    4. Backup-Erstellung - Hinweis auf js-controller 4.1
    • Ro75
      Ro75 last edited by
      Backup Protokoll
      [DEBUG] [iobroker] host.ubuntu-server 15310 states saved
      [DEBUG] [iobroker] host.ubuntu-server 16487 objects saved
      [DEBUG] [iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_09_10-02_10_10_backupiobroker.tar.gz
      [DEBUG] [iobroker] This backup can only be restored with js-controller version up from 4.1
      [DEBUG] [iobroker] done
      [DEBUG] [influxDB] InfluxDB-Backup for is started ...
      [DEBUG] [influxDB] Start InfluxDB Backup ...
      [DEBUG] [influxDB] InfluxDB Backup tmp directory created
      [DEBUG] [influxDB] Backup created: /opt/iobroker/backups/influxDB_2024_09_10-02_10_21_backupiobroker.tar.gz
      [DEBUG] [influxDB] Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_09_10-02_10_21_backupiobroker"
      [DEBUG] [influxDB] InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_09_10-02_10_21_backupiobroker" successfully deleted
      [DEBUG] [influxDB] InfluxDB-Backup for is finish
      [DEBUG] [influxDB] Backup created: /opt/iobroker/backups/influxDB_2024_09_10-02_10_32_backupiobroker.tar.gz
      [DEBUG] [influxDB] Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_09_10-02_10_32_backupiobroker"
      [DEBUG] [influxDB] InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_09_10-02_10_32_backupiobroker" successfully deleted
      [DEBUG] [influxDB] done
      [DEBUG] [mysql] MySql-Backup started ...
      [DEBUG] [mysql] MySql File deleted!
      [DEBUG] [mysql] MySql-Backup for is finish
      [DEBUG] [mysql] done
      [DEBUG] [redis] Start Redis Backup ...
      [DEBUG] [redis] Created redistmp directory
      [DEBUG] [redis] detected redis file: dump.rdb | file type: rdb
      [DEBUG] [redis] Packed 131MB so far...
      [DEBUG] [redis] Packed 282MB so far...
      [DEBUG] [redis] Backup created: /opt/iobroker/backups/redis_2024_09_10-02_10_33_backupiobroker.tar.gz
      [DEBUG] [redis] Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
      [DEBUG] [redis] redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
      [DEBUG] [redis] done
      [DEBUG] [zigbee] found zigbee database: zigbee.0
      [DEBUG] [zigbee] done
      [DEBUG] [grafana] Start Grafana Backup ...
      [DEBUG] [grafana] Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
      [DEBUG] [grafana] Created dashboard directory
      [DEBUG] [grafana] Created dashboards_manually_restore directory
      [DEBUG] [grafana] Created datasource directory
      [DEBUG] [grafana] start Grafana request ...
      [DEBUG] [grafana] Grafana is available ... Status: 200
      [DEBUG] [grafana] found Dashboard: tanken
      [DEBUG] [grafana] found Dashboard: 10-monate
      [DEBUG] [grafana] found Dashboard: hardware
      [DEBUG] [grafana] found Dashboard: 3-tage
      [DEBUG] [grafana] found Dashboard: 10-tage
      [DEBUG] [grafana] found Dashboard: 24-stunden
      [DEBUG] [grafana] found Dashboard: 15-minuten
      [DEBUG] [grafana] found Dashboard: 7-tage
      [DEBUG] [grafana] found Dashboard: 12-monate
      [DEBUG] [grafana] found Dashboard: 12-stunden
      [DEBUG] [grafana] found Dashboard: 60-minuten
      [DEBUG] [grafana] found Dashboard: langzeit
      [DEBUG] [grafana] start Grafana backup compress ...
      [DEBUG] [grafana] Backup created: /opt/iobroker/backups/grafana_2024_09_10-02_10_57_backupiobroker.tar.gz
      [DEBUG] [grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
      [DEBUG] [grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
      [DEBUG] [grafana] done
      [DEBUG] [javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] found Script: QRAnzeige
      [DEBUG] [javascripts] found Script: APIpiHole
      [DEBUG] [javascripts] found Script: Biowetter
      [DEBUG] [javascripts] found Script: Luftdaten
      [DEBUG] [javascripts] found Script: Boinc
      [DEBUG] [javascripts] found Script: WOL
      [DEBUG] [javascripts] found Script: test603349
      [DEBUG] [javascripts] found Script: DBPowerManagement
      [DEBUG] [javascripts] found Script: Zigbee
      [DEBUG] [javascripts] found Script: WANInfo
      [DEBUG] [javascripts] found Script: Parcel
      [DEBUG] [javascripts] found Script: Equalizer
      [DEBUG] [javascripts] found Script: Kontakte
      [DEBUG] [javascripts] found Script: Pollenflug
      [DEBUG] [javascripts] found Script: Meldungen
      [DEBUG] [javascripts] found Script: Kalender_gross
      [DEBUG] [javascripts] found Script: Vorhersage
      [DEBUG] [javascripts] found Script: Nachrichtensystem
      [DEBUG] [javascripts] found Script: Gerätesteuerung
      [DEBUG] [javascripts] found Script: HPYasu
      [DEBUG] [javascripts] found Script: DetailInfoListen
      [DEBUG] [javascripts] found Script: Speedtest
      [DEBUG] [javascripts] found Script: Haushaltgeräte
      [DEBUG] [javascripts] found Script: GeoDaten
      [DEBUG] [javascripts] found Script: Belüftung
      [DEBUG] [javascripts] found Script: TimerCountdown
      [DEBUG] [javascripts] found Script: Bildzuordnung
      [DEBUG] [javascripts] found Script: Beleuchtung
      [DEBUG] [javascripts] found Script: Kalender_mini
      [DEBUG] [javascripts] found Script: AkiveView
      [DEBUG] [javascripts] found Script: Rechenkraft
      [DEBUG] [javascripts] found Script: PCRyzen
      [DEBUG] [javascripts] found Script: Listen
      [DEBUG] [javascripts] found Script: Geräteüberwachung
      [DEBUG] [javascripts] found Script: vis-materialdesign0
      [DEBUG] [javascripts] found Script: HPConvertible
      [DEBUG] [javascripts] found Script: InfoListen
      [DEBUG] [javascripts] found Script: UbuntuServer
      [DEBUG] [javascripts] found Script: SNMP
      [DEBUG] [javascripts] found Script: Dashboard
      [DEBUG] [javascripts] found Script: DeviceStatistik
      [DEBUG] [javascripts] found Script: WifiBat
      [DEBUG] [javascripts] found Script: DBWallpaper
      [DEBUG] [javascripts] found Script: AqaraSchalter
      [DEBUG] [javascripts] found Script: IstaAblesung
      [DEBUG] [javascripts] found Script: MyCloudEx2Ultra
      [DEBUG] [javascripts] found Script: Hauptsteuerung
      [DEBUG] [javascripts] found Script: Volumensteuerung
      [DEBUG] [javascripts] found Script: WhatsApp
      [DEBUG] [javascripts] found Script: WindowsAnzeige
      [DEBUG] [javascripts] found Script: Berechnungen
      [DEBUG] [javascripts] found Script: Musik
      [DEBUG] [javascripts] found Script: Zeitplanung
      [DEBUG] [javascripts] found Script: enums_list
      [DEBUG] [javascripts] found Script: Wetterwarnung
      [DEBUG] [javascripts] found Script: RandomUserAgent
      [DEBUG] [javascripts] found Script: WetterBilderTagNacht
      [DEBUG] [javascripts] found Script: systemweit
      [DEBUG] [javascripts] found Script: OMVNas
      [DEBUG] [javascripts] found Script: Tankstellen
      [DEBUG] [javascripts] found Script: PINAbfrage
      [DEBUG] [javascripts] found Script: LastFM
      [DEBUG] [javascripts] found Script: InfluxAliasKor
      [DEBUG] [javascripts] found Script: Briefanzeige
      [DEBUG] [javascripts] found Script: Anrufbeantworter
      [DEBUG] [javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      [DEBUG] [javascripts] Backup created: /opt/iobroker/backups/javascripts_2024_09_10-02_11_03_backupiobroker.tar.gz
      [DEBUG] [javascripts] done
      [DEBUG] [ftp] FTP connected.
      [DEBUG] [ftp] Send iobroker_2024_09_10-02_10_10_backupiobroker.tar.gz
      [DEBUG] [ftp] Send influxDB_2024_09_10-02_10_21_backupiobroker.tar.gz
      [DEBUG] [ftp] Send influxDB_2024_09_10-02_10_32_backupiobroker.tar.gz
      [DEBUG] [ftp] Send mysql_2024_09_10-02_10_33_backupiobroker.tar.gz
      [DEBUG] [ftp] Send redis_2024_09_10-02_10_33_backupiobroker.tar.gz
      [DEBUG] [ftp] Send zigbee.0_2024_09_10-02_10_56_backupiobroker.tar.gz
      [DEBUG] [ftp] Send grafana_2024_09_10-02_10_57_backupiobroker.tar.gz
      [DEBUG] [ftp] Send javascripts_2024_09_10-02_11_03_backupiobroker.tar.gz
      [DEBUG] [ftp] delete /iobroker_2024_09_05-02_10_10_backupiobroker.tar.gz
      [DEBUG] [ftp] delete /influxDB_2024_09_05-02_10_21_backupiobroker.tar.gz
      [DEBUG] [ftp] delete /influxDB_2024_09_05-02_10_32_backupiobroker.tar.gz
      [DEBUG] [ftp] delete /mysql_2024_09_05-02_10_32_backupiobroker.tar.gz
      [DEBUG] [ftp] delete /redis_2024_09_05-02_10_33_backupiobroker.tar.gz
      [DEBUG] [ftp] delete /zigbee.0_2024_09_05-02_10_56_backupiobroker.tar.gz
      [DEBUG] [ftp] delete /grafana_2024_09_05-02_10_57_backupiobroker.tar.gz
      [DEBUG] [ftp] delete /javascripts_2024_09_05-02_11_03_backupiobroker.tar.gz
      [DEBUG] [ftp] done
      [DEBUG] [clean] delete /opt/iobroker/backups/iobroker_2024_09_05-02_10_10_backupiobroker.tar.gz
      [DEBUG] [clean] delete /opt/iobroker/backups/influxDB_2024_09_05-02_10_32_backupiobroker.tar.gz
      [DEBUG] [clean] delete /opt/iobroker/backups/influxDB_2024_09_05-02_10_21_backupiobroker.tar.gz
      [DEBUG] [clean] delete /opt/iobroker/backups/mysql_2024_09_05-02_10_32_backupiobroker.tar.gz
      [DEBUG] [clean] delete /opt/iobroker/backups/redis_2024_09_05-02_10_33_backupiobroker.tar.gz
      [DEBUG] [clean] delete /opt/iobroker/backups/zigbee.0_2024_09_05-02_10_56_backupiobroker.tar.gz
      [DEBUG] [clean] delete /opt/iobroker/backups/grafana_2024_09_05-02_10_57_backupiobroker.tar.gz
      [DEBUG] [clean] delete /opt/iobroker/backups/javascripts_2024_09_05-02_11_03_backupiobroker.tar.gz
      [DEBUG] [clean] done
      [DEBUG] [historyHTML] new history html values created
      [DEBUG] [historyHTML] done
      [DEBUG] [historyJSON] new history json values created
      [DEBUG] [historyJSON] done
      [DEBUG] [notification] done
      Sieht bei mir nicht anders aus. Vielleicht nur etwas "unglücklich" formuliert im Protokoll.
      Ro75.
      Y 1 Reply Last reply Reply Quote 0
      • Y
        Yak55 @Ro75 last edited by
        @ro75 naja, das wäre mir die liebste Lösung😊
        Homoran Meister Mopper 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Yak55 last edited by
          @yak55 sagte in Backup-Erstellung - Hinweis auf js-controller 4.1:
          ich fang mal hinten an,
          was wäre dir lieb
          @ro75 sagte in Backup-Erstellung - Hinweis auf js-controller 4.1:
          ich kann leider das log von @Yak55 mobil nicht entziffern.
          Wo ist denn das Problem?
          nicht dass wir aneinander vorbei reden.
          ich war von einer Meldung brim Restore ausgegangen, allerdings war das hier
          Das Backup wurde gerade im Adapter neu gestartet, dabei habe ich das gesehen,
          schon nicht mehr eindeutig, obwohl einige User beim restore ebenfalls vom backup reden.
          • Meister Mopper
            Meister Mopper @Yak55 last edited by Meister Mopper
            Kann sein, aber wie soll dann ein restore erfolgen? Hast du versucht, ein backup zurückzuspielen?
            Ro75 1 Reply Last reply Reply Quote 0
            • Ro75
              Ro75 @Meister Mopper last edited by
              @meister-mopper es geht um die Meldung im Log bei der Erstellung vom Backup, mit dem Hinweis für ein Restore.
              Ro75.
                MiB Swap: 100.0 total, 0.2 free, 99.8 used. 179.1 avail Mem
                mit 1GB RAM kommst du nicht eeit.
                Der Swap ist auch schon aufgebraucht.
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                ist auch nicht mehr aktuell
                genau wie
                usr/bin/nodejs v18.19.1
                Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                da stimmt was nicht!!!
                Betriebssystem ruft nach Pflege
                Pending Updates: 73
                instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                da laufen Prozesse doppelt.
                startet der Pi öfters von selber neu?
                • Y
                  Yak55 @Homoran last edited by
                  @homoran Wie ich oben bereits geschrieben habe wird beim manuellen Backup über den Adapter der Hinweis ausgegeben, dass ein Restore nur mit js-controller 4.1 möglich ist, obwohl es mit 6.0.11 erzeugt wurde. Ist das nur ein falscher Text im Protokoll, oder muss ich damit rechnen, dass ich bei einem Fehler das Backup nicht mehr nutzen kann, ohne eine altes System aufsetzen zu müssen?
                    Thomas Braun Most Active @Yak55 last edited by
                    AB js-controller 4.1. Also auch höheren Versionen.
                    • Y
                      Yak55 @Thomas Braun last edited by
                      @thomas-braun ja, richtig lesen hilft manchmal "up from" 😕
                        jepp, und das ist doch nicht.
                        • Y
                          @homoran ok, vielen Dank, ich werde mal ein bisschen Systempflege betreiben - das Backup sollte ja notfalls funktionieren 😊
                            Homoran Global Moderator Administrators @Yak55 last edited by Homoran
                            @yak55 es gibt nämlich bei einem versuch des Restores rines Backups mit controller v4 auf einem System mit controller >v4.1 auch eine Warnmeldung.
                            In der wird dann sogar gesagt wie in so einrm Falle vorgegangen werden kann.
                            Leider wird das oft weggeklickt und das Übel nimmt seinen Lauf...
                            • Y
                              @homoran 👍
                              438
