    4. [Neuer Adapter] EuSec
    • Longbow
      Longbow @guitardoc last edited by
      @guitardoc
      ich bekomme leider nur Fehlermeldungen vom Iobroker wenn ich die neue Version (1.3.2) update:
      bei der Version 1.2.1 keine Fehlermeldung. An was liegt das bei mir, wenn bei Euch alles klappt ?
      web.0
      2024-09-13 10:41:55.906	info	http server listening on port 8082
      web.0
      2024-09-13 10:41:55.903	error	Cannot start extension "eusec.0": Error: Cannot find module 'iobroker.eusec/build/lib/web.js'Require stack:- /opt/iobroker/node_modules/iobroker.web/main.js
      web.0
      2024-09-13 10:41:55.902	info	socket.io server listening on port 8082
      web.0
      2024-09-13 10:41:55.694	info	starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
      host.iobroker-Final
      2024-09-13 10:41:54.310	info	Rebuild for adapter system.adapter.eusec.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.iobroker-Final
      2024-09-13 10:41:54.310	error	instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker-Final
      2024-09-13 10:41:54.310	error	Caught by controller[0]: Node.js v20.17.0
      host.iobroker-Final
      2024-09-13 10:41:54.310	error	Caught by controller[0]: }
      host.iobroker-Final
      2024-09-13 10:41:54.310	error	Caught by controller[0]: requestPath: 'eufy-security-client'
      host.iobroker-Final
      2024-09-13 10:41:54.310	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
      host.iobroker-Final
      2024-09-13 10:41:54.310	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker-Final
      2024-09-13 10:41:54.310	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32) {
      host.iobroker-Final
      2024-09-13 10:41:54.310	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:36:35)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1211:27)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:771:18)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:487:19)
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: ^
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: throw err;
      host.iobroker-Final
      2024-09-13 10:41:54.309	error	Caught by controller[0]: node:internal/modules/cjs/loader:495
      host.iobroker-Final
      2024-09-13 10:41:53.781	info	instance system.adapter.eusec.0 in version "1.3.2" (non-npm: bropat/ioBroker.eusec#3fa381bf8ccb5eda3d13d201490ee4ee0207c1b0) started with pid 387373
        guitardoc @Longbow last edited by
        @longbow Hast du die alte Version vorher deinstalliert? Du musst erst den eusec-Adapter komplett deinstallieren und dann über die Katze die Git-Version installieren. Dann sollten keine Fehlermeldungen mehr kommen.,
        Longbow 1 Reply Last reply Reply Quote 0
        • Longbow
          @guitardoc ja habe ich über die Mülltonne im iobroker... oder wie kann ich das anderes lösen
            @longbow Unter Adapter oder unter Instanzen? Du musst den Adapter löschen, nicht die Instanz. Dann den Adapter neu installieren und danach noch die Instanz erzeugen.
            • Longbow
              @guitardoc hab ich auch so gemacht gerade erneut, die Fehlermeldungen bleiben. 2024-09-13 13_09_36-adapters - iobroker-Final.png
                @longbow und dann hierüber neu installiert:
                • Longbow
                  Longbow @guitardoc last edited by Longbow
                  @guitardoc genau so habe ich und mache ich es auch.
                  Kann nicht mal in dem Adapter die Daten Speichern, er geht zwar auf speichern, aber wenn ich erneut ins Instanz gehe, ist es leer
                  host.iobroker-Final
                  2024-09-13 14:06:53.380	info	iobroker npm-rebuild: Rebuilding native modules ...
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	info	iobroker rebuild
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	warn	adapter "eusec" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	info	system.adapter.eusec.0 will be rebuilt
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	info	Adapter system.adapter.eusec.0 needs rebuild and will be restarted afterwards.
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: Node.js v20.17.0
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: }
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: requestPath: 'eufy-security-client'
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32) {
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:36:35)
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                  host.iobroker-Final
                  2024-09-13 14:06:52.818	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                  host.iobroker-Final
                  2024-09-13 14:06:52.817	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                  host.iobroker-Final
                  2024-09-13 14:06:52.817	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1211:27)
                  host.iobroker-Final
                  2024-09-13 14:06:52.817	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:771:18)
                  host.iobroker-Final
                  2024-09-13 14:06:52.817	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:487:19)
                  host.iobroker-Final
                  2024-09-13 14:06:52.817	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
                  host.iobroker-Final
                  2024-09-13 14:06:52.817	error	Caught by controller[0]: ^
                  host.iobroker-Final
                  2024-09-13 14:06:52.817	error	Caught by controller[0]: throw err;
                  host.iobroker-Final
                  2024-09-13 14:06:52.817	error	Caught by controller[0]: node:internal/modules/cjs/loader:495
                  host.iobroker-Final
                  2024-09-13 14:06:51.996	info	instance system.adapter.eusec.0 in version "1.3.2" started with pid 393588
                    @longbow said in [Neuer Adapter] EuSec:
                    Das sieht so aus, als ob da schon was installiert war. Mach mal unter ssh
                    cd /opt/iobroker/
                    npm ls
                    • Longbow
                      @guitardoc sagte in [Neuer Adapter] EuSec:
                      npm ls
                      also gerade ausgeführt... was soll es zeigen?
                      Ok als ich es gepostet habe, gehen... es ist ein Eufy Security Client installiert, wieso und warum? Kann das der Grund sein, in den Adapter finde ich diesen nicht, wie lösche ich diesen?
                      iobroker.inst@3.0.0 /opt/iobroker
                      +-- @iobroker-javascript.0/chroma-js@npm:chroma-js@3.1.1
                      +-- @iobroker-javascript.0/mathjs@npm:mathjs@13.1.1
                      +-- @iobroker-javascript.0/moment-duration-format@npm:moment-duration-format@2.3.2
                      +-- @iobroker-javascript.0/moment-timezone@npm:moment-timezone@0.5.45
                      +-- @iobroker-javascript.0/moment@npm:moment@2.30.1
                      +-- @iobroker-javascript.0/night@npm:night@0.0.0
                      +-- eufy-security-client@3.1.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#27e7c87d67810667022cf6cabb0c46ab1b818654)
                      +-- iobroker.accuweather@1.5.0
                      +-- iobroker.admin@7.0.23
                      +-- iobroker.alarm@3.6.1
                      +-- iobroker.alias-manager@1.2.6
                      +-- iobroker.backitup@3.0.22
                      +-- iobroker.bidirectional-counter@2.1.3
                      +-- iobroker.chromecast@3.4.1
                      +-- iobroker.cloud@5.0.1
                      +-- iobroker.daswetter@3.1.16
                      +-- iobroker.device-watcher@2.12.1
                      +-- iobroker.discovery@4.5.0
                      +-- iobroker.doorbird@1.7.0
                      +-- iobroker.drag-indicator@2.2.0
                      +-- iobroker.dwd@2.8.5
                      +-- iobroker.energiefluss-erweitert@0.4.1
                      +-- iobroker.eventlist@2.0.1
                      +-- iobroker.fritzdect@2.5.11
                      +-- iobroker.fullcalendar@2.4.2
                      +-- iobroker.geofency@1.2.4
                      +-- iobroker.history@3.0.1
                      +-- iobroker.hm-rega@5.0.0
                      +-- iobroker.hm-rpc@1.17.0
                      +-- iobroker.homeconnect@1.4.1
                      +-- iobroker.hue@3.12.0
                      +-- iobroker.ical@1.15.0
                      +-- iobroker.icons-addictive-flavour-png@0.1.0
                      +-- iobroker.icons-freepic@1.0.0
                      +-- iobroker.icons-icons8@0.0.1
                      +-- iobroker.icons-material-png@0.1.0
                      +-- iobroker.icons-material-svg@0.1.0
                      +-- iobroker.icons-mfd-png@1.2.1
                      +-- iobroker.icons-mfd-svg@1.2.0
                      +-- iobroker.icons-open-icon-library-png@0.1.2
                      +-- iobroker.icons-smarthome@1.0.0
                      +-- iobroker.icons-ultimate-png@1.0.1
                      +-- iobroker.influxdb@4.0.2
                      +-- iobroker.info@2.0.0
                      +-- iobroker.iot@3.3.0
                      +-- iobroker.javascript@8.7.6
                      +-- iobroker.js-controller@6.0.11
                      +-- iobroker.klf200@1.2.0
                      +-- iobroker.lightcontrol@0.8.0
                      +-- iobroker.linkeddevices@1.5.5
                      +-- iobroker.modbus@6.2.3
                      +-- iobroker.mqtt@5.2.0
                      +-- iobroker.myenergi@0.0.3
                      +-- iobroker.net-tools@1.0.11
                      +-- iobroker.netatmo@3.1.0
                      +-- iobroker.nina@0.0.25
                      +-- iobroker.notification-manager@1.1.2
                      +-- iobroker.nuki-extended@2.7.0
                      +-- iobroker.onvif@1.1.4
                      +-- iobroker.openweathermap@1.1.2
                      +-- iobroker.operating-hours@1.1.0
                      +-- iobroker.ping@1.6.2
                      +-- iobroker.places@1.2.0
                      +-- iobroker.pollenflug@2.0.0
                      +-- iobroker.proxmox@2.3.0
                      +-- iobroker.pushover@3.0.6
                      +-- iobroker.reolink@1.1.1
                      +-- iobroker.robonect@1.3.6
                      +-- iobroker.roborock@0.6.11 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#801511a70e1eeb3ae66f2608f9d6c86b8933e515)
                      +-- iobroker.samsung_tizen@1.1.0
                      +-- iobroker.scenes@3.2.1
                      +-- iobroker.shelly@7.0.0
                      +-- iobroker.simple-api@2.8.0
                      +-- iobroker.smartgarden@2.0.1
                      +-- iobroker.smartthings@0.0.4
                      +-- iobroker.socketio@6.7.1
                      +-- iobroker.solaredge@1.4.1
                      +-- iobroker.sonos@3.0.0
                      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
                      +-- iobroker.sql@3.0.1
                      +-- iobroker.statistics@2.4.0
                      +-- iobroker.systeminfo@1.2.0
                      +-- iobroker.tankerkoenig@3.4.0
                      +-- iobroker.tr-064@4.3.0
                      +-- iobroker.trashschedule@3.3.0
                      +-- iobroker.tuya@3.16.0
                      +-- iobroker.unifi@0.7.0
                      +-- iobroker.upnp@1.0.21
                      +-- iobroker.virtualpowermeter@1.4.6
                      +-- iobroker.vis-bars@0.1.4
                      +-- iobroker.vis-canvas-gauges@1.0.1
                      +-- iobroker.vis-colorpicker@2.0.3
                      +-- iobroker.vis-fancyswitch@1.1.0
                      +-- iobroker.vis-google-fonts@1.0.4
                      +-- iobroker.vis-history@1.0.0
                      +-- iobroker.vis-hqwidgets@1.5.1
                      +-- iobroker.vis-icontwo@1.5.0
                      +-- iobroker.vis-inventwo@3.3.4
                      +-- iobroker.vis-jqui-mfd@1.1.1
                      +-- iobroker.vis-justgage@2.1.7
                      +-- iobroker.vis-map@1.1.2
                      +-- iobroker.vis-material-advanced@1.7.4
                      +-- iobroker.vis-material@0.1.3
                      +-- iobroker.vis-materialdesign@0.5.9
                      +-- iobroker.vis-metro@1.2.0
                      +-- iobroker.vis-plumb@1.0.2
                      +-- iobroker.vis-rgraph@0.0.2
                      +-- iobroker.vis-timeandweather@1.2.2
                      +-- iobroker.vis-weather@2.5.9
                      +-- iobroker.vis@1.5.6
                      +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
                      +-- iobroker.weather-warnings@0.6.7
                      +-- iobroker.weatherunderground@3.7.0
                      +-- iobroker.web@6.2.5
                      +-- iobroker.welcome@0.3.0
                      +-- iobroker.wolf-smartset@1.2.3
                      +-- iobroker.wolf@1.7.0
                      +-- iobroker.ws@2.6.2
                      +-- iobroker.yr@5.3.0
                      `-- npm@10.3.0
                        Adnim @Longbow last edited by
                        @longbow
                        also da nix von Hand löschen würde ich sagen.
                        Ich glaube du hast da nen Update Stau im System; hau mal nen IOB Diag raus...
                        • Longbow
                          @adnim
                          Mhh kann so was passieren...
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                           Static hostname: iobroker-Final
                                 Icon name: computer-container
                                   Chassis: container ☐
                            Virtualization: lxc
                                    Kernel: Linux 6.2.16-3-pve
                              Architecture: x86-64
                          model name      : Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz
                          Docker          : false
                          Virtualization  : lxc
                          Kernel          : x86_64
                          Userland        : 64 bit
                          Systemuptime and Load:
                           17:18:05 up 14 days,  3:39,  3 users,  load average: 1.25, 1.22, 1.12
                          CPU threads: 4
                          *** Time and Time Zones ***
                                         Local time: Sat 2024-09-14 17:18:05 CEST
                                     Universal time: Sat 2024-09-14 15:18:05 UTC
                                           RTC time: n/a
                                        NTP service: inactive
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          longbow
                          HOME=/home/longbow
                          GROUPS=longbow sudo users iobroker
                          iobroker
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video plugdev
                          *** Display-Server-Setup ***
                          Display-Server: false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:             12G        5.5G        4.3G         90K        3.0G        7.4G
                          Swap:           8.6G        126K        8.6G
                          Total:           21G        5.5G         12G
                          Active iob-Instances:   64
                                  12288 M total memory
                                   5271 M used memory
                                   1878 M active memory
                                   5748 M inactive memory
                                   4145 M free memory
                                      0 M buffer memory
                                   2871 M swap cache
                                   8191 M total swap
                                      0 M used swap
                                   8191 M free swap
                          top - 17:18:05 up 14 days,  3:39,  3 users,  load average: 1.25, 1.22, 1.12
                          Tasks:  93 total,   2 running,  91 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  12288.0 total,   4142.8 free,   5273.9 used,   2871.3 buff/cache
                          MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.   7014.1 avail Mem
                          *** FAILED SERVICES ***
                            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                          LOAD   = Reflects whether the unit definition was properly loaded.
                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                          SUB    = The low-level unit activation state, values depend on unit type.
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          Filesystem                       Type      Size  Used Avail Use% Mounted on
                          /dev/mapper/pve-vm--240--disk--0 ext4       94G   14G   76G  16% /
                          none                             tmpfs     492K  4.0K  488K   1% /dev
                          udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                          tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                          tmpfs                            tmpfs     3.2G  136K  3.2G   1% /run
                          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                          tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                          dmesg: read kernel buffer failed: Operation not permitted
                          Show mounted filesystems:
                          TARGET                                                  SOURCE                           FSTYPE     OPTIONS
                          /                                                       /dev/mapper/pve-vm--240--disk--0 ext4       rw,relatime,stripe=16
                          |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3251320k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                          | |-/run/user/1000                                      tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=1625656k,nr_inodes=406414,mode=700,uid=101000,gid=101000,inode64
                          | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                          | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                          | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                          | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                          | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                          |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                          | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                          | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
                          | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
                          | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
                          | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                          | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                          | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                          | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                          | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                          | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                          | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
                          | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
                          | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
                          | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                          | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
                          | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
                            |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
                            |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
                            |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
                            `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          /var:
                          4.3G    /var/
                          3.5G    /var/log/journal/4482dacb35484bddab24b914a301d279
                          3.5G    /var/log
                          712M    /var/cache
                          Archived and active journals take up 19.3M in the file system.
                          /opt/iobroker/backups:
                          518M    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          1.9G    /opt/iobroker/iobroker-data/
                          1.3G    /opt/iobroker/iobroker-data/files
                          441M    /opt/iobroker/iobroker-data/files/javascript.admin
                          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                          408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          130M    /opt/iobroker/iobroker-data/states.jsonl
                          55M     /opt/iobroker/iobroker-data/objects.jsonl
                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                          USB-Devices by-id:
                          No Devices found 'by-id'
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v20.17.0
                          /usr/bin/node           v20.17.0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          /usr/bin/corepack       0.29.3
                          nodejs:
                            Installed: 20.17.0-1nodesource1
                            Candidate: 20.17.0-1nodesource1
                            Version table:
                           *** 20.17.0-1nodesource1 600
                                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                  100 /var/lib/dpkg/status
                               20.16.0-1nodesource1 600
                               20.15.1-1nodesource1 600
                               20.15.0-1nodesource1 600
                               20.14.0-1nodesource1 600
                               20.13.1-1nodesource1 600
                               20.13.0-1nodesource1 600
                               20.12.2-1nodesource1 600
                               20.12.1-1nodesource1 600
                               20.12.0-1nodesource1 600
                               20.11.1-1nodesource1 600
                               20.11.0-1nodesource1 600
                               20.10.0-1nodesource1 600
                               20.9.0-1nodesource1 600
                               20.8.1-1nodesource1 600
                               20.8.0-1nodesource1 600
                               20.7.0-1nodesource1 600
                               20.6.1-1nodesource1 600
                               20.6.0-1nodesource1 600
                               20.5.1-1nodesource1 600
                               20.5.0-1nodesource1 600
                               20.4.0-1nodesource1 600
                               20.3.1-1nodesource1 600
                               20.3.0-1nodesource1 600
                               20.2.0-1nodesource1 600
                               20.1.0-1nodesource1 600
                               20.0.0-1nodesource1 600
                               18.19.0+dfsg-6~deb12u2 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                               18.19.0+dfsg-6~deb12u1 500
                                  500 http://security.debian.org bookworm-security/main amd64 Packages
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          admin:          7.0.23
                          javascript:     8.7.6
                          nodejs modules from github:     4
                          Adapter State
                          + system.adapter.accuweather.0            : accuweather           : iobroker-Final                           -  enabled
                          + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.alarm.0                  : alarm                 : iobroker-Final                           -  enabled
                            system.adapter.alias-manager.0          : alias-manager         : iobroker-Final                           - disabled
                          + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
                            system.adapter.bidirectional-counter.0  : bidirectional-counter : iobroker-Final                           - disabled
                            system.adapter.chromecast.0             : chromecast            : iobroker-Final                           - disabled
                          + system.adapter.cloud.0                  : cloud                 : iobroker-Final                           -  enabled
                            system.adapter.daswetter.0              : daswetter             : iobroker-Final                           -  enabled
                          + system.adapter.device-watcher.0         : device-watcher        : iobroker-Final                           -  enabled
                          + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
                          + system.adapter.doorbird.0               : doorbird              : iobroker-Final                           -  enabled
                            system.adapter.drag-indicator.0         : drag-indicator        : iobroker-Final                           - disabled
                            system.adapter.dwd.0                    : dwd                   : iobroker-Final                           -  enabled
                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-Final                           -  enabled
                            system.adapter.eventlist.0              : eventlist             : iobroker-Final                           - disabled
                          + system.adapter.fritzdect.0              : fritzdect             : iobroker-Final                           -  enabled
                            system.adapter.fullcalendar.0           : fullcalendar          : iobroker-Final                           - disabled
                          + system.adapter.geofency.0               : geofency              : iobroker-Final                           -  enabled, port: 7999, bind: 0.0.0.0
                          + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : iobroker-Final                           -  enabled
                            system.adapter.hm-rega.1                : hm-rega               : iobroker-Final                           - disabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Final                           -  enabled, port: 18701
                          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-Final                           -  enabled, port: 12001
                            system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-Final                           - disabled, port: 12001
                          + system.adapter.homeconnect.0            : homeconnect           : iobroker-Final                           -  enabled
                          + system.adapter.hue.0                    : hue                   : iobroker-Final                           -  enabled, port: 443
                            system.adapter.ical.0                   : ical                  : iobroker-Final                           -  enabled
                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Final                           - disabled
                            system.adapter.icons-freepic.0          : icons-freepic         : iobroker-Final                           - disabled
                            system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Final                           - disabled
                            system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Final                           - disabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-Final                           - disabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Final                           - disabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Final                           - disabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Final                           - disabled
                            system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker-Final                           - disabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Final                           - disabled
                          + system.adapter.influxdb.0               : influxdb              : iobroker-Final                           -  enabled, port: 8086
                          + system.adapter.info.0                   : info                  : iobroker-Final                           -  enabled
                          + system.adapter.iot.0                    : iot                   : iobroker-Final                           -  enabled
                          + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
                          + system.adapter.klf200.0                 : klf200                : iobroker-Final                           -  enabled
                            system.adapter.lightcontrol.0           : lightcontrol          : iobroker-Final                           - disabled
                            system.adapter.linkeddevices.0          : linkeddevices         : iobroker-Final                           - disabled
                          + system.adapter.modbus.0                 : modbus                : iobroker-Final                           -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : iobroker-Final                           -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.myenergi.0               : myenergi              : iobroker-Final                           -  enabled
                          + system.adapter.net-tools.0              : net-tools             : iobroker-Final                           -  enabled
                          + system.adapter.netatmo.0                : netatmo               : iobroker-Final                           -  enabled
                          + system.adapter.nina.0                   : nina                  : iobroker-Final                           -  enabled
                          + system.adapter.notification-manager.0   : notification-manager  : iobroker-Final                           -  enabled
                          + system.adapter.nuki-extended.0          : nuki-extended         : iobroker-Final                           -  enabled
                          + system.adapter.onvif.0                  : onvif                 : iobroker-Final                           -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899, 888
                            system.adapter.openweathermap.0         : openweathermap        : iobroker-Final                           -  enabled
                          + system.adapter.operating-hours.0        : operating-hours       : iobroker-Final                           -  enabled
                            system.adapter.ping.0                   : ping                  : iobroker-Final                           - disabled
                            system.adapter.places.0                 : places                : iobroker-Final                           - disabled
                          + system.adapter.pollenflug.0             : pollenflug            : iobroker-Final                           -  enabled
                          + system.adapter.proxmox.0                : proxmox               : iobroker-Final                           -  enabled, port: 8006
                          + system.adapter.pushover.0               : pushover              : iobroker-Final                           -  enabled
                          + system.adapter.reolink.0                : reolink               : iobroker-Final                           -  enabled
                          + system.adapter.reolink.1                : reolink               : iobroker-Final                           -  enabled
                          + system.adapter.reolink.2                : reolink               : iobroker-Final                           -  enabled
                            system.adapter.robonect.0               : robonect              : iobroker-Final                           - disabled
                          + system.adapter.roborock.0               : roborock              : iobroker-Final                           -  enabled
                            system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker-Final                           - disabled, port: 8002
                          + system.adapter.scenes.0                 : scenes                : iobroker-Final                           -  enabled
                          + system.adapter.shelly.0                 : shelly                : iobroker-Final                           -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.simple-api.0             : simple-api            : iobroker-Final                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          + system.adapter.smartgarden.0            : smartgarden           : iobroker-Final                           -  enabled
                            system.adapter.smartthings.0            : smartthings           : iobroker-Final                           - disabled
                            system.adapter.solaredge.0              : solaredge             : iobroker-Final                           -  enabled
                            system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
                          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-Final                           -  enabled
                          + system.adapter.sql.0                    : sql                   : iobroker-Final                           -  enabled
                          + system.adapter.statistics.0             : statistics            : iobroker-Final                           -  enabled
                          + system.adapter.systeminfo.0             : systeminfo            : iobroker-Final                           -  enabled
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Final                           -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : iobroker-Final                           -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : iobroker-Final                           -  enabled
                          + system.adapter.tuya.0                   : tuya                  : iobroker-Final                           -  enabled
                          + system.adapter.tuya.1                   : tuya                  : iobroker-Final                           -  enabled
                          + system.adapter.tuya.2                   : tuya                  : iobroker-Final                           -  enabled
                          + system.adapter.unifi.0                  : unifi                 : iobroker-Final                           -  enabled
                          + system.adapter.upnp.0                   : upnp                  : iobroker-Final                           -  enabled
                            system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-Final                           - disabled
                            system.adapter.vis-bars.0               : vis-bars              : iobroker-Final                           - disabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-Final                           - disabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Final                           - disabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-Final                           -  enabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-Final                           -  enabled
                            system.adapter.vis-history.0            : vis-history           : iobroker-Final                           -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Final                           - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-Final                           - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-Final                           -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-Final                           - disabled
                            system.adapter.vis-justgage.0           : vis-justgage          : iobroker-Final                           - disabled
                            system.adapter.vis-map.0                : vis-map               : iobroker-Final                           - disabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-Final                           - disabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-Final                           -  enabled
                            system.adapter.vis-metro.0              : vis-metro             : iobroker-Final                           - disabled
                            system.adapter.vis-plumb.0              : vis-plumb             : iobroker-Final                           -  enabled
                            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Final                           - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Final                           - disabled
                            system.adapter.vis-weather.0            : vis-weather           : iobroker-Final                           - disabled
                            system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
                          + system.adapter.vw-connect.0             : vw-connect            : iobroker-Final                           -  enabled
                          + system.adapter.vw-connect.1             : vw-connect            : iobroker-Final                           -  enabled
                          + system.adapter.weather-warnings.0       : weather-warnings      : iobroker-Final                           -  enabled
                            system.adapter.weatherunderground.0     : weatherunderground    : iobroker-Final                           -  enabled
                          + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.welcome.0                : welcome               : iobroker-Final                           -  enabled, port: 80, bind: 0.0.0.0, run as: admin
                          + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker-Final                           -  enabled
                          + system.adapter.wolf.0                   : wolf                  : iobroker-Final                           -  enabled, port: 12004, bind: 0.0.0.0
                            system.adapter.yr.0                     : yr                    : iobroker-Final                           -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Upgrade policy: none
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                          Adapter    "admin"        : 7.0.23   , installed 7.0.23
                          Adapter    "alarm"        : 3.6.1    , installed 3.6.1
                          Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                          Adapter    "bidirectional-counter": 2.2.0, installed 2.2.0
                          Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                          Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                          Adapter    "doorbird"     : 1.7.0    , installed 1.7.0
                          Adapter    "drag-indicator": 2.2.0   , installed 2.2.0
                          Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                          Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
                          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                          Adapter    "fullcalendar" : 2.4.2    , installed 2.4.2
                          Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                          Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                          Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                          Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                          Adapter    "hue"          : 3.12.0   , installed 3.12.0
                          Adapter    "ical"         : 1.15.0   , installed 1.15.0
                          Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
                          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                          Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
                          Adapter    "iot"          : 3.3.0    , installed 3.3.0
                          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                          Controller "js-controller": 6.0.11   , installed 6.0.11
                          Adapter    "klf200"       : 1.2.0    , installed 1.2.0
                          Adapter    "lightcontrol" : 0.8.0    , installed 0.8.0
                          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                          Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                          Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
                          Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                          Adapter    "nina"         : 0.0.25   , installed 0.0.25
                          Adapter    "notification-manager": 1.1.2, installed 1.1.2
                          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                          Adapter    "operating-hours": 1.1.0  , installed 1.1.0
                          Adapter    "places"       : 1.2.0    , installed 1.2.0
                          Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                          Adapter    "pushover"     : 4.1.0    , installed 3.0.6  [Updatable]
                          Adapter    "reolink"      : 1.1.1    , installed 1.1.1
                          Adapter    "robonect"     : 1.3.6    , installed 1.3.6
                          Adapter    "roborock"     : 0.6.4    , installed 0.6.11
                          Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                          Adapter    "scenes"       : 3.2.1    , installed 3.2.1
                          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                          Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                          Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
                          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                          Adapter    "sql"          : 3.0.1    , installed 3.0.1
                          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                          Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                          Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                          Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
                          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                          Adapter    "welcome"      : 0.3.0    , installed 0.3.0
                          Adapter    "wolf"         : 1.7.0    , installed 1.7.0
                          Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
                          Adapter    "ws"           : 2.6.2    , installed 2.6.2
                          Adapter    "yr"           : 5.3.0    , installed 5.3.0
                          Objects and States
                          Objects:        58506
                          States:         46276
                          Hit:1 http://security.debian.org bookworm-security InRelease
                          Hit:2 http://deb.debian.org/debian bookworm InRelease
                          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 192.168.178.240:18701   0.0.0.0:*               LISTEN      1001       512516892  381431/io.hm-rpc.0
                          tcp        0      0 192.168.178.240:12001   0.0.0.0:*               LISTEN      1001       512517743  381442/io.hm-rpc.1
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          419981791  294/master
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       512511819  381099/iobroker.js-
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       512511824  381099/iobroker.js-
                          tcp        0      0 0.0.0.0:8100            0.0.0.0:*               LISTEN      1001       512527792  382060/io.doorbird.
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       512521923  381635/io.shelly.0
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          419979059  1/systemd
                          tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       512526179  381961/io.wolf.0
                          tcp6       0      0 :::7906                 :::*                    LISTEN      1001       512521448  381244/io.roborock.
                          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       512547557  382879/io.upnp.0
                          tcp6       0      0 :::7999                 :::*                    LISTEN      1001       512516041  381395/io.geofency.
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       513254766  387362/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       512512795  381117/io.admin.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       512539420  382911/io.simple-ap
                          tcp6       0      0 :::8095                 :::*                    LISTEN      1001       512534319  382574/io.onvif.0
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          419981792  294/master
                          tcp6       0      0 :::6824                 :::*                    LISTEN      1001       512521447  381244/io.roborock.
                          tcp6       0      0 :::1984                 :::*                    LISTEN      1001       512520456  381571/go2rtc_linux
                          tcp6       0      0 :::80                   :::*                    LISTEN      1001       512537054  382784/io.welcome.0
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          419979061  1/systemd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          419980077  1/systemd
                          tcp6       0      0 :::8554                 :::*                    LISTEN      1001       512518925  381571/go2rtc_linux
                          tcp6       0      0 :::8555                 :::*                    LISTEN      1001       512518926  381571/go2rtc_linux
                          tcp6       0      0 :::51989                :::*                    LISTEN      1001       512525054  382028/io.nuki-exte
                          udp        0      0 192.168.178.240:5353    0.0.0.0:*                           1001       512521215  381756/io.tr-064.0
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       512522784  381868/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       512522785  381868/io.tuya.0
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          419979060  1/systemd
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       512542779  382879/io.upnp.0
                          udp        0      0 0.0.0.0:35611           0.0.0.0:*                           1001       512537584  382879/io.upnp.0
                          udp6       0      0 :::111                  :::*                                0          419979062  1/systemd
                          udp6       0      0 :::8555                 :::*                                1001       512560717  383682/go2rtc
                          2024-09-14 17:15:26.014  - info: host.iobroker-Final instance system.adapter.daswetter.0 in version "3.1.16" started with pid 428529
                          2024-09-14 17:15:26.657  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
                          2024-09-14 17:15:26.677  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
                          2024-09-14 17:15:26.688  - info: web.0 (387362) ==> Connected system.user.admin from ::ffff:192.168.178.38
                          2024-09-14 17:15:26.884  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
                          Copy text starting here:
                                                  v.2024-05-22
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               64 bit
                          Timezone:               Europe/Berlin (CEST, +0200)
                          User-ID:                1000
                          Boot Target:            graphical.target
                          Pending OS-Updates:     0
                          Pending iob updates:    1
                          Nodejs-Installation:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          Recommended versions are nodejs 20.17.0 and npm 10.8.2
                          MEMORY:
                          Mem:             12G        5.5G        4.4G         90K        3.0G        7.4G
                          Total:           21G        5.5G         12G
                          ioBroker Core:          js-controller           6.0.11
                                                  admin                   7.0.23
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                58506
                          States:                 46276
                          Size of iob-Database:
                          59M     /opt/iobroker/iobroker-data/objects.jsonl
                          132M    /opt/iobroker/iobroker-data/states.jsonl
                          === Mark text until here for copying ===
                          longbow@iobroker-Final:~$
                          • Longbow
                            Kann mir keiner einen Tipp geben oder behilflich sein ?
                              @longbow Der Security Client muss raus, den hast du dir bei irgendeinem Installationsversuch eingefangen:
                              npm uninstall eufy-security-client
                              • Longbow
                                @guitardoc Danke, hat geklappt... der Adapter könnte installiert werden, nur leider werden meinen Cam, die Bilder angezeigt... spricht wie binde ich nun diese ein?
                                G G 2 Replies Last reply Reply Quote 0
                                  @longbow Da kann ich dir leider nicht helfen, ich nutze den Adapter nur, um den Modus in Abhängigkeit von Anwesenheit und Tageszeit zu steuern.
                                    GMJ @Longbow last edited by GMJ
                                    @longbow
                                    So gehts -> http://IP_BROKER:PORT_BROKER_VIS/eusec.0/T8030P0815/last_event/T8213P0815.jpg
                                    In Vis in ein "Basic Image" in die URL
                                    astuermer 1 Reply Last reply Reply Quote 0
                                    • Longbow
                                      @gmj Danke, das geht sehr gut.
                                      Wie kann man das Live einfügen? Also aufrufen, bekommen?
                                        @longbow
                                        Kein Live Bild so einfach "da"
                                        Nutze ich nicht.... denn man muss so wie ich das verstanden haben das Livebild starten (per datenpunkt triggern) dann gibt es einen Stream den man dann irgend wie einbinden könnte .... und danach den Stream wieder beenden. Sonst refresh Bild im widget in x ms einstellbar dann gibt es auktuelles wenn da.
                                        • astuermer
                                          astuermer @GMJ last edited by astuermer
                                          @gmj sagte in [Neuer Adapter] EuSec:
                                          @longbow
                                          Da kommt bei mir leider nur das:
                                          404
                                          Oops! The page you're looking for can't be found. 😔
                                          File /eusec.0/hier Pfad mit Dateiname.jpg not found
                                          Update: Hat sich erledigt mit einem neuen Update. Was nachwievor nicht läuft, dass der Akkustand sich automatisch aktualisiert. Ich muss dazu jedesmal den Adapter neu starten.
                                          • astuermer
                                            astuermer last edited by
                                            Was von Vorteil wäre: Timestamp pro Kamera.
                                            Klar man kann es in der eufy App ins Bild integrieren, aber bei Tageslicht ist das nicht lesbar. Das wäre als Value pro Kamera toll 👍🏻
                                            1.0k
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            455643
