    3. Off Topic
    4. "certifi"-Sicherheitslücke bei iobroker Raspberry Pi
    UNSOLVED "certifi"-Sicherheitslücke bei iobroker Raspberry Pi
      sticks @Thomas Braun last edited by
      Hi, nein, das habe ich noch nicht gemacht.
      Hier die Ergebnisse:
      # npm audit report
      @75lb/deep-merge  <=1.1.1
      Severity: high
      @75lb/deep-merge Prototype Pollution vulnerability - https://github.com/advisori        es/GHSA-28mc-g557-92m7
      fix available via `npm audit fix`
      node_modules/@75lb/deep-merge
      axios  0.8.1 - 0.27.2 || 1.0.0 - 1.7.3
      Severity: high
      Axios Cross-Site Request Forgery Vulnerability - https://github.com/advisories/G        HSA-wf5p-g6vw-rhxx
      Server-Side Request Forgery in axios - https://github.com/advisories/GHSA-8hc4-v        h64-cxmj
      fix available via `npm audit fix --force`
      Will install iobroker.unifi@0.6.3, which is a breaking change
      node_modules/@alcalzone/pak/node_modules/axios
      node_modules/axios
      node_modules/iobroker.daswetter/node_modules/axios
      node_modules/iobroker.javascript/node_modules/axios
      node_modules/iobroker.parser/node_modules/axios
      node_modules/iobroker.socketio/node_modules/axios
      node_modules/iobroker.switchbot-hub/node_modules/axios
      node_modules/iobroker.ws/node_modules/axios
      node_modules/node-hue-api/node_modules/axios
      node_modules/node-ical/node_modules/axios
      node_modules/node-unifi/node_modules/axios
        @alcalzone/pak  0.3.0 - 0.10.0
        Depends on vulnerable versions of axios
          @iobroker/js-controller-adapter  *
          Depends on vulnerable versions of @alcalzone/pak
          Depends on vulnerable versions of @iobroker/db-objects-file
          Depends on vulnerable versions of @iobroker/db-objects-jsonl
          Depends on vulnerable versions of @iobroker/db-objects-redis
          Depends on vulnerable versions of @iobroker/db-states-file
          Depends on vulnerable versions of @iobroker/db-states-jsonl
          Depends on vulnerable versions of @iobroker/db-states-redis
          Depends on vulnerable versions of @iobroker/js-controller-common
          Depends on vulnerable versions of @iobroker/js-controller-common-db
          node_modules/@iobroker/js-controller-adapter
            iobroker.js-controller  >=4.0.0-alpha.1-20210830-d9828cd3
            Depends on vulnerable versions of @iobroker/js-controller-adapter
            Depends on vulnerable versions of @iobroker/js-controller-cli
            node_modules/iobroker.js-controller
          @iobroker/js-controller-common-db  >=6.0.1-alpha.0-20240522-6037ce8ae
          node_modules/@iobroker/js-controller-common-db
            @iobroker/db-base  >=6.0.1-alpha.0-20240522-6037ce8ae
            node_modules/@iobroker/db-base
              @iobroker/db-objects-file  >=6.0.1-alpha.0-20240522-6037ce8ae
              Depends on vulnerable versions of @iobroker/db-base
              node_modules/@iobroker/db-objects-file
              @iobroker/db-objects-jsonl  >=6.0.1-alpha.0-20240522-6037ce8ae
              node_modules/@iobroker/db-objects-jsonl
              @iobroker/db-objects-redis  >=6.0.1-alpha.0-20240522-6037ce8ae
              node_modules/@iobroker/db-objects-redis
              @iobroker/db-states-file  >=6.0.1-alpha.0-20240522-6037ce8ae
              node_modules/@iobroker/db-states-file
              @iobroker/db-states-jsonl  >=6.0.1-alpha.0-20240522-6037ce8ae
              node_modules/@iobroker/db-states-jsonl
              @iobroker/db-states-redis  >=6.0.1-alpha.0-20240522-6037ce8ae
              node_modules/@iobroker/db-states-redis
            @iobroker/js-controller-cli  >=6.0.1-alpha.0-20240522-6037ce8ae
            node_modules/@iobroker/js-controller-cli
            @iobroker/js-controller-common  >=6.0.1-alpha.0-20240522-6037ce8ae
        iobroker.switchbot-hub  *
        iobroker.unifi  >=0.6.4
        Depends on vulnerable versions of node-unifi
        node_modules/iobroker.unifi
        node-hue-api  2.0.0-RC1 - 5.0.0-alpha.2
          iobroker.hue  >=0.6.2
          Depends on vulnerable versions of node-hue-api
          node_modules/iobroker.hue
        node-ical  0.15.3 - 0.16.1
          iobroker.jarvis  >=3.0.0
          Depends on vulnerable versions of ip
          Depends on vulnerable versions of node-ical
          Depends on vulnerable versions of semver
          node_modules/iobroker.jarvis
        node-unifi  >=2.3.0
      braces  <3.0.3
      Severity: high
      Uncontrolled resource consumption in braces - https://github.com/advisories/GHSA        -grv7-fg5c-xmjg
      node_modules/braces
      debug  <=2.6.8 || 4.0.0 - 4.3.0
      Severity: high
      debug Inefficient Regular Expression Complexity vulnerability - https://github.c        om/advisories/GHSA-9vvw-cc9w-f27h
      Regular Expression Denial of Service in debug - https://github.com/advisories/GH        SA-gxpj-cx7g-858c
      Depends on vulnerable versions of ms
      Will install iobroker.tr-064@0.0.8, which is a breaking change
      node_modules/engine.io-client/node_modules/debug
      node_modules/iobroker.socketio/node_modules/debug
      node_modules/iobroker.web/node_modules/debug
      node_modules/mdns-discovery/node_modules/debug
      node_modules/socket.io-client/node_modules/debug
      node_modules/socket.io-parser/node_modules/debug
        engine.io  0.7.8 - 0.7.9 || 3.4.0 - 6.5.4
        Depends on vulnerable versions of debug
        Depends on vulnerable versions of ws
        node_modules/iobroker.socketio/node_modules/engine.io
        node_modules/iobroker.web/node_modules/engine.io
          socket.io  2.2.0 - 3.0.4
          Depends on vulnerable versions of engine.io
          Depends on vulnerable versions of socket.io-parser
          node_modules/iobroker.socketio/node_modules/socket.io
          node_modules/iobroker.web/node_modules/socket.io
            iobroker.socketio  3.0.0 - 3.0.13 || 3.1.3 - 3.1.5 || 4.1.0 - 5.0.2 || 6.1        .0 - 6.5.7 || >=6.6.0
            node_modules/iobroker.web/node_modules/iobroker.socketio
              iobroker.web  4.2.1 - 4.3.0 || >=5.2.3
              Depends on vulnerable versions of iobroker.socketio
        engine.io-client  <=3.1.1 || 3.5.0 - 3.5.3 || 4.0.0-alpha.0 - 5.2.0
        Depends on vulnerable versions of parsejson
        node_modules/iobroker.web/node_modules/engine.io-client
          socket.io-client  1.0.0-pre - 2.1.1
          Depends on vulnerable versions of engine.io-client
            iobroker.cloud  <=2.4.6 || 2.8.0 - 3.0.2 || >=4.0.11
            Depends on vulnerable versions of socket.io-client
            node_modules/iobroker.cloud
        mdns-discovery  >=0.0.4
        Depends on vulnerable versions of dns-packet
          iobroker.discovery  *
          Depends on vulnerable versions of mdns-discovery
          Depends on vulnerable versions of node-ssdp
          node_modules/iobroker.discovery
          iobroker.tr-064  >=0.1.1
          Depends on vulnerable versions of tr-O64
          Depends on vulnerable versions of xml2js
          node_modules/iobroker.tr-064
        socket.io-parser  <=3.3.3 || 3.4.0 - 4.0.2
        node_modules/iobroker.socketio/node_modules/socket.io-parser
        node_modules/iobroker.web/node_modules/socket.io-client/node_modules/socket.io        -parser
        node_modules/iobroker.web/node_modules/socket.io-parser
      ip  *
      Severity: high
      ip SSRF improper categorization in isPublic - https://github.com/advisories/GHSA        -2p57-rm9w-gvfp
      Will install iobroker.jarvis@3.1.3, which is a breaking change
      node_modules/ip
        dns-packet  <=5.2.4
        node_modules/dns-packet
        node-ssdp  >=1.0.1
        node_modules/node-ssdp
      lodash  <=4.17.20
      Severity: critical
      Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advi        sories/GHSA-x5rq-j2xg-h7qm
      Prototype Pollution in lodash - https://github.com/advisories/GHSA-4xc9-xhrj-v57        4
      Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advi        sories/GHSA-29mw-wpgm-hmr9
      Prototype Pollution in lodash - https://github.com/advisories/GHSA-p6mc-m468-83g        w
      Command Injection in lodash - https://github.com/advisories/GHSA-35jh-r3h4-6jhm
      Prototype Pollution in lodash - https://github.com/advisories/GHSA-fvqr-27wr-82f        m
      Prototype Pollution in lodash - https://github.com/advisories/GHSA-jf85-cpcp-j69        5
      Will install iobroker.modbus@0.3.11, which is a breaking change
      node_modules/stampit/node_modules/lodash
        stampit  2.0.1 - 2.1.2
        Depends on vulnerable versions of lodash
          iobroker.modbus  >=0.4.5
          Depends on vulnerable versions of put
          Depends on vulnerable versions of stampit
          Depends on vulnerable versions of stampit-event-bus
          Depends on vulnerable versions of stampit-state-machine
          node_modules/iobroker.modbus
          stampit-event-bus  *
          node_modules/stampit-event-bus
          stampit-state-machine  *
          node_modules/stampit-state-machine
      micromatch  <4.0.8
      Severity: moderate
      Regular Expression Denial of Service (ReDoS) in micromatch - https://github.com/        advisories/GHSA-952p-6rrq-rcjv
      node_modules/micromatch
      ms  <2.0.0
      Severity: moderate
      Vercel ms Inefficient Regular Expression Complexity vulnerability - https://gith        ub.com/advisories/GHSA-w9mr-4mfr-499f
      node_modules/engine.io-client/node_modules/ms
      node_modules/mdns-discovery/node_modules/ms
      node_modules/socket.io-client/node_modules/ms
      node_modules/socket.io-parser/node_modules/ms
      parsejson  *
      Severity: high
      Regular Expression Denial of Service in parsejson - https://github.com/advisorie        s/GHSA-q75g-2496-mxpp
      Will install iobroker.cloud@4.0.10, which is a breaking change
      node_modules/parsejson
      path-to-regexp  <=0.1.9 || 0.2.0 - 7.2.0
      Severity: high
      path-to-regexp outputs backtracking regular expressions - https://github.com/adv        isories/GHSA-9wv6-86v2-598j
      Will install iobroker.simple-api@2.7.2, which is a breaking change
      node_modules/nise/node_modules/path-to-regexp
        express  4.0.0-rc1 - 4.19.2 || 5.0.0-alpha.1 - 5.0.0-beta.3
        Depends on vulnerable versions of path-to-regexp
        node_modules/express
        nise  *
        node_modules/nise
          sinon  >=3.0.0
          Depends on vulnerable versions of nise
          node_modules/sinon
            @iobroker/testing  *
            Depends on vulnerable versions of sinon
            Depends on vulnerable versions of sinon-chai
            node_modules/@iobroker/testing
              iobroker.simple-api  >=2.8.0
              Depends on vulnerable versions of @iobroker/testing
              node_modules/iobroker.simple-api
            sinon-chai  >=3.0.0
            node_modules/sinon-chai
      put  *
      Sensitive Data Exposure in put - https://github.com/advisories/GHSA-v6gv-fg46-h8        9j
      node_modules/put
      request  *
      Severity: moderate
      Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7        -x288-28g6
      Depends on vulnerable versions of tough-cookie
      Will install iobroker.backitup@0.2.7, which is a breaking change
      node_modules/request
        dropbox-v2-api  *
        Depends on vulnerable versions of request
        node_modules/dropbox-v2-api
          iobroker.backitup  >=0.3.0
          Depends on vulnerable versions of dropbox-v2-api
          node_modules/iobroker.backitup
        iobroker.javascript  *
        iobroker.vw-connect  *
        node_modules/iobroker.vw-connect
        tr-O64  *
        node_modules/tr-O64
      semver  7.0.0 - 7.5.1
      Severity: high
      semver vulnerable to Regular Expression Denial of Service - https://github.com/a        dvisories/GHSA-c2qf-rxjj-qqgw
      node_modules/iobroker.jarvis/node_modules/semver
      tough-cookie  <4.1.3
      Severity: moderate
      tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/G        HSA-72xf-g2v4-qvf3
      node_modules/tough-cookie
      ws  2.1.0 - 5.2.3 || 7.0.0 - 7.5.9 || 8.0.0 - 8.17.0
      Severity: high
      ws affected by a DoS when handling a request with many HTTP headers - https://gi        thub.com/advisories/GHSA-3h5v-q93c-6h6q
      node_modules/engine.io/node_modules/ws
      node_modules/iobroker.web/node_modules/ws
      node_modules/socket.io-adapter/node_modules/ws
      node_modules/websocket-stream/node_modules/ws
        socket.io-adapter  2.5.2 - 2.5.4
        websocket-stream  4.0.0 - 5.1.2 || >=5.4.0
          iobroker.mqtt  >=2.1.0
          Depends on vulnerable versions of websocket-stream
          node_modules/iobroker.mqtt
      xml2js  <0.5.0
      Severity: moderate
      xml2js is vulnerable to prototype pollution - https://github.com/advisories/GHSA        -776f-qx25-q3cc
      node_modules/xml2js
        iobroker.onkyo  >=2.0.0
        node_modules/iobroker.onkyo
      68 vulnerabilities (4 low, 28 moderate, 34 high, 2 critical)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues possible (including breaking changes), run:
      Some issues need review, and may require choosing
      a different dependency.
        Thomas Braun Most Active @sticks last edited by Thomas Braun
        @sticks
        Deine Herumgehampel als root halte ich im Übrigen für das größere Sicherheitsproblem...
        Sorry, der Report fängt mit einer Raute an...
        Ich wollte auch eigentlich nur deutlich machen, das jedes System offene 'Issues' hat. Die kannst du eh nicht alle angehen. Regelmäßige Systempflege sollte reichen. Um die konkrete Klassifizierung der Dinger kümmert sich im Fall von Debian halt das 'Debian Security Team'.
        Die können hoffentlich die konkrete Schwere des Problems für die einzelnen Releases bewerten.
          sticks @Thomas Braun last edited by sticks
          Da mir Tenable im "normalen" SSH-Context die ganze Linux-Befehlshistorie mit tausenden Prüfbefehlen auf Schwachstellen voll haut,arbeite ich gerne im Root Context da ich dort dann meine eigene Befehlshistorie sehe. Das das von manchen Linux-Profis nicht gern gesehen wird, ist mir klar.
          (PS: Stimmt, in dem Fall oben habe ich sogar im normalen User-Context gearbeitet. 😉 )
          Ich selbst habe alle meine Serversysteme (viele Raspberrys, 2x ESXi Server, paar Windows-Server, NAS-Systeme) in der kostenlosen Lösung von Tenable Nessus. Ich patche die meisten Linux-Systeme daher mindestens einmal die Woche, da immer einige Schwachstellen vorhanden sind, wie du schon sagst. Pro System sind oft 50-80 Schwachstellen völlig normal. - Wenn eine Schwachstelle aber als "hochkritisch" eingestuft wird, wie in diesem Fall geschehen, stecke ich meist einige Energie rein das abzustellen. - Manchmal ist dies nicht möglich, im Fall jetzt hätte es ja sein können das dies mit einem bestimmten Befehl oder Deinstallation eines bestimmten iobroker Adapters gelöst gewesen wäre. - Dies ist aber nicht der Fall, von daher muss ich das einfach so hinnehmen. Was beruhigt, das die Schwachstellenbewertung "kritisch" hier ja eher unzutreffend zu sein scheint.
          Demnach hat mein Raspberry mit iobroker derzeoit 92x harmlose Schwachstelllen, 5x medium Schwachstellen und eben diese 1x certifi die als kritisch eingestuft wird.
            @sticks sagte in "certifi"-Sicherheitslücke bei iobroker Raspberry Pi:
            ??? Die Historie ist doch als user viel besser zu sehen. Inkl. eines Wechsels in die root-Rolle.
            Lass den Quark mit der root shell einfach bleiben.
            Das Verhalten ist gefährlicher als deine ganzen 'Issues', die du da panisch versuchst zu stopfen.
              Panisch ist hier keiner. Ich gehe besonnen an die Sache heran:
              Nach Bekanntwerden der vermeintlich kritischen Lücke versucht man sich bestmöglich in die unbekannte Materie einzulesen. Habe mich eingearbeitet, durch das Github gelesen und dort stand ja mehr oder weniger: Wenn du genau dieses Problem/Sicherheitslücke hast dann mach mit pip ein Update und die Sache ist gelöst, denn der Maintainer con certifi hat sich schon drum gekümmert. - Ja, in diesem Fall war die Installation von pip unnötig, aber das konnte ich der Github Dokumentation zu certifi erstmal nicht entnehmen, stand da doch man kann die Lücke durch ein pip install certifi stopfen. - Als ich danach aber den Hinweis bekam, dass das ganze "externally-managed-environment" ist, war natürlich auch für mich klar, dass ich hiermit keinen Erfolg werden habe. Insofern, wenn das ganze "externally-managed-environment" ist, dann frage ich doch mal die Jungs im iobroker Forum, vielleicht ist das Problem dort ja schon bekannt. Hier habe ich nun die Hinweise auf Debian bekommen, damit ist die Sache für mich auch OK, habe ich doch jetzt die Gewissheit das ich hier nichts übersehen / fremdverursacht habe.
              Kommentare zu Herumgebastel, Quark und Panik halte ich hingegen für unangebracht für einen professionellen Austausch.
                Da keiner von uns beiden offenbar Profi ist passt das wieder.
                  Homoran Global Moderator Administrators @sticks last edited by
                  wo soll's denn sonst herkommen?
                    sticks @Homoran last edited by sticks
                    Woanders her. - Gibt ja viele Wege wie Dateien/Pakete in einem Linux-System landen können, evtl. eben auch durch iobroker selbst.
                    In meinem Fall habe ich z.B. zwei unterschiedliche Raspberry Pis, beide haben ein topaktuelles Debian Bookworm als Betriebssystem. Der Raspberry mit iobroker-Installation meldet mir die certifi-Sicherheitslücke, der Raspberry auf dem nur FHEM läuft hat die Lücke (noch) nicht gemeldet. - Von daher habe ich natürlich im iobroker-Bereich mit Problematiken gerechnet.
                    Edit: Der FHEM-PI hat die Lücke aber scheinbar auch, macht ja auch Sinn, das ist nur noch nicht über Tenable Nessus gemeldet:
                    fhempi:~ $ apt policy python3-certifi
                    python3-certifi:
                      Installiert:           2022.9.24-1
                      Installationskandidat: 2022.9.24-1
                      Versionstabelle:
                     *** 2022.9.24-1 500
                            500 http://deb.debian.org/debian bookworm/main armhf Packages
                            100 /var/lib/dpkg/status
                      Homoran Global Moderator Administrators @sticks last edited by Homoran
                      aber dann würde iobroker python ja auch über apt aus debian Quellen installieren.
                      iobroker selbst ist javascript/nodejs code
                      auch EDIT:
                      Das ergibt auch Sinn, weil meines Wissens Python mit dem OS mitkommt.
                        @homoran sagte in "certifi"-Sicherheitslücke bei iobroker Raspberry Pi:
                        Python selber schon. Die meisten (bzw. sehr viele) python-Pakete kann man direkt aus den Debian-Repos angeln. Pakete heißen dann immer 'python3-$PYTHONMODUL'. Dann sind die Versionen auch von Debian Security getrackt.
                        Nebenher kann man Pakete aber auch per python pip installieren. Dann läuft es natürlich an apt/dpkg ungesehen vorbei.
                        Und da dieses 'wilde installieren von irgendwas von irgendwoher' bei den Distributionen für Kopfschmerzen gesorgt hat, weil dann andere Dinge dadurch kaputt gingen hat man das ganze per 'externally managed system' ausgebremst. So einfach kann man nun nicht mehr per pip global python-Pakete nachinstallieren.
                          und wo ist dann noch der Bezug zu ioBroker?
                          Hat sich das jetzt in Luft aufgelöst, und der Thread kann nach offTopic?
                            Ja genau. Der Bezug zu iobroker ließ sich insofern klären, dass es keinen gibt 🙂
                              ich würde sogar doweit gehen zu behaupten, dass diese Lücke nur User betreffen könnte, die dieses Modul in Verbindung mit eigenen python Programmen verwenden.
                              Allerdi gs fehlt mir für eine gesicherte Aussage die notwendige Expertise
                                Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                Weil es mir gerade beim Update meines siduction-Systems aufgefallen ist:
                                [2024-09-11] Accepted python-certifi 2024.8.30-1 (source) into unstable (Sebastien Delafond)
                                https://tracker.debian.org/pkg/python-certifi
                                1315
