    4. iob diag - Skript
    iob diag - Skript
      Thomas Braun Most Active @TT-Tom last edited by
      @tt-tom sagte in iob diag - Skript:
      @Thomas-Braun nutzt du lsb_release -a zur Abfrage des OS?
      Jein, -a gibt alles aus, ich lese den Codename per
      lsb_release -sc
      aus. Scheint also kein default package zu sein.
        TT-Tom @TT-Tom last edited by TT-Tom
        @tt-tom
        @Thomas-Braun
        nochmal mit iobroker Installation. User tom wurde angelegt und die Timezone wurde geändert.
        root@testsystem:~# ./iob_diag.sh
        You should not be root on your system!
        Better use your standard user!
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and end.
        It helps us to help you!
        Press any key to continue
        ========== Start marking the full check here ===========
        ```bash
        Script v.2024-09-07
        *** BASE SYSTEM ***
         Static hostname: testsystem
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.8.12-1-pve
            Architecture: x86-64
        Package configuration
                          ┌───────────────────────┤ Configuring tzdata ├───────────────────────┐
                          │ Please select the city or region corresponding to your time zone.  │
                          │ Time zone:                                                         │
                          │                           Amsterdam       -                        │
                          │                           Andorra         ▒                        │
                          │                           Astrakhan       0                        │
                          │                           Athens          ▒                        │
                          │                           Belfast         ▒                        │
                          │                           Belgrade        ▒                        │
                          │                           Berlin          ▒                        │
                          │                           Bratislava      ▒                        │
                          │                           Brussels        ▒                        │
                          │                           Bucharest       ▒                        │
                          │                           Budapest        ▒                        │
                          │                           Busingen        .                        │
                          │                 <Ok>                     <Cancel>                  │
        Current default time zone: 'Europe/Berlin'
        Local time is now:      Sun Sep  8 20:07:44 CEST 2024.
        Universal Time is now:  Sun Sep  8 18:07:44 UTC 2024.
        Setting up time synchronization with systemd-timesyncd
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
        A root login is not required in most Linux Distributions.
        Enter the username for a new user (Not 'root' and not 'iobroker'!): tom
        Enter the password for the new user:
        Confirm the password for the new user:
        Adding new user account...
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            2.1G        284M        1.6G        118K        229M        1.9G
        Swap:           1.1G          0B        1.1G
        Total:          3.2G        284M        2.7G
        Active iob-Instances:   4
                 2048 M total memory
                  271 M used memory
                  399 M active memory
                   66 M inactive memory
                 1557 M free memory
                    0 M buffer memory
                  219 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        top - 20:08:01 up 5 min,  1 user,  load average: 0.04, 0.17, 0.16
        Tasks:  25 total,   1 running,  24 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   2048.0 total,   1555.1 free,    273.6 used,    219.4 buff/cache
        MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1774.4 avail Mem
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--106--disk--0 ext4      7.8G  2.1G  5.3G  29% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
        tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
        tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--106--disk--0 ext4   rw,relatime,stripe=16
        /var:
        400M    /var/
        237M    /var/cache
        234M    /var/cache/apt
        158M    /var/cache/apt/archives
        146M    /var/lib
        Archived and active journals take up 16.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        62M     /opt/iobroker/iobroker-data/
        57M     /opt/iobroker/iobroker-data/files
        31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        8.4M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.70cad8ba.js
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
        5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
        5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
        5.0M    /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        testsystem          testsystem (version: 6.0.11, hostname: testsystem    , alive, uptime: 316)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.0.23
        javascript:     "javascript" not found
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : testsystem                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : testsystem                               -  enabled
        + system.adapter.discovery.0              : discovery             : testsystem                               -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.0.23   , installed 7.0.23
        Adapter    "backitup"     : 3.0.19   , installed 3.0.19
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Objects and States
        Objects:        148
        States:         103
        Hit:1 http://security.debian.org bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       80745598   155/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       80745603   155/iobroker.js-con
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          80743343   319/master
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          80742867   1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       80751205   436/io.admin.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          80743344   319/master
        tcp6       0      0 :::22                   :::*                    LISTEN      0          80742219   1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          80742869   1/init
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          80742305   95/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          80742868   1/init
        udp6       0      0 :::111                  :::*                                0          80742870   1/init
        2024-09-08 18:02:43.093  - info: backitup.0 (371) starting. Version 3.0.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
        2024-09-08 18:02:43.111  - info: backitup.0 (371) [iobroker] backup will be activated at 02:48 every 1 day(s)
        2024-09-08 18:02:46.482  - info: host.testsystem instance system.adapter.discovery.0 in version "4.5.0" started with pid 386
        2024-09-08 18:02:47.002  - info: discovery.0 (386) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
        2024-09-08 18:03:34.073  - info: admin.0 (330) ==> Connected system.user.admin from ::ffff:192.168.178.12
        2024-09-08 18:04:30.739  - info: host.testsystem stopInstance system.adapter.admin.0 (force=false, process=true)
        2024-09-08 18:04:30.741  - info: admin.0 (330) Got terminate signal TERMINATE_YOURSELF
        2024-09-08 18:04:30.741  - info: admin.0 (330) terminating http server on port 8081
        2024-09-08 18:04:30.743  - info: admin.0 (330) terminating
        2024-09-08 18:04:30.743  - info: admin.0 (330) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-09-08 18:04:30.781  - info: host.testsystem stopInstance system.adapter.admin.0 send kill signal
        2024-09-08 18:04:31.244  - info: admin.0 (330) terminating
        2024-09-08 18:04:31.281  - info: host.testsystem instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-09-08 18:04:34.403  - info: host.testsystem instance system.adapter.admin.0 in version "7.0.23" started with pid 436
        2024-09-08 18:04:35.068  - info: admin.0 (436) starting. Version 7.0.23 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
        2024-09-08 18:04:35.079  - info: admin.0 (436) requesting all objects
        2024-09-08 18:04:35.285  - info: admin.0 (436) received all objects
        2024-09-08 18:04:35.382  - info: admin.0 (436) socket.io server listening on port 8081
        2024-09-08 18:04:35.383  - info: admin.0 (436) http server listening on port 8081
        2024-09-08 18:04:35.383  - info: admin.0 (436) Use link "http://127.0.0.1:8081" to configure.
        2024-09-08 18:04:37.576  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
        2024-09-08 18:04:37.615  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
        2024-09-08 18:04:37.645  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
        2024-09-08 18:04:45.342  - info: admin.0 (436) ==> Connected system.user.admin from ::ffff:192.168.178.12
        2024-09-08 18:04:57.657  - info: admin.0 (436) <== Disconnect system.user.admin from ::ffff:192.168.178.12 admin
        iob diag has finished.
          @tt-tom
          Den
          chpasswd: (user tom) pam_chauthtok() failed, error:
          kann ich mir gerade nicht so wirklich erklären. Zumal es bei @Meister-Mopper alles wie gedacht funktioniert...
            Also mit vorheriger Installation des ioBroker funktioniert es?
              TT-Tom @Thomas Braun last edited by
              ja mit iobroker ist alles sauber durchgelaufen.
                Na dann....
                Das Skript kommt ja im Normalfall auch erst mit dem ioBroker auf das System.
                  TT-Tom @Thomas Braun last edited by TT-Tom
                  Den
                  der User konnte ja nicht der Gruppe iobroker zugeordnet werden.
                    Das sollte aber nicht der Grund für die Meldung sein.
                    Wie dem auch sei, das Skript ruft man ja in der Realität nur bei vorhandener Installation des ioBrokers auf.
                      Knirpso @Thomas Braun last edited by Knirpso
                      Anbei noch der gewünschte Log aus https://forum.iobroker.net/topic/76922/schaltverhalten-iot-adapter-mit-alexa/4
                      Script v.2024-09-16
                      *** BASE SYSTEM ***
                      Hardware Vendor : Synology Inc.
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Docker          : v9.1.2
                      Virtualization  : Docker
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
                      CPU threads: 8
                      *** LIFE CYCLE STATUS ***
                      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                      *** TIME AND TIMEZONES ***
                      Tue Sep 17 15:25:15 UTC 2024
                      Tue Sep 17 17:25:15 CEST 2024
                      CEST +0200
                      Etc/UTC
                      root
                      HOME=/root
                      GROUPS=root
                      iobroker
                      HOME=/opt/iobroker
                      Display-Server: true
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Mem:             67G        7.4G        1.0G        215M         59G         59G
                      Swap:            42G        307M         42G
                      Total:          109G        7.7G         43G
                      Active iob-Instances:   17
                              64084 M total memory
                               7067 M used memory
                               7965 M active memory
                              52969 M inactive memory
                                971 M free memory
                                 84 M buffer memory
                              56764 M swap cache
                              40499 M total swap
                                293 M used swap
                              40206 M free swap
                      top - 17:25:15 up 143 days,  6:35,  0 user,  load average: 1.09, 1.31, 1.33
                      Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
                      MiB Mem :  64084.8 total,    969.7 free,   7068.6 used,  56848.9 buff/cache
                      MiB Swap:  40499.9 total,  40206.6 free,    293.3 used.  57016.2 avail Mem
                      *** FILESYSTEM ***
                      /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /
                      tmpfs          tmpfs   64M     0   64M   0% /dev
                      tmpfs          tmpfs   32G     0   32G   0% /sys/fs/cgroup
                      shm            tmpfs   64M     0   64M   0% /dev/shm
                      /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /opt/iobroker
                      /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /etc/hosts
                      tmpfs          tmpfs   32G     0   32G   0% /proc/acpi
                      tmpfs          tmpfs   32G     0   32G   0% /proc/scsi
                      tmpfs          tmpfs   32G     0   32G   0% /sys/firmware
                      /                  /dev/synorbd_1[/@syno/@docker/btrfs/subvolumes/43c485044ed9f1e230e9f082f08e839ece82e19c0db5e0e02d5f344f954dfa66]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                      |-/opt/iobroker    /dev/synorbd_1[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                      |-/etc/resolv.conf /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                      |-/etc/hostname    /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                      `-/etc/hosts       /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
                      /var:
                      34M     /var/
                      32M     /var/lib
                      19M     /var/lib/apt/lists
                      19M     /var/lib/apt
                      13M     /var/lib/dpkg
                      33M     /opt/iobroker/backups/
                      1.1G    /opt/iobroker/iobroker-data/
                      756M    /opt/iobroker/iobroker-data/files
                      441M    /opt/iobroker/iobroker-data/files/javascript.admin
                      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      117M    /opt/iobroker/iobroker-data/states.jsonl
                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                      USB-Devices by-id:
                      HINT:
                      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                      /dev/ttyACM0
                      HINT:
                      Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                      /dev/ttyACM0
                      /usr/bin/nodejs         v18.20.4
                      /usr/bin/node           v18.20.4
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.28.0
                      nodejs:
                        Installed: 18.20.4-1nodesource1
                        Candidate: 18.20.4-1nodesource1
                        Version table:
                       *** 18.20.4-1nodesource1 1001
                             1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                           18.20.3-1nodesource1 1001
                           18.20.2-1nodesource1 1001
                           18.20.1-1nodesource1 1001
                           18.20.0-1nodesource1 1001
                           18.19.1-1nodesource1 1001
                              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                           18.19.0-1nodesource1 1001
                           18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1308286)
                      slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 268408)
                      admin:          7.0.23
                      javascript:     8.7.6
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                      + system.adapter.history.0                : history               : iobroker                                 -  enabled
                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.mystrom.0                : mystrom               : iobroker                                 -  enabled
                      + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
                        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                      + system.adapter.zigbee.1                 : zigbee                : slave1-raspberrypi                       -  enabled, port: /dev/ttyACM0
                      + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                      + instance is alive
                      │ (index) │   name   │                           url                           │ auto upgrade │
                      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                      Adapter    "roborock"     : 0.6.4    , installed 0.6.4
                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                      Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                      Objects and States
                      Objects:        3786
                      States:         2647
                      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Pending Updates: 26
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3946312486 -
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3946312479 -
                      tcp        0      0 127.0.0.11:42340        0.0.0.0:*               LISTEN      0          3946306647 -
                      tcp6       0      0 :::6824                 :::*                    LISTEN      1000       78218444   -
                      tcp6       0      0 :::8554                 :::*                    LISTEN      1000       78220248   -
                      tcp6       0      0 :::8555                 :::*                    LISTEN      1000       78220249   -
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3946310901 -
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3946317922 -
                      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       3946324298 -
                      tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3946324745 -
                      tcp6       0      0 :::1984                 :::*                    LISTEN      1000       78243001   -
                      tcp6       0      0 :::7906                 :::*                    LISTEN      1000       78218445   -
                      udp        0      0 127.0.0.11:56032        0.0.0.0:*                           0          3946306646 -
                      udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1000       38730773   -
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       3946311323 -
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       3946311324 -
                      2024-09-17 17:01:23.903  - error: mystrom.0 (386) 200
                      2024-09-17 17:01:23.903  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
                      2024-09-17 17:01:23.903  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                      2024-09-17 17:01:23.904  - info: mystrom.0 (386) Set update interval for FCF5C418FF54 to 60
                      2024-09-17 17:01:23.920  - info: mystrom.0 (386) Set update interval for FCF5C418FB0C to 60
                      2024-09-17 17:01:23.922  - error: mystrom.0 (386) 200
                      2024-09-17 17:01:23.922  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
                      2024-09-17 17:01:23.922  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                      2024-09-17 17:01:23.923  - error: mystrom.0 (386) 200
                      2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
                      2024-09-17 17:01:23.924  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                      2024-09-17 17:01:23.924  - error: mystrom.0 (386) 200
                      2024-09-17 17:01:23.924  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
                      2024-09-17 17:01:23.930  - error: mystrom.0 (386) 200
                      2024-09-17 17:01:23.930  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
                      2024-09-17 17:01:23.930  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                      2024-09-17 17:01:23.936  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
                      2024-09-17 17:01:23.937  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
                      2024-09-17 17:01:23.941  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                      2024-09-17 17:01:23.942  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                      2024-09-17 17:01:23.962  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                      2024-09-17 17:01:23.966  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                      2024-09-17 17:03:36.237  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                      Edit: Log von Skriptversion 2024-09-16 angehängt.
                        Thomas Braun Most Active @Knirpso last edited by
                        @knirpso Bitte die aktuelle Version 2024-09-16 verwenden.
                          Thomas Braun Most Active @Knirpso last edited by Thomas Braun
                          @knirpso
                          Hm. Kannst du mal die Ausgabe von
                          pgrep -l '[X]|[w]ayland|X11|wayfire'
                          posten?
                          Oder auch die anderen Dockeristen.
                            root@iobroker:/opt/iobroker# pgrep -l '[X]|[w]ayland|X11|wayfire'
                            pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                            Try `pgrep -f' option to match against the complete command line.
                              @knirpso sagte in iob diag - Skript:
                              pgrep -lf '[X]|[w]ayland|X11|wayfire'
                                root@iobroker:/opt/iobroker# pgrep -lf '[X]|[w]ayland|X11|wayfire'
                                1966 go2rtc_linux_am
                                root@pihole:/# pgrep -lf '[X]|[w]ayland|X11|wayfire'
                                root@pihole:/#
                                Mehr hab ich nicht
                                  @knirpso
                                  Danke, Grund für den 'flase positive' gefunden.
                                    @knirpso
                                    Zieh bitte die aktuelle Version nochmal.
                                      Script v.2024-09-17
                                      *** BASE SYSTEM ***
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      Docker          : v9.1.2
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                       18:05:31 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
                                      CPU threads: 8
                                      Wed Sep 18 16:05:31 UTC 2024
                                      Wed Sep 18 18:05:31 CEST 2024
                                      CEST +0200
                                      Etc/UTC
                                      root
                                      HOME=/root
                                      GROUPS=root
                                      iobroker
                                      HOME=/opt/iobroker
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Mem:             67G        7.5G        849M        216M         59G         59G
                                      Swap:            42G        305M         42G
                                      Total:          109G        7.8G         43G
                                      Active iob-Instances:   16
                                               7174 M used memory
                                               8048 M active memory
                                              53007 M inactive memory
                                                810 M free memory
                                                 84 M buffer memory
                                              56817 M swap cache
                                              40499 M total swap
                                                290 M used swap
                                              40209 M free swap
                                      top - 18:05:32 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
                                      Tasks:  34 total,   2 running,  32 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :  64084.8 total,    809.2 free,   7175.6 used,  56902.5 buff/cache
                                      MiB Swap:  40499.9 total,  40209.0 free,    290.9 used.  56909.1 avail Mem
                                      *** FILESYSTEM ***
                                      /var:
                                      34M     /var/
                                      32M     /var/lib
                                      19M     /var/lib/apt
                                      13M     /var/lib/dpkg
                                      40M     /opt/iobroker/backups/
                                      1017M   /opt/iobroker/iobroker-data/
                                      20M     /opt/iobroker/iobroker-data/states.jsonl
                                      USB-Devices by-id:
                                      HINT:
                                      /dev/ttyACM0
                                      HINT:
                                      /dev/ttyACM0
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1397104)
                                      slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 357226)
                                      admin:          7.0.23
                                      javascript:     8.7.6
                                      Adapter State
                                        system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                                      + instance is alive
                                      Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
                                      Objects and States
                                      Objects:        3786
                                      States:         2638
                                      Pending Updates: 28
                                      2024-09-18 18:01:23.039  - error: mystrom.0 (386) 200
                                      2024-09-18 18:01:23.039  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
                                      2024-09-18 18:01:23.039  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                      2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
                                      2024-09-18 18:01:23.040  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                      2024-09-18 18:01:23.040  - error: mystrom.0 (386) 200
                                      2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
                                      2024-09-18 18:01:23.046  - error: mystrom.0 (386) 200
                                      2024-09-18 18:01:23.046  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
                                      2024-09-18 18:01:23.046  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                      2024-09-18 18:01:23.048  - error: mystrom.0 (386) 200
                                      2024-09-18 18:01:23.048  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
                                      2024-09-18 18:01:23.048  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
                                      2024-09-18 18:01:23.051  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-18 18:01:23.052  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
                                      2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
                                      2024-09-18 18:01:23.062  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-18 18:01:23.068  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-18 18:01:23.075  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
                                      2024-09-18 18:05:46.619  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                                      2024-09-18 18:05:49.032  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
                                      2024-09-18 18:05:49.037  - info: admin.0 (157) <== Disconnect system.user.admin from ::ffff:192.168.212.23 iot
                                        Shadowhunter23 last edited by Shadowhunter23
                                        Script v.2024-09-17
                                        *** BASE SYSTEM ***
                                         Static hostname: iobroker
                                          Virtualization: lxc
                                        OS is similar to:
                                        model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                                        Docker          : false
                                        Virtualization  : lxc
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         18:19:46 up 4 days,  6:33,  1 user,  load average: 0.12, 0.12, 0.10
                                        CPU threads: 4
                                        Operating System is the current Debian stable version codenamed 'bookworm'!
                                                       Local time: Wed 2024-09-18 18:19:46 CEST
                                                   Universal time: Wed 2024-09-18 16:19:46 UTC
                                                         RTC time: n/a
                                                      NTP service: n/a
                                                  RTC in local TZ: no
                                        tobias
                                        HOME=/home/tobias
                                        GROUPS=tobias sudo users iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev redis
                                        Desktop:
                                        Terminal:       tty
                                        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Do you want to switch to 'multi-user.target'? (y/n)
                                        @Thomas-Braun
                                        Kannst du mir diese Frage erklären? Was ändert sich wenn ich mit y weiter mache?
                                        edit
                                        Ist ein LXC unter Proxmox.
                                        Noch ein edit
                                        Google hilft:
                                        multi-user.target -> The multiuser target in Linux is a Command Line Interface and it's like a mode where multiple people can use the computer at the same time. It's perfect for situations where several users need to log in and do their own stuff on the computer simultaneously. So, when your system is in the multiuser target, it's ready for several users to work on it together.
                                        graphical.target -> The multiuser target in Linux is a Graphical User Interface and it's like a mode where multiple people can use the computer at the same time. It's perfect for situations where several users need to log in and do their own stuff on the computer simultaneously. So, when your system is in the multiuser target, it's ready for several users to work on it together.
                                        Steht das jetzt nicht im Gegensatz zu Display-Server: false?
                                          Thomas Braun Most Active @Shadowhunter23 last edited by Thomas Braun
                                          @shadowhunter23 sagte in iob diag - Skript:
                                          Nein, das boot.target ist unabhängig davon ob da wirklich ein Display-Server installiert ist und gestartet werden kann.
                                          Das boot.target auf einem Server sollte aber dennoch multi-user sein. Deswegen der Vorschlag das so einzurichten.
                                          S Thomas Braun 2 Replies Last reply Reply Quote 0
                                            Shadowhunter23 @Thomas Braun last edited by
                                            Danke, hab's umgestellt und muss das aufnehmen in meine Neuinstallation Routine.
                                            738
                                            153329
