    4. Adapter: Amtron Wallbox
    • Rene_HM
      Rene_HM Developer last edited by Rene_HM
      Für die Mennekes Amtron Wallbox gibt es nun einen Adapter für ioBroker.
      Features:
      • Lesen von System- und Status-Informationen
      • derzeit wird die REST API unterstützt. Diese bietet nur das Lesen von Daten.
      • getestet auf einer AMTRON Charge Control 11 C2
      to do:
      • Erweiterung auf andere Typen von Amtron
      • Schreiben von Daten
      Der Adapter kann über github oder NPM installiert werden.
      Für feedback, Anregungen und Testergebnisse wäre ich dankbar...
      D L 3 Replies Last reply Reply Quote 0
        dorsen @Rene_HM last edited by dorsen
        @rene_hm Danke für den tollen Adapter! 👍
        Aktuell bekomme ich für meine Charge Control folgende Hinweise im Log:
        info State value to set for "amtronwallbox.0.Charge Control.CableAttached" has to be type "boolean" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.MaxCurrent" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.ContactcyclesType2" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.ContactCyclesSchuko" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.EnergyManagerCurrent" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.Current" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.FreeCharging" has to be type "boolean" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.SigCurrent" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.Transaction" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.Power" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.Meter" has to be type "number" but received type "string"
        info State value to set for "amtronwallbox.0.Charge Control.TimeSinceChargingStart" has to be type "number" but received type "string"
          @rene_hm Wo hast du die API Dokumentation gefunden? Ich finde bei Mennekes leider nichts 😞
          • Rene_HM
            Rene_HM Developer @dorsen last edited by
            @dorsen sagte in Adapter: Amtron Wallbox:
            ja, die sind in der nächsten Version behoben.
            Es gibt zwei verschieden API:
            1. die Version für die Wallbox mit App (also die teure Variante der Box)
              Dort wird diese REST Api verwendet. Hier kann man auch den Ladestrom beeinflussen.
            2. die "billige" Version der Wallbox ohne App (die habe leider ich 😞 )
              Dort wird diese REST Api verwendet und das ist aktuell auch im Adapter implementiert. Leider kann man hier den Ladestrom nicht beeinflussen. Ich hoffe, das geht dann mit SMA Semp
            • Rene_HM
              Es gibt eine neue Version des Adapters auf github.
              Diese Version unterstützt nun die RestAPI und damit auch die XTRA, Premium usw.
              Derzeit werden folgende Daten gelesen:
              • allgemeine Geräte-Informationen
              • Ladedaten
              • Statistik-Daten
              Im nächsten step kommt dann noch das Schreiben der Daten (z.Bsp. max. Ladestrom).
              Achtung Die Auswahl des Gerätetypes in der Geräte-Liste ist nicht schön lesbar. Einfach ein wenig hoch und runtersrcollen:
              • icebear
                icebear last edited by icebear
                Hallo, ich hab jetzt auch mal den Adapter installiert und hab eine kurze Frage.
                Was ist mit API-Schlüssel gemeint? Was muß ich da eintragen?
                WB= Amtron xtra C11 mit App
                EDIT: Hat sich erledigt, hatte mich nur verschrieben beim API-Schlüssel, jetzt gehts
                  helpme @icebear last edited by helpme
                  @icebear said in Adapter: Amtron Wallbox:
                  Hallo zusammen, hab gerade auch den Adapter installiert.
                  Was ist mit API Schlüssel gemeint? Ist das die PIN1 von der Wallbox?
                  Wenn ich diese eingebe, werden mir allerdings keine Daten im Apdater angezeigt.
                  Amtron xtra 11
                  icebear 1 Reply Last reply Reply Quote 0
                  • icebear
                    icebear @helpme last edited by icebear
                    @helpme said in Adapter: Amtron Wallbox:
                    Ja das ist die PIN
                    Name, IP und Typ sind richtig eingetragen?
                      jrichl @Rene_HM last edited by
                      @rene_hm
                      Hallo, ich habe den Adapter jetzt auch einmal installiert, und er funktioniert auf meiner XTRA soweit auch gut. Ich wollte nur nachfragen ob inzwischen auch das Schreiben von Daten - also der Ladestrom implementiert ist? Einen entsprechenden Datenpunkt dazu kann ich nicht finden.
                      Oder ist das ActPwr der entsprechend gesetzt werden muss?
                        goudi last edited by
                        Hy, ich habe die Amtron Professional mit Firmwarestand 5.22.5
                        Nach diesem Link habe ich die REST api aktiviert und kann wie auch auslesen.
                        https://www.adminlabs.de/mennekes-amtron-wallbox-api-auslesen/
                        Aber ich bekomme leider keine Verbindung im IObroker. Wo ist um alles in der Welt die PIN einzustellen?
                        Noch ne Frage zur Anwendung:
                        Kann ich über IObroker dann irgendwann die Energiesteuerung (Überschussladen) einstellen?
                        Kann ich je nach Authorisierung mit unterschiedlichen RFID Chips zwischen "normalem Laden" und "überschussladen" umschalten?
                        Sollte das jetzt schon gehen, würde ich mich freuen wenn mir jemand verrät wie...
                        • icebear
                          icebear @goudi last edited by
                          @goudi said in Adapter: Amtron Wallbox:
                          Hier:
                            goudi @icebear last edited by
                            @icebear Vielen Dank für den Hinweis,
                            im Iobroker ist mir das klar - aber nicht in der BOX - Oberfläche - dort finde ich eine solche Angabe nicht.
                            Ich hoffe, mir kann das jemand auf der anderen Seite auch zeigen.
                            liebe Grüße
                            • icebear
                              Ah, Sorry ich hab grad mal nachgeschaut und gesehen das die Amtron Professional mit einer anderen Oberfläche arbeitet als die Xtra.
                              Ich weiß nicht ob der Adapter mit der Professional funktioniert, da mußte den Adapter Entwickler fragen, am besten im Git-Hub.
                              Du kannst ja versuchen was passiert wenn du in den Einstellungen auf der Box bei 'Rest-Schnittstelle' einstellen kannst, also vielleicht ohne UUID
                                Lennerocker @Rene_HM last edited by
                                ich bin seit gestern Besitzer einer Mennekes Amtron 4you 500, die ich auch in iobroker einbinden will. Bei der Suche nach einem passenden Adapter bin ich auf deinen gestoßen. Installation ohne Probleme. Die Instanz ist aktiviert (verbunden mit Host, Lebenszeichen). Danach aber eine Fehlermeldung: exception in read_rest [Error: connect ETIMEDOUT
                                Kann es sein, dass der Adapter für meine Box nicht funktioniert oder mache ich da einen grundlegenden Fehler?
                                VG Bernard
                                @rene_hm said in Adapter: Amtron Wallbox:
                                Features:
                                to do:
                                • Rene_HM
                                  Rene_HM Developer @Lennerocker last edited by
                                  @lennerocker
                                  Die Amtron 4you 500 kenne ich noch gar nicht, deshalb gehe ich erst mal davon aus, dass sie noch nicht unterstützt wird. Wir müssen also erst mal herausfinden, wie man mit dem Teil reden muss.
                                  Wenn die Box die RestApi unterstützt, du dieses Interface aktiviert hast, könnte sie als Type "ChargeControl"
                                  funktionieren.
                                  Du kannst aber auch testweise im browser mal diese URL aufrufen (natürlich mit der IP, wie sie bei dir im Netzwerk eingerichtet ist)
                                  http:// DEINE_IP /rest/full_state
                                    @rene_hm
                                    mit dem Link startet das Webinterface der Box mit der Loginaufforderung. Im Protokollbereich wird für den erfolgreichen Loginversuch die Event-ID REST_API-2 angegeben. Kannst Du damit was anfangen?
                                      jokeras @jrichl last edited by
                                      @jrichl
                                      Ich habe auch die Xtra 11 C2. Im Folder charge habe ich allerdings nur "null" Daten. Im Folder info sind Daten da. Aber eben nicht die Total Energy, die ich gern auslesen würde.
                                      Was hast du im Adapter eingestellt? IP + PIN 1 (App PIN)?
                                      2040
