    4. Adapter-Updates über die Weboberfläche ausgegraut ...
    • MartinP
      MartinP @Thomas Braun last edited by MartinP
      Nach Quer gucken sieht das gut aus ... (bis auf die MQTT Adapter Probleme)
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: iobroker-test-sicher
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-1-pve
          Architecture: x86-64
      model name      : Intel(R) Celeron(R) CPU  N3000  @ 1.04GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       14:00:14 up 11 min,  2 users,  load average: 50.09, 49.87, 49.65
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Mon 2024-09-16 14:00:14 CEST
                 Universal time: Mon 2024-09-16 12:00:14 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      martin
      HOME=/home/martin
      GROUPS=martin sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            6.4G        2.0G        3.7G        118K        808M        4.5G
      Swap:           6.4G          0B        6.4G
      Total:           12G        2.0G         10G
      Active iob-Instances:   23
               6144 M total memory
               1872 M used memory
               2145 M active memory
                394 M inactive memory
               3500 M free memory
                  0 M buffer memory
                771 M swap cache
               6144 M total swap
                  0 M used swap
               6144 M free swap
      top - 14:00:14 up 11 min,  2 users,  load average: 50.09, 49.87, 49.65
      Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 25.0 us, 25.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   6144.0 total,   3498.8 free,   1874.1 used,    771.3 buff/cache
      MiB Swap:   6144.0 total,   6144.0 free,      0.0 used.   4269.9 avail Mem
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0 ext4       63G   20G   40G  33% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                                  SOURCE                           FSTYPE     OPTIONS
      /                                                       /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=1595988k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
      | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=3956668k,nr_inodes=989167,mode=755,inode64
      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      3.9G    /var/
      2.1G    /var/lib
      1.9G    /var/lib/influxdb/engine/data/f11825691705bf53/autogen
      Archived and active journals take up 144.8M in the file system.
      /opt/iobroker/backups:
      9.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      827M    /opt/iobroker/iobroker-data/
      710M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
       *** 20.17.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://ftp.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.0.23
      javascript:     8.7.6
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-test-sicher                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker-test-sicher                     -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-test-sicher                     -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-test-sicher                     -  enabled
      + system.adapter.email.0                  : email                 : iobroker-test-sicher                     -  enabled
        system.adapter.fahrplan.0               : fahrplan              : iobroker-test-sicher                     - disabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-test-sicher                     -  enabled
        system.adapter.frigate.0                : frigate               : iobroker-test-sicher                     - disabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker-test-sicher                     -  enabled
        system.adapter.ical.0                   : ical                  : iobroker-test-sicher                     -  enabled
        system.adapter.ical.1                   : ical                  : iobroker-test-sicher                     -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker-test-sicher                     -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobroker-test-sicher                     -  enabled
      + system.adapter.javascript.1             : javascript            : iobroker-test-sicher                     -  enabled
      + system.adapter.meross.0                 : meross                : iobroker-test-sicher                     -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-test-sicher                     -  enabled, port: 1888
        system.adapter.mqtt-client.1            : mqtt-client           : iobroker-test-sicher                     - disabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-test-sicher                     -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : iobroker-test-sicher                     - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.operating-hours.0        : operating-hours       : iobroker-test-sicher                     -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker-test-sicher                     -  enabled
      + system.adapter.reolink.0                : reolink               : iobroker-test-sicher                     -  enabled
      + system.adapter.reolink.1                : reolink               : iobroker-test-sicher                     -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker-test-sicher                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.snmp.0                   : snmp                  : iobroker-test-sicher                     -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker-test-sicher                     -  enabled, port: 1892, bind: 0.0.0.0
      + system.adapter.tradfri.0                : tradfri               : iobroker-test-sicher                     -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker-test-sicher                     -  enabled
        system.adapter.vis.0                    : vis                   : iobroker-test-sicher                     -  enabled
      + system.adapter.web.0                    : web                   : iobroker-test-sicher                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.23   , installed 7.0.23
      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
      Adapter    "benchmark"    : 1.3.0    , installed 1.3.0
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "frigate"      : 1.2.0    , installed 1.2.1
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
      Adapter    "operating-hours": 1.1.0  , installed 1.1.0
      Adapter    "reolink"      : 1.1.1    , installed 1.1.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
      Objects and States
      Objects:        2779
      States:         2351
      Hit:1 http://ftp.debian.org/debian bookworm InRelease
      Hit:2 http://ftp.debian.org/debian bookworm-updates InRelease
      Hit:3 http://security.debian.org bookworm-security InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          108794370  1/init
      tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       108813845  525/io.sonoff.0
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       108812050  498/io.mqtt.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          108803046  348/master
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       108805140  368/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       108805058  368/iobroker.js-con
      tcp6       0      0 :::111                  :::*                    LISTEN      0          108794372  1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          108794682  1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          108803047  348/master
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        108804726  367/grafana
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       108816478  687/io.simple-api.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        108803748  172/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       108805796  417/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       108816757  669/io.web.0
      udp        0      0 0.0.0.0:46184           0.0.0.0:*                           1001       108815704  676/io.tradfri.0
      udp        0      0 0.0.0.0:40879           0.0.0.0:*                           1001       108815883  587/io.snmp.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          108794371  1/init
      udp6       0      0 :::111                  :::*                                0          108794373  1/init
      2024-09-16 13:59:42.757  - info: admin.0 (417) ==> Connected system.user.admin from ::ffff:192.168.2.115
      2024-09-16 13:59:45.755  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 4 deleted after 12 retries
      2024-09-16 13:59:45.755  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 3 deleted after 12 retries
      2024-09-16 14:00:00.074  - info: host.iobroker-test-sicher instance system.adapter.ical.0 in version "1.15.0" started with pid 1500
      2024-09-16 14:00:00.226  - info: javascript.0 (455) script.js.Energiezaehler.Gaszaehler: Actual Pulses 137474 Last Pulses 137469 =0.557
      2024-09-16 14:00:06.909  - info: ical.0 (1500) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.17.0, js-controller: 6.0.11
      2024-09-16 14:00:09.415  - info: ical.0 (1500) processing URL: Martin_docker http://192.168.2.146:5232/martin/e4c584bc-2ea6-bae6-1d4e-debe6a702f21/
      2024-09-16 14:00:09.776  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:00:14.925  - info: ical.0 (1500) Terminated (NO_ERROR): Without reason
      2024-09-16 14:00:15.529  - info: host.iobroker-test-sicher instance system.adapter.ical.0 having pid 1500 terminated with code 0 (NO_ERROR)
      2024-09-16 14:00:15.781  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:00:17.792  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:00:19.783  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:00:21.782  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:00:22.567  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connection closed: closed
      2024-09-16 14:00:31.955  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connected with secret 1726488031944_3480
      2024-09-16 14:00:31.974  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] Received pubrec on esp32-e0624b304ec0 for unknown messageId 1
      2024-09-16 14:00:59.831  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:01:05.833  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:01:09.833  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:01:11.835  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:01:11.836  - warn: mqtt.0 (498) Client [esp32-e0624b304ec0] Message 5 deleted after 11 retries
      2024-09-16 14:01:12.577  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connection closed: closed
      2024-09-16 14:01:21.946  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] connected with secret 1726488081946_210
      2024-09-16 14:01:21.953  - info: mqtt.0 (498) Client [esp32-e0624b304ec0] Received pubrec on esp32-e0624b304ec0 for unknown messageId 1
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @MartinP last edited by
        @martinp sagte in Adapter-Updates über die Weboberfläche ausgegraut ...:
        wirklich?
        Ro75.
        MartinP 1 Reply Last reply Reply Quote 1
        • MartinP
          MartinP @Ro75 last edited by MartinP
          @ro75 Ist ein LXC-Container, habe nicht PVE rebootet, sondern nur den Container über die PVE Weboberfläche.... die Weboberfläche von iob war jedenfalls nicht erreichbar 😉
          EDIT ich sehe da 11 Minuten uptime ...
          14:10:46 up 22 min,  1 user,  load average: 47.30, 48.30, 49.00
          Der erste Wert ist wohl die aktuelle Uhrzeit
            Thomas Braun Most Active @MartinP last edited by
            Da geht es eher drum. Wobei so eine Load auf 'Haushaltsware' auch eher unrealistisch ist.
            • MartinP
              @thomas-braun Ist eine ziemlich lahme Kiste, ein Celeron N3000 spielt etwa in der Liga eines Pi4 ...
              Proxmox selber zeigt etwas niedrigere "Fieberkurven" für den LXC-Container
              Kann es sein, dass bei einem LXC-Container da falsch angezeigt wird - das wird im PVE selber angezeigt:
              EDIT: Das sind die gehosteten VMs / LXC
              • MartinP
                MartinP @MartinP last edited by
                Schade, die Zigbee2mqtt VM scheint das Zeitliche gesegnet zu haben - sieht gestartet aus, ist aber per IP nicht erreichbar...
                  Homoran Global Moderator Administrators @MartinP last edited by Homoran
                  naja, über 2 oder 4 (je nach CPU) sollte der Wert nicht liegen
                  • MartinP
                    MartinP @Homoran last edited by
                    @homoran said in Adapter-Updates über die Weboberfläche ausgegraut ...:
                    Sind das keine Prozentwerte?
                    Der Celeron N3000 hat eben je nach Benchmark nur etwa 1/5 ... 1/10 der Performance eines Intel N100 ...
                    da werden aus 2...4 auf dem N100 eben 10...40%....
                    Der LXC-Container selber scheint sich auch die prognostizierten 10 ... 40% zu gönnen 🙂
                      Normalerweise nicht.
                      die load average ist nicht %CPU
                      Bei der load average sollte der Wert nicht die Anzahl der Kerne überschreiten.
                      Ab da ist Abarbeitungsrückstau.
                      EDIT: Was du da zeigst ist tatsächlich %CPU!
                      iob diag zeigt aber die load average der letzten, der letzten 5 und der letzten 15 Minuten an
                      • MartinP
                        MartinP @Homoran last edited by MartinP
                        @homoran Ja, der Wert ist SEHR hoch ....
                        https://wiki.ubuntuusers.de/uptime/
                        Zwei Kerne -> nicht viel höher als 2 wäre das Ziel ...
                        Vielleicht schlage ich dann doch mal zu, wenn irgendwann ein Hardware "Schnapper" vor die Flinte kommt ...
                        Entweder ein gebrauchter sparsamer i5 oder ein N100 ...
                        Das ist aus dem PVE Hauptfenster und DEFINITIV dieser "Load Avg." Wert und keine Prozente... dauerhaft auf 45 ...50 ...
                          ich tippe da aber auf eine Fehlanzeige/Softwareproblem.
                          Bei 2 Kernen würdest du wahrscheinlich bei einer Load von 5 schon nicht mehr auf den Server kommen.
                          • MartinP
                            Würde ich auch vermuten...
                            Die Wuppdizität der iobroker Oberfläche und der VIS-Fenster ist sicherlich nicht die beste, aber ich sitze beruflich sehr viel auf Rechnern per remote Session, und bin das eigentlich gewöhnt 😉
                            Meinem Spieltrieb werde ich aber ggfs trotzdem Einhalt gebieten - keine weiteren LXC-Container auf die arme Kiste 😉
                            • MartinP
                              MartinP @MartinP last edited by MartinP
                              Noch ein wenig Lesefutter
                              https://www.suse.com/support/kb/doc/?id=000016923
                              The vmstat command's "r" column under "procs" shows the current number of processes waiting to get on the run queue at a given instant in time. The uptime command shows the average number of processes on the run queue and waiting to get on the run queue in the last one, five and fifteen minutes. In the example above, the load averages indicate the server is getting busier, because the average processes in the last minute is higher than the fifteen minute average.
                              root@pve:~# vmstat 1 4
                              procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu-----
                               r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
                               4  0 2030592 837036 907484 2304212    3    3   114   151 2022 2108 25 20 51  1  0
                               1  0 2030592 837036 907484 2304212    0    0   768    88 3643 3739 31 41 28  1  0
                               1  0 2030592 837036 907484 2304212    0    0     0   140 2910 2883 16 13 71  1  0
                               2  0 2030592 837036 907484 2304212    0    0     0   288 3291 3201 19 23 57  2  0
                              Hier noch zum Vergleich die Werte vom Linux Mint PC mit Cinnamon Desktop ...
                              martin@martin-D2836-S1:~$ uptime
                               19:36:58 up 10 days, 10:23,  1 user,  load average: 0,61, 0,15, 0,05
                              martin@martin-D2836-S1:~$ vmstat 1 4
                              Prozesse -----------Speicher---------- ---Auslagerung-- -----E/A---- -System-- ------CPU-----
                               r  b   swpd   frei   buff  Cache   si   so    bi    bo   in   cs US SY ID WA st
                               0  0 1981436 730472 1574332 1412080    0    1    23    27    2    4  1  1 98  0  0
                               0  0 1981436 730724 1574332 1412140    0    0     0     0 2377 4077  2  1 98  0  0
                               0  0 1981436 730724 1574332 1412140    0    0     0     0 3073 5397  1  1 99  0  0
                               1  0 1981436 730724 1574332 1412140    0    0     0     0 2337 3928  2  1 98  0  0
                              526
