      Kerschte_de @Armilar last edited by Kerschte_de
      @armilar ... getan. Hier der Auszug aus der console:
      00:00:00.001 HDW: ESP32-D0WD-V3 v3.0
      00:00:00.064 UFS: FlashFS mounted with 288 kB free
      00:00:00.102 CFG: Loaded from File, Count 245
      00:00:00.113 QPC: Count 1
      00:00:00.168 BRY: Berry initialized, RAM used 3904 bytes
      00:00:00.182 Project tasmota - Tasmota Version 14.1.0(release-nspanel)-3_0_0(2024-06-03T11:56:09)
      00:00:00.348 NXP: Initializing Driver
      00:00:00.351 BRY: Successfully loaded 'autoexec.be'
      00:00:00.357 NXP: Screen Initialized
      00:00:00.468 RSL: RESULT = {"CustomRecv":"event,startup,53,eu"}
      00:00:01.000 WIF: Connecting to AP1 GlasRepThiel Channel 1 BSSId 74:42:7F:B9:EC:1B in mode HT20 as NSPanel-85C180-0384...
      00:00:03.483 WIF: Connected
      00:00:03.738 HTP: Web server active on NSPanel-85C180-0384 with IP address 192.168.188.230
      17:57:39.734 MQT: Attempting connection...
      17:57:39.753 MQT: Connected
      17:57:39.755 MQT: RagowSmartHome/NSPanel_85C180/tele/LWT = Online (retained)
      17:57:39.757 MQT: RagowSmartHome/NSPanel_85C180/cmnd/POWER =
      17:57:39.761 MQT: RagowSmartHome/NSPanel_85C180/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"14.1.0(release-nspanel)","FallbackTopic":"cmnd/DVES_85C180_fb/","GroupTopic":"RagowSmartHome/tasmotas/cmnd/"}}
      17:57:39.785 MQT: RagowSmartHome/NSPanel_85C180/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-85C180-0384","IPAddress":"192.168.188.230","IP6Global":"","IP6Local":"fe80::3ee9:eff:fe85:c180%st1"}}
      17:57:39.797 MQT: RagowSmartHome/NSPanel_85C180/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":80}}
      17:57:39.810 MQT: RagowSmartHome/NSPanel_85C180/stat/RESULT = {"POWER1":"OFF"}
      17:57:39.822 MQT: RagowSmartHome/NSPanel_85C180/stat/POWER1 = OFF
      17:57:39.823 MQT: RagowSmartHome/NSPanel_85C180/stat/RESULT = {"POWER2":"OFF"}
      17:57:39.835 MQT: RagowSmartHome/NSPanel_85C180/stat/POWER2 = OFF
      17:57:39.890 MQT: RagowSmartHome/NSPanel_85C180/stat/RESULT = {"Command":"Unknown"}
      17:57:39.943 MQT: RagowSmartHome/NSPanel_85C180/stat/RESULT = {"CustomSend":"Done"}
      17:57:41.139 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:57:42.871 QPC: Reset
      17:57:43.868 MQT: RagowSmartHome/NSPanel_85C180/tele/STATE = {"Time":"2024-09-05T17:57:43","Uptime":"0T00:00:08","UptimeSec":8,"Heap":133,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":200,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":213},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"GlasRepThiel","BSSId":"74:42:7F:B9:EC:1B","Channel":1,"Mode":"HT20","RSSI":100,"Signal":-44,"LinkCount":1,"Downtime":"0T00:00:03"}}
      17:57:43.905 MQT: RagowSmartHome/NSPanel_85C180/tele/SENSOR = {"Time":"2024-09-05T17:57:43","ANALOG":{"Temperature1":29.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
      17:57:47.121 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:57:53.521 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:57:59.422 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:58:05.421 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:58:11.321 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:58:17.320 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:58:23.321 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:58:29.222 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      17:58:35.221 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
      Danach reboot des Displays. Leider kreiselt es weiter.
      Mir fällt noch ein. Der Beispiel-Datensatz für das Template habe ich aufgrund der vielen Versuche noch aus der englischen Anleitung übernommen. Der weicht ja etwas ggü der deutschen Anleitung ab:
      englische Anleitung:
      {"NAME":"NSPanel","GPIO":[0,0,0,0,3872,0,0,0,0,0,32,0,0,0,0,225,0,480,224,1,0,0,0,33,0,0,0,0,0,0,0,0,0,0,4736,0],"FLAG":0,"BASE":1,"CMND":"ADCParam 2,11200,10000,3950 | Sleep 0 | BuzzerPWM 1"}
      deutsche Anleitung:
      {"NAME":"NSPanel","GPIO":[0,0,0,0,3872,0,0,0,0,0,32,0,0,0,0,225,0,480,224,1,0,0,0,33,0,0,0,0,0,0,0,0,0,0,4736,0],"FLAG":0,"BASE":1}
      Ist bei mir gerade "stochern im Nebel" --> tut mir leid
      • Armilar
        Armilar Most Active Forum Testing @Kerschte_de last edited by
        @kerschte_de sagte in SONOFF NSPanel mit Lovelace UI:
        event,startup,53,eu
        Was passiert, wenn du in der Console
        CustomSend time~18:00
        eingibst
          @armilar said in SONOFF NSPanel mit Lovelace UI:
          Dann wird in der console so darauf reagiert:
          18:04:19.608 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
          18:04:25.508 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
          18:04:31.508 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
          18:04:35.939 MQT: RagowSmartHome/NSPanel_85C180/tele/STATE = {"Time":"2024-09-05T18:04:35","Uptime":"0T00:05:09","UptimeSec":309,"Heap":126,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":526,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":213},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"GlasRepThiel","BSSId":"74:42:7F:B9:EC:1B","Channel":1,"Mode":"HT20","RSSI":100,"Signal":-42,"LinkCount":1,"Downtime":"0T00:00:04"}}
          18:04:35.977 MQT: RagowSmartHome/NSPanel_85C180/tele/SENSOR = {"Time":"2024-09-05T18:04:35","ANALOG":{"Temperature1":29.3},"ESP32":{"Temperature":54.4},"TempUnit":"C"}
          18:04:37.408 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
          18:04:43.408 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
          18:04:47.058 CMD: CustomSend time~18:00
          18:04:47.069 MQT: RagowSmartHome/NSPanel_85C180/stat/RESULT = {"CustomSend":"Done"}
          18:04:49.408 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
          18:04:55.308 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
            TT-Tom @Kerschte_de last edited by
            @kerschte_de
            Welche Daten kommen bei
            Mqtt-Client……Tele.Result an.
            Armilar 1 Reply Last reply Reply Quote 1
            • Armilar
              Armilar Most Active Forum Testing @TT-Tom last edited by
              @tt-tom
              Wahrscheinlich nur
              event,startup,53,eu
              Der CustomSend funktioniert nicht. Könnte man evtl. mal vom mqtt-client.0 auf den mqtt.0 umsteigen?
                @armilar genau das passiert. Die Eingabe kommt nicht an.
                • GregorS
                  GregorS @TT-Tom last edited by
                  @tt-tom
                  Hier die Daten der beiden Datenpunkte:
                  0^17:00+60+120+180+240^21:00+300+360+420+480^01:00+540+600+660+720^05:00+780+840+900+960^09:00+1020+1080+1140+1200^13:00+1260+1320+1380~0:262~21:259~62:250~103:243~144:235~185:230~226:231~267:235~309:237~391:236~473:234~597:232~679:232~802:232~843:237~885:243~967:246~1008:246~1090:249~1214:252~1337:254~1419:255
                  Aber die Seite müsste doch angezeigt werden, oder?
                    @kerschte_de
                    Zeige mal bitte alle Einstellungen von der mqtt Instanz.
                      Kerschte_de @TT-Tom last edited by
                      @tt-tom
                      Ich habe den Client jedoch schon gelöscht und richte gerade den Broker/Client-Adapter als Client ein. Ziel: Instanz soll mqtt.0 werden.
                        @kerschte_de
                        Okay so läuft es bei mir auch.
                          TT-Tom @GregorS last edited by
                          @gregors
                          Du musst den Alias nochmal neu anlegen. Der Datenpunkt heißt ACTUAL, mehr nicht.
                            Kerschte_de @TT-Tom last edited by Kerschte_de
                            @tt-tom
                            Das Script habe ich nun angepasst und MQTT läuft wieder auf dem ioB.
                            javascript.0
                            2024-09-05 18:31:20.888	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false ~17299~
                            javascript.0
                            2024-09-05 18:31:20.887	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Entity ist kein String
                            javascript.0
                            2024-09-05 18:31:20.887	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false 
                            javascript.0
                            javascript.0
                            2024-09-05 18:31:20.886	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: HandleScreensaverUpdate payload: weatherUpdate~~~~65504~~29.8 °C~~~~65363~Sonne~06:24~~~~34351~Wind~6.1m/s~~~~34351~Böen~9.0m/s~~~~65535~Windr.~O~
                            javascript.0
                            2024-09-05 18:31:20.886	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: moments.js --> Datum O valid?: false
                            javascript.0
                            2024-09-05 18:31:20.866	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: moments.js --> Datum 2024-09-05T06:24:00+02:00 valid?: true
                            javascript.0
                            2024-09-05 18:31:04.386	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: renderCurrentPage
                            javascript.0
                            2024-09-05 18:31:04.151	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: HandleMessage -> sleepReached
                            javascript.0
                            2024-09-05 18:31:04.151	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false ~17299~
                            javascript.0
                            2024-09-05 18:31:04.150	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Entity ist kein String
                            javascript.0
                            2024-09-05 18:31:04.150	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false 
                            javascript.0
                            javascript.0
                            2024-09-05 18:31:04.149	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false ~17299~
                            javascript.0
                            2024-09-05 18:31:04.149	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Entity ist kein String
                            javascript.0
                            javascript.0
                            javascript.0
                            2024-09-05 18:31:04.147	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: HandleScreensaverUpdate payload: weatherUpdate~~~~65504~~29.8 °C~~~~63878~Do~15° 33°~~~~65504~Fr~14° 30°~~~~38066~Sa~17° 32°~~~~65504~So~17° 32°~
                            javascript.0
                            2024-09-05 18:30:55.808	error	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: AxiosError: getaddrinfo ENOTFOUND undefined at Function.AxiosError.from (file:///opt/iobroker/node_modules/@iobroker-javascript.0/axios/lib/core/AxiosError.js:92:14) at RedirectableRequest.handleRequestError (file:///opt/iobroker/node_modules/@iobroker-javascript.0/axios/lib/adapters/http.js:620:25) at RedirectableRequest.emit (node:events:519:28) at RedirectableRequest.emit (node:domain:488:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:531:35) at ClientRequest.emit (node:domain:488:12) at emitErrorEvent (node:_http_client:108:11) at Socket.socketErrorListener (node:_http_client:511:5) at Socket.emit (node:events:519:28) at Axios.request (file:///opt/iobroker/node_modules/@iobroker-javascript.0/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'ENOTFOUND', errno: -3008, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=Status0', data: undefined }, request: <ref *1> Writable { _events: { close: undefined, error: [Function: handleRequestError], prefinish: undefined, finish: undefined, drain: undefined, response: [Function: handleResponse], socket: [Function: handleRequestSocket] }, _writableState: WritableState { highWaterMark: 16384, length: 0, corked: 0, onwrite: [Function: bound onwrite], writelen: 0, bufferedIndex: 0, pendingcb: 0, [Symbol(kState)]: 17580812, [Symbol(kBufferedValue)]: null }, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Status0', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Status0' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _eventsCount: 3, _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: true, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 0ab3228bdcbf4434805cb5f56bb6a367-b33093e5bdb0da64\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=0ab3228bdcbf4434805cb5f56bb6a367\r\n' + 'Host: undefined\r\n' + 'Connection: keep-alive\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=Status0', _ended: false, res: null, aborted: false, timeoutCb: [Function: emitRequestTimeout], upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(shapeMode)]: false, [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 16384, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=Status0', [Symbol(shapeMode)]: true, [Symbol(kCapture)]: false }, cause: Error: getaddrinfo ENOTFOUND undefined at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) { errno: -3008, code: 'ENOTFOUND', syscall: 'getaddrinfo', hostname: 'undefined' }}
                            javascript.0
                            2024-09-05 18:30:54.117	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: renderCurrentPage
                            javascript.0
                            2024-09-05 18:30:53.858	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: renderCurrentPage
                            javascript.0
                            2024-09-05 18:30:53.231	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: online tasmota firmware version => 14.2.0
                            javascript.0
                            2024-09-05 18:30:53.230	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: online tasmota firmware version => 14.2.0
                            javascript.0
                            2024-09-05 18:30:53.226	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: renderCurrentPage
                            --> Das Display ist ERWACHT !!! <--
                            T 1 Reply Last reply Reply Quote 2
                              @kerschte_de
                              Na dann kann es ja weiter gehen, viel Spaß noch.
                                @tt-tom @Armilar
                                HERZLICHEN DANK an euch beide, richtig großartig. Allein ist man in dieser Sache schnell "lost". Von daher Hut ab für eure Geduld und euren Fleiß. Hut ab !
                                  lustig29 @Armilar last edited by lustig29
                                  @lustig29
                                  Ist ganz normaler Auslieferungszustand ohne SetOption x
                                  Das heißt SetOption73 und SetOption114 sind auch aus. Was Du auch in der Tasmota-Konsole eingestellt hast, mach es rückgängig und du hörst die Relais auch schalten…
                                  Wie genau mache ich das rückgängig?
                                  Über den userdata_Datenpunkt kann ich die Relais an und aus schalten. Per Taste am Gerät passiert aber nichts.
                                    TT-Tom @lustig29 last edited by
                                    @lustig29
                                    In dem du die Option auf 0 setzt.
                                    SetOption73 0
                                      lustig29 @TT-Tom last edited by
                                      @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                                      SetOption73 0
                                      Perfekt. Danke für die schnelle Hilfe.
                                        TT-Tom @lustig29 last edited by TT-Tom
                                        @lustig29
                                        Musst du mit allen Optionen machen, die du gesetzt hast.
                                        • GregorS
                                          Wollte es alleine versuchen, aber es klappt einfach nicht.
                                          Ich habe 3 elektrische Rolläden.
                                          Dazu wollte ich eine Seite bauen, wo der Zustand der einzelnen Rolläden dargestellt wird.
                                          Die Idee war das "blinds-horizontal" Icon zu nutzen. Daneben der Stellwert der Rollade. Dazu noch 2 Pfeile "hoch" und "runter". Das Icon sollte die Farbe wechseln, Grün bei Wert <10%, Rot >75%.
                                          Als Alias habe ich 4 Werte angelegt.
                                          // Rolläden
                                          let Rolladen: PageType =
                                              'type': 'cardEntities',
                                              'heading': 'Rolläden',
                                              'useColor': true,
                                              'subPage': false,
                                              'items': [
                                          //        <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ.ACTUAL', icon: 'window-shutter', name: 'Rolladen test', interpolateColor: true},
                                          //        <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ.CLOSE', icon: "'button1Page', name: 'runter'},
                                          //        <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ.OPEN', icon: 'button2Page', name: 'hoch'},
                                                  <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ.ACTUAL', icon: 'blinds-horizontal', name: 'Büro'},
                                          Es wird nur die leere Page mit der Überschrift angezeigt.
                                            @gregors
                                            du braucht bei den Seiten nur den Channel angeben, den Rest sucht sich das Script selber.
                                            GregorS 1 Reply Last reply Reply Quote 2
                                            lovelace ui nspanel sonoff
                                            271
                                            7720
                                            6630578
