    4. Modul LCN belastet CPU mit 103% nach update
    • I
      IOJoe22 last edited by
      @djmarc75
      du meinst so?
      iob diag iobroker 20240814.txt
      ok.
        Homoran Global Moderator Administrators @IOJoe22 last edited by
        @iojoe22 sagte in Modul LCN belastet CPU mit 103% nach update:
        du meinst so?
        nein!
        @djmarc75 sagte in Modul LCN belastet CPU mit 103% nach update:
        in Codetags
        • I
          IOJoe22 @Homoran last edited by IOJoe22
          @Homoran
          gerade neu erstellt:
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: surfer100
                 Icon name: computer-desktop
                   Chassis: desktop
          Operating System: Ubuntu 22.04.4 LTS
                    Kernel: Linux 5.15.0-118-generic
              Architecture: x86-64
           Hardware Vendor: FUJITSU
            Hardware Model: D3400-B1
          model name	: Intel(R) Celeron(R) CPU G3900 @ 2.80GHz
          Docker          : false
          Virtualization  : none
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           17:44:13 up 23:08,  2 users,  load average: 1.79, 1.93, 1.97
          CPU threads: 2
          *** Time and Time Zones ***
                         Local time: Wed 2024-08-14 17:44:13 CEST
                     Universal time: Wed 2024-08-14 15:44:13 UTC
                           RTC time: Wed 2024-08-14 15:44:13
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          joe
          HOME=/home/joe
          GROUPS=joe adm cdrom sudo audio dip www-data video plugdev ssl-cert netdev lpadmin scanner lxd sambashare ftp iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio www-data video bluetooth mysql redis
          *** Display-Server-Setup ***
          Display-Server: true
          Desktop:
          Terminal: 	tty
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:            3.8G        2.2G        162M         43M        1.4G        1.3G
          Swap:           4.0G        358M        3.7G
          Total:          7.8G        2.5G        3.9G
          Active iob-Instances: 	26
                   3766 M total memory
                   2158 M used memory
                   1507 M active memory
                   1662 M inactive memory
                    162 M free memory
                    293 M buffer memory
                   1152 M swap cache
                   4049 M total swap
                    358 M used swap
                   3691 M free swap
          top - 17:44:13 up 23:08,  2 users,  load average: 1.79, 1.93, 1.97
          Tasks: 214 total,   3 running, 211 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 70.0 us, 13.3 sy,  0.0 ni, 16.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3766.6 total,    162.1 free,   2158.1 used,   1446.5 buff/cache
          MiB Swap:   4050.0 total,   3692.0 free,    358.0 used.   1298.1 avail Mem
          *** FAILED SERVICES ***
            UNIT          LOAD   ACTIVE SUB    DESCRIPTION
          * mysql.service loaded failed failed MySQL Community Server
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          Filesystem     Type   Size  Used Avail Use% Mounted on
          tmpfs          tmpfs  377M  1.8M  375M   1% /run
          /dev/sda3      ext4   117G   42G   69G  38% /
          tmpfs          tmpfs  1.9G  1.2M  1.9G   1% /dev/shm
          tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
          /dev/sda2      vfat   512M  6.1M  506M   2% /boot/efi
          /dev/sdb1      ext4   1.8T  870G  871G  50% /srv
          /dev/sdc1      ext4   458G   51G  384G  12% /cloud
          tmpfs          tmpfs  377M   84K  377M   1% /run/user/115
          tmpfs          tmpfs  377M   80K  377M   1% /run/user/1000
          [Tue Aug 13 18:36:01 2024] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Tue Aug 13 18:36:01 2024] EXT4-fs (sda3): re-mounted. Opts: errors=remount-ro. Quota mode: none.
          [Tue Aug 13 18:36:03 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Tue Aug 13 18:36:03 2024] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          Show mounted filesystems:
          TARGET                                        SOURCE                         FSTYPE          OPTIONS
          /                                             /dev/sda3                      ext4            rw,relatime,errors=remount-ro
          |-/sys                                        sysfs                          sysfs           rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security                      securityfs                     securityfs      rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup                            cgroup2                        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore                            pstore                         pstore          rw,nosuid,nodev,noexec,relatime
          | |-/sys/firmware/efi/efivars                 efivarfs                       efivarfs        rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf                               bpf                            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/debug                         debugfs                        debugfs         rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/tracing                       tracefs                        tracefs         rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/fuse/connections                  fusectl                        fusectl         rw,nosuid,nodev,noexec,relatime
          | `-/sys/kernel/config                        configfs                       configfs        rw,nosuid,nodev,noexec,relatime
          |-/proc                                       proc                           proc            rw,nosuid,nodev,noexec,relatime
          | |-/proc/sys/fs/binfmt_misc                  systemd-1                      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16730
          | | `-/proc/sys/fs/binfmt_misc                binfmt_misc                    binfmt_misc     rw,nosuid,nodev,noexec,relatime
          | `-/proc/fs/nfsd                             nfsd                           nfsd            rw,relatime
          |-/dev                                        udev                           devtmpfs        rw,nosuid,relatime,size=1891624k,nr_inodes=472906,mode=755,inode64
          | |-/dev/pts                                  devpts                         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | |-/dev/shm                                  tmpfs                          tmpfs           rw,nosuid,nodev,inode64
          | |-/dev/hugepages                            hugetlbfs                      hugetlbfs       rw,relatime,pagesize=2M
          | `-/dev/mqueue                               mqueue                         mqueue          rw,nosuid,nodev,noexec,relatime
          |-/run                                        tmpfs                          tmpfs           rw,nosuid,nodev,noexec,relatime,size=385708k,mode=755,inode64
          | |-/run/lock                                 tmpfs                          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
          | |-/run/credentials/systemd-sysusers.service none                           ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/rpc_pipefs                           sunrpc                         rpc_pipefs      rw,relatime
          | |-/run/user/1000                            tmpfs                          tmpfs           rw,nosuid,nodev,relatime,size=385704k,nr_inodes=96426,mode=700,uid=1000,gid=1000,inode64
          | |-/run/snapd/ns                             tmpfs[/snapd/ns]               tmpfs           rw,nosuid,nodev,noexec,relatime,size=385708k,mode=755,inode64
          | | |-/run/snapd/ns/cups.mnt                  nsfs[mnt:[4026532576]]         nsfs            rw
          | | `-/run/snapd/ns/firefox.mnt               nsfs[mnt:[4026532482]]         nsfs            rw
          | `-/run/user/115                             tmpfs                          tmpfs           rw,nosuid,nodev,relatime,size=385704k,nr_inodes=96426,mode=700,uid=115,gid=123,inode64
          |   `-/run/user/115/gvfs                      gvfsd-fuse                     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=115,group_id=123
          |-/snap/bare/5                                /dev/loop1                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/chromium/2923                         /dev/loop3                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/core20/2264                           /dev/loop5                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/core20/2318                           /dev/loop6                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/core22/1439                           /dev/loop4                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/cups/1052                             /dev/loop7                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/chromium/2921                         /dev/loop2                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/core22/1380                           /dev/loop0                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/cups/1058                             /dev/loop9                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/core24/423                            /dev/loop8                     squashfs        ro,nodev,relatime,errors=continue
          |-/snap/curl/1679                             /dev/loop10                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/mesa-2404/143                         /dev/loop12                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/gnome-42-2204/172                     /dev/loop13                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/gnome-3-38-2004/143                   /dev/loop15                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/gnome-42-2204/176                     /dev/loop14                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/firefox/4698                          /dev/loop11                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/curl/1754                             /dev/loop16                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/gnome-46-2404/39                      /dev/loop18                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/gtk-common-themes/1535                /dev/loop19                    squashfs        ro,nodev,relatime,errors=continue
          |-/var/snap/firefox/common/host-hunspell      /dev/sda3[/usr/share/hunspell] ext4            ro,noexec,noatime,errors=remount-ro
          |-/snap/hunspell-dictionaries-1-7-2004/2      /dev/loop22                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/mesa-2404/44                          /dev/loop20                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/gnome-3-38-2004/140                   /dev/loop17                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/snapd/21759                           /dev/loop21                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/gnome-46-2404/42                      /dev/loop23                    squashfs        ro,nodev,relatime,errors=continue
          |-/snap/snapd/21465                           /dev/loop24                    squashfs        ro,nodev,relatime,errors=continue
          |-/boot/efi                                   /dev/sda2                      vfat            rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
          |-/srv                                        /dev/sdb1                      ext4            rw,relatime
          |-/cloud                                      /dev/sdc1                      ext4            rw,relatime
          `-/snap/firefox/4757                          /dev/loop25                    squashfs        ro,nodev,relatime,errors=continue
          /var:
          11G	/var/
          8.1G	/var/lib
          6.4G	/var/lib/snapd
          4.5G	/var/lib/snapd/snaps
          1.7G	/var/log/journal/50162298c18e44438bae95855b92db80
          Archived and active journals take up 1.6G in the file system.
          /opt/iobroker/backups:
          2.7G	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.6G	/opt/iobroker/iobroker-data/
          1020M	/opt/iobroker/iobroker-data/files
          441M	/opt/iobroker/iobroker-data/files/javascript.admin
          412M	/opt/iobroker/iobroker-data/history
          409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          27M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
          26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.bad2715c.js.map
          26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.bad2715c.js.map
          24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.20.4
          /usr/bin/node 		v18.20.4
          /usr/bin/npm 		10.7.0
          /usr/bin/npx 		10.7.0
          /usr/bin/corepack 	0.28.0
          nodejs:
            Installed: 18.20.4-1nodesource1
            Candidate: 18.20.4-1nodesource1
            Version table:
           *** 18.20.4-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.3-1nodesource1 1001
               18.20.2-1nodesource1 1001
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.9~dfsg-1ubuntu3.6 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                  500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
               12.22.9~dfsg-1ubuntu3 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	6.0.9
          admin: 		7.0.22
          javascript: 	8.7.6
          nodejs modules from github: 	2
          +-- iobroker.hyperion_ng@0.1.23 (git+ssh://git@github.com/felixganzer/ioBroker.hyperion_ng.git#b27f55704d34a7eed2865ca421409d091d86cd38)
          +-- iobroker.hyperion@0.0.15 (git+ssh://git@github.com/ruhigundrelaxed/ioBroker.hyperion.git#faa3749a64c63522cf62920a3c1a1949d94782d1)
          Adapter State
          + system.adapter.admin.0                  : admin                 : surfer100                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : surfer100                                -  enabled
          + system.adapter.bluelink.0               : bluelink              : surfer100                                -  enabled
            system.adapter.discovery.0              : discovery             : surfer100                                - disabled
            system.adapter.dwd.0                    : dwd                   : surfer100                                -  enabled
          + system.adapter.echarts.0                : echarts               : surfer100                                -  enabled
          + system.adapter.enigma2.0                : enigma2               : surfer100                                -  enabled
            system.adapter.flot.0                   : flot                  : surfer100                                -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : surfer100                                -  enabled
          + system.adapter.history.0                : history               : surfer100                                -  enabled
          + system.adapter.hue.0                    : hue                   : surfer100                                -  enabled, port: 443
          + system.adapter.hyperion_ng.0            : hyperion_ng           : surfer100                                -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : surfer100                                -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : surfer100                                -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: surfer100                                -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : surfer100                                -  enabled
          + system.adapter.javascript.0             : javascript            : surfer100                                -  enabled
          + system.adapter.lcn.0                    : lcn                   : surfer100                                -  enabled, port: 4114
          + system.adapter.linux-control.0          : linux-control         : surfer100                                -  enabled
          + system.adapter.luxtronik1.0             : luxtronik1            : surfer100                                -  enabled, port: 8899
            system.adapter.material.0               : material              : surfer100                                -  enabled
          + system.adapter.modbus.0                 : modbus                : surfer100                                -  enabled
          + system.adapter.modbus.1                 : modbus                : surfer100                                -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : surfer100                                -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : surfer100                                -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.net-tools.0              : net-tools             : surfer100                                - disabled
            system.adapter.onvif.0                  : onvif                 : surfer100                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
            system.adapter.openweathermap.0         : openweathermap        : surfer100                                -  enabled
          + system.adapter.panasonic-viera.0        : panasonic-viera       : surfer100                                -  enabled
            system.adapter.ping.0                   : ping                  : surfer100                                - disabled
            system.adapter.pushover.0               : pushover              : surfer100                                - disabled
          + system.adapter.scenes.0                 : scenes                : surfer100                                -  enabled
          + system.adapter.sonoff.0                 : sonoff                : surfer100                                -  enabled, port: 1885, bind: 0.0.0.0
            system.adapter.sql.0                    : sql                   : surfer100                                - disabled, port: 3306
          + system.adapter.tr-064.1                 : tr-064                : surfer100                                -  enabled
            system.adapter.vis-history.0            : vis-history           : surfer100                                -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : surfer100                                -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : surfer100                                -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : surfer100                                -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : surfer100                                -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : surfer100                                -  enabled
            system.adapter.vis-metro.0              : vis-metro             : surfer100                                -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : surfer100                                -  enabled
            system.adapter.vis.0                    : vis                   : surfer100                                -  enabled
          + system.adapter.web.0                    : web                   : surfer100                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : surfer100                                -  enabled
          + instance is alive
          ioBroker-Repositories
          │ (index) │   name   │                           url                           │ auto upgrade │
          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.0.22   , installed 7.0.22
          Adapter    "backitup"     : 3.0.16   , installed 3.0.16
          Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "echarts"      : 1.7.2    , installed 1.9.0
          Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
          Adapter    "hue"          : 3.11.0   , installed 3.11.0
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.9    , installed 6.0.9
          Adapter    "lcn"          : 2.0.1    , installed 2.0.1
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "luxtronik1"   : 0.4.1    , installed 0.4.1
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "modbus"       : 6.2.3    , installed 6.0.1  [Updatable]
          Adapter    "mqtt"         : 5.2.0    , installed 6.0.1
          Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
          Adapter    "openweathermap": 1.0.4   , installed 1.0.4
          Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "scenes"       : 3.2.1    , installed 3.2.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.0    , installed 3.1.1
          Adapter    "sql"          : 3.0.1    , installed 3.0.1
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects: 	11677
          States: 	7965
          Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
          Hit:6 https://ppa.launchpadcontent.net/ondrej/apache2/ubuntu jammy InRelease
          Hit:7 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
          Hit:8 https://ppa.launchpadcontent.net/remmina-ppa-team/remmina-next/ubuntu jammy InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:59959           0.0.0.0:*               LISTEN      0          26426      1402/rpc.mountd
          tcp        0      0 0.0.0.0:56055           0.0.0.0:*               LISTEN      0          26466      1402/rpc.mountd
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        23821      795/systemd-resolve
          tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          26985      -
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25624      1002/sshd: /usr/sbi
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15909      1/init
          tcp        0      0 0.0.0.0:2121            0.0.0.0:*               LISTEN      0          26973      1383/python3
          tcp        0      0 0.0.0.0:53509           0.0.0.0:*               LISTEN      127        26403      1391/rpc.statd
          tcp        0      0 0.0.0.0:37331           0.0.0.0:*               LISTEN      0          27001      -
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1007       26584      1125/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1007       26588      1125/iobroker.js-co
          tcp        0      0 0.0.0.0:50927           0.0.0.0:*               LISTEN      0          26452      1402/rpc.mountd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1007       28580      1868/io.mqtt.1
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1007       29120      1883/io.sonoff.0
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          143865     46269/cupsd
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      130        25161      965/redis-server 12
          tcp6       0      0 :::55307                :::*                    LISTEN      0          26460      1402/rpc.mountd
          tcp6       0      0 :::2049                 :::*                    LISTEN      0          26995      -
          tcp6       0      0 :::22                   :::*                    LISTEN      0          25626      1002/sshd: /usr/sbi
          tcp6       0      0 :::21                   :::*                    LISTEN      0          24739      977/vsftpd
          tcp6       0      0 :::111                  :::*                    LISTEN      0          15911      1/init
          tcp6       0      0 :::80                   :::*                    LISTEN      0          24962      1093/apache2
          tcp6       0      0 :::53547                :::*                    LISTEN      0          26440      1402/rpc.mountd
          tcp6       0      0 :::47613                :::*                    LISTEN      127        26414      1391/rpc.statd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          143864     46269/cupsd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1007       29207      1914/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1007       27256      1470/io.admin.0
          tcp6       0      0 :::58393                :::*                    LISTEN      0          26472      1402/rpc.mountd
          tcp6       0      0 ::1:6379                :::*                    LISTEN      130        25162      965/redis-server 12
          tcp6       0      0 :::44481                :::*                    LISTEN      0          27004      -
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          143903     46274/cups-browsed
          udp        0      0 127.0.0.1:719           0.0.0.0:*                           0          26384      1391/rpc.statd
          udp        0      0 0.0.0.0:45897           0.0.0.0:*                           0          27000      -
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           113        24652      873/avahi-daemon: r
          udp        0      0 0.0.0.0:46529           0.0.0.0:*                           0          26449      1402/rpc.mountd
          udp        0      0 0.0.0.0:46803           0.0.0.0:*                           0          26417      1402/rpc.mountd
          udp        0      0 0.0.0.0:36870           0.0.0.0:*                           127        26400      1391/rpc.statd
          udp        0      0 0.0.0.0:57388           0.0.0.0:*                           113        24654      873/avahi-daemon: r
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        23820      795/systemd-resolve
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15910      1/init
          udp        0      0 0.0.0.0:41370           0.0.0.0:*                           0          26463      1402/rpc.mountd
          udp6       0      0 :::51948                :::*                                127        26406      1391/rpc.statd
          udp6       0      0 :::5353                 :::*                                113        24653      873/avahi-daemon: r
          udp6       0      0 :::34739                :::*                                113        24655      873/avahi-daemon: r
          udp6       0      0 :::47179                :::*                                0          26469      1402/rpc.mountd
          udp6       0      0 :::111                  :::*                                0          15912      1/init
          udp6       0      0 :::41178                :::*                                0          27003      -
          udp6       0      0 :::37133                :::*                                0          26457      1402/rpc.mountd
          udp6       0      0 :::43289                :::*                                0          26945      1402/rpc.mountd
          udp6       0      0 fe80::47b9:d3ed:423:546 :::*                                0          27660      878/NetworkManager
          2024-08-14 10:00:18.013  - info: host.surfer100 instance system.adapter.dwd.0 in version "2.8.5" started with pid 57989
          2024-08-14 10:00:20.347  - info: host.surfer100 instance system.adapter.dwd.0 having pid 57989 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-08-14 10:15:18.022  - info: host.surfer100 instance system.adapter.dwd.0 in version "2.8.5" started with pid 58184
          2024-08-14 10:15:20.461  - info: host.surfer100 instance system.adapter.dwd.0 having pid 58184 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-08-14 10:15:59.891  - error: lcn.0 (1992) Cannot send 0:20(RELAY_OUT, out=4, val="true"): timeout
          2024-08-14 10:30:18.013  - info: host.surfer100 instance system.adapter.dwd.0 in version "2.8.5" started with pid 58238
          2024-08-14 10:30:20.426  - info: host.surfer100 instance system.adapter.dwd.0 having pid 58238 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-08-14 10:39:03.579  - info: bluelink.0 (2409) Read new update for TMAK381GFPJ078595 directly from the car
          2024-08-14 10:39:32.605  - info: bluelink.0 (2409) Update for TMAK381GFPJ078595 successfull
          2024-08-14 10:45:18.012  - info: host.surfer100 instance system.adapter.dwd.0 in version "2.8.5" started with pid 58439
          2024-08-14 10:45:20.343  - info: host.surfer100 instance system.adapter.dwd.0 having pid 58439 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-08-14 11:00:18.013  - info: host.surfer100 instance system.adapter.dwd.0 in version "2.8.5" started with pid 58487
          2024-08-14 11:00:20.290  - info: host.surfer100 instance system.adapter.dwd.0 having pid 58487 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-08-14 11:15:18.012  - info: host.surfer100 instance system.adapter.dwd.0 in version "2.8.5" started with pid 58683
          2024-08-14 11:15:20.380  - info: host.surfer100 instance system.adapter.dwd.0 having pid 58683 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-08-14 11:30:18.012  - info: host.surfer100 instance system.adapter.dwd.0 in version "2.8.5" started with pid 58738
          2024-08-14 11:30:20.468  - info: host.surfer100 instance system.adapter.dwd.0 having pid 58738 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-08-14 11:31:28.734  - info: admin.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.1.113
          2024-08-14 11:33:29.526  - info: admin.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.1.113
          2024-08-14 11:35:13.734  - info: javascript.0 (1513) Stopping script script.js.common.Diff_Temp
          2024-08-14 11:35:13.845  - info: javascript.0 (1513) Start JavaScript script.js.common.Diff_Temp (Blockly)
          2024-08-14 11:35:13.859  - info: javascript.0 (1513) script.js.common.Diff_Temp: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          2024-08-14 11:37:26.243  - info: admin.0 (1470) <== Disconnect system.user.admin from ::ffff:192.168.1.113 javascript
          2024-08-14 11:37:26.474  - info: admin.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.1.113
          2024-08-14 17:35:30.717  - info: admin.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.1.113
          • I
            @iojoe22
            Frage dazu: Gibt es eine Anleitung zur Fehlersuche, wenn ein Adapter Probleme macht? Z.B. Einstellungen des Adapters finden, prüfen ggf. ändern?
            Die Log-Stufe für den LCN-Adapter steht auf debug, es werden aktuell die üblichen Daten empfangen und gesendet, so wie es sein soll. Keine Fehlermeldungen.
            Oder kommt der Celeron jetzt einfach an seine Grenzen? zu den einfachen Aufgaben im ioBroker noch 25 Module ständig abfragen, berechnen, steuern, ein Skript versorgen u.s.w.
              Thomas Braun Most Active @IOJoe22 last edited by Thomas Braun
              @iojoe22
              CPU threads: 2
              Die Kiste ist einfach komplett dicht.
              Warum läuft da z. B. auch ein Desktop mit zwei Browsern, komplettem gnome, chromium, firefox, cups, hunspell usw. mit?
              Schalt den Kram halt schonmal aus. Wozu brauchst du da eine Rechtschreibprüfung????
              Warum steigt der mysql-Server aus?
              NodeJS auf Version 20 bringen.
              • I
                IOJoe22 @Thomas Braun last edited by IOJoe22
                Habe den Server an meinen Arbeitsplatz geholt und bin manchmal direkt drauf 🙂
                Die Browser waren sicher nur sporadisch aktiv.
                Display bauche ich dann auch manchmal.
                Rechtschreibprüfung kann natürlich rausfliegen.
                MySQL lief schon vor dem ioB da nextcloud installiert, das hat jedoch seit einem Update nicht mehr funktioniert und ich bin nicht der Datenbankexperte um das wieder hin zu bekommen 😞 Dann kam iob und hat auch eine Datenbank erstellt. Da möchte ich nicht dran rumfummeln und gute Tipps hatte ich nicht mit google gefunden....
                NodeJS 20 ist nun installiert 👍
                Habe noch einen Hinweis in der Host - einige Betriebssytemdateien könnten upgedated werden, bricht jedoch mit einem Fehler ab, dass aufgrund eines Depots ... nodesource .... node 20, weil die i386-Architektur nicht unterstützt wird. Habe die Datei jedoch nicht im System gefunden zum Ändern.
                Vielleicht ist eine Neuinstallation der einfachere Weg, mal sehen...
                P.S. Wollte heute morgen antworten, da kam immer ein Fehler beim Erstellen. Deshalb hab ich jetzt die Links u.s.w. weggelassen, nun klappt es.
                Thomas Braun BananaJoe 2 Replies Last reply Reply Quote 0
                  Ist halt falsch, weil man Server immer OHNE Desktop nur per SSH 'an seinen Arbeitsplatz holt'.
                  • BananaJoe
                    BananaJoe Most Active @IOJoe22 last edited by
                    Ein Display anzuschließen schließt ja nicht aus den Desktop / GUI abzuschalten. Dann hast du halt nur den Text-Prompt wie bei einer SSH Sitzung. Spart ja auch einiges an RAM und CPU, dein System sieht jetzt nicht überdimensioniert aus.
                    Notfalls könnte man den Desktop dann per Befehl starten
                    • I
                      @thomas-braun sagte in Modul LCN belastet CPU mit 103% nach update:
                      Jaaa, aaaber manches ist bequemer mit Grafik, wenn man nicht den ganzen Tag die Befehle in der Konsole eintippt. Früher konnte ich das noch besser.
                      Was mich jetzt stört, ist die Meldung:
                      Das Laden der konfigurierten Datei »main/binary-i386/Packages« wird übersprungen, da das Depot »https://deb.nodesource.com/node_20.x nodistro InRelease« die Architektur »i386« nicht unterstützt.
                      Dadurch wird das Update/Upgrade verhindert und ich habe keine Datei Namens main/binary-i386/Packages 😞
                      Und mysql möchte ich auch gern wieder ans Laufen bringen, finde mit google jedoch keine Hinweise, wie man strukturiert an das Problem herangehen kann,
                      Wenn der Server wieder korrekt läuft, kommt er in seine Ecke und wird über SSH administriert.
                      Wenn ihr ein zwei Links für mich habt bin ich dankbar.
                        Das ist Quatsch. Das halbe Dutzend an bennötigten Kommandos kann/sollte man parat haben.
                        Nein, es wird nur übersprungen.
                        Davon abgesehen, trag dir die Architektur in der Quelle ein. Ungefähr so:
                        deb [arch=amd64 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                        • I
                          Hab die Zeile zur sources.list zugefügt:
                          deb http://de.archive.ubuntu.com/ubuntu/ jammy main restricted universe multiverse
                          deb http://de.archive.ubuntu.com/ubuntu/ jammy-updates main restricted universe multiverse
                          deb http://security.ubuntu.com/ubuntu jammy-security main restricted universe multiverse
                          deb http://de.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
                          bringt jedoch keine Besserung (glaub ich), die Fehlermeldung ist noch da:
                          joe@surfer100:/etc/apt$ sudo apt-get update
                          OK:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
                          OK:2 https://deb.nodesource.com/node_20.x nodistro InRelease
                          OK:3 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                          OK:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                          OK:5 https://ppa.launchpadcontent.net/ondrej/apache2/ubuntu jammy InRelease
                          OK:6 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                          OK:7 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
                          OK:8 https://ppa.launchpadcontent.net/remmina-ppa-team/remmina-next/ubuntu jammy InRelease
                          Paketlisten werden gelesen… Fertig
                          W: Ziel Packages (main/binary-amd64/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel Packages (main/binary-all/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel Translations (main/i18n/Translation-de_DE) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel Translations (main/i18n/Translation-de) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel Translations (main/i18n/Translation-en) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel DEP-11 (main/dep11/Components-amd64.yml) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel DEP-11 (main/dep11/Components-all.yml) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel DEP-11-icons-small (main/dep11/icons-48x48.tar) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel DEP-11-icons (main/dep11/icons-64x64.tar) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel CNF (main/cnf/Commands-amd64) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          W: Ziel CNF (main/cnf/Commands-all) ist mehrfach konfiguriert in /etc/apt/sources.list:7 und /etc/apt/sources.list.d/nodesource.list:1
                          N: Das Laden der konfigurierten Datei »main/binary-i386/Packages« wird übersprungen, da das Depot »https://deb.nodesource.com/node_20.x nodistro InRelease« die Architektur »i386« nicht unterstützt.
                          Du meinst doch die Sources.list, oder?
                            Nein, das gehört in die /etc/apt/sources.list.d/nodesource.list
                            Deswegen hast du jetzt auch die Meldungen zu den Doubletten.
                            Lösch die Zeile aus der sources.list raus.
                            • I
                              Ah, danke für den Hinweis. Jetzt läufts ohne Fehlermeldung. Hatte die Zeile schon vor 1-2 Wochen eingetragen (auch ein Tip hier in einem Thread) aber nicht mit arch=amd64 🙂
                              Jedoch wird immer noch nichts upgedatet:
                              joe@surfer100:/etc/apt/sources.list.d$ sudo apt-get upgrade
                              Abhängigkeitsbaum wird aufgebaut… Fertig
                              Statusinformationen werden eingelesen… Fertig
                              Paketaktualisierung (Upgrade) wird berechnet… Fertig
                              Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                galera-4 libconfig-inifiles-perl libdaxctl1 libdbd-mysql-perl libdbi-perl libflashrom1 libftdi1-2
                                libgraphicsmagick-q16-3 libllvm13 libmariadb3 libndctl6 libpmem1 libterm-readkey-perl mariadb-common php8.1-mysql
                                php8.2-bcmath php8.2-intl php8.2-mysql php8.2-redis socat
                              Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                              Die folgenden Pakete sind zurückgehalten worden:
                                base-files python3-distupgrade python3-update-manager shim-signed ubuntu-release-upgrader-core
                                ubuntu-release-upgrader-gtk update-manager update-manager-core
                              0 aktualisiert, 0 neu installiert, 0 zu entfernen und 8 nicht aktualisiert.
                              Nur 8 nicht aktualisiert...
                              Und iob meldet immer noch: Betriebssystem-Paket-Updates verfügbar.
                              apt-utils/jammy-updates 2.4.13 amd64 [aktualisierbar von: 2.4.12]
                              apt/jammy-updates 2.4.13 amd64 [aktualisierbar von: 2.4.12]
                              base-files/jammy-updates 12ubuntu4.7 amd64 [aktualisierbar von: 12ubuntu4.6]
                              e2fsprogs/jammy-updates 1.46.5-2ubuntu1.2 amd64 [aktualisierbar von: 1.46.5-2ubuntu1.1]
                              gir1.2-javascriptcoregtk-4.0/jammy-updates,jammy-security 2.44.3-0ubuntu0.22.04.1 amd64 [aktualisierbar von: 2.44.2-0ubuntu0.22.04.1]
                              gir1.2-webkit2-4.0/jammy-updates,jammy-security 2.44.3-0ubuntu0.22.04.1 amd64 [aktualisierbar von: 2.44.2-0ubuntu0.22.04.1]
                              language-pack-de-base/jammy-updates,jammy-updates 1:22.04+20240902 all [aktualisierbar von: 1:22.04+20240212]
                              language-pack-de/jammy-updates,jammy-updates 1:22.04+20240902 all [aktualisierbar von: 1:22.04+20240212]
                              language-pack-en-base/jammy-updates,jammy-updates 1:22.04+20240902 all [aktualisierbar von: 1:22.04+20240212]
                              language-pack-en/jammy-updates,jammy-updates 1:22.04+20240902 all [aktualisierbar von: 1:22.04+20240212]
                              language-pack-gnome-de-base/jammy-updates,jammy-updates 1:22.04+20240902 all [aktualisierbar von: 1:22.04+20240212]
                              language-pack-gnome-de/jammy-updates,jammy-updates 1:22.04+20240902 all [aktualisierbar von: 1:22.04+20240212]
                              language-pack-gnome-en-base/jammy-updates,jammy-updates 1:22.04+20240902 all [aktualisierbar von: 1:22.04+20240212]
                              language-pack-gnome-en/jammy-updates,jammy-updates 1:22.04+20240902 all [aktualisierbar von: 1:22.04+20240212]
                              libapache2-mod-php8.2/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              libapache2-mod-php8.3/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              libapt-pkg6.0/jammy-updates 2.4.13 amd64 [aktualisierbar von: 2.4.12]
                              libcom-err2/jammy-updates 1.46.5-2ubuntu1.2 amd64 [aktualisierbar von: 1.46.5-2ubuntu1.1]
                              libext2fs2/jammy-updates 1.46.5-2ubuntu1.2 amd64 [aktualisierbar von: 1.46.5-2ubuntu1.1]
                              libjavascriptcoregtk-4.0-18/jammy-updates,jammy-security 2.44.3-0ubuntu0.22.04.1 amd64 [aktualisierbar von: 2.44.2-0ubuntu0.22.04.1]
                              libpython3-stdlib/jammy-updates 3.10.6-1~22.04.1 amd64 [aktualisierbar von: 3.10.6-1~22.04]
                              libss2/jammy-updates 1.46.5-2ubuntu1.2 amd64 [aktualisierbar von: 1.46.5-2ubuntu1.1]
                              libtiff-dev/jammy-updates,jammy-security 4.3.0-6ubuntu0.10 amd64 [aktualisierbar von: 4.3.0-6ubuntu0.9]
                              libtiff5/jammy-updates,jammy-security 4.3.0-6ubuntu0.10 amd64 [aktualisierbar von: 4.3.0-6ubuntu0.9]
                              libtiffxx5/jammy-updates,jammy-security 4.3.0-6ubuntu0.10 amd64 [aktualisierbar von: 4.3.0-6ubuntu0.9]
                              libwebkit2gtk-4.0-37/jammy-updates,jammy-security 2.44.3-0ubuntu0.22.04.1 amd64 [aktualisierbar von: 2.44.2-0ubuntu0.22.04.1]
                              logsave/jammy-updates 1.46.5-2ubuntu1.2 amd64 [aktualisierbar von: 1.46.5-2ubuntu1.1]
                              php8.1-ast/jammy 1.1.2-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 1.1.1-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.1-igbinary/jammy 3.2.16-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 3.2.15-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-bcmath/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-bz2/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-cli/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-common/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-curl/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-gd/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-gmp/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-igbinary/jammy 3.2.16-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 3.2.15-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-intl/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-mbstring/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-mysql/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-opcache/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-readline/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-xml/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2-zip/jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.2/jammy,jammy 8.2.23-1+ubuntu22.04.1+deb.sury.org+1 all [aktualisierbar von: 8.2.22-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-bcmath/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-bz2/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-cli/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-common/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-curl/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-gd/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-gmp/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-igbinary/jammy 3.2.16-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 3.2.15-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-intl/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-mbstring/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-mysql/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-opcache/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-phpdbg/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-readline/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-xml/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3-zip/jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 amd64 [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              php8.3/jammy,jammy 8.3.11-1+ubuntu22.04.1+deb.sury.org+1 all [aktualisierbar von: 8.3.10-1+ubuntu22.04.1+deb.sury.org+1]
                              python-apt-common/jammy-updates,jammy-updates 2.4.0ubuntu4 all [aktualisierbar von: 2.4.0ubuntu3]
                              python3-apt/jammy-updates 2.4.0ubuntu4 amd64 [aktualisierbar von: 2.4.0ubuntu3]
                              python3-distupgrade/jammy-updates,jammy-updates 1:22.04.20 all [aktualisierbar von: 1:22.04.19]
                              python3-minimal/jammy-updates 3.10.6-1~22.04.1 amd64 [aktualisierbar von: 3.10.6-1~22.04]
                              python3/jammy-updates 3.10.6-1~22.04.1 amd64 [aktualisierbar von: 3.10.6-1~22.04]
                              shim-signed/jammy-updates 1.51.4+15.8-0ubuntu1 amd64 [aktualisierbar von: 1.51.3+15.7-0ubuntu1]
                              ubuntu-advantage-tools/jammy-updates,jammy-updates 33.2~22.04 all [aktualisierbar von: 32.3.1~22.04]
                              ubuntu-drivers-common/jammy-updates 1:0.9.6.2~0.22.04.7 amd64 [aktualisierbar von: 1:0.9.6.2~0.22.04.6]
                              ubuntu-pro-client-l10n/jammy-updates 33.2~22.04 amd64 [aktualisierbar von: 32.3.1~22.04]
                              ubuntu-pro-client/jammy-updates 33.2~22.04 amd64 [aktualisierbar von: 32.3.1~22.04]
                              ubuntu-release-upgrader-core/jammy-updates,jammy-updates 1:22.04.20 all [aktualisierbar von: 1:22.04.19]
                              ubuntu-release-upgrader-gtk/jammy-updates,jammy-updates 1:22.04.20 all [aktualisierbar von: 1:22.04.19]
                              vsftpd/jammy-updates 3.0.5-0ubuntu1.1 amd64 [aktualisierbar von: 3.0.5-0ubuntu1]
                                Das ist eine Schnubbibuntu-Eigenart.
                                Hatte ich schon mal erwähnt, das ich davon nichts halte?
                                Die 8 Updates sind 'phased' und werden in Wellen ausgerollt.
                                Und die Meldung im ioBroker musst du manuell bestätigen, die aktualisiert sich nicht von alleine.
                                Und eigentlich sollten die Updates auch gar nicht alle auf deiner Kiste notwendig sein, weil auf einem Server KEIN DesktopEnvironment wie Gnome läuft... Was nicht installiert ist braucht keine Ressourcen, keine Updates und schleppt auch keine Sicherheitslücken an und kann auch nicht abstürzen.
                                I Codierknecht 2 Replies Last reply Reply Quote 0
                                  hattest du die Meldung bestätigt?
                                  Sonst ist das noch die alte Meldung
                                  • I
                                    ok, werde bei nächster Gelegenheit ein nacktes Server-Linux draufspielen, Konsole kann ich ja auch.
                                    Danke für die Hilfe. 👍
                                    Möchte mich vorher nur schlau machen, wie ich mysql richtig einrichte/was ich beachten muss.
                                    Der Apache2 läuft zwar noch, aber ich bekomme in phpmyadmin Fehlermeldungen und kann mich nicht einloggen,
                                    weiß nicht mehr, was ich da gemacht habe 😞
                                    • Codierknecht
                                      Codierknecht Developer Most Active @Thomas Braun last edited by
                                      @IOJoe22
                                      Das was Thomas schreibt kann man nicht oft genug wiederholen.
                                      Insbesondere auf einem nicht wirklich üppig ausgestatteten System wie Deinem.
                                      Aber auch auf einem Rechenwunder hat ein Desktop und der ganze andere Quatsch nix zu suchen.
                                      So ein Server soll vor allem eins machen: Stabil und zuverlässig seinen Dienst verrichten.
                                      Das soll alles auch noch auf der Büchse laufen? Mit dem kleinen Celeron und 4 GB RAM?
                                      Ich befürchte, Du verlangst da etwas viel von dem Kleinen.
                                      • I
                                        @homoran sagte in Modul LCN belastet CPU mit 103% nach update:
                                        ok, hab sie bestätigt, ist jetzt weg. Danke.
                                        @codierknecht sagte in Modul LCN belastet CPU mit 103% nach update:
                                        Bisher war die Auslastung nicht hoch, der Server lief 99,9% im Standby und war kalt. Wird nur als Kopie meiner Daten vom Arbeitsrechner genutzt und sollte von den Handys Bilder über WLAN speichern, wenn sie im Bereich sind.
                                        Und seit einiger Zeit beherbergt er den iob, der hier nicht sonderlich beansprucht wurde.
                                        Erst mit dem Update von iob hat er eine ständige hohe Auslastung von 100% auf einem Kern durch die LCN Instanz und wird leicht warm an den Lüftungsschlitzen auf dem Gehäuse bei passiver Kühlung der CPU.
                                        Daher hatte ich hier nachgefragt, ob es ein Fehler im iob sein kann....
                                          Homoran Global Moderator Administrators @Codierknecht last edited by
                                          Das schlimmste sind die nur 2 Kerne
                                          wie definierst du das?
                                          load average?
                                          letztere steigt auch an wenn I/O Vorgänge bremsen.
                                          Das schaukelt sich dann hoch
                                          • I
                                            Nun, das ist ein Bauvorschlag aus c`t 2016 mit PicoPSU90 und ext. 12V Netzteil, passiv gekühlter CPU schrieb ich ja schon - und läuft nun über 8 Jahre ununterbrochen mit 9W im Leerlauf 🙂
                                            load average?
                                            Einfach nach Gefühl (und Erfahrung). Seit den C64 Zeiten hat man einiges erlebt und "gebastelt".
                                            Aufmerksam hinschauen, fühlen der Temperaturen, manchmal messen und testen....
                                            Vielleicht könnt ihr euch noch daran erinnern. Es gab früher CPUs ohne thermal Controlling. Wenn du den Kühlkörper schräg aufgesetzt hattest, was es das für die CPU. So schnell konntest du gar nicht abschalten, wie die starb. Heute ist das vergessen.
                                            So bin ich ja auf die 100% Last durch die LCN Instanz gekommen. Die Wärme im Server gab es bis dahin nicht. Der Server tut den ganzen Tag nicht viel.
                                            Habe festgestellt, dass nach einem Neustart die Last durch die LCN Instanz einige Minuten gering ist, so 40%. Es wird nicht an den normalen I/O Funktionen liegen, denn die starten ja sofort mit der Abfrage aller LCN Module...
                                            Es kann etwas sein, was später einsetzt, z.B. ein Script oder so. Hab nur keinen Plan, wie man sowas testet. Werde ein Script mal ausschalten und die CPU-Last beobachten.
                                            OliverIO BananaJoe 2 Replies Last reply Reply Quote 0
                                            2563
