    4. Puppeteer Adapter
    Puppeteer Adapter
    • Jensen
      Jensen @Jensen last edited by
      Ich habe also den Puppeteer Adapter über die Console wieder deinstalliert.
      Bei der Vorbereitung einer Neuinstallation wollte ich alle Scripte exportieren, da kommt dann sowas:
      Jensen 1 Reply Last reply Reply Quote 0
      • Jensen
        Jensen @Jensen last edited by Jensen
        iob fix
        c:\ioBroker>iob fix
        Need to install the following packages:
        @iobroker/fix@6.0.1
        Ok to proceed? (y) y
        Windows installation starting... (fixing = true)
        NPM version: 10.8.3
        No path given, using c:\ioBroker\iobroker-data
        Compressing c:\ioBroker\iobroker-data\states.jsonl
        Cannot compress states.jsonl: Error: Failed to lock DB file "c:\ioBroker\iobroker-data\states.jsonl"!
            at JsonlDB.open (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@alcalzone\jsonl-db\build\lib\db.js:185:19)
            at async compressDB (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:37:9)
            at async main (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:78:17)
        Compressing c:\ioBroker\iobroker-data\objects.jsonl
        Cannot compress objects.jsonl: Error: Failed to lock DB file "c:\ioBroker\iobroker-data\objects.jsonl"!
            at async main (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:93:17)
        No relevant JSONL files found to compress, skip
        NPM version: 10.8.3
        Write "iobroker start" to start the ioBroker
        npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "c:/ioBroker"
        npm error code EBUSY
        npm error syscall rename
        npm error path c:\ioBroker\node_modules\iobroker.admin
        npm error dest c:\ioBroker\node_modules\.iobroker.admin-FjHuUvU7
        npm error errno -4082
        npm error EBUSY: resource busy or locked, rename 'c:\ioBroker\node_modules\iobroker.admin' -> 'c:\ioBroker\node_modules\.iobroker.admin-FjHuUvU7'
        npm error A complete log of this run can be found in: C:\Users\IpsJensen\AppData\Local\npm-cache\_logs\2024-09-07T06_21_00_662Z-debug-0.log
        Error when installing dotenv Library: Error: Command failed: npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "c:/ioBroker"
        sieht auch nicht berauschend aus
        • Jensen
          Und was mir noch auffällt, ich habe kein admin.0, sondern nur ein admin.1
          Das ist doch auch nicht normal, oder?
          • Jensen
            Nach Einrichten der Istanz admin.0 und Löschen von admin.1 kann ich die Skripte jetzt wieder problemlos exportieren.
            • OliverIO
              OliverIO @Jensen last edited by
              @jensen
              Schon seltsam.
              Er meckert das ein bestimmtes Modul nicht gefunden worden ist.
              Neuinstallation macht Sinn. Es sind Zuviel kleinklein Probleme
              Und ob das dann später noch stabil läuft ist auch keine Garantie.
              Was für Hardware und Festplatte hast du im Einsatz?
              • Jensen
                Jensen @OliverIO last edited by
                @oliverio
                NUC i5 mit SSD
                • OliverIO
                  @jensen
                  Ne dann ist es eher unwahrscheinlich das die Platte was hat
                  • Jensen
                    @oliverio
                    So, ich habe den Sonntag für eine Neuinstallation genutzt.
                    ioBroker neu installiert, die Basics eingerichtet, dann ein Restore, dann hier und da ein wenig geradeziehen, alles halbwegs stressfrei.
                    Als dann alles wieder lief und ich keine Probleme mehr sehen konnte, wieder den Puppeteer Adapter installiert, direkt von der Adapterseite, alles problemlos und ohne Fehlermeldungen.
                    Insofern hat die Neuinstallation schon mal was gebracht.
                    Leider kann ich aber immer noch keine Bilder erzeugen.
                    Der Adapter liefert folgende Fehlermeldung:
                    • bei den Flot Charts
                    Could not take screenshot of "http://localhost:8082/flot/index.html?timeType=static&relativeEnd=now&range=10&aggregateType=count&aggregateSpan=300&hoverDetail=false&useComma=false&zoom=false&noedit=true&animation=0&l%5B0%5D%5Bid%5D=javascript.0.Haus.Verbrauch&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=6&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=0&l%5B0%5D%5BafterComma%5D=2&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B1%5D%5Bid%5D=javascript.0.Haus.Einspeisung&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=0&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B2%5D%5Bid%5D=javascript.0.PV.TriPower.PV-Leistung_kW&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%23ffc300&l%5B2%5D%5Bthickness%5D=1&l%5B2%5D%5Bshadowsize%5D=0&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=2&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B3%5D%5Bid%5D=modbus.1.inputRegisters.13350_TO_TotalDemand&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%2352a0ff&l%5B3%5D%5Bthickness%5D=1&l%5B3%5D%5Bshadowsize%5D=0&l%5B3%5D%5Bname%5D=PV+Demand&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=1&l%5B3%5D%5BignoreNull%5D=&l%5B3%5D%5BafterComma%5D=2&l%5B3%5D%5Bdashes%5D=false&l%5B3%5D%5BdashLength%5D=10&l%5B3%5D%5BspaceLength%5D=10&l%5B4%5D%5Bid%5D=modbus.1.coils.12310_PV_Freigabe&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=-15&l%5B4%5D%5Bmax%5D=5&l%5B4%5D%5Bthickness%5D=1&l%5B4%5D%5Bshadowsize%5D=0&l%5B4%5D%5Bname%5D=PV+Freigabe&l%5B4%5D%5BignoreNull%5D=&l%5B4%5D%5BafterComma%5D=2&l%5B4%5D%5Bdashes%5D=false&l%5B4%5D%5BdashLength%5D=10&l%5B4%5D%5BspaceLength%5D=10&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&start=2024-09-07&start_time=06:00:00&end=2024-09-08&end_time=20:00:00&width=700&height=300&legend=nw&legColumns=5&legBgOpacity=0&timeFormat=%25H%3A%25M": net::ERR_ABORTED at http://localhost:8082/flot/index.html?timeType=static&relativeEnd=now&range=10&aggregateType=count&aggregateSpan=300&hoverDetail=false&useComma=false&zoom=false&noedit=true&animation=0&l%5B0%5D%5Bid%5D=javascript.0.Haus.Verbrauch&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=6&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=0&l%5B0%5D%5BafterComma%5D=2&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B1%5D%5Bid%5D=javascript.0.Haus.Einspeisung&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=0&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B2%5D%5Bid%5D=javascript.0.PV.TriPower.PV-Leistung_kW&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%23ffc300&l%5B2%5D%5Bthickness%5D=1&l%5B2%5D%5Bshadowsize%5D=0&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=2&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B3%5D%5Bid%5D=modbus.1.inputRegisters.13350_TO_TotalDemand&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%2352a0ff&l%5B3%5D%5Bthickness%5D=1&l%5B3%5D%5Bshadowsize%5D=0&l%5B3%5D%5Bname%5D=PV+Demand&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=1&l%5B3%5D%5BignoreNull%5D=&l%5B3%5D%5BafterComma%5D=2&l%5B3%5D%5Bdashes%5D=false&l%5B3%5D%5BdashLength%5D=10&l%5B3%5D%5BspaceLength%5D=10&l%5B4%5D%5Bid%5D=modbus.1.coils.12310_PV_Freigabe&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=-15&l%5B4%5D%5Bmax%5D=5&l%5B4%5D%5Bthickness%5D=1&l%5B4%5D%5Bshadowsize%5D=0&l%5B4%5D%5Bname%5D=PV+Freigabe&l%5B4%5D%5BignoreNull%5D=&l%5B4%5D%5BafterComma%5D=2&l%5B4%5D%5Bdashes%5D=false&l%5B4%5D%5BdashLength%5D=10&l%5B4%5D%5BspaceLength%5D=10&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&start=2024-09-07&start_time=06:00:00&end=2024-09-08&end_time=20:00:00&width=700&height=300&legend=nw&legColumns=5&legBgOpacity=0&timeFormat=%25H%3A%25M
                    und bei meiner Wetter Seite
                    Could not take screenshot of "file:///C:/ioBroker/images/msnweather1.html": Navigation timeout of 30000 ms exceeded
                    In beiden Fällen kann ich die URL im Browser aufrufen und bekomme angezeigt, was ich erwarte.
                    Da ich nichts an meinen Scripten geändert habe, und beide Fälle für die ich den Puppeteer Adapter monatelang benutzt habe nun nicht mehr funktionieren, denke ich, das muß mit irgendeinem Update zu tun haben. Aber ich finde keinen Ansatz, wo ich nun wieder suchen könnte.
                    • OliverIO
                      @jensen
                      Kannst du mir mal komplette Beispiele geben?
                      Verwendest du sendto oder die datenpunkte?
                      Ich versuche das mal nachzustellen
                      • Jensen
                        @oliverio
                        Ich benutze sendto, im Groben sieht das bei mir so aus :
                        function createImage(_output, _url) {
                            //log(_url);
                            log('try to create : ' + _output);
                            sendTo('puppeteer.0', 'screenshot', {
                                url: _url,
                                path: '../../images/' + _output,
                                viewportOptions: {
                                    width: 700,
                                    height: 300
                                renderTime: 20000
                            obj => {
                              if (obj.error) {
                                log('Error taking screenshot: ${obj.error.message}', 'error');
                        // PV heute
                        var url01 = 'http://localhost:8082/flot/ .........';
                        createImage('img01.png', url01);
                        Die Url müßtest du durch was Brauchbares auf deinem System ersetzen.
                        Ich glaube aber, das Problem steckt tiefer, entweder in der verwendeten Puppeteer Version oder eher in der darunterliegenden chrome Version.
                        Ich finde auf meinem System schon wieder so viele verschiedene Versionen von chrome, das verwirrt mich.
                        Unter C:\Windows\System32\config\systemprofile.cache\puppeteer\chrome
                        Im Benutzer Verzeichnis C:\Users\IpsJensen.cache\puppeteer\chrome
                        Wie sind da die Zusammenhänge?
                        Wer installiert was wann wo, und wo wird entschieden, was benutzt wird?
                        Jensen OliverIO 3 Replies Last reply Reply Quote 0
                        • Jensen
                          @foxriver76
                          Könntest Du vielleicht einem Ahnungslosen etwas weiter helfen?
                          Ich weiß hier einfach nicht weiter.
                          • OliverIO
                            @jensen
                            Der Adapter nutzt eigentlich nur das folgende package.
                            Dies sorgt sich um das herunterladen und das richtige ansprechen des Browsers.
                            https://www.npmjs.com/package/puppeteer
                            Hauptanwendungszweck dieses Pakets ist automatisierter Tests von webanwendungen.
                            Dazu wird meist die applikation in einer gekapselten virtuellen Umgebung (meist sowas wie docker) installiert, die Tests ausgeführt und am Ende die komplette Umgebung wieder weggeworfen.
                            Andere anwendungsfälle sind webscraping oder sowas wie hier, was aber wahrscheinlich bei weitem nicht so oft in der Welt angewendet wird.
                            Das deinstallieren von Browsern wurde erst letztes Jahr hinzugefügt
                            https://github.com/puppeteer/puppeteer/pull/10179
                            Ob das im Adapter berücksichtigt ist weiß ich nicht.
                            Die Ursache deiner Fehler kann vielfältig sein.
                            Bei flot stand im Ergebnis ein net_err drin. Das deutet darauf hin, das irgendwas mit der netzverbindung nicht passt. Aber auch hier kann es vielfältig sein. Am wahrscheinlichsten sind timeouts, aber daher wollte ich das mal für mich selbst probieren um das einzugrenzen.
                            Bei deinem msnwetter kann es sein, das der Anbieter Begrenzungen eingebaut hat, die ein automatisiertes Abrufen verhindert. Ich selbst bin im Zusammenhang einer nieten Fragestellung letztens auch auf sowas gestoßen, das der Abruf im Browser funktioniert, mit puppeteer aber nicht. Wie die verhinderungsstrategie funktioniert weiß ich aktuell nicht.
                            Also ichdenke nicht das der Fehler aktuell noch an puppeteer liegt
                            OrKoN created this issue in puppeteer/puppeteer
                            closed feat: add ability to uninstall a browser #10179
                            • OliverIO
                              OliverIO @Jensen last edited by OliverIO
                              @jensen sagte in Puppeteer Adapter:
                              also flot funktioniert bei mir
                              msn weather eigentlich auch, allerdings erhalte ich mit puppeteer nur die folgende seite
                              link ist
                              https://www.msn.com/en-us/weather/forecast/in-Frankfurt,Hesse
                              aufgrund des net_err vermute ich, das irgendwas mit dem abruf der daten von deinem nuc nicht passt.
                              probiere es mal direkt von dort mit curl
                              um im script eine bessere fehlermeldung zu erhalten ändere mal die zeile zu.
                              da waren die falschen anfürhungszeichen drin und message ist da auch nicht vorhanden.
                              ich frage mich wie du die fehlermeldung weiter oben produzieren konntest?
                                      log(`Error taking screenshot: ${obj.error}`, 'error');
                              wenn der timeout von puppeteer nicht reicht, dann solltest du die folgende option einbauen
                              waitForTimeout
                                      url: _url,
                                      viewportOptions: {
                                          width: 700,
                                          height: 300
                                    renderTime: 20000,
                                    waitOption: {
                                      waitForTimeout: 20000,
                              der generelle timeout ist auf 5 sekunden eingestellt, was eigentlich reichen sollte.
                              überprüfe auch mal noch deinen bilderpfad, ob der existiert.
                              evtl mal ohne pfad nur mit img.png eintragen, dann findest du das bild unter /opt/iobroker/ioberoker-data
                              • Jensen
                                @oliverio
                                Für msnweather brauchst du die von mir geparste Datei.
                                msnweather1.html
                                (Bitte nicht an den komischen Zeichen vor dem °C stören, das ist ein anderes Thema.
                                Was ist der Unterschied bei diesen verschiedenen Apostrophen?
                                Ich habe meine Log Zeile geändert.
                                Die waitOption habe ich auch dazu gebaut.
                                Ergebnis:
                                javascript.0
                                   2024-09-09 15:48:27.524	error	script.js.test.PuppeteerSample3: Error taking screenshot: timeout
                                javascript.0
                                   2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                javascript.0
                                   2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: try to create : msnweather1.png
                                javascript.0
                                   2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: file:///C:/ioBroker/images/msnweather1.html
                                javascript.0
                                   2024-09-09 15:48:07.495	info	Start JavaScript script.js.test.PuppeteerSample3 (Javascript/js)
                                Interessant ist, ich habe waitOption auf 60000, renderTime auf 30000, aber der timeout kommt nach 20000.
                                • Jensen
                                  Ohne Pfad bringt auch keine Änderung.
                                  • OliverIO
                                    @jensen
                                    Was sagt curl?
                                    • Jensen
                                      @oliverio
                                      curl ?
                                      Was muß ich tun?
                                      • OliverIO
                                        @jensen
                                        curl müsste seit windows 10 installiert sein.
                                        du gehst auf die komandozeile deines nucs
                                        am besten mit der gleichen berechtigung wie iobroker
                                        und führst bspw das aus
                                        in anführungszeichen steht der link.
                                        curl ruft dann die daten ab, ungefähr so wie es puppeteer macht und gibt sie aus.
                                        wenn irgendwelche fehler dabei angezeigt werden könnte das interessant sein
                                        curl "https://www.msn.com/en-us/weather/forecast/in-Frankfurt,Hesse?loc=eyJsIjoiRnJhbmtmdXJ0IiwiciI6Ikhlc3NlIiwicjIiOiJGcmFua2Z1cnQgYW0gTWFpbiIsImMiOiJHZXJtYW55IiwiaSI6IkRFIiwidCI6MTAyLCJnIjoiZW4tdXMiLCJ4IjoiOC42Nzk0OTk2MjYxNTk2NjgiLCJ5IjoiNTAuMTEwOTAwODc4OTA2MjUiLCJvIjp0cnVlfQ%3D%3D&weadegreetype=C"
                                        hier die anleitung für curl
                                        https://curl.se/docs/manpage.html
                                        • Jensen
                                          @oliverio
                                          Wir müssen das verschieben.
                                          Ich bin jetzt erst mal 2 Wochen auf Montage und hier ist die Internetverbindung momentan sehr schlecht, komme nicht per VPN auf den Rechner.
                                          • OliverIO
                                            @jensen
                                            alles gut. du schreibst am besten wieder in diesen thread wenns weitere fragen gibt
                                            3974
