    4. Javascript Adapter deaktiviert / stürzt ab
      bubiman @DJMarc75 last edited by
      @djmarc75 sagte in Javascript Adapter deaktiviert / stürzt ab:
      @bubiman sagte in Javascript Adapter deaktiviert / stürzt ab:
      das Ergebnis von iob diag gebeten. Die Ausgaben habe ich angefügt
      Bitte nicht als Textdatei sondern ebenfalls in Codetags hier einfügen.
      iob diag 1
      Skript v.2024-05-22
      *** BASE SYSTEM ***
      Hardware Vendor : To Be Filled By O.E.M.
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v10.0.0
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       14:22:23 up 317 days,  4:57,  0 user,  load average: 8.03, 7.78, 6.13
      CPU threads: 8
      *** Time and Time Zones ***
      Thu Sep 12 12:22:23 UTC 2024
      Thu Sep 12 14:22:23 CEST 2024
      CEST +0200
      Etc/UTC
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/opt/iobroker
      GROUPS=users tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             33G         12G        620M        659M         21G         21G
      Swap:             0B          0B          0B
      Total:           33G         12G        620M
      Active iob-Instances:   35
              32078 M total memory
              11594 M used memory
              12686 M active memory
              16929 M inactive memory
                582 M free memory
                  0 M buffer memory
              20985 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 14:22:24 up 317 days,  4:57,  0 user,  load average: 8.11, 7.80, 6.14
      Tasks:  42 total,   1 running,  41 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  32078.0 total,    574.4 free,  11600.9 used,  20989.4 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.  20477.1 avail Mem
      *** FILESYSTEM ***
      Filesystem     Type       Size  Used Avail Use% Mounted on
      /dev/loop2     btrfs       60G   15G   45G  26% /
      tmpfs          tmpfs       64M     0   64M   0% /dev
      shm            tmpfs       64M     0   64M   0% /dev/shm
      shfs           fuse.shfs  477G  172G  305G  37% /opt/iobroker
      /dev/sdg1      xfs        1.9T  1.6T  309G  84% /opt/frigate
      /dev/loop2     btrfs       60G   15G   45G  26% /etc/hosts
      Show mounted filesystems:
      TARGET             SOURCE        FSTYPE    OPTIONS
      /                  /dev/loop2[/btrfs/subvolumes/82fad975bd3220cdc55af77f388bef877109962798d4b72f1c7e7a6b4cda6f1a]       btrfs     rw,noatime,space_cache=v2,subvolid=12930,subvol=/btrfs/subvolumes/82fad975bd3220cdc55af77f388bef877109962798d4b72f1c7e7a6b4cda6f1a
      |-/proc            proc        proc      rw,nosuid,nodev,noexec,relatime
      |-/dev             tmpfs        tmpfs     rw,nosuid,size=65536k,mode=755,inode64
      | |-/dev/pts       devpts        devpts    rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
      | |-/dev/mqueue    mqueue        mqueue    rw,nosuid,nodev,noexec,relatime
      | `-/dev/shm       shm        tmpfs     rw,nosuid,nodev,noexec,relatime,size=65536k,inode64
      |-/sys             sysfs        sysfs     rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/cgroup cgroup        cgroup2   rw,nosuid,nodev,noexec,relatime
      |-/opt/userscripts shfs[/appdata/iobroker/scripts]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
      |-/opt/frigate     /dev/sdg1[/frigate]        xfs       ro,relatime,attr2,inode64,logbufs=8,logbsize=32k,noquota
      |-/opt/iobroker    shfs[/appdata/iobroker/data]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
      |-/etc/resolv.conf /dev/loop2[/containers/60eb4c042417da7dab806a6736b49b2ed8d29a81ad49012a8956855fbd298276/resolv.conf] btrfs     rw,noatime,space_cache=v2,subvolid=5,subvol=/
      |-/etc/hostname    /dev/loop2[/containers/60eb4c042417da7dab806a6736b49b2ed8d29a81ad49012a8956855fbd298276/hostname]    btrfs     rw,noatime,space_cache=v2,subvolid=5,subvol=/
      `-/etc/hosts       /dev/loop2[/containers/60eb4c042417da7dab806a6736b49b2ed8d29a81ad49012a8956855fbd298276/hosts]       btrfs     rw,noatime,space_cache=v2,subvolid=5,subvol=/
      /var:
      34M     /var/
      32M     /var/lib
      19M     /var/lib/apt/lists
      19M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      334M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      909M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      133M    /opt/iobroker/iobroker-data/states.jsonl
      64M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
       *** 20.17.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          7.0.23
      javascript:     8.7.6
      nodejs modules from github:     1
      +-- iobroker.labcom@0.1.5 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#13ae01a87552c17f49fc39f49ae3dd5bde870906)
      Adapter State
      + system.adapter.admin.0                  : admin                 : 60eb4c042417                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : 60eb4c042417                             -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : 60eb4c042417                             -  enabled
      + system.adapter.backitup.0               : backitup              : 60eb4c042417                             -  enabled
      + system.adapter.deconz.0                 : deconz                : 60eb4c042417                             -  enabled, port: 80
        system.adapter.devices.0                : devices               : 60eb4c042417                             - disabled
      + system.adapter.discovery.0              : discovery             : 60eb4c042417                             -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : 60eb4c042417                             -  enabled
      + system.adapter.fb-checkpresence.1       : fb-checkpresence      : 60eb4c042417                             -  enabled
        system.adapter.fb-checkpresence.2       : fb-checkpresence      : 60eb4c042417                             - disabled
        system.adapter.flot.0                   : flot                  : 60eb4c042417                             - disabled
      + system.adapter.frigate.0                : frigate               : 60eb4c042417                             -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : 60eb4c042417                             -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : 60eb4c042417                             -  enabled, port: 2001
      + system.adapter.hm-rpc.1                 : hm-rpc                : 60eb4c042417                             -  enabled, port: 2010
      + system.adapter.hm-rpc.2                 : hm-rpc                : 60eb4c042417                             -  enabled, port: 9292
      + system.adapter.hmip.0                   : hmip                  : 60eb4c042417                             -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : 60eb4c042417                             -  enabled
      + system.adapter.hs100.0                  : hs100                 : 60eb4c042417                             -  enabled
        system.adapter.ical.0                   : ical                  : 60eb4c042417                             -  enabled
      + system.adapter.influxdb.0               : influxdb              : 60eb4c042417                             -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : 60eb4c042417                             -  enabled
      + system.adapter.innogy-smarthome.0       : innogy-smarthome      : 60eb4c042417                             -  enabled
      + system.adapter.jarvis.0                 : jarvis                : 60eb4c042417                             -  enabled
      + system.adapter.javascript.0             : javascript            : 60eb4c042417                             -  enabled
        system.adapter.labcom.0                 : labcom                : 60eb4c042417                             -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : 60eb4c042417                             -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.pvforecast.0             : pvforecast            : 60eb4c042417                             -  enabled
      + system.adapter.shelly.0                 : shelly                : 60eb4c042417                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : 60eb4c042417                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : 60eb4c042417                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : 60eb4c042417                             -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : 60eb4c042417                             -  enabled, port: 3308
      + system.adapter.statistics.0             : statistics            : 60eb4c042417                             -  enabled
      + system.adapter.telegram.0               : telegram              : 60eb4c042417                             -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : 60eb4c042417                             -  enabled
        system.adapter.tr-064.1                 : tr-064                : 60eb4c042417                             - disabled
      + system.adapter.tradfri.0                : tradfri               : 60eb4c042417                             -  enabled
        system.adapter.twinkly.0                : twinkly               : 60eb4c042417                             - disabled
      + system.adapter.vesync.0                 : vesync                : 60eb4c042417                             -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : 60eb4c042417                             -  enabled
        system.adapter.vis.0                    : vis                   : 60eb4c042417                             - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : 60eb4c042417                             -  enabled
      + system.adapter.web.0                    : web                   : 60eb4c042417                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zigbee.0                 : zigbee                : iobroker2                                - disabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.23   , installed 7.0.23
      Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "frigate"      : 1.2.0    , installed 1.2.0
      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "hmip"         : 1.23.3   , installed 1.23.3
      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
      Adapter    "hs100"        : 2.2.0    , installed 2.2.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.11   , installed 6.0.9  [Updatable]
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        80267
      States:         80010
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      99         4116192141 348/io.hm-rpc.1
      tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      99         4116194894 333/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      99         4116192211 471/io.sonoff.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      99         4116193012 524/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      99         4116198434 460/io.mqtt.0
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      99         4116182584 205/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      99         4116187175 205/iobroker.js-con
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      99         4116190178 630/io.jarvis.0
      tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      99         4116192886 498/io.hm-rpc.2
      tcp6       0      0 :::8084                 :::*                    LISTEN      99         4116194091 585/io.socketio.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      99         4116192995 623/io.simple-api.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      99         4116194415 239/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      99         4116194095 615/io.web.0
      tcp6       0      0 :::1885                 :::*                    LISTEN      99         4116190179 746/io.frigate.0
      udp        0      0 0.0.0.0:58663           0.0.0.0:*                           99         4116194071 609/io.tradfri.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           99         4116194027 505/io.deconz.0
      udp        0      0 172.17.0.3:5353         0.0.0.0:*                           99         4116195669 383/io.tr-064.0
      2024-09-12 14:24:47.324  - debug: statistics.0 (598) [STATE CHANGE] stateChange => true
      2024-09-12 14:24:47.324  - debug: statistics.0 (598) [STATE CHANGE] schedule onStateChangeTimeCntValue for hs100.0.192_168_3_205.state
      2024-09-12 14:24:47.324  - debug: statistics.0 (598) [EXECUTING] time count hs100.0.192_168_3_205.state
      2024-09-12 14:24:47.325  - debug: statistics.0 (598) [STATE CHANGE] new last temp.timeCount.hs100.0.192_168_3_205.state.last: true
      2024-09-12 14:24:47.379  - debug: statistics.0 (598) [STATE CHANGE] new last01 temp.timeCount.hs100.0.192_168_3_205.state.last01: 1726143887320 12 Sep 2024 14:24:47
      2024-09-12 14:24:47.425  - debug: statistics.0 (598) [STATE EQUAL] 1->1 delta 4 state 12 Sep 2024 14:24:47 last 12 Sep 2024 14:24:42
      2024-09-12 14:24:47.425  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onDay: 47373
      2024-09-12 14:24:47.470  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onWeek: 282227
      2024-09-12 14:24:47.515  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onMonth: 909010
      2024-09-12 14:24:47.561  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onQuarter: 5762392
      2024-09-12 14:24:47.608  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onYear: 21081306
      2024-09-12 14:24:49.132  - warn: frigate.0 (746) fetchEventHistory error from http://http://192.168.3.220/:5000/api/events
      2024-09-12 14:24:49.134  - warn: frigate.0 (746) Error: getaddrinfo ENOTFOUND http
      2024-09-12 14:24:52.323  - debug: statistics.0 (598) [STATE CHANGE] ======================= hs100.0.192_168_3_205.state =======================
      2024-09-12 14:24:52.323  - debug: statistics.0 (598) [STATE CHANGE] stateChange => true
      2024-09-12 14:24:52.323  - debug: statistics.0 (598) [STATE CHANGE] schedule onStateChangeTimeCntValue for hs100.0.192_168_3_205.state
      2024-09-12 14:24:52.323  - debug: statistics.0 (598) [EXECUTING] time count hs100.0.192_168_3_205.state
      2024-09-12 14:24:52.324  - debug: statistics.0 (598) [STATE CHANGE] new last temp.timeCount.hs100.0.192_168_3_205.state.last: true
      2024-09-12 14:24:52.387  - debug: statistics.0 (598) [STATE CHANGE] new last01 temp.timeCount.hs100.0.192_168_3_205.state.last01: 1726143892318 12 Sep 2024 14:24:52
      2024-09-12 14:24:52.434  - debug: statistics.0 (598) [STATE EQUAL] 1->1 delta 4 state 12 Sep 2024 14:24:52 last 12 Sep 2024 14:24:47
      2024-09-12 14:24:52.435  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onDay: 47377
      2024-09-12 14:24:52.484  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onWeek: 282231
      2024-09-12 14:24:52.529  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onMonth: 909014
      2024-09-12 14:24:52.575  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onQuarter: 5762396
      2024-09-12 14:24:52.629  - debug: statistics.0 (598) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onYear: 21081310
      iob diag 2
                              v.2024-05-22
      model name      : Intel(R) Atom(TM) CPU C3758 @ 2.20GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v10.0.0
      Installation:           Docker
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               CEST +0200
      User-ID:                0
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.17.0 and npm 10.8.2
      MEMORY:
      Mem:             33G         12G        1.1G        674M         21G         21G
      Swap:             0B          0B          0B
      Total:           33G         12G        1.1G
      ioBroker Core:          js-controller           6.0.9
                              admin                   7.0.23
      Objects type: jsonl
      States  type: jsonl
      Objects:                80267
      States:                 80010
      Size of iob-Database:
      6.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      6.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      137M    /opt/iobroker/iobroker-data/states.jsonl
      1.4M    /opt/iobroker/iobroker-data/states.json.migrated
      1.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        warum er gelegentlich abstürzt
        Ich tippe, Glaskugeltechnisch, mal auf AmokSkripte welche idR durch z.B. Schleifen verursacht werden - aber erst mal reine Vermutung
        Ooook ich habe da ein nicht gerade schönes Skript was mir die Lampen je nach Bewegung und Helligkeit im Raum ein und ausschaltet. Das läuft aber sicher schon seit nem Jahr ohne Änderung und so lange stürzt der Javascript Adapter noch nicht ab.
        • DJMarc75
          DJMarc75 @bubiman last edited by
          muss ja nicht unbedingt dieses EINE oder überhaupt ein Skript sein - aber der LoadAverage bei Dir ist schon mehr als bedenklich.
          Hast Du Skripte unter GLOBAL abgelegt?
          Falls ja - mach das nicht !
            Unter Global liegt kein Skript
            • DJMarc75
              @bubiman
              Was mir grad auffällt:
              Nicht mal auf die Idee gekommen das Teil mal zu rebooten ?
              Sollte man ja auch machen wenn man ordentlich Updates fährt 🙂
                @bubiman
                Der Unraid Server läuft recht stabil, da hatte ich jetzt schon länger keine Probleme. Der iobroker wird jeden morgen um 4:00 Uhr mit dem BackItUp Adapter gesichert und neu gestartet.
                  A Former User @bubiman last edited by
                  @bubiman
                  Was sind denn die Fehlermeldungen des Javascript-Adapters?
                  Im Screenshot sieht man nicht wirklich was...
                    Homoran Global Moderator Administrators @bubiman last edited by
                    gibt es zum Javascript Adapter keinen Eintrag:
                    und zum controller?
                      bubiman @Guest last edited by
                      @ilovegym sagte in Javascript Adapter deaktiviert / stürzt ab:
                      @bubiman
                      Das ist es ja, ich habe noch keine Fehlermeldung im Protokoll vom Javascript Adapter gesehen
                        bubiman @bubiman last edited by bubiman
                        Jetzt habe ich es gerade einmal "live" mitbekommen:
                        Unter Protokolle gibt es keinen Eintrag vom JS Adapter und unterm Host gibt es auch nichts über den "Absturz" und Neustart.
                        Ich habe mir jetzt einmal die iobroker.current.log von heute runtergeladen und auch da finde ich nichts. Den Screenshot habe ich um 19:01 gemacht, im Log sehe ich den letzten Eintrag vor 19:01 um 19:00.00 von javascript.0
                        2024-09-15 19:00:00.092  - info: javascript.0 (255) script.js.common.SmartHome.LowBattery1: Innogy Sensoren:
                        wenn ich dann das Log nach unten scrolle wird es komisch, um 19:03 springt es auf einmal wieder auf 19:00 mit dem JS Adapter:
                        2024-09-15 19:03:16.968  - debug: statistics.0 (626) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onDay: 62424
                        2024-09-15 19:03:17.013  - debug: statistics.0 (626) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onWeek: 532658
                        2024-09-15 19:03:17.064  - debug: statistics.0 (626) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onMonth: 1159441
                        2024-09-15 19:03:17.117  - debug: statistics.0 (626) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onQuarter: 6012823
                        2024-09-15 19:03:17.162  - debug: statistics.0 (626) [STATE EQUAL] 1->1 new val temp.timeCount.hs100.0.192_168_3_205.state.onYear: 21331737
                        2024-09-15 19:00:51.571  - info: javascript.0 (255) script.js.common.SmartHome.LowBattery1: LowBatter : false
                        2024-09-15 19:00:51.572  - info: javascript.0 (255) script.js.common.SmartHome.LowBattery1: LowBatter : false
                        Ich sehe nirgends zwische 18:59 und 19:03 einen Eintrag der auf einen Absturz und Neustart des JS Adapters hindeutet.
                        Hat irgendwer eine Idee was ich versuchen könnte? Ich hatte irgendwo gelesen, dass jemand einen zweiten JS Adapter erzeugt hat und Skripte aufgeteilt hat aber wenn ich das richtig verstanden habe ging es da um RAM Probleme und mein JS Adapter braucht nur 340MB zZ
                          paul53 @bubiman last edited by
                          @bubiman sagte: 19:00 mit dem JS Adapter:
                          Die Log-Ausgaben des Skriptes "LowBattery1" kommen zu schnell hintereinander, was nach einer Endlosschleife aussieht. Deaktiviere mal das Skript und zeige es uns.
                            bubiman @paul53 last edited by
                            Das Skript geht einmal die Stunde durch alle Sensoren von vier Adaptern und überprüft ob eine der Batterien fast leer ist, ich weiß dass es nicht schön ist:
                            Codierknecht Asgothian 2 Replies Last reply Reply Quote 0
                            • Codierknecht
                              Codierknecht Developer Most Active @bubiman last edited by
                              @bubiman
                              Hast Du Dir mal den Adapter "Device-Watcher" angeschaut?
                              • Asgothian
                                Asgothian Developer @bubiman last edited by
                                @bubiman über wie viele Sensoren reden wir ?
                                Setz doch mal in jede Schleife ein "pause 50 ms"
                                A.
                                  bubiman @Asgothian last edited by
                                  @asgothian sagte in Javascript Adapter deaktiviert / stürzt ab:
                                  A.
                                  Sind ca. 50 Sensoren. Ich hab das Skript jetzt mal ausgeschaltet und versuche morgen ein Auge auf die Adapter zu haben ob der weiterhin ausfällt.
                                  Wenn ich wenigstens sehen könnte wann der ausfällt aber ich finde im Log nichts
                                    bubiman @Codierknecht last edited by
                                    @codierknecht sagte in Javascript Adapter deaktiviert / stürzt ab:
                                    @bubiman
                                    Bisher noch nicht aber ich möchte aktuell erstmal keine weiteren einbinden sofern ich nicht weiß was da los ist.
                                    Codierknecht B 2 Replies Last reply Reply Quote 0
                                    • Codierknecht
                                      @bubiman
                                      Naja - der macht eigentlich genau das was Du suchst.
                                        @bubiman
                                        Ich hab ihn doch installiert
                                          Leider benachrichtigt der Device Watcher nicht wenn die JS Instanz abstürzt. Ich bekomme nur eine Meldung wenn ich die JS Instanz selber beende
                                          • Asgothian
                                            Der device watcher soll den batteriestatus überwachen - nicht den js Adapter
                                            A.
                                            2463
