    4. Puppeteer Adapter
    Puppeteer Adapter
    • OliverIO
      OliverIO @Jensen last edited by
      @jensen
      ok, das hängt direkt an der installation von iobroker und kommt wahrscheinlich von einer deiner
      manuellen versuche puppeteer zu installieren. daher dann auch manuell deinstallieren
      was passiert wenn du jetzt
      npm uninstall puppeteer
      eingibst?
      bitte dann auch nochmal
      npm ls puppeteer ausführen
      Jensen 1 Reply Last reply Reply Quote 0
      • Jensen
        Jensen @OliverIO last edited by Jensen
        @oliverio
        c:\ioBroker>npm uninstall puppeteer
        npm error code EBUSY
        npm error syscall rename
        npm error path c:\ioBroker\node_modules\iobroker.admin
        npm error dest c:\ioBroker\node_modules\.iobroker.admin-FjHuUvU7
        npm error errno -4082
        npm error EBUSY: resource busy or locked, rename 'c:\ioBroker\node_modules\iobroker.admin' -> 'c:\ioBroker\node_modules\.iobroker.admin-FjHuUvU7'
        npm error A complete log of this run can be found in: C:\Users\IpsJensen\AppData\Local\npm-cache\_logs\2024-09-05T11_35_36_427Z-debug-0.log
        c:\ioBroker>npm ls puppeteer
        iobroker.inst@3.0.0 c:\ioBroker
        `-- iobroker.puppeteer@0.3.0
          `-- puppeteer@22.15.0
        • Jensen
          Jensen @Jensen last edited by
          @OliverIO
          mit angehaltenem ioBroker sieht's so aus
          npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
          npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
          npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
          npm warn deprecated npmlog@5.0.1: This package is no longer supported.
          npm warn deprecated npmlog@6.0.2: This package is no longer supported.
          npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
          npm warn deprecated har-validator@5.1.5: this library is no longer supported
          npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
          npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
          npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
          npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
          npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
          npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
          npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
          npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
          npm warn deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
          npm warn deprecated gauge@4.0.4: This package is no longer supported.
          npm warn deprecated gauge@3.0.2: This package is no longer supported.
          npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm warn deprecated sinon@15.2.0: 16.1.1
          changed 1360 packages, and audited 1362 packages in 1m
          170 packages are looking for funding
            run `npm fund` for details
          57 vulnerabilities (6 low, 30 moderate, 20 high, 1 critical)
          To address issues that do not require attention, run:
            npm audit fix
          To address all issues possible (including breaking changes), run:
            npm audit fix --force
          Some issues need review, and may require choosing
          a different dependency.
          Run `npm audit` for details.
          Qix- created this issue in visionmedia/debug
          closed ReDos Vulnerability Regression Visibility Notice #797
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
          • OliverIO
            @jensen
            ah ok,
            hab selbst was übersehen.
            siehst du im iobroker noch den adapter pupeteer?
            dann dort über die oberfläche den adapter entfernen.
            • Jensen
              @oliverio
              direkt aus der Adapterseite aufgerufen
              $ iobroker del puppeteer --custom --debug
              Delete adapter "puppeteer"
              host.IpsServerWB Deleting 1 object(s).
              You might have to delete it yourself!
              Process exited with code 0
              dann auf der Console
              • OliverIO
                @jensen
                ok, dann mal mit gewalt
                du gehst direkt in das hauptverzeichnis von iobroker
                auf linux /opt/iobroker
                auf windows weiß ich nicht genau, aber in diesem verzeichnis muss
                sich eine datei package.json befinden.
                in diesem verzeichnis führst du den folgenden befehl aus
                npm uninstall iobroker.puppeteer
                und dann wieder den ls befehl und im iobroker in der adapter seite schauen ob der adapter weg ist.
                wenn das auch nicht richtig funktioniert, dann gebe ich die installation als verloren auf
                und du musst neu installieren. wahrscheinlich hat sich da was verrannt, was mit den normalen mitteln nicht auflösbar ist.
                evtl weiß dann noch jemand anderes was.
                • Jensen
                  @oliverio
                  c:\ioBroker>npm uninstall iobroker.puppeteer
                  added 1 package, removed 64 packages, changed 1296 packages, and audited 1299 packages in 1m
                  165 packages are looking for funding
                    npm audit fix
                  • Jensen
                    @OliverIO
                    das ist jetzt mal neu
                    `-- (empty)
                    • OliverIO
                      OliverIO @Jensen last edited by OliverIO
                      @jensen
                      und ist er in der adapter sicht des iobrokers auch weg?
                      wenn ja, kannst ihn wieder über die adaptersicht des iobrokers wieder installieren
                      und schauen ob alles funktioniert
                      und bitte nur noch die iobroker befehle und die iobroker oberfläche verwenden.
                      npm ist für dich tabu, ausser jemand der sich auskennt sagt es ausdrücklich.
                      dann aber auch immer nur mit vorhergehendem backup
                      • Jensen
                        @oliverio
                        In der Adapteransicht wird er auch nicht mehr als installiert gelistet, sieht alles sehr gut aus.
                        Ich lasse es bis morgen ruhen, damit heute Nacht erst mal das Backup durchläuft.
                        Dann ein neuer Versuch, ohne npm 🙂
                        Danke für die Hilfe und die Geduld mit mir.
                        • Jensen
                          Jensen @Jensen last edited by Jensen
                          Wie versprochen werde ich jetzt alle Schritte dokumentieren, die ich unternehme um den Puppeteer Adapter wieder ins System zu bringen.
                          Adapter installieren
                          Eigentlich denke ich, man sollte über die Adapterseite jeden Adapter bei laufendem System installieren können. Der Versuch, den Puppeteer Adapter zu installieren gibt mir folgende Rückmeldung:
                          $ iobroker add puppeteer auto --host IpsServerWB --debug
                          NPM version: 10.8.2
                          Installing iobroker.puppeteer@0.3.0... (System call)
                          npm error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-09-06T05_46_44_817Z-debug-0.log
                          host.IpsServerWB Cannot install iobroker.puppeteer@0.3.0: 4294963214
                          ERROR: Process exited with code 25
                          Der komplette Log umfasst über 8000 Zeilen, ich hänge ihn hier als Datei ran.
                          Wenn ich mir die Log Datei anschaue, dann verstehe ich meistens nur Bahnhof, aber irgendwie beschleicht mich das Gefühl, an meinem System ist immer noch was im Argen.
                          • OliverIO
                            @jensen
                            hm, der konkrete fehler ist der
                            7083 verbose stack Error: EBUSY: resource busy or locked, rename 'C:\ioBroker\node_modules\iobroker.admin' -> 'C:\ioBroker\node_modules\.iobroker.admin-GBn0lhRQ'
                            da wird versucht das verzeichnis umzubenennen. jetzt bin ich nicht firm im detailprozess der adapter installation. umgehen kannst du das, indem du den iobroker stoppst, prüfst ob iobroker wirklich beendet ist und dann von der kommandozeile aus installierst.
                            ich hab mal noch das fix kommando hinzugefügt, das prüft deine installation ob die richtigen berechtigungen überall gesetzt sind.
                            durch deine wilden npm befehle hast du sicherlich auch mal mit sudo gearbeitet, weil linux wegen berechtigung gemeckert hat?
                            iobroker stop
                            iobroker fix
                            iobroker isrun
                            iobroker install iobroker.puppeteer
                            iobroker start
                            der adapter ist dann installiert, eine neue instanz musst du dann noch selbst von der adapterseite aus erzeugen
                            • Jensen
                              @oliverio
                              Ist ein Windows System, nix sudo.
                              Die Variante mit Anhalten des Systems habe ich ja bereits mehrmals gemacht.
                              Ich würde gerne erst mal klären, warum sich der Adapter nicht mit laufendem System installieren läßt, ich denke, das ist nicht normal.
                              Es sei denn, jemand kann erklären, warum das so ist.
                              Ein iob fix kann ich aber morgen mal machen, mal sehen, was da so passiert.
                              Und falls jemand erklären kann, ob die vielen Meldungen im npm Log so ihre Richtigkeit haben, das wäre auch eine prima Sache.
                              • OliverIO
                                @jensen
                                Im npm log wird detailliert berichtet was
                                Alles bei der Installation gemacht wird.
                                Von daher erstmal alles ok, bis auf die eine Fehlermeldung
                                Das ebusy sagt das ein Prozess aktuell in diesem Verzeichnis läuft und daher das umbenennen der Verzeichnisses nicht funktioniert.
                                Daher iobroker stoppen.
                                Das sollte normalerweise schon funktionieren.
                                Deine Installation hat wahrscheinlich schon einen hau.
                                Besser wäre es schon alles komplett neu zu installieren.
                                Die Abfolge ist um aktuell weiterzukommen
                                • Jensen
                                  @oliverio
                                  Ok, dann mal mit stoppen
                                  c:\ioBroker>npm install iobroker.puppeteer
                                  npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (github.com/visionmedia/debug/issues/797)
                                  npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See v8.dev/blog/math-random for details.
                                  npm warn deprecated request@2.88.2: request has been deprecated, see github.com/request/request/issues/3142
                                  added 64 packages, removed 2 packages, changed 1295 packages, and audited 1361 packages in 3m
                                    npm audit fix
                                  jetzt sieht das wieder so aus
                                  Bei dem Versuch, über die Adapterseite eine Instanz zu erzeugen, kommt dann das
                                  node:internal/modules/cjs/loader:1225 const err = new Error(message); ^ Error: Cannot find module 'C:\ioBroker\node_modules\deep-clone\index.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15) at Module._load (node:internal/modules/cjs/loader:1051:27) at cjsLoader (node:internal/modules/esm/translators:346:17) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:286:7) at ModuleJob.run (node:internal/modules/esm/module_job:234:25) at async ModuleLoader.import (node:internal/modules/esm/loader:473:24) { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v20.17.0
                                  ERROR: Process exited with code 1
                                  Ich glaube, das ist alles zwecklos.
                                  Eine Neuinstallation muß her.
                                  Jensen OliverIO 2 Replies Last reply Reply Quote 0
                                  • Jensen
                                    Ich habe also den Puppeteer Adapter über die Console wieder deinstalliert.
                                    Bei der Vorbereitung einer Neuinstallation wollte ich alle Scripte exportieren, da kommt dann sowas:
                                    • Jensen
                                      iob fix
                                      c:\ioBroker>iob fix
                                      Need to install the following packages:
                                      @iobroker/fix@6.0.1
                                      Ok to proceed? (y) y
                                      Windows installation starting... (fixing = true)
                                      NPM version: 10.8.3
                                      No path given, using c:\ioBroker\iobroker-data
                                      Compressing c:\ioBroker\iobroker-data\states.jsonl
                                      Cannot compress states.jsonl: Error: Failed to lock DB file "c:\ioBroker\iobroker-data\states.jsonl"!
                                          at JsonlDB.open (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@alcalzone\jsonl-db\build\lib\db.js:185:19)
                                          at async compressDB (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:37:9)
                                          at async main (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:78:17)
                                      Compressing c:\ioBroker\iobroker-data\objects.jsonl
                                      Cannot compress objects.jsonl: Error: Failed to lock DB file "c:\ioBroker\iobroker-data\objects.jsonl"!
                                          at async main (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:93:17)
                                      No relevant JSONL files found to compress, skip
                                      NPM version: 10.8.3
                                      Write "iobroker start" to start the ioBroker
                                      npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "c:/ioBroker"
                                      npm error A complete log of this run can be found in: C:\Users\IpsJensen\AppData\Local\npm-cache\_logs\2024-09-07T06_21_00_662Z-debug-0.log
                                      Error when installing dotenv Library: Error: Command failed: npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "c:/ioBroker"
                                      sieht auch nicht berauschend aus
                                      • Jensen
                                        Und was mir noch auffällt, ich habe kein admin.0, sondern nur ein admin.1
                                        Das ist doch auch nicht normal, oder?
                                        • Jensen
                                          Nach Einrichten der Istanz admin.0 und Löschen von admin.1 kann ich die Skripte jetzt wieder problemlos exportieren.
                                          • OliverIO
                                            @jensen
                                            Schon seltsam.
                                            Er meckert das ein bestimmtes Modul nicht gefunden worden ist.
                                            Neuinstallation macht Sinn. Es sind Zuviel kleinklein Probleme
                                            Und ob das dann später noch stabil läuft ist auch keine Garantie.
                                            Was für Hardware und Festplatte hast du im Einsatz?
                                            3989
