    4. Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus
      Thomas Braun Most Active @UHU01 last edited by
      @uhu01
      iob logs --watch | uniq
      anschauen, Ausgabe von
      ls -lAh /dev/serial/by-id
      prüfen.
      UHU01 1 Reply Last reply Reply Quote 0
      • UHU01
        UHU01 @Thomas Braun last edited by
        Der Pfad scheint zu stimmen.
        Hier das LOG:
        2023-03-2515:10:58.569-info:host.raspberrypi"system.adapter.zigbee.0"disabled
        2023-03-2515:10:58.572-info:host.raspberrypistopInstancesystem.adapter.zigbee.0(force=false,process=true)
        2023-03-2515:10:58.581-info:zigbee.0(13088)GotterminatesignalTERMINATE_YOURSELF
        2023-03-2515:10:58.639-info:host.raspberrypistopInstancesystem.adapter.zigbee.0sendkillsignal
        2023-03-2515:10:58.583-info:zigbee.0(13088)cleanedeverythingup...
        2023-03-2515:10:58.586-info:zigbee.0(13088)Zigbee:disablingjoiningnewdevices.
        2023-03-2515:10:58.696-warn:zigbee.0(13088)Failedtostopzigbeeduringstartup
        2023-03-2515:10:58.697-info:zigbee.0(13088)terminating
        2023-03-2515:10:58.699-info:zigbee.0(13088)Terminated(ADAPTER_REQUESTED_TERMINATION):Withoutreason
        2023-03-2515:10:59.329-info:host.raspberrypiinstancesystem.adapter.zigbee.0terminatedwithcode11(ADAPTER_REQUESTED_TERMINATION)
        2023-03-2515:11:02.563-info:host.raspberrypi"system.adapter.zigbee.0"enabled
        2023-03-2515:11:03.121-info:host.raspberrypiinstancesystem.adapter.zigbee.0startedwithpid15126
        2023-03-2515:11:08.522-info:zigbee.0(15126)starting.Version1.8.10in/opt/iobroker/node_modules/iobroker.zigbee,node:v16.19.0,js-controller:4.0.24
        2023-03-2515:11:08.718-info:zigbee.0(15126)deleteoldBackupfiles.keeponlylast10
        2023-03-2515:11:08.721-info:zigbee.0(15126)StartingZigbeenpm...
        2023-03-2515:11:09.475-info:zigbee.0(15126)InstalledVersion:iobroker.zigbee@1.8.10
        2023-03-2515:11:09.654-error:zigbee.0(15126)Configurationisnotconsistentwithadapterstate/backup!
        2023-03-2515:11:09.655-error:zigbee.0(15126)-PANID:configured=6753,adapter=6754
        2023-03-2515:11:09.657-error:zigbee.0(15126)-ExtendedPANID:configured=00124b0026b877e1,adapter=00124b0026b877e1
        2023-03-2515:11:09.658-error:zigbee.0(15126)-NetworkKey:configured=01030507090b0d0f00020406080a0c0d,adapter=01030507090b0d0f00020406080a0c0d
        2023-03-2515:11:09.659-error:zigbee.0(15126)-ChannelList:configured=11,adapter=11
        2023-03-2515:11:09.660-error:zigbee.0(15126)Pleaseupdateconfigurationtopreventfurtherissues.
        2023-03-2515:11:09.660-error:zigbee.0(15126)Ifyouwishtore-commissionyournetwork,pleaseremovecoordinatorbackupat/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        2023-03-2515:11:09.662-error:zigbee.0(15126)Re-commissioningyournetworkwillrequirere-pairingofalldevices!
        2023-03-2515:11:09.861-error:zigbee.0(15126)Startingzigbee-herdsmanproblem:"startupfailed-configuration-adaptermismatch-seelogsaboveformoreinformation"
        2023-03-2515:11:09.862-error:zigbee.0(15126)FailedtostartZigbee
        2023-03-2515:11:09.862-error:zigbee.0(15126)Errorherdsmanstart
        2023-03-2515:11:19.866-info:zigbee.0(15126)Trytoreconnect.1attemptsleft
        2023-03-2515:11:19.867-info:zigbee.0(15126)StartingZigbeenpm...
        2023-03-2515:11:19.897-info:zigbee.0(15126)InstalledVersion:iobroker.zigbee@1.8.10
        2023-03-2515:11:20.149-error:zigbee.0(15126)Startingzigbee-herdsmanproblem:"Errorwhileopeningserialport'Error:ErrorResourcetemporarilyunavailableCannotlockport'"
        2023-03-2515:11:20.152-error:zigbee.0(15126)FailedtostartZigbee
        2023-03-2515:11:20.154-error:zigbee.0(15126)Errorherdsmanstart
          Thomas Braun Most Active @UHU01 last edited by Thomas Braun
          @uhu01 sagte in Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus:
          Und wenn du genau schaust und die Ausgabe hier zum Besten gibst?
          Mit 'scheinbaren Dingen' aus Nacherzählungen kann man nix anfangen.
          Und wo sind die Leerzeichen hin?
          Wie kopierst du das womit woher?
          So (ähnlich) soll das aussehen:
          2023-03-25 15:18:36.256  - info: host.chet instance system.adapter.zigbee.0 started with pid 368095
          2023-03-25 15:18:40.908  - info: zigbee.0 (368095) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.15.0, js-controller: 4.0.24
          2023-03-25 15:18:41.056  - info: zigbee.0 (368095) delete old Backup files. keep only last 10
          2023-03-25 15:18:41.058  - info: zigbee.0 (368095) Starting Zigbee  npm ...
          2023-03-25 15:18:41.721  - info: zigbee.0 (368095) Installed Version: iobroker.zigbee@1.8.10
          2023-03-25 15:18:53.842  - info: zigbee.0 (368095) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
          2023-03-25 15:18:53.854  - info: zigbee.0 (368095) Unable to disable LED, unsupported function.
          2023-03-25 15:18:53.876  - info: zigbee.0 (368095)   --> transmitPower : normal
          2023-03-25 15:18:53.883  - info: zigbee.0 (368095) Currently no devices.
          2023-03-25 15:18:53.885  - info: zigbee.0 (368095) Zigbee started
            Die PAN-ID muss übereinstimmen. Also im Adapter anpassen.
            • UHU01
              UHU01 @Thomas Braun last edited by UHU01
              hier die Ausgabe:
              lrwxrwxrwx 1 root root 13 25. Mär 12:47 usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 -> ../../ttyUSB0
              Und der Eintrag im Adapter:
              /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
              Und nochnal ein neues Log. Ist direkt aus Putty kopiert.
              2023-03-25 15:37:07.313  - info: zigbee.0 (15126) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
              2023-03-25 15:37:20.987  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2023-03-25 15:37:20.998  - info: zigbee.0 (15126) Got terminate signal TERMINATE_YOURSELF
              2023-03-25 15:37:21.041  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
              2023-03-25 15:37:21.000  - info: zigbee.0 (15126) cleaned everything up...
              2023-03-25 15:37:21.006  - info: zigbee.0 (15126) Zigbee: disabling joining new devices.
              2023-03-25 15:37:21.125  - warn: zigbee.0 (15126) Failed to stop zigbee during startup
              2023-03-25 15:37:21.126  - info: zigbee.0 (15126) terminating
              2023-03-25 15:37:21.128  - info: zigbee.0 (15126) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-03-25 15:37:21.716  - info: admin.0 (8202) <== Disconnect system.user.admin from ::ffff:192.168.178.241
              2023-03-25 15:37:21.829  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-03-25 15:37:24.299  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31775
              2023-03-25 15:37:30.150  - info: zigbee.0 (31775) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
              2023-03-25 15:37:30.295  - info: zigbee.0 (31775) delete old Backup files. keep only last 10
              2023-03-25 15:37:30.298  - info: zigbee.0 (31775) Starting Zigbee  npm ...
              2023-03-25 15:37:31.056  - info: zigbee.0 (31775) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:37:33.953  - info: zigbee.0 (31775) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
              2023-03-25 15:37:33.966  - info: zigbee.0 (31775) Unable to disable LED, unsupported function.
              2023-03-25 15:37:34.032  - info: zigbee.0 (31775)   --> transmitPower : normal
              2023-03-25 15:37:34.041  - info: zigbee.0 (31775) Currently no devices.
              2023-03-25 15:37:34.044  - info: zigbee.0 (31775) Zigbee started
              2023-03-25 15:37:34.055  - error: zigbee.0 (31775) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
              2023-03-25 15:37:34.242  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2023-03-25 15:37:34.252  - info: zigbee.0 (31775) Got terminate signal TERMINATE_YOURSELF
              2023-03-25 15:37:34.254  - info: zigbee.0 (31775) cleaned everything up...
              2023-03-25 15:37:34.256  - info: zigbee.0 (31775) Zigbee: disabling joining new devices.
              2023-03-25 15:37:34.289  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
              2023-03-25 15:37:34.755  - info: zigbee.0 (31775) terminating
              2023-03-25 15:37:34.758  - info: zigbee.0 (31775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-03-25 15:37:35.295  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 31775
              2023-03-25 15:37:35.444  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-03-25 15:37:37.465  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31980
              2023-03-25 15:37:42.769  - info: zigbee.0 (31980) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
              2023-03-25 15:37:42.932  - info: zigbee.0 (31980) delete old Backup files. keep only last 10
              2023-03-25 15:37:42.935  - info: zigbee.0 (31980) Starting Zigbee  npm ...
              2023-03-25 15:37:43.743  - info: zigbee.0 (31980) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:37:43.894  - error: zigbee.0 (31980) Configuration is not consistent with adapter state/backup!
              2023-03-25 15:37:43.895  - error: zigbee.0 (31980) - PAN ID: configured=6754, adapter=6754
              2023-03-25 15:37:43.895  - error: zigbee.0 (31980) - Extended PAN ID: configured=6b2ac77581741024, adapter=00124b0026b877e1
              2023-03-25 15:37:43.896  - error: zigbee.0 (31980) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
              2023-03-25 15:37:43.897  - error: zigbee.0 (31980) - Channel List: configured=11, adapter=11
              2023-03-25 15:37:43.898  - error: zigbee.0 (31980) Please update configuration to prevent further issues.
              2023-03-25 15:37:43.899  - error: zigbee.0 (31980) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
              2023-03-25 15:37:43.899  - error: zigbee.0 (31980) Re-commissioning your network will require re-pairing of all devices!
              2023-03-25 15:37:44.068  - error: zigbee.0 (31980) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
              2023-03-25 15:37:44.069  - error: zigbee.0 (31980) Failed to start Zigbee
              2023-03-25 15:37:44.070  - error: zigbee.0 (31980) Error herdsman start
              2023-03-25 15:37:54.075  - info: zigbee.0 (31980) Try to reconnect. 1 attempts left
              2023-03-25 15:37:54.076  - info: zigbee.0 (31980) Starting Zigbee  npm ...
              2023-03-25 15:37:54.120  - info: zigbee.0 (31980) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:37:54.372  - error: zigbee.0 (31980) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              2023-03-25 15:37:54.373  - error: zigbee.0 (31980) Failed to start Zigbee
              2023-03-25 15:37:54.374  - error: zigbee.0 (31980) Error herdsman start
              2023-03-25 15:37:58.384  - info: host.raspberrypi "system.adapter.zigbee.0" disabled
              2023-03-25 15:37:58.384  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2023-03-25 15:37:58.395  - info: zigbee.0 (31980) Got terminate signal TERMINATE_YOURSELF
              2023-03-25 15:37:58.397  - info: zigbee.0 (31980) cleaned everything up...
              2023-03-25 15:37:58.406  - info: zigbee.0 (31980) Zigbee: disabling joining new devices.
              2023-03-25 15:37:58.462  - warn: zigbee.0 (31980) Failed to stop zigbee during startup
              2023-03-25 15:37:58.463  - info: zigbee.0 (31980) terminating
              2023-03-25 15:37:58.466  - info: zigbee.0 (31980) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-03-25 15:37:58.588  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
              2023-03-25 15:37:59.101  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-03-25 15:38:01.241  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
              2023-03-25 15:38:01.582  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 32191
              2023-03-25 15:38:07.197  - info: zigbee.0 (32191) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
              2023-03-25 15:38:07.373  - info: zigbee.0 (32191) delete old Backup files. keep only last 10
              2023-03-25 15:38:07.376  - info: zigbee.0 (32191) Starting Zigbee  npm ...
              2023-03-25 15:38:08.268  - info: zigbee.0 (32191) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:38:08.421  - error: zigbee.0 (32191) Configuration is not consistent with adapter state/backup!
              2023-03-25 15:38:08.422  - error: zigbee.0 (32191) - PAN ID: configured=6754, adapter=6754
              2023-03-25 15:38:08.423  - error: zigbee.0 (32191) - Extended PAN ID: configured=6b2ac77581741024, adapter=00124b0026b877e1
              2023-03-25 15:38:08.424  - error: zigbee.0 (32191) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
              2023-03-25 15:38:08.425  - error: zigbee.0 (32191) - Channel List: configured=11, adapter=11
              2023-03-25 15:38:08.425  - error: zigbee.0 (32191) Please update configuration to prevent further issues.
              2023-03-25 15:38:08.426  - error: zigbee.0 (32191) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
              2023-03-25 15:38:08.427  - error: zigbee.0 (32191) Re-commissioning your network will require re-pairing of all devices!
              2023-03-25 15:38:08.595  - error: zigbee.0 (32191) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
              2023-03-25 15:38:08.596  - error: zigbee.0 (32191) Failed to start Zigbee
              2023-03-25 15:38:08.597  - error: zigbee.0 (32191) Error herdsman start
              2023-03-25 15:38:13.204  - info: admin.0 (8202) ==> Connected system.user.admin from ::ffff:192.168.178.241
              2023-03-25 15:38:13.362  - error: zigbee.0 (32191) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              2023-03-25 15:38:13.593  - info: zigbee.0 (32191) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
              2023-03-25 15:38:18.601  - info: zigbee.0 (32191) Try to reconnect. 1 attempts left
              2023-03-25 15:38:18.602  - info: zigbee.0 (32191) Starting Zigbee  npm ...
              2023-03-25 15:38:18.648  - info: zigbee.0 (32191) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:38:18.917  - error: zigbee.0 (32191) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              2023-03-25 15:38:18.918  - error: zigbee.0 (32191) Failed to start Zigbee
              2023-03-25 15:38:18.918  - error: zigbee.0 (32191) Error herdsman start
              2023-03-25 15:38:26.219  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2023-03-25 15:38:26.226  - info: zigbee.0 (32191) Got terminate signal TERMINATE_YOURSELF
              2023-03-25 15:38:26.269  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
              2023-03-25 15:38:26.228  - info: zigbee.0 (32191) cleaned everything up...
              2023-03-25 15:38:26.236  - info: zigbee.0 (32191) Zigbee: disabling joining new devices.
              2023-03-25 15:38:26.288  - warn: zigbee.0 (32191) Failed to stop zigbee during startup
              2023-03-25 15:38:26.289  - info: zigbee.0 (32191) terminating
              2023-03-25 15:38:26.291  - info: zigbee.0 (32191) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-03-25 15:38:26.928  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-03-25 15:38:27.067  - info: admin.0 (8202) <== Disconnect system.user.admin from ::ffff:192.168.178.241
              2023-03-25 15:38:29.749  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 32552
              2023-03-25 15:38:34.927  - info: zigbee.0 (32552) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
              2023-03-25 15:38:35.116  - info: zigbee.0 (32552) delete old Backup files. keep only last 10
              2023-03-25 15:38:35.120  - info: zigbee.0 (32552) Starting Zigbee  npm ...
              2023-03-25 15:38:35.800  - info: zigbee.0 (32552) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:38:35.951  - error: zigbee.0 (32552) Configuration is not consistent with adapter state/backup!
              2023-03-25 15:38:35.952  - error: zigbee.0 (32552) - PAN ID: configured=6753, adapter=6754
              2023-03-25 15:38:35.953  - error: zigbee.0 (32552) - Extended PAN ID: configured=6b2ac77581741024, adapter=00124b0026b877e1
              2023-03-25 15:38:35.953  - error: zigbee.0 (32552) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
              2023-03-25 15:38:35.954  - error: zigbee.0 (32552) - Channel List: configured=11, adapter=11
              2023-03-25 15:38:35.955  - error: zigbee.0 (32552) Please update configuration to prevent further issues.
              2023-03-25 15:38:35.956  - error: zigbee.0 (32552) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
              2023-03-25 15:38:35.956  - error: zigbee.0 (32552) Re-commissioning your network will require re-pairing of all devices!
              2023-03-25 15:38:36.123  - error: zigbee.0 (32552) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
              2023-03-25 15:38:36.124  - error: zigbee.0 (32552) Failed to start Zigbee
              2023-03-25 15:38:36.124  - error: zigbee.0 (32552) Error herdsman start
              2023-03-25 15:38:46.130  - info: zigbee.0 (32552) Try to reconnect. 1 attempts left
              2023-03-25 15:38:46.131  - info: zigbee.0 (32552) Starting Zigbee  npm ...
              2023-03-25 15:38:46.183  - info: zigbee.0 (32552) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:38:46.470  - error: zigbee.0 (32552) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              2023-03-25 15:38:46.471  - error: zigbee.0 (32552) Failed to start Zigbee
              2023-03-25 15:38:46.472  - error: zigbee.0 (32552) Error herdsman start
              2023-03-25 15:39:21.701  - info: admin.0 (8202) ==> Connected system.user.admin from ::ffff:192.168.178.241
              2023-03-25 15:39:21.973  - error: zigbee.0 (32552) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              2023-03-25 15:39:22.212  - info: zigbee.0 (32552) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
              2023-03-25 15:39:30.643  - info: host.raspberrypi "system.adapter.zigbee.0" disabled
              2023-03-25 15:39:30.644  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2023-03-25 15:39:30.692  - info: zigbee.0 (32552) Got terminate signal TERMINATE_YOURSELF
              2023-03-25 15:39:30.693  - info: zigbee.0 (32552) cleaned everything up...
              2023-03-25 15:39:30.699  - info: zigbee.0 (32552) Zigbee: disabling joining new devices.
              2023-03-25 15:39:30.815  - warn: zigbee.0 (32552) Failed to stop zigbee during startup
              2023-03-25 15:39:30.817  - info: zigbee.0 (32552) terminating
              2023-03-25 15:39:30.819  - info: zigbee.0 (32552) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-03-25 15:39:30.914  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
              2023-03-25 15:39:31.450  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-03-25 15:39:33.294  - info: admin.0 (8202) <== Disconnect system.user.admin from ::ffff:192.168.178.241
              2023-03-25 15:39:37.090  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
              2023-03-25 15:39:37.400  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 858
              2023-03-25 15:39:42.719  - info: zigbee.0 (858) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
              2023-03-25 15:39:42.859  - info: zigbee.0 (858) delete old Backup files. keep only last 10
              2023-03-25 15:39:42.861  - info: zigbee.0 (858) Starting Zigbee  npm ...
              2023-03-25 15:39:43.741  - info: zigbee.0 (858) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:39:43.899  - error: zigbee.0 (858) Configuration is not consistent with adapter state/backup!
              2023-03-25 15:39:43.901  - error: zigbee.0 (858) - PAN ID: configured=6754, adapter=6754
              2023-03-25 15:39:43.902  - error: zigbee.0 (858) - Extended PAN ID: configured=6b2ac77581741024, adapter=00124b0026b877e1
              2023-03-25 15:39:43.903  - error: zigbee.0 (858) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
              2023-03-25 15:39:43.904  - error: zigbee.0 (858) - Channel List: configured=11, adapter=11
              2023-03-25 15:39:43.906  - error: zigbee.0 (858) Please update configuration to prevent further issues.
              2023-03-25 15:39:43.907  - error: zigbee.0 (858) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
              2023-03-25 15:39:43.907  - error: zigbee.0 (858) Re-commissioning your network will require re-pairing of all devices!
              2023-03-25 15:39:44.094  - error: zigbee.0 (858) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
              2023-03-25 15:39:44.095  - error: zigbee.0 (858) Failed to start Zigbee
              2023-03-25 15:39:44.096  - error: zigbee.0 (858) Error herdsman start
              2023-03-25 15:39:54.102  - info: zigbee.0 (858) Try to reconnect. 1 attempts left
              2023-03-25 15:39:54.103  - info: zigbee.0 (858) Starting Zigbee  npm ...
              2023-03-25 15:39:54.136  - info: zigbee.0 (858) Installed Version: iobroker.zigbee@1.8.10
              2023-03-25 15:39:54.505  - error: zigbee.0 (858) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              2023-03-25 15:39:54.507  - error: zigbee.0 (858) Failed to start Zigbee
              2023-03-25 15:39:54.508  - error: zigbee.0 (858) Error herdsman start
              2023-03-25 15:41:21.022  - info: admin.0 (8202) ==> Connected system.user.admin from ::ffff:192.168.178.241
              2023-03-25 15:41:21.204  - error: zigbee.0 (858) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              2023-03-25 15:41:21.370  - info: zigbee.0 (858) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
              Thomas Braun 3 Replies Last reply Reply Quote 0
                Anpassen.
                  node: v16.19.0
                  könntest du auf die aktuelle Empfehlung nodejs@18 bringen.
                    @uhu01
                    Den Chipsatztyp musst du wohl auch von TI Z-Stack/CCxxxx
                    auf Silicon Labs EZSP/EFR32 setzen.
                    • UHU01
                      UHU01 last edited by UHU01
                      nodejs aktualisiert,
                      mehrfach die Extended PAN ID aktualisiert,
                      mehrfach den Adaper neu gestartet,
                      jetzt funktioniert es!
                      Danke Dir vielmals!
                      P.S. TI Z-Stack/CCxxxx war aber richtig, zumindest habe ich es nicht geändert.
                        Honnkoponko @UHU01 last edited by
                        @uhu01
                        hallo könntest du mir bitte sagen wie kann ich SonOff installieren?
                        Muss ich nur Instanz/Adapter einfügen oder zuerst muss ich etwas mit USB installieren? Gibt es eine Anleitung wie ich das machen soll?
                        • Asgothian
                          Asgothian Developer @Honnkoponko last edited by
                          @honnkoponko sagte in Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus:
                          @uhu01
                          unter der Bedingung das du einfach einen nativ installierten ioBroker hast:
                          • Zigbee Adapter installieren, NICHT starten
                          • Im Zigbee-Adapter den seriellen Port vom Sonoff Stick eintragen (entweder /dev/ttyAM... oder /dev/serial/by-id/...
                          • Korrekte Firmware aussuchen (ember bei Dongle-E, TI-ZStack bei Dongle-P)
                          • PanID und ExtPanID anpassen
                          • Adapter starten
                          A.
                            Honnkoponko @Asgothian last edited by
                            @asgothian
                            danke
                            wäre es möglich dass du mir schreibst wie jeder Punkt kann ich machen? Ich kenne mich nicht aus mit Befehle und Konsole leider...
                              Hallo @Thomas-Braun
                              Könntest du mir auch mit USB SonOff helfen ich bekomme folgendes Fehler
                              2024-11-18 11:51:00.730  - info: host.domiobroker77 "system.adapter.zigbee.0" disabled
                              2024-11-18 11:51:00.731  - info: host.domiobroker77 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                              2024-11-18 11:51:00.739  - info: zigbee.0 (1725) Got terminate signal TERMINATE_YOURSELF
                              2024-11-18 11:51:00.742  - info: zigbee.0 (1725) cleaned everything up...
                              2024-11-18 11:51:00.754  - info: zigbee.0 (1725) Zigbee: disabling joining new devices.
                              2024-11-18 11:51:00.774  - warn: zigbee.0 (1725) Failed to stop zigbee during startup
                              2024-11-18 11:51:00.775  - info: zigbee.0 (1725) terminating
                              2024-11-18 11:51:00.776  - debug: zigbee.0 (1725) Plugin sentry destroyed
                              2024-11-18 11:51:00.777  - info: zigbee.0 (1725) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-11-18 11:51:00.830  - info: host.domiobroker77 stopInstance system.adapter.zigbee.0 send kill signal
                              2024-11-18 11:51:01.245  - info: zigbee.0 (1725) terminating
                              2024-11-18 11:51:01.366  - info: host.domiobroker77 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-11-18 11:51:11.212  - info: host.domiobroker77 "system.adapter.zigbee.0" enabled
                              2024-11-18 11:51:11.663  - info: host.domiobroker77 instance system.adapter.zigbee.0 in version "1.10.3" started with pid 1835
                              2024-11-18 11:51:15.573  - debug: zigbee.0 (1835) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2024-11-18 11:51:15.620  - debug: zigbee.0 (1835) Objects client ready ... initialize now
                              2024-11-18 11:51:15.623  - debug: zigbee.0 (1835) Objects create System PubSub Client
                              2024-11-18 11:51:15.625  - debug: zigbee.0 (1835) Objects create User PubSub Client
                              2024-11-18 11:51:15.697  - debug: zigbee.0 (1835) Objects client initialize lua scripts
                              2024-11-18 11:51:15.709  - debug: zigbee.0 (1835) Objects connected to redis: 127.0.0.1:9001
                              2024-11-18 11:51:15.753  - debug: zigbee.0 (1835) Redis States: Use Redis connection: 127.0.0.1:9000
                              2024-11-18 11:51:15.773  - debug: zigbee.0 (1835) States create System PubSub Client
                              2024-11-18 11:51:15.775  - debug: zigbee.0 (1835) States create User PubSub Client
                              2024-11-18 11:51:15.847  - debug: zigbee.0 (1835) States connected to redis: 127.0.0.1:9000
                              2024-11-18 11:51:15.891  - debug: zigbee.0 (1835) Plugin sentry Initialize Plugin (enabled=true)
                              2024-11-18 11:51:16.397  - info: zigbee.0 (1835) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.16.0, js-controller: 6.0.9
                              2024-11-18 11:51:16.446  - debug: zigbee.0 (1835) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[139,122,111,94,77,60,43,26]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_5a52e2baefdbed118632e92d62c613ac-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                              2024-11-18 11:51:16.535  - info: zigbee.0 (1835) delete old Backup files. keep only last 10
                              2024-11-18 11:51:16.537  - info: zigbee.0 (1835) Starting Zigbee  npm ...
                              2024-11-18 11:51:16.600  - debug: zigbee.0 (1835) Starting zigbee-herdsman...
                              2024-11-18 11:51:17.011  - info: zigbee.0 (1835) Installed Version: iobroker.zigbee@1.10.3
                              2024-11-18 11:51:17.405  - debug: zigbee.0 (1835) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_11_18-11_51_16.tar.gz success
                              2024-11-18 11:51:37.754  - error: zigbee.0 (1835) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                              2024-11-18 11:51:37.755  - error: zigbee.0 (1835) Failed to start Zigbee
                              2024-11-18 11:51:37.756  - error: zigbee.0 (1835) Error herdsman start
                              2024-11-18 11:51:47.761  - info: zigbee.0 (1835) Try to reconnect. 1 attempts left
                              2024-11-18 11:51:47.762  - info: zigbee.0 (1835) Starting Zigbee  npm ...
                              2024-11-18 11:51:47.769  - debug: zigbee.0 (1835) Starting zigbee-herdsman...
                              2024-11-18 11:51:47.779  - info: zigbee.0 (1835) Installed Version: iobroker.zigbee@1.10.3
                              2024-11-18 11:51:47.975  - error: zigbee.0 (1835) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                              2024-11-18 11:51:47.978  - error: zigbee.0 (1835) Failed to start Zigbee
                              2024-11-18 11:51:47.979  - error: zigbee.0 (1835) Error herdsman start
                              Hier ich liste was ich gemacht habe:
                              1. Mit
                              /dev/serial/by-id/
                              Habe ich Device bekommen:
                              mwit@domiobroker77:~ $ ls /dev/serial/by-id/
                              1. In Adapter Setting habe ich das eingetragen (mit DevID und ExtDevID)
                              Adapter started und will nicht grün sein...;(
                              Was kann ich dort anpassen?
                              Wie kann ich aus Putty nur zigbee Logs zeigen?
                              Mit
                              mwit@domiobroker77:~ $ iob logs --watch | uniq
                              Zeig alle Adapter Logs. Kann ich das irgendwie filtern?
                              haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
                              • haselchen
                                haselchen Most Active @Honnkoponko last edited by
                                @honnkoponko
                                Es reicht ja wenn du das Log vom Adapterstart zeigst.
                                Eventuell im Adapter noch den Debug Modus anschalten.
                                  Thomas Braun Most Active @Honnkoponko last edited by
                                  Deutet auf Trouble mit der Firmware hin. Steck das Ding mal aus und nach ein paar Minuten wieder ein. Betreibst du den Stick an einer USB-Verlängerung?
                                  Ordentlicher Reboot schadet auch nichts.
                                    Honnkoponko @Thomas Braun last edited by
                                    Reboot habe ich gemacht
                                    Ich probiere noch mit rein und raus
                                    Ich nutze USB Verlängerung (nicht möglich direkt in USB port einstecken)
                                    Ist das fixierbar oder einfacher CC2652P Zigbee Dongle kaufen? (habe ich gelesen CC2531 haben Probleme)
                                    Soll ich andere USB Port versuchen - macht das Sinn?
                                      Ja, aber der Sonoff 3.0 hat ohnehin einen anderen Chipsatz, nicht den CC2531.
                                      Ich weiß nie, welchen der beiden bei Sonoff gerade verwendet wird. Stell mal testweise den Stack auf EZSP (oder so ähnlich) um.
                                        Honnkoponko @Thomas Braun last edited by Honnkoponko
                                        Habe ich rein raus gemacht und nichts.
                                        Für EZSP EInstellung:
                                        zigbee.0
                                        PID
                                        Time
                                        debug
                                        Message
                                        zigbee.0
                                        2052	2024-11-18 12:48:57.567	error	Error herdsman start
                                        zigbee.0
                                        2052	2024-11-18 12:48:57.567	error	Failed to start Zigbee
                                        zigbee.0
                                        2052	2024-11-18 12:48:57.566	error	Starting zigbee-herdsman problem : "Failure to connect"
                                        zigbee.0
                                        2052	2024-11-18 12:48:27.322	info	Installed Version: iobroker.zigbee@1.10.3
                                        zigbee.0
                                        2052	2024-11-18 12:48:27.312	debug	Starting zigbee-herdsman...
                                        zigbee.0
                                        2052	2024-11-18 12:48:27.304	info	Starting Zigbee npm ...
                                        zigbee.0
                                        2052	2024-11-18 12:48:27.303	info	Try to reconnect. 1 attempts left
                                        zigbee.0
                                        2052	2024-11-18 12:48:17.297	error	Error herdsman start
                                        zigbee.0
                                        2052	2024-11-18 12:48:17.296	error	Failed to start Zigbee
                                        zigbee.0
                                        2052	2024-11-18 12:48:17.294	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                        Ich habe ZBDongle-E so ich denke es ist CC2652P CHipset
                                        Einstellung sollte TI Z-Stack/CCxxxx sein
                                        Was kann ich noch probieren?
                                        Andere USB Port oder was?
                                        DOngle ist in USB 2.0 - soll ich USB 3.0 nutzen?
                                        Oder USB-Verlängerung ist zu lange - ich habe 5m...Kann das Probleme machen?
                                        Asgothian haselchen 2 Replies Last reply Reply Quote 0
                                        • Asgothian
                                          zigbee.0
                                          PID
                                          Time
                                          debug
                                          Message
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          Der Sonoff-ZBDongle-e sollte einen EZSP Chipsatz haben. Ansonsten beschwert sich der Adapter über eine inkonsistente Konfiguration. Daher bitte
                                          • Adapter anhalten
                                          • sicher gehen das kein Zigbee Prozess mehr läuft - das kann bis zu 20 Sekunden dauern
                                          • die Datei nvbackup.json im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 löschen
                                          • adapter wieder starten
                                          A.
                                          • haselchen
                                            haselchen Most Active @Honnkoponko last edited by haselchen
                                            @honnkoponko
                                            Nun mal nicht so hippelig.
                                            Hast Du ein -E oder -P ?
                                            Welche Firmware ist auf dem Stick?
                                            Wenn wir das alles geklärt haben , versuch mal die PAN ID auf Ausgangslage zu setzen .
                                            Alles große D.
                                            Aber erst wenn das oben geklärt ist.
                                            9215
