    4. iob diag - Skript
    iob diag - Skript
    • Nashra
      Nashra Most Active Forum Testing @Thomas Braun last edited by
      Moin, hier mit LXC
                              v.2024-08-18_5
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-1-pve
          Architecture: x86-64
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    2
      Nodejs-Installation:
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      Recommended versions are nodejs 20.16.0 and npm 10.8.1
      MEMORY:
      Mem:             12G        4.1G        7.9G        122K        873M        8.7G
      Swap:             0B          0B          0B
      Total:           12G        4.1G        7.9G
      Active iob-Instances:   45
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.9
                              admin                   7.0.22
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
      Objects:                54190
      States:                 50980
      Size of iob-Database:
      86M     /opt/iobroker/iobroker-data/objects.jsonl
      88M     /opt/iobroker/iobroker-data/states.jsonl
      Your Operating System is the current Debian stable version 'bookworm'!
      • Negalein
        Negalein Global Moderator @Thomas Braun last edited by
        hier ein LXC
                                v.2024-08-18_5
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 5.15.30-2-pve
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Vienna (CEST, +0200)
        User-ID:                1001
        Pending OS-Updates:     31
        Pending iob updates:    4
        /usr/bin/nodejs         v20.15.0
        /usr/bin/node           v20.15.0
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.1
        MEMORY:
        Mem:             10G        4.8G        4.4G        0.0K        865M        5.3G
        Swap:           3.1G        1.1G        2.0G
        Total:           13G        5.8G        6.4G
        Active iob-Instances:   60
        Active repo(s): Beta (latest)
        ioBroker Core:          js-controller           5.0.19
                                admin                   7.0.24
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                32233
        States:                 31404
        53M     /opt/iobroker/iobroker-data/objects.jsonl
        29M     /opt/iobroker/iobroker-data/objects.json.migrated
        29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        0       /opt/iobroker/iobroker-data/objects.json.broken
        54M     /opt/iobroker/iobroker-data/states.jsonl
        9.4M    /opt/iobroker/iobroker-data/states.json.migrated
        9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
        Your Operating System jammy is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
          Shadowhunter23 last edited by
          Vielleicht noch ein Hinweis, ich habe 4 zigbee Adapter und keinen USB Stick. Angezeigt wird nur bis Adapter .2
          Die Koordinatoren sind alle per Netzwerk eingebunden. Ob du das abfragen kann das kein USB Stick angeschlossen ist weiß ich nicht.
          USB-Devices by-id:
          No Devices found 'by-id'
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
            Thomas Braun Most Active @Shadowhunter23 last edited by
            @shadowhunter23
            Ich war davon ausgeganen, das 3 zigbee-Instanzen ausreichend sein sollten.
            Ich würde da auch eher per Router ein Zigbee-Netz draus weben, an deiner Stelle.
            Und ich vergleiche auch nur die EInträge von 'by-id' mit den Ports aus dem Adapter.
            Ob die Einstellungen dann die richtigen sind musst du selber prüfen.
            Ist ja auch nur ein Hinweis.
            Kurz: Won't fix.
              Shadowhunter23 @Thomas Braun last edited by Shadowhunter23
              Auch hier, Won't fix 🙂 . Das ist schon mit Absicht so gemacht.
              Kurz: Won't fix.
              OK, war ja auch nur ein Hinweis.
                Thomas Braun Most Active @Shadowhunter23 last edited by Thomas Braun
                Da ich das Skript in den letzten Tagen um einige Funktionen (Anlage eines users, wenn es als root oder 'iobroker' aufgerufen wird; setzen der Zeitzone, wenn eine vermutlich falsche (wie Europe/London oder UTC) erkannt wird) und kritische Fehler im Kernel Ring Puffer (dmesg) jetzt gemeldet werden würde ich gerne ein paar Läufe auf anderen Systemen als meinen Testkisten sehen. Insbesondere LXC und Docker ist da interessant für mich.
                Es gibt auch ein paar Meldungen auf deutsch, wenn das Skript mit der Option '--de' aufgerufen wird. Auch dazu wäre Feedback willkommen. Gleich vorweg: Es kann keine vollständige Übersetzung geben, da einige Kommandos nur englische Ausgaben liefern.
                Bitte diese Beta-Version wie im ersten Beitrag gezeigt lokal ausführen, im ioBroker selber ist diese Version v.2024-09-07 natürlich noch nicht implementiert.
                Meister Mopper 1 Reply Last reply Reply Quote 1
                  TT-Tom last edited by TT-Tom
                  Hallo Thomas,
                  habe das Script aus dem Standartuser Ordner Tom gestartet. Musste zwischen durch das Password für sudo eingeben. System LXC-Container mit einem Testsystem auf Beta-Repro.
                  Script v.2024-09-07
                  *** BASE SYSTEM ***
                   Static hostname: iobtest
                    Virtualization: lxc
                  OS is similar to:
                  model name	: Intel(R) N100
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   14:11:14 up 24 days, 36 min,  1 user,  load average: 0.06, 0.08, 0.01
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                  *** TIME AND TIMEZONES ***
                                 Local time: Sun 2024-09-08 14:11:14 CEST
                             Universal time: Sun 2024-09-08 12:11:14 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  tom
                  HOME=/home/tom
                  GROUPS=tom sudo users iobroker
                  iobroker
                  [sudo] password for tom:
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  *** DISPLAY-SERVER SETUP ***
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Mem:            8.4G        1.6G        5.2G        131K        1.6G        6.8G
                  Swap:           536M          0B        536M
                  Total:          8.9G        1.6G        5.7G
                  Active iob-Instances: 	10
                           8000 M total memory
                           1507 M used memory
                           1442 M active memory
                           1464 M inactive memory
                           4944 M free memory
                              0 M buffer memory
                           1547 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  top - 14:11:34 up 24 days, 36 min,  1 user,  load average: 0.05, 0.07, 0.01
                  Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   8000.0 total,   4944.3 free,   1508.0 used,   1547.8 buff/cache
                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6492.0 avail Mem
                  *** FAILED SERVICES ***
                    UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                  * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                  * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                  LOAD   = Reflects whether the unit definition was properly loaded.
                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                  SUB    = The low-level unit activation state, values depend on unit type.
                  2 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  dmesg: read kernel buffer failed: Operation not permitted
                  No critical errors detected
                  *** FILESYSTEM ***
                  Filesystem                       Type      Size  Used Avail Use% Mounted on
                  /dev/mapper/pve-vm--101--disk--0 ext4       63G  6.0G   54G  10% /
                  none                             tmpfs     492K  4.0K  488K   1% /dev
                  udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                  tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                  tmpfs                            tmpfs     3.1G  124K  3.1G   1% /run
                  tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                  Show mounted filesystems:
                  TARGET SOURCE                           FSTYPE OPTIONS
                  /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                  /var:
                  463M	/var/
                  250M	/var/cache
                  246M	/var/cache/apt
                  170M	/var/cache/apt/archives
                  154M	/var/lib
                  Archived and active journals take up 16.4M in the file system.
                  /opt/iobroker/backups:
                  46M	/opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  767M	/opt/iobroker/iobroker-data/
                  645M	/opt/iobroker/iobroker-data/files
                  493M	/opt/iobroker/iobroker-data/files/javascript.admin
                  461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                  460M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  30M	/opt/iobroker/iobroker-data/objects.jsonl
                  19M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
                  14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                  8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                  USB-Devices by-id:
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs 	v20.17.0
                  /usr/bin/node 		v20.17.0
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  /usr/bin/corepack 	0.29.3
                  nodejs:
                    Installed: 20.17.0-1nodesource1
                    Candidate: 20.17.0-1nodesource1
                    Version table:
                   *** 20.17.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                          100 /var/lib/dpkg/status
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://security.debian.org bookworm-security/main amd64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310623)
                  Core adapters versions
                  js-controller: 	6.0.11
                  admin: 		7.1.0
                  javascript: 	8.8.2
                  nodejs modules from github: 	2
                  +-- iobroker.iosapp@1.0.3 (git+ssh://git@github.com/tt-tom17/ioBroker.iosapp.git#57aa9615040d4d80b735ca0fb4beddc5aee69c9d)
                  +-- iobroker.nspanel-lovelace-ui@0.0.4-preAlpha.3 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#eaa0acd87ee8a90d72fee56e8fc3531ee62a94e4)
                  Adapter State
                    system.adapter.accuweather.0            : accuweather           : iobtest                                  - disabled
                  + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                  + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                    system.adapter.devices.0                : devices               : iobtest                                  - disabled
                  + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                    system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                  + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                  + system.adapter.iosapp.0                 : iosapp                : iobtest                                  -  enabled
                  + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                  + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                    system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  - disabled
                    system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                  + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
                    system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                    system.adapter.web.0                    : web                   : iobtest                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): beta
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                  Adapter    "admin"        : 7.1.0    , installed 7.1.0
                  Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                  Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
                  Adapter    "ical"         : 1.15.0   , installed 1.15.0
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.2  [Updatable]
                  Controller "js-controller": 6.0.11   , installed 6.0.11
                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                  Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                  Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "sql"          : 3.0.1    , installed 3.0.1
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "web"          : 6.3.0    , installed 6.3.0
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Adapter    "yahka"        : 1.0.8    , installed 1.0.8
                  Objects and States
                  Objects: 	4034
                  States: 	3519
                  Hit:1 http://security.debian.org bookworm-security InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                  Reading package lists... Done
                  Pending Updates: 2
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13079      1/systemd
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13990      296/master
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29389306   35190/iobroker.js-c
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29389311   35190/iobroker.js-c
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13991      296/master
                  tcp6       0      0 :::9192                 :::*                    LISTEN      1001       29392405   35471/io.iosapp.0
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          13081      1/systemd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13201      1/systemd
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60327454   91363/io.admin.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13080      1/systemd
                  udp6       0      0 :::111                  :::*                                0          13082      1/systemd
                  2024-09-08 14:02:49.853  - info: javascript.1 (61255) Start JavaScript script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch (JavaScript/js)
                  2024-09-08 14:02:49.860  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2024-09-08 14:02:49.864  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Connected!
                  2024-09-08 14:02:49.899  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch:  ist das eine zahl false
                  2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Tagesverbrauch: 5.1 kWh
                  2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Wochenverbrauch: 39.3 kWh
                  2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Monatsverbrauch: 47.3 kWh
                  2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Quartalsverbrauch: 455.6 kWh
                  2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Jahrsverbrauch: 2018.2 kWh
                  2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Betroffene Zeilen: 0
                  2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Serverstatus: 34
                  2024-09-08 14:05:39.663  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                  2024-09-08 14:05:39.895  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                  2024-09-08 14:05:48.012  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127484
                  2024-09-08 14:05:48.620  - info: netatmo-crawler.0 (127484) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                  2024-09-08 14:05:48.637  - info: netatmo-crawler.0 (127484) Getting data for stationid:70:ee:50:35:dc:b6
                  2024-09-08 14:06:07.272  - info: netatmo-crawler.0 (127484) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2024-09-08 14:06:07.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127484 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-09-08 14:10:44.041  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                  2024-09-08 14:10:44.229  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                  2024-09-08 14:10:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127529
                  2024-09-08 14:10:48.618  - info: netatmo-crawler.0 (127529) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                  2024-09-08 14:10:48.635  - info: netatmo-crawler.0 (127529) Getting data for stationid:70:ee:50:35:dc:b6
                  2024-09-08 14:10:59.398  - info: netatmo-crawler.0 (127529) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2024-09-08 14:10:59.907  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127529 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  			v.2024-09-07
                    Virtualization: lxc
                  Installation: 		lxc
                  Kernel: 		x86_64
                  Userland: 		64 bit
                  User-ID: 		1000
                  Pending OS-Updates: 	2
                  Pending iob updates: 	1
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  Recommended versions are nodejs 20.17.0 and npm 10.8.2
                  nodeJS installation is correct
                  MEMORY:
                  Mem:            8.4G        1.7G        5.0G        131K        1.6G        6.7G
                  Swap:           536M          0B        536M
                  Total:          8.9G        1.7G        5.6G
                  ioBroker Core: 		js-controller 		6.0.11
                  			admin 			7.1.0
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		4034
                  States: 		3519
                  6.0M	/opt/iobroker/iobroker-data/states.jsonl
                  in deutsch
                  *** ioBroker Diagnose ***
                  Das Fenster des Terminalprogramms (puTTY) bitte so groß wie möglich ziehen oder den Vollbildmodus verwenden.
                  Die nachfolgenden Prüfungen liefern Hinweise zu etwaigen Fehlern, bitte im Forum hochladen:
                  https://forum.iobroker.net
                  Bitte die vollständige Ausgabe, einschließlich der ``` Zeichen am Anfang und am Ende markieren und kopieren.
                  Es hilft beim helfen!
                  Bitte eine Taste drücken
                  ========== Langfassung ab hier markieren und kopieren ===========
                  Skript v.2024-09-07
                  *** GRUNDSYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   14:17:19 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
                  CPU threads: 4
                  *** LEBENSZYKLUS STATUS ***
                  Das Betriebssystem mit dem Codenamen '' ist unbekannt. Bitte den Status der Unterstützung eigenständig prüfen.
                  *** ZEIT UND ZEITZONEN ***
                                 Local time: Sun 2024-09-08 14:17:19 CEST
                             Universal time: Sun 2024-09-08 12:17:19 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  *** User und Gruppen ***
                  User der 'iob diag' aufgerufen hat:
                  tom
                  HOME=/home/tom
                  User der den 'js-controller' ausführt:
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Swap:           536M          0B        536M
                           8000 M total memory
                           1507 M used memory
                           1439 M active memory
                           1471 M inactive memory
                           4936 M free memory
                              0 M buffer memory
                           1555 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  top - 14:17:20 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
                  MiB Mem :   8000.0 total,   4935.5 free,   1509.3 used,   1555.3 buff/cache
                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6490.7 avail Mem
                  Es wurden keine kritischen Fehler gefunden
                  *** FILESYSTEM ***
                  /var:
                  463M	/var/
                  250M	/var/cache
                  246M	/var/cache/apt
                  154M	/var/lib
                  768M	/opt/iobroker/iobroker-data/
                  USB-Devices by-id:
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310968)
                  admin: 		7.1.0
                  javascript: 	8.8.2
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	3978
                  States: 	3463
                  Hit:2 http://security.debian.org bookworm-security InRelease
                  Offene Systemupdates: 2
                  2024-09-08 14:15:47.449  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                  2024-09-08 14:15:47.640  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                  2024-09-08 14:15:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 128557
                  2024-09-08 14:15:48.614  - info: netatmo-crawler.0 (128557) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                  2024-09-08 14:15:48.630  - info: netatmo-crawler.0 (128557) Getting data for stationid:70:ee:50:35:dc:b6
                  2024-09-08 14:15:58.272  - info: netatmo-crawler.0 (128557) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2024-09-08 14:15:58.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 128557 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  ============ Langfassung bis hier markieren =============
                  iob diag hat das System inspiziert.
                  Beliebige Taste für eine Zusammenfassung drücken
                  Zusammfassung ab hier markieren und kopieren:
                  ===================== ZUSAMMENFASSUNG =====================
                  			v.2024-09-07
                    Virtualization: lxc
                  Installation: 		lxc
                  Kernel: 		x86_64
                  Userland: 		64 bit
                  User-ID: 		1000
                  Offene OS-Updates: 	2
                  Offene iob updates: 	1
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  Empfohlene Versionen sind zurzeit nodejs 20.17.0 und npm 10.8.2
                  nodeJS ist korrekt installiert
                  MEMORY:
                  Mem:            8.4G        1.6G        5.1G        131K        1.6G        6.8G
                  Swap:           536M          0B        536M
                  			admin 			7.1.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		3978
                  States: 		3463
                  6.4M	/opt/iobroker/iobroker-data/states.jsonl
                  =================== ENDE DER ZUSAMMENFASSUNG ====================
                  === Ausgabe bis hier markieren und kopieren ===
                  tom@iobtest:~$
                    Thomas Braun Most Active @TT-Tom last edited by Thomas Braun
                    @tt-tom sagte in iob diag - Skript:
                    Hm. Da sollte eigentlich dann 'bookworm' gemeldet werden. Muss ich dann im LXC mal schauen, ob und wo ich die Info anderweitig bekomme.
                    Kannst du mal bitte
                    lsb_release -a
                    cat /etc/debian_version
                    hostnamectl
                    im Container ausführen?
                      TT-Tom @Thomas Braun last edited by TT-Tom
                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, permitted by applicable law.
                      Letzte Anmeldung: Sonntag, den 08. September 2024,
                      tom@iobtest:~$ lsb_release
                      -bash: Isb_release: Kommando nicht gefunden.
                      tom@iobtest:~$ lsb_release -a
                      tom@iobtest:~$cat /etc/debian_version
                      12.7
                      tom@iobtest:*$ hostnamectl
                      Chassis: container
                      Machine ID: 661945b8c6614fe89d03fba976fb627e
                      Boot ID: 9650d956e3ce42b185dda1a4dcaa22f4
                      Virtualization: lxc
                      Operating System: ;;https://www.debian.org/Debian GNU/Linux 12 (bookworm);;
                      tom@iobtest:~$
                      Edit: hostnamectl aktualisiert.
                        Shadowhunter23 last edited by Shadowhunter23
                        Proxmox lxc
                        Script v.2024-09-07
                        *** BASE SYSTEM ***
                         Static hostname: iobroker
                          Virtualization: lxc
                        OS is similar to:
                        model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         16:16:01 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
                        CPU threads: 4
                        Operating System is the current Debian stable version codenamed 'bookworm'!
                                       Local time: Sun 2024-09-08 16:16:01 CEST
                                   Universal time: Sun 2024-09-08 14:16:01 UTC
                                         RTC time: n/a
                                      NTP service: n/a
                                  RTC in local TZ: no
                        tobias
                        HOME=/home/tobias
                        GROUPS=tobias sudo users iobroker
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev redis
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:             10G        4.4G        4.9G        499K        1.4G        6.4G
                        Swap:             0B          0B          0B
                        Total:           10G        4.4G        4.9G
                        Active iob-Instances:   50
                                10240 M total memory
                                 4176 M used memory
                                 1435 M active memory
                                 3875 M inactive memory
                                 4689 M free memory
                                    0 M buffer memory
                                 1374 M swap cache
                                    0 M total swap
                                    0 M used swap
                                    0 M free swap
                        top - 16:16:02 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
                        Tasks:  80 total,   1 running,  79 sleeping,   0 stopped,   0 zombie
                        MiB Mem :  10240.0 total,   4687.7 free,   4178.0 used,   1374.8 buff/cache
                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6062.0 avail Mem
                        1 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/mapper/pve-vm--400--disk--0 ext4       16G   11G  4.1G  73% /
                        udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                        tmpfs                            tmpfs     3.1G  144K  3.1G   1% /run
                        /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                        /var:
                        1.1G    /var/
                        491M    /var/lib
                        340M    /var/lib/redis
                        307M    /var/cache
                        303M    /var/cache/apt
                        Archived and active journals take up 48.9M in the file system.
                        248M    /opt/iobroker/backups/
                        706M    /opt/iobroker/iobroker-data/
                        573M    /opt/iobroker/iobroker-data/files
                        299M    /opt/iobroker/iobroker-data/files/javascript.admin
                        265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        40M     /opt/iobroker/iobroker-data/objects.jsonl
                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                        29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.448016d7.js.map
                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
                        19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                        USB-Devices by-id:
                        HINT:
                        tcp
                        HINT:
                        tcp
                        HINT:
                        tcp
                        HINT:
                        Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                        tcp
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        At least one iobroker host is running.
                        Objects type: redis
                        States  type: redis
                        Hosts:
                        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848141)
                        admin:          7.1.0
                        javascript:     8.8.3
                        nodejs modules from github:     0
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                        + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                        + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                        + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                        + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                        + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                          system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                          system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                        + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                        + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                        + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                        + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                        + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                        + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                        + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                        + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                        + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                          system.adapter.sayit.4                  : sayit                 : iobroker                                 - disabled
                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                        + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                        + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                        + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                        + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                        + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                        + instance is alive
                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                        Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                        Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                        Adapter    "email"        : 1.3.1    , installed 1.3.1
                        Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                        Adapter    "iot"          : 3.4.0    , installed 3.4.0
                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                        Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
                        Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                        Adapter    "notification-manager": 1.2.1, installed 1.2.1
                        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                        Adapter    "operating-hours": 1.1.0  , installed 1.1.0
                        Adapter    "ping"         : 1.7.3    , installed 1.7.3
                        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                        Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                        Adapter    "shelly"       : 8.1.1    , installed 8.1.1
                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                        Adapter    "text2command" : 3.0.3    , installed 3.0.3
                        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                        Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                        Adapter    "wireguard"    : 1.6.4    , installed 1.6.4
                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                        Objects and States
                        Objects:        11315
                        States:         10115
                        Hit:5 https://packages.redis.io/deb bookworm InRelease
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          118935115  1/systemd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       156490584  651521/io.mqtt.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       118947555  877/io.shelly.1
                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        118941820  170/redis-server 12
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          118940237  404/master
                        tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       118943133  781/io.nuki.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          118937351  1/systemd
                        tcp6       0      0 :::80                   :::*                    LISTEN      0          135858214  294782/apache2
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          118935117  1/systemd
                        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       118951273  1120/io.fullybrowse
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          118940238  404/master
                        tcp6       0      0 ::1:6379                :::*                    LISTEN      106        118941821  170/redis-server 12
                        tcp6       0      0 :::8093                 :::*                    LISTEN      1001       118953403  1186/io.rest-api.0
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       118953652  1281/io.simple-api.
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       149284472  525475/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       118956323  1397/io.web.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          118935218  90/dhclient
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          118935116  1/systemd
                        udp        0      0 192.168.0.222:123       0.0.0.0:*                           0          118937414  180/ntpd
                        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          118937412  180/ntpd
                        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          118937408  180/ntpd
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       118946983  661/io.chromecast.0
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       118947492  857/io.shelly.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       118943201  897/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       118943202  897/io.tuya.0
                        udp6       0      0 :::111                  :::*                                0          118935118  1/systemd
                        udp6       0      0 fe80::8c62:1cff:fe4:123 :::*                                105        118940387  180/ntpd
                        udp6       0      0 ::1:123                 :::*                                0          118937416  180/ntpd
                        udp6       0      0 :::123                  :::*                                0          118937405  180/ntpd
                        2024-09-08 14:00:00.013  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1049671
                        2024-09-08 14:00:04.018  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1049691
                        2024-09-08 14:00:08.105  - info: host.iobroker instance system.adapter.ical.1 having pid 1049671 terminated with code 0 (NO_ERROR)
                        2024-09-08 14:00:10.686  - info: host.iobroker instance system.adapter.ical.0 having pid 1049691 terminated with code 0 (NO_ERROR)
                        2024-09-08 14:30:00.013  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1051935
                        2024-09-08 14:30:04.019  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1051950
                        2024-09-08 14:30:06.665  - info: host.iobroker instance system.adapter.ical.0 having pid 1051935 terminated with code 0 (NO_ERROR)
                        2024-09-08 14:30:12.176  - info: host.iobroker instance system.adapter.ical.1 having pid 1051950 terminated with code 0 (NO_ERROR)
                        2024-09-08 15:00:00.022  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1054104
                        2024-09-08 15:00:04.027  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1054124
                        2024-09-08 15:00:08.093  - info: host.iobroker instance system.adapter.ical.1 having pid 1054104 terminated with code 0 (NO_ERROR)
                        2024-09-08 15:00:10.660  - info: host.iobroker instance system.adapter.ical.0 having pid 1054124 terminated with code 0 (NO_ERROR)
                        2024-09-08 15:30:00.016  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1056283
                        2024-09-08 15:30:04.021  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1056303
                        2024-09-08 15:30:06.698  - info: host.iobroker instance system.adapter.ical.0 having pid 1056283 terminated with code 0 (NO_ERROR)
                        2024-09-08 15:30:12.224  - info: host.iobroker instance system.adapter.ical.1 having pid 1056303 terminated with code 0 (NO_ERROR)
                        2024-09-08 16:00:00.015  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1058656
                        2024-09-08 16:00:04.021  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1058676
                        2024-09-08 16:00:08.144  - info: host.iobroker instance system.adapter.ical.1 having pid 1058656 terminated with code 0 (NO_ERROR)
                        2024-09-08 16:00:10.674  - info: host.iobroker instance system.adapter.ical.0 having pid 1058676 terminated with code 0 (NO_ERROR)
                                                v.2024-09-07
                          Virtualization: lxc
                        Installation:           lxc
                        Kernel:                 x86_64
                        Userland:               64 bit
                        User-ID:                1000
                        Pending iob updates:    0
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        MEMORY:
                        Mem:             10G        4.4G        4.9G        524K        1.4G        6.3G
                        Swap:             0B          0B          0B
                                                admin                   7.1.0
                        Objects type: redis
                        States  type: redis
                        Objects:                11315
                        States:                 10115
                        4.0M    /opt/iobroker/iobroker-data/states.jsonl
                        Deutsch:
                        Skript v.2024-09-07
                        *** GRUNDSYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
                        CPU threads: 4
                        Das Betriebssystem ist das aktuelle, stabile Debian 'bookworm'!
                                       Local time: Sun 2024-09-08 16:20:31 CEST
                                   Universal time: Sun 2024-09-08 14:20:31 UTC
                                         RTC time: n/a
                                      NTP service: n/a
                                  RTC in local TZ: no
                        tobias
                        HOME=/home/tobias
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:             0B          0B          0B
                                 4186 M used memory
                                 1444 M active memory
                                 4678 M free memory
                                    0 M buffer memory
                                 1375 M swap cache
                                    0 M total swap
                                    0 M used swap
                                    0 M free swap
                        top - 16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
                        Tasks:  86 total,   2 running,  83 sleeping,   0 stopped,   1 zombie
                        %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :  10240.0 total,   4677.1 free,   4187.5 used,   1375.9 buff/cache
                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6052.5 avail Mem
                        *** FILESYSTEM ***
                        tmpfs                            tmpfs     3.1G  168K  3.1G   1% /run
                        tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/0
                        /var:
                        1.1G    /var/
                        491M    /var/lib
                        340M    /var/lib/redis
                        307M    /var/cache
                        303M    /var/cache/apt
                        USB-Devices by-id:
                        HINT:
                        tcp
                        HINT:
                        tcp
                        HINT:
                        tcp
                        HINT:
                        tcp
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: redis
                        States  type: redis
                        Hosts:
                        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848411)
                        admin:          7.1.0
                        javascript:     8.8.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        11315
                        States:         10115
                        Offene Systemupdates: 0
                        (Not all processes could be identified, non-owned process info
                         will not be shown, you would have to be root to see it all.)
                                                v.2024-09-07
                          Virtualization: lxc
                        Installation:           lxc
                        Kernel:                 x86_64
                        Userland:               64 bit
                        User-ID:                1000
                        Offene OS-Updates:      0
                        Offene iob updates:     0
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        MEMORY:
                        Swap:             0B          0B          0B
                                                admin                   7.1.0
                        Objects type: redis
                        States  type: redis
                        Objects:                11315
                        States:                 10115
                          Homoran Global Moderator Administrators @Shadowhunter23 last edited by
                          @shadowhunter23 sagte in iob diag - Skript:
                          fehlende Gruppe für den user (adm?)
                          • Meister Mopper
                            Meister Mopper @Thomas Braun last edited by
                            Habe mal einen Proxmox Test LXC angeschmissen und das Skript laufen lassen:
                            Langfassung:
                            Script v.2024-09-07
                            *** BASE SYSTEM ***
                            Static hostname: ioTest
                             Virtualization: lxc
                            OS is similar to:
                            model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
                            CPU threads: 1
                                          Local time: Sun 2024-09-08 17:01:44 CEST
                                      Universal time: Sun 2024-09-08 15:01:44 UTC
                                            RTC time: n/a
                                     RTC in local TZ: no
                            thomas
                            HOME=/home/thomas
                            GROUPS=thomas adm sudo iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            2.1G        1.1G        982M        118K        102M        1.1G
                            Swap:             0B          0B          0B
                            Total:          2.1G        1.1G        982M
                                    2048 M total memory
                                    1013 M used memory
                                    1090 M active memory
                                       0 M inactive memory
                                     936 M free memory
                                       0 M buffer memory
                                      98 M swap cache
                                       0 M total swap
                                       0 M used swap
                                       0 M free swap
                            top - 17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
                            Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
                            MiB Mem :   2048.0 total,    935.0 free,   1014.9 used,     98.1 buff/cache
                            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1033.1 avail Mem
                            * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
                            3 loaded units listed.
                            *** FILESYSTEM ***
                            rpool/data/subvol-300-disk-0 zfs        12G  6.0G  6.1G  50% /
                            udev                         devtmpfs   16G     0   16G   0% /dev/tty
                            tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
                            tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
                            tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
                            /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
                            /var:
                            1.1G    /var/
                            603M    /var/log
                            602M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
                            369M    /var/lib
                            Archived and active journals take up 601.0M in the file system.
                            489M    /opt/iobroker/backups/
                            8.5K    /opt/iobroker/backups/scripte0
                            164M    /opt/iobroker/iobroker-data/
                            105M    /opt/iobroker/iobroker-data/files
                            47M     /opt/iobroker/iobroker-data/files/javascript.admin
                            40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                            3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
                            3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
                            3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
                            3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
                            USB-Devices by-id:
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                             Version table:
                                   500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                            ioBroker Status
                            Objects type: redis
                            States  type: redis
                            Hosts:
                            ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 286)
                            admin:          7.0.23
                            javascript:     8.7.6
                            | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                            | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                             system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
                            + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
                             system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
                             system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
                            + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
                             system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
                             system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
                             system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
                             system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
                             system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
                             system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
                             system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
                             system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
                             system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
                             system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
                             system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
                            + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            Active repo(s): stable
                            Used repository: stable
                            Adapter    "admin"        : 7.0.23   , installed 7.0.23
                            Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                            Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                            Adapter    "denon"        : 1.15.12  , installed 1.15.12
                            Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                            Adapter    "ham"          : 5.3.1    , installed 5.3.1
                            Adapter    "heos"         : 2.2.1    , installed 2.2.1
                            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                            Adapter    "linux-control": 1.1.5    , installed 1.1.5
                            Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                            Adapter    "nina"         : 0.0.25   , installed 0.0.25
                            Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
                            Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                            Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                            Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                            Adapter    "solax"        : 0.9.9    , installed 0.9.9
                            Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                            Adapter    "synology"     : 3.1.0    , installed 3.1.0
                            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                            Adapter    "traccar"      : 1.1.4    , installed 1.1.4
                            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                            Objects and States
                            Objects:        453
                            States:         337
                            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146671219  117/redis-server 12
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146671191  124/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146670661  1/systemd
                            tcp6       0      0 :::6556                 :::*                    LISTEN      0          146670958  1/systemd
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146671441  166/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146672892  237/io.web.0
                            tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146671220  117/redis-server 12
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          146671202  124/sshd: /usr/sbin
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          146670663  1/systemd
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146670662  1/systemd
                            udp6       0      0 :::111                  :::*                                0          146670664  1/systemd
                            2024-09-08 16:57:10.689  - info: javascript.0 (193) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                            2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all states
                            2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all objects
                            2024-09-08 16:57:11.031  - info: javascript.0 (193) received all states
                            2024-09-08 16:57:11.518  - info: javascript.0 (193) received all objects
                            Kurzfassung:
                                                   v.2024-09-07
                             Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                1001
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                            Mem:            2.1G        1.1G        1.0G        118K         62M        1.1G
                            Swap:             0B          0B          0B
                            Total:          2.1G        1.1G        1.0G
                                                   admin                   7.0.23
                            Objects type: redis
                            States  type: redis
                            Objects:                453
                            States:                 337
                            1.9M    /opt/iobroker/iobroker-data/objects.json.bak
                            221K    /opt/iobroker/iobroker-data/states.json.bak
                            Langfassung DE:
                            Skript v.2024-09-07
                            *** GRUNDSYSTEM ***
                             Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
                            CPU threads: 1
                                          Local time: Sun 2024-09-08 17:04:41 CEST
                                      Universal time: Sun 2024-09-08 15:04:41 UTC
                                            RTC time: n/a
                                     RTC in local TZ: no
                            thomas
                            HOME=/home/thomas
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:             0B          0B          0B
                                    2048 M total memory
                                    1018 M used memory
                                    1055 M active memory
                                       0 M inactive memory
                                     970 M free memory
                                       0 M buffer memory
                                      59 M swap cache
                                       0 M total swap
                                       0 M used swap
                                       0 M free swap
                            top - 17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
                            %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   2048.0 total,    968.4 free,   1020.2 used,     59.6 buff/cache
                            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1027.8 avail Mem
                            *** FILESYSTEM ***
                            /var:
                            1.1G    /var/
                            603M    /var/log
                            369M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                             Version table:
                            ioBroker Status
                            Objects type: redis
                            States  type: redis
                            Hosts:
                            ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 466)
                            admin:          7.0.23
                            javascript:     8.7.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        453
                            States:         337
                            Kurzfassung DE:
                                                   v.2024-09-07
                             Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                1001
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                            Swap:             0B          0B          0B
                                                   admin                   7.0.23
                            Objects type: redis
                            States  type: redis
                            Objects:                453
                            States:                 337
                              Thomas Braun Most Active @Homoran last edited by Thomas Braun
                              @homoran sagte in iob diag - Skript:
                              Nee, LXC-Eigenheit.
                              Bei Meister Mopper wird auch richtig Bookworm erkannt...
                              Meister Mopper T 3 Replies Last reply Reply Quote 1
                              • Meister Mopper
                                Jetzt mal die Variante als root user:
                                Script v.2024-09-07
                                *** BASE SYSTEM ***
                                 Virtualization: lxc
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                17:46:56 up 50 min,  1 user,  load average: 0.65, 0.48, 0.44
                                CPU threads: 1
                                              Local time: Sun 2024-09-08 17:46:56 CEST
                                          Universal time: Sun 2024-09-08 15:46:56 UTC
                                                RTC time: n/a
                                         RTC in local TZ: no
                                root
                                HOME=/root
                                GROUPS=root
                                iobroker
                                HOME=/home/iobroker
                                A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                                A root login is not required in most Linux Distributions.
                                Enter the username for a new user (Not 'root' and not 'iobroker'!): testuser
                                Enter the password for the new user:
                                Confirm the password for the new user:
                                Adding new user account...
                                Desktop:
                                Terminal:
                                *** MEMORY ***
                                Mem:            2.1G        1.1G        1.0G        110K         64M        1.1G
                                Swap:             0B          0B          0B
                                        2048 M total memory
                                        1022 M used memory
                                        1048 M active memory
                                           0 M inactive memory
                                         964 M free memory
                                           0 M buffer memory
                                          61 M swap cache
                                           0 M total swap
                                           0 M used swap
                                           0 M free swap
                                top - 17:47:31 up 50 min,  1 user,  load average: 0.41, 0.44, 0.43
                                Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                                MiB Mem :   2048.0 total,    962.5 free,   1024.3 used,     61.2 buff/cache
                                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1023.7 avail Mem
                                *** FILESYSTEM ***
                                tmpfs                        tmpfs     6.3G  104K  6.3G   1% /run
                                /var:
                                1.1G    /var/
                                603M    /var/log
                                369M    /var/lib
                                Archived and active journals take up 601.1M in the file system.
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                 Version table:
                                ioBroker Status
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 1351)
                                admin:          7.0.23
                                javascript:     8.7.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        453
                                States:         337
                                Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                Pending Updates: 0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146791638  5317/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146791954  5388/io.web.0
                                2024-09-08 17:24:26.513  - info: javascript.0 (193) terminating
                                2024-09-08 17:24:26.514  - info: javascript.0 (193) Terminated (NO_ERROR): Without reason
                                2024-09-08 17:24:26.518  - info: javascript.0 (193) Got terminate signal TERMINATE_YOURSELF
                                2024-09-08 17:24:27.005  - info: javascript.0 (193) terminating
                                2024-09-08 17:25:05.872  - info: javascript.0 (5358) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                2024-09-08 17:25:06.028  - info: javascript.0 (5358) requesting all states
                                2024-09-08 17:25:06.029  - info: javascript.0 (5358) requesting all objects
                                2024-09-08 17:25:06.044  - info: javascript.0 (5358) received all states
                                2024-09-08 17:25:06.261  - info: javascript.0 (5358) received all objects
                                Mein eingerichteter testuser hat auch die richtigen Rechte bekommen.
                                testuser@ioTest:~$ groups
                                testuser adm dialout sudo audio video plugdev users iobroker
                                  @Meister-Mopper
                                  @Shadowhunter23
                                  von welcher Konsole habt ihr das script gestartet? aus der Proxmox oder per ssh aus einem Terminal?
                                  Meister Mopper W 2 Replies Last reply Reply Quote 0
                                  • Meister Mopper
                                    Meister Mopper @TT-Tom last edited by
                                    @Meister-Mopper
                                    @Shadowhunter23
                                    ssh vom windows terminal
                                      Wildbill @TT-Tom last edited by
                                      @tt-tom Das sollte egal sein. Wenn Du Dich per SSH in einem LXC anmeldest landest Du im selben Userspace, als wenn Du Dich über die Proxmox-Konsole im LXC anmeldest.
                                      Gruss, Jürgen
                                        TT-Tom @Wildbill last edited by
                                        @wildbill
                                        ich nutze die Konsole von Proxmox nicht, da Safari mich da immer ärgert. Darum die Frage, ob es vielleicht kleine Abweichungen gibt.
                                        @Thomas-Braun nutzt du lsb_release -a zur Abfrage des OS?
                                        ich habe nur das Standard Template für den LXC genommen und folgende Pakete nach installiert.
                                        apt install -y curl gnupg ca-certificates sudo mc
                                        W Thomas Braun 2 Replies Last reply Reply Quote 0
                                        • Meister Mopper
                                          So, jetzt noch timedatectl:
                                          Auf Normalzeit umgestellt:
                                          Current default time zone: 'Etc/UTC'
                                          Local time is now:      Sun Sep  8 16:09:36 UTC 2024.
                                          Universal Time is now:  Sun Sep  8 16:09:36 UTC 2024.
                                          thomas@ioTest:~$
                                          Skript gestartet:
                                          Script v.2024-09-07
                                          *** BASE SYSTEM ***
                                           Virtualization: lxc
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          16:12:51 up 4 min,  2 users,  load average: 0.20, 0.27, 0.33
                                          CPU threads: 1
                                                        Local time: Sun 2024-09-08 16:12:51 UTC
                                                    Universal time: Sun 2024-09-08 16:12:51 UTC
                                                          RTC time: n/a
                                                         Time zone: Etc/UTC (UTC, +0000)
                                                   RTC in local TZ: no
                                          Timezone is probably wrong. Do you want to reconfigure it? (y/n)
                                          Setting up timezone
                                          Enter the timezone for the server (default is Europe/Berlin):
                                          Setting up time synchronization with systemd-timesyncd
                                          thomas
                                          HOME=/home/thomas
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            2.1G        1.1G        1.1G        118K         10M        1.1G
                                          Swap:             0B          0B          0B
                                          Total:          2.1G        1.1G        1.1G
                                                  2048 M total memory
                                                  1019 M used memory
                                                  1009 M active memory
                                                     0 M inactive memory
                                                  1018 M free memory
                                                     0 M buffer memory
                                                    10 M swap cache
                                                     0 M total swap
                                                     0 M used swap
                                                     0 M free swap
                                          top - 18:13:07 up 4 min,  2 users,  load average: 0.22, 0.27, 0.33
                                          Tasks:  28 total,   1 running,  27 sleeping,   0 stopped,   0 zombie
                                          MiB Mem :   2048.0 total,   1016.4 free,   1021.2 used,     10.6 buff/cache
                                          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1026.8 avail Mem
                                          *** FILESYSTEM ***
                                          /var:
                                          1.1G    /var/
                                          603M    /var/log
                                          369M    /var/lib
                                          Archived and active journals take up 601.2M in the file system.
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                           Version table:
                                          ioBroker Status
                                          Objects type: redis
                                          States  type: redis
                                          Hosts:
                                          admin:          7.0.23
                                          javascript:     8.7.6
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        453
                                          States:         337
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146965130  1/init
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146967666  123/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146967727  113/redis-server 12
                                          tcp6       0      0 :::111                  :::*                    LISTEN      0          146965132  1/init
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          146967677  123/sshd: /usr/sbin
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146968429  237/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146967920  151/io.admin.0
                                          tcp6       0      0 :::6556                 :::*                    LISTEN      0          146965446  1/init
                                          tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146967728  113/redis-server 12
                                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146965131  1/init
                                          udp6       0      0 :::111                  :::*                                0          146965133  1/init
                                          2024-09-08 17:56:50.232  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                          2024-09-08 17:56:50.378  - info: javascript.0 (192) requesting all states
                                          2024-09-08 17:56:50.379  - info: javascript.0 (192) requesting all objects
                                          2024-09-08 17:56:50.395  - info: javascript.0 (192) received all states
                                          2024-09-08 17:56:50.615  - info: javascript.0 (192) received all objects
                                          2024-09-08 17:58:03.057  - info: javascript.0 (192) terminating
                                          2024-09-08 17:58:03.060  - info: javascript.0 (192) Terminated (NO_ERROR): Without reason
                                          2024-09-08 17:58:03.071  - info: javascript.0 (192) Got terminate signal TERMINATE_YOURSELF
                                          2024-09-08 17:58:03.545  - info: javascript.0 (192) terminating
                                          2024-09-08 18:08:28.307  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                          2024-09-08 18:08:28.451  - info: javascript.0 (192) requesting all states
                                          2024-09-08 18:08:28.452  - info: javascript.0 (192) requesting all objects
                                          2024-09-08 18:08:28.468  - info: javascript.0 (192) received all states
                                          2024-09-08 18:08:28.700  - info: javascript.0 (192) received all objects
                                          Kontrolle:
                                          thomas@ioTest:~$ timedatectl
                                                         Local time: So 2024-09-08 18:15:10 CEST
                                                     Universal time: So 2024-09-08 16:15:10 UTC
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          Ich sag mal: Perfekt!
                                            @tt-tom Läuft bei mir mit Safari problemlos. Wobei ich auch lieber direkt per SSH-Terminal einsteige, da dann manche Funktionalität (z.B. Menüs in mc) funktionieren, die die Proxmox-Konsole nicht hergibt. Aber alle Befehle, die man im Terminal direkt eingibt, ergeben dasselbe. Vorausgesetzt natürlich, man meldet sich per SSH oder in der Proxmox-Konsole mit demselben User an.
                                            Aber genug OT.
                                            Gruss, Jürgen
                                            738
                                            153759
