    4. iob diag - Skript
    iob diag - Skript
      Thomas Braun Most Active @Feuersturm last edited by
      @feuersturm
      In der Summary gleichlautend?
      Ich hab da noch einen Knoten drin, scheint mir.
      • Feuersturm
        Feuersturm @Thomas Braun last edited by
        @thomas-braun Sieht gut aus bei mir:
        Skript v.2024-08-18
        *** BASE SYSTEM ***
         Static hostname: ioB-Prod-Testsystem
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 6.5.13-1-pve
            Architecture: x86-64
        OS is similar to: debian
        model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         21:22:28 up 15 days,  7:24,  1 user,  load average: 1.95, 2.04, 2.25
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
        und Summary
                                v.2024-08-18
                 Chassis: container
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1001
        Display-Server:         false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    2
        Nodejs-Installation:
        /usr/bin/nodejs         v20.16.0
        /usr/bin/node           v20.16.0
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.2
        Recommended versions are nodejs 20.16.0 and npm 10.8.1
        MEMORY:
        Mem:            8.0G        2.2G        4.8G        0.0K        1.0G        5.8G
        Swap:           2.0G        1.1G        976M
        Total:           10G        3.3G        5.8G
        Active iob-Instances:   31
        Upgrade policy: none
        ioBroker Core:          js-controller           6.0.10
                                admin                   7.0.23
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : ioB-Prod-Testsystem                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8082, bind: 192.168.178.105, run as: admin
        + system.adapter.web.1                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
        Objects:                14532
        States:                 12032
        Size of iob-Database:
        27M     /opt/iobroker/iobroker-data/objects.jsonl
        17M     /opt/iobroker/iobroker-data/objects.json.migrated
        17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
        1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
        19M     /opt/iobroker/iobroker-data/states.jsonl
        6.3M    /opt/iobroker/iobroker-data/states.json.migrated
        6.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
          Homoran Global Moderator Administrators @Feuersturm last edited by
          @feuersturm rein aus Neugier
          welche Farbe hat die Zeile?
            @feuersturm
            Danke. Bei 'testing releases' wird da warum auch immer was unterschiedliches angezeigt. Und ich verstehe gerade nicht warum...
            • Feuersturm
              Feuersturm @Homoran last edited by
              @homoran sagte in iob diag - Skript:
              Bei der Langfassung und Summary ist die Information Gelb,
                @feuersturm sagte in iob diag - Skript:
                So soll es sein. Stabile Releases wären Grün, abgekündigte wären Rot.
                Nashra Negalein 2 Replies Last reply Reply Quote 0
                • Nashra
                  Nashra Most Active Forum Testing @Thomas Braun last edited by
                  Moin, hier mit LXC
                                          v.2024-08-18_5
                   Static hostname: ioBroker
                           Chassis: container ☐
                    Virtualization: lxc
                            Kernel: Linux 6.8.12-1-pve
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               64 bit
                  User-ID:                1000
                  /usr/bin/npm            10.8.1
                  /usr/bin/npx            10.8.1
                  MEMORY:
                  Mem:             12G        4.1G        7.9G        122K        873M        8.7G
                  Swap:             0B          0B          0B
                  Total:           12G        4.1G        7.9G
                  Active iob-Instances:   45
                  ioBroker Core:          js-controller           6.0.9
                                          admin                   7.0.22
                  Objects type: jsonl
                  States  type: jsonl
                  + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                  Objects:                54190
                  States:                 50980
                  86M     /opt/iobroker/iobroker-data/objects.jsonl
                  88M     /opt/iobroker/iobroker-data/states.jsonl
                  Your Operating System is the current Debian stable version 'bookworm'!
                  • Negalein
                    Negalein Global Moderator @Thomas Braun last edited by
                    hier ein LXC
                                            v.2024-08-18_5
                             Chassis: container
                      Virtualization: lxc
                              Kernel: Linux 5.15.30-2-pve
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               64 bit
                    Timezone:               Europe/Vienna (CEST, +0200)
                    User-ID:                1001
                    Pending OS-Updates:     31
                    Pending iob updates:    4
                    /usr/bin/nodejs         v20.15.0
                    /usr/bin/node           v20.15.0
                    /usr/bin/npm            10.7.0
                    /usr/bin/npx            10.7.0
                    /usr/bin/corepack       0.28.1
                    MEMORY:
                    Mem:             10G        4.8G        4.4G        0.0K        865M        5.3G
                    Swap:           3.1G        1.1G        2.0G
                    Total:           13G        5.8G        6.4G
                    Active iob-Instances:   60
                    Active repo(s): Beta (latest)
                    ioBroker Core:          js-controller           5.0.19
                                            admin                   7.0.24
                    Objects type: jsonl
                    States  type: jsonl
                    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects:                32233
                    States:                 31404
                    53M     /opt/iobroker/iobroker-data/objects.jsonl
                    29M     /opt/iobroker/iobroker-data/objects.json.migrated
                    29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                    0       /opt/iobroker/iobroker-data/objects.json.broken
                    54M     /opt/iobroker/iobroker-data/states.jsonl
                    9.4M    /opt/iobroker/iobroker-data/states.json.migrated
                    9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                    Your Operating System jammy is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                      Shadowhunter23 last edited by
                      Vielleicht noch ein Hinweis, ich habe 4 zigbee Adapter und keinen USB Stick. Angezeigt wird nur bis Adapter .2
                      Die Koordinatoren sind alle per Netzwerk eingebunden. Ob du das abfragen kann das kein USB Stick angeschlossen ist weiß ich nicht.
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      HINT:
                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                      tcp
                      HINT:
                      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                      tcp
                      HINT:
                      Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                      tcp
                        Thomas Braun Most Active @Shadowhunter23 last edited by
                        @shadowhunter23
                        Ich war davon ausgeganen, das 3 zigbee-Instanzen ausreichend sein sollten.
                        Ich würde da auch eher per Router ein Zigbee-Netz draus weben, an deiner Stelle.
                        Und ich vergleiche auch nur die EInträge von 'by-id' mit den Ports aus dem Adapter.
                        Ob die Einstellungen dann die richtigen sind musst du selber prüfen.
                        Ist ja auch nur ein Hinweis.
                        Kurz: Won't fix.
                          Shadowhunter23 @Thomas Braun last edited by Shadowhunter23
                          Auch hier, Won't fix 🙂 . Das ist schon mit Absicht so gemacht.
                          Kurz: Won't fix.
                          OK, war ja auch nur ein Hinweis.
                            Thomas Braun Most Active @Shadowhunter23 last edited by Thomas Braun
                            Da ich das Skript in den letzten Tagen um einige Funktionen (Anlage eines users, wenn es als root oder 'iobroker' aufgerufen wird; setzen der Zeitzone, wenn eine vermutlich falsche (wie Europe/London oder UTC) erkannt wird) und kritische Fehler im Kernel Ring Puffer (dmesg) jetzt gemeldet werden würde ich gerne ein paar Läufe auf anderen Systemen als meinen Testkisten sehen. Insbesondere LXC und Docker ist da interessant für mich.
                            Es gibt auch ein paar Meldungen auf deutsch, wenn das Skript mit der Option '--de' aufgerufen wird. Auch dazu wäre Feedback willkommen. Gleich vorweg: Es kann keine vollständige Übersetzung geben, da einige Kommandos nur englische Ausgaben liefern.
                            Bitte diese Beta-Version wie im ersten Beitrag gezeigt lokal ausführen, im ioBroker selber ist diese Version v.2024-09-07 natürlich noch nicht implementiert.
                            Meister Mopper 1 Reply Last reply Reply Quote 1
                              TT-Tom last edited by TT-Tom
                              Hallo Thomas,
                              habe das Script aus dem Standartuser Ordner Tom gestartet. Musste zwischen durch das Password für sudo eingeben. System LXC-Container mit einem Testsystem auf Beta-Repro.
                              Script v.2024-09-07
                              *** BASE SYSTEM ***
                               Static hostname: iobtest
                                Virtualization: lxc
                              OS is similar to:
                              model name	: Intel(R) N100
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               14:11:14 up 24 days, 36 min,  1 user,  load average: 0.06, 0.08, 0.01
                              CPU threads: 4
                              Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                              *** TIME AND TIMEZONES ***
                                             Local time: Sun 2024-09-08 14:11:14 CEST
                                         Universal time: Sun 2024-09-08 12:11:14 UTC
                                               RTC time: n/a
                                            NTP service: inactive
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              tom
                              HOME=/home/tom
                              GROUPS=tom sudo users iobroker
                              iobroker
                              [sudo] password for tom:
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev
                              *** DISPLAY-SERVER SETUP ***
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Mem:            8.4G        1.6G        5.2G        131K        1.6G        6.8G
                              Swap:           536M          0B        536M
                              Total:          8.9G        1.6G        5.7G
                              Active iob-Instances: 	10
                                       8000 M total memory
                                       1507 M used memory
                                       1442 M active memory
                                       1464 M inactive memory
                                       4944 M free memory
                                          0 M buffer memory
                                       1547 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        512 M free swap
                              top - 14:11:34 up 24 days, 36 min,  1 user,  load average: 0.05, 0.07, 0.01
                              Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8000.0 total,   4944.3 free,   1508.0 used,   1547.8 buff/cache
                              MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6492.0 avail Mem
                              *** FAILED SERVICES ***
                                UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                              * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                              * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                              LOAD   = Reflects whether the unit definition was properly loaded.
                              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                              SUB    = The low-level unit activation state, values depend on unit type.
                              2 loaded units listed.
                              *** DMESG CRITICAL ERRORS ***
                              dmesg: read kernel buffer failed: Operation not permitted
                              No critical errors detected
                              *** FILESYSTEM ***
                              Filesystem                       Type      Size  Used Avail Use% Mounted on
                              /dev/mapper/pve-vm--101--disk--0 ext4       63G  6.0G   54G  10% /
                              none                             tmpfs     492K  4.0K  488K   1% /dev
                              udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                              tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                              tmpfs                            tmpfs     3.1G  124K  3.1G   1% /run
                              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                              Show mounted filesystems:
                              TARGET SOURCE                           FSTYPE OPTIONS
                              /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                              /var:
                              463M	/var/
                              250M	/var/cache
                              246M	/var/cache/apt
                              170M	/var/cache/apt/archives
                              154M	/var/lib
                              Archived and active journals take up 16.4M in the file system.
                              /opt/iobroker/backups:
                              46M	/opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              767M	/opt/iobroker/iobroker-data/
                              645M	/opt/iobroker/iobroker-data/files
                              493M	/opt/iobroker/iobroker-data/files/javascript.admin
                              461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                              460M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                              35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                              30M	/opt/iobroker/iobroker-data/objects.jsonl
                              19M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
                              14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                              8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                              USB-Devices by-id:
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs 	v20.17.0
                              /usr/bin/node 		v20.17.0
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              /usr/bin/corepack 	0.29.3
                              nodejs:
                                Installed: 20.17.0-1nodesource1
                                Candidate: 20.17.0-1nodesource1
                                Version table:
                               *** 20.17.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                                   18.19.0+dfsg-6~deb12u2 500
                                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                   18.19.0+dfsg-6~deb12u1 500
                                      500 http://security.debian.org bookworm-security/main amd64 Packages
                              No problems detected
                              Errors in npm tree: 0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310623)
                              Core adapters versions
                              js-controller: 	6.0.11
                              admin: 		7.1.0
                              javascript: 	8.8.2
                              nodejs modules from github: 	2
                              +-- iobroker.iosapp@1.0.3 (git+ssh://git@github.com/tt-tom17/ioBroker.iosapp.git#57aa9615040d4d80b735ca0fb4beddc5aee69c9d)
                              +-- iobroker.nspanel-lovelace-ui@0.0.4-preAlpha.3 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#eaa0acd87ee8a90d72fee56e8fc3531ee62a94e4)
                              Adapter State
                                system.adapter.accuweather.0            : accuweather           : iobtest                                  - disabled
                              + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                              + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                                system.adapter.devices.0                : devices               : iobtest                                  - disabled
                              + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                                system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                              + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                              + system.adapter.iosapp.0                 : iosapp                : iobtest                                  -  enabled
                              + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                              + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                                system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                                system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  - disabled
                                system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                              + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
                                system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                                system.adapter.web.0                    : web                   : iobtest                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): beta
                              Installed ioBroker-Instances
                              Used repository: beta
                              Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                              Adapter    "admin"        : 7.1.0    , installed 7.1.0
                              Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                              Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
                              Adapter    "ical"         : 1.15.0   , installed 1.15.0
                              Adapter    "javascript"   : 8.8.3    , installed 8.8.2  [Updatable]
                              Controller "js-controller": 6.0.11   , installed 6.0.11
                              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                              Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                              Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                              Adapter    "sql"          : 3.0.1    , installed 3.0.1
                              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                              Adapter    "web"          : 6.3.0    , installed 6.3.0
                              Adapter    "ws"           : 2.6.2    , installed 2.6.2
                              Adapter    "yahka"        : 1.0.8    , installed 1.0.8
                              Objects and States
                              Objects: 	4034
                              States: 	3519
                              Hit:1 http://security.debian.org bookworm-security InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                              Reading package lists... Done
                              Pending Updates: 2
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13079      1/systemd
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13990      296/master
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29389306   35190/iobroker.js-c
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29389311   35190/iobroker.js-c
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13991      296/master
                              tcp6       0      0 :::9192                 :::*                    LISTEN      1001       29392405   35471/io.iosapp.0
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          13081      1/systemd
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          13201      1/systemd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60327454   91363/io.admin.0
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13080      1/systemd
                              udp6       0      0 :::111                  :::*                                0          13082      1/systemd
                              2024-09-08 14:02:49.853  - info: javascript.1 (61255) Start JavaScript script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch (JavaScript/js)
                              2024-09-08 14:02:49.860  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2024-09-08 14:02:49.864  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Connected!
                              2024-09-08 14:02:49.899  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch:  ist das eine zahl false
                              2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Tagesverbrauch: 5.1 kWh
                              2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Wochenverbrauch: 39.3 kWh
                              2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Monatsverbrauch: 47.3 kWh
                              2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Quartalsverbrauch: 455.6 kWh
                              2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Jahrsverbrauch: 2018.2 kWh
                              2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Betroffene Zeilen: 0
                              2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Serverstatus: 34
                              2024-09-08 14:05:39.663  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                              2024-09-08 14:05:39.895  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                              2024-09-08 14:05:48.012  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127484
                              2024-09-08 14:05:48.620  - info: netatmo-crawler.0 (127484) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                              2024-09-08 14:05:48.637  - info: netatmo-crawler.0 (127484) Getting data for stationid:70:ee:50:35:dc:b6
                              2024-09-08 14:06:07.272  - info: netatmo-crawler.0 (127484) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                              2024-09-08 14:06:07.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127484 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-09-08 14:10:44.041  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                              2024-09-08 14:10:44.229  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                              2024-09-08 14:10:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127529
                              2024-09-08 14:10:48.618  - info: netatmo-crawler.0 (127529) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                              2024-09-08 14:10:48.635  - info: netatmo-crawler.0 (127529) Getting data for stationid:70:ee:50:35:dc:b6
                              2024-09-08 14:10:59.398  - info: netatmo-crawler.0 (127529) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                              2024-09-08 14:10:59.907  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127529 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              			v.2024-09-07
                                Virtualization: lxc
                              Installation: 		lxc
                              Kernel: 		x86_64
                              Userland: 		64 bit
                              User-ID: 		1000
                              Pending OS-Updates: 	2
                              Pending iob updates: 	1
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              Recommended versions are nodejs 20.17.0 and npm 10.8.2
                              nodeJS installation is correct
                              MEMORY:
                              Mem:            8.4G        1.7G        5.0G        131K        1.6G        6.7G
                              Swap:           536M          0B        536M
                              Total:          8.9G        1.7G        5.6G
                              ioBroker Core: 		js-controller 		6.0.11
                              			admin 			7.1.0
                              ioBroker Status: 	iobroker is running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		4034
                              States: 		3519
                              6.0M	/opt/iobroker/iobroker-data/states.jsonl
                              in deutsch
                              *** ioBroker Diagnose ***
                              Das Fenster des Terminalprogramms (puTTY) bitte so groß wie möglich ziehen oder den Vollbildmodus verwenden.
                              Die nachfolgenden Prüfungen liefern Hinweise zu etwaigen Fehlern, bitte im Forum hochladen:
                              https://forum.iobroker.net
                              Bitte die vollständige Ausgabe, einschließlich der ``` Zeichen am Anfang und am Ende markieren und kopieren.
                              Es hilft beim helfen!
                              Bitte eine Taste drücken
                              ========== Langfassung ab hier markieren und kopieren ===========
                              Skript v.2024-09-07
                              *** GRUNDSYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               14:17:19 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
                              CPU threads: 4
                              *** LEBENSZYKLUS STATUS ***
                              Das Betriebssystem mit dem Codenamen '' ist unbekannt. Bitte den Status der Unterstützung eigenständig prüfen.
                              *** ZEIT UND ZEITZONEN ***
                                             Local time: Sun 2024-09-08 14:17:19 CEST
                                         Universal time: Sun 2024-09-08 12:17:19 UTC
                                               RTC time: n/a
                                        RTC in local TZ: no
                              *** User und Gruppen ***
                              User der 'iob diag' aufgerufen hat:
                              tom
                              HOME=/home/tom
                              User der den 'js-controller' ausführt:
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Swap:           536M          0B        536M
                                       8000 M total memory
                                       1507 M used memory
                                       1439 M active memory
                                       1471 M inactive memory
                                       4936 M free memory
                                          0 M buffer memory
                                       1555 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        512 M free swap
                              top - 14:17:20 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
                              MiB Mem :   8000.0 total,   4935.5 free,   1509.3 used,   1555.3 buff/cache
                              MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6490.7 avail Mem
                              Es wurden keine kritischen Fehler gefunden
                              *** FILESYSTEM ***
                              /var:
                              463M	/var/
                              250M	/var/cache
                              246M	/var/cache/apt
                              154M	/var/lib
                              768M	/opt/iobroker/iobroker-data/
                              USB-Devices by-id:
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310968)
                              admin: 		7.1.0
                              javascript: 	8.8.2
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects: 	3978
                              States: 	3463
                              Hit:2 http://security.debian.org bookworm-security InRelease
                              Offene Systemupdates: 2
                              2024-09-08 14:15:47.449  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                              2024-09-08 14:15:47.640  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                              2024-09-08 14:15:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 128557
                              2024-09-08 14:15:48.614  - info: netatmo-crawler.0 (128557) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                              2024-09-08 14:15:48.630  - info: netatmo-crawler.0 (128557) Getting data for stationid:70:ee:50:35:dc:b6
                              2024-09-08 14:15:58.272  - info: netatmo-crawler.0 (128557) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                              2024-09-08 14:15:58.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 128557 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              ============ Langfassung bis hier markieren =============
                              iob diag hat das System inspiziert.
                              Beliebige Taste für eine Zusammenfassung drücken
                              Zusammfassung ab hier markieren und kopieren:
                              ===================== ZUSAMMENFASSUNG =====================
                              			v.2024-09-07
                                Virtualization: lxc
                              Installation: 		lxc
                              Kernel: 		x86_64
                              Userland: 		64 bit
                              User-ID: 		1000
                              Offene OS-Updates: 	2
                              Offene iob updates: 	1
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              Empfohlene Versionen sind zurzeit nodejs 20.17.0 und npm 10.8.2
                              nodeJS ist korrekt installiert
                              MEMORY:
                              Mem:            8.4G        1.6G        5.1G        131K        1.6G        6.8G
                              Swap:           536M          0B        536M
                              			admin 			7.1.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		3978
                              States: 		3463
                              6.4M	/opt/iobroker/iobroker-data/states.jsonl
                              =================== ENDE DER ZUSAMMENFASSUNG ====================
                              === Ausgabe bis hier markieren und kopieren ===
                              tom@iobtest:~$
                                Thomas Braun Most Active @TT-Tom last edited by Thomas Braun
                                @tt-tom sagte in iob diag - Skript:
                                Hm. Da sollte eigentlich dann 'bookworm' gemeldet werden. Muss ich dann im LXC mal schauen, ob und wo ich die Info anderweitig bekomme.
                                Kannst du mal bitte
                                lsb_release -a
                                cat /etc/debian_version
                                hostnamectl
                                im Container ausführen?
                                  TT-Tom @Thomas Braun last edited by TT-Tom
                                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, permitted by applicable law.
                                  Letzte Anmeldung: Sonntag, den 08. September 2024,
                                  tom@iobtest:~$ lsb_release
                                  -bash: Isb_release: Kommando nicht gefunden.
                                  tom@iobtest:~$ lsb_release -a
                                  tom@iobtest:~$cat /etc/debian_version
                                  12.7
                                  tom@iobtest:*$ hostnamectl
                                  Chassis: container
                                  Machine ID: 661945b8c6614fe89d03fba976fb627e
                                  Boot ID: 9650d956e3ce42b185dda1a4dcaa22f4
                                  Virtualization: lxc
                                  Operating System: ;;https://www.debian.org/Debian GNU/Linux 12 (bookworm);;
                                  tom@iobtest:~$
                                  Edit: hostnamectl aktualisiert.
                                    Shadowhunter23 last edited by Shadowhunter23
                                    Proxmox lxc
                                    Script v.2024-09-07
                                    *** BASE SYSTEM ***
                                     Static hostname: iobroker
                                      Virtualization: lxc
                                    OS is similar to:
                                    model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                     16:16:01 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
                                    CPU threads: 4
                                    Operating System is the current Debian stable version codenamed 'bookworm'!
                                                   Local time: Sun 2024-09-08 16:16:01 CEST
                                               Universal time: Sun 2024-09-08 14:16:01 UTC
                                                     RTC time: n/a
                                                  NTP service: n/a
                                              RTC in local TZ: no
                                    tobias
                                    HOME=/home/tobias
                                    GROUPS=tobias sudo users iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    GROUPS=iobroker tty dialout audio video plugdev redis
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:             10G        4.4G        4.9G        499K        1.4G        6.4G
                                    Swap:             0B          0B          0B
                                    Total:           10G        4.4G        4.9G
                                    Active iob-Instances:   50
                                            10240 M total memory
                                             4176 M used memory
                                             1435 M active memory
                                             3875 M inactive memory
                                             4689 M free memory
                                                0 M buffer memory
                                             1374 M swap cache
                                                0 M total swap
                                                0 M used swap
                                                0 M free swap
                                    top - 16:16:02 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
                                    Tasks:  80 total,   1 running,  79 sleeping,   0 stopped,   0 zombie
                                    MiB Mem :  10240.0 total,   4687.7 free,   4178.0 used,   1374.8 buff/cache
                                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6062.0 avail Mem
                                    1 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/mapper/pve-vm--400--disk--0 ext4       16G   11G  4.1G  73% /
                                    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                    tmpfs                            tmpfs     3.1G  144K  3.1G   1% /run
                                    /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                                    /var:
                                    1.1G    /var/
                                    491M    /var/lib
                                    340M    /var/lib/redis
                                    307M    /var/cache
                                    303M    /var/cache/apt
                                    Archived and active journals take up 48.9M in the file system.
                                    248M    /opt/iobroker/backups/
                                    706M    /opt/iobroker/iobroker-data/
                                    573M    /opt/iobroker/iobroker-data/files
                                    299M    /opt/iobroker/iobroker-data/files/javascript.admin
                                    265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                    264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                    40M     /opt/iobroker/iobroker-data/objects.jsonl
                                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                    29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.448016d7.js.map
                                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
                                    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                    USB-Devices by-id:
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    HINT:
                                    Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                                    tcp
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    At least one iobroker host is running.
                                    Objects type: redis
                                    States  type: redis
                                    Hosts:
                                    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848141)
                                    admin:          7.1.0
                                    javascript:     8.8.3
                                    nodejs modules from github:     0
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                                    + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                                    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                                    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                                    + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                                    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                                      system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                                      system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                                    + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                                    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                    + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                                    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                    + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                                    + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                                    + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                                    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                                    + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                                    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                                    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                                      system.adapter.sayit.4                  : sayit                 : iobroker                                 - disabled
                                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                    + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                                    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                                    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                                    + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                                    + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                                    + instance is alive
                                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                    Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                                    Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                    Adapter    "email"        : 1.3.1    , installed 1.3.1
                                    Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                                    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                    Adapter    "iot"          : 3.4.0    , installed 3.4.0
                                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                    Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
                                    Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                                    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                    Adapter    "notification-manager": 1.2.1, installed 1.2.1
                                    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                                    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                    Adapter    "operating-hours": 1.1.0  , installed 1.1.0
                                    Adapter    "ping"         : 1.7.3    , installed 1.7.3
                                    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                    Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                                    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                                    Adapter    "shelly"       : 8.1.1    , installed 8.1.1
                                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                    Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                                    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                    Adapter    "wireguard"    : 1.6.4    , installed 1.6.4
                                    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                    Objects and States
                                    Objects:        11315
                                    States:         10115
                                    Hit:5 https://packages.redis.io/deb bookworm InRelease
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          118935115  1/systemd
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       156490584  651521/io.mqtt.0
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       118947555  877/io.shelly.1
                                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        118941820  170/redis-server 12
                                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          118940237  404/master
                                    tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       118943133  781/io.nuki.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          118937351  1/systemd
                                    tcp6       0      0 :::80                   :::*                    LISTEN      0          135858214  294782/apache2
                                    tcp6       0      0 :::111                  :::*                    LISTEN      0          118935117  1/systemd
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       118951273  1120/io.fullybrowse
                                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          118940238  404/master
                                    tcp6       0      0 ::1:6379                :::*                    LISTEN      106        118941821  170/redis-server 12
                                    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       118953403  1186/io.rest-api.0
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       118953652  1281/io.simple-api.
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       149284472  525475/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       118956323  1397/io.web.0
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          118935218  90/dhclient
                                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          118935116  1/systemd
                                    udp        0      0 192.168.0.222:123       0.0.0.0:*                           0          118937414  180/ntpd
                                    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          118937412  180/ntpd
                                    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          118937408  180/ntpd
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       118946983  661/io.chromecast.0
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       118947492  857/io.shelly.0
                                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       118943201  897/io.tuya.0
                                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       118943202  897/io.tuya.0
                                    udp6       0      0 :::111                  :::*                                0          118935118  1/systemd
                                    udp6       0      0 fe80::8c62:1cff:fe4:123 :::*                                105        118940387  180/ntpd
                                    udp6       0      0 ::1:123                 :::*                                0          118937416  180/ntpd
                                    udp6       0      0 :::123                  :::*                                0          118937405  180/ntpd
                                    2024-09-08 14:00:00.013  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1049671
                                    2024-09-08 14:00:04.018  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1049691
                                    2024-09-08 14:00:08.105  - info: host.iobroker instance system.adapter.ical.1 having pid 1049671 terminated with code 0 (NO_ERROR)
                                    2024-09-08 14:00:10.686  - info: host.iobroker instance system.adapter.ical.0 having pid 1049691 terminated with code 0 (NO_ERROR)
                                    2024-09-08 14:30:00.013  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1051935
                                    2024-09-08 14:30:04.019  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1051950
                                    2024-09-08 14:30:06.665  - info: host.iobroker instance system.adapter.ical.0 having pid 1051935 terminated with code 0 (NO_ERROR)
                                    2024-09-08 14:30:12.176  - info: host.iobroker instance system.adapter.ical.1 having pid 1051950 terminated with code 0 (NO_ERROR)
                                    2024-09-08 15:00:00.022  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1054104
                                    2024-09-08 15:00:04.027  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1054124
                                    2024-09-08 15:00:08.093  - info: host.iobroker instance system.adapter.ical.1 having pid 1054104 terminated with code 0 (NO_ERROR)
                                    2024-09-08 15:00:10.660  - info: host.iobroker instance system.adapter.ical.0 having pid 1054124 terminated with code 0 (NO_ERROR)
                                    2024-09-08 15:30:00.016  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1056283
                                    2024-09-08 15:30:04.021  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1056303
                                    2024-09-08 15:30:06.698  - info: host.iobroker instance system.adapter.ical.0 having pid 1056283 terminated with code 0 (NO_ERROR)
                                    2024-09-08 15:30:12.224  - info: host.iobroker instance system.adapter.ical.1 having pid 1056303 terminated with code 0 (NO_ERROR)
                                    2024-09-08 16:00:00.015  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1058656
                                    2024-09-08 16:00:04.021  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1058676
                                    2024-09-08 16:00:08.144  - info: host.iobroker instance system.adapter.ical.1 having pid 1058656 terminated with code 0 (NO_ERROR)
                                    2024-09-08 16:00:10.674  - info: host.iobroker instance system.adapter.ical.0 having pid 1058676 terminated with code 0 (NO_ERROR)
                                                            v.2024-09-07
                                      Virtualization: lxc
                                    Installation:           lxc
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    User-ID:                1000
                                    Pending iob updates:    0
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    MEMORY:
                                    Mem:             10G        4.4G        4.9G        524K        1.4G        6.3G
                                    Swap:             0B          0B          0B
                                                            admin                   7.1.0
                                    Objects type: redis
                                    States  type: redis
                                    Objects:                11315
                                    States:                 10115
                                    4.0M    /opt/iobroker/iobroker-data/states.jsonl
                                    Deutsch:
                                    Skript v.2024-09-07
                                    *** GRUNDSYSTEM ***
                                      Virtualization: lxc
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                     16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
                                    CPU threads: 4
                                    Das Betriebssystem ist das aktuelle, stabile Debian 'bookworm'!
                                                   Local time: Sun 2024-09-08 16:20:31 CEST
                                               Universal time: Sun 2024-09-08 14:20:31 UTC
                                                     RTC time: n/a
                                                  NTP service: n/a
                                              RTC in local TZ: no
                                    tobias
                                    HOME=/home/tobias
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:             0B          0B          0B
                                             4186 M used memory
                                             1444 M active memory
                                             4678 M free memory
                                                0 M buffer memory
                                             1375 M swap cache
                                                0 M total swap
                                                0 M used swap
                                                0 M free swap
                                    top - 16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
                                    Tasks:  86 total,   2 running,  83 sleeping,   0 stopped,   1 zombie
                                    %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :  10240.0 total,   4677.1 free,   4187.5 used,   1375.9 buff/cache
                                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6052.5 avail Mem
                                    *** FILESYSTEM ***
                                    tmpfs                            tmpfs     3.1G  168K  3.1G   1% /run
                                    tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/0
                                    /var:
                                    1.1G    /var/
                                    491M    /var/lib
                                    340M    /var/lib/redis
                                    307M    /var/cache
                                    303M    /var/cache/apt
                                    USB-Devices by-id:
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: redis
                                    States  type: redis
                                    Hosts:
                                    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848411)
                                    admin:          7.1.0
                                    javascript:     8.8.3
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        11315
                                    States:         10115
                                    Offene Systemupdates: 0
                                    (Not all processes could be identified, non-owned process info
                                     will not be shown, you would have to be root to see it all.)
                                                            v.2024-09-07
                                      Virtualization: lxc
                                    Installation:           lxc
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    User-ID:                1000
                                    Offene OS-Updates:      0
                                    Offene iob updates:     0
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    MEMORY:
                                    Swap:             0B          0B          0B
                                                            admin                   7.1.0
                                    Objects type: redis
                                    States  type: redis
                                    Objects:                11315
                                    States:                 10115
                                      Homoran Global Moderator Administrators @Shadowhunter23 last edited by
                                      @shadowhunter23 sagte in iob diag - Skript:
                                      fehlende Gruppe für den user (adm?)
                                      • Meister Mopper
                                        Meister Mopper @Thomas Braun last edited by
                                        Habe mal einen Proxmox Test LXC angeschmissen und das Skript laufen lassen:
                                        Langfassung:
                                        Script v.2024-09-07
                                        *** BASE SYSTEM ***
                                        Static hostname: ioTest
                                         Virtualization: lxc
                                        OS is similar to:
                                        model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
                                        CPU threads: 1
                                                      Local time: Sun 2024-09-08 17:01:44 CEST
                                                  Universal time: Sun 2024-09-08 15:01:44 UTC
                                                        RTC time: n/a
                                                 RTC in local TZ: no
                                        thomas
                                        HOME=/home/thomas
                                        GROUPS=thomas adm sudo iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            2.1G        1.1G        982M        118K        102M        1.1G
                                        Swap:             0B          0B          0B
                                        Total:          2.1G        1.1G        982M
                                                2048 M total memory
                                                1013 M used memory
                                                1090 M active memory
                                                   0 M inactive memory
                                                 936 M free memory
                                                   0 M buffer memory
                                                  98 M swap cache
                                                   0 M total swap
                                                   0 M used swap
                                                   0 M free swap
                                        top - 17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
                                        Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
                                        MiB Mem :   2048.0 total,    935.0 free,   1014.9 used,     98.1 buff/cache
                                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1033.1 avail Mem
                                        * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
                                        3 loaded units listed.
                                        *** FILESYSTEM ***
                                        rpool/data/subvol-300-disk-0 zfs        12G  6.0G  6.1G  50% /
                                        udev                         devtmpfs   16G     0   16G   0% /dev/tty
                                        tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
                                        tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
                                        tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
                                        /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
                                        /var:
                                        1.1G    /var/
                                        603M    /var/log
                                        602M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
                                        369M    /var/lib
                                        Archived and active journals take up 601.0M in the file system.
                                        489M    /opt/iobroker/backups/
                                        8.5K    /opt/iobroker/backups/scripte0
                                        164M    /opt/iobroker/iobroker-data/
                                        105M    /opt/iobroker/iobroker-data/files
                                        47M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                                        3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
                                        3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
                                        3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
                                        3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                         Version table:
                                               500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                        ioBroker Status
                                        Objects type: redis
                                        States  type: redis
                                        Hosts:
                                        ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 286)
                                        admin:          7.0.23
                                        javascript:     8.7.6
                                        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                        | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                         system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
                                        + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
                                         system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
                                         system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
                                        + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
                                         system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
                                         system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
                                         system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
                                         system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
                                         system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
                                         system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
                                         system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
                                         system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
                                         system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
                                         system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
                                         system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
                                        + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + instance is alive
                                        Active repo(s): stable
                                        Used repository: stable
                                        Adapter    "admin"        : 7.0.23   , installed 7.0.23
                                        Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                                        Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                                        Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                        Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                        Adapter    "heos"         : 2.2.1    , installed 2.2.1
                                        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                        Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
                                        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                                        Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                        Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                                        Adapter    "solax"        : 0.9.9    , installed 0.9.9
                                        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                        Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                        Adapter    "traccar"      : 1.1.4    , installed 1.1.4
                                        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                        Objects and States
                                        Objects:        453
                                        States:         337
                                        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                        Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                                        Pending Updates: 0
                                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146671219  117/redis-server 12
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146671191  124/sshd: /usr/sbin
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146670661  1/systemd
                                        tcp6       0      0 :::6556                 :::*                    LISTEN      0          146670958  1/systemd
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146671441  166/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146672892  237/io.web.0
                                        tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146671220  117/redis-server 12
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          146671202  124/sshd: /usr/sbin
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          146670663  1/systemd
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146670662  1/systemd
                                        udp6       0      0 :::111                  :::*                                0          146670664  1/systemd
                                        2024-09-08 16:57:10.689  - info: javascript.0 (193) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                        2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all states
                                        2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all objects
                                        2024-09-08 16:57:11.031  - info: javascript.0 (193) received all states
                                        2024-09-08 16:57:11.518  - info: javascript.0 (193) received all objects
                                        Kurzfassung:
                                                               v.2024-09-07
                                         Virtualization: lxc
                                        Installation:           lxc
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        User-ID:                1001
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        MEMORY:
                                        Mem:            2.1G        1.1G        1.0G        118K         62M        1.1G
                                        Swap:             0B          0B          0B
                                        Total:          2.1G        1.1G        1.0G
                                                               admin                   7.0.23
                                        Objects type: redis
                                        States  type: redis
                                        Objects:                453
                                        States:                 337
                                        1.9M    /opt/iobroker/iobroker-data/objects.json.bak
                                        221K    /opt/iobroker/iobroker-data/states.json.bak
                                        Langfassung DE:
                                        Skript v.2024-09-07
                                        *** GRUNDSYSTEM ***
                                         Virtualization: lxc
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
                                        CPU threads: 1
                                                      Local time: Sun 2024-09-08 17:04:41 CEST
                                                  Universal time: Sun 2024-09-08 15:04:41 UTC
                                                        RTC time: n/a
                                                 RTC in local TZ: no
                                        thomas
                                        HOME=/home/thomas
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:             0B          0B          0B
                                                2048 M total memory
                                                1018 M used memory
                                                1055 M active memory
                                                   0 M inactive memory
                                                 970 M free memory
                                                   0 M buffer memory
                                                  59 M swap cache
                                                   0 M total swap
                                                   0 M used swap
                                                   0 M free swap
                                        top - 17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
                                        %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   2048.0 total,    968.4 free,   1020.2 used,     59.6 buff/cache
                                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1027.8 avail Mem
                                        *** FILESYSTEM ***
                                        /var:
                                        1.1G    /var/
                                        603M    /var/log
                                        369M    /var/lib
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                         Version table:
                                        ioBroker Status
                                        Objects type: redis
                                        States  type: redis
                                        Hosts:
                                        ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 466)
                                        admin:          7.0.23
                                        javascript:     8.7.6
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        453
                                        States:         337
                                        Kurzfassung DE:
                                                               v.2024-09-07
                                         Virtualization: lxc
                                        Installation:           lxc
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        User-ID:                1001
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        MEMORY:
                                        Swap:             0B          0B          0B
                                                               admin                   7.0.23
                                        Objects type: redis
                                        States  type: redis
                                        Objects:                453
                                        States:                 337
                                          Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                          Nee, LXC-Eigenheit.
                                          Bei Meister Mopper wird auch richtig Bookworm erkannt...
                                          Meister Mopper T 3 Replies Last reply Reply Quote 1
                                          • Meister Mopper
                                            Jetzt mal die Variante als root user:
                                            Script v.2024-09-07
                                            *** BASE SYSTEM ***
                                             Virtualization: lxc
                                            OS is similar to:
                                            Docker          : false
                                            Kernel          : x86_64
                                            Userland        : 64 bit
                                            17:46:56 up 50 min,  1 user,  load average: 0.65, 0.48, 0.44
                                            CPU threads: 1
                                                          Local time: Sun 2024-09-08 17:46:56 CEST
                                                      Universal time: Sun 2024-09-08 15:46:56 UTC
                                                            RTC time: n/a
                                                     RTC in local TZ: no
                                            root
                                            HOME=/root
                                            GROUPS=root
                                            iobroker
                                            HOME=/home/iobroker
                                            A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                                            A root login is not required in most Linux Distributions.
                                            Enter the username for a new user (Not 'root' and not 'iobroker'!): testuser
                                            Enter the password for the new user:
                                            Confirm the password for the new user:
                                            Adding new user account...
                                            Desktop:
                                            Terminal:
                                            *** MEMORY ***
                                            Mem:            2.1G        1.1G        1.0G        110K         64M        1.1G
                                            Swap:             0B          0B          0B
                                                    2048 M total memory
                                                    1022 M used memory
                                                    1048 M active memory
                                                       0 M inactive memory
                                                     964 M free memory
                                                       0 M buffer memory
                                                      61 M swap cache
                                                       0 M total swap
                                                       0 M used swap
                                                       0 M free swap
                                            top - 17:47:31 up 50 min,  1 user,  load average: 0.41, 0.44, 0.43
                                            Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                                            MiB Mem :   2048.0 total,    962.5 free,   1024.3 used,     61.2 buff/cache
                                            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1023.7 avail Mem
                                            *** FILESYSTEM ***
                                            tmpfs                        tmpfs     6.3G  104K  6.3G   1% /run
                                            /var:
                                            1.1G    /var/
                                            603M    /var/log
                                            369M    /var/lib
                                            Archived and active journals take up 601.1M in the file system.
                                            USB-Devices by-id:
                                            /usr/bin/npm            10.8.2
                                            /usr/bin/npx            10.8.2
                                            nodejs:
                                             Version table:
                                            ioBroker Status
                                            Objects type: redis
                                            States  type: redis
                                            Hosts:
                                            ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 1351)
                                            admin:          7.0.23
                                            javascript:     8.7.6
                                            Adapter State
                                            + instance is alive
                                            Objects and States
                                            Objects:        453
                                            States:         337
                                            Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                            Pending Updates: 0
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146791638  5317/io.admin.0
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146791954  5388/io.web.0
                                            2024-09-08 17:24:26.513  - info: javascript.0 (193) terminating
                                            2024-09-08 17:24:26.514  - info: javascript.0 (193) Terminated (NO_ERROR): Without reason
                                            2024-09-08 17:24:26.518  - info: javascript.0 (193) Got terminate signal TERMINATE_YOURSELF
                                            2024-09-08 17:24:27.005  - info: javascript.0 (193) terminating
                                            2024-09-08 17:25:05.872  - info: javascript.0 (5358) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                            2024-09-08 17:25:06.028  - info: javascript.0 (5358) requesting all states
                                            2024-09-08 17:25:06.029  - info: javascript.0 (5358) requesting all objects
                                            2024-09-08 17:25:06.044  - info: javascript.0 (5358) received all states
                                            2024-09-08 17:25:06.261  - info: javascript.0 (5358) received all objects
                                            Mein eingerichteter testuser hat auch die richtigen Rechte bekommen.
                                            testuser@ioTest:~$ groups
                                            testuser adm dialout sudo audio video plugdev users iobroker
                                            738
                                            153225
