    4. iob diag - Skript
    iob diag - Skript
      Thomas Braun Most Active @Homoran last edited by Thomas Braun
      @homoran sagte in iob diag - Skript:
      fehlende Gruppe für den user (adm?)
      Nee, LXC-Eigenheit.
      Bei Meister Mopper wird auch richtig Bookworm erkannt...
      Meister Mopper T 3 Replies Last reply Reply Quote 1
      • Meister Mopper
        Meister Mopper @Thomas Braun last edited by
        Jetzt mal die Variante als root user:
        Script v.2024-09-07
        *** BASE SYSTEM ***
        Static hostname: ioTest
              Icon name: computer-container
                Chassis: container ☐
         Virtualization: lxc
                 Kernel: Linux 6.8.12-1-pve
           Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
        17:46:56 up 50 min,  1 user,  load average: 0.65, 0.48, 0.44
        CPU threads: 1
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                      Local time: Sun 2024-09-08 17:46:56 CEST
                  Universal time: Sun 2024-09-08 15:46:56 UTC
                        RTC time: n/a
                     NTP service: inactive
                 RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev redis
        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
        A root login is not required in most Linux Distributions.
        Enter the username for a new user (Not 'root' and not 'iobroker'!): testuser
        Enter the password for the new user:
        Confirm the password for the new user:
        Adding new user account...
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            2.1G        1.1G        1.0G        110K         64M        1.1G
        Swap:             0B          0B          0B
        Total:          2.1G        1.1G        1.0G
        Active iob-Instances:   5
                2048 M total memory
                1022 M used memory
                1048 M active memory
                   0 M inactive memory
                 964 M free memory
                   0 M buffer memory
                  61 M swap cache
                   0 M total swap
                   0 M used swap
                   0 M free swap
        top - 17:47:31 up 50 min,  1 user,  load average: 0.41, 0.44, 0.43
        Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   2048.0 total,    962.5 free,   1024.3 used,     61.2 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1023.7 avail Mem
        *** FAILED SERVICES ***
         UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                   Type      Size  Used Avail Use% Mounted on
        rpool/data/subvol-300-disk-0 zfs        12G  6.0G  6.1G  50% /
        none                         tmpfs     492K  4.0K  488K   1% /dev
        udev                         devtmpfs   16G     0   16G   0% /dev/tty
        tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
        tmpfs                        tmpfs     6.3G  104K  6.3G   1% /run
        tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
        Show mounted filesystems:
        TARGET SOURCE                       FSTYPE OPTIONS
        /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
        /var:
        1.1G    /var/
        603M    /var/log
        602M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
        369M    /var/lib
        Archived and active journals take up 601.1M in the file system.
        /opt/iobroker/backups:
        489M    /opt/iobroker/backups/
        8.5K    /opt/iobroker/backups/scripte0
        /opt/iobroker/iobroker-data:
        164M    /opt/iobroker/iobroker-data/
        105M    /opt/iobroker/iobroker-data/files
        47M     /opt/iobroker/iobroker-data/files/javascript.admin
        40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
        3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
        3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
        3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
        3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
         Installed: 20.17.0-1nodesource1
         Candidate: 20.17.0-1nodesource1
         Version table:
        *** 20.17.0-1nodesource1 1001
               500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               100 /var/lib/dpkg/status
            20.16.0-1nodesource1 1001
            20.15.1-1nodesource1 1001
            20.15.0-1nodesource1 1001
            20.14.0-1nodesource1 1001
            20.13.1-1nodesource1 1001
            20.13.0-1nodesource1 1001
            20.12.2-1nodesource1 1001
            20.12.1-1nodesource1 1001
            20.12.0-1nodesource1 1001
            20.11.1-1nodesource1 1001
            20.11.0-1nodesource1 1001
            20.10.0-1nodesource1 1001
            20.9.0-1nodesource1 1001
            20.8.1-1nodesource1 1001
            20.8.0-1nodesource1 1001
            20.7.0-1nodesource1 1001
            20.6.1-1nodesource1 1001
            20.6.0-1nodesource1 1001
            20.5.1-1nodesource1 1001
            20.5.0-1nodesource1 1001
            20.4.0-1nodesource1 1001
            20.3.1-1nodesource1 1001
            20.3.0-1nodesource1 1001
            20.2.0-1nodesource1 1001
            20.1.0-1nodesource1 1001
            20.0.0-1nodesource1 1001
            18.19.0+dfsg-6~deb12u2 500
               500 http://deb.debian.org/debian bookworm/main amd64 Packages
            18.19.0+dfsg-6~deb12u1 500
               500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: redis
        States  type: redis
        Hosts:
        ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 1351)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.0.23
        javascript:     8.7.6
        nodejs modules from github:     2
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
         system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
        + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
         system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
         system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
        + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
         system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
         system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
         system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
         system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
         system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
         system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
         system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
         system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
         system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
         system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
         system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
        + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.0.23   , installed 7.0.23
        Adapter    "backitup"     : 3.0.19   , installed 3.0.19
        Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
        Adapter    "denon"        : 1.15.12  , installed 1.15.12
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "heos"         : 2.2.1    , installed 2.2.1
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
        Adapter    "samsung"      : 0.6.0    , installed 0.6.0
        Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solax"        : 0.9.9    , installed 0.9.9
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "traccar"      : 1.1.4    , installed 1.1.4
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        453
        States:         337
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146671219  117/redis-server 12
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146671191  124/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146670661  1/systemd
        tcp6       0      0 :::6556                 :::*                    LISTEN      0          146670958  1/systemd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146791638  5317/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146791954  5388/io.web.0
        tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146671220  117/redis-server 12
        tcp6       0      0 :::22                   :::*                    LISTEN      0          146671202  124/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          146670663  1/systemd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146670662  1/systemd
        udp6       0      0 :::111                  :::*                                0          146670664  1/systemd
        2024-09-08 16:57:10.689  - info: javascript.0 (193) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
        2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all states
        2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all objects
        2024-09-08 16:57:11.031  - info: javascript.0 (193) received all states
        2024-09-08 16:57:11.518  - info: javascript.0 (193) received all objects
        2024-09-08 17:24:26.513  - info: javascript.0 (193) terminating
        2024-09-08 17:24:26.514  - info: javascript.0 (193) Terminated (NO_ERROR): Without reason
        2024-09-08 17:24:26.518  - info: javascript.0 (193) Got terminate signal TERMINATE_YOURSELF
        2024-09-08 17:24:27.005  - info: javascript.0 (193) terminating
        2024-09-08 17:25:05.872  - info: javascript.0 (5358) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
        2024-09-08 17:25:06.028  - info: javascript.0 (5358) requesting all states
        2024-09-08 17:25:06.029  - info: javascript.0 (5358) requesting all objects
        2024-09-08 17:25:06.044  - info: javascript.0 (5358) received all states
        2024-09-08 17:25:06.261  - info: javascript.0 (5358) received all objects
        Mein eingerichteter testuser hat auch die richtigen Rechte bekommen.
        testuser@ioTest:~$ groups
        testuser adm dialout sudo audio video plugdev users iobroker
          TT-Tom @Thomas Braun last edited by
          @Meister-Mopper
          @Shadowhunter23
          von welcher Konsole habt ihr das script gestartet? aus der Proxmox oder per ssh aus einem Terminal?
          Meister Mopper W 2 Replies Last reply Reply Quote 0
          • Meister Mopper
            Meister Mopper @TT-Tom last edited by
            @tt-tom sagte in iob diag - Skript:
            @Meister-Mopper
            @Shadowhunter23
            ssh vom windows terminal
              Wildbill @TT-Tom last edited by
              @tt-tom Das sollte egal sein. Wenn Du Dich per SSH in einem LXC anmeldest landest Du im selben Userspace, als wenn Du Dich über die Proxmox-Konsole im LXC anmeldest.
              Gruss, Jürgen
                TT-Tom @Wildbill last edited by
                @wildbill
                ich nutze die Konsole von Proxmox nicht, da Safari mich da immer ärgert. Darum die Frage, ob es vielleicht kleine Abweichungen gibt.
                @Thomas-Braun nutzt du lsb_release -a zur Abfrage des OS?
                ich habe nur das Standard Template für den LXC genommen und folgende Pakete nach installiert.
                apt install -y curl gnupg ca-certificates sudo mc
                W Thomas Braun 2 Replies Last reply Reply Quote 0
                • Meister Mopper
                  So, jetzt noch timedatectl:
                  Auf Normalzeit umgestellt:
                  Current default time zone: 'Etc/UTC'
                  Local time is now:      Sun Sep  8 16:09:36 UTC 2024.
                  Universal Time is now:  Sun Sep  8 16:09:36 UTC 2024.
                  thomas@ioTest:~$
                  Skript gestartet:
                  Script v.2024-09-07
                  *** BASE SYSTEM ***
                   Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  16:12:51 up 4 min,  2 users,  load average: 0.20, 0.27, 0.33
                  CPU threads: 1
                                Local time: Sun 2024-09-08 16:12:51 UTC
                            Universal time: Sun 2024-09-08 16:12:51 UTC
                                  RTC time: n/a
                                 Time zone: Etc/UTC (UTC, +0000)
                           RTC in local TZ: no
                  Timezone is probably wrong. Do you want to reconfigure it? (y/n)
                  Setting up timezone
                  Enter the timezone for the server (default is Europe/Berlin):
                  Setting up time synchronization with systemd-timesyncd
                  thomas
                  HOME=/home/thomas
                  GROUPS=thomas adm sudo iobroker
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            2.1G        1.1G        1.1G        118K         10M        1.1G
                  Swap:             0B          0B          0B
                  Total:          2.1G        1.1G        1.1G
                          2048 M total memory
                          1019 M used memory
                          1009 M active memory
                             0 M inactive memory
                          1018 M free memory
                             0 M buffer memory
                            10 M swap cache
                             0 M total swap
                             0 M used swap
                             0 M free swap
                  top - 18:13:07 up 4 min,  2 users,  load average: 0.22, 0.27, 0.33
                  Tasks:  28 total,   1 running,  27 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   2048.0 total,   1016.4 free,   1021.2 used,     10.6 buff/cache
                  MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1026.8 avail Mem
                  *** FILESYSTEM ***
                  tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
                  /var:
                  1.1G    /var/
                  603M    /var/log
                  369M    /var/lib
                  Archived and active journals take up 601.2M in the file system.
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                   Version table:
                  ioBroker Status
                  Objects type: redis
                  States  type: redis
                  Hosts:
                  ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 286)
                  admin:          7.0.23
                  javascript:     8.7.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        453
                  States:         337
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146965130  1/init
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146967666  123/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146967727  113/redis-server 12
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          146965132  1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          146967677  123/sshd: /usr/sbin
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146968429  237/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146967920  151/io.admin.0
                  tcp6       0      0 :::6556                 :::*                    LISTEN      0          146965446  1/init
                  tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146967728  113/redis-server 12
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146965131  1/init
                  udp6       0      0 :::111                  :::*                                0          146965133  1/init
                  2024-09-08 17:56:50.232  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                  2024-09-08 17:56:50.378  - info: javascript.0 (192) requesting all states
                  2024-09-08 17:56:50.379  - info: javascript.0 (192) requesting all objects
                  2024-09-08 17:56:50.395  - info: javascript.0 (192) received all states
                  2024-09-08 17:56:50.615  - info: javascript.0 (192) received all objects
                  2024-09-08 17:58:03.057  - info: javascript.0 (192) terminating
                  2024-09-08 17:58:03.060  - info: javascript.0 (192) Terminated (NO_ERROR): Without reason
                  2024-09-08 17:58:03.071  - info: javascript.0 (192) Got terminate signal TERMINATE_YOURSELF
                  2024-09-08 17:58:03.545  - info: javascript.0 (192) terminating
                  2024-09-08 18:08:28.307  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                  2024-09-08 18:08:28.451  - info: javascript.0 (192) requesting all states
                  2024-09-08 18:08:28.452  - info: javascript.0 (192) requesting all objects
                  2024-09-08 18:08:28.468  - info: javascript.0 (192) received all states
                  2024-09-08 18:08:28.700  - info: javascript.0 (192) received all objects
                  Kontrolle:
                  thomas@ioTest:~$ timedatectl
                                 Local time: So 2024-09-08 18:15:10 CEST
                             Universal time: So 2024-09-08 16:15:10 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  Ich sag mal: Perfekt!
                    @tt-tom Läuft bei mir mit Safari problemlos. Wobei ich auch lieber direkt per SSH-Terminal einsteige, da dann manche Funktionalität (z.B. Menüs in mc) funktionieren, die die Proxmox-Konsole nicht hergibt. Aber alle Befehle, die man im Terminal direkt eingibt, ergeben dasselbe. Vorausgesetzt natürlich, man meldet sich per SSH oder in der Proxmox-Konsole mit demselben User an.
                    Aber genug OT.
                    Gruss, Jürgen
                      TT-Tom last edited by TT-Tom
                      @Thomas-Braun
                      ein Auszug vom User root. Ich habe ein LXC mit Debian 12 neu aufgesetzt und nur den root user. Iobroker habe ich jetzt nicht installiert, wollte nur das Anlegen eines Standarduser testen. Hat so nicht ganz funktioniert, wenn ich es heute noch schaffe, lege ich eine komplette iobroker Installation als root an und teste dann nochmal.
                      root
                      HOME=/root
                      GROUPS=root
                      js-controller is not running
                      Enter the username for a new user (Not 'root' and not 'iobroker'!): tom
                      useradd: group 'iobroker' does not exist
                      chpasswd: (user tom) pam_chauthtok() failed, error:
                      Authentication token manipulation error
                      chpasswd: (line 1, user tom) password not changed
                      T Thomas Braun 2 Replies Last reply Reply Quote 1
                        Thomas Braun Most Active @TT-Tom last edited by
                        Jein, -a gibt alles aus, ich lese den Codename per
                        lsb_release -sc
                        aus. Scheint also kein default package zu sein.
                          TT-Tom @TT-Tom last edited by TT-Tom
                          @tt-tom
                          @Thomas-Braun
                          nochmal mit iobroker Installation. User tom wurde angelegt und die Timezone wurde geändert.
                          root@testsystem:~# ./iob_diag.sh
                          You should not be root on your system!
                          Better use your standard user!
                          *** ioBroker Diagnosis ***
                          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                          https://forum.iobroker.net
                          Just copy and paste the Summary Page, including the ``` characters at start and end.
                          It helps us to help you!
                          Press any key to continue
                          ========== Start marking the full check here ===========
                          ```bash
                          Script v.2024-09-07
                          *** BASE SYSTEM ***
                           Static hostname: testsystem
                            Virtualization: lxc
                          Package configuration
                                            ┌───────────────────────┤ Configuring tzdata ├───────────────────────┐
                                            │ Please select the city or region corresponding to your time zone.  │
                                            │ Time zone:                                                         │
                                            │                           Amsterdam       -                        │
                                            │                           Andorra         ▒                        │
                                            │                           Astrakhan       0                        │
                                            │                           Athens          ▒                        │
                                            │                           Belfast         ▒                        │
                                            │                           Belgrade        ▒                        │
                                            │                           Berlin          ▒                        │
                                            │                           Bratislava      ▒                        │
                                            │                           Brussels        ▒                        │
                                            │                           Bucharest       ▒                        │
                                            │                           Budapest        ▒                        │
                                            │                           Busingen        .                        │
                                            │                 <Ok>                     <Cancel>                  │
                          Current default time zone: 'Europe/Berlin'
                          Local time is now:      Sun Sep  8 20:07:44 CEST 2024.
                          Universal Time is now:  Sun Sep  8 18:07:44 UTC 2024.
                          root
                          HOME=/root
                          GROUPS=root
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Mem:            2.1G        284M        1.6G        118K        229M        1.9G
                          Swap:           1.1G          0B        1.1G
                          Total:          3.2G        284M        2.7G
                          Active iob-Instances:   4
                                   2048 M total memory
                                    271 M used memory
                                    399 M active memory
                                     66 M inactive memory
                                   1557 M free memory
                                      0 M buffer memory
                                    219 M swap cache
                                   1024 M total swap
                                      0 M used swap
                                   1024 M free swap
                          top - 20:08:01 up 5 min,  1 user,  load average: 0.04, 0.17, 0.16
                          Tasks:  25 total,   1 running,  24 sleeping,   0 stopped,   0 zombie
                          MiB Mem :   2048.0 total,   1555.1 free,    273.6 used,    219.4 buff/cache
                          MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1774.4 avail Mem
                          2 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/mapper/pve-vm--106--disk--0 ext4      7.8G  2.1G  5.3G  29% /
                          udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                          tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                          tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
                          /      /dev/mapper/pve-vm--106--disk--0 ext4   rw,relatime,stripe=16
                          /var:
                          400M    /var/
                          237M    /var/cache
                          234M    /var/cache/apt
                          158M    /var/cache/apt/archives
                          146M    /var/lib
                          Archived and active journals take up 16.0M in the file system.
                          4.0K    /opt/iobroker/backups/
                          62M     /opt/iobroker/iobroker-data/
                          57M     /opt/iobroker/iobroker-data/files
                          31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                          8.4M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.70cad8ba.js
                          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                          5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                          5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                          5.0M    /opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                                  500 http://security.debian.org bookworm-security/main amd64 Packages
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          testsystem          testsystem (version: 6.0.11, hostname: testsystem    , alive, uptime: 316)
                          admin:          7.0.23
                          javascript:     "javascript" not found
                          nodejs modules from github:     0
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : testsystem                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : testsystem                               -  enabled
                          + system.adapter.discovery.0              : discovery             : testsystem                               -  enabled
                          + instance is alive
                          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                          Objects and States
                          Objects:        148
                          States:         103
                          Hit:1 http://security.debian.org bookworm-security InRelease
                          Hit:2 http://deb.debian.org/debian bookworm InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       80745598   155/iobroker.js-con
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       80745603   155/iobroker.js-con
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          80743343   319/master
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          80742867   1/init
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       80751205   436/io.admin.0
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          80743344   319/master
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          80742219   1/init
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          80742869   1/init
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          80742305   95/dhclient
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          80742868   1/init
                          udp6       0      0 :::111                  :::*                                0          80742870   1/init
                          2024-09-08 18:02:43.093  - info: backitup.0 (371) starting. Version 3.0.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                          2024-09-08 18:02:43.111  - info: backitup.0 (371) [iobroker] backup will be activated at 02:48 every 1 day(s)
                          2024-09-08 18:02:46.482  - info: host.testsystem instance system.adapter.discovery.0 in version "4.5.0" started with pid 386
                          2024-09-08 18:02:47.002  - info: discovery.0 (386) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                          2024-09-08 18:03:34.073  - info: admin.0 (330) ==> Connected system.user.admin from ::ffff:192.168.178.12
                          2024-09-08 18:04:30.739  - info: host.testsystem stopInstance system.adapter.admin.0 (force=false, process=true)
                          2024-09-08 18:04:30.741  - info: admin.0 (330) Got terminate signal TERMINATE_YOURSELF
                          2024-09-08 18:04:30.741  - info: admin.0 (330) terminating http server on port 8081
                          2024-09-08 18:04:30.743  - info: admin.0 (330) terminating
                          2024-09-08 18:04:30.743  - info: admin.0 (330) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-09-08 18:04:30.781  - info: host.testsystem stopInstance system.adapter.admin.0 send kill signal
                          2024-09-08 18:04:31.244  - info: admin.0 (330) terminating
                          2024-09-08 18:04:31.281  - info: host.testsystem instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-09-08 18:04:34.403  - info: host.testsystem instance system.adapter.admin.0 in version "7.0.23" started with pid 436
                          2024-09-08 18:04:35.068  - info: admin.0 (436) starting. Version 7.0.23 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                          2024-09-08 18:04:35.079  - info: admin.0 (436) requesting all objects
                          2024-09-08 18:04:35.285  - info: admin.0 (436) received all objects
                          2024-09-08 18:04:35.382  - info: admin.0 (436) socket.io server listening on port 8081
                          2024-09-08 18:04:35.383  - info: admin.0 (436) http server listening on port 8081
                          2024-09-08 18:04:35.383  - info: admin.0 (436) Use link "http://127.0.0.1:8081" to configure.
                          2024-09-08 18:04:37.576  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                          2024-09-08 18:04:37.615  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                          2024-09-08 18:04:37.645  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                          2024-09-08 18:04:45.342  - info: admin.0 (436) ==> Connected system.user.admin from ::ffff:192.168.178.12
                          2024-09-08 18:04:57.657  - info: admin.0 (436) <== Disconnect system.user.admin from ::ffff:192.168.178.12 admin
                          iob diag has finished.
                            @tt-tom
                            Den
                            kann ich mir gerade nicht so wirklich erklären. Zumal es bei @Meister-Mopper alles wie gedacht funktioniert...
                              Also mit vorheriger Installation des ioBroker funktioniert es?
                                ja mit iobroker ist alles sauber durchgelaufen.
                                  Na dann....
                                  Das Skript kommt ja im Normalfall auch erst mit dem ioBroker auf das System.
                                    TT-Tom @Thomas Braun last edited by TT-Tom
                                    Den
                                    der User konnte ja nicht der Gruppe iobroker zugeordnet werden.
                                      Das sollte aber nicht der Grund für die Meldung sein.
                                      Wie dem auch sei, das Skript ruft man ja in der Realität nur bei vorhandener Installation des ioBrokers auf.
                                        Knirpso @Thomas Braun last edited by Knirpso
                                        Anbei noch der gewünschte Log aus https://forum.iobroker.net/topic/76922/schaltverhalten-iot-adapter-mit-alexa/4
                                        Script v.2024-09-16
                                        *** BASE SYSTEM ***
                                        Hardware Vendor : Synology Inc.
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        Docker          : v9.1.2
                                        Virtualization  : Docker
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
                                        CPU threads: 8
                                        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                        Tue Sep 17 15:25:15 UTC 2024
                                        Tue Sep 17 17:25:15 CEST 2024
                                        CEST +0200
                                        Etc/UTC
                                        root
                                        HOME=/root
                                        GROUPS=root
                                        iobroker
                                        HOME=/opt/iobroker
                                        Display-Server: true
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Mem:             67G        7.4G        1.0G        215M         59G         59G
                                        Swap:            42G        307M         42G
                                        Total:          109G        7.7G         43G
                                        Active iob-Instances:   17
                                                64084 M total memory
                                                 7067 M used memory
                                                 7965 M active memory
                                                52969 M inactive memory
                                                  971 M free memory
                                                   84 M buffer memory
                                                56764 M swap cache
                                                40499 M total swap
                                                  293 M used swap
                                                40206 M free swap
                                        top - 17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
                                        Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
                                        MiB Mem :  64084.8 total,    969.7 free,   7068.6 used,  56848.9 buff/cache
                                        MiB Swap:  40499.9 total,  40206.6 free,    293.3 used.  57016.2 avail Mem
                                        *** FILESYSTEM ***
                                        /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /
                                        tmpfs          tmpfs   64M     0   64M   0% /dev
                                        tmpfs          tmpfs   32G     0   32G   0% /sys/fs/cgroup
                                        shm            tmpfs   64M     0   64M   0% /dev/shm
                                        /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /opt/iobroker
                                        /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /etc/hosts
                                        tmpfs          tmpfs   32G     0   32G   0% /proc/acpi
                                        tmpfs          tmpfs   32G     0   32G   0% /proc/scsi
                                        tmpfs          tmpfs   32G     0   32G   0% /sys/firmware
                                        /                  /dev/synorbd_1[/@syno/@docker/btrfs/subvolumes/43c485044ed9f1e230e9f082f08e839ece82e19c0db5e0e02d5f344f954dfa66]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                        |-/opt/iobroker    /dev/synorbd_1[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                        |-/etc/resolv.conf /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                        |-/etc/hostname    /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                        `-/etc/hosts       /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                                        /var:
                                        34M     /var/
                                        32M     /var/lib
                                        19M     /var/lib/apt/lists
                                        19M     /var/lib/apt
                                        13M     /var/lib/dpkg
                                        33M     /opt/iobroker/backups/
                                        1.1G    /opt/iobroker/iobroker-data/
                                        756M    /opt/iobroker/iobroker-data/files
                                        441M    /opt/iobroker/iobroker-data/files/javascript.admin
                                        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        117M    /opt/iobroker/iobroker-data/states.jsonl
                                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                                        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                                        USB-Devices by-id:
                                        HINT:
                                        Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        /dev/ttyACM0
                                        HINT:
                                        Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        /dev/ttyACM0
                                        /usr/bin/nodejs         v18.20.4
                                        /usr/bin/node           v18.20.4
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.28.0
                                        nodejs:
                                          Installed: 18.20.4-1nodesource1
                                          Candidate: 18.20.4-1nodesource1
                                          Version table:
                                         *** 18.20.4-1nodesource1 1001
                                               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                             18.20.3-1nodesource1 1001
                                             18.20.2-1nodesource1 1001
                                             18.20.1-1nodesource1 1001
                                             18.20.0-1nodesource1 1001
                                             18.19.1-1nodesource1 1001
                                                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                                             18.19.0-1nodesource1 1001
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1308286)
                                        slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 268408)
                                        admin:          7.0.23
                                        javascript:     8.7.6
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                          system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                                        + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                        + system.adapter.mystrom.0                : mystrom               : iobroker                                 -  enabled
                                        + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                                        + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
                                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                                        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                        + system.adapter.zigbee.1                 : zigbee                : slave1-raspberrypi                       -  enabled, port: /dev/ttyACM0
                                        + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                        + instance is alive
                                        │ (index) │   name   │                           url                           │ auto upgrade │
                                        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                                        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                        Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                        Adapter    "roborock"     : 0.6.4    , installed 0.6.4
                                        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                                        Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                        Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
                                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                        Objects and States
                                        Objects:        3786
                                        States:         2647
                                        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Pending Updates: 26
                                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3946312486 -
                                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3946312479 -
                                        tcp        0      0 127.0.0.11:42340        0.0.0.0:*               LISTEN      0          3946306647 -
                                        tcp6       0      0 :::6824                 :::*                    LISTEN      1000       78218444   -
                                        tcp6       0      0 :::8554                 :::*                    LISTEN      1000       78220248   -
                                        tcp6       0      0 :::8555                 :::*                    LISTEN      1000       78220249   -
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3946310901 -
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3946317922 -
                                        tcp6       0      0 :::8083                 :::*                    LISTEN      1000       3946324298 -
                                        tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3946324745 -
                                        tcp6       0      0 :::1984                 :::*                    LISTEN      1000       78243001   -
                                        tcp6       0      0 :::7906                 :::*                    LISTEN      1000       78218445   -
                                        udp        0      0 127.0.0.11:56032        0.0.0.0:*                           0          3946306646 -
                                        udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1000       38730773   -
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       3946311323 -
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       3946311324 -
                                        2024-09-17 17:01:23.903  - error: mystrom.0 (386) 200
                                        2024-09-17 17:01:23.903  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
                                        2024-09-17 17:01:23.903  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                        2024-09-17 17:01:23.904  - info: mystrom.0 (386) Set update interval for FCF5C418FF54 to 60
                                        2024-09-17 17:01:23.920  - info: mystrom.0 (386) Set update interval for FCF5C418FB0C to 60
                                        2024-09-17 17:01:23.922  - error: mystrom.0 (386) 200
                                        2024-09-17 17:01:23.922  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
                                        2024-09-17 17:01:23.922  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                        2024-09-17 17:01:23.923  - error: mystrom.0 (386) 200
                                        2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
                                        2024-09-17 17:01:23.924  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                        2024-09-17 17:01:23.924  - error: mystrom.0 (386) 200
                                        2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
                                        2024-09-17 17:01:23.930  - error: mystrom.0 (386) 200
                                        2024-09-17 17:01:23.930  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
                                        2024-09-17 17:01:23.930  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                        2024-09-17 17:01:23.936  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
                                        2024-09-17 17:01:23.937  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
                                        2024-09-17 17:01:23.941  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                        2024-09-17 17:01:23.942  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                        2024-09-17 17:01:23.962  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                        2024-09-17 17:01:23.966  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                        2024-09-17 17:03:36.237  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                                        Edit: Log von Skriptversion 2024-09-16 angehängt.
                                          Thomas Braun Most Active @Knirpso last edited by
                                          @knirpso Bitte die aktuelle Version 2024-09-16 verwenden.
                                            Thomas Braun Most Active @Knirpso last edited by Thomas Braun
                                            @knirpso
                                            Hm. Kannst du mal die Ausgabe von
                                            pgrep -l '[X]|[w]ayland|X11|wayfire'
                                            posten?
                                            Oder auch die anderen Dockeristen.
                                            738
                                            153474
