    4. VIS2 Editor und Runtime laden nicht
      Thomas Braun Most Active @28michi05 last edited by
      @28michi05
      Bindings oder sowas gesetzt?
      Schau dir das Konstrukt per
      iob diag
      an.
      2 1 Reply Last reply Reply Quote 1
        sigi234 Forum Testing Most Active @28michi05 last edited by
        @28michi05
        Web Adapter läuft und Richtig eingestellt?
        • 2
          28michi05 @Thomas Braun last edited by
          @thomas-braun bindings habe ich wenn dann unbeabsichtigt gesetzt. laut der Diagnose sind bindings mit 0.0.0.0 gesetzt bei den Adaptern Admin, shelly und web.
            Homoran Global Moderator Administrators @28michi05 last edited by Homoran
            @28michi05 sagte in VIS2 Editor und Runtime laden laden nicht:
            laut der Diagnose
            bitte immer alles zeigen!
            2 2 Replies Last reply Reply Quote 0
            • 2
              28michi05 @Homoran last edited by
              Skript v.2024-05-22
              *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
                        Kernel: Linux 6.6.31+rpt-rpi-v8
                  Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               10:28:01 up 15:25,  5 users,  load average: 0.65, 0.60, 0.54
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Mon 2024-09-09 10:28:01 CEST
                         Universal time: Mon 2024-09-09 08:28:01 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
              *** Display-Server-Setup ***
              Display-Server: true
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            8.2G        2.5G        4.0G        600M        2.4G        5.6G
              Swap:           209M          0B        209M
              Total:          8.4G        2.5G        4.2G
              Active iob-Instances:   9
                       7810 M total memory
                       2427 M used memory
                       2229 M active memory
                       1010 M inactive memory
                       3803 M free memory
                        118 M buffer memory
                       2163 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 10:28:01 up 15:25,  5 users,  load average: 0.65, 0.60, 0.54
              Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   7810.0 total,   3801.9 free,   2428.6 used,   2282.6 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5381.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  3.6G     0  3.6G   0% /dev
              tmpfs          tmpfs     782M  1.4M  780M   1% /run
              /dev/mmcblk0p2 ext4      117G  7.5G  104G   7% /
              tmpfs          tmpfs     3.9G   27M  3.8G   1% /dev/shm
              /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
              tmpfs          tmpfs     781M   44K  781M   1% /run/user/1000
              [Sun Sep  8 19:02:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:B4:0D:C3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=14353cd3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              [Sun Sep  8 19:02:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
              [Sun Sep  8 19:02:09 2024] EXT4-fs (mmcblk0p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET                                                  SOURCE         FSTYPE          OPTIONS
              /                                                       /dev/mmcblk0p2 ext4            rw,noatime
              |-/sys                                                  sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/security                                securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/cgroup                                      cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
              | |-/sys/fs/pstore                                      pstore         pstore          rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/bpf                                         bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
              | |-/sys/kernel/debug                                   debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/tracing                                 tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/fuse/connections                            fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
              | `-/sys/kernel/config                                  configfs       configfs        rw,nosuid,nodev,noexec,relatime
              |-/proc                                                 proc           proc            rw,relatime
              | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4465
              |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc     rw,nosuid,nodev,noexec,relatime
              |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=3725564k,nr_inodes=931391,mode=755
              | |-/dev/pts                                            devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
              | |-/dev/shm                                            tmpfs          tmpfs           rw,nosuid,nodev
              | `-/dev/mqueue                                         mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
              |-/run                                                  tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=799748k,mode=755
              | |-/run/lock                                           tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
              | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
              | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
              | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
              | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs      rw,relatime
              | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
              | `-/run/user/1000                                      tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=799744k,nr_inodes=199936,mode=700,uid=1000,gid=1000
              |   |-/run/user/1000/gvfs                               gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              |   `-/run/user/1000/doc                                portal         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              `-/boot/firmware                                        /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              674M    /var/
              201M    /var/lib
              191M    /var/cache
              184M    /var/cache/apt
              141M    /var/lib/apt/lists
              Archived and active journals take up 79.9M in the file system.
              /opt/iobroker/backups:
              10M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              774M    /opt/iobroker/iobroker-data/
              716M    /opt/iobroker/iobroker-data/files
              441M    /opt/iobroker/iobroker-data/files/javascript.admin
              409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
              19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.17.0
              /usr/bin/node           v20.17.0
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.29.3
              nodejs:
                Installed: 20.17.0-1nodesource1
                Candidate: 20.17.0-1nodesource1
                Version table:
               *** 20.17.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                   18.19.0+dfsg-6~deb12u1 500
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  6.0.11
              admin:          7.0.23
              javascript:     8.7.6
              nodejs modules from github:     0
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
              + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
              + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
              + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
              + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.0.23   , installed 7.0.23
              Adapter    "backitup"     : 3.0.19   , installed 3.0.19
              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "modbus"       : 6.2.3    , installed 6.2.3
              Adapter    "shelly"       : 7.0.0    , installed 7.0.0
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Objects and States
              Objects:        665
              States:         483
              [BHit:1 http://deb.debian.org/debian bookworm InRelease
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 129
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10485      1417/iobroker.js-co
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10490      1417/iobroker.js-co
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          130404     2560/cupsd
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8114       1586/io.shelly.1
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6833       761/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          130403     2560/cupsd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8029       1526/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10002      1619/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          6835       761/sshd: /usr/sbin
              udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       326360     4254/chromium-brows
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6056       555/avahi-daemon: r
              udp        0      0 0.0.0.0:38504           0.0.0.0:*                           104        6058       555/avahi-daemon: r
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          131476     2563/cups-browsed
              udp6       0      0 :::50012                :::*                                104        6059       555/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        6057       555/avahi-daemon: r
              udp6       0      0 fe80::e8e7:82c:8276:546 :::*                                0          326702     665/NetworkManager
              2024-09-09 09:29:09.240  - info: host.raspberrypi "system.adapter.vis-2.0" disabled
              2024-09-09 09:29:09.244  - info: host.raspberrypi stopInstance system.adapter.vis-2.0 (force=false, process=true)
              2024-09-09 09:29:09.253  - info: vis-2.0 (1634) Got terminate signal TERMINATE_YOURSELF
              2024-09-09 09:29:09.264  - info: vis-2.0 (1634) terminating
              2024-09-09 09:29:09.267  - info: vis-2.0 (1634) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-09-09 09:29:09.298  - info: host.raspberrypi stopInstance system.adapter.vis-2.0 send kill signal
              2024-09-09 09:29:09.770  - info: vis-2.0 (1634) terminating
              2024-09-09 09:29:09.822  - info: host.raspberrypi instance system.adapter.vis-2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-09-09 09:30:31.408  - info: host.raspberrypi iobroker add vis-2 --host raspberrypi
              2024-09-09 09:30:35.000  - error: host.raspberrypi iobroker host.raspberrypi error: this adapter does not allow multiple instances
              2024-09-09 09:30:36.062  - info: host.raspberrypi iobroker exit 19
              2024-09-09 09:30:59.174  - info: admin.0 (1526) <== Disconnect system.user.admin from ::ffff:192.168.178.33 admin
              2024-09-09 09:31:04.357  - info: host.raspberrypi "system.adapter.vis-2.0" enabled
              2024-09-09 09:31:04.850  - info: host.raspberrypi instance system.adapter.vis-2.0 in version "2.9.32" started with pid 5026
              2024-09-09 09:31:08.049  - info: vis-2.0 (5026) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.17.0, js-controller: 6.0.11
              2024-09-09 09:31:08.422  - info: vis-2.0 (5026) vis-2 license is OK.
              2024-09-09 09:31:08.476  - info: vis-2.0 (5026) config.js changed. Upload.
              2024-09-09 09:32:13.178  - info: web.0 (1619) ==> Connected system.user.admin from ::ffff:192.168.178.61
              2024-09-09 09:44:00.663  - info: web.0 (1619) ==> Connected system.user.admin from ::ffff:127.0.0.1
              2024-09-09 09:51:52.070  - info: web.0 (1619) ==> Connected system.user.admin from ::ffff:127.0.0.1
              2024-09-09 10:19:44.208  - info: web.0 (1619) <== Disconnect system.user.admin from ::ffff:192.168.178.61
              2024-09-09 10:20:28.213  - info: admin.0 (1526) ==> Connected system.user.admin from ::ffff:192.168.178.61
              iob diag has finished.
              Press any key for a summary
              • 2
                @homoran sorry, erledigt 👍
                der web adapter läuft auch, Zugriff von allen IP´s erlaubt und der Port sollte mit 8082 auch passen. Ansonsten ist nichts angewählt.
                  @28michi05
                  Und den Desktop auch ausschalten, wenn da nicht ein Bildschirm unmittelbar dranhängt.
                  • 2
                    @thomas-braun hatte eben noch den TV via HDMI mit dem Raspy verbunden. Habe ich jetzt ausgesteckt. Jetzt hängt der Raspy nurnoch am Netzwerk und ich greife per Windows Notebook über Putty drauf zu.
                    Hier nochmal die Diagnose:
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     11:00:05 up 7 min,  4 users,  load average: 0.42, 0.44, 0.27
                    CPU threads: 4
                    Current issues:
                                   Local time: Mon 2024-09-09 11:00:05 CEST
                               Universal time: Mon 2024-09-09 09:00:05 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            8.2G        1.1G        6.3G         16M        883M        7.1G
                    Swap:           209M          0B        209M
                    Total:          8.4G        1.1G        6.6G
                             7810 M total memory
                             1044 M used memory
                             1188 M active memory
                              435 M inactive memory
                             6053 M free memory
                               47 M buffer memory
                              795 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    top - 11:00:06 up 7 min,  4 users,  load average: 0.42, 0.44, 0.27
                    Tasks: 227 total,   1 running, 226 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   7810.0 total,   6051.5 free,   1046.6 used,    843.1 buff/cache
                    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6763.5 avail Mem
                    *** FILESYSTEM ***
                    tmpfs          tmpfs     782M  1.3M  780M   1% /run
                    tmpfs          tmpfs     3.9G  148K  3.9G   1% /dev/shm
                    tmpfs          tmpfs     781M   40K  781M   1% /run/user/1000
                    [Mon Sep  9 10:52:49 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:B4:0D:C3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=14353cd3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                    [Mon Sep  9 10:52:52 2024] EXT4-fs (mmcblk0p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
                    [Mon Sep  9 10:52:54 2024] EXT4-fs (mmcblk0p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
                    | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=91
                    /var:
                    690M    /var/
                    201M    /var/lib
                    191M    /var/cache
                    184M    /var/cache/apt
                    Archived and active journals take up 95.9M in the file system.
                    775M    /opt/iobroker/iobroker-data/
                    USB-Devices by-id:
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          7.0.23
                    javascript:     8.7.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        671
                    States:         489
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7363       736/cupsd
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9818       737/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10327      737/iobroker.js-con
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          708        755/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11756      2071/io.shelly.1
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11791      2101/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12551      1971/io.admin.0
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7362       736/cupsd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          710        755/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          8494       1015/cups-browsed
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        581        525/avahi-daemon: r
                    udp        0      0 0.0.0.0:59403           0.0.0.0:*                           104        583        525/avahi-daemon: r
                    udp6       0      0 :::45324                :::*                                104        584        525/avahi-daemon: r
                    udp6       0      0 fe80::e8e7:82c:8276:546 :::*                                0          9486       658/NetworkManager
                    udp6       0      0 :::5353                 :::*                                104        582        525/avahi-daemon: r
                    2024-09-09 10:54:32.980  - info: shelly.1 (2071) [MQTT] Device with client id "shellyplus1pm-c4d8d542c648" connected!
                    2024-09-09 10:54:50.206  - info: admin.0 (1971) <== Disconnect system.user.admin from ::ffff:192.168.178.35 admin
                    2024-09-09 10:54:58.240  - info: shelly.1 (2071) [MQTT] Device with client id "shellyplus1pm-e465b8fb0fc8" connected!
                    2024-09-09 10:55:00.029  - info: shelly.1 (2071) [MQTT] Device with client id "shellyplus1pm-10061cd31974" connected!
                      sehr gut!
                      aber der Didplay Server läuft immer noch
                      und
                      gibt es immer noch
                      • 2
                        28michi05 last edited by 28michi05
                        Ok, Danke erstmal für die Mühe und Geduld mit mir, jetzt komm ich mir schon fast doof vor 😕
                        Sprich erstmal alle 129 Updates auf dem Raspy durchführen?
                        Ein Display würde ich aber in Zukunft auch gern verwenden. Trotzdem zum Testen erstmal den Displayserver auf dem Raspy deaktivieren?
                          Ja, ist eine Grundvoraussetzung für alles andere. Die Kisten sind auf einem aktuellen Stand zu halten.
                          iob stop
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                          Künftig regelmäßiger selber aktiv werden.
                          Wenn da ein Bildschirm (für eine Visualisierung?) dran soll lass den Display-Server laufen. Aber nur dann! Server werden im Allgemeinen ohne graphischen Mumpitz betrieben.
                          2 2 Replies Last reply Reply Quote 1
                          • 2
                            @thomas-braun Display soll dranhängen.
                            Das Ganze soll im Endstadium eigentlich nur per Modbus Daten von meinem Wechselrichter abrufen und je nach Einspeisung ins Netz dann je eine Phase eines Heizstabes zur Erwärmung meines Brauchwassers über je einen Shelly schalten. Das Display soll mir dann den aktuellen Zustand und evtl. ein paar Verbrauchswerte anzeigen. Und das sollte ja alles im Paket so möglich sein 😊
                            An die Updates mache ich mich gleich. Dann schonmal vielen Dank soweit.
                            • 2
                              @thomas-braun So, danke für eure Geduld, ich musste zwischenzeitlich in die Schicht 😁
                              Jetzt ist alles upgedatet, sowohl der Raspy, als auch alle Adapter. Leider immernoch das Problem, dass ich nur einen weißen Bildschirm angezeigt bekomme.
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                        Kernel: Linux 6.6.47+rpt-rpi-v8
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                               21:07:26 up 5 min,  4 users,  load average: 0.27, 0.43, 0.24
                              CPU threads: 4
                              Current issues:
                                             Local time: Mon 2024-09-09 21:07:27 CEST
                                         Universal time: Mon 2024-09-09 19:07:27 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            8.2G        1.2G        6.1G         16M        1.0G        7.0G
                              Swap:           209M          0B        209M
                              Total:          8.4G        1.2G        6.4G
                                       7809 M total memory
                                       1129 M used memory
                                       1278 M active memory
                                        536 M inactive memory
                                       5858 M free memory
                                         48 M buffer memory
                                        906 M swap cache
                                        199 M total swap
                                          0 M used swap
                                        199 M free swap
                              top - 21:07:27 up 5 min,  4 users,  load average: 0.27, 0.43, 0.24
                              Tasks: 222 total,   2 running, 220 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 16.7 us,  8.3 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   7810.0 total,   5856.1 free,   1130.9 used,    955.8 buff/cache
                              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6679.1 avail Mem
                              *** FILESYSTEM ***
                              tmpfs          tmpfs     781M  1.3M  780M   1% /run
                              /dev/mmcblk0p2 ext4      117G  8.6G  103G   8% /
                              /dev/mmcblk0p1 vfat      510M   76M  435M  15% /boot/firmware
                              [Mon Sep  9 21:01:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:B4:0D:C3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=14353cd3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                              [Mon Sep  9 21:01:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
                              [Mon Sep  9 21:01:56 2024] EXT4-fs (mmcblk0p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
                              | `-/sys/fs/fuse/connections                            fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
                              | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5312
                              |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=3725432k,nr_inodes=931358,mode=755
                              |-/run                                                  tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=799744k,mode=755
                              | `-/run/user/1000                                      tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=799740k,nr_inodes=199935,mode=700,uid=1000,gid=1000
                              /var:
                              1.2G    /var/
                              701M    /var/cache
                              688M    /var/cache/apt
                              575M    /var/cache/apt/archives
                              204M    /var/lib
                              Archived and active journals take up 119.9M in the file system.
                              885M    /opt/iobroker/iobroker-data/
                              817M    /opt/iobroker/iobroker-data/files
                              28M     /opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          7.0.23
                              javascript:     8.7.6
                              Adapter State
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
                                system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
                                system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
                                system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                              + instance is alive
                              Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                              Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
                              Objects and States
                              Objects:        699
                              States:         500
                              [BHit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7343       754/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       13762      2470/io.shelly.1
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8605       740/cupsd
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7101       741/iobroker.js-con
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7107       741/iobroker.js-con
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          7345       754/sshd: /usr/sbin
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8604       740/cupsd
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10193      1939/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11908      1448/io.admin.0
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          7523       974/cups-browsed
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        8525       552/avahi-daemon: r
                              udp        0      0 0.0.0.0:55512           0.0.0.0:*                           104        8527       552/avahi-daemon: r
                              udp6       0      0 fe80::e8e7:82c:8276:546 :::*                                0          6754       673/NetworkManager
                              udp6       0      0 :::33584                :::*                                104        8528       552/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                104        8526       552/avahi-daemon: r
                              2024-09-09 21:05:34.662  - info: admin.0 (1448) ==> Connected system.user.admin from ::ffff:192.168.178.35
                              2024-09-09 21:06:02.217  - info: admin.0 (1448) <== Disconnect system.user.admin from ::ffff:192.168.178.35 javascript
                              2024-09-09 21:06:06.050  - info: admin.0 (1448) <== Disconnect system.user.admin from ::ffff:192.168.178.35 admin
                                wirklich nichts?
                                Bitte die Konfiguration zeigen
                                2 1 Reply Last reply Reply Quote 0
                                • 2
                                  @homoran ich hoffe hier sind screenshots ok.
                                    Natürlich!
                                    Und gar nichts hast du zum Glück nicht konfiguriert, immerhin das integrierte socket.io.
                                    Also nochmal zusammengefasst
                                    Auf dem pi mit angeschlossenem Monitor und der 127.0.0.1 läuft es, auf jedem anderen Rechner mit <RaspiIP>:8082 nicht?
                                    Auch nicht auf dem Raspi?
                                    Dann hättest du wohl möglicherweise ein Netzwerkproblem oder Firewall.
                                    Am Browser am PC bitte F12 drücken, dort den Reiter Console öffnen und dann die <raspiIP>8082/vis/edit.html Aufrufen.
                                    Anschließend Screenshot von den Fehlermeldungen in der Browserkonsole machen und hier posten
                                    • 2
                                      Ja, direkt auf dem Pi klappt es mit der 127...
                                      Übers Netzwerk mit der 192... kommt mir das Fenster mit Editor, Runtime,... und sobald ich dann auf Editor klicke erscheint kurz das IO Broker Symbol und dann bleibt alles weiß.
                                      • 2
                                        @homoran sorry, hier die Konsole
                                          @28michi05 da sagt er dass er die vis-views.json nicht findet.
                                          jetzt weiss ich nicht ob das die richtige ist, und sie bei vis2 auch so heisst, oder die views von vis öffnen will.
                                          kann aber auch mein Fehler sein, da ich dir den Link für vis gegeben habe.
                                          den von vis2 kenne ich nicht
                                            auch vom RasPi aus?
                                            oder nur vom PC
                                            1986
