    4. Adapter Update nicht möglich
    • Codierknecht
      Codierknecht Developer Most Active @martin last edited by
      @martin
      Wer kann mir da weiter helfen?
      Zeig erstmal, wie Du da aufgestellt bist. Die Langfassung von
      iob diag
        Thomas Braun Most Active @martin last edited by
        @martin
        Jag den Fixer drüber.
        iob stop
        iob fix
        iob start
          martin @Codierknecht last edited by Homoran
          @codierknecht
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: ioBroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
          Operating System: Ubuntu 23.04
                    Kernel: Linux 6.2.16-3-pve
              Architecture: x86-64
          Firmware Version: 5.27
          model name      : Intel(R) N95
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           11:52:38 up  1:29,  2 users,  load average: 0.20, 0.24, 0.21
          CPU threads: 2
          *** Time and Time Zones ***
                         Local time: Fri 2024-09-06 11:52:38 CEST
                     Universal time: Fri 2024-09-06 09:52:38 UTC
                           RTC time: n/a
                        NTP service: n/a
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            5.4G        3.5G        1.2G        135K        639M        1.9G
          Swap:           2.1G          0B        2.1G
          Total:          7.5G        3.5G        3.4G
          Active iob-Instances:   43
                   5120 M total memory
                   3355 M used memory
                    284 M active memory
                   3478 M inactive memory
                   1154 M free memory
                      0 M buffer memory
                    609 M swap cache
                   2048 M total swap
                      0 M used swap
                   2048 M free swap
          top - 11:52:38 up  1:29,  2 users,  load average: 0.20, 0.24, 0.21
          Tasks:  74 total,   1 running,  73 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   5120.0 total,   1152.9 free,   3357.1 used,    610.0 buff/cache
          MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1762.9 avail Mem
          *** FAILED SERVICES ***
            UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
          * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          2 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                       Type   Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--101--disk--0 ext4    24G  8.0G   15G  36% /
          none                             tmpfs  492K  4.0K  488K   1% /dev
          tmpfs                            tmpfs  7.7G     0  7.7G   0% /dev/shm
          tmpfs                            tmpfs  3.1G  128K  3.1G   1% /run
          tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
          dmesg: read kernel buffer failed: Operation not permitted
          Show mounted filesystems:
          TARGET                                                  SOURCE                           FSTYPE      OPTIONS
          /                                                       /dev/mapper/pve-vm--101--disk--0 ext4        rw,relatime,stripe=16
          |-/run                                                  tmpfs                            tmpfs       rw,nosuid,nodev,size=3214852k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
          | |-/run/lock                                           tmpfs                            tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
          | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          |-/dev                                                  none                             tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
          | |-/dev/shm                                            tmpfs                            tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
          | |-/dev/mqueue                                         mqueue                           mqueue      rw,relatime
          | |-/dev/ttyUSB0                                        udev[/ttyUSB0]                   devtmpfs    rw,nosuid,relatime,size=8002608k,nr_inodes=2000652,mode=755,inode64
          | |-/dev/.lxc/proc                                      proc                             proc        rw,relatime
          | |-/dev/.lxc/sys                                       sys                              sysfs       rw,relatime
          | |-/dev/full                                           udev[/full]                      devtmpfs    rw,nosuid,relatime,size=8002608k,nr_inodes=2000652,mode=755,inode64
          | |-/dev/null                                           udev[/null]                      devtmpfs    rw,nosuid,relatime,size=8002608k,nr_inodes=2000652,mode=755,inode64
          | |-/dev/random                                         udev[/random]                    devtmpfs    rw,nosuid,relatime,size=8002608k,nr_inodes=2000652,mode=755,inode64
          | |-/dev/tty                                            udev[/tty]                       devtmpfs    rw,nosuid,relatime,size=8002608k,nr_inodes=2000652,mode=755,inode64
          | |-/dev/urandom                                        udev[/urandom]                   devtmpfs    rw,nosuid,relatime,size=8002608k,nr_inodes=2000652,mode=755,inode64
          | |-/dev/zero                                           udev[/zero]                      devtmpfs    rw,nosuid,relatime,size=8002608k,nr_inodes=2000652,mode=755,inode64
          | |-/dev/pts                                            devpts                           devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/ptmx                                           devpts[/ptmx]                    devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/console                                        devpts[/0]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/tty1                                           devpts[/1]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | `-/dev/tty2                                           devpts[/2]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          |-/proc                                                 proc                             proc        rw,nosuid,nodev,noexec,relatime
          | |-/proc/sys                                           proc[/sys]                       proc        ro,relatime
          | | |-/proc/sys/net                                     proc[/sys/net]                   proc        rw,nosuid,nodev,noexec,relatime
          | | |-/proc/sys/fs/binfmt_misc                          binfmt_misc                      binfmt_misc rw,nosuid,nodev,noexec,relatime
          | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
          | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc        ro,relatime
          | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          `-/sys                                                  sysfs                            sysfs       ro,nosuid,nodev,noexec,relatime
            |-/sys/fs/fuse/connections                            fusectl                          fusectl     rw,nosuid,nodev,noexec,relatime
            |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs       rw,nosuid,nodev,noexec,relatime
            |-/sys/kernel/debug                                   debugfs                          debugfs     rw,nosuid,nodev,noexec,relatime
            |-/sys/kernel/security                                securityfs                       securityfs  rw,nosuid,nodev,noexec,relatime
            |-/sys/fs/pstore                                      pstore                           pstore      rw,nosuid,nodev,noexec,relatime
            |-/sys/firmware/efi/efivars                           efivarfs                         efivarfs    rw,nosuid,nodev,noexec,relatime
            |-/sys/fs/cgroup                                      none                             cgroup2     rw,nosuid,nodev,noexec,relatime
            `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          2.2G    /var/
          1.5G    /var/log
          1.3G    /var/log/journal/2ca175e2ab56499d842db8554cdadcec
          479M    /var/cache
          Archived and active journals take up 1.2G in the file system.
          /opt/iobroker/backups:
          150M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          774M    /opt/iobroker/iobroker-data/files
          352M    /opt/iobroker/iobroker-data/files/javascript.admin
          326M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          325M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          34M     /opt/iobroker/iobroker-data/objects.jsonl
          31M     /opt/iobroker/iobroker-data/states.jsonl
          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
          27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6cf67273a545ed119760c68f0a86e0b4-if00-port0
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyUSB0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.4
          /usr/bin/node           v18.20.4
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.0
          nodejs:
            Installed: 18.20.4-1nodesource1
            Candidate: 18.20.4-1nodesource1
            Version table:
           *** 18.20.4-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.3-1nodesource1 500
               18.20.2-1nodesource1 500
               18.20.1-1nodesource1 500
               18.20.0-1nodesource1 500
               18.19.1-1nodesource1 500
               18.19.0-1nodesource1 500
               18.18.2-1nodesource1 500
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0+dfsg1-1ubuntu2 500
                  500 http://archive.ubuntu.com/ubuntu lunar/universe amd64 Packages
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
          Temp directories causing npm8 problem: 1
          Some problems detected, please run iob fix
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.9
          admin:          7.0.22
          javascript:     8.7.6
          nodejs modules from github:     5
          +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#d9348a97d2b8511c3d13a258b6c232270614a89d)
          +-- iobroker.blockly-plus@0.0.1 (git+ssh://git@github.com/excal-foley/ioBroker.blockly-plus.git#8487239d69fc53c13853013110da15b42bc487e9)
          +-- iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a780906787264e3)
          +-- iobroker.sunnyportal@0.1.5 (git+ssh://git@github.com/marvincaspar/ioBroker.sunnyportal.git#0eeecbfa57a6366daf4f6070e7ab27885af3c3c8)
          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          + system.adapter.asterisk.0               : asterisk              : ioBroker                                 -  enabled, port: 5038
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
            system.adapter.blockly-plus.0           : blockly-plus          : ioBroker                                 - disabled
          + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
            system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
          + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          + system.adapter.divera247.0              : divera247             : ioBroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
          + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
            system.adapter.firetv.0                 : firetv                : ioBroker                                 - disabled
          + system.adapter.fritzbox.0               : fritzbox              : ioBroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
          + system.adapter.fritzdect.1              : fritzdect             : ioBroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
          + system.adapter.homepilot20.0            : homepilot20           : ioBroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
            system.adapter.ical.1                   : ical                  : ioBroker                                 - disabled
            system.adapter.ical.2                   : ical                  : ioBroker                                 - disabled
            system.adapter.ical.3                   : ical                  : ioBroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          + system.adapter.mercedesme.0             : mercedesme            : ioBroker                                 -  enabled
          + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
          + system.adapter.mihome.0                 : mihome                : ioBroker                                 -  enabled, port: 9898, bind: 0.0.0.0
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
          + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
            system.adapter.octoprint.2              : octoprint             : ioBroker                                 - disabled
          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
            system.adapter.proxmox.0                : proxmox               : ioBroker                                 - disabled, port: 8006
            system.adapter.reolink.0                : reolink               : ioBroker                                 - disabled
            system.adapter.reolink.1                : reolink               : ioBroker                                 - disabled
            system.adapter.reolink.2                : reolink               : ioBroker                                 - disabled
            system.adapter.reolink.3                : reolink               : ioBroker                                 - disabled
            system.adapter.rssfeed.1                : rssfeed               : ioBroker                                 - disabled
          + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
          + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
          + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1888, bind: 0.0.0.0
            system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 - disabled
            system.adapter.sunnyportal.0            : sunnyportal           : ioBroker                                 - disabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.terminal.0               : terminal              : ioBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          + system.adapter.trashschedule.1          : trashschedule         : ioBroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          │ (index) │   name   │                           url                           │ auto upgrade │
          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
          Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
          Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
          Adapter    "cameras"      : 2.1.2    , installed 2.0.5  [Updatable]
          Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "divera247"    : 0.2.0    , installed 0.2.0
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "firetv"       : 2.1.0    , installed 2.1.0
          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
          Adapter    "fullybrowser" : 3.0.12   , installed 2.2.0  [Updatable]
          Adapter    "homepilot"    : 1.2.3    , installed 1.2.3
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.11   , installed 6.0.9  [Updatable]
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "nina"         : 0.0.25   , installed 0.0.25
          Adapter    "node-red"     : 5.2.1    , installed 4.0.3  [Updatable]
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
          Adapter    "reolink"      : 1.1.1    , installed 1.1.0  [Updatable]
          Adapter    "rssfeed"      : 3.1.0    , installed 2.9.7  [Updatable]
          Adapter    "scenes"       : 3.2.1    , installed 2.3.9  [Updatable]
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
          Adapter    "snmp"         : 3.2.0    , installed 3.2.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
          Adapter    "synology"     : 3.1.0    , installed 3.1.0
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "telegram"     : 3.9.0    , installed 3.3.2  [Updatable]
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        24736
          States:         25746
          Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:2 http://archive.ubuntu.com/ubuntu lunar InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu lunar-updates InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu lunar-security InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1000       308119     1180/io.sonoff.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       307842     1116/io.mqtt.1
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       307989     1150/io.shelly.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       304713     704/node-red
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       308678     1101/io.mqtt.0
          tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        293629     108/systemd-resolve
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          293285     1/init
          tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      111        305032     745/asterisk
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          305874     917/master
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       305351     589/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       305358     589/iobroker.js-con
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        293627     108/systemd-resolve
          tcp6       0      0 :::1235                 :::*                    LISTEN      1000       305624     704/node-red
          tcp6       0      0 :::1238                 :::*                    LISTEN      1000       305630     704/node-red
          tcp6       0      0 :::1237                 :::*                    LISTEN      1000       305628     704/node-red
          tcp6       0      0 :::1236                 :::*                    LISTEN      1000       305626     704/node-red
          tcp6       0      0 :::9275                 :::*                    LISTEN      1000       305646     704/node-red
          tcp6       0      0 :::1106                 :::*                    LISTEN      1000       305650     704/node-red
          tcp6       0      0 :::9876                 :::*                    LISTEN      1000       305632     704/node-red
          tcp6       0      0 :::1579                 :::*                    LISTEN      1000       305666     704/node-red
          tcp6       0      0 :::1555                 :::*                    LISTEN      1000       305648     704/node-red
          tcp6       0      0 :::22                   :::*                    LISTEN      0          298333     1/init
          tcp6       0      0 :::21                   :::*                    LISTEN      0          298410     127/vsftpd
          tcp6       0      0 :::111                  :::*                    LISTEN      0          293287     1/init
          tcp6       0      0 :::1010                 :::*                    LISTEN      1000       305662     704/node-red
          tcp6       0      0 :::1009                 :::*                    LISTEN      1000       305660     704/node-red
          tcp6       0      0 :::1003                 :::*                    LISTEN      1000       305640     704/node-red
          tcp6       0      0 :::1002                 :::*                    LISTEN      1000       305638     704/node-red
          tcp6       0      0 :::1001                 :::*                    LISTEN      1000       305636     704/node-red
          tcp6       0      0 :::1000                 :::*                    LISTEN      1000       305634     704/node-red
          tcp6       0      0 :::1005                 :::*                    LISTEN      1000       305642     704/node-red
          tcp6       0      0 :::1004                 :::*                    LISTEN      1000       305644     704/node-red
          tcp6       0      0 :::11666                :::*                    LISTEN      1000       305658     704/node-red
          tcp6       0      0 :::10769                :::*                    LISTEN      1000       305670     704/node-red
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          305875     917/master
          tcp6       0      0 :::37003                :::*                    LISTEN      1000       305654     704/node-red
          tcp6       0      0 :::7531                 :::*                    LISTEN      1000       305664     704/node-red
          tcp6       0      0 :::7532                 :::*                    LISTEN      1000       305668     704/node-red
          tcp6       0      0 :::7774                 :::*                    LISTEN      1000       305656     704/node-red
          tcp6       0      0 :::7773                 :::*                    LISTEN      1000       305652     704/node-red
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       316045     1570/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       327697     1653/io.admin.0
          tcp6       0      0 :::8088                 :::*                    LISTEN      1000       314821     1476/io.terminal.0
          tcp6       0      0 :::8000                 :::*                    LISTEN      1000       317477     1540/io.upnp.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       315366     1540/io.upnp.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       305671     704/node-red
          udp        0      0 0.0.0.0:51996           0.0.0.0:*                           1000       308312     1026/io.broadlink2.
          udp        0      0 0.0.0.0:35757           0.0.0.0:*                           1000       315138     1540/io.upnp.0
          udp        0      0 0.0.0.0:4569            0.0.0.0:*                           111        306002     745/asterisk
          udp        0      0 0.0.0.0:5060            0.0.0.0:*                           111        305049     745/asterisk
          udp        0      0 192.168.177.44:5353     0.0.0.0:*                           1000       310358     1195/io.tr-064.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       310454     1210/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       310455     1210/io.tuya.0
          udp        0      0 0.0.0.0:47757           0.0.0.0:*                           1000       308313     1026/io.broadlink2.
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       308303     1026/io.broadlink2.
          udp        0      0 0.0.0.0:39764           0.0.0.0:*                           1000       309049     1165/io.snmp.0
          udp        0      0 0.0.0.0:39783           0.0.0.0:*                           1000       308310     1026/io.broadlink2.
          udp        0      0 0.0.0.0:40346           0.0.0.0:*                           1000       466583     1026/io.broadlink2.
          udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        293628     108/systemd-resolve
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        293626     108/systemd-resolve
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          293286     1/init
          udp        0      0 192.168.177.44:123      0.0.0.0:*                           0          293752     134/ntpd
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          293750     134/ntpd
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          293746     134/ntpd
          udp        0      0 0.0.0.0:41323           0.0.0.0:*                           1000       308311     1026/io.broadlink2.
          udp        0      0 0.0.0.0:33576           0.0.0.0:*                           111        305043     745/asterisk
          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1000       307697     1086/io.mihome.0
          udp6       0      0 :::39868                :::*                                111        305044     745/asterisk
          udp6       0      0 :::111                  :::*                                0          293288     1/init
          udp6       0      0 fe80::bcb8:2eff:fe9:123 :::*                                110        299067     134/ntpd
          udp6       0      0 ::1:123                 :::*                                0          293754     134/ntpd
          udp6       0      0 :::123                  :::*                                0          293743     134/ntpd
          2024-09-06 11:52:49.004  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.3 {"val":true,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1712152168042}
          2024-09-06 11:52:49.004  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.7 {"val":true,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1700661946992}
          2024-09-06 11:52:49.004  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.9 {"val":0,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1694674001124}
          2024-09-06 11:52:49.004  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.10 {"val":0,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1694674001397}
          2024-09-06 11:52:49.004  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.11 {"val":0,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1694674001420}
          2024-09-06 11:52:49.004  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.15 {"val":0,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1694674001499}
          2024-09-06 11:52:49.004  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.17 {"val":0,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1725592963123}
          2024-09-06 11:52:49.004  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.18 {"val":0,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1725616068101}
          2024-09-06 11:52:49.005  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.19 {"val":0,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1725616068101}
          2024-09-06 11:52:49.005  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.20 {"val":227.7,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1725616308794}
          2024-09-06 11:52:49.005  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.26 {"val":0,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1694674001937}
          2024-09-06 11:52:49.005  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.26-0 {"val":false,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1694674001954}
          2024-09-06 11:52:49.006  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.101 {"val":false,"ack":true,"ts":1725616368958,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1694674002008}
          2024-09-06 11:52:49.006  - debug: tuya.0 (1210) stateChange tuya.0.684745503ce90ee9dd80.102 {"val":false,"ack":true,"ts":1725616368959,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1694674002067}
          2024-09-06 11:52:49.006  - debug: tuya.0 (1210) stateChange tuya.0.711315732462ab419b76.1 {"val":false,"ack":true,"ts":1725616368959,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1600796445943}
          2024-09-06 11:52:49.006  - debug: tuya.0 (1210) stateChange tuya.0.711315732462ab419b76.2 {"val":0,"ack":true,"ts":1725616368959,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1600796445943}
          2024-09-06 11:52:49.007  - debug: tuya.0 (1210) stateChange tuya.0.711315732462ab419b76.3 {"val":0,"ack":true,"ts":1725616368959,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1600796445943}
          2024-09-06 11:52:49.007  - debug: tuya.0 (1210) stateChange tuya.0.711315732462ab419b76.4 {"val":0,"ack":true,"ts":1725616368959,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1600796445943}
          2024-09-06 11:52:49.007  - debug: tuya.0 (1210) stateChange tuya.0.711315732462ab419b76.5 {"val":0,"ack":true,"ts":1725616368959,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1600796445943}
          2024-09-06 11:52:49.008  - debug: tuya.0 (1210) stateChange tuya.0.711315732462ab419b76.6 {"val":0,"ack":true,"ts":1725616368959,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1600796445943}
          2024-09-06 11:52:49.008  - debug: tuya.0 (1210) stateChange tuya.0.711315732462ab419b76.7 {"val":false,"ack":true,"ts":1725616368959,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1600796445943}
          2024-09-06 11:52:52.281  - error: bambulab.0 (1262) Connection issue occurred Error: connect EHOSTUNREACH 192.168.179.116:8883
          2024-09-06 11:52:52.281  - warn: bambulab.0 (1262) Connection to Printer closed
          2024-09-06 11:52:53.254  - debug: tuya.0 (1210) 38325110cc50e3d44d56: Received data: {"devId":"38325110cc50e3d44d56","dps":{"6":2345},"t":1725616373,"s":3133312}
          2024-09-06 11:52:53.257  - debug: tuya.0 (1210) stateChange tuya.0.38325110cc50e3d44d56.6 {"val":234.5,"ack":true,"ts":1725616373256,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1725616373256}
            martin @Thomas Braun last edited by
               Welcome to the ioBroker installation fixer!
                Script version: 2024-01-04
                Installing prerequisites (1/5)
            Hit:1 http://archive.ubuntu.com/ubuntu lunar InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu lunar-updates InRelease
            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists... Done
                Checking ioBroker user and directory permissions (2/5)
            Created /etc/sudoers.d/iobroker
            Fixing directory permissions...
                Check and cleanup npm temporary directories (3/5)
            Done.
                Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
              Danke für eure schnelle Hilfe.
              Der iob fix hat geholfen, die Adapter lassen sich jetzt wieder updaten.
                @martin
                Dein OS Ubuntu 23.04 'Lunar Lobster
                ist abgekündigt und muss durch eine noch lebende Version ersetzt werden.
                Entweder durch die aktuelle LTS-Version 24.04 oder (meine Empfehlung) durch das Original: Debian 12
                • BananaJoe
                  BananaJoe Most Active @martin last edited by
                  @martin wie @Thomas-Braun schon gesehen hat: Wenn Ubuntu (gilt aber auch für alle anderen Linux-Distributionen) dann solltest du immer eine LTS-Version nehmen.
                  alle geraden Versionsnummern wie 20.04, 22.04, 24.04 sind Langzeitversionen mit mehreren Jahren Support / Updates.
                  Alle Ungraden Versionen wie 21.xx, 23.xx sind eher Testversionen die nur wenige Monate Support / Updates haben.
                  • Codierknecht
                    @martin
                    Man fummelt da nicht als root rum.
                    root
                      martin @Thomas Braun last edited by martin
                      Danke. Wie kriege ich das denn hin, dass ich auf die 24.04. updaten kann? Habe von Linux so gut wie gar keine Ahnung.
                      Thomas Braun BananaJoe 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @martin last edited by Thomas Braun
                        @martin
                        Von 23.04 aus musst du jede nachfolgende Version installieren, um dann auf 24.04 zu landen.
                        Im Moment ist das aber bei Ubuntu wohl auch irgendwie 'kaputt' (Das S in Ubuntu steht für Stabilität...)
                        Ich würde da gleich Debian 12 neuinstallieren.
                        Ist doch ein Container-Zeuch, also ein Wegwerf-Artikel. Wird Schnubbibuntu halt weg. Und zwar weit.
                          Okay, und dann muss ich unter Debian 12 den kompletten iobroker neu aufsetzen?
                            @martin sagte in Adapter Update nicht möglich:
                            Du kennst den 'Backitup'-Adapter?
                              Ja, den habe ich auch laufen. Nur irgendwie kam da bei bisherigen Umzügen nicht alles mit.
                                Was fehlte denn?
                                Eigentlich nimmt der doch schon alles mögliche mit, wenn der richtig eingerichtet ist.
                                  martin last edited by martin
                                  Was genau gefehlt hat kann ich dir nicht mehr sagen, aber ich musste immer einiges nacharbeiten.
                                  Gibt es evtl. einen Ordner den man komplett kopieren und auf dem neuen Debian einfügen kann?
                                  Thomas Braun da_Woody 2 Replies Last reply Reply Quote 0
                                    Genau das MACHT doch der Backitup-Adapter (und noch etwas mehr, was du beim grobschlächtigen 'einfach drüberklatschen' garantiert nicht machst).
                                    • da_Woody
                                      da_Woody @martin last edited by
                                      @martin das problem ist halt, wenn du im backup sauerei hast, nimmst du die mit.
                                      keine ahnung wie aufwändig deine insatll ist. komplett neu mit debian und gut ist.
                                      • BananaJoe
                                        Auf 23.10: https://www.renefuerst.eu/einfaches-upgrade-von-ubuntu-23-04-auf-ubuntu-23-10/
                                        Danach geht es genauso auf die 24.04. die kann ggf. noch etwas dauern-
                                        Der Upgrader dazu ist gerade noch in der Testphase, in bestimmten Konstellationen gibt es ggf. Probleme.
                                        Vorher ein Backup ist Pflicht
                                          Thomas Braun Most Active @BananaJoe last edited by
                                          @bananajoe
                                          Setzt aber voraus, das 23.04 sowie 23.10 noch auf den Servern vorhanden ist. Ubuntu räumt diese Interimsversionen üblicherweise immer recht zügig ab und du schaust an der Stelle ins Leere.
                                            @thomas-braun Ich habe jetzt mal Debian12 installiert und per Backitup alles wiederhergestellt.
                                            Scheint auch alles zu laufen, bis auf Zigbee. Muss ich da das Dongle wieder neu installieren??
                                            adapter problem adapter update error fehler update
                                            828
