    3. Einsteigerfragen
    4. mqtt Adapter startet nicht mehr nach js-controller update
    • wendy2702
      Stell das loggen für den MQTT mal auf Debug und poste dann das log vom start
      rtwl 1 Reply Last reply Reply Quote 0
      • rtwl
        rtwl @wendy2702 last edited by rtwl
        @wendy2702
        Hier der Debug Log
        2024-09-04 21:53:22.196 - warn: zigbee.0 (1081) DeviceAvailability:Stopping to ping 0x000b57fffe2a31ca TRADFRI bulb E27 WS�opal 980lm after 4 ping attempts
        2024-09-04 21:59:31.441 - info: mqtt.0 (1563) Got terminate signal TERMINATE_YOURSELF
        2024-09-04 21:59:31.445 - info: mqtt.0 (1563) terminating
        2024-09-04 21:59:31.447 - info: mqtt.0 (1563) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-09-04 21:59:31.949 - info: mqtt.0 (1563) terminating
        2024-09-04 21:59:37.058 - info: javascript.0 (788) script.js.common.Adapter_check: 🟥 mqtt
        2024-09-04 21:59:37.341 - debug: mqtt.0 (3068) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-09-04 21:59:37.395 - debug: mqtt.0 (3068) Objects client ready ... initialize now
        2024-09-04 21:59:37.398 - debug: mqtt.0 (3068) Objects create System PubSub Client
        2024-09-04 21:59:37.400 - debug: mqtt.0 (3068) Objects create User PubSub Client
        2024-09-04 21:59:37.516 - debug: mqtt.0 (3068) Objects client initialize lua scripts
        2024-09-04 21:59:37.526 - debug: mqtt.0 (3068) Objects connected to redis: 127.0.0.1:9001
        2024-09-04 21:59:37.595 - debug: mqtt.0 (3068) Redis States: Use Redis connection: 127.0.0.1:9000
        2024-09-04 21:59:37.627 - debug: mqtt.0 (3068) States create System PubSub Client
        2024-09-04 21:59:37.628 - debug: mqtt.0 (3068) States create User PubSub Client
        2024-09-04 21:59:37.732 - debug: mqtt.0 (3068) States connected to redis: 127.0.0.1:9000
        2024-09-04 21:59:37.794 - debug: mqtt.0 (3068) Plugin sentry Initialize Plugin (enabled=true)
        2024-09-04 21:59:38.391 - info: mqtt.0 (3068) starting. Version 5.2.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.20.4, js-controller: 6.0.11
        2024-09-04 21:59:38.592 - info: mqtt.0 (3068) Starting MQTT authenticated server on 0.0.0.0:1883
        2024-09-04 21:59:38.667 - debug: mqtt.0 (3068) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1725479978661,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725430558620}
        @thomas-braun sagte in mqtt Adapter startet nicht mehr nach js-controller update:
        Der mqtt-Adapter fungiert als Server?
        Ja, so ist er aktuell eingestellt.
        Ehrlichgesagt hab ich keine Ahnung was hier korrekt wäre. Aber wenn das nicht automatisch geändert wurde, war das immer so und hab bis heute vor dem js-controller update so funktioniert.
        • wendy2702
          wendy2702 @rtwl last edited by
          @rtwl ok. Mein Fehler.
          Log posten vom start bis zu dem Zeitpunkt wenn er wieder ausfällt. Also neu startet
          • rtwl
            @wendy2702
            Er fällt ja nicht aus, er Verbindet sich gar nicht.
            es werden nur die oberen 2 Punkte grün. Der untere "Verbindung" Punkt bleibt immer Rot.
            • wendy2702
              @rtwl ok.
              Das heißt im log kommt nicht mehr?
              • rtwl
                @wendy2702
                nein leider nicht 🤔
                • rtwl
                  rtwl last edited by
                  Meine aktuellen Einstellungen:
                  • rtwl
                    rtwl last edited by
                    kann es ein Bug sein, beim js-controller? bzw beim aktualisieren über den Admin?
                    Kann man mit einem consolen Befehl da was machen?
                      @rtwl sagte in mqtt Adapter startet nicht mehr nach js-controller update:
                      die bleibt auch solange rot bis die Gegenstelle(sprich eines deiner Geräte) verbunden/erreichbar ist
                      • rtwl
                        rtwl @crunchip last edited by
                        @crunchip
                        oh man - ich sag ja, ich hab keine Erfahrung mit MQTT.
                        Das war der Fehler. Ich hab die Gegenstelle also meine Smartmeter-Modul rebootet. jetzt läuft es wieder.
                        Sorry und danke für eure Geduld.
                        Wenigstens bin ich jetzt dank @Thomas-Braun auf nodejs@20 😉
                        1.0k
                        740
