    • Armilar
      Armilar Most Active Forum Testing @Kerschte_de last edited by
      @kerschte_de sagte in SONOFF NSPanel mit Lovelace UI:
      event,startup,53,eu
      Was passiert, wenn du in der Console
      CustomSend time~18:00
      eingibst
        Kerschte_de @Armilar last edited by
        @armilar said in SONOFF NSPanel mit Lovelace UI:
        Dann wird in der console so darauf reagiert:
        18:04:19.608 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
        18:04:25.508 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
        18:04:31.508 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
        18:04:35.939 MQT: RagowSmartHome/NSPanel_85C180/tele/STATE = {"Time":"2024-09-05T18:04:35","Uptime":"0T00:05:09","UptimeSec":309,"Heap":126,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":526,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":213},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"GlasRepThiel","BSSId":"74:42:7F:B9:EC:1B","Channel":1,"Mode":"HT20","RSSI":100,"Signal":-42,"LinkCount":1,"Downtime":"0T00:00:04"}}
        18:04:35.977 MQT: RagowSmartHome/NSPanel_85C180/tele/SENSOR = {"Time":"2024-09-05T18:04:35","ANALOG":{"Temperature1":29.3},"ESP32":{"Temperature":54.4},"TempUnit":"C"}
        18:04:37.408 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
        18:04:43.408 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
        18:04:47.058 CMD: CustomSend time~18:00
        18:04:47.069 MQT: RagowSmartHome/NSPanel_85C180/stat/RESULT = {"CustomSend":"Done"}
        18:04:49.408 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
        18:04:55.308 MQT: RagowSmartHome/NSPanel_85C180/tele/RESULT = {"CustomRecv":"event,startup,53,eu"}
          TT-Tom @Kerschte_de last edited by
          @kerschte_de
          Welche Daten kommen bei
          Mqtt-Client……Tele.Result an.
          Armilar 1 Reply Last reply Reply Quote 1
          • Armilar
            Armilar Most Active Forum Testing @TT-Tom last edited by
            @tt-tom
            Wahrscheinlich nur
            event,startup,53,eu
            Der CustomSend funktioniert nicht. Könnte man evtl. mal vom mqtt-client.0 auf den mqtt.0 umsteigen?
              @armilar genau das passiert. Die Eingabe kommt nicht an.
              • GregorS
                GregorS @TT-Tom last edited by
                @tt-tom
                Hier die Daten der beiden Datenpunkte:
                0^17:00+60+120+180+240^21:00+300+360+420+480^01:00+540+600+660+720^05:00+780+840+900+960^09:00+1020+1080+1140+1200^13:00+1260+1320+1380~0:262~21:259~62:250~103:243~144:235~185:230~226:231~267:235~309:237~391:236~473:234~597:232~679:232~802:232~843:237~885:243~967:246~1008:246~1090:249~1214:252~1337:254~1419:255
                Aber die Seite müsste doch angezeigt werden, oder?
                  @kerschte_de
                  Zeige mal bitte alle Einstellungen von der mqtt Instanz.
                    Kerschte_de @TT-Tom last edited by
                    @tt-tom
                    Ich habe den Client jedoch schon gelöscht und richte gerade den Broker/Client-Adapter als Client ein. Ziel: Instanz soll mqtt.0 werden.
                      @kerschte_de
                      Okay so läuft es bei mir auch.
                        TT-Tom @GregorS last edited by
                        @gregors
                        Du musst den Alias nochmal neu anlegen. Der Datenpunkt heißt ACTUAL, mehr nicht.
                          Kerschte_de @TT-Tom last edited by Kerschte_de
                          @tt-tom
                          Das Script habe ich nun angepasst und MQTT läuft wieder auf dem ioB.
                          javascript.0
                          2024-09-05 18:31:20.888	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false ~17299~
                          javascript.0
                          2024-09-05 18:31:20.887	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Entity ist kein String
                          javascript.0
                          2024-09-05 18:31:20.887	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false 
                          javascript.0
                          javascript.0
                          2024-09-05 18:31:20.886	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: HandleScreensaverUpdate payload: weatherUpdate~~~~65504~~29.8 °C~~~~65363~Sonne~06:24~~~~34351~Wind~6.1m/s~~~~34351~Böen~9.0m/s~~~~65535~Windr.~O~
                          javascript.0
                          2024-09-05 18:31:20.886	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: moments.js --> Datum O valid?: false
                          javascript.0
                          2024-09-05 18:31:20.866	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: moments.js --> Datum 2024-09-05T06:24:00+02:00 valid?: true
                          javascript.0
                          2024-09-05 18:31:04.386	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: renderCurrentPage
                          javascript.0
                          2024-09-05 18:31:04.151	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: HandleMessage -> sleepReached
                          javascript.0
                          2024-09-05 18:31:04.151	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false ~17299~
                          javascript.0
                          2024-09-05 18:31:04.150	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Entity ist kein String
                          javascript.0
                          2024-09-05 18:31:04.150	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false 
                          javascript.0
                          javascript.0
                          2024-09-05 18:31:04.149	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Icon1 else false ~17299~
                          javascript.0
                          2024-09-05 18:31:04.149	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: Entity ist kein String
                          javascript.0
                          javascript.0
                          javascript.0
                          2024-09-05 18:31:04.147	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: HandleScreensaverUpdate payload: weatherUpdate~~~~65504~~29.8 °C~~~~63878~Do~15° 33°~~~~65504~Fr~14° 30°~~~~38066~Sa~17° 32°~~~~65504~So~17° 32°~
                          javascript.0
                          2024-09-05 18:30:55.808	error	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: AxiosError: getaddrinfo ENOTFOUND undefined at Function.AxiosError.from (file:///opt/iobroker/node_modules/@iobroker-javascript.0/axios/lib/core/AxiosError.js:92:14) at RedirectableRequest.handleRequestError (file:///opt/iobroker/node_modules/@iobroker-javascript.0/axios/lib/adapters/http.js:620:25) at RedirectableRequest.emit (node:events:519:28) at RedirectableRequest.emit (node:domain:488:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:531:35) at ClientRequest.emit (node:domain:488:12) at emitErrorEvent (node:_http_client:108:11) at Socket.socketErrorListener (node:_http_client:511:5) at Socket.emit (node:events:519:28) at Axios.request (file:///opt/iobroker/node_modules/@iobroker-javascript.0/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'ENOTFOUND', errno: -3008, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=Status0', data: undefined }, request: <ref *1> Writable { _events: { close: undefined, error: [Function: handleRequestError], prefinish: undefined, finish: undefined, drain: undefined, response: [Function: handleResponse], socket: [Function: handleRequestSocket] }, _writableState: WritableState { highWaterMark: 16384, length: 0, corked: 0, onwrite: [Function: bound onwrite], writelen: 0, bufferedIndex: 0, pendingcb: 0, [Symbol(kState)]: 17580812, [Symbol(kBufferedValue)]: null }, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Status0', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Status0' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _eventsCount: 3, _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: true, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 0ab3228bdcbf4434805cb5f56bb6a367-b33093e5bdb0da64\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=0ab3228bdcbf4434805cb5f56bb6a367\r\n' + 'Host: undefined\r\n' + 'Connection: keep-alive\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=Status0', _ended: false, res: null, aborted: false, timeoutCb: [Function: emitRequestTimeout], upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(shapeMode)]: false, [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 16384, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=Status0', [Symbol(shapeMode)]: true, [Symbol(kCapture)]: false }, cause: Error: getaddrinfo ENOTFOUND undefined at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) { errno: -3008, code: 'ENOTFOUND', syscall: 'getaddrinfo', hostname: 'undefined' }}
                          javascript.0
                          2024-09-05 18:30:54.117	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: renderCurrentPage
                          javascript.0
                          2024-09-05 18:30:53.858	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: renderCurrentPage
                          javascript.0
                          2024-09-05 18:30:53.231	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: online tasmota firmware version => 14.2.0
                          javascript.0
                          2024-09-05 18:30:53.230	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: online tasmota firmware version => 14.2.0
                          javascript.0
                          2024-09-05 18:30:53.226	info	script.js.common.NSPanel.NSPANEL_WZ_4_4_0_1: renderCurrentPage
                          --> Das Display ist ERWACHT !!! <--
                          T 1 Reply Last reply Reply Quote 2
                            @kerschte_de
                            Na dann kann es ja weiter gehen, viel Spaß noch.
                              @tt-tom @Armilar
                              HERZLICHEN DANK an euch beide, richtig großartig. Allein ist man in dieser Sache schnell "lost". Von daher Hut ab für eure Geduld und euren Fleiß. Hut ab !
                                lustig29 @Armilar last edited by lustig29
                                @lustig29
                                Ist ganz normaler Auslieferungszustand ohne SetOption x
                                Das heißt SetOption73 und SetOption114 sind auch aus. Was Du auch in der Tasmota-Konsole eingestellt hast, mach es rückgängig und du hörst die Relais auch schalten…
                                Wie genau mache ich das rückgängig?
                                Über den userdata_Datenpunkt kann ich die Relais an und aus schalten. Per Taste am Gerät passiert aber nichts.
                                  TT-Tom @lustig29 last edited by
                                  @lustig29
                                  In dem du die Option auf 0 setzt.
                                  SetOption73 0
                                    lustig29 @TT-Tom last edited by
                                    @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                                    SetOption73 0
                                    Perfekt. Danke für die schnelle Hilfe.
                                      TT-Tom @lustig29 last edited by TT-Tom
                                      @lustig29
                                      Musst du mit allen Optionen machen, die du gesetzt hast.
                                      • GregorS
                                        Wollte es alleine versuchen, aber es klappt einfach nicht.
                                        Ich habe 3 elektrische Rolläden.
                                        Dazu wollte ich eine Seite bauen, wo der Zustand der einzelnen Rolläden dargestellt wird.
                                        Die Idee war das "blinds-horizontal" Icon zu nutzen. Daneben der Stellwert der Rollade. Dazu noch 2 Pfeile "hoch" und "runter". Das Icon sollte die Farbe wechseln, Grün bei Wert <10%, Rot >75%.
                                        Als Alias habe ich 4 Werte angelegt.
                                        // Rolläden
                                        let Rolladen: PageType =
                                            'type': 'cardEntities',
                                            'heading': 'Rolläden',
                                            'useColor': true,
                                            'subPage': false,
                                            'items': [
                                        //        <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ.ACTUAL', icon: 'window-shutter', name: 'Rolladen test', interpolateColor: true},
                                        //        <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ.CLOSE', icon: "'button1Page', name: 'runter'},
                                        //        <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ.OPEN', icon: 'button2Page', name: 'hoch'},
                                                <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ.ACTUAL', icon: 'blinds-horizontal', name: 'Büro'},
                                        Es wird nur die leere Page mit der Überschrift angezeigt.
                                          @gregors
                                          du braucht bei den Seiten nur den Channel angeben, den Rest sucht sich das Script selber.
                                          GregorS 1 Reply Last reply Reply Quote 2
                                          • GregorS
                                            GregorS @TT-Tom last edited by GregorS
                                            @tt-tom
                                            Top. Funktioniert.
                                            Wie kann ich jetzt noch die Farbe entsprechend der %ualen Rückmeldung ändern?
                                            Es wird aber nur das AZ angezeigt.
                                                'useColor': true,
                                                'subPage': false,
                                                'items': [
                                                    <PageItem>{ id: 'alias.0.NSPanel.Rolläden.AZ', name: 'Arbeitszimmer' },
                                                    <PageItem>{ id: 'alias.0.NSPanel.Rolläden.WZTüre', name: 'Wohnzimmer Türe' },
                                                    <PageItem>{ id: 'alias.0.NSPanel.Rolläden.WZFenster', name: 'Wohnzimmer Fenster' },
                                            Bei jedem Bildwechsel blinkt die Seite kurz 2 mal ???
                                            Ich suche ein Script, das hat jemand geschrieben um Temperaturwerte für ein LChart zu übertragen.
                                            Leider hab ich darin herumgemehrt und jetzt weiß ich nicht mehr was alles falsch ist und bei über 6300 Threats 😖
                                            const Debug = false;
                                            const NSPanel_Path = '0_userdata.0.NSPanel.';
                                            const Path = NSPanel_Path + 'History_Chart.Temp.';
                                            let   PathSensor = '';
                                            let SensorName = 'Temperatur AZ',
                                            let SensorName = 'Temperatur WZ',
                                            let SensorName = 'Temperatur Bad',
                                            //                  'EG.Gaeste_WC.Temperatur',
                                            //                  'EG.Wohnzimmer.Temperatur',
                                            const Sensor = [].concat('hm-rpc.1.000A9BE990C516.1.ACTUAL_TEMPERATURE')  // Temperatur Arbeitszimmer
                                            const Sensor = [].concat('hm-rpc.1.000A9BE990CFC3.1.ACTUAL_TEMPERATURE')  // Temperatur Wohnzimmer
                                            const Sensor = [].concat('hm-rpc.1.000A9BE990C35D.1.ACTUAL_TEMPERATURE')  // Temperatur Badezimmer
                                            //                 .concat('deconz.0.Sensors.12.temperature')  // EG.Gaeste_WC.Temperatur
                                            let   triggeredSensor = 0;
                                            const numberOfHoursAgo = 24;
                                            const xAxisTicksEveryM = 60;
                                            const xAxisLabelEveryM = 240;
                                            const InfluxInstance = 'influxdb.1';
                                            // Ab hier keine Ändeungen
                                            let coordinates = '';
                                            on({ id: Sensor, change: 'any' }, async function (obj) {
                                                if (Debug) console.log(obj.id);
                                                if (Debug) console.log(Sensor.indexOf(obj.id));
                                                if (Debug) console.log(SensorName[Sensor.indexOf(obj.id)])
                                                PathSensor = Path + SensorName[Sensor.indexOf(obj.id)]
                                            lovelace ui nspanel sonoff
                                            271
                                            7725
                                            6654041
