E3DC Hauskraftwerk steuern
@arnod
Ich hatte gestern ein Problem mit meinem E3DC RSCP Adapter und habe ihn daraufhin neu installiert.
Seitdem bekomme ich ChargeControl nicht mehr korrekt zum Laufen. Die Fehler sagen mir nicht wirklich was, da die Zeilennummern nicht übereinstimmen.
Vielleich kannst du mir sagen, welche Werte fehlen, die dringend benötigt werden.
Danke schonmal.Das Debug Log sagt folgendes:
.0 2024-09-12 00:30:06.043 error at Ladesteuerung (script.js.E3DC_ChargeControl.Charge_Control:440:105) javascript.0 2024-09-12 00:30:06.043 error at script.js.E3DC_ChargeControl.Charge_Control:446:30 javascript.0 2024-09-12 00:30:06.043 error at Array.map (<anonymous>) javascript.0 2024-09-12 00:30:06.043 error at script.js.E3DC_ChargeControl.Charge_Control:446:49 javascript.0 2024-09-12 00:30:06.043 error script.js.E3DC_ChargeControl.Charge_Control: TypeError: Cannot read properties of null (reading 'val') javascript.0 2024-09-12 00:30:03.042 error at Object.<anonymous> (script.js.E3DC_ChargeControl.Charge_Control:2395:63) javascript.0 2024-09-12 00:30:03.042 error at Ladesteuerung (script.js.E3DC_ChargeControl.Charge_Control:440:105) javascript.0 2024-09-12 00:30:03.042 error at script.js.E3DC_ChargeControl.Charge_Control:446:30 javascript.0 2024-09-12 00:30:03.042 error at Array.map (<anonymous>) javascript.0 2024-09-12 00:30:03.042 error at script.js.E3DC_ChargeControl.Charge_Control:446:49 javascript.0 2024-09-12 00:30:03.042 error script.js.E3DC_ChargeControl.Charge_Control: TypeError: Cannot read properties of null (reading 'val') javascript.0 2024-09-12 00:30:00.031 error at Object.<anonymous> (script.js.E3DC_ChargeControl.Charge_Control:2395:63) javascript.0 2024-09-12 00:30:00.031 error at Ladesteuerung (script.js.E3DC_ChargeControl.Charge_Control:440:105) javascript.0 2024-09-12 00:30:00.031 error at processImmediate (node:internal/timers:454:9) javascript.0 2024-09-12 00:30:00.031 error at runNextTicks (node:internal/process/task_queues:60:5) javascript.0 2024-09-12 00:30:00.031 error at script.js.E3DC_ChargeControl.Charge_Control:446:30 javascript.0 2024-09-12 00:30:00.031 error at Array.map (<anonymous>) javascript.0 2024-09-12 00:30:00.030 error at script.js.E3DC_ChargeControl.Charge_Control:446:49 javascript.0 2024-09-12 00:30:00.030 error script.js.E3DC_ChargeControl.Charge_Control: TypeError: Cannot read properties of null (reading 'val') -
Fehler gefunden.
e3dc-rscp.0.EMS.SET_POWER_MODE war leer.
Sollte das nicht der Adapter setzen oder macht das ChargeControl?
Nachdem ich 0 eingetragen habe, hat ChargeControl selbstständig Idle gesetzt und läuft automatisch.Ich weiß nicht, ob das sinnvoll ist aber kann ChargeControl bei einem leeren Feld, nicht einfach beim Start etwas setzen (0)?
@psrelax
Ist bei mir auch aufgetretene und ich schaue mir das an, wie diesen Fehler abfangen kann. -
Neue Version Charge-Control auf GitHub hochgeladen.
Version: 1.5.6
Änderungen:- Wenn SET_POWER_MODE = null ist, wird jetzt 0 eingetragen und nicht mehr mit einem Fehler beendet.
- Fehler bei der Erstellung Diagramm PrognoseAuto_kWh korrigiert.
- Script aufgeräumt und optimiert
hat sich ne Kleinigkeit eingeschlichen...
bei Autonomiezeit in h und m
istawait setStateAsync(sID_Autonomiezeit, `${currentHours}:${currentMinutes.toString().padStart(2,"0")} h / ${totalHours}:${totalMinutes.toString().padStart(2,"0")} h` );soll:
await setStateAsync(sID_Autonomiezeit, `${currentHours}:${currentMinutes.toString().padStart(2,"0")} h / ${totalHours}:${totalMinutes.toString().padStart(2,"0")} m` );Das Format ist auch noch nicht so ganz passend.. siehe Bild... 16 h / 32 m würde mir besser gefallen..
Beides sind h und m also so wäre es richtig, um bei deinem Beispiel zu bleiben:
16 h 05 m / 32 h 00 m
Links ist die Reichweite beim aktuellen Verbrauch und recht mit dem Durchschnittsverbrauch berechnet.
Da ich diesen auch in einem anderen Script verwende und der String sonst so lang wird, habe ich es mir einfach gemacht undhangefügt und mit:Stunden und Minuten getrennt.Vorteil ist, dass man es einfach wieder trennen kann und in jedem Script verwenden kann mit:
(await getStateAsync(sID_Autonomiezeit)).val.split(' / ')[1].split(' ')[0].split(':').map(Number);Ich weiß, das würde anders auch gehen
@arnod
Ich komme mit der Ladelogik noch nicht ganz klar.
Heute Nachmittag wurde der Speicher geladen, was für mich so in Ordnung war.
Jetzt in der Nacht fängt er wieder das Laden an, verstehe das bei dem Preis nicht.Wird der Strompreis der Batterie zu den 0,20€ der max. Strompreis-Freigabe hinzugerechnet?
Normalerweise müsste der aktuelle Strompreis minus Speicherstrompreis, unterhalb vom eingestellten max. Strompreis liegen, damit geladen wird.
Auch der beste Ladezeitraum sagt, dass erst morgen geladen werden soll.
Ich werd noch ned ganz schlau draus.
2024-09-14 23:00:00.337 warn script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 1,5,9,4,3,12, javascript.0 2024-09-14 23:00:00.337 info script.js.E3DC_ChargeControl.Tibber: eAutoLaden = false javascript.0 2024-09-14 23:00:00.337 info script.js.E3DC_ChargeControl.Tibber: Power_Grid = -17 javascript.0 2024-09-14 23:00:00.337 info script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -1284 javascript.0 2024-09-14 23:00:00.337 info script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true javascript.0 2024-09-14 23:00:00.337 info script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false javascript.0 2024-09-14 23:00:00.337 info script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.287 javascript.0 2024-09-14 23:00:00.337 info script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 javascript.0 2024-09-14 23:00:00.337 info script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 3:45 h / 5:11 m javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 2 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 41 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 4.377600000000001 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: maxStrompreisUser = 0.2 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.1856 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0.26305 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0.2619 javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 15.09. / 4:00 - 6:00 Uhr javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Sun Sep 15 2024 11:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Sat Sep 14 2024 23:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) javascript.0 2024-09-14 23:00:00.336 info script.js.E3DC_ChargeControl.Tibber: timerIds2 = 135567787 javascript.0 2024-09-14 23:00:00.335 info script.js.E3DC_ChargeControl.Tibber: timerIds1 = 135567773 javascript.0 2024-09-14 23:00:00.335 info script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.0.6 ******************* javascript.0 2024-09-14 23:00:00.000 warn script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 23:00:00 auf true gesetzt. javascript.0 2024-09-14 22:00:00.250 warn script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 1,5,9,4,3,12, javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: eAutoLaden = false javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: Power_Grid = -27 javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -960 javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: BatterieLaden = false javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2977 javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 javascript.0 2024-09-14 22:00:00.250 info script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 6:32 h / 6:35 m javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 2 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 49 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 4.377600000000001 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: maxStrompreisUser = 0.2 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.1856 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0.26305 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0.2619 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 15.09. / 4:00 - 6:00 Uhr javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Sun Sep 15 2024 11:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Sat Sep 14 2024 23:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: timerIds2 = 135567787 javascript.0 2024-09-14 22:00:00.249 info script.js.E3DC_ChargeControl.Tibber: timerIds1 = 135567773 javascript.0 2024-09-14 22:00:00.248 info script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.0.6 ******************* -
@psrelax sagte in E3DC Hauskraftwerk steuern:
Ich auch nicht
Ich habe jetzt die Logik komplett geändert.
Es gibt zwei Schwellwerte „hoher Strompreis“ und "niedriger Strompreis" die von dir nach deinen Bedürfnissen eingestellt werden können.Somit gibt es drei Bereiche, hoch zwischen hoch und niedrig und niedriger Preis.
Logik, wenn Tibber Preis über Schwellwert hoher Preis liegt:
- Entladen wird zugelassen, wenn der Tibberpreis über den Batteriepreis + Ladeverluste steigt.
- Laden wird gesperrt.
- E-Auto Laden wird gesperrt
Logik, wenn Tibber Preis unter Schwellwert hoher und über Schwellwert niedriger Preis liegt:
- Entladen wird zugelassen, wenn der Tibber Preis über den Batteriepreis + Ladeverluste steigt.
- Entladen wird gesperrt, wenn als Nächstes eine hohe Preisphase kommt und die Batterieladung dann ausreicht, um diese zu überbrücken.
- Laden wird nur zugelassen, wenn als Nächstes eine hohe Preisphase kommt, wo der Tibber Preis über den Schwellwert hoher Preis + Ladeverluste steigt und die Batterieladung nicht ausreicht, um diese Phase zu überbrücken.
- E-Auto Laden wird freigegeben
Logik, wenn Tibber Preis unter Schwellwert niedriger Preis liegt:
- Laden wird freigegeben, wenn E-Auto nicht geladen wird.
So kann jeder selber entscheiden, wie er die einzelnen Bereiche einteilt, sodass es für ihn passt.
Habe es jetzt aber erst zwei Tage getestet und es können immer noch Fehler enthalten sein.Neue Version 1.1.0
Bitte folgende Objekt ID's löschen:
0_userdata.0.TibberSkript.Anzeige_VIS.energieAusNetzBatterie
0_userdata.0.TibberSkript.USER_ANPASSUNGEN.maxStrompreisNeue VIS View zum Importieren ist auch auf Github.
@arnod sagte in E3DC Hauskraftwerk steuern:
Danke für deine Bemühungen. Macht bestimmt nen Haufen Arbeit.
Hab dazu noch Fragen.Logik, wenn Tibber Preis über Schwellwert hoher Preis liegt:
Wird der Batteriepreis vom Schwellwert hoher Preis abgezogen, damit schon vorher der hohe Preis anliegt?
Wird hier ab 10cent laden freigegeben? Verstehe das nicht ganz.
Laden wird freigegeben, wenn E-Auto nicht geladen wird.Wird hier nie pauschal der Speicher verwendet? Wenn genug SOC vorhanden ist, kann doch auch bei niedrigen Stromkosten aus dem Speicher gezogen werden.
Wieso wird das Laden freigegeben wenn das E-Auto nicht geladen wird? Ist hier der Speicher gemeint oder das E-Auto? Was ist wenn das E-Auto gerade geladen wird?Anmerkung zu Vis: beide Schwellwerte werden bei mir weiß angezeigt und sind somit nicht lesbar. Hab "Ohne JQuery Stil" angehakt und schon sieht man die Werte. Ich denke das hat keine Auswirkung auf die Funktion.
@psrelax
Warte noch mit dem Testen.
Habe heute wieder mehrere Fehler gefunden.
Ich werde das ganze erstmal bei mir ausgiebig testen und dann eine korrigierte Version hochladen.Ich denke, es macht auch Sinn eine Anleitung mit Bildern zu erstellen, damit das Ganze besser verständlich ist.
@arnod
Ok, habs schon bei mir eingerichtet. Ich warte
@psrelax
Ich habe die Version 1.1.1 vom Tibber Script hochgeladen.
Ich denke, es sind sicher noch ein paar Fehler enthalten, aber die meisten sollten jetzt bereinigt sein.Wird der Batteriepreis vom Schwellwert hoher Preis abgezogen, damit schon vorher der hohe Preis anliegt?
Vom Schwellwert wird nichts abgezogen.
Beim hohen Schwellwert den Preis eintragen, ab dem du deine Batterie nicht mehr laden willst (bei mir 0,26€)
Als niedrigen Schwellwert den Preis eintragen, ab dem du sofort laden willst (bei mir 0,20€).
Zwischen hohen und niedrigen Schwellwert wird nur die Batterie geladen, wenn als Nächstes der Preis ansteigt und die aktuelle Batterieladung nicht ausreicht, um diese Hochpreisphase zu überbrücken.
Der Batteriepreis wird nur verwendet das Entladen der Batterie zu sperren, wenn der Tibber Preis günstiger ist.Wird hier nie pauschal der Speicher verwendet? Wenn genug SOC vorhanden ist, kann doch auch bei niedrigen Stromkosten aus dem Speicher gezogen werden.
Wenn der Tibber Preis unter dem niedrigen Schwellwert ist, wird die Batterie immer auf den Eingestellten SOC geladen, wenn dieser erreicht ist, wird nur dann entladen, wenn der Tibber Preis höher als der Batteriepreis ist.
Ist bei mir nicht ausgewählt und wird trotzdem angezeigt. Hat aber keine Auswirkung auf die Funktion.
Bitte auch prüfen ob beim e3dc-rscp Adapter der TAG
TAG_EMS_REQ_BAT_SOCdas Abfrageintervall auf S eingestellt ist. -
Neue Version 1.1.2 vom Tibber Script hochgeladen.
Fehler Cannot read properties of null (reading 'getTime') behoben. -
Hi Arno,
hatte heute ein seltsames Phänomen, die Ladeleistung am Akku ist immer wieder geschwankt zwischen 3000W und ~1200W. Mir kam es so vor, als ob die Ladeleistung immer auf 3000 Watt gesetzt wurde, wenn Strom aus dem Akku entnommen wurde.
Aber Lade- bzw. Entladeleistung sind doch eigentlich getrennt (dachte ich).Anbei das Log.
StefanLog E3DC Control.txt -
@stiwy18
Das ist das Problem mit der Trägheit der Steuerung.
Deine PV-Leistung von ca. 5000 W deckt gerade so deinen Eigenverbrauch von ca. 3200 W.
5000 W - 3000 W = 2000 W - 500 W um rechtzeitig umschalten zu können und Netzbezug zu vermeiden = 1500 W Spielraum.
Immer wenn die PV-Leistung sinkt oder der Eigenverbrauch steig, kann es sein das die Regelgrenze -500 W überschritten wird und die Regelung E3DC überlassen wird.
Bis aber E3DC die Regelung wieder übernimmt dauert es bis zu 3 sek. und wenn in der Zeit aber die PV-Leistung wieder steigt oder der Hausverbrauch wieder sinkt übernimmt das Skript wieder die Regelung.
Beispiel aus deinem LOG
13:51:09
PV Leistung (5072 W) - Power_Home_W (3256W) - M_Power (3000) = - 1184 W Netzbezug Regelung wird E3DC überlassen um entladen aus der Batterie zu ermöglichen.13:51:27
PV Leistung (5236 W) - Power_Home_W (3312W) - M_Power (1355) = 569 W gerade noch über 500 W und Regelung wird wieder vom Skript übernommen.Ich kann das noch etwas optimieren indem ich M_Power reduziere , aber damit wird das gleiche Problem nur in einen anderen Bereich verschoben. Dann würde es bei dir nicht bei 5000 W PV-Leistung auftreten sondern bei 3000 W.
@arnod
Die Entladesperre oder auch Ladefreigabe zwischen 21:00 und 07:30/12:00 Uhr verstehe ich nicht.
2024-09-25 00:00:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 00:00:00.248 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 651446164 2024-09-25 00:00:00.248 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 651446191 2024-09-25 00:00:00.248 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Tue Sep 24 2024 23:50:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:00:00.248 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:00:00.248 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 23:50 Uhr bis 17:00 Uhr 2024-09-25 00:00:00.248 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2582 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 55 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 9:00 h / 6:32 h 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = null 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -762 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -8 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = false 2024-09-25 00:00:00.249 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 00:00:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 00:00:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-24T04:00:00.000Z","end":"2024-09-24T08:00:00.000Z","averagePrice":0.33075,"startLocale":"24.9.2024, 06:00:00","endLocale":"24.9.2024, 10:00:00"},{"start":"2024-09-24T15:00:00.000Z","end":"2024-09-24T19:00:00.000Z","averagePrice":0.319675,"startLocale":"24.9.2024, 17:00:00","endLocale":"24.9.2024, 21:00:00"},{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 00:00:00.250 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,23,3, 2024-09-25 00:10:00.286 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 00:10:00 auf true gesetzt. 2024-09-25 00:10:00.414 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 00:10:00.414 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 652102719 2024-09-25 00:10:00.414 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 652102741 2024-09-25 00:10:00.414 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 00:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:10:00.414 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:10:00.414 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 0:10 Uhr bis 17:00 Uhr 2024-09-25 00:10:00.414 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 54 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 7:20 h / 5:41 h 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2474 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -915 2024-09-25 00:10:00.415 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -10 2024-09-25 00:10:00.416 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 00:10:00.416 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 00:10:00.416 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 00:10:00.416 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 00:10:00.416 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 00:20:00.132 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 00:20:00 auf true gesetzt. 2024-09-25 00:20:00.313 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 00:20:00.314 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 652425795 2024-09-25 00:20:00.314 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 652425822 2024-09-25 00:20:00.314 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 00:20:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:20:00.314 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:20:00.314 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 0:20 Uhr bis 17:00 Uhr 2024-09-25 00:20:00.314 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 00:20:00.314 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 53 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 8:06 h / 5:39 h 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2474 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 00:20:00.315 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 00:20:00.316 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -837 2024-09-25 00:20:00.316 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -1 2024-09-25 00:20:00.316 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 00:20:00.316 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 00:20:00.316 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 00:20:00.317 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 00:20:00.317 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 00:30:00.159 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 00:30:00 auf true gesetzt. 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 652752250 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 652752273 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 00:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 0:30 Uhr bis 17:00 Uhr 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 00:30:00.288 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 52 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 8:36 h / 5:37 h 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2474 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -789 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -1 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 00:30:00.289 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 00:30:00.290 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 00:30:00.290 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 00:40:00.144 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 00:40:00 auf true gesetzt. 2024-09-25 00:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 00:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 653074757 2024-09-25 00:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 653074776 2024-09-25 00:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 00:40:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 0:40 Uhr bis 17:00 Uhr 2024-09-25 00:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 00:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 51 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 8:08 h / 5:35 h 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2474 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -798 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -32 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 00:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 00:40:00.231 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 00:40:00.231 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 00:40:00.231 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 00:50:00.173 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 00:50:00 auf true gesetzt. 2024-09-25 00:50:00.299 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 00:50:00.299 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 653392552 2024-09-25 00:50:00.299 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 653392574 2024-09-25 00:50:00.299 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 00:50:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:50:00.299 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 00:50:00.299 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 0:50 Uhr bis 17:00 Uhr 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 51 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 10:22 h / 5:35 h 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2474 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -618 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -24 2024-09-25 00:50:00.300 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 00:50:00.301 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 00:50:00.301 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 00:50:00.301 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 00:50:00.301 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 01:00:00.168 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 01:00:00 auf true gesetzt. 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 653707027 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 653707048 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 01:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 1:00 Uhr bis 17:00 Uhr 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 01:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 50 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 9:36 h / 5:34 h 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2363 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -678 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -24 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 01:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 01:00:00.255 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 01:00:00.255 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 01:10:00.145 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 01:10:00 auf true gesetzt. 2024-09-25 01:10:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 01:10:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 654023927 2024-09-25 01:10:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 654023949 2024-09-25 01:10:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 01:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:10:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:10:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 1:10 Uhr bis 17:00 Uhr 2024-09-25 01:10:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 49 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 9:43 h / 4:42 h 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2363 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -642 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -18 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 01:10:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 01:10:00.231 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 01:10:00.231 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 01:10:00.231 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 01:20:00.145 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 01:20:00 auf true gesetzt. 2024-09-25 01:20:00.272 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 01:20:00.272 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 654342089 2024-09-25 01:20:00.272 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 654342116 2024-09-25 01:20:00.272 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 01:20:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:20:00.272 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:20:00.272 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 1:20 Uhr bis 17:00 Uhr 2024-09-25 01:20:00.272 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 49 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 11:00 h / 4:42 h 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2363 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -558 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 14 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 01:20:00.273 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 01:20:00.274 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 01:20:00.274 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 01:20:00.274 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 01:30:00.165 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 01:30:00 auf true gesetzt. 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 654657782 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 654657803 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 01:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 1:30 Uhr bis 17:00 Uhr 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 01:30:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 48 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 11:15 h / 4:40 h 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2363 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -534 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -12 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 01:30:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 01:30:00.252 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 01:40:00.111 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 01:40:00 auf true gesetzt. 2024-09-25 01:40:00.237 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 01:40:00.237 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 654975415 2024-09-25 01:40:00.237 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 654975459 2024-09-25 01:40:00.237 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 01:40:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:40:00.237 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:40:00.237 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 1:40 Uhr bis 17:00 Uhr 2024-09-25 01:40:00.237 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 01:40:00.237 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 47 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 11:15 h / 4:39 h 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2363 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -528 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -29 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 01:40:00.238 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 01:40:00.239 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 01:40:00.239 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 01:40:00.239 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 01:50:00.158 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 01:50:00 auf true gesetzt. 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 655292677 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 655292696 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 01:50:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 1:50 Uhr bis 17:00 Uhr 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 01:50:00.244 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 47 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 9:54 h / 4:39 h 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2363 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -594 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 16 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 01:50:00.245 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 01:50:00.246 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 01:50:00.246 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 02:00:00.194 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 02:00:00 auf true gesetzt. 2024-09-25 02:00:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 02:00:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 655612638 2024-09-25 02:00:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 655612660 2024-09-25 02:00:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 02:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:00:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:00:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 2:00 Uhr bis 17:00 Uhr 2024-09-25 02:00:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 02:00:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 46 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 10:42 h / 4:37 h 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2328 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -564 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 8 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 02:00:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 02:00:00.293 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 02:00:00.293 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 02:00:00.293 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 02:10:00.207 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 02:10:00 auf true gesetzt. 2024-09-25 02:10:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 02:10:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 655945910 2024-09-25 02:10:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 655945929 2024-09-25 02:10:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 02:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:10:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:10:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 2:10 Uhr bis 17:00 Uhr 2024-09-25 02:10:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 02:10:00.291 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 0.11040772106814956 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 45 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 6:34 h / 3:46 h 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2328 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -864 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 10124 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 02:10:00.292 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 02:10:00.293 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 02:10:00.293 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 02:10:00.293 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 02:20:00.102 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 02:20:00 auf true gesetzt. 2024-09-25 02:20:00.219 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 02:20:00.219 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 656279413 2024-09-25 02:20:00.219 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 656279439 2024-09-25 02:20:00.219 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 02:20:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:20:00.219 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:20:00.219 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 2:20 Uhr bis 17:00 Uhr 2024-09-25 02:20:00.219 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 02:20:00.219 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 44 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 6:25 h / 3:44 h 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2328 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -861 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 10042 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 02:20:00.220 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 02:20:00.221 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 02:20:00.221 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 02:30:00.144 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 02:30:00 auf true gesetzt. 2024-09-25 02:30:00.284 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 02:30:00.284 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 656609422 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 656609457 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 02:30:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 2:30 Uhr bis 17:00 Uhr 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 43 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 6:16 h / 3:42 h 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 02:30:00.285 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2328 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -864 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 10110 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 02:30:00.286 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 02:30:00.286 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 02:40:00.144 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 02:40:00 auf true gesetzt. 2024-09-25 02:40:00.228 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 02:40:00.228 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 656936790 2024-09-25 02:40:00.228 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 656936812 2024-09-25 02:40:00.228 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 02:40:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:40:00.228 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:40:00.228 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 2:40 Uhr bis 17:00 Uhr 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 42 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 6:09 h / 3:40 h 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2328 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -864 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 10168 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 02:40:00.229 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 02:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 02:40:00.230 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 02:40:00.230 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 02:50:00.146 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 02:50:00 auf true gesetzt. 2024-09-25 02:50:00.239 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 02:50:00.239 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 657265401 2024-09-25 02:50:00.239 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 657265423 2024-09-25 02:50:00.239 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 02:50:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:50:00.239 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 2:50 Uhr bis 17:00 Uhr 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 41 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 3:38 h / 3:38 h 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 02:50:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2328 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -861 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 10229 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 02:50:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 02:50:00.241 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 03:00:00.157 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 03:00:00 auf true gesetzt. 2024-09-25 03:00:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 03:00:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 657589618 2024-09-25 03:00:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 657589639 2024-09-25 03:00:00.250 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 03:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 3:00 Uhr bis 17:00 Uhr 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 40 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 3:38 h / 3:38 h 2024-09-25 03:00:00.251 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2331 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -861 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 10262 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 03:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 03:00:00.252 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 03:10:00.111 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 03:10:00 auf true gesetzt. 2024-09-25 03:10:00.196 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 03:10:00.196 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 657914874 2024-09-25 03:10:00.196 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 657914895 2024-09-25 03:10:00.196 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 03:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 03:10:00.196 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 3:10 Uhr bis 17:00 Uhr 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 39 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 2:45 h / 2:45 h 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 03:10:00.197 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2331 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -861 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 10205 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 03:10:00.198 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 03:10:00.198 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-25 03:20:00.145 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 03:20:00 auf true gesetzt.Ich kann leider nicht den ganzen Zeitraum der Logs wegen der Begrenzung anhängen. Sag bescheid, wenn du mehr brauchst.
@arnod Danke dir Arno, das heisst, meine Easee Wallboxen arbeiten quasi gegen dein Script. Die Versuchen soviel PV Strom wie möglich ins Auto zu laden, hierzu hab ich aus deinem Skript die Sollladeleistung verwendet
Okay, dann muss ich mal überlegen, ob ich da etwas Puffer einbaue, da diese 3000W immer dann als Wert für die Easee Wallboxen Steuerung verwendet wird.
Danke!
Stefan -
@psrelax
Ich brauche nur die LOG Ausgabe um 21:00 Uhr und ca. 21:10 um zu verstehen, warum da geladen wurde.
Wenn möglich noch 7:30 Uhr und 12:00 Uhr, also immer der Bereich wo eine Entscheidung getroffen wurde zum Laden oder Entladesperre.Du kannst dich an BatterieLaden = true / false orientieren und immer den LOG Bereich suchen, wo sich da was geändert hat.
@arnod
Hier bitte
2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 613954522 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 613954565 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Tue Sep 24 2024 05:50:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Tue Sep 24 2024 06:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = Hochpreisphase 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2582 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-24 20:50:00.185 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 2.4526886122525013 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 76 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 10:22 h / 9:21 h 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.3072 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = false 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -942 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -30 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = false 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-24T15:00:00.000Z","Endzeit":"2024-09-24T19:00:00.000Z","StartzeitLokal":"24.9.2024, 17:00:00","EndzeitLokal":"24.9.2024, 21:00:00"} 2024-09-24 20:50:00.186 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-24T04:00:00.000Z","end":"2024-09-24T08:00:00.000Z","averagePrice":0.33075,"startLocale":"24.9.2024, 06:00:00","endLocale":"24.9.2024, 10:00:00"},{"start":"2024-09-24T15:00:00.000Z","end":"2024-09-24T19:00:00.000Z","averagePrice":0.319675,"startLocale":"24.9.2024, 17:00:00","endLocale":"24.9.2024, 21:00:00"},{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-24 20:50:00.186 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,23,3, 2024-09-24 21:00:00.231 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 21:00:00 auf true gesetzt. 2024-09-24 21:00:00.323 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-24 21:00:00.323 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 645887328 2024-09-24 21:00:00.323 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 645887350 2024-09-24 21:00:00.323 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Tue Sep 24 2024 21:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-24 21:00:00.323 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-24 21:00:00.323 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 21:00 Uhr bis 17:00 Uhr 2024-09-24 21:00:00.323 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2582 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 2.4526886122525013 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 75 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 10:26 h / 9:19 h 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2819 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -930 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 0 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-24 21:00:00.324 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-24 21:00:00.325 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-24 21:00:00.325 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-24T04:00:00.000Z","end":"2024-09-24T08:00:00.000Z","averagePrice":0.33075,"startLocale":"24.9.2024, 06:00:00","endLocale":"24.9.2024, 10:00:00"},{"start":"2024-09-24T15:00:00.000Z","end":"2024-09-24T19:00:00.000Z","averagePrice":0.319675,"startLocale":"24.9.2024, 17:00:00","endLocale":"24.9.2024, 21:00:00"},{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-24 21:00:00.325 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-24 21:10:00.145 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 21:10:00 auf true gesetzt. 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 646218385 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 646218407 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Tue Sep 24 2024 21:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 21:10 Uhr bis 17:00 Uhr 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2582 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-24 21:10:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 2.4526886122525013 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 74 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 10:05 h / 8:35 h 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2819 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -942 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 0 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-24 21:10:00.235 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-24T04:00:00.000Z","end":"2024-09-24T08:00:00.000Z","averagePrice":0.33075,"startLocale":"24.9.2024, 06:00:00","endLocale":"24.9.2024, 10:00:00"},{"start":"2024-09-24T15:00:00.000Z","end":"2024-09-24T19:00:00.000Z","averagePrice":0.319675,"startLocale":"24.9.2024, 17:00:00","endLocale":"24.9.2024, 21:00:00"},{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-24 21:10:00.235 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10, 2024-09-24 21:20:00.186 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 21:20:00 auf true gesetzt. 2024-09-24 21:20:00.270 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 646548536 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 646548555 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Tue Sep 24 2024 21:20:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = 21:20 Uhr bis 17:00 Uhr 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2582 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-24 21:20:00.282 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 2.4526886122525013 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 73 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 10:42 h / 8:33 h 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2819 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -849 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -19 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-24 21:20:00.283 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-24T04:00:00.000Z","end":"2024-09-24T08:00:00.000Z","averagePrice":0.33075,"startLocale":"24.9.2024, 06:00:00","endLocale":"24.9.2024, 10:00:00"},{"start":"2024-09-24T15:00:00.000Z","end":"2024-09-24T19:00:00.000Z","averagePrice":0.319675,"startLocale":"24.9.2024, 17:00:00","endLocale":"24.9.2024, 21:00:00"},{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-24 21:20:00.283 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,2,7,1,22,3,6,10,10,10,2024-09-25 07:20:00.232 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 07:20:00.232 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 665657137 2024-09-25 07:20:00.232 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 665657159 2024-09-25 07:20:00.232 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 07:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = Laden mit PV-Leistung 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 19 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 4:35 h / 0:57 h 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 07:20:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2858 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -519 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -9 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 07:20:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 07:20:00.234 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,7,1,22,14, 2024-09-25 07:30:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 07:30:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 665657137 2024-09-25 07:30:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 665657159 2024-09-25 07:30:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 07:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 07:30:00.240 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = Laden mit PV-Leistung 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 18 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 5:02 h / 1:10 h 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 07:30:00.241 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2858 2024-09-25 07:30:00.242 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 07:30:00.242 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 07:30:00.242 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -420 2024-09-25 07:30:00.242 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 6 2024-09-25 07:30:00.242 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 07:30:00.242 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 07:30:00.242 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 07:30:00.242 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 07:30:00.242 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,7,1,22,14, 2024-09-25 07:40:00.232 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 07:40:00.232 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 665657137 2024-09-25 07:40:00.232 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 665657159 2024-09-25 07:40:00.232 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 07:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = Laden mit PV-Leistung 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 41.587199999999996 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 18 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 7:11 h / 1:19 h 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 07:40:00.233 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2858 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = -294 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 11 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 07:40:00.234 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 07:40:00.234 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,7,1,22,14,2024-09-25 11:50:00.188 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 665657137 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 665657159 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 07:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = Laden mit PV-Leistung 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 11:50:00.189 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 36.09284004808893 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 79 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 8:32 h / 8:32 h 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2162 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = true 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = 1152 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -5783 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 11:50:00.190 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 11:50:00.190 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 4,5,7,1,22,14, 2024-09-25 11:53:57.699 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 11:53:57 auf false gesetzt. 2024-09-25 12:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 12:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 665657137 2024-09-25 12:00:00.252 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 665657201 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 07:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = Laden mit PV-Leistung 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 36.09284004808893 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 80 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 8:32 h / 8:32 h 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 12:00:00.253 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2089 2024-09-25 12:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 12:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = false 2024-09-25 12:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = 1176 2024-09-25 12:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -2220 2024-09-25 12:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 12:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 12:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 12:00:00.254 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 12:00:00.254 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 10,4,5,2,7,1,22,14, 2024-09-25 12:01:29.857 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 12:01:29 auf false gesetzt. 2024-09-25 12:09:12.046 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 12:09:11 auf false gesetzt. 2024-09-25 12:10:00.211 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ******************* Debug LOG Tibber Skript Version 1.1.2 ******************* 2024-09-25 12:10:00.211 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds1 = 665657137 2024-09-25 12:10:00.211 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerIds2 = 665657201 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget1 = Wed Sep 25 2024 07:10:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: timerTarget2 = Wed Sep 25 2024 17:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = max SOC erreicht 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2085 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis = 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis = 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: PrognoseBerechnung_kWh_heute = 36.09284004808893 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 82 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 8 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 8:32 h / 8:32 h 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.1057 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.1057 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: aktuellerPreisTibber = 0.2089 2024-09-25 12:10:00.212 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: bEntladenSperren = false 2024-09-25 12:10:00.213 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = false 2024-09-25 12:10:00.213 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = 1200 2024-09-25 12:10:00.213 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: Power_Grid = -3557 2024-09-25 12:10:00.213 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true 2024-09-25 12:10:00.213 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null} 2024-09-25 12:10:00.213 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":"2024-09-25T15:00:00.000Z","Endzeit":"2024-09-25T20:00:00.000Z","StartzeitLokal":"25.9.2024, 17:00:00","EndzeitLokal":"25.9.2024, 22:00:00"} 2024-09-25 12:10:00.213 - info: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[{"start":"2024-09-25T15:00:00.000Z","end":"2024-09-25T20:00:00.000Z","averagePrice":0.34985999999999995,"startLocale":"25.9.2024, 17:00:00","endLocale":"25.9.2024, 22:00:00"}],"lowPhases":[]} 2024-09-25 12:10:00.213 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 10,10,4,5,2,7,1,22,14, 2024-09-25 12:16:46.162 - warn: javascript.0 (208) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieLaden wurde um 12:16:46 auf false gesetzt. -
Noch etwas.
Ich bekomme seit gestern den ähnlichen Fehler, den du vor ein paar Posts mit "getTime" behoben hast.
script.js.E3DC_ChargeControl.Tibber: Fehler in Funktion tibberSteuerungHauskraftwerk: Cannot read properties of null (reading 'getHours')
