Request actual repository
Das ist nicht die Langfassung.
@thomas-braun wie komme ich zur langfassung?
@dirk-4 Die erscheint vor der Zusammenfassung.
@thomas-braun Skript v.2024-05-22
*** BASE SYSTEM *** Static hostname: iobroker Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 20:26:06 up 20:51, 1 user, load average: 1.89, 1.04, 0.83 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Tue 2024-09-10 20:26:06 CEST Universal time: Tue 2024-09-10 18:26:06 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iobroker HOME=/home/iobroker GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 2.7G 348M 0.0K 776M 1.0G Swap: 99M 96M 3.0M Total: 3.9G 2.8G 351M Active iob-Instances: 23 3793 M total memory 2668 M used memory 1303 M active memory 1961 M inactive memory 347 M free memory 38 M buffer memory 738 M swap cache 99 M total swap 96 M used swap 3 M free swap *** top - Table Of Processes *** top - 20:26:06 up 20:51, 1 user, load average: 1.89, 1.04, 0.83 Tasks: 174 total, 1 running, 173 sleeping, 0 stopped, 0 zombie %Cpu(s): 11.9 us, 3.0 sy, 0.0 ni, 82.1 id, 1.5 wa, 0.0 hi, 1.5 si, 0.0 st MiB Mem : 3793.3 total, 347.8 free, 2668.1 used, 777.4 buff/cache MiB Swap: 100.0 total, 3.3 free, 96.7 used. 1049.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 54G 16G 36G 31% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 759M 1.2M 758M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 255M 31M 225M 13% /boot tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [sudo] password for iobroker: [Mon Sep 9 23:34:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@50 smsc95xx.macaddr=E4:5F:01:F7:33:48 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=bae113ef-02 rootfstype=ext4 fsck.repair=yes rootwait [Mon Sep 9 23:34:22 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem [Mon Sep 9 23:34:22 2024] EXT4-fs (sda2): write access will be enabled during recovery [Mon Sep 9 23:34:22 2024] EXT4-fs (sda2): orphan cleanup on readonly fs [Mon Sep 9 23:34:22 2024] EXT4-fs (sda2): 7 orphan inodes deleted [Mon Sep 9 23:34:22 2024] EXT4-fs (sda2): recovery complete [Mon Sep 9 23:34:22 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Mon Sep 9 23:34:22 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Mon Sep 9 23:34:24 2024] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime |-/dev devtmpfs devtmpfs rw,relatime,size=1677960k,nr_inodes=419490,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime | |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime | `-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000 `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 6.8G /var/ 6.1G /var/log 4.1G /var/log/journal/a6c9fe95480b46608f7e8939e2042a18 4.1G /var/log/journal 358M /var/lib Archived and active journals take up 4.0G in the file system. /opt/iobroker/backups: 984M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.2G /opt/iobroker/iobroker-data/ 950M /opt/iobroker/iobroker-data/files 441M /opt/iobroker/iobroker-data/files/javascript.admin 409M /opt/iobroker/iobroker-data/files/javascript.admin/static 408M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 25M /opt/iobroker/iobroker-data/objects.jsonl 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 24M /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map 24M /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.bf7d9efc.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v18.20.4 /usr/bin/node v18.20.4 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 nodejs: Installed: 18.20.4-1nodesource1 Candidate: 18.20.4-1nodesource1 Version table: *** 18.20.4-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.20.3-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 6.0.11 admin: 7.0.23 javascript: 8.7.6 nodejs modules from github: 1 +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83) Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.echarts.0 : echarts : iobroker - enabled + system.adapter.energiefluss.0 : energiefluss : iobroker - enabled system.adapter.flot.0 : flot : iobroker - enabled + system.adapter.fronius.0 : fronius : iobroker - enabled + system.adapter.hyperion_ng.0 : hyperion_ng : iobroker - enabled system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.info.0 : info : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.modbus.0 : modbus : iobroker - enabled system.adapter.node-red.0 : node-red : iobroker - disabled, port: 1884, bind: 0.0.0.0 + system.adapter.pvforecast.0 : pvforecast : iobroker - enabled + system.adapter.rpi2.0 : rpi2 : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 8085, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.tibberconnect.0 : tibberconnect : iobroker - disabled + system.adapter.tibberlink.0 : tibberlink : iobroker - enabled + system.adapter.time-switch.0 : time-switch : iobroker - enabled system.adapter.vis-bars.0 : vis-bars : iobroker - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - enabled system.adapter.vis-history.0 : vis-history : iobroker - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - enabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled system.adapter.vis-weather.0 : vis-weather : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - disabled + system.adapter.wled.0 : wled : iobroker - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 8085, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.0.23 , installed 7.0.23 Adapter "backitup" : 3.0.22 , installed 3.0.22 Adapter "discovery" : 4.5.0 , installed 4.5.0 Adapter "echarts" : 1.7.2 , installed 1.7.2 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "eventlist" : 2.0.1 , installed 2.0.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fronius" : 2.1.1 , installed 2.1.1 Adapter "heizoel24-mex": 1.3.5 , installed 1.3.5 Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 8.7.6 , installed 8.7.6 Controller "js-controller": 6.0.11 , installed 6.0.11 Adapter "modbus" : 6.2.3 , installed 6.2.3 Adapter "node-red" : 5.2.1 , installed 5.2.1 Adapter "pvforecast" : 3.0.0 , installed 3.0.0 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 7.0.0 , installed 7.0.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.1.0 , installed 3.1.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 3.9.0 , installed 3.9.0 Adapter "tibberlink" : 3.4.8 , installed 3.4.8 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2-widgets-energy": 1.0.0, installed 1.0.0 Adapter "vis-2-widgets-gauges": 1.1.0, installed 1.1.0 Adapter "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "wled" : 0.7.2 , installed 0.7.2 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 4297 States: 3563 *** OS-Repositories and Updates *** W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.releases.hyperion-project.org bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 21710A7427490076 W: Failed to fetch https://apt.hyperion-project.org/dists/bullseye/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 21710A7427490076 W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://security.debian.org/debian-security bullseye-security InRelease Hit:4 http://deb.debian.org/debian bullseye-updates InRelease Get:5 https://repos.influxdata.com/debian stretch InRelease [12.9 kB] Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Get:7 https://apt.releases.hyperion-project.org bullseye InRelease [4741 B] Err:5 https://repos.influxdata.com/debian stretch InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E Err:7 https://apt.releases.hyperion-project.org bullseye InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 21710A7427490076 Fetched 17.6 kB in 2s (8132 B/s) Reading package lists... W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.releases.hyperion-project.org bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 21710A7427490076 W: Failed to fetch https://apt.hyperion-project.org/dists/bullseye/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 21710A7427490076 W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:8085 0.0.0.0:* LISTEN 1000 17601 1407/io.shelly.0 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1000 17080 1462/io.shelly.1 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1000 16819 1210/io.sonoff.0 tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 110 12133 629/influxd tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1000 14733 704/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1000 12937 704/iobroker.js-con tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12062 541/sshd: /usr/sbin tcp6 0 0 :::8086 :::* LISTEN 110 14728 629/influxd tcp6 0 0 :::8082 :::* LISTEN 1000 16270 1628/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1000 13119 981/io.admin.0 tcp6 0 0 :::8092 :::* LISTEN 1000 14709 625/hyperiond tcp6 0 0 :::8090 :::* LISTEN 1000 12863 625/hyperiond tcp6 0 0 :::19400 :::* LISTEN 1000 12143 625/hyperiond tcp6 0 0 :::19444 :::* LISTEN 1000 15515 625/hyperiond tcp6 0 0 :::19445 :::* LISTEN 1000 12142 625/hyperiond tcp6 0 0 :::22 :::* LISTEN 0 12064 541/sshd: /usr/sbin udp 0 0 0.0.0.0:5353 0.0.0.0:* 1000 20404 2310/io.wled.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1000 12848 625/hyperiond udp 0 0 0.0.0.0:5353 0.0.0.0:* 1000 12845 625/hyperiond udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 1654 425/avahi-daemon: r udp 0 0 0.0.0.0:48851 0.0.0.0:* 108 1656 425/avahi-daemon: r udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 12153 625/hyperiond udp 0 0 0.0.0.0:68 0.0.0.0:* 0 14564 624/dhcpcd udp6 0 0 :::546 :::* 0 12280 624/dhcpcd udp6 0 0 :::51807 :::* 108 1657 425/avahi-daemon: r udp6 0 0 :::5353 :::* 1000 12849 625/hyperiond udp6 0 0 :::5353 :::* 1000 12846 625/hyperiond udp6 0 0 :::5353 :::* 108 1655 425/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-09-10 20:27:53.124 - info: shelly.0 (1407) [authEnabled] 192.168.178.65 (shelly1 / shelly1-349454737925 / SHSW-1#349454737925#1): This device is not protected via restricted login (see adapter documentation for details) 2024-09-10 20:27:53.463 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2616_Grid_L1_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:27:56.141 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2616_Grid_L1_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:27:56.183 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2618_Grid_L2_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:27:56.185 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2620_Grid_L3_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:27:57.461 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2618_Grid_L2_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:27:58.583 - info: shelly.0 (1407) [authEnabled] 192.168.178.63 (shelly1 / shelly1-3494547331F8 / SHSW-1#3494547331F8#1): This device is not protected via restricted login (see adapter documentation for details) 2024-09-10 20:27:58.786 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2616_Grid_L1_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:28:00.033 - info: javascript.0 (1010) script.js.Eigene_Skripte.Aktive_Skripte.Strom_Schalter_4_Spülmaschiene_: getState(id=sonoff.0.nous4.ENERGY_Power, timerId=undefined) => {"val":0,"ack":true,"ts":1725992876215,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1725975055286} 2024-09-10 20:28:00.034 - info: javascript.0 (1010) script.js.Eigene_Skripte.Aktive_Skripte.Strom_Schalter_4_Spülmaschiene_: setForeignState(id=sonoff.0.nous4.POWER, state={"val":false,"ack":false,"ts":1725992880034,"q":0,"from":"system.adapter.javascript.0","lc":1725984000037,"c":"script.js.Eigene_Skripte.Aktive_Skripte.Strom_Schalter_4_Spülmaschiene_"}) 2024-09-10 20:28:00.128 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2620_Grid_L3_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:28:00.233 - info: javascript.0 (1010) script.js.Eigene_Skripte.Aktive_Skripte.Heizung.Temperatur_Boiler_: 53.2 2024-09-10 20:28:00.520 - info: javascript.0 (1010) script.js.Eigene_Skripte.Aktive_Skripte.Heizung.Temperatur_Boiler_: 26.8 2024-09-10 20:28:00.522 - info: javascript.0 (1010) script.js.Eigene_Skripte.Aktive_Skripte.Heizung.Temperatur_Boiler_: 26.4 2024-09-10 20:28:01.347 - info: shelly.1 (1462) [authEnabled] 192.168.178.64 (shelly1minig3 / shelly1minig3-543204615e90 / shelly1minig3#543204615e90#1): This device is not protected via restricted login (see adapter documentation for details) 2024-09-10 20:28:02.800 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2618_Grid_L2_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:28:03.423 - info: shelly.0 (1407) [authEnabled] 192.168.178.65 (shelly1 / shelly1-349454737925 / SHSW-1#349454737925#1): This device is not protected via restricted login (see adapter documentation for details) 2024-09-10 20:28:05.476 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2618_Grid_L2_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:28:08.144 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2618_Grid_L2_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:28:08.787 - info: shelly.0 (1407) [authEnabled] 192.168.178.63 (shelly1 / shelly1-3494547331F8 / SHSW-1#3494547331F8#1): This device is not protected via restricted login (see adapter documentation for details) 2024-09-10 20:28:09.739 - error: rpi2.0 (1235) GPIO is not initialized! 2024-09-10 20:28:11.602 - info: shelly.1 (1462) [authEnabled] 192.168.178.64 (shelly1minig3 / shelly1minig3-543204615e90 / shelly1minig3#543204615e90#1): This device is not protected via restricted login (see adapter documentation for details) 2024-09-10 20:28:12.184 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2616_Grid_L1_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:28:12.227 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2618_Grid_L2_–_Voltage" has no existing object, this might lead to an error in future versions 2024-09-10 20:28:12.229 - warn: modbus.0 (1184) State "modbus.0.inputRegisters.30.2620_Grid_L3_–_Voltage" has no existing object, this might lead to an error in future versions============ Mark until here for C&P =============
iob diag has finished.
Press any key for a summary
@dirk-4 sagte in Request actual repository:
Dein Dateisystem hat 'nen Schuss.
Installier da NEU Raspberry OS 12 'Bookworm' und dann legst du dir auch einen gescheiten user an. NICHT 'iobroker', der ist für den Systemuser vorgesehen.
'dirk' wäre doch eine gute Alternative... -
@thomas-braun Das muss ich dann wohl mal machen leider. Wenn ich hier von dem System ein Backup mache kann ich das dann wieder verwenden oder muss ich dann wieder alles neu einrichten?
Kann man das Dateisystem nicht Reparieren? -
Hast du kein Backup von Sonntag?
Bringt dir ja nix die defekten Dateien zu sichern. Die sind ja kaputt. -
@thomas-braun Das Problem habe ich ja schon länger.
Ein Backup mit dem Backitup-Adapter musst Du eigentlich nur auf dem neuen System wiederherstellen.
Das dauert 'ne Weile, aber dann ist in der Regel alles wieder am Start.
Sollte dann natürlich ein Backup eines funktionsfähigen Zustands sein. -
@codierknecht Erstmal Danke für eure Hilfe.
Das musst du alleine auch deswegen schon machen, weil es keinen funktionierenden Upgradepfad von Bullseye auf Bookworm gibt.
