    4. node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version
    • 15. 05. Wartungsarbeiten am ioBroker Forum
    • Smart_Home
      Smart_Home last edited by
      Hallo zusammen, wollte den JS-Controller updaten. Seitdem funktioniert der Slave nicht mehr und hat sich verabschiedet. Bin über jeden Rat froh.
      Folgender Fehler ist wahrscheinlich der Grund:
      node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
      Beim Master hat das Update ganz normal funktioniert....
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: ioBroker-Slave
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       00:23:33 up 21 min,  1 user,  load average: 0.18, 0.28, 0.25
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      VCHI initialization failed
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      ~ Throttling has occurred
      ~ Soft temperature limit has occurred
      *** Time and Time Zones ***
                     Local time: Sun 2024-09-15 00:23:33 BST
                 Universal time: Sat 2024-09-14 23:23:33 UTC
                       RTC time: n/a
                      Time zone: Europe/London (BST, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      marco
      HOME=/home/marco
      GROUPS=marco sudo iobroker
      js-controller is not running
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G         51M        7.3G        8.0M        512M        7.6G
      Swap:           99M          0B         99M
      Total:         8.0G         51M        7.4G
      Active iob-Instances:   0
               7898 M total memory
                 51 M used memory
                177 M active memory
                319 M inactive memory
               7334 M free memory
                 55 M buffer memory
                457 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 00:23:33 up 21 min,  1 user,  load average: 0.18, 0.28, 0.25
      Tasks: 130 total,   1 running, 129 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  1.5 sy,  0.0 ni, 98.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7898.7 total,   7335.1 free,     50.9 used,    512.7 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7607.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4       30G  4.3G   24G  16% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1001
      [Sun Sep 15 00:01:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D6:F9:35 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=218c65c6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Sun Sep 15 00:01:35 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Sep 15 00:01:35 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Sep 15 00:01:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET                                SOURCE         FSTYPE     OPTIONS
      /                                     /dev/mmcblk0p2 ext4       rw,noatime
      |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=3879288k,nr_inodes=74941,mode=755
      | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
      | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
      |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
      | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
      | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
      | | |-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
      | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
      | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
      | | `-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
      | `-/sys/kernel/config                configfs       configfs   rw,relatime
      |-/proc                               proc           proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
      | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
      | `-/run/user/1001                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=808828k,mode=700,uid=1001,gid=1001
      `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.1G    /var/
      860M    /var/cache
      855M    /var/cache/apt
      796M    /var/cache/apt/archives
      93M     /var/lib
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      47M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      7.8M    /opt/iobroker/iobroker-data/
      3.3M    /opt/iobroker/iobroker-data/files
      2.8M    /opt/iobroker/iobroker-data/files/info.admin
      2.4M    /opt/iobroker/iobroker-data/files/info.admin/lib
      1.1M    /opt/iobroker/iobroker-data/files/info.admin/lib/fonts
      1.9M    /opt/iobroker/iobroker-data/objects.json.bak
      436K    /opt/iobroker/iobroker-data/files/info.admin/lib/fonts/fontawesome-webfont.svg
      264K    /opt/iobroker/iobroker-data/files/info.admin/lib/js/simplemde.min.js
      256K    /opt/iobroker/iobroker-data/files/info.admin/words.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2403592-if00
      *** NodeJS-Installation ***
      nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      /usr/bin/corepack
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
       *** 20.17.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Core adapters versions
      js-controller:
      admin:
      javascript:
      nodejs modules from github:     0
      Adapter State
      ioBroker-Repositories
      Installed ioBroker-Instances
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14248      576/sshd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14250      576/sshd
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14119      568/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13966      362/avahi-daemon: r
      udp        0      0 0.0.0.0:37212           0.0.0.0:*                           108        13968      362/avahi-daemon: r
      udp6       0      0 :::50847                :::*                                108        13969      362/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13967      362/avahi-daemon: r
      2024-09-14 21:12:22.453  - warn: zigbee.1 (23454) DeviceAvailability:Stopping to ping 0x7cb03eaa0a06b83e Plug 01 after 4 ping attempts
      2024-09-14 21:19:54.673  - info: zigbee.1 (23454) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2403592","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2403592-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
      2024-09-14 21:31:41.015  - info: host.ioBroker-Slave Controller will upgrade itself to version 6.0.11
      2024-09-14 22:52:52.662  - info: zigbee.1 (23454) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2403592","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2403592-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
      2024-09-14 22:52:58.076  - info: zigbee.1 (23454) Zigbee: allowing new devices to join.
      2024-09-14 22:53:14.152  - info: zigbee.1 (23454) Starting interview of '0x54ef441000ac4ff2'
      2024-09-14 22:53:26.152  - info: zigbee.1 (23454) Successfully interviewed '0x54ef441000ac4ff2', device has successfully been paired
      2024-09-14 22:53:26.152  - info: zigbee.1 (23454) Device '0x54ef441000ac4ff2' is supported, identified as: Aqara Motion sensor P1 (RTCGQ14LM)
      2024-09-14 22:53:26.154  - info: zigbee.1 (23454) -> Configuring 0x54ef441000ac4ff2 lumi.motion.ac02
      2024-09-14 22:53:26.185  - warn: zigbee.1 (23454) download icon from https://www.zigbee2mqtt.io/images/devices/RTCGQ14LM.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/RTCGQ14LM.png
      2024-09-14 22:53:30.267  - info: zigbee.1 (23454) DeviceConfigure successful 0x54ef441000ac4ff2 lumi.motion.ac02
      2024-09-14 22:54:30.567  - info: zigbee.1 (23454) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2403592","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2403592-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
      2024-09-14 22:54:59.278  - info: zigbee.1 (23454) Zigbee: stop joining
      2024-09-14 23:08:32.542  - info: host.ioBroker-Slave received SIGTERM
      2024-09-14 23:08:32.548  - info: zigbee.1 (23454) cleaned everything up...
      2024-09-14 23:08:32.547  - info: host.ioBroker-Slave stopInstance system.adapter.zigbee.1 (force=false, process=true)
      2024-09-14 23:08:32.562  - info: host.ioBroker-Slave stopInstance system.adapter.zigbee.1 send kill signal
      2024-09-14 23:08:32.555  - info: zigbee.1 (23454) Zigbee: disabling joining new devices.
      2024-09-14 23:08:32.707  - info: zigbee.1 (23454) Got terminate signal TERMINATE_YOURSELF
      2024-09-14 23:08:32.900  - info: zigbee.1 (23454) terminating
      2024-09-14 23:08:32.901  - info: zigbee.1 (23454) Terminated (NO_ERROR): Without reason
      2024-09-14 23:08:33.058  - info: zigbee.1 (23454) terminating
      2024-09-14 23:08:33.679  - info: host.ioBroker-Slave instance system.adapter.zigbee.1 terminated with code 0 (NO_ERROR)
      2024-09-14 23:08:33.680  - info: host.ioBroker-Slave All instances are stopped.
      2024-09-14 23:08:33.776  - info: host.ioBroker-Slave terminated
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @Smart_Home last edited by
        @smart_home sagte in node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version:
        buster
        Ist tot und muss durch eine noch aktiv unterstützte Version ersetzt werden.
        Installier da NEU Raspberry OS 12 'Bookworm'. In der 64Bit-Lite-Version. Und dann dort die richtige Zeitzone setzen. Oder wohnst du in England?
        Künftig das Betriebssystem besser auf Stand halten.
        • Smart_Home
          @thomas-braun verdammt....hatte gehofft es geht ohne. Ne ist Deutschland. Danke dir.
          Thomas Braun OliverIO 3 Replies Last reply Reply Quote 0
            @smart_home
            Nein, das geht auch bei dir nicht ohne komplette Neuinstallation.
            • OliverIO
              OliverIO @Smart_Home last edited by OliverIO
              @smart_home
              du hast da auch noch ein paar andere Issues
              das wird mit dem nächsten betriebssystem nicht besser
                @smart_home
                Bring das vorübgehend per
                iob nodejs-update 18
                auf die letzte Version, die noch mit buster funktioniert.
                Smart_Home 1 Reply Last reply Reply Quote 1
                • Smart_Home
                  Smart_Home @Thomas Braun last edited by
                  @thomas-braun sagte in node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version:
                  Gott sei dank! 😄 Jetzt funktionieren wenigstens die Zigbee Geräte wieder.
                  Dankeeee...
                    @smart_home
                    Das ist aber nur eine behelfsmäßige Krücke. Das muss in nächster Zeit komplett neuinstalliert werden. Kommste nicht drumherum.
                    Smart_Home 1 Reply Last reply Reply Quote 0
                    • Smart_Home
                      @thomas-braun I know. Danke dir. 🙂
                        @smart_home
                        Und die Zeitzone würde ich jetzt korrigieren. Und auch auf dem Master danach schauen.
                          Thomas Braun Most Active @Thomas Braun last edited by
                          @apollon77
                          Magst du bitte den aktuellen Code von 'nodejs-update' hochladen? Danke.
                          31.6k
                          79.5k
                          469
