    4. Adapter-Updates über die Weboberfläche ausgegraut ...
    • MartinP
      MartinP @haus-automatisierung last edited by
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: iobroker-test-sicher
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-1-pve
          Architecture: x86-64
      grep: /proc/cpuinfo: Transport endpoint is not connected
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      uptime: Cannot get system uptime: Transport endpoint is not connected
      CPU threads:
      *** Time and Time Zones ***
                     Local time: Mon 2024-09-16 13:31:51 CEST
                 Universal time: Mon 2024-09-16 11:31:51 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      martin
      HOME=/home/martin
      GROUPS=martin sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      free: Unable to create meminfo structure
      Active iob-Instances:   23
      vmstat: Unable to create system stat structure
      Tasks:  51 total,   6 running,  45 sleeping,   0 stopped,   0 zombie
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
        23858 iobroker  20   0   21.5g 304908  18816 R     ?     ?     29,39 iobroke+
        23983 iobroker  20   0   21.1g  60184  17024 R     ?     ?     11,06 io.sono+
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** FILESYSTEM ***
      df: /proc/cpuinfo: Transport endpoint is not connected
      df: /proc/diskstats: Transport endpoint is not connected
      df: /proc/loadavg: Transport endpoint is not connected
      df: /proc/meminfo: Transport endpoint is not connected
      df: /proc/slabinfo: Transport endpoint is not connected
      df: /proc/stat: Transport endpoint is not connected
      df: /proc/swaps: Transport endpoint is not connected
      df: /proc/uptime: Transport endpoint is not connected
      df: /sys/devices/system/cpu: Transport endpoint is not connected
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0 ext4       63G   20G   40G  34% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  128K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     780M     0  780M   0% /run/user/1000
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                                  SOURCE                           FSTYPE     OPTIONS
      /                                                       /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=1595988k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=797992k,nr_inodes=199498,mode=700,uid=101000,gid=101000,inode64
      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
      | `-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | | `-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      3.9G    /var/
      2.1G    /var/lib
      1.9G    /var/lib/influxdb/engine/data/f11825691705bf53/autogen
      Archived and active journals take up 144.8M in the file system.
      /opt/iobroker/backups:
      9.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      841M    /opt/iobroker/iobroker-data/
      710M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
       *** 20.17.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://ftp.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.0.23
      javascript:     8.7.6
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-test-sicher                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker-test-sicher                     -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-test-sicher                     -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-test-sicher                     -  enabled
      + system.adapter.email.0                  : email                 : iobroker-test-sicher                     -  enabled
        system.adapter.fahrplan.0               : fahrplan              : iobroker-test-sicher                     - disabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-test-sicher                     -  enabled
        system.adapter.frigate.0                : frigate               : iobroker-test-sicher                     - disabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker-test-sicher                     -  enabled
        system.adapter.ical.0                   : ical                  : iobroker-test-sicher                     -  enabled
        system.adapter.ical.1                   : ical                  : iobroker-test-sicher                     -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker-test-sicher                     -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobroker-test-sicher                     -  enabled
      + system.adapter.javascript.1             : javascript            : iobroker-test-sicher                     -  enabled
      + system.adapter.meross.0                 : meross                : iobroker-test-sicher                     -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-test-sicher                     -  enabled, port: 1888
        system.adapter.mqtt-client.1            : mqtt-client           : iobroker-test-sicher                     - disabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-test-sicher                     -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : iobroker-test-sicher                     - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.operating-hours.0        : operating-hours       : iobroker-test-sicher                     -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker-test-sicher                     -  enabled
      + system.adapter.reolink.0                : reolink               : iobroker-test-sicher                     -  enabled
      + system.adapter.reolink.1                : reolink               : iobroker-test-sicher                     -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker-test-sicher                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.snmp.0                   : snmp                  : iobroker-test-sicher                     -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker-test-sicher                     -  enabled, port: 1892, bind: 0.0.0.0
      + system.adapter.tradfri.0                : tradfri               : iobroker-test-sicher                     -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker-test-sicher                     -  enabled
        system.adapter.vis.0                    : vis                   : iobroker-test-sicher                     -  enabled
      + system.adapter.web.0                    : web                   : iobroker-test-sicher                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.23   , installed 7.0.23
      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
      Adapter    "benchmark"    : 1.3.0    , installed 1.3.0
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "frigate"      : 1.2.0    , installed 1.2.1
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
      Adapter    "operating-hours": 1.1.0  , installed 1.1.0
      Adapter    "reolink"      : 1.1.1    , installed 1.1.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
      Objects and States
      Objects:        2772
      States:         2335
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://ftp.debian.org/debian bookworm InRelease
      Hit:3 http://ftp.debian.org/debian bookworm-updates InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Reading package lists...
      Pending Updates: 2
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       47038856   23858/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       47038215   23858/iobroker.js-c
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          47037918   23855/master
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       47049804   23972/io.mqtt.0
      tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       47048784   23983/io.sonoff.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          37062479   1/systemd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       47050706   24087/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47039488   23882/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        37086061   171/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       47049402   24111/io.simple-api
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        37086634   362/grafana
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          47037919   23855/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          37062481   1/systemd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          37064689   1/systemd
      udp        0      0 0.0.0.0:51509           0.0.0.0:*                           1001       47049328   24104/io.tradfri.0
      udp        0      0 0.0.0.0:43417           0.0.0.0:*                           1001       47050914   24049/io.snmp.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          37062480   1/systemd
      udp6       0      0 :::111                  :::*                                0          37062482   1/systemd
      2024-09-16 13:25:43.727  - debug: backitup.0 (165255) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-09-16 13:25:43.818  - debug: backitup.0 (165255) States create System PubSub Client
      2024-09-16 13:25:43.830  - debug: backitup.0 (165255) States create User PubSub Client
      2024-09-16 13:25:44.093  - debug: backitup.0 (165255) States connected to redis: 127.0.0.1:9000
      2024-09-16 13:25:44.096  - silly: backitup.0 (165255) statesDB connected
      2024-09-16 13:25:44.177  - debug: backitup.0 (165255) Plugin sentry Initialize Plugin (enabled=true)
      2024-09-16 13:25:45.300  - info: backitup.0 (165255) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
      2024-09-16 13:25:45.334  - debug: backitup.0 (165255) BackItUp has recognized a linux system
      2024-09-16 13:25:45.387  - silly: backitup.0 (165255) States system redis pmessage system.adapter.backitup.0.logLevel/system.adapter.backitup.0.logLevel:{"val":"silly","ack":true,"ts":1726485945363,"q":0,"from":"system.adapter.backitup.0","lc":1692783464076}
      2024-09-16 13:25:45.449  - info: backitup.0 (165255) [iobroker] backup will be activated at 02:40 every 1 day(s)
      2024-09-16 13:25:45.592  - debug: backitup.0 (165255) [iobroker] 10 40 02 */1 * *
      2024-09-16 13:25:45.600  - debug: backitup.0 (165255) No backup file was found
      2024-09-16 13:27:08.895  - info: admin.0 (23882) <== Disconnect system.user.admin from ::ffff:192.168.2.115 admin
      2024-09-16 13:27:09.802  - info: admin.0 (23882) ==> Connected system.user.admin from ::ffff:192.168.2.115
      2024-09-16 13:27:17.395  - error: host.iobroker-test-sicher cannot get getHostInfo: Cannot read properties of undefined (reading 'speed')
      2024-09-16 13:29:59.167  - info: admin.0 (23882) <== Disconnect system.user.admin from ::ffff:192.168.2.115 admin
      2024-09-16 13:29:59.268  - info: admin.0 (23882) ==> Connected system.user.admin from ::ffff:192.168.2.115
      2024-09-16 13:29:59.292  - info: admin.0 (23882) <== Disconnect system.user.admin from ::ffff:192.168.2.115 admin
      2024-09-16 13:30:00.429  - info: host.iobroker-test-sicher instance system.adapter.ical.0 in version "1.15.0" started with pid 165326
      2024-09-16 13:30:01.177  - info: admin.0 (23882) ==> Connected system.user.admin from ::ffff:192.168.2.115
      2024-09-16 13:30:17.048  - error: host.iobroker-test-sicher cannot get getHostInfo: Cannot read properties of undefined (reading 'speed')
      2024-09-16 13:30:18.975  - info: ical.0 (165326) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.17.0, js-controller: 6.0.11
      2024-09-16 13:30:22.684  - info: ical.0 (165326) processing URL: Martin_docker http://192.168.2.146:5232/martin/e4c584bc-2ea6-bae6-1d4e-debe6a702f21/
      2024-09-16 13:30:28.829  - info: ical.0 (165326) Terminated (NO_ERROR): Without reason
      2024-09-16 13:30:29.385  - info: host.iobroker-test-sicher instance system.adapter.ical.0 having pid 165326 terminated with code 0 (NO_ERROR)
      MartinP Ro75 Thomas Braun 3 Replies Last reply Reply Quote 0
      • MartinP
        MartinP @MartinP last edited by
        ebdddcd1-a0f1-4d9c-8cf1-c52100f96bf8-grafik.png @martinp
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          Ro75 @MartinP last edited by
          @martinp sagte in Adapter-Updates über die Weboberfläche ausgegraut ...:
          laut dem hier aktuell, gar kein Update notwendig.
          sollte sicherlich nicht sein - habe darauf keine Antwort.
          Ro75.
          • Ro75
            @martinp starte mal die Kiste komplett durch.
            Ro75.
            • MartinP
              MartinP @Ro75 last edited by
              @ro75 hatte das mit "iob update" und "iob upgrade" einfach old shool über die Konsole gemacht ...
              inzwischen auch iob stop, iob fix und iob start absolviert ...
              • MartinP
                @martinp nach iob start
                	2024-09-16 13:45:39.502	error	cannot get getHostInfo: Cannot read properties of undefined (reading 'speed')
                	2024-09-16 13:45:15.064	error	Caught by controller[0]: [pidusage] We couldn't find uptime from /proc/uptime, using os.uptime() value
                  Thomas Braun Most Active @MartinP last edited by
                  Wenn ich mir die ganzen 'obskuren' Meldungen anschaue würde ich sagen, der Container rumpelt da irgendwie ein kleinwenig neben der Spur.
                  • MartinP
                    MartinP @Thomas Braun last edited by
                    @thomas-braun Habe ihn gerade mal neu gestartet ...
                    Jetzt ist alles wieder ok...
                      @martinp
                      Und die ganzen Meldungen/Testfelder aus
                      iob diag
                      sind auch wieder wie erwartet?
                      • MartinP
                        MartinP @Thomas Braun last edited by MartinP
                        Nach Quer gucken sieht das gut aus ... (bis auf die MQTT Adapter Probleme)
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        model name      : Intel(R) Celeron(R) CPU  N3000  @ 1.04GHz
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         14:00:14 up 11 min,  2 users,  load average: 50.09, 49.87, 49.65
                        CPU threads: 2
                                       Local time: Mon 2024-09-16 14:00:14 CEST
                                   Universal time: Mon 2024-09-16 12:00:14 UTC
                                         RTC time: n/a
                                  RTC in local TZ: no
                        martin
                        HOME=/home/martin
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:            6.4G        2.0G        3.7G        118K        808M        4.5G
                        Swap:           6.4G          0B        6.4G
                        Total:           12G        2.0G         10G
                                 6144 M total memory
                                 1872 M used memory
                                 2145 M active memory
                                  394 M inactive memory
                                 3500 M free memory
                                    0 M buffer memory
                                  771 M swap cache
                                 6144 M total swap
                                    0 M used swap
                                 6144 M free swap
                        top - 14:00:14 up 11 min,  2 users,  load average: 50.09, 49.87, 49.65
                        Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 25.0 us, 25.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   6144.0 total,   3498.8 free,   1874.1 used,    771.3 buff/cache
                        MiB Swap:   6144.0 total,   6144.0 free,      0.0 used.   4269.9 avail Mem
                        *** FILESYSTEM ***
                        /dev/mapper/pve-vm--101--disk--0 ext4       63G   20G   40G  33% /
                        tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
                        | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                        | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                        | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                        /var:
                        3.9G    /var/
                        2.1G    /var/lib
                        827M    /opt/iobroker/iobroker-data/
                        15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.map
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          7.0.23
                        javascript:     8.7.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2779
                        States:         2351
                        Hit:1 http://ftp.debian.org/debian bookworm InRelease
                        Hit:2 http://ftp.debian.org/debian bookworm-updates InRelease
                        Hit:3 http://security.debian.org bookworm-security InRelease
                        Hit:4 https://repos.influxdata.com/debian stable InRelease
                        Hit:5 https://apt.grafana.com stable InRelease
                        Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          108794370  1/init
                        tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       108813845  525/io.sonoff.0
                        tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       108812050  498/io.mqtt.0
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          108803046  348/master
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       108805140  368/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       108805058  368/iobroker.js-con
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          108794372  1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          108794682  1/init
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          108803047  348/master
                        tcp6       0      0 :::3000                 :::*                    LISTEN      109        108804726  367/grafana
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       108816478  687/io.simple-api.0
                        tcp6       0      0 :::8086                 :::*                    LISTEN      998        108803748  172/influxd
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       108805796  417/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       108816757  669/io.web.0
                        udp        0      0 0.0.0.0:46184           0.0.0.0:*                           1001       108815704  676/io.tradfri.0
                        udp        0      0 0.0.0.0:40879           0.0.0.0:*                           1001       108815883  587/io.snmp.0
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          108794371  1/init
                        udp6       0      0 :::111                  :::*                                0          108794373  1/init
                        2024-09-16 13:59:42.757  - info: admin.0 (417) ==> Connected system.user.admin from ::ffff:192.168.2.115
                        2024-09-16 13:59:45.755  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 4 deleted after 12 retries
                        2024-09-16 13:59:45.755  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 3 deleted after 12 retries
                        2024-09-16 14:00:00.074  - info: host.iobroker-test-sicher instance system.adapter.ical.0 in version "1.15.0" started with pid 1500
                        2024-09-16 14:00:00.226  - info: javascript.0 (455) script.js.Energiezaehler.Gaszaehler: Actual Pulses 137474 Last Pulses 137469 =0.557
                        2024-09-16 14:00:06.909  - info: ical.0 (1500) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.17.0, js-controller: 6.0.11
                        2024-09-16 14:00:09.415  - info: ical.0 (1500) processing URL: Martin_docker http://192.168.2.146:5232/martin/e4c584bc-2ea6-bae6-1d4e-debe6a702f21/
                        2024-09-16 14:00:09.776  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:00:14.925  - info: ical.0 (1500) Terminated (NO_ERROR): Without reason
                        2024-09-16 14:00:15.529  - info: host.iobroker-test-sicher instance system.adapter.ical.0 having pid 1500 terminated with code 0 (NO_ERROR)
                        2024-09-16 14:00:15.781  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:00:17.792  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:00:19.783  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:00:21.782  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:00:22.567  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connection closed: closed
                        2024-09-16 14:00:31.955  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connected with secret 1726488031944_3480
                        2024-09-16 14:00:31.974  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] Received pubrec on esp32-e0624b304ec0 for unknown messageId 1
                        2024-09-16 14:00:59.831  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:01:05.833  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:01:09.833  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:01:11.835  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:01:11.836  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
                        2024-09-16 14:01:12.577  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connection closed: closed
                        2024-09-16 14:01:21.946  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connected with secret 1726488081946_210
                        2024-09-16 14:01:21.953  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] Received pubrec on esp32-e0624b304ec0 for unknown messageId 1
                        • Ro75
                          wirklich?
                          Ro75.
                          MartinP 1 Reply Last reply Reply Quote 1
                          • MartinP
                            MartinP @Ro75 last edited by MartinP
                            @ro75 Ist ein LXC-Container, habe nicht PVE rebootet, sondern nur den Container über die PVE Weboberfläche.... die Weboberfläche von iob war jedenfalls nicht erreichbar 😉
                            EDIT ich sehe da 11 Minuten uptime ...
                            14:10:46 up 22 min,  1 user,  load average: 47.30, 48.30, 49.00
                            Der erste Wert ist wohl die aktuelle Uhrzeit
                              Da geht es eher drum. Wobei so eine Load auf 'Haushaltsware' auch eher unrealistisch ist.
                              • MartinP
                                @thomas-braun Ist eine ziemlich lahme Kiste, ein Celeron N3000 spielt etwa in der Liga eines Pi4 ...
                                Proxmox selber zeigt etwas niedrigere "Fieberkurven" für den LXC-Container
                                Kann es sein, dass bei einem LXC-Container da falsch angezeigt wird - das wird im PVE selber angezeigt:
                                EDIT: Das sind die gehosteten VMs / LXC
                                • MartinP
                                  Schade, die Zigbee2mqtt VM scheint das Zeitliche gesegnet zu haben - sieht gestartet aus, ist aber per IP nicht erreichbar...
                                    Homoran Global Moderator Administrators @MartinP last edited by Homoran
                                    naja, über 2 oder 4 (je nach CPU) sollte der Wert nicht liegen
                                    • MartinP
                                      MartinP @Homoran last edited by
                                      @homoran said in Adapter-Updates über die Weboberfläche ausgegraut ...:
                                      Sind das keine Prozentwerte?
                                      Der Celeron N3000 hat eben je nach Benchmark nur etwa 1/5 ... 1/10 der Performance eines Intel N100 ...
                                      da werden aus 2...4 auf dem N100 eben 10...40%....
                                      Der LXC-Container selber scheint sich auch die prognostizierten 10 ... 40% zu gönnen 🙂
                                        Normalerweise nicht.
                                        die load average ist nicht %CPU
                                        Bei der load average sollte der Wert nicht die Anzahl der Kerne überschreiten.
                                        Ab da ist Abarbeitungsrückstau.
                                        EDIT: Was du da zeigst ist tatsächlich %CPU!
                                        iob diag zeigt aber die load average der letzten, der letzten 5 und der letzten 15 Minuten an
                                        • MartinP
                                          MartinP @Homoran last edited by MartinP
                                          @homoran Ja, der Wert ist SEHR hoch ....
                                          https://wiki.ubuntuusers.de/uptime/
                                          Zwei Kerne -> nicht viel höher als 2 wäre das Ziel ...
                                          Vielleicht schlage ich dann doch mal zu, wenn irgendwann ein Hardware "Schnapper" vor die Flinte kommt ...
                                          Entweder ein gebrauchter sparsamer i5 oder ein N100 ...
                                          Das ist aus dem PVE Hauptfenster und DEFINITIV dieser "Load Avg." Wert und keine Prozente... dauerhaft auf 45 ...50 ...
                                            ich tippe da aber auf eine Fehlanzeige/Softwareproblem.
                                            Bei 2 Kernen würdest du wahrscheinlich bei einer Load von 5 schon nicht mehr auf den Server kommen.
                                            526
