      TT-Tom @GregorS last edited by TT-Tom
      @gregors
      so der code für das mrIcon2
          mrIcon2ScreensaverEntity: {
              ScreensaverEntity: '0_userdata.0.example_number',
              ScreensaverEntityIconOn: null,
              ScreensaverEntityIconOff: null,
              ScreensaverEntityIconSelect: { '0': 'shield-off', '1': 'shield', '2': 'shield-home' },
              ScreensaverEntityValue: null,
              ScreensaverEntityValueDecimalPlace: 1,
              ScreensaverEntityValueUnit: null,
              ScreensaverEntityOnColor: Red,
              ScreensaverEntityOffColor: Green,
       <block type="on" id="y?b@(GIxA5-afpeG_h,q" x="62" y="63">
         <field name="OID">alias.0.NSPanel.Alarm.TYPE</field>
           <block type="controls_if" id="6*]DRyCOx|!l}Ms#LE|t">
             <mutation elseif="2"></mutation>
               <block type="logic_compare" id="YtsRwf+[dMod1m0ayC`G">
                 <field name="OP">EQ</field>
                   <block type="on_source" id="Y!KoM.A}AA-?BPnlO+,|">
                   <block type="text" id="!6HE`BwhVU_m^`+Kyd$2">
                     <field name="TEXT">D1</field>
               <block type="update" id="9.BYW]%7fnr^Brvdub]H">
                 <field name="OID">0_userdata.0.example_number</field>
                   <block type="math_number" id="f!fGv+y|j/^z!XMTEy7`">
                     <field name="NUM">0</field>
             <value name="IF1">
               <block type="logic_compare" id=";({}}jkx!QmR]J^[%o%=">
                   <block type="on_source" id="x*d`|kmHdGbgeH!D8*tJ">
                   <block type="text" id="X}kGW!x))Z(E@~Kv8#40">
                     <field name="TEXT">A1</field>
             <statement name="DO1">
               <block type="update" id="=6O1ojQ#yh#8y??w]jzK">
                   <block type="math_number" id="?~VV3pYwtm-[TMAVZZQe">
                     <field name="NUM">1</field>
             <value name="IF2">
               <block type="logic_compare" id="tABH3Q+XAAZpprG0dk$!">
                   <block type="on_source" id=".A/am`xS9?{,Gd9rf}l:">
                   <block type="text" id="Sq,t}6)0ovLtt7WAr6ia">
                     <field name="TEXT">A2</field>
             <statement name="DO2">
               <block type="update" id="o;W`RL.71t6ie0:bjt?k">
                   <block type="math_number" id="IG(g68za76dxG}_A*0{@">
                     <field name="NUM">2</field>
      es gehen nur zwei Farben (an/aus, 0/1) also ist disarmed (D1) 0/grün alle andern Werte Rot
      GregorS N 3 Replies Last reply Reply Quote 1
        bob der 1. last edited by bob der 1.
        ich stehe hier vor dem Problem das sich das Display nicht flashen lässt:
        Im der Konsole gibt es folende Ausgabe
        Aktuell läuft 14.2.0 (release-tasmota32) auf dem NS.War nagel neu und habe auch eine 12 Version versucht.
        Bin auch strikt nach der Anleitung aus dem Wiki verfahren.
        kann jemand damit etwas anfangen.?
        13:31:20.896 CMD: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.4.0.tft
        13:31:20.904 MQT: SmartHome/Sonoff_NS1/stat/RESULT = {"FlashNextion":"Done"}
        13:31:20.922 FLH: host: nspanel.pky.eu, port: 80, get: /lovelace-ui/github/nspanel-v4.4.0.tft
        13:31:21.455 FLH: Send (High Speed) flash start
        13:31:21.801 FLH: Something has gone wrong flashing display firmware [bytes('85')]
        13:31:59.385 MQT: SmartHome/Sonoff_NS1/stat/RESULT = {"CustomSend":"Done"}
        13:32:59.374 MQT: SmartHome/Sonoff_NS1/stat/RESULT = {"CustomSend":"Done"}
        13:33:51.418 MQT: SmartHome/Sonoff_NS1/stat/RESULT = {"POWER1":"OFF"}
        13:33:51.420 MQT: SmartHome/Sonoff_NS1/stat/POWER1 = OFF
        13:33:51.575 MQT: SmartHome/Sonoff_NS1/stat/RESULT = {"CustomSend":"Done"}
        13:33:51.819 MQT: SmartHome/Sonoff_NS1/stat/RESULT = {"POWER1":"OFF"}
        13:33:51.822 MQT: SmartHome/Sonoff_NS1/stat/POWER1 = OFF
        13:33:52.467 MQT: SmartHome/Sonoff_NS1/stat/RESULT = {"POWER1":"OFF"}
        13:33:52.469 MQT: SmartHome/Sonoff_NS1/stat/POWER1 = OFF
        13:33:59.277 MQT: SmartHome/Sonoff_NS1/stat/RESULT = {"CustomSend":"Done"}
        • GregorS
          GregorS @TT-Tom last edited by
          @tt-tom
          Funktioniert einwandfrei.
          Danke !!! 👍
            TT-Tom @bob der 1. last edited by
            @bob-der-1
            versuche diese Befehle in der Tasmota Konsole nacheinander.
            https://forum.iobroker.net/post/1192017
              bob der 1. @TT-Tom last edited by
              @tt-tom
              Danke schon mal,gebe morgen Rückmeldung dazu.
              Leider ist.meine heutige Display Zeit rum....
              Welche Tasmo Version sollte man eigentlich nehmen.
              Also bin ich mit der aktuellsten also nicht ganz auf dem Holzweg gelandet.
              Bin wohl auch duech die vielen Anleitungen durcheinander gekommen😎
                Kuckuckmann @GregorS last edited by
                @gregors & @TTom
                Könnt Ihr mir nochmal kurz zusammenstellen, was ihr hier gemacht habt? ich würde das dann in die Wiki übernehmen 🙂
                Danke Euch vorab
                LG
                  TT-Tom @Kuckuckmann last edited by
                  @kuckuckmann
                  Zwei Varianten auf dem Screensaver den Status der AlarmPage anzuzeigen. Die erste Variante war für den Advanced als Icon in der Indikatorenreihe inkl. Sprung auf die AlarmPage.
                  Die zweite Variante ist für den Standard Screensaver, wo der Status auf mrIcon2 dargestellt wird.
                  Beide Varianten sind noch nicht vollständig ausgebaut. Es gibt Schutzstufe 1-4 (A1-A4). Werde die Blockly noch darauf hin anpassen.
                  Kannst aber im Wiki schon mal soweit übernehmen und platzieren.
                  GregorS 1 Reply Last reply Reply Quote 1
                  • GregorS
                    Problem beim erstellen eines Charts.
                    let CardLChartExample: PageType =
                        'type': 'cardLChart',
                        'heading': 'AZ_Temperatur',
                        'items': [{
                                    yAxis: 'Temperatur [°C]',
                                    yAxisTicks: [-250, -200, -150, -100,-50, 0, 50, 100, 150, 200, 250, 300],
                                    onColor: Yellow
                        pages: [
                            NSPanel_Service, //Auto-Alias Service Page
                            //Unlock_Service            //Auto-Alias Service Page (Service Pages used with cardUnlock)
                                Radiosender,
                                Buero_Alarm,
                                AZ_Temperatur,
                            //    Fenster,
                    Es kommt aber immer dieser Fehler:
                    script.js.NSPanel_2_V4_4_0_1: TypeScript compilation failed: AZ_Temperatur, ^ ERROR: Cannot find name 'AZ_Temperatur'.
                    Hänge irgendwie fest. Habe mehrer Seiten angelegt, aber hier ist Ende.
                      @gregors
                      Hinter let steht der Name der Seite. In deinem Fall CardLChartExample
                      heading Ist die Überschrift auf der Seite.
                      GregorS 1 Reply Last reply Reply Quote 0
                        bob der 1. @TT-Tom last edited by bob der 1.
                        @tt-tom
                        19:58:24.919 FLH: host: nspanel.pky.eu, port: 80, get: /lovelace-ui/github/nspanel-v4.4.0.tft
                        19:58:25.614 FLH: Send (High Speed) flash start
                        19:58:25.964 FLH: Something has gone wrong flashing display firmware [bytes('85')]
                        Display Schwarz
                        Dann
                        20:03:31.896 CMD: FlashNextion http://nspanel.pky.eu/lui.tft
                        20:03:31.900 RSL: RESULT = {"FlashNextion":"Done"}
                        20:03:31.938 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                        20:03:32.426 FLH: Send (High Speed) flash start
                        20:03:32.779 RSL: RESULT = {"Flashing":{"complete": 0, "time_elapsed": 0}}
                        Display weiss Model does not match.....
                        Anschließend
                        20:06:12.991 CMD: FlashNextionAdv6 http://nspanel.pky.eu/lui.tft
                        20:06:12.995 RSL: RESULT = {"FlashNextionAdv":"Done"}
                        20:06:13.023 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                        Keine Veränderung im Display
                        20:07:57.153 CMD: FlashNextionAdv0 http://nspanel.pky.eu/lui.tft
                        20:07:57.157 RSL: RESULT = {"FlashNextionAdv":"Done"}
                        20:07:57.191 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
                        20:07:57.682 FLH: Send (High Speed) flash start
                        20:07:58.034 FLH: Something has gone wrong flashing display firmware [bytes('85')]
                        Wieder schwarz und bleibt bei writing Data stehen...Konsole passiert auch nichts
                        Tasmota 14.0.2.0 ns Panel
                        T GregorS 2 Replies Last reply Reply Quote 0
                          @bob-der-1
                          lese dir bitte mal die Beiträge nach dem Link durch, den ich dir gesendet habe. @lustig29 hatte auch Probleme mit dem Flashen. Ist dann auf Tasmota auf 12 gegangen.
                            @tt-tom
                            Soweit bin ich nicht gekommen.....
                            Lese immer erst und mache dann weiter....
                            Melde mich natürlich wenn ich da angekommen bin
                              @tt-tom
                              Nachdem ich bei dem Post angekommen bin,in dem der Hinweis Tasmota 12.0.2 erwähnt wurde und diese geflasht habe wurde das Display auch "erkannt".Display Flash lief beim 1.mal direkt durch.
                              Was auch anders ist ,das im MainFaceplate die Temp. des ESP nun angezeigt wird.....in der Condig wird ja beschrieben was man ab der 12er diesen wieder anschalten muss,ging aber auch nie.
                              Nun ziehe ich mal die Version hoch und versuche MQTT und die Skripte zu laufen zu bekommen.
                              Danke schon mal
                                @bob-der-1
                                Dann bist du jetzt schon der zweite mit dieser Problematik. Wenn es noch ein zwei User trifft, gehe ich mal von einem Fehler aus.
                                Wenn alles auf dem neuesten Stand ist und läuft gib nochmal Bescheid.
                                Viel Spaß noch 👍🏻
                                B 2 Replies Last reply Reply Quote 1
                                  @tt-tom
                                  Natürlich gebe ich Feddback dazu.
                                  Eventuell liegt es an unterschiedlicher Hardware,eventuell habe ich ein frühes Gerät erwischt oder ein Gerät das irgendwie etwas anders ist als die große Masse.
                                  Ich schau mal ob ich Bilder/Infos dazu sammeln kann was auf der Platine steht.Was ich nicht versucht habe mit Tasmota 13.x.x.x....könnte ja sein das es der Safeboot ist der da etwas harkelt?
                                    ssteinberger1988 last edited by
                                    Hallo
                                    Seit gestern habe ich hier ein NSPanel liegen und habe auch schon einiges hinbekommen.
                                    Die MQTT-Verbindung zu meinem ioBroker funktioniert, aber egal was ich probiere, mein NSPanel zeigt dauerhaft "Waiting for content" an
                                    Ich habe die aktuelle NSPanel.ts genutzt.
                                    Auch sonst bin ich dem Wiki mit den aktuell vorhandenen Scripts gefolgt.
                                    Auf dem NSPanel läuft Tasmota 14.1.0 (14.2.0 wollte gar nicht richtig laufen, deshalb 14.1.0)
                                    Ab und an kommt auch die Anzeige, dass eine neue Version verfügbar ist, aber egal wo ich da tippe, passieren tut gar nichts.
                                    Welche Informationen werden gebraucht, damit ihr mir helfen könnt? Bin leider auch hier im Forum bisher ein absoluter Neuling.
                                    Grüße Sascha
                                    • GregorS
                                      @tt-tom
                                      Habe ich passsend geändert, aber es wird keine Seite angezeigt.
                                      Es gibt nur die Seiten Radiosender, Alarmanlage und die Servicepage
                                                  Radiosender,
                                                  Buero_Alarm,
                                                  CardLChartExample,
                                              //    Fenster,
                                      • GregorS
                                        GregorS @bob der 1. last edited by
                                        @bob-der-1
                                        Ich habe in der Konsole Reset 6 und Reset 2 ausgeführt und dann
                                        mit
                                        FlashNextionAdv1 http://nspanel.pky.eu/lui-release.tft
                                        geflasht. Danach lief mein Panel wieder.
                                        tasmota32-nspanel.bin
                                          bob der 1. @GregorS last edited by
                                          @gregors sagte in SONOFF NSPanel mit Lovelace UI:
                                          @bob-der-1
                                          mit
                                          aktuell rennt das Panel ja, muss es morgen nur auf Tasmota 14 bringen....
                                          Reset 6 dann 2 hatte ich nicht versucht!
                                            bob der 1. @ssteinberger1988 last edited by
                                            @ssteinberger1988 sagte in SONOFF NSPanel mit Lovelace UI:
                                            Hallo
                                            Grüße Sascha
                                            Schau mal das https://www.youtube.com/watch?v=ZPLJk2ZLo_8
                                            ab der 12 Minute an.....denke das hier der Fehler liegt.
                                            lovelace ui nspanel sonoff
                                            271
                                            7720
                                            6621134
