    4. Icon mit Farbe je nach Temperatur-Wert eines Sensors
      Warum nimmst du nicht das Widget Basic value list HTML?
      Ok, ich weiß nicht, ob du da für die Beschriftung auf die Werte eines Datenpunkts zugreifen kannst.
      Auf jeden Fall kannst Du da die Farbe nach Zustand ändern.
      Werde das aber mal mit deinem valve Widget testen. Dauert aber was am Tablet.
      Rainer
        Bei mir klappt es mit der Farbe des Icons.
        War allerdings faul und habe nicht zu viel eingetragen.
        [{"tpl":"tplMfdCustom10","data":{"oid":"hm-rpc.1.LEQ0773306.2.TEMPERATURE","visibility-cond":"==","visibility-val":1,"asButton":true,"icon0":"widgets/jqui-mfd/img/sani_valve_0.svg","icon1":"widgets/jqui-mfd/img/sani_valve_10.svg","icon2":"widgets/jqui-mfd/img/sani_valve_20.svg","icon3":"widgets/jqui-mfd/img/sani_valve_30.svg","icon4":"widgets/jqui-mfd/img/sani_valve_40.svg","icon5":"widgets/jqui-mfd/img/sani_valve_50.svg","icon6":"widgets/jqui-mfd/img/sani_valve_60.svg","icon7":"widgets/jqui-mfd/img/sani_valve_70.svg","icon8":"widgets/jqui-mfd/img/sani_valve_80.svg","icon9":"widgets/jqui-mfd/img/sani_valve_90.svg","icon10":"widgets/jqui-mfd/img/sani_valve_100.svg","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"min":"20","max":"30","iconColor10":"#f40906","iconColor9":"#efb40b","iconColor8":"#f7ce36","iconColor7":"#ece813","iconColor6":"#a847f5","iconColor5":"#2443e0"},"style":{"left":"511px","top":"141px"},"widgetSet":"jqui-mfd"}]
        Rainer
          apollon77 last edited by
          Hey,
          ich will ja nicht die Text-Werte farblich machen sondern ein Icon was davor steht, also in der Art so:
          Das Icon bekommt noch die Warnsymbole eingeblendet für LOWBAT und UNREACH 🙂
          Habe gerade mal das valuelist gecheckt … da muss ich glaube ich noch mehr einsteigen wie ich da das Bild hinbekomme oder die Farben flexibilisieren?! Hab ich gerade spontan nicht gefunden 😞
            H …. dann muss ich heute Abend nochmal spielen und mir deins anschauen...
              Ooohje … gefunden ...
              Mit SVG Icons tut es ... mit PNG nicht 😞
              Andere off-Topic Frage: Wann werden denn die icons (speziell mdf) aktualisiert? Was muss man dazu tun?
              Es gibt neue Icons im Set laut deren Webseite. Habe nur gesehen das die wohl beim installieren des Adapters geladen werden ... Muss ich für ein Update den Adapter also löschen und neu anlegen?
                @apollon77:
                Es gibt neue Icons im Set laut deren Webseite. Habe nur gesehen das die wohl beim installieren des Adapters geladen werden … Muss ich für ein Update den Adapter also löschen und neu anlegen? `
                Ich denke du musst Bluefox ganz lieb bitten ein Update für den Adapter mit den neuen Icons zu machen 😉
                Rainer
                  Jain … wenn ich den Code richtig verstehe wird es bei der Installation automagisch runtergeladen und ist gar nicht im Paket selbst drin
                    Dann würde ich einfach mal drüberinstallieren.
                    Vorher npm cache clean
                    Viel Glück
                    Rainer
                      A Former User last edited by Homoran
                      dieser Beitrag ist zwar schon etwas älter, dennoch habe ich seit Jahren schon mehrere funktionierende Lösungen.
                      Meine neuste läuft bereits rein über php und zeigt zu jeder einzelnen Temperatur in 0,1°-Schriiten einen Farbwert, und auch die Farbe selbst.
                      Zuvor hatte ich bereits Bilder, wie im Eingangspost erwähnt und danach eine Javascript-Lösung. Die neueste Variante kann man sogar in einer sich ständig aktualisierenden PDF-Datei einbinden.
                      Falls hieran irgendjemand Interesse hat biete ich meine Hilfe an.
                      Mit freundlichen Grüßen
                        Einstein2002 @Guest last edited by Homoran
                        @solarfanenrico sagte in Icon mit Farbe je nach Temperatur-Wert eines Sensors:
                        ich würde gerne auf Deine Hilfe zurückkommen. Oder auf jede andere Hilfe.
                        Was möchte ich machen? Ich habe eine Raumtemperaturanzeige und die soll in den verschiedenen Farben je nach Temperatur Anzeigen.
                        Ich habe das Value & Indicator versucht, steige aber nicht so richtig durch wie ich was wo einzustellen habe.
                        Danke jetzt schon mal.
                        Gruß Michael
                          Homoran Global Moderator Administrators @Einstein2002 last edited by
                          @einstein2002 sagte in Icon mit Farbe je nach Temperatur-Wert eines Sensors:
                          wo haperts denn?
                            Einstein2002 @Homoran last edited by
                            Das habe ich eingestellt, aber die Anzeige bleibt immer nur weiß
                              @einstein2002 da fehlt min, mid und max
                                Okay,
                                was wären denn vernünftige Werte für einen Innenraum?
                                0, 15 40?
                                  Okay,
                                  0, 15 40?
                                  nicht wirklich!
                                  18, 21, 25??
                                  kältest gewünschte, wohlfühltemperatur, Hitzegrenze
                                  probiers aus
                                    Bleibt weiterhin weiß
                                    Hatte erst mit meinen Werten und jetzt Deine Werte gesetzt, nur wenn ich die 3 Farben lösche Ändert sich etwas, aber ich kann nicht genau nachvollziehen wie sich dann die Farben ändern.
                                      was?
                                      E 2 Replies Last reply Reply Quote 0
                                        Ich habe jetzt die drei Farben gelöscht und meine Anzeige springt auf Rot.
                                        Ich ändere mal die Temperatur zum Test um, denke aber so könnte es gehen.
                                        Ich melde mich gleich...
                                          Danke das war der entscheidende Tipp!!
                                          Jetzt geht es, Dankeschön!!!!
                                            @einstein2002 hab's gerade angesehen
                                            dann hab ich -wie du- Hintergrund angehakt
                                            null problemo
                                            2975
