    3. Off Topic
    4. "certifi"-Sicherheitslücke bei iobroker Raspberry Pi
    UNSOLVED "certifi"-Sicherheitslücke bei iobroker Raspberry Pi
      Thomas Braun Most Active @sticks last edited by Thomas Braun
      @sticks
      Schon mal per
      cd /opt/iobroker/ && npm audit
      geschaut...
      Und NEIN, du sollst da nicht per audit fix irgendwas korrigieren...
        sticks @Thomas Braun last edited by
        Hi, nein, das habe ich noch nicht gemacht.
        Hier die Ergebnisse:
        # npm audit report
        @75lb/deep-merge  <=1.1.1
        Severity: high
        @75lb/deep-merge Prototype Pollution vulnerability - https://github.com/advisori        es/GHSA-28mc-g557-92m7
        fix available via `npm audit fix`
        node_modules/@75lb/deep-merge
        axios  0.8.1 - 0.27.2 || 1.0.0 - 1.7.3
        Severity: high
        Axios Cross-Site Request Forgery Vulnerability - https://github.com/advisories/G        HSA-wf5p-g6vw-rhxx
        Server-Side Request Forgery in axios - https://github.com/advisories/GHSA-8hc4-v        h64-cxmj
        fix available via `npm audit fix --force`
        Will install iobroker.unifi@0.6.3, which is a breaking change
        node_modules/@alcalzone/pak/node_modules/axios
        node_modules/axios
        node_modules/iobroker.daswetter/node_modules/axios
        node_modules/iobroker.javascript/node_modules/axios
        node_modules/iobroker.parser/node_modules/axios
        node_modules/iobroker.socketio/node_modules/axios
        node_modules/iobroker.switchbot-hub/node_modules/axios
        node_modules/iobroker.ws/node_modules/axios
        node_modules/node-hue-api/node_modules/axios
        node_modules/node-ical/node_modules/axios
        node_modules/node-unifi/node_modules/axios
          @alcalzone/pak  0.3.0 - 0.10.0
          Depends on vulnerable versions of axios
            @iobroker/js-controller-adapter  *
            Depends on vulnerable versions of @alcalzone/pak
            Depends on vulnerable versions of @iobroker/db-objects-file
            Depends on vulnerable versions of @iobroker/db-objects-jsonl
            Depends on vulnerable versions of @iobroker/db-objects-redis
            Depends on vulnerable versions of @iobroker/db-states-file
            Depends on vulnerable versions of @iobroker/db-states-jsonl
            Depends on vulnerable versions of @iobroker/db-states-redis
            Depends on vulnerable versions of @iobroker/js-controller-common
            Depends on vulnerable versions of @iobroker/js-controller-common-db
            node_modules/@iobroker/js-controller-adapter
              iobroker.js-controller  >=4.0.0-alpha.1-20210830-d9828cd3
              Depends on vulnerable versions of @iobroker/js-controller-adapter
              Depends on vulnerable versions of @iobroker/js-controller-cli
              node_modules/iobroker.js-controller
            @iobroker/js-controller-common-db  >=6.0.1-alpha.0-20240522-6037ce8ae
            node_modules/@iobroker/js-controller-common-db
              @iobroker/db-base  >=6.0.1-alpha.0-20240522-6037ce8ae
              node_modules/@iobroker/db-base
                @iobroker/db-objects-file  >=6.0.1-alpha.0-20240522-6037ce8ae
                Depends on vulnerable versions of @iobroker/db-base
                node_modules/@iobroker/db-objects-file
                @iobroker/db-objects-jsonl  >=6.0.1-alpha.0-20240522-6037ce8ae
                node_modules/@iobroker/db-objects-jsonl
                @iobroker/db-objects-redis  >=6.0.1-alpha.0-20240522-6037ce8ae
                node_modules/@iobroker/db-objects-redis
                @iobroker/db-states-file  >=6.0.1-alpha.0-20240522-6037ce8ae
                node_modules/@iobroker/db-states-file
                @iobroker/db-states-jsonl  >=6.0.1-alpha.0-20240522-6037ce8ae
                node_modules/@iobroker/db-states-jsonl
                @iobroker/db-states-redis  >=6.0.1-alpha.0-20240522-6037ce8ae
                node_modules/@iobroker/db-states-redis
              @iobroker/js-controller-cli  >=6.0.1-alpha.0-20240522-6037ce8ae
              node_modules/@iobroker/js-controller-cli
              @iobroker/js-controller-common  >=6.0.1-alpha.0-20240522-6037ce8ae
          iobroker.switchbot-hub  *
          iobroker.unifi  >=0.6.4
          Depends on vulnerable versions of node-unifi
          node_modules/iobroker.unifi
          node-hue-api  2.0.0-RC1 - 5.0.0-alpha.2
            iobroker.hue  >=0.6.2
            Depends on vulnerable versions of node-hue-api
            node_modules/iobroker.hue
          node-ical  0.15.3 - 0.16.1
            iobroker.jarvis  >=3.0.0
            Depends on vulnerable versions of ip
            Depends on vulnerable versions of node-ical
            Depends on vulnerable versions of semver
            node_modules/iobroker.jarvis
          node-unifi  >=2.3.0
        braces  <3.0.3
        Severity: high
        Uncontrolled resource consumption in braces - https://github.com/advisories/GHSA        -grv7-fg5c-xmjg
        node_modules/braces
        debug  <=2.6.8 || 4.0.0 - 4.3.0
        Severity: high
        debug Inefficient Regular Expression Complexity vulnerability - https://github.c        om/advisories/GHSA-9vvw-cc9w-f27h
        Regular Expression Denial of Service in debug - https://github.com/advisories/GH        SA-gxpj-cx7g-858c
        Depends on vulnerable versions of ms
        Will install iobroker.tr-064@0.0.8, which is a breaking change
        node_modules/engine.io-client/node_modules/debug
        node_modules/iobroker.socketio/node_modules/debug
        node_modules/iobroker.web/node_modules/debug
        node_modules/mdns-discovery/node_modules/debug
        node_modules/socket.io-client/node_modules/debug
        node_modules/socket.io-parser/node_modules/debug
          engine.io  0.7.8 - 0.7.9 || 3.4.0 - 6.5.4
          Depends on vulnerable versions of debug
          Depends on vulnerable versions of ws
          node_modules/iobroker.socketio/node_modules/engine.io
          node_modules/iobroker.web/node_modules/engine.io
            socket.io  2.2.0 - 3.0.4
            Depends on vulnerable versions of engine.io
            Depends on vulnerable versions of socket.io-parser
            node_modules/iobroker.socketio/node_modules/socket.io
            node_modules/iobroker.web/node_modules/socket.io
              iobroker.socketio  3.0.0 - 3.0.13 || 3.1.3 - 3.1.5 || 4.1.0 - 5.0.2 || 6.1        .0 - 6.5.7 || >=6.6.0
              node_modules/iobroker.web/node_modules/iobroker.socketio
                iobroker.web  4.2.1 - 4.3.0 || >=5.2.3
                Depends on vulnerable versions of iobroker.socketio
          engine.io-client  <=3.1.1 || 3.5.0 - 3.5.3 || 4.0.0-alpha.0 - 5.2.0
          Depends on vulnerable versions of parsejson
          node_modules/iobroker.web/node_modules/engine.io-client
            socket.io-client  1.0.0-pre - 2.1.1
            Depends on vulnerable versions of engine.io-client
              iobroker.cloud  <=2.4.6 || 2.8.0 - 3.0.2 || >=4.0.11
              Depends on vulnerable versions of socket.io-client
              node_modules/iobroker.cloud
          mdns-discovery  >=0.0.4
          Depends on vulnerable versions of dns-packet
            iobroker.discovery  *
            Depends on vulnerable versions of mdns-discovery
            Depends on vulnerable versions of node-ssdp
            node_modules/iobroker.discovery
            iobroker.tr-064  >=0.1.1
            Depends on vulnerable versions of tr-O64
            Depends on vulnerable versions of xml2js
            node_modules/iobroker.tr-064
          socket.io-parser  <=3.3.3 || 3.4.0 - 4.0.2
          node_modules/iobroker.socketio/node_modules/socket.io-parser
          node_modules/iobroker.web/node_modules/socket.io-client/node_modules/socket.io        -parser
          node_modules/iobroker.web/node_modules/socket.io-parser
        ip  *
        Severity: high
        ip SSRF improper categorization in isPublic - https://github.com/advisories/GHSA        -2p57-rm9w-gvfp
        Will install iobroker.jarvis@3.1.3, which is a breaking change
        node_modules/ip
          dns-packet  <=5.2.4
          node_modules/dns-packet
          node-ssdp  >=1.0.1
          node_modules/node-ssdp
        lodash  <=4.17.20
        Severity: critical
        Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advi        sories/GHSA-x5rq-j2xg-h7qm
        Prototype Pollution in lodash - https://github.com/advisories/GHSA-4xc9-xhrj-v57        4
        Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advi        sories/GHSA-29mw-wpgm-hmr9
        Prototype Pollution in lodash - https://github.com/advisories/GHSA-p6mc-m468-83g        w
        Command Injection in lodash - https://github.com/advisories/GHSA-35jh-r3h4-6jhm
        Prototype Pollution in lodash - https://github.com/advisories/GHSA-fvqr-27wr-82f        m
        Prototype Pollution in lodash - https://github.com/advisories/GHSA-jf85-cpcp-j69        5
        Will install iobroker.modbus@0.3.11, which is a breaking change
        node_modules/stampit/node_modules/lodash
          stampit  2.0.1 - 2.1.2
          Depends on vulnerable versions of lodash
            iobroker.modbus  >=0.4.5
            Depends on vulnerable versions of put
            Depends on vulnerable versions of stampit
            Depends on vulnerable versions of stampit-event-bus
            Depends on vulnerable versions of stampit-state-machine
            node_modules/iobroker.modbus
            stampit-event-bus  *
            node_modules/stampit-event-bus
            stampit-state-machine  *
            node_modules/stampit-state-machine
        micromatch  <4.0.8
        Severity: moderate
        Regular Expression Denial of Service (ReDoS) in micromatch - https://github.com/        advisories/GHSA-952p-6rrq-rcjv
        node_modules/micromatch
        ms  <2.0.0
        Severity: moderate
        Vercel ms Inefficient Regular Expression Complexity vulnerability - https://gith        ub.com/advisories/GHSA-w9mr-4mfr-499f
        node_modules/engine.io-client/node_modules/ms
        node_modules/mdns-discovery/node_modules/ms
        node_modules/socket.io-client/node_modules/ms
        node_modules/socket.io-parser/node_modules/ms
        parsejson  *
        Severity: high
        Regular Expression Denial of Service in parsejson - https://github.com/advisorie        s/GHSA-q75g-2496-mxpp
        Will install iobroker.cloud@4.0.10, which is a breaking change
        node_modules/parsejson
        path-to-regexp  <=0.1.9 || 0.2.0 - 7.2.0
        Severity: high
        path-to-regexp outputs backtracking regular expressions - https://github.com/adv        isories/GHSA-9wv6-86v2-598j
        Will install iobroker.simple-api@2.7.2, which is a breaking change
        node_modules/nise/node_modules/path-to-regexp
          express  4.0.0-rc1 - 4.19.2 || 5.0.0-alpha.1 - 5.0.0-beta.3
          Depends on vulnerable versions of path-to-regexp
          node_modules/express
          nise  *
          node_modules/nise
            sinon  >=3.0.0
            Depends on vulnerable versions of nise
            node_modules/sinon
              @iobroker/testing  *
              Depends on vulnerable versions of sinon
              Depends on vulnerable versions of sinon-chai
              node_modules/@iobroker/testing
                iobroker.simple-api  >=2.8.0
                Depends on vulnerable versions of @iobroker/testing
                node_modules/iobroker.simple-api
              sinon-chai  >=3.0.0
              node_modules/sinon-chai
        put  *
        Sensitive Data Exposure in put - https://github.com/advisories/GHSA-v6gv-fg46-h8        9j
        node_modules/put
        request  *
        Severity: moderate
        Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7        -x288-28g6
        Depends on vulnerable versions of tough-cookie
        Will install iobroker.backitup@0.2.7, which is a breaking change
        node_modules/request
          dropbox-v2-api  *
          Depends on vulnerable versions of request
          node_modules/dropbox-v2-api
            iobroker.backitup  >=0.3.0
            Depends on vulnerable versions of dropbox-v2-api
            node_modules/iobroker.backitup
          iobroker.javascript  *
          iobroker.vw-connect  *
          node_modules/iobroker.vw-connect
          tr-O64  *
          node_modules/tr-O64
        semver  7.0.0 - 7.5.1
        Severity: high
        semver vulnerable to Regular Expression Denial of Service - https://github.com/a        dvisories/GHSA-c2qf-rxjj-qqgw
        node_modules/iobroker.jarvis/node_modules/semver
        tough-cookie  <4.1.3
        Severity: moderate
        tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/G        HSA-72xf-g2v4-qvf3
        node_modules/tough-cookie
        ws  2.1.0 - 5.2.3 || 7.0.0 - 7.5.9 || 8.0.0 - 8.17.0
        Severity: high
        ws affected by a DoS when handling a request with many HTTP headers - https://gi        thub.com/advisories/GHSA-3h5v-q93c-6h6q
        node_modules/engine.io/node_modules/ws
        node_modules/iobroker.web/node_modules/ws
        node_modules/socket.io-adapter/node_modules/ws
        node_modules/websocket-stream/node_modules/ws
          socket.io-adapter  2.5.2 - 2.5.4
          websocket-stream  4.0.0 - 5.1.2 || >=5.4.0
            iobroker.mqtt  >=2.1.0
            Depends on vulnerable versions of websocket-stream
            node_modules/iobroker.mqtt
        xml2js  <0.5.0
        Severity: moderate
        xml2js is vulnerable to prototype pollution - https://github.com/advisories/GHSA        -776f-qx25-q3cc
        node_modules/xml2js
          iobroker.onkyo  >=2.0.0
          node_modules/iobroker.onkyo
        68 vulnerabilities (4 low, 28 moderate, 34 high, 2 critical)
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues possible (including breaking changes), run:
        Some issues need review, and may require choosing
        a different dependency.
          @sticks
          Deine Herumgehampel als root halte ich im Übrigen für das größere Sicherheitsproblem...
          Sorry, der Report fängt mit einer Raute an...
          Ich wollte auch eigentlich nur deutlich machen, das jedes System offene 'Issues' hat. Die kannst du eh nicht alle angehen. Regelmäßige Systempflege sollte reichen. Um die konkrete Klassifizierung der Dinger kümmert sich im Fall von Debian halt das 'Debian Security Team'.
          Die können hoffentlich die konkrete Schwere des Problems für die einzelnen Releases bewerten.
            sticks @Thomas Braun last edited by sticks
            Da mir Tenable im "normalen" SSH-Context die ganze Linux-Befehlshistorie mit tausenden Prüfbefehlen auf Schwachstellen voll haut,arbeite ich gerne im Root Context da ich dort dann meine eigene Befehlshistorie sehe. Das das von manchen Linux-Profis nicht gern gesehen wird, ist mir klar.
            (PS: Stimmt, in dem Fall oben habe ich sogar im normalen User-Context gearbeitet. 😉 )
            Ich selbst habe alle meine Serversysteme (viele Raspberrys, 2x ESXi Server, paar Windows-Server, NAS-Systeme) in der kostenlosen Lösung von Tenable Nessus. Ich patche die meisten Linux-Systeme daher mindestens einmal die Woche, da immer einige Schwachstellen vorhanden sind, wie du schon sagst. Pro System sind oft 50-80 Schwachstellen völlig normal. - Wenn eine Schwachstelle aber als "hochkritisch" eingestuft wird, wie in diesem Fall geschehen, stecke ich meist einige Energie rein das abzustellen. - Manchmal ist dies nicht möglich, im Fall jetzt hätte es ja sein können das dies mit einem bestimmten Befehl oder Deinstallation eines bestimmten iobroker Adapters gelöst gewesen wäre. - Dies ist aber nicht der Fall, von daher muss ich das einfach so hinnehmen. Was beruhigt, das die Schwachstellenbewertung "kritisch" hier ja eher unzutreffend zu sein scheint.
            Demnach hat mein Raspberry mit iobroker derzeoit 92x harmlose Schwachstelllen, 5x medium Schwachstellen und eben diese 1x certifi die als kritisch eingestuft wird.
              @sticks sagte in "certifi"-Sicherheitslücke bei iobroker Raspberry Pi:
              ??? Die Historie ist doch als user viel besser zu sehen. Inkl. eines Wechsels in die root-Rolle.
              Lass den Quark mit der root shell einfach bleiben.
              Das Verhalten ist gefährlicher als deine ganzen 'Issues', die du da panisch versuchst zu stopfen.
                Panisch ist hier keiner. Ich gehe besonnen an die Sache heran:
                Nach Bekanntwerden der vermeintlich kritischen Lücke versucht man sich bestmöglich in die unbekannte Materie einzulesen. Habe mich eingearbeitet, durch das Github gelesen und dort stand ja mehr oder weniger: Wenn du genau dieses Problem/Sicherheitslücke hast dann mach mit pip ein Update und die Sache ist gelöst, denn der Maintainer con certifi hat sich schon drum gekümmert. - Ja, in diesem Fall war die Installation von pip unnötig, aber das konnte ich der Github Dokumentation zu certifi erstmal nicht entnehmen, stand da doch man kann die Lücke durch ein pip install certifi stopfen. - Als ich danach aber den Hinweis bekam, dass das ganze "externally-managed-environment" ist, war natürlich auch für mich klar, dass ich hiermit keinen Erfolg werden habe. Insofern, wenn das ganze "externally-managed-environment" ist, dann frage ich doch mal die Jungs im iobroker Forum, vielleicht ist das Problem dort ja schon bekannt. Hier habe ich nun die Hinweise auf Debian bekommen, damit ist die Sache für mich auch OK, habe ich doch jetzt die Gewissheit das ich hier nichts übersehen / fremdverursacht habe.
                Kommentare zu Herumgebastel, Quark und Panik halte ich hingegen für unangebracht für einen professionellen Austausch.
                  Da keiner von uns beiden offenbar Profi ist passt das wieder.
                    Homoran Global Moderator Administrators @sticks last edited by
                    wo soll's denn sonst herkommen?
                      sticks @Homoran last edited by sticks
                      Woanders her. - Gibt ja viele Wege wie Dateien/Pakete in einem Linux-System landen können, evtl. eben auch durch iobroker selbst.
                      In meinem Fall habe ich z.B. zwei unterschiedliche Raspberry Pis, beide haben ein topaktuelles Debian Bookworm als Betriebssystem. Der Raspberry mit iobroker-Installation meldet mir die certifi-Sicherheitslücke, der Raspberry auf dem nur FHEM läuft hat die Lücke (noch) nicht gemeldet. - Von daher habe ich natürlich im iobroker-Bereich mit Problematiken gerechnet.
                      Edit: Der FHEM-PI hat die Lücke aber scheinbar auch, macht ja auch Sinn, das ist nur noch nicht über Tenable Nessus gemeldet:
                      fhempi:~ $ apt policy python3-certifi
                      python3-certifi:
                        Installiert:           2022.9.24-1
                        Installationskandidat: 2022.9.24-1
                        Versionstabelle:
                       *** 2022.9.24-1 500
                              500 http://deb.debian.org/debian bookworm/main armhf Packages
                              100 /var/lib/dpkg/status
                        Homoran Global Moderator Administrators @sticks last edited by Homoran
                        aber dann würde iobroker python ja auch über apt aus debian Quellen installieren.
                        iobroker selbst ist javascript/nodejs code
                        auch EDIT:
                        Das ergibt auch Sinn, weil meines Wissens Python mit dem OS mitkommt.
                          @homoran sagte in "certifi"-Sicherheitslücke bei iobroker Raspberry Pi:
                          Python selber schon. Die meisten (bzw. sehr viele) python-Pakete kann man direkt aus den Debian-Repos angeln. Pakete heißen dann immer 'python3-$PYTHONMODUL'. Dann sind die Versionen auch von Debian Security getrackt.
                          Nebenher kann man Pakete aber auch per python pip installieren. Dann läuft es natürlich an apt/dpkg ungesehen vorbei.
                          Und da dieses 'wilde installieren von irgendwas von irgendwoher' bei den Distributionen für Kopfschmerzen gesorgt hat, weil dann andere Dinge dadurch kaputt gingen hat man das ganze per 'externally managed system' ausgebremst. So einfach kann man nun nicht mehr per pip global python-Pakete nachinstallieren.
                            und wo ist dann noch der Bezug zu ioBroker?
                            Hat sich das jetzt in Luft aufgelöst, und der Thread kann nach offTopic?
                              Ja genau. Der Bezug zu iobroker ließ sich insofern klären, dass es keinen gibt 🙂
                                ich würde sogar doweit gehen zu behaupten, dass diese Lücke nur User betreffen könnte, die dieses Modul in Verbindung mit eigenen python Programmen verwenden.
                                Allerdi gs fehlt mir für eine gesicherte Aussage die notwendige Expertise
                                  Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                  Weil es mir gerade beim Update meines siduction-Systems aufgefallen ist:
                                  [2024-09-11] Accepted python-certifi 2024.8.30-1 (source) into unstable (Sebastien Delafond)
                                  https://tracker.debian.org/pkg/python-certifi
                                  1310
