    4. Test Adapter OpenLigaDB
    • OliverIO
      OliverIO @OliverIO last edited by
      @oliverio sagte in Test Adapter OpenLigaDB:
      nochmal, da war immer noch ein fehler drin
      let dp_allmatches = "openligadb.0.bl1.2024.allmatches";
      let dp_currgameday = "openligadb.0.bl1.2024.currgameday";
      let dp_signal="0_userdata.0.Fussball.bvb";
      async function main(){
          let allmatches = await getStateAsync(dp_allmatches);
          let currgameday = await getStateAsync(dp_currgameday);
          let fav = filterFavGames(JSON.parse(allmatches.val),"",1,currgameday.val,"Borussia Dortmund",false,"");
          fav = fav.filter(el=>checkDateInRange(el.matchDateTime,24));
          console.log(fav);
          setState(dp_signal,!!fav.length);
      main();
      function filterFavGames(allmatches, gameday, gamedaycount, currgameday, filter, shortname, abbreviation) {
          if (!Array.isArray(allmatches)) return [];
          gameday = gameday || currgameday || "";
          gameday = parseInt(gameday) || "";
          gamedaycount = parseInt(gamedaycount) || 9999;
          currgameday = parseInt(currgameday);
          abbreviation = abbreviation || "";
          shortname = shortname || false;
          filter = filter || "";
          return allmatches.reduce(function (result, item) {
              let found;
              item.abbreviation = abbreviation;
              if (gameday > 0 && item.group.groupOrderID >= gameday && item.group.groupOrderID < gameday + gamedaycount) found = item;
              if (gameday < 0 && item.group.groupOrderID >= currgameday + gameday && item.group.groupOrderID < currgameday + gameday + gamedaycount) found = item;
              item.filter = filter;
              item.shortname = shortname;
              if (found && (checkHighlite(item.team1.teamName, filter) || checkHighlite(item.team2.teamName, filter))) result.push(item);
              return result;
      function checkHighlite(value, highlights, sep) {
          sep = typeof sep !== "undefined" ? sep : ";";
          const highlight = highlights.split(sep);
          return highlight.reduce(function (acc, cur) {
              if (cur == "") return acc;
              return acc || value.toLowerCase().indexOf(cur.toLowerCase()) >= 0;
          }, false);
      function checkDateInRange(date,hours) {
          let futureDate=new Date(date).getTime();
          return futureDate < Date.now()+hours*60*60*1000 ;
        Einstein2002 last edited by
        Ja danke,
        jetzt läuft das Script, aber leider alle DP noch immer auf True.
        Wenn es nicht sein soll.... dann lassen wir es?
        Ich kann leider nichts dazu tun und ich habe schon sehr deine Zeit in Anspruch genommen.
        Nur wenn Du magst machen wir weiter. Ich kann gut verstehen wenn Du keine Lust mehr hast.
        Hilft ein Neustart von IOB?
        Oder kann ich sonst noch etwas an Infos geben?
        Ich würde ja gerne Helfen, aber das Versteh ich nicht.. Leider.
        • OliverIO
          OliverIO @Einstein2002 last edited by
          @einstein2002
          also genau in der letzten version ist mein datenpunkt false, da borussia erst
          am 2024-09-13T20:30:00 spielt
          wenn man die stunden auf 27 einstellt, dann geht es wieder auf true
          wie hast du den datenpunkt angelegt?
          gibt es hinweise im iobroker log?
            Ich habe die Datenpunkte jetzt gelöscht und neu angelegt,
            jetzt alle auf False!
            Ich Starte mal alles neu!
            Moment bitte!
            Irgendwas ist hier ganz komisch.
              So da bin ich wieder,
              habe mal von allem ein paar Fotos gemacht, ist aber nichts faul !
              Der eine Verein spielt heute vielleicht fällt dir ja noch was auf?
              Screenshot 2024-09-12 184609.png Screenshot 2024-09-12 184439.png Screenshot 2024-09-12 184429.png Screenshot 2024-09-12 184409.png Screenshot 2024-09-12 184241.png Screenshot 2024-09-12 184125.png Screenshot 2024-09-12 184105.png Screenshot 2024-09-12 184041.png
                Einstein2002 last edited by Einstein2002
                hier ist script besser zu sehen:
                Dort spielen die gerade
                • OliverIO
                  OliverIO @Einstein2002 last edited by OliverIO
                  @einstein2002
                  du suchst in der bundesliga 1 nach Mühlberg?
                  es wäre gut wenn wir ein konsistentes beispiel innerhalb einer liga nehmen könnten
                    Einstein2002 @OliverIO last edited by
                    @oliverio
                    ja habe es gerade bemerkt! Durch das ganze Kopieren habe ich es nicht umgeändert! Mist!!!!
                      Bleibt aber trotzdem auf False.
                      • OliverIO
                        @einstein2002
                        ob der datenpunkt gesetzt wird oder nicht hängt auch von der anzahl der stunden ab.
                        wenn du es größer machst, dann findet das skript das spiel
                        muss halt ein wenig rechnen
                        • OliverIO
                          @einstein2002
                          hier funktioniert es.
                          gib mal nur
                          mühlberg
                          als suchbegriff ein
                            nein bleibt sturr auf false.
                            Auch der BVB mit 27 Stunden falsch.
                            Mir gehen die Ideen aus.
                              kann ich bei der Einrichtung was falsch gemacht haben?? Vorhin ging es ja einmal auf True und dann nicht wieder zurück!
                              Jetzt bleibt der Wert auf False und verändert sich nicht.
                              • OliverIO
                                @einstein2002
                                so dann nochmal komplett ersetzen
                                ich habe ein paar logausgaben hinzugefügt.
                                da müsste dann unten so etwas angezeigt werden
                                datenpunktname für signal noch anpassen
                                let dp_allmatches = "openligadb.0.KOLWTBJ.2024.allmatches";
                                let dp_currgameday = "openligadb.0.KOLWTBJ.2024.currgameday";
                                let dp_signal="0_userdata.0.testFolder.bool";
                                let suchbegriff = "mühlberg"
                                    let fav = filterFavGames(JSON.parse(allmatches.val),"",1,currgameday.val,suchbegriff,false,"");
                                    console.log("ungefiltert");
                                    console.log(fav);
                                    console.log("gefiltert");
                                    console.log(fav);
                                    console.log("statuswert");
                                    console.log(!!fav.length);
                                main();
                                        let found;
                                        return result;
                                    }, false);
                                E 2 Replies Last reply Reply Quote 0
                                  @oliverio
                                  Es funktioniert! Einwandfrei.
                                  Ich habe alles noch einmal neu angelegt und eingerichtet.
                                  Jetzt läuft es nach Deinem Update.
                                  Super!! Jetzt kann ich weitermachen.
                                  Gaaaanz lieben Dank für Deine Geduld und Wissen!!!
                                  Grüße Michael
                                  • icebear
                                    icebear last edited by icebear
                                    @OliverIO
                                    Du hattest ja mal diese Script geschrieben:
                                    // hier konfigurieren start
                                    let gameday= getState("openligadb.0.bl1.2023.currgameday").val;
                                    let allmatches = JSON.parse(getState("openligadb.0.bl1.2023.allmatches").val);
                                    let highlight="vfb;bayern"; //suchstrings für die lieblingsvereine, dessen ergebnisse herausgesucht werden sollen. mehrere mit ; getrennt
                                    let dp="0_userdata.0.test.test1"; // name des datenpunkts in dem der ergebnistext landen soll
                                    let separator=" | "; // zeichen, die die einzelnen ergebnisse voneinander trennen
                                    // hier konfigurieren ende
                                    console.log("matches:"+allmatches.length);
                                    console.log("gameday:"+gameday);
                                    console.log("highlight:"+highlight);
                                    let results = filterFavGames(allmatches,gameday,highlight,true);
                                    console.log("result:"+results.join(separator));
                                    setState(dp,results.join(separator));
                                    function filterFavGames(allmatches,gameday,highlight,short=false) {
                                        gameday = parseInt(gameday);
                                        let results =  allmatches.reduce(function(result,item){
                                            var found;
                                            item.short=short;
                                            if (gameday == item.group.groupOrderID) found=item;
                                            if (found && (checkFavorites(item.team1.teamName,highlight) || checkFavorites(item.team2.teamName,highlight)) ) result.push(prepareResultString(item));
                                            return result;
                                        return results;
                                    function getResult(results) {
                                        if (results.length==0) return {};
                                        results = results.reduce(function(acc,cur){
                                            if (cur.resultTypeID>(acc.resultTypeID||0)) acc = cur;
                                            return acc;
                                        return results;
                                    function checkFavorites(value,favorites,sep) {
                                        sep = typeof sep !== 'undefined' ? sep : ";";
                                        var favorite = favorites.split(sep);
                                        return favorite.reduce(function(acc,cur){
                                            if (cur=='') return acc;
                                            return acc || value.toLowerCase().indexOf(cur.toLowerCase())>=0;
                                        },false);
                                    function prepareResultString(item){
                                        var team1name = item.short ? item.team1.shortName : item.team1.teamName;
                                        var team2name = item.short ? item.team2.shortName : item.team2.teamName;
                                        var result = getResult(item.matchResults);
                                        var team1result = result.hasOwnProperty('pointsTeam1') ? result.pointsTeam1 : '-';
                                        var team2result = result.hasOwnProperty('pointsTeam2') ? result.pointsTeam2 : '-';
                                        return team1name + " "+team1result + " : " + team2result + " "+team2name;
                                    Wäre es möglich das Script so abzuändern, das es nur das Vereinswappen anzeigt anstatt den Vereinsnamen?
                                    Und zweite Frage: Was ist den daraus geworden das als Laufschrift anzeigen zulassen, z.B, in VIS-2?
                                    Edit: würde natürlich auch mit dem Favorite Club Widget gehen, wenn man da die Bezeichnung abwählen könnte, so das nur die Wappen da stehen.
                                    Edit2: Warum werden bei den Spielen der 2. Buli die Ergebnisse erst nach Spielende aktualisiert, bei der 1. Buli aber bei jedem Tor?
                                    ( Ich hab das Verhalten am WE festgestellt, weil ich die meisten Tore sowie Torschützen selber bei openliga eingetragen hab)
                                    • OliverIO
                                      OliverIO last edited by OliverIO
                                      @icebear
                                      ich baue da was ins widget ein
                                      kommt mit 1.5.0
                                      option only logo
                                      • OliverIO
                                        Neue Version 1.5.0
                                        • Hinzufügen eines CSS-Beispiels für das PivotTable-Widget
                                        • Hinzufügen des Befehls sendTo getMatchData um per javascript die spieldaten abzurufen und auf einen zeitbereich einzugrenzen. Details dazu siehe readme
                                        • Entfernen veralteter Widgets
                                        • Hinzufügen der Widget-Option „nur Logo“, um den Teamnamen zu unterdrücken
                                        icebear E 2 Replies Last reply Reply Quote 1
                                        • icebear
                                          icebear @OliverIO last edited by
                                          @oliverio said in Test Adapter OpenLigaDB:
                                          Perfekt, Danke für die super schnelle Umsetzung !
                                            könnte ich noch mal ein Beispiel bekommen wie diese Funktion richtig angelegt wird
                                            {a:oid;vis.binds["openligadb"].checkTodayFavorite('oid_allmatches','clubsuche1,clubsuche2')?'ja':'nein'}
                                            ich hab das so abgeändert aber bekomme immer nur eine 0 angezeigt:
                                            {a:oid;vis.binds["openligadb.0.bl1.2024"].checkTodayFavorite('openligadb.0.bl1.2024.allmatches','frankfurt,dortmund')?'ja':'nein'}
                                            Da komme ich nicht ganz mit:
                                            oid ein beliebiger Datenpunkt, der nur aufgrund der Notation des Bindings ausgewählt werden muss. Dieser Datenpunkt darf kein JSON zurückgeben.
                                            Die habe ich wie in der Anleitung beschrieben in einem html Widget
                                            Link Text
                                            adapter openligadb test
                                            56
                                            672
                                            108914
