    3. Off Topic
    4. Pflege des Betriebssystems
    5. Hilfe die Disk ist voll
    • mcm1957
      mcm1957 @Uwe Waizmann last edited by
      @uwe-waizmann
      DANKE - aber bitte um die LANGFASSUNG. Die wird vor der Zusammenfassung angezeigt
      Uwe Waizmann 1 Reply Last reply Reply Quote 0
      • Uwe Waizmann
        Uwe Waizmann @mcm1957 last edited by
        @mcm1957
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: whome
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 32 bit
        Systemuptime and Load:
         16:44:48 up 45 min,  2 users,  load average: 0.31, 0.40, 0.52
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-09-14 16:44:48 CEST
                   Universal time: Sat 2024-09-14 14:44:48 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            7.8G        1.1G        5.4G        3.0M        1.3G        6.6G
        Swap:            56M          0B         56M
        Total:          7.9G        1.1G        5.5G
        Active iob-Instances:   20
                 7811 M total memory
                 1114 M used memory
                 1213 M active memory
                  602 M inactive memory
                 5415 M free memory
                  268 M buffer memory
                 1012 M swap cache
                   56 M total swap
                    0 M used swap
                   56 M free swap
        top - 16:44:48 up 45 min,  2 users,  load average: 0.31, 0.40, 0.52
        Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7811.3 total,   5415.3 free,   1115.0 used,   1281.0 buff/cache
        MiB Swap:     57.0 total,     57.0 free,      0.0 used.   6570.9 avail Mem
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * isc-dhcp-server.service loaded failed failed LSB: DHCP server
        * log2ram.service         loaded failed failed Log2Ram
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       15G   14G   35M 100% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
        /dev/sda1      vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
        [Sat Sep 14 15:59:21 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:EE:BA:65 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=804a9e20-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sat Sep 14 15:59:25 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Sat Sep 14 15:59:25 2024] EXT4-fs (sda2): write access will be enabled during recovery
        [Sat Sep 14 15:59:26 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
        [Sat Sep 14 15:59:26 2024] EXT4-fs (sda2): 5 orphan inodes deleted
        [Sat Sep 14 15:59:26 2024] EXT4-fs (sda2): recovery complete
        [Sat Sep 14 15:59:26 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Sep 14 15:59:26 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sat Sep 14 15:59:30 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                          SOURCE      FSTYPE      OPTIONS
        /                               /dev/sda2   ext4        rw,noatime
        |-/dev                          devtmpfs    devtmpfs    rw,relatime,size=3735168k,nr_inodes=933792,mode=755
        | |-/dev/shm                    tmpfs       tmpfs       rw,nosuid,nodev
        | |-/dev/pts                    devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                 mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
        |-/proc                         proc        proc        rw,relatime
        | `-/proc/sys/fs/binfmt_misc    systemd-1   autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |   `-/proc/sys/fs/binfmt_misc  binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/sys                          sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security        securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup              cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore              pstore      pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                 bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/tracing         tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/debug           debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
        | | `-/sys/kernel/debug/tracing tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/fuse/connections    fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
        | `-/sys/kernel/config          configfs    configfs    rw,nosuid,nodev,noexec,relatime
        |-/run                          tmpfs       tmpfs       rw,nosuid,nodev,size=1599760k,nr_inodes=819200,mode=755
        | |-/run/lock                   tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs             sunrpc      rpc_pipefs  rw,relatime
        | `-/run/user/1000              tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=799876k,nr_inodes=199969,mode=700,uid=1000,gid=1000
        `-/boot                         /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        6.0G    /var/
        3.4G    /var/cache/apt
        3.4G    /var/cache
        3.3G    /var/cache/apt/archives
        1.5G    /var/log/journal/97c404ce9aca44939722b7a9f9be5de6
        Archived and active journals take up 1.4G in the file system.
        /opt/iobroker/backups:
        89M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        574M    /opt/iobroker/iobroker-data/
        441M    /opt/iobroker/iobroker-data/files
        142M    /opt/iobroker/iobroker-data/files/vis-2
        139M    /opt/iobroker/iobroker-data/files/javascript.admin
        118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        27M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        Temp directories causing npm8 problem: 28
        Some problems detected, please run iob fix
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          6.17.14
        javascript:     8.3.1
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : whome                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : whome                                    -  enabled
          system.adapter.chromecast.0             : chromecast            : whome                                    - disabled
        + system.adapter.cloud.0                  : cloud                 : whome                                    -  enabled
          system.adapter.daswetter.0              : daswetter             : whome                                    - disabled
          system.adapter.devices.0                : devices               : whome                                    -  enabled
        + system.adapter.discovery.0              : discovery             : whome                                    -  enabled
          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : whome                                    - disabled
        + system.adapter.followthesun.0           : followthesun          : whome                                    -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : whome                                    -  enabled
        + system.adapter.info.0                   : info                  : whome                                    -  enabled
        + system.adapter.javascript.0             : javascript            : whome                                    -  enabled
          system.adapter.lovelace.0               : lovelace              : whome                                    - disabled, port: 8093, bind: 0.0.0.0, run as: admin
        + system.adapter.melcloud.0               : melcloud              : whome                                    -  enabled
          system.adapter.midea.0                  : midea                 : whome                                    - disabled
        + system.adapter.mqtt.0                   : mqtt                  : whome                                    -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.mqtt.1                   : mqtt                  : whome                                    - disabled, port: 1883, bind: 0.0.0.0
          system.adapter.mqtt.2                   : mqtt                  : whome                                    - disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.node-red.0               : node-red              : whome                                    -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.ping.0                   : ping                  : whome                                    -  enabled
          system.adapter.sayit.0                  : sayit                 : whome                                    - disabled
        + system.adapter.shelly.0                 : shelly                : whome                                    -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : whome                                    -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : whome                                    -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.telegram.0               : telegram              : whome                                    - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.telegram.1               : telegram              : whome                                    - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.telegram.2               : telegram              : whome                                    - disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : whome                                    -  enabled
        + system.adapter.tuya.0                   : tuya                  : whome                                    -  enabled
          system.adapter.vis-2.0                  : vis-2                 : whome                                    - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : whome                                    -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : whome                                    -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : whome                                    -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : whome                                    -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : whome                                    -  enabled
          system.adapter.vis-metro.0              : vis-metro             : whome                                    -  enabled
          system.adapter.vis-weather.0            : vis-weather           : whome                                    -  enabled
          system.adapter.vis.0                    : vis                   : whome                                    -  enabled
        + system.adapter.web.0                    : web                   : whome                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.web.1                    : web                   : whome                                    -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        List is empty
        Installed ioBroker-Instances
        Error: Object "system.repositories" not found
        Objects and States
        Objects:        5365
        States:         4187
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14201      573/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       34222      2637/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       34217      2637/iobroker.js-co
        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14210      627/vncserver-x11-c
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       107613     2856/io.shelly.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      117        12267      598/mosquitto
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       106161     2728/node-red
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       106849     2811/io.sonoff.0
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      116        14104      582/redis-server 12
        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      115        16681      675/mariadbd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15427      628/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       107348     3055/io.web.0
        tcp6       0      0 :::8083                 :::*                    LISTEN      1001       109967     3151/io.web.1
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34256      2655/io.admin.0
        tcp6       0      0 ::1:6379                :::*                    LISTEN      116        14105      582/redis-server 12
        tcp6       0      0 :::5900                 :::*                    LISTEN      0          14209      627/vncserver-x11-c
        tcp6       0      0 :::1883                 :::*                    LISTEN      117        12268      598/mosquitto
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14200      573/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15429      628/sshd: /usr/sbin
        tcp6       0      0 :::80                   :::*                    LISTEN      0          14285      847/apache2
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15569      720/cups-browsed
        udp        0      0 0.0.0.0:45736           0.0.0.0:*                           108        2018       419/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2016       419/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       106235     2794/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       106962     2840/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       106963     2840/io.tuya.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14123      467/dhcpcd
        udp6       0      0 :::546                  :::*                                0          15323      467/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        2017       419/avahi-daemon: r
        udp6       0      0 :::51145                :::*                                108        2019       419/avahi-daemon: r
        2024-09-14 16:33:30.258  - info: admin.0 (2655) ==> Connected system.user.admin from ::ffff:192.168.1.63
        2024-09-14 16:41:10.393  - info: web.1 (3151) ==> Connected system.user.admin from ::ffff:192.168.1.63
        2024-09-14 16:41:14.508  - info: web.1 (3151) ==> Connected system.user.admin from ::ffff:192.168.1.63
        2024-09-14 16:41:37.852  - info: web.1 (3151) ==> Connected system.user.admin from ::ffff:192.168.1.33
        2024-09-14 16:42:12.805  - info: admin.0 (2655) <== Disconnect system.user.admin from ::ffff:192.168.1.63
        2024-09-14 16:42:12.939  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:13.058  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:13.298  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:13.538  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:13.779  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:14.023  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:14.262  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:14.503  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:14.744  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:14.982  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:15.225  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:15.470  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:15.711  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:15.953  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:16.196  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:16.440  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:16.683  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:16.927  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:17.171  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        2024-09-14 16:42:17.412  - warn: admin.0 (2655) Cannot read file ("admin.admin"/"admin.png"): Not exists
        iob diag has finished.
        Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Uwe Waizmann last edited by Thomas Braun
          @uwe-waizmann sagte in Hilfe die Disk ist voll:
          Wie kann ich herrausfinden was gelöscht werden kann?
          Indem du in die Verzeichnisse mit den dicken Dingern einsteigst und schaust was da genau drin liegt.
          • Ro75
            Ro75 @Uwe Waizmann last edited by
            [Sat Sep 14 15:59:26 2024] EXT4-fs (sda2): 5 orphan inodes deleted [Sat Sep 14 15:59:26 2024] EXT4-fs (sda2): recovery complete
            Das Dateisystem und / oder der Datenträger hat einen treffer. Neuinstallation, ggfs. mit neuem Datenträger.
            Ro75.
              @uwe-waizmann
              Du könntest das aber auch als Anlass nehmen die Kiste mit 'Raspberry OS 12 (Bookworm)' komplett neuaufzusetzen, diesmal dann in der reinen 64Bit-Version.
              Musst du früher oder später eh machen, dann kannst du das auch jetzt in Angriff nehmen.
              • Uwe Waizmann
                Uwe Waizmann @Thomas Braun last edited by
                Also Backup vom IOB machen,
                System neu aufsetzen mit bookwoorm
                dann restore vom iob?
                Thomas Braun Ro75 2 Replies Last reply Reply Quote 0
                  Nein, vorhandenes Backup herauskramen.
                  Jetzt würdest du ja nur die kaputten Dateien speichern.
                  • Ro75
                    @uwe-waizmann Benutze bitte einen neuen Datenträger. Das Dateisystem hat nen Treffer. Ein Backup daraus kann defekt sein. Wenn du dann den Datenträger neu bespielst und das Backup einspielst, hast du ggfs. gar nichts mehr.
                    Ro75.
                      Thomas Braun Most Active @Ro75 last edited by
                      @ro75 sagte in Hilfe die Disk ist voll:
                      Der dann auch gerne größer als 16GB sein darf.
                      • Uwe Waizmann
                        Also Backup von gestern oder früher?
                        Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
                          Von 'vor dem Einschlag im Dateisystem'.
                          • Uwe Waizmann
                            @thomas-braun said in Hilfe die Disk ist voll:
                            Hab das Problem ja erst heute bemerkt nach dem Update.
                            Kann also nicht sagen wann das war,
                            Sehe gerade, auf der Disk sind 120GB hab ich wohl mal partitioniert, weis aber nicht mehr warum. war bestimmt damit es auf einer SD noch Platz hatte.
                            • OliverIO
                              OliverIO @Uwe Waizmann last edited by
                              @uwe-waizmann
                              Wenn du eine sd Karte kaufst, dann ruhig eine die etwas teuerer ist.
                              Also solche die pro, extreme, endurance,sdxc,sdhc oder Ultra im Namen haben.
                              Die sind dann meist auch etwas schneller.
                              Systembedingt ist es auch gut eine sd Karte nicht ganz voll zu machen (75%?) dann bleibt noch genügend Platz um defekte Blöcke zu ersetzen.
                              • OliverIO
                                OliverIO @Uwe Waizmann last edited by OliverIO
                                @uwe-waizmann
                                Ah ok, du bootest bereits von einer ssd, sehr gut.
                                Dann ist wahrscheinlich kein „physischer“ Schaden.
                                Nur ein logischer, der passieren kann wenn man linux hart ausschaltet.
                                Aber dann kannst dir auch die Smart Daten mal anschauen, wie der Status der ssd ist.
                                • Uwe Waizmann
                                  Uwe Waizmann @OliverIO last edited by
                                  Super vielen Dank für Eure schnelle Hilfe,
                                  Wie kann ich mir die Smart Daten anschauen?
                                  Gibt es einen kleinen Leitfaden wie man schnell und einfach ein neues System aufsetzen kann?
                                  Ist schon eine nette Weile her als ich das das letzte mal gemacht habe.
                                    @uwe-waizmann
                                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                      Homoran Global Moderator Administrators @Uwe Waizmann last edited by
                                      Jetzt ist die Platte voll und ich hab keine Ahnung was die 14 Gig vollgemacht hat.
                                      und das ist ein Bug von ioBroker?
                                      • OliverIO
                                        @uwe-waizmann
                                        Hier eine Übersicht für Debian artige
                                        https://wiki.ubuntuusers.de/Festplattenstatus/
                                        Paket nennt sich smartmontools
                                        • Meister Mopper
                                          Meister Mopper @Homoran last edited by
                                          @homoran sagte in Hilfe die Disk ist voll:
                                          Vielleicht schiebst du die offtopic-Kategorie und das topic zum Betriebssystem mal an Pos1.
                                          Der Mensch neigt dazu, beim Lesen von Anfang bis zum Ende die Geduld zu verlieren 🤷‍♂️ .
                                            Homoran Global Moderator Administrators @Meister Mopper last edited by Homoran
                                            @meister-mopper sagte in Hilfe die Disk ist voll:
                                            Sorry, aber ich verstehe nicht was du gerade von mir willst.
                                            Ehrlich!
                                            Hab zwar einen Verdacht, aber bei der Überprüfung nur festgestellt dass der Thread hier sogar im englischen Forum ist.
                                            1.0k
                                            81.1k
                                            56
                                            8090
