    4. Victron Smartmeter ET340 wie per RS485 auslesen
      Homoran Global Moderator Administrators @hg6806 last edited by
      @hg6806 ich glaube du musst due Hex Adresse in Dezimal umrechnen und dann eintragen
      • hg6806
        hg6806 Most Active last edited by
        Du meinst du physik. Adressen wahrscheinlich.
        Wenn ich das tue, verschwinden die Werte komplett.
          @hg6806 sagte in Victron Smartmeter ET340 wie per RS485 auslesen:
          Wenn ich das tue,
          zeigen!
          passiert das such wenn du Alias verwenden anhakst?
          was steht im debug-log?
          • hg6806
            hg6806 Most Active @Homoran last edited by
            So ist es eingestellt:
            Und das ist das Log:
            v7.0.23
            Log-Größe: 5.8 KB
            modbus.6
            Zeit
            debug
            Nachricht
            modbus.6
            2024-09-14 13:24:04.750	debug	Cleaning up request fifo.
            modbus.6
            2024-09-14 13:24:04.749	debug	Clearing timeout of the current request.
            modbus.6
            2024-09-14 13:24:04.748	info	Disconnected from slave
            modbus.6
            2024-09-14 13:24:03.747	warn	[1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
            modbus.6
            2024-09-14 13:24:03.746	error	Request timed out.
            modbus.6
            2024-09-14 13:24:03.746	warn	Error: undefined
            modbus.6
            2024-09-14 13:23:58.742	debug	[DevID_1/disInputs] Poll address 0 - 0 bits
            modbus.6
            2024-09-14 13:23:58.741	debug	[DevID_1] Poll start ---------------------
            modbus.6
            2024-09-14 13:23:58.741	info	Connected to slave
            modbus.6
            2024-09-14 13:23:58.727	debug	connect to serial /dev/ttyUSB2 with 38400
            modbus.6
            2024-09-14 13:23:58.524	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
            modbus.6
            2024-09-14 13:23:58.523	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
            modbus.6
            2024-09-14 13:23:58.326	debug	Initialize Objects for holdingRegs: []
            modbus.6
            2024-09-14 13:23:58.326	debug	Add inputRegisters.300052_Hz: {"_id":"inputRegisters.300052_Hz","type":"state","common":{"name":"Hz","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"Hz"},"native":{"regType":"inputRegs","address":270051,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":10}}
            modbus.6
            2024-09-14 13:23:58.326	debug	Add inputRegisters.300001_V_L1-N: {"_id":"inputRegisters.300001_V_L1-N","type":"state","common":{"name":"V L1-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":270000,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":0.1}}
            modbus.6
            2024-09-14 13:23:58.326	debug	Add undefined: {"type":"state","common":{"name":"V L3-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":-29997,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":"10"}}
            modbus.6
            2024-09-14 13:23:58.326	error	Invalid object: {"type":"state","common":{"name":"V L3-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":-29997,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":"10"}}
            modbus.6
            2024-09-14 13:23:58.326	error	Invalid data inputRegisters/1: {"_address":4,"deviceId":1,"name":"V L3-N","description":"V L3-N","unit":"V","type":"int32be","len":2,"factor":"10","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-29997,"fullId":"modbus.6.1"}
            modbus.6
            2024-09-14 13:23:58.325	debug	Add undefined: {"type":"state","common":{"name":"V L2-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":-29999,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":"0.1"}}
            modbus.6
            2024-09-14 13:23:58.325	error	Invalid object: {"type":"state","common":{"name":"V L2-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":-29999,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":"0.1"}}
            modbus.6
            2024-09-14 13:23:58.325	error	Invalid data inputRegisters/0: {"_address":2,"deviceId":1,"name":"V L2-N","description":"V L2-N","unit":"V","type":"int32be","len":2,"factor":"0.1","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-29999,"fullId":"modbus.6.0"}
            modbus.6
            2024-09-14 13:23:58.324	debug	Initialize Objects for inputRegs: [{"_address":2,"deviceId":1,"name":"V L2-N","description":"V L2-N","unit":"V","type":"int32be","len":2,"factor":"0.1","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-29999},{"_address":4,"deviceId":1,"name":"V L3-N","description":"V L3-N","unit":"V","type":"int32be","len":2,"factor":"10","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-29997},{"_address":300001,"deviceId":1,"name":"V L1-N","description":"V L1-N","unit":"V","type":"int32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":270000,"id":"inputRegisters.300001_V_L1-N"},{"_address":300052,"name":"Hz","description":"Hz","unit":"Hz","type":"uint16be","len":1,"factor":10,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","deviceId":1,"address":270051,"id":"inputRegisters.300052_Hz"}]
            modbus.6
            2024-09-14 13:23:58.324	debug	Initialize Objects for coils: []
            modbus.6
            2024-09-14 13:23:58.324	debug	Add discreteInputs.10016: {"_id":"discreteInputs.10016","type":"state","common":{"name":"","role":"level","type":"boolean","read":true,"write":false,"def":false},"native":{"regType":"disInputs","address":0,"deviceId":1}}
            modbus.6
            2024-09-14 13:23:58.324	debug	Initialize Objects for disInputs: [{"_address":10014,"deviceId":1,"name":"","description":"","formula":"","role":"level","room":"","cw":"","isScale":"","address":0,"id":"discreteInputs.10016","len":1}]
            modbus.6
            2024-09-14 13:23:58.323	error	Invalid inputRegisters address: -29999
            modbus.6
            2024-09-14 13:23:58.322	error	Invalid inputRegisters address: -29997
            modbus.6
            2024-09-14 13:23:58.121	info	starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.15.1, js-controller: 6.0.11
            modbus.6
            2024-09-14 13:23:57.863	debug	Plugin sentry Initialize Plugin (enabled=true)
            modbus.6
            2024-09-14 13:23:53.088	info	terminating
            modbus.6
            2024-09-14 13:23:52.586	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            modbus.6
            2024-09-14 13:23:52.586	debug	Plugin sentry destroyed
            modbus.6
            2024-09-14 13:23:52.585	info	terminating
            modbus.6
            2024-09-14 13:23:52.583	info	Got terminate signal TERMINATE_YOURSELF
              bitte nur ein Register bis es läuft.
              sobald auch nur ein Fehler in der Liste ist kommt gar kein Wert!
              das kann man jetzt nicht zuordnen!
              Hier sieht man mehr
                                      2024-09-14 13:23:58.324	debug	Initialize Objects for inputRegs: [{"**_address":2,"**deviceId":1,"name":"V L2-N","description":"V L2-N","unit":"V","type":"int32be","len":2,"factor":"0.1","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","**address":-29999}**,{"_address":4,"deviceId":1,"name":"V L3-N","description":"V L3-N","unit":"V","type":"int32be","len":2,"factor":"10","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-29997},{"_address":300001,"deviceId":1,"name":"V L1-N","description":"V L1-N","unit":"V","type":"int32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":270000,"id":"inputRegisters.300001_V_L1-N"},{"_address":300052,"name":"Hz","description":"Hz","unit":"Hz","type":"uint16be","len":1,"factor":10,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","deviceId":1,"address":270051,"id":"inputRegisters.300052_Hz"}]
              bitte nur mit einer hardware Adresse arbeiten und dann mal mit und ohne Aluas probieren.
              Hier wird beides umgerechnet. Adressen mit 6 Stellen sind mir (und anscheinend auch dem Adapter) unbekannt
              • hg6806
                ...kam von der eingetragenen phy. Adr. "2"
                Jetzt nochmal reduziert auf:
                Hier das Log nach der Ruduktion:
                v7.0.23
                Log-Größe: 845.4 KB
                modbus.6
                Zeit
                debug
                Nachricht
                modbus.6
                2024-09-14 14:20:59.283	debug	Cleaning up request fifo.
                modbus.6
                2024-09-14 14:20:59.283	debug	Clearing timeout of the current request.
                modbus.6
                2024-09-14 14:20:59.280	info	Disconnected from slave
                modbus.6
                2024-09-14 14:20:58.280	warn	[1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                modbus.6
                2024-09-14 14:20:58.279	error	Request timed out.
                modbus.6
                2024-09-14 14:20:58.279	warn	Error: undefined
                modbus.6
                2024-09-14 14:20:53.275	debug	[DevID_1/disInputs] Poll address 0 - 0 bits
                modbus.6
                2024-09-14 14:20:53.274	debug	[DevID_1] Poll start ---------------------
                modbus.6
                2024-09-14 14:20:53.273	info	Connected to slave
                modbus.6
                2024-09-14 14:20:53.259	debug	connect to serial /dev/ttyUSB2 with 38400
                modbus.6
                2024-09-14 14:20:52.940	debug	Initialize Objects for holdingRegs: []
                modbus.6
                2024-09-14 14:20:52.940	debug	Add inputRegisters.300001_V_L1-N: {"_id":"inputRegisters.300001_V_L1-N","type":"state","common":{"name":"V L1-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":270000,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":0.1}}
                modbus.6
                2024-09-14 14:20:52.939	debug	Initialize Objects for inputRegs: [{"_address":300001,"deviceId":1,"name":"V L1-N","description":"V L1-N","unit":"V","type":"int32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":270000,"id":"inputRegisters.300001_V_L1-N"}]
                modbus.6
                2024-09-14 14:20:52.939	debug	Initialize Objects for coils: []
                modbus.6
                2024-09-14 14:20:52.939	debug	Add discreteInputs.10016: {"_id":"discreteInputs.10016","type":"state","common":{"name":"","role":"level","type":"boolean","read":true,"write":false,"def":false},"native":{"regType":"disInputs","address":0,"deviceId":1}}
                modbus.6
                2024-09-14 14:20:52.938	debug	Initialize Objects for disInputs: [{"_address":10014,"deviceId":1,"name":"","description":"","formula":"","role":"level","room":"","cw":"","isScale":"","address":0,"id":"discreteInputs.10016","len":1}]
                modbus.6
                2024-09-14 14:20:52.715	info	starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.15.1, js-controller: 6.0.11
                modbus.6
                2024-09-14 14:20:52.506	debug	Plugin sentry Initialize Plugin (enabled=true)
                modbus.6
                2024-09-14 14:20:52.259	debug	States create User PubSub Client
                modbus.6
                2024-09-14 14:20:52.258	debug	States create System PubSub Client
                modbus.6
                2024-09-14 14:20:52.160	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                modbus.6
                2024-09-14 14:20:52.041	debug	Objects connected to redis: 127.0.0.1:9001
                modbus.6
                2024-09-14 14:20:51.982	debug	Objects client initialize lua scripts
                modbus.6
                2024-09-14 14:20:51.771	debug	Objects create User PubSub Client
                modbus.6
                2024-09-14 14:20:51.770	debug	Objects create System PubSub Client
                modbus.6
                2024-09-14 14:20:51.728	debug	Objects client ready ... initialize now
                modbus.6
                2024-09-14 14:20:51.667	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                modbus.6
                2024-09-14 14:20:12.588	info	terminating
                modbus.6
                2024-09-14 14:20:12.087	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                modbus.6
                2024-09-14 14:20:12.086	debug	Plugin sentry destroyed
                modbus.6
                2024-09-14 14:20:12.086	info	terminating
                modbus.6
                2024-09-14 14:20:12.084	info	Got terminate signal TERMINATE_YOURSELF
                modbus.6
                2024-09-14 14:19:56.121	debug	Cleaning up request fifo.
                modbus.6
                2024-09-14 14:19:56.120	debug	Clearing timeout of the current request.
                modbus.6
                2024-09-14 14:19:56.118	info	Disconnected from slave
                modbus.6
                2024-09-14 14:19:55.117	warn	[1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                modbus.6
                2024-09-14 14:19:55.117	error	Request timed out.
                modbus.6
                2024-09-14 14:19:55.116	warn	Error: undefined
                modbus.6
                2024-09-14 14:19:50.114	debug	[DevID_1/disInputs] Poll address 0 - 0 bits
                modbus.6
                2024-09-14 14:19:50.113	debug	[DevID_1] Poll start ---------------------
                modbus.6
                2024-09-14 14:19:50.113	info	Connected to slave
                modbus.6
                2024-09-14 14:19:50.101	debug	connect to serial /dev/ttyUSB2 with 38400
                modbus.6
                2024-09-14 14:19:49.889	debug	Remove old object modbus.6.inputRegisters.300052_Hz
                modbus.6
                2024-09-14 14:19:49.838	debug	Initialize Objects for holdingRegs: []
                modbus.6
                2024-09-14 14:19:49.838	debug	Add inputRegisters.300001_V_L1-N: {"_id":"inputRegisters.300001_V_L1-N","type":"state","common":{"name":"V L1-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":270000,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":0.1}}
                modbus.6
                2024-09-14 14:19:49.838	debug	Initialize Objects for inputRegs: [{"_address":300001,"deviceId":1,"name":"V L1-N","description":"V L1-N","unit":"V","type":"int32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":270000,"id":"inputRegisters.300001_V_L1-N"}]
                modbus.6
                2024-09-14 14:19:49.838	debug	Initialize Objects for coils: []
                modbus.6
                2024-09-14 14:19:49.837	debug	Add discreteInputs.10016: {"_id":"discreteInputs.10016","type":"state","common":{"name":"","role":"level","type":"boolean","read":true,"write":false,"def":false},"native":{"regType":"disInputs","address":0,"deviceId":1}}
                modbus.6
                2024-09-14 14:19:49.837	debug	Initialize Objects for disInputs: [{"_address":10014,"deviceId":1,"name":"","description":"","formula":"","role":"level","room":"","cw":"","isScale":"","address":0,"id":"discreteInputs.10016","len":1}]
                modbus.6
                2024-09-14 14:19:49.637	info	starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.15.1, js-controller: 6.0.11
                modbus.6
                2024-09-14 14:19:49.355	debug	Plugin sentry Initialize Plugin (enabled=true)
                modbus.6
                2024-09-14 14:19:49.278	debug	States connected to redis: 127.0.0.1:9000
                modbus.6
                2024-09-14 14:19:49.178	debug	States create User PubSub Client
                modbus.6
                2024-09-14 14:19:49.178	debug	States create System PubSub Client
                modbus.6
                2024-09-14 14:19:49.123	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                modbus.6
                2024-09-14 14:19:49.042	debug	Objects connected to redis: 127.0.0.1:9001
                modbus.6
                2024-09-14 14:19:49.036	debug	Objects client initialize lua scripts
                modbus.6
                2024-09-14 14:19:48.879	debug	Objects create User PubSub Client
                modbus.6
                2024-09-14 14:19:48.878	debug	Objects create System PubSub Client
                modbus.6
                2024-09-14 14:19:48.832	debug	Objects client ready ... initialize now
                modbus.6
                2024-09-14 14:19:48.766	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                modbus.6
                2024-09-14 14:19:44.458	info	terminating
                modbus.6
                2024-09-14 14:19:43.957	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                modbus.6
                2024-09-14 14:19:43.957	debug	Plugin sentry destroyed
                modbus.6
                2024-09-14 14:19:43.956	info	terminating
                modbus.6
                2024-09-14 14:19:43.955	info	Got terminate signal TERMINATE_YOURSELF
                modbus.6
                2024-09-14 14:19:43.770	debug	Cleaning up request fifo.
                modbus.6
                2024-09-14 14:19:43.770	debug	Clearing timeout of the current request.
                modbus.6
                2024-09-14 14:19:43.768	info	Disconnected from slave
                modbus.6
                2024-09-14 14:19:42.767	warn	[1] Poll error count: 3 code: {"err":"timeout","timeout":5000}
                modbus.6
                2024-09-14 14:19:42.767	error	Request timed out.
                modbus.6
                2024-09-14 14:19:42.766	warn	Error: undefined
                modbus.6
                2024-09-14 14:19:37.765	debug	[DevID_1/disInputs] Poll address 0 - 0 bits
                modbus.6
                2024-09-14 14:19:37.765	debug	[DevID_1] Poll start ---------------------
                modbus.6
                2024-09-14 14:19:37.765	info	Connected to slave
                modbus.6
                2024-09-14 14:19:37.754	debug	connect to serial /dev/ttyUSB2 with 38400
                Mit und ohne Aliases ausprobiert.
                Muss ich noch eine Geräte-ID eintragen? Steht noch auf 1
                  Natürlich wenn dein Energymeter nicht die ID1 hat.
                  aber die könnte stimmen.
                  du sollst nicht die sechsstrllige nehmen!!!
                  • hg6806
                    hg6806 Most Active @Homoran last edited by hg6806
                    Nur die sechstellige funktioniert!
                    Hier ein Log mit der Phy. Adresse:
                    v7.0.23
                    Log-Größe: 2.3 MB
                    modbus.6
                    Zeit
                    debug
                    Nachricht
                    modbus.6
                    2024-09-14 16:38:41.122	debug	[DevID_1/disInputs] Poll address 0 - 0 bits
                    modbus.6
                    2024-09-14 16:38:41.121	debug	[DevID_1] Poll start ---------------------
                    modbus.6
                    2024-09-14 16:38:41.121	info	Connected to slave
                    modbus.6
                    2024-09-14 16:38:41.108	debug	connect to serial /dev/ttyUSB2 with 38400
                    modbus.6
                    2024-09-14 16:38:41.032	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                    modbus.6
                    2024-09-14 16:38:40.873	debug	Initialize Objects for holdingRegs: []
                    modbus.6
                    2024-09-14 16:38:40.872	debug	Add undefined: {"type":"state","common":{"name":"V L1-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":-30001,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":"0.1"}}
                    modbus.6
                    2024-09-14 16:38:40.871	error	Invalid object: {"type":"state","common":{"name":"V L1-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":-30001,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":"0.1"}}
                    modbus.6
                    2024-09-14 16:38:40.871	error	Invalid data inputRegisters/0: {"_address":"0","deviceId":1,"name":"V L1-N","description":"V L1-N","unit":"V","type":"int32be","len":2,"factor":"0.1","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-30001,"fullId":"modbus.6.0"}
                    modbus.6
                    2024-09-14 16:38:40.871	debug	Initialize Objects for inputRegs: [{"_address":"0","deviceId":1,"name":"V L1-N","description":"V L1-N","unit":"V","type":"int32be","len":2,"factor":"0.1","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-30001}]
                    modbus.6
                    2024-09-14 16:38:40.871	debug	Initialize Objects for coils: []
                    modbus.6
                    2024-09-14 16:38:40.870	debug	Add discreteInputs.10016: {"_id":"discreteInputs.10016","type":"state","common":{"name":"","role":"level","type":"boolean","read":true,"write":false,"def":false},"native":{"regType":"disInputs","address":0,"deviceId":1}}
                    modbus.6
                    2024-09-14 16:38:40.869	debug	Initialize Objects for disInputs: [{"_address":10014,"deviceId":1,"name":"","description":"","formula":"","role":"level","room":"","cw":"","isScale":"","address":0,"id":"discreteInputs.10016","len":1}]
                    modbus.6
                    2024-09-14 16:38:40.868	error	Invalid inputRegisters address: -30001
                    modbus.6
                    2024-09-14 16:38:40.611	info	starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.15.1, js-controller: 6.0.11
                    modbus.6
                    2024-09-14 16:38:40.039	debug	Plugin sentry Initialize Plugin (enabled=true)
                    modbus.6
                    2024-09-14 16:38:39.941	debug	States connected to redis: 127.0.0.1:9000
                    modbus.6
                    2024-09-14 16:38:39.759	debug	States create User PubSub Client
                    modbus.6
                    2024-09-14 16:38:39.758	debug	States create System PubSub Client
                    modbus.6
                    2024-09-14 16:38:39.653	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                    modbus.6
                    2024-09-14 16:38:39.573	debug	Objects connected to redis: 127.0.0.1:9001
                    modbus.6
                    2024-09-14 16:38:39.569	debug	Objects client initialize lua scripts
                    modbus.6
                    2024-09-14 16:38:39.407	debug	Objects create User PubSub Client
                    modbus.6
                    2024-09-14 16:38:39.406	debug	Objects create System PubSub Client
                    modbus.6
                    2024-09-14 16:38:39.360	debug	Objects client ready ... initialize now
                    modbus.6
                    2024-09-14 16:38:39.300	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                    modbus.6
                    2024-09-14 16:38:18.759	info	terminating
                    modbus.6
                    2024-09-14 16:38:18.258	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    modbus.6
                    2024-09-14 16:38:18.257	debug	Plugin sentry destroyed
                    modbus.6
                    2024-09-14 16:38:18.257	info	terminating
                    modbus.6
                    2024-09-14 16:38:18.256	info	Got terminate signal TERMINATE_YOURSELF
                    modbus.6
                    2024-09-14 16:37:47.001	debug	Cleaning up request fifo.
                    modbus.6
                    2024-09-14 16:37:47.001	debug	Clearing timeout of the current request.
                    modbus.6
                    2024-09-14 16:37:46.999	info	Disconnected from slave
                    modbus.6
                    2024-09-14 16:37:45.999	warn	[1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                    modbus.6
                    2024-09-14 16:37:45.998	error	Request timed out.
                    modbus.6
                    2024-09-14 16:37:45.998	warn	Error: undefined
                    modbus.6
                    2024-09-14 16:37:40.993	debug	[DevID_1/disInputs] Poll address 0 - 0 bits
                    modbus.6
                    2024-09-14 16:37:40.993	debug	[DevID_1] Poll start ---------------------
                    modbus.6
                    2024-09-14 16:37:40.992	info	Connected to slave
                    modbus.6
                    2024-09-14 16:37:40.973	debug	connect to serial /dev/ttyUSB2 with 38400
                    modbus.6
                    2024-09-14 16:37:40.866	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                    modbus.6
                    2024-09-14 16:37:40.703	debug	Remove old object modbus.6.inputRegisters.300001_V_L1-N
                    modbus.6
                    2024-09-14 16:37:40.636	debug	Initialize Objects for holdingRegs: []
                    modbus.6
                    2024-09-14 16:37:40.635	debug	Add undefined: {"type":"state","common":{"name":"V L1-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":-30001,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":"0.1"}}
                    modbus.6
                    2024-09-14 16:37:40.635	error	Invalid object: {"type":"state","common":{"name":"V L1-N","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"V"},"native":{"regType":"inputRegs","address":-30001,"deviceId":1,"type":"int32be","len":2,"offset":0,"factor":"0.1"}}
                    modbus.6
                    2024-09-14 16:37:40.635	error	Invalid data inputRegisters/0: {"_address":"0","deviceId":1,"name":"V L1-N","description":"V L1-N","unit":"V","type":"int32be","len":2,"factor":"0.1","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-30001,"fullId":"modbus.6.0"}
                    modbus.6
                    2024-09-14 16:37:40.634	debug	Initialize Objects for inputRegs: [{"_address":"0","deviceId":1,"name":"V L1-N","description":"V L1-N","unit":"V","type":"int32be","len":2,"factor":"0.1","offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":-30001}]
                    modbus.6
                    2024-09-14 16:37:40.634	debug	Initialize Objects for coils: []
                    modbus.6
                    2024-09-14 16:37:40.634	debug	Add discreteInputs.10016: {"_id":"discreteInputs.10016","type":"state","common":{"name":"","role":"level","type":"boolean","read":true,"write":false,"def":false},"native":{"regType":"disInputs","address":0,"deviceId":1}}
                    modbus.6
                    2024-09-14 16:37:40.632	debug	Initialize Objects for disInputs: [{"_address":10014,"deviceId":1,"name":"","description":"","formula":"","role":"level","room":"","cw":"","isScale":"","address":0,"id":"discreteInputs.10016","len":1}]
                    modbus.6
                    2024-09-14 16:37:40.631	error	Invalid inputRegisters address: -30001
                    modbus.6
                    2024-09-14 16:37:40.336	info	starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.15.1, js-controller: 6.0.11
                    modbus.6
                    2024-09-14 16:37:39.999	debug	Plugin sentry Initialize Plugin (enabled=true)
                    modbus.6
                    2024-09-14 16:37:39.889	debug	States connected to redis: 127.0.0.1:9000
                    modbus.6
                    2024-09-14 16:37:39.711	debug	States create User PubSub Client
                    modbus.6
                    2024-09-14 16:37:39.710	debug	States create System PubSub Client
                    modbus.6
                    2024-09-14 16:37:39.601	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                    modbus.6
                    2024-09-14 16:37:39.515	debug	Objects connected to redis: 127.0.0.1:9001
                    modbus.6
                    2024-09-14 16:37:39.507	debug	Objects client initialize lua scripts
                    modbus.6
                    2024-09-14 16:37:39.356	debug	Objects create User PubSub Client
                    modbus.6
                    2024-09-14 16:37:39.355	debug	Objects create System PubSub Client
                    modbus.6
                    2024-09-14 16:37:39.354	debug	Objects client ready ... initialize now
                    modbus.6
                    2024-09-14 16:37:39.272	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                    modbus.6
                    2024-09-14 16:37:35.035	info	terminating
                    modbus.6
                    2024-09-14 16:37:34.534	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    modbus.6
                    2024-09-14 16:37:34.533	debug	Plugin sentry destroyed
                    modbus.6
                    2024-09-14 16:37:34.533	info	terminating
                    modbus.6
                    2024-09-14 16:37:34.532	info	Got terminate signal TERMINATE_YOURSELF
                    modbus.6
                    2024-09-14 16:36:48.811	debug	Cleaning up request fifo.
                    modbus.6
                    2024-09-14 16:36:48.811	debug	Clearing timeout of the current request.
                    modbus.6
                    2024-09-14 16:36:48.809	info	Disconnected from slave
                    modbus.6
                    2024-09-14 16:36:47.810	warn	[1] Poll error count: 3 code: {"err":"timeout","timeout":5000}
                    modbus.6
                    2024-09-14 16:36:47.809	error	Request timed out.
                    modbus.6
                    2024-09-14 16:36:47.809	warn	Error: undefined
                    modbus.6
                    2024-09-14 16:36:42.809	debug	[DevID_1/disInputs] Poll address 0 - 0 bits
                    modbus.6
                    2024-09-14 16:36:42.809	debug	[DevID_1] Poll start ---------------------
                    modbus.6
                    2024-09-14 16:36:42.808	info	Connected to slave
                    modbus.6
                    2024-09-14 16:36:42.797	debug	connect to serial /dev/ttyUSB2 with 38400
                      Homoran Global Moderator Administrators @hg6806 last edited by Homoran
                      tatsächlich?
                      mit und ohne Alias???
                      • hg6806
                        Das war mit, ohne Alias aber das gleich
                          versteh ich nicht
                          • hg6806
                            Das war mit Alias. Ohne Alias gab es den gleichen Fehler.
                            Ich breche hier ab, da ich gerade festgestellt habe, dass ich an den Abzweig zur Wärmepumpe nicht rankomme, da plombierter Bereich.
                            Der Zähler hatte ich auch nur 1-phasig an ein Kabel angeschlossen. Vielleicht lag es auch daran.
                            Trotzdem Danke.
                              Das kann nicht sein!
                              dann verändern sich die Register um 30000 oder 30001.
                              Die invalid Adress muss sich definitiv ändern.
                              steht bei dir noch was in den discrete Inputs??
                              möglich!
                              an welcher Phase denn? Die anderen sind dann natürlich 0
                              1006
