    4. Adapter-Updates über die Weboberfläche ausgegraut ...
    • MartinP
      MartinP @Thomas Braun last edited by
      @thomas-braun Habe ihn gerade mal neu gestartet ...
      Jetzt ist alles wieder ok...
        Thomas Braun Most Active @MartinP last edited by
        @martinp
        Und die ganzen Meldungen/Testfelder aus
        iob diag
        sind auch wieder wie erwartet?
        • MartinP
          MartinP @Thomas Braun last edited by MartinP
          Nach Quer gucken sieht das gut aus ... (bis auf die MQTT Adapter Probleme)
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: iobroker-test-sicher
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-1-pve
              Architecture: x86-64
          model name      : Intel(R) Celeron(R) CPU  N3000  @ 1.04GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           14:00:14 up 11 min,  2 users,  load average: 50.09, 49.87, 49.65
          CPU threads: 2
          *** Time and Time Zones ***
                         Local time: Mon 2024-09-16 14:00:14 CEST
                     Universal time: Mon 2024-09-16 12:00:14 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          martin
          HOME=/home/martin
          GROUPS=martin sudo iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            6.4G        2.0G        3.7G        118K        808M        4.5G
          Swap:           6.4G          0B        6.4G
          Total:           12G        2.0G         10G
          Active iob-Instances:   23
                   6144 M total memory
                   1872 M used memory
                   2145 M active memory
                    394 M inactive memory
                   3500 M free memory
                      0 M buffer memory
                    771 M swap cache
                   6144 M total swap
                      0 M used swap
                   6144 M free swap
          top - 14:00:14 up 11 min,  2 users,  load average: 50.09, 49.87, 49.65
          Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 25.0 us, 25.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   6144.0 total,   3498.8 free,   1874.1 used,    771.3 buff/cache
          MiB Swap:   6144.0 total,   6144.0 free,      0.0 used.   4269.9 avail Mem
          *** FAILED SERVICES ***
            UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
          * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
          * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          3 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--101--disk--0 ext4       63G   20G   40G  33% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
          tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          dmesg: read kernel buffer failed: Operation not permitted
          Show mounted filesystems:
          TARGET                                                  SOURCE                           FSTYPE     OPTIONS
          /                                                       /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
          |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=1595988k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
          | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
          | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
          | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
          |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
          | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
          | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
          | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
          | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
          | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
          | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
          | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
          | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
          | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
          | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
          | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
          | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
          | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
          | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
          | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
          | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
            |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
            |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
            |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
            `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          3.9G    /var/
          2.1G    /var/lib
          1.9G    /var/lib/influxdb/engine/data/f11825691705bf53/autogen
          Archived and active journals take up 144.8M in the file system.
          /opt/iobroker/backups:
          9.1G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          827M    /opt/iobroker/iobroker-data/
          710M    /opt/iobroker/iobroker-data/files
          441M    /opt/iobroker/iobroker-data/files/javascript.admin
          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
          15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.17.0
          /usr/bin/node           v20.17.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.3
          nodejs:
            Installed: 20.17.0-1nodesource1
            Candidate: 20.17.0-1nodesource1
            Version table:
           *** 20.17.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://ftp.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.11
          admin:          7.0.23
          javascript:     8.7.6
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker-test-sicher                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : iobroker-test-sicher                     -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker-test-sicher                     -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker-test-sicher                     -  enabled
          + system.adapter.email.0                  : email                 : iobroker-test-sicher                     -  enabled
            system.adapter.fahrplan.0               : fahrplan              : iobroker-test-sicher                     - disabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-test-sicher                     -  enabled
            system.adapter.frigate.0                : frigate               : iobroker-test-sicher                     - disabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker-test-sicher                     -  enabled
            system.adapter.ical.0                   : ical                  : iobroker-test-sicher                     -  enabled
            system.adapter.ical.1                   : ical                  : iobroker-test-sicher                     -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker-test-sicher                     -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : iobroker-test-sicher                     -  enabled
          + system.adapter.javascript.1             : javascript            : iobroker-test-sicher                     -  enabled
          + system.adapter.meross.0                 : meross                : iobroker-test-sicher                     -  enabled
          + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-test-sicher                     -  enabled, port: 1888
            system.adapter.mqtt-client.1            : mqtt-client           : iobroker-test-sicher                     - disabled, port: 1883
          + system.adapter.mqtt.0                   : mqtt                  : iobroker-test-sicher                     -  enabled, port: 1888, bind: 0.0.0.0
            system.adapter.mqtt.1                   : mqtt                  : iobroker-test-sicher                     - disabled, port: 1883, bind: 0.0.0.0
          + system.adapter.operating-hours.0        : operating-hours       : iobroker-test-sicher                     -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker-test-sicher                     -  enabled
          + system.adapter.reolink.0                : reolink               : iobroker-test-sicher                     -  enabled
          + system.adapter.reolink.1                : reolink               : iobroker-test-sicher                     -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker-test-sicher                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.snmp.0                   : snmp                  : iobroker-test-sicher                     -  enabled
          + system.adapter.sonoff.0                 : sonoff                : iobroker-test-sicher                     -  enabled, port: 1892, bind: 0.0.0.0
          + system.adapter.tradfri.0                : tradfri               : iobroker-test-sicher                     -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker-test-sicher                     -  enabled
            system.adapter.vis.0                    : vis                   : iobroker-test-sicher                     -  enabled
          + system.adapter.web.0                    : web                   : iobroker-test-sicher                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.0.23   , installed 7.0.23
          Adapter    "backitup"     : 3.0.22   , installed 3.0.22
          Adapter    "benchmark"    : 1.3.0    , installed 1.3.0
          Adapter    "deconz"       : 1.4.1    , installed 1.4.1
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
          Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
          Adapter    "frigate"      : 1.2.0    , installed 1.2.1
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.11   , installed 6.0.11
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
          Adapter    "operating-hours": 1.1.0  , installed 1.1.0
          Adapter    "reolink"      : 1.1.1    , installed 1.1.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "snmp"         : 3.2.0    , installed 3.2.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
          Objects and States
          Objects:        2779
          States:         2351
          Hit:1 http://ftp.debian.org/debian bookworm InRelease
          Hit:2 http://ftp.debian.org/debian bookworm-updates InRelease
          Hit:3 http://security.debian.org bookworm-security InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          108794370  1/init
          tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       108813845  525/io.sonoff.0
          tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       108812050  498/io.mqtt.0
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          108803046  348/master
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       108805140  368/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       108805058  368/iobroker.js-con
          tcp6       0      0 :::111                  :::*                    LISTEN      0          108794372  1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          108794682  1/init
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          108803047  348/master
          tcp6       0      0 :::3000                 :::*                    LISTEN      109        108804726  367/grafana
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       108816478  687/io.simple-api.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      998        108803748  172/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       108805796  417/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       108816757  669/io.web.0
          udp        0      0 0.0.0.0:46184           0.0.0.0:*                           1001       108815704  676/io.tradfri.0
          udp        0      0 0.0.0.0:40879           0.0.0.0:*                           1001       108815883  587/io.snmp.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          108794371  1/init
          udp6       0      0 :::111                  :::*                                0          108794373  1/init
          2024-09-16 13:59:42.757  - info: admin.0 (417) ==> Connected system.user.admin from ::ffff:192.168.2.115
          2024-09-16 13:59:45.755  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 4 deleted after 12 retries
          2024-09-16 13:59:45.755  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 3 deleted after 12 retries
          2024-09-16 14:00:00.074  - info: host.iobroker-test-sicher instance system.adapter.ical.0 in version "1.15.0" started with pid 1500
          2024-09-16 14:00:00.226  - info: javascript.0 (455) script.js.Energiezaehler.Gaszaehler: Actual Pulses 137474 Last Pulses 137469 =0.557
          2024-09-16 14:00:06.909  - info: ical.0 (1500) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.17.0, js-controller: 6.0.11
          2024-09-16 14:00:09.415  - info: ical.0 (1500) processing URL: Martin_docker http://192.168.2.146:5232/martin/e4c584bc-2ea6-bae6-1d4e-debe6a702f21/
          2024-09-16 14:00:09.776  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:00:14.925  - info: ical.0 (1500) Terminated (NO_ERROR): Without reason
          2024-09-16 14:00:15.529  - info: host.iobroker-test-sicher instance system.adapter.ical.0 having pid 1500 terminated with code 0 (NO_ERROR)
          2024-09-16 14:00:15.781  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:00:17.792  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:00:19.783  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:00:21.782  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:00:22.567  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connection closed: closed
          2024-09-16 14:00:31.955  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connected with secret 1726488031944_3480
          2024-09-16 14:00:31.974  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] Received pubrec on esp32-e0624b304ec0 for unknown messageId 1
          2024-09-16 14:00:59.831  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:01:05.833  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:01:09.833  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:01:11.835  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:01:11.836  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
          2024-09-16 14:01:12.577  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connection closed: closed
          2024-09-16 14:01:21.946  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connected with secret 1726488081946_210
          2024-09-16 14:01:21.953  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] Received pubrec on esp32-e0624b304ec0 for unknown messageId 1
          Ro75 1 Reply Last reply Reply Quote 0
          • Ro75
            Ro75 @MartinP last edited by
            @martinp sagte in Adapter-Updates über die Weboberfläche ausgegraut ...:
            wirklich?
            Ro75.
            MartinP 1 Reply Last reply Reply Quote 1
            • MartinP
              MartinP @Ro75 last edited by MartinP
              @ro75 Ist ein LXC-Container, habe nicht PVE rebootet, sondern nur den Container über die PVE Weboberfläche.... die Weboberfläche von iob war jedenfalls nicht erreichbar 😉
              EDIT ich sehe da 11 Minuten uptime ...
              14:10:46 up 22 min,  1 user,  load average: 47.30, 48.30, 49.00
              Der erste Wert ist wohl die aktuelle Uhrzeit
                Da geht es eher drum. Wobei so eine Load auf 'Haushaltsware' auch eher unrealistisch ist.
                • MartinP
                  @thomas-braun Ist eine ziemlich lahme Kiste, ein Celeron N3000 spielt etwa in der Liga eines Pi4 ...
                  Proxmox selber zeigt etwas niedrigere "Fieberkurven" für den LXC-Container
                  Kann es sein, dass bei einem LXC-Container da falsch angezeigt wird - das wird im PVE selber angezeigt:
                  EDIT: Das sind die gehosteten VMs / LXC
                  • MartinP
                    MartinP @MartinP last edited by
                    Schade, die Zigbee2mqtt VM scheint das Zeitliche gesegnet zu haben - sieht gestartet aus, ist aber per IP nicht erreichbar...
                      Homoran Global Moderator Administrators @MartinP last edited by Homoran
                      naja, über 2 oder 4 (je nach CPU) sollte der Wert nicht liegen
                      • MartinP
                        MartinP @Homoran last edited by
                        @homoran said in Adapter-Updates über die Weboberfläche ausgegraut ...:
                        Sind das keine Prozentwerte?
                        Der Celeron N3000 hat eben je nach Benchmark nur etwa 1/5 ... 1/10 der Performance eines Intel N100 ...
                        da werden aus 2...4 auf dem N100 eben 10...40%....
                        Der LXC-Container selber scheint sich auch die prognostizierten 10 ... 40% zu gönnen 🙂
                          Normalerweise nicht.
                          die load average ist nicht %CPU
                          Bei der load average sollte der Wert nicht die Anzahl der Kerne überschreiten.
                          Ab da ist Abarbeitungsrückstau.
                          EDIT: Was du da zeigst ist tatsächlich %CPU!
                          iob diag zeigt aber die load average der letzten, der letzten 5 und der letzten 15 Minuten an
                          • MartinP
                            MartinP @Homoran last edited by MartinP
                            @homoran Ja, der Wert ist SEHR hoch ....
                            https://wiki.ubuntuusers.de/uptime/
                            Zwei Kerne -> nicht viel höher als 2 wäre das Ziel ...
                            Vielleicht schlage ich dann doch mal zu, wenn irgendwann ein Hardware "Schnapper" vor die Flinte kommt ...
                            Entweder ein gebrauchter sparsamer i5 oder ein N100 ...
                            Das ist aus dem PVE Hauptfenster und DEFINITIV dieser "Load Avg." Wert und keine Prozente... dauerhaft auf 45 ...50 ...
                              ich tippe da aber auf eine Fehlanzeige/Softwareproblem.
                              Bei 2 Kernen würdest du wahrscheinlich bei einer Load von 5 schon nicht mehr auf den Server kommen.
                              • MartinP
                                Würde ich auch vermuten...
                                Die Wuppdizität der iobroker Oberfläche und der VIS-Fenster ist sicherlich nicht die beste, aber ich sitze beruflich sehr viel auf Rechnern per remote Session, und bin das eigentlich gewöhnt 😉
                                Meinem Spieltrieb werde ich aber ggfs trotzdem Einhalt gebieten - keine weiteren LXC-Container auf die arme Kiste 😉
                                • MartinP
                                  MartinP @MartinP last edited by MartinP
                                  Noch ein wenig Lesefutter
                                  https://www.suse.com/support/kb/doc/?id=000016923
                                  The vmstat command's "r" column under "procs" shows the current number of processes waiting to get on the run queue at a given instant in time. The uptime command shows the average number of processes on the run queue and waiting to get on the run queue in the last one, five and fifteen minutes. In the example above, the load averages indicate the server is getting busier, because the average processes in the last minute is higher than the fifteen minute average.
                                  root@pve:~# vmstat 1 4
                                  procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu-----
                                   r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
                                   4  0 2030592 837036 907484 2304212    3    3   114   151 2022 2108 25 20 51  1  0
                                   1  0 2030592 837036 907484 2304212    0    0   768    88 3643 3739 31 41 28  1  0
                                   1  0 2030592 837036 907484 2304212    0    0     0   140 2910 2883 16 13 71  1  0
                                   2  0 2030592 837036 907484 2304212    0    0     0   288 3291 3201 19 23 57  2  0
                                  Hier noch zum Vergleich die Werte vom Linux Mint PC mit Cinnamon Desktop ...
                                  martin@martin-D2836-S1:~$ uptime
                                   19:36:58 up 10 days, 10:23,  1 user,  load average: 0,61, 0,15, 0,05
                                  martin@martin-D2836-S1:~$ vmstat 1 4
                                  Prozesse -----------Speicher---------- ---Auslagerung-- -----E/A---- -System-- ------CPU-----
                                   r  b   swpd   frei   buff  Cache   si   so    bi    bo   in   cs US SY ID WA st
                                   0  0 1981436 730472 1574332 1412080    0    1    23    27    2    4  1  1 98  0  0
                                   0  0 1981436 730724 1574332 1412140    0    0     0     0 2377 4077  2  1 98  0  0
                                   0  0 1981436 730724 1574332 1412140    0    0     0     0 3073 5397  1  1 99  0  0
                                   1  0 1981436 730724 1574332 1412140    0    0     0     0 2337 3928  2  1 98  0  0
                                  526
