    4. Fehler in host.raspberryPi
      Thomas Braun Most Active @werner2000x last edited by
      @werner2000x sagte in Fehler in host.raspberryPi:
      Display-Server: true
      Boot Target: graphical.target
      OHNE Desktop.
      werner2000x 1 Reply Last reply Reply Quote 0
      • werner2000x
        werner2000x @Thomas Braun last edited by
        @thomas-braun Jetzt ohne Desktop:
                                v.2024-05-22
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        Display-Server:         false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    36
        Nodejs-Installation:
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        npm:                    N/A
        npx:                    N/A
        corepack:       N/A
        Recommended versions are nodejs  and npm
        *** nodejs is NOT correctly installed ***
        Wrong installation path detected. This needs to be fixed.
        Please execute
        iobroker nodejs-update
        to fix these errors.
        MEMORY:
        Mem:            8.2G        2.1G        5.1G        1.3M        1.2G        6.1G
        Swap:           104M          0B        104M
        Total:          8.3G        2.1G        5.2G
        Active iob-Instances:   14
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
          system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                4543
        States:                 3654
        Size of iob-Database:
        16M     /opt/iobroker/iobroker-data/objects.jsonl
        7.1M    /opt/iobroker/iobroker-data/states.jsonl
          Thomas Braun Most Active @werner2000x last edited by Thomas Braun
          iob nodejs-update 20
          Und dann die Updates reinschaufeln.
            @werner2000x
            Wie schafft man es eigentlich, den ioBroker zu installieren, dann aber bei nodejs irgendwas krummes an Land zu ziehen?
            • werner2000x
              @thomas-braun Ich habe die Installation über eine alt 64 Bit Version mit Bullseye gestartet.
              Mit iob diag erhalte ich jetzt` ``
              *** iob diag is starting up, please wait ***
              The state system.host.raspberrypi.versions.nodeNewestNext was not found!
              The state system.host.raspberrypi.versions.npmNewestNext was not found!
              The state system.host.raspberrypi.versions.nodeCurrent was not found!
                Das funktioniert NICHT.
                RaspberryOS 12 'Bookworm' muss KOMPLETT NEUINSTALLIERT WERDEN!
                • werner2000x
                  werner2000x last edited by werner2000x
                  @thomas-braun Ich habe die lite version von bookworm installiert, kann mich aber mit keinem login anmelden, obwohl ich einen datei userconf mit login daten erstell habe. Eine SSH Verbindung klappt, jedoch fehlen mit die login daten.
                  Wie geht das jetzt bei bookworm?
                    ??? Wie sonst auch.
                    Was machst du da? Welche Datei 'userconf'?
                    Mach es danach:
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    Da wird dann auch ein user und auch der ssh-Server eingerichtet.
                    • werner2000x
                      @thomas-braun Jetzt gabe ich die SD Card neu aufgesetzt.
                      Der Info Adapter konnte nicht gestartet werden, das habe ich Ihn gelöscht.
                      Wie kann man ihn neu installieren?
                        Gar nicht. Der wird nicht mehr unterstützt.
                        • werner2000x
                          @thomas-braun Der RPI Adapter hat noch Fehlermeldungen:
                          rpi2.0
                          2024-09-14 12:51:42.705	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 8780528 107384372 8% / /1024
                            Homoran Global Moderator Administrators @werner2000x last edited by
                            welche Version?
                              Nicht in der Version 2..0. Kann sein das die aber noch Beta ist.
                              • werner2000x
                                @thomas-braun Ich habe die Version 2.0
                                  Kann eigentlich nicht sein. Das falsche parsing wurde da korrigiert.
                                  iob diag
                                  in der Langfassung liefert?
                                  • werner2000x
                                    @thomas-braun Der Fehler ist noch da:
                                    2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) VALUE: 204796 POST: (rpi.swap_total - $1)/1024
                                    2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.swap.swap_used VALUE = 0
                                    2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) CURRENT = temperature true
                                    2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) -1
                                    2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) ---> POST: $1/1000 for soc_temp in [object Object]
                                    2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) VALUE: 66218 POST: $1/1000
                                    2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.temperature.soc_temp VALUE = 66.22
                                    2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) CURRENT = uptime true
                                    2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) -1
                                    2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) ---> POST: for uptime in [object Object]
                                    2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.uptime.uptime VALUE = 1511
                                    2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) CURRENT = wlan true
                                    2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) -1
                                    2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) ---> POST: $1*-1 for wifi_received in [object Object]
                                    2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) VALUE: 0 POST: $1*-1
                                    2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.wlan.wifi_received VALUE = 0
                                    2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) ---> POST: for wifi_send in [object Object]
                                    2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.wlan.wifi_send VALUE = 0
                                    2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) CURRENT = gpios undefined
                                    2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) -1
                                    2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) CURRENT = inputPullUp undefined
                                    2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) -1
                                    2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = inputDebounceMs undefined
                                    2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonPullUp undefined
                                    2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonDebounceMs undefined
                                    2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonPressMs undefined
                                    2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) -1
                                    2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) CURRENT = buttonDoubleMs undefined
                                    2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) CURRENT = dhtPollInterval undefined
                                    2024-09-19 11:54:11.197 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.cpu_frequency found state = {"val":1800,"ack":true,"ts":1726739651194,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739427963}
                                    2024-09-19 11:54:11.239 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load1 found state = {"val":0.7,"ack":true,"ts":1726739651236,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651236}
                                    2024-09-19 11:54:11.241 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load5 found state = {"val":0.61,"ack":true,"ts":1726739651236,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651236}
                                    2024-09-19 11:54:11.244 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load15 found state = {"val":0.82,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                    2024-09-19 11:54:11.245 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.scaling_governor found state = {"val":"ondemand","ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972151}
                                    2024-09-19 11:54:11.247 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.cpu_voltage found state = {"val":0.92,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739427964}
                                    2024-09-19 11:54:11.251 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.mem_arm found state = {"val":948,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310982794}
                                    2024-09-19 11:54:11.252 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.mem_gpu found state = {"val":76,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310982794}
                                    2024-09-19 11:54:11.254 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_total found state = {"val":7809.97,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972151}
                                    2024-09-19 11:54:11.256 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_free found state = {"val":4582.61,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                    2024-09-19 11:54:11.259 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_available found state = {"val":5839.04,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                    2024-09-19 11:54:11.260 - debug: rpi2.0 (4899) stateChange for rpi2.0.network.net_received found state = {"val":-195147982,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                    2024-09-19 11:54:11.262 - debug: rpi2.0 (4899) stateChange for rpi2.0.network.net_send found state = {"val":45400627,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                    2024-09-19 11:54:11.264 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_root_total found state = {"val":119529.39,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972153}
                                    2024-09-19 11:54:11.265 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_boot_total found state = {"val":null,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                    2024-09-19 11:54:11.267 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_root_used found state = {"val":13036.82,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                    2024-09-19 11:54:11.269 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_boot_used found state = {"val":null,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                    2024-09-19 11:54:11.276 - debug: rpi2.0 (4899) stateChange for rpi2.0.swap.swap_total found state = {"val":200,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972163}
                                    2024-09-19 11:54:11.277 - debug: rpi2.0 (4899) stateChange for rpi2.0.swap.swap_used found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972164}
                                    2024-09-19 11:54:11.279 - debug: rpi2.0 (4899) stateChange for rpi2.0.temperature.soc_temp found state = {"val":66.22,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651238}
                                    2024-09-19 11:54:11.281 - debug: rpi2.0 (4899) stateChange for rpi2.0.uptime.uptime found state = {"val":1511,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651238}
                                    2024-09-19 11:54:11.283 - debug: rpi2.0 (4899) stateChange for rpi2.0.wlan.wifi_received found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972164}
                                    2024-09-19 11:54:11.284 - debug: rpi2.0 (4899) stateChange for rpi2.0.wlan.wifi_send found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972226}
                                      @werner2000x
                                      Ich seh da keine Fehler der Art
                                      • werner2000x
                                        @thomas-braun Der Log war zu kurz:
                                        pi2.0
                                        2024-09-19 12:19:10.905	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13321100 102843800 12% / /1024
                                        rpi2.0
                                        2024-09-19 12:19:10.904	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13321100 102843800 12% / /1024
                                        rpi2.0
                                        2024-09-19 12:18:10.928	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320888 102844012 12% / /1024
                                        rpi2.0
                                        2024-09-19 12:18:10.927	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320888 102844012 12% / /1024
                                        rpi2.0
                                        2024-09-19 12:17:10.907	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320584 102844316 12% / /1024
                                        rpi2.0
                                        2024-09-19 12:17:10.905	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320584 102844316 12% / /1024
                                        rpi2.0
                                        2024-09-19 12:16:10.904	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
                                        rpi2.0
                                        2024-09-19 12:16:10.903	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
                                          @werner2000x
                                          cd /opt/iobroker
                                          npm ls
                                          • werner2000x
                                            Ausgabe:
                                            :/opt/iobroker $ npm ls
                                            iobroker.inst@3.0.0 /opt/iobroker
                                            ├── @emnapi/runtime@1.2.0 extraneous
                                            ├── iobroker.admin@7.1.1
                                            ├── iobroker.alexa2@3.26.5
                                            ├── iobroker.alias-manager@1.2.6
                                            ├── iobroker.backitup@3.0.22
                                            ├── iobroker.ble@0.14.0
                                            ├── iobroker.bshb@0.2.8
                                            ├── iobroker.chromecast@3.4.1
                                            ├── iobroker.cloud@5.0.1
                                            ├── iobroker.daikin-cloud@0.4.8
                                            ├── iobroker.denon@1.15.12
                                            ├── iobroker.device-reminder@3.1.2
                                            ├── iobroker.discovery@5.0.0
                                            ├── iobroker.echarts@1.7.2
                                            ├── iobroker.email@1.3.1
                                            ├── iobroker.energiefluss@3.6.0
                                            ├── iobroker.flot@1.12.0
                                            ├── iobroker.fritzbox@0.6.0
                                            ├── iobroker.fritzdect@2.5.11
                                            ├── iobroker.heos@2.2.1
                                            ├── iobroker.history@3.0.1
                                            ├── iobroker.homeconnect@1.4.1
                                            ├── iobroker.hue@3.12.0
                                            ├── iobroker.ical@1.15.0
                                            ├── iobroker.icons-fatcow-hosting@0.1.0
                                            ├── iobroker.icons-icons8@0.0.1
                                            ├── iobroker.icons-material-png@0.1.0
                                            ├── iobroker.icons-mfd-svg@1.2.0
                                            ├── iobroker.influxdb@4.0.2
                                            ├── iobroker.innogy-smarthome@1.2.6
                                            ├── iobroker.iot@3.3.0
                                            ├── iobroker.iqontrol@2.3.0
                                            ├── iobroker.jarvis@3.1.8
                                            ├── iobroker.javascript@8.7.6
                                            ├── iobroker.js-controller@6.0.11
                                            ├── iobroker.lovelace@4.1.10
                                            ├── iobroker.material@1.3.1
                                            ├── iobroker.meross@1.17.0
                                            ├── iobroker.mqtt@5.2.0
                                            ├── iobroker.net-tools@1.0.11
                                            ├── iobroker.node-red@5.2.1
                                            ├── iobroker.openweathermap@1.1.2
                                            ├── iobroker.parser@2.2.2
                                            ├── iobroker.pushover@4.1.0
                                            ├── iobroker.pvforecast@3.0.0
                                            ├── iobroker.ring@5.1.0
                                            ├── iobroker.rpi2@1.3.2
                                            ├── iobroker.simple-api@2.8.0
                                            ├── iobroker.socketio@6.7.1
                                            ├── iobroker.systeminfo@1.2.0
                                            ├── iobroker.text2command@3.0.3
                                            ├── iobroker.tr-064@4.3.0
                                            ├── iobroker.trashschedule@3.3.0
                                            ├── iobroker.tuya@3.16.0
                                            ├── iobroker.vis-2-widgets-energy@1.0.0
                                            ├── iobroker.vis-2-widgets-gauges@1.1.0
                                            ├── iobroker.vis-2-widgets-material@1.4.8
                                            ├── iobroker.vis-2@2.9.32
                                            ├── iobroker.vis-bars@0.1.4
                                            ├── iobroker.vis-canvas-gauges@1.0.1
                                            ├── iobroker.vis-colorpicker@2.0.3
                                            ├── iobroker.vis-fancyswitch@1.1.0
                                            ├── iobroker.vis-history@1.0.0
                                            ├── iobroker.vis-hqwidgets@1.5.1
                                            ├── iobroker.vis-icontwo@1.5.0
                                            ├── iobroker.vis-inventwo@3.3.4
                                            ├── iobroker.vis-jqui-mfd@1.1.1
                                            ├── iobroker.vis-justgage@2.1.7
                                            ├── iobroker.vis-map@1.1.2
                                            ├── iobroker.vis-material-advanced@1.7.4
                                            ├── iobroker.vis-material@0.1.3
                                            ├── iobroker.vis-materialdesign@0.5.9
                                            ├── iobroker.vis-metro@1.2.0
                                            ├── iobroker.vis-timeandweather@1.2.2
                                            ├── iobroker.vis@1.5.6
                                            ├── iobroker.web@6.2.5
                                            └── iobroker.ws@2.6.2
                                            pi@raspberrypi:/opt/iobroker $
                                            1266
