    4. Milight Adapter Error nach JS Update auf 18.16.1
    • U
      URI3L last edited by
      ich habe den JS Controller auf 18.16.1 upgedated und jetzt spuckt der Milight Adapter folgende Fehlermeldungen aus:
      Aus den Fehlermeldungen werde ich nicht schlau. Kann mir jemand bitte helfen?
      2024-09-01 17:12:17.364 - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.milight/milight.js:472
      2024-09-01 17:12:17.364 - error: host.iobroker Caught by controller[0]: adapter = new utils.Adapter(options);
      2024-09-01 17:12:17.364 - error: host.iobroker Caught by controller[0]: ^
      2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: TypeError: utils.Adapter is not a constructor
      2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.milight/milight.js:472:16)
      2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.milight/milight.js:682:5)
      2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
      2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:23:47
      2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: Node.js v18.16.1
      2024-09-01 17:12:17.367 - error: host.iobroker instance system.adapter.milight.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-09-01 17:12:17.367 - info: host.iobroker Restart adapter system.adapter.milight.2 because enabled
      Thomas Braun Ro75 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @URI3L last edited by
        @uri3l Bring es auf nodejs@20 und schau es dir dann nochmal an.
        iob nodejs-update 20
        • Ro75
          Ro75 @URI3L last edited by
          @uri3l sagte in Milight Adapter Error nach JS Update auf 18.16.1:
          von was eigentlich? 16.x? Welches BS läuft denn da (noch) ? GGfs. Debian Buster?
          Ro75
          • U
            URI3L @Ro75 last edited by
            @ro75 Raspbian 10 ist installiert. Welche Node Version vorher war, kann ich nicht sagen. war aber kein großer Versionssprung, da ich öfters mal update. Könnte man das aus den Backitup-Sicherungen auslesen?
            @Thomas-Braun Wenn ich auf 20 update, kommt folgende Meldung:
            ioBroker nodejs fixer 2024-05-23
            You requested to install latest version from nodejs v20 tree.
            Your current setup is:
            /usr/bin/node 		v18.16.1
            /usr/local/bin/npm 		9.6.7
            /usr/local/bin/npx 		9.6.7
            /usr/local/bin/corepack 	0.18.0
            *** nodejs is NOT correctly installed ***
            We found these nodejs versions available for installation:
            nodejs:
              Installed: 18.16.1-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
                 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
             *** 18.16.1-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u3 500
            Your nodejs-Installation seems to be faulty. Shall we try to fix it?
            Press <y> to continue or any other key to quit
            Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
            • Ro75
              @uri3l Mit Buster kommst du nicht auf Nodejs 20! Viel zu alt.
              Ro75.
                @uri3l
                Da siehste auch schon die Fehler. OS zu alt und nodejs ist da irgendwie reingeklatscht worden.
                Installier da NEU ein Raspberry OS 12.
                • U
                  URI3L @Thomas Braun last edited by
                  @thomas-braun Vielen Dank. Ich bin jetzt auf OS12 und es läuft wieder.
                  Danke an alle
