot, tot, tot.
          Installier da NEU! das aktuelle Relase Debian 12 'Bookworm', diesmal in der 64Bit-Version. OHNE Desktop.
            Wenn ich bookworm auf dem neuen pi habe, kann ich iob aus den Backups wiederherstellen?
            Thomas Braun W 2 Replies Last reply Reply Quote 0
              Theoretisch ja. In der Praxis setzt das natürlich ein sauberes Backup voraus. Wenn du da den Fehler schon drin hast wird der natürlich auch so falsch wieder eingespielt. Musst du ausprobieren.
              W mcm1957 3 Replies Last reply Reply Quote 0
                ich habe eigentlich immer 10 oder 15 backups.
                Der Fehler ist erst seit 2oder 3 Tagen.
                  Wolhem @Wolhem last edited by
                  @wolhem
                  Ich werde mal versuchen und werde berichten.
                  • mcm1957
                    mcm1957 @Thomas Braun last edited by
                    @thomas-braun said in (gelöst) npm error code EOVERRIDE:
                    Im Prinzip stimmt die Aussage für Backups natürlich.
                    Aber ich dachte bisher dass das ioBroker Backup NUR die Konfigurationsdaten enthält. Die Adapter werden doch erst nach dem Restaurieren der Konfig via backitup neu installiert. Und da sollte doch der ganze npm Baum auch neu erstellt werden.
                    Oder steh ich bei der Hitze grad auf der Leitung?
                      @wolhem Muss ich das Backup auf den Raspi kopieren?
                      Auf dem Fritz.NAS findet er es nicht?
                        @thomas-braun Muss ich das Backup auf den Raspi kopieren?
                        0
                          @wolhem
                          Du musst den Backitup-Adapter (wenn du den verwendet hast) wieder so einrichten wie im Altsystem. Dazu kann man z. B. die Konfig separat sicher.
                            @thomas-braun kann ich ein Backup der konfig über die Konsole machen?
                            oder ich schlecht wegen der Fehler?
                              Thomas Braun Most Active @Wolhem last edited by Homoran
                              @wolhem
                              Backup anlegen:
                              iob backup
                              Backup zurückspielen:
                              iob restore /pfad/zum/backup
                              Wo liegt denn dein Backup nun?
                                @thomas-braun http://192.168.61.1/nas#/files/BACKUP
                                  @wolhem
                                  Dann hol die doch von da wieder zurück? Ich versteh gerade dein Problem nicht.
                                    @thomas-braun wenn ich bei dem neuen pi das backup mit dem Pfad konfiguriere findet er kein backup
                                      @wolhem
                                      Du solltest die Freigabe (CIFS?/NFS?) in Backitup im Bereich NAS einrichten. Dann wird die in /opt/iobroker/backups gemountet und dann findet 'er' da auch die Dateien.
                                        @thomas-braun ich hab beide schon probiert.😵
                                        wie muss der Pfad eigegeben werden? vielleicht habe ich da was falsch
                                          Generell solltest du mal sagen was du da genau mit welchen Rückmeldungen im LogFile oder im Terminal bekommst.
                                          So ist das nur gerate.
                                            @thomas-braun Ich melde mich die Tage noch mal, muss jetzt weg.
                                            9074
