    4. Fehlermeldung nach Neuinstallation und Rückladen von Backup
    • N
      Nr5lebt last edited by
      hallo zusammen,
      nach neuinstallation von iobroker auf omv 7 und rückladen eines backups hatte iobroker nur noch eine Fehlermeldung für mich übrig:
      Error in GUI!
      Please open the browser console (F12), copy error text from there and create the issue on github
      Without this information it is not possible to analyse the error.
      It should looks like
      error
      If in the second line you will see at :3000/static/js/main.chunk.js:36903 and not the normal file name,
      please try to reproduce an error with opened browser console. In this case the special "map" files will be loaded and the developers can see the real name of functions and files.
      Loading chunk 6552 failed. (error: http://192.168.178.50:8081/static/js/6552.8a972966.chunk.js)
      t.f.j@http://192.168.178.50:8081/static/js/main.148da242.js:1:14165
      t.e/<@http://192.168.178.50:8081/static/js/main.148da242.js:1:1152
      t.e@http://192.168.178.50:8081/static/js/main.148da242.js:1:1130
      32098/Ba<@http://192.168.178.50:8081/static/js/7669.72a3d01c.chunk.js:1:1651072
      P@http://192.168.178.50:8081/static/js/4905.33747b16.chunk.js:2:3345
      xi@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:120729
      bs@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:109363
      vs@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:109291
      gs@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:109152
      is@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:106270
      Hl@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:46915
      62280/rs/<@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:103865
      Kann mir einer helfen?
      • Codierknecht
        Codierknecht Developer Most Active @Nr5lebt last edited by
        @nr5lebt sagte in Fehlermeldung nach Neuinstallation und Rückladen von Backup:
        Steht doch da
        N 2 Replies Last reply Reply Quote 0
        • N
          Nr5lebt @Codierknecht last edited by Homoran
          @codierknecht
          [2024-09-15T17:44:24.445Z] No READY flag received in 3 seconds. Re-init 3957.af86c9f9.chunk.js:2:243182
          Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.50:8081/?sid=1726422261443&name=admin aufbauen. socket.io.js:140:21
          [2024-09-15T17:44:24.446Z] Start reconnect 5 3957.af86c9f9.chunk.js:2:243182
          Die Verbindung zu ws://192.168.178.50:8081/?sid=1726422261443&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
          [2024-09-15T17:44:24.449Z] Reconnect is already running 5 3957.af86c9f9.chunk.js:2:243182
          [2024-09-15T17:44:24.450Z] ws connection error: CLOSE_ABNORMAL 3957.af86c9f9.chunk.js:2:243182
          [2024-09-15T17:44:24.450Z] Reconnect is already running 5 3957.af86c9f9.chunk.js:2:243182
          [2024-09-15T17:44:29.447Z] Try to connect 3957.af86c9f9.chunk.js:2:243182
          [2024-09-15T17:44:32.451Z] No READY flag received in 3 seconds. Re-init 3957.af86c9f9.chunk.js:2:243182
          Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.50:8081/?sid=1726422269448&name=admin aufbauen. socket.io.js:140:21
          [2024-09-15T17:44:32.451Z] Start reconnect 5 3957.af86c9f9.chunk.js:2:243182
          Die Verbindung zu ws://192.168.178.50:8081/?sid=1726422269448&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
          [2024-09-15T17:44:32.453Z] Reconnect is already running 5 3957.af86c9f9.chunk.js:2:243182
          [2024-09-15T17:44:32.453Z] ws connection error: CLOSE_ABNORMAL 3957.af86c9f9.chunk.js:2:243182
          [2024-09-15T17:44:32.454Z] Reconnect is already running 5
          das hier?
          • N
            @codierknecht das hier?
            N Ro75 2 Replies Last reply Reply Quote 0
            • N
              Nr5lebt @Nr5lebt last edited by
              @Homoran hallo, kannst du mir noch hoffnung geben?
              • Ro75
                Ro75 @Nr5lebt last edited by
                @nr5lebt du hast doch das selbe Thema in einem anderen Thread beschrieben. Warum nochmal? Hatte dir dort schon was dazu geschrieben.
                Ro75
                • N
                  Nr5lebt @Ro75 last edited by
                  @ro75 das war doch was ganz anderes (omv, rechteprobleme bei installation von iobroker)
                  mein iobroker lief ja eben, hab backup zurückgespielt und jetzt das
                  Ro75 1 Reply Last reply Reply Quote 0
                  • Ro75
                    @nr5lebt und an dieser Stelle nochmal. Auf Dauer wird das nicht sauber und zuverlässig funktionieren!
                    Ro75.
