      bitwicht last edited by
      die CAM lief seit monaten ohne Probleme und jetzt bekomme ich den Fehler:
      Sie startet dann alle paar Sekunden neu.
      Hardwaredefekt?
      [0d00h00m00s] 2024-09-03T10:35:21 <INF> [MAIN] =================================================
      [0d00h00m00s] 2024-09-03T10:35:21 <INF> [MAIN] ==================== Start ======================
      [0d00h00m00s] 2024-09-03T10:35:21 <INF> [MAIN] PSRAM size: 8388608 byte (8MB / 64MBit)
      [0d00h00m00s] 2024-09-03T10:35:21 <INF> [MAIN] Total heap: 4376759 byte
      [0d00h00m08s] 2024-09-03T10:35:29 <ERR> [MAIN] Camera framebuffer check failed
      [0d00h00m08s] 2024-09-03T10:35:29 <ERR> [HELPER] New System Status: 0x00000100
      [0d00h00m08s] 2024-09-03T10:35:29 <INF> [MAIN] Camera info: PID: 0x26, VER: 0x42, MIDL: 0x7f, MIDH: 0xa2
      [0d00h00m08s] 2024-09-03T10:35:30 <INF> [SDCARD] Basic R/W check started...
      [0d00h00m08s] 2024-09-03T10:35:30 <INF> [SDCARD] Basic R/W check successful
      [0d00h00m08s] 2024-09-03T10:35:30 <INF> [SNTP] TimeServer not defined, using default: pool.ntp.org
      [0d00h00m08s] 2024-09-03T10:35:30 <INF> [SNTP] Configuring NTP Client...
      [0d00h00m08s] 2024-09-03T12:35:30 <INF> [SNTP] Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
      [0d00h00m08s] 2024-09-03T12:35:30 <INF> [SNTP] Time is already set: 2024-09-03 12:35:30
      [0d00h00m08s] 2024-09-03T12:35:30 <INF> [MAIN] CPU frequency: 160 MHz
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [SDCARD] Folder/file presence check started...
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [SDCARD] Folder/file presence check successful
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [MAIN] Tag: 'v15.3.0', Release: v15.3.0 (Commit: 3fbff0a), Date/Time: 2023-07-22 09:42, Web UI: Release: v15.3.0 (Commit: 3fbff0a)
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [MAIN] Reset reason: Via esp_restart
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [WLANINI] SSID: xxxxx
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [WLANINI] Password: XXXXXXXX
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [WLANINI] Hostname: xxxxx
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [WLANINI] RSSIThreshold: 0
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [MAIN] WLAN config loaded, init WIFI...
      [0d00h00m09s] 2024-09-03T12:35:30 <INF> [WIFI] Automatic interface config --> Use DHCP service
      [0d00h00m09s] 2024-09-03T12:35:31 <INF> [WIFI] Set hostname to: xxxxxxx
      [0d00h00m09s] 2024-09-03T12:35:31 <INF> [WIFI] Init successful
      [0d00h00m13s] 2024-09-03T12:35:35 <INF> [WIFI] Connected to: xxxxx, RSSI: -83
      [0d00h00m14s] 2024-09-03T12:35:36 <INF> [WIFI] Assigned IP: xxxxxx
      [0d00h00m15s] 2024-09-03T12:35:37 <INF> [SNTP] Time is synced with NTP Server pool.ntp.org: 2024-09-03 12:35:37
      [0d00h00m17s] 2024-09-03T12:35:39 <INF> [MAIN] Device info: CPU cores: 2, Chip revision: 100
      [0d00h00m17s] 2024-09-03T12:35:39 <INF> [MAIN] SD card info: Name: SD32G, Capacity: 30448MB, Free: 30414MB
      [0d00h00m19s] 2024-09-03T12:35:41 <WRN> [MAIN] Initialization completed with non-critical errors!
      [0d00h00m21s] 2024-09-03T12:35:43 <INF> [LOGFILE] Set log level to ERROR
      [0d00h00m36s] 2024-09-03T12:35:58 <ERR> [CAM] is not working anymore (CaptureToBasisImage) - most probably caused by a hardware problem (instablility, ...). System will reboot.
      • ESP8266
        ESP8266 last edited by ESP8266
        @bitwicht , ich würde erstmal die Cam neu stecken. Sonst neu aufsetzen.
          Dan.Master @ESP8266 last edited by
          Hallo bei begann so ein Verhalten mit einem "gutem" IKEA Netzteil.
          Die ESP32 im CAM Modus sind meiner Erfahrung nach auch sehr empfindlich bei der Spannungsversorgung. Probiere auch mal ein anderes Netzteil
          DerDani
            final @Dan.Master last edited by final
            Moin Zusammen.
            Ich habe einen Itron Aquadis DN20 Zähler, und würde gerne auch mit Ai-on-the-edge auslesen und in iobroker über MQTT einbinden.
            Die Diskussion auf github mit funktionierenden ESP32Cam Modulen hab ich gefunden, allerdings haben gerade die neueren genannten Produkte auf Amazon eher schlechte Bewertungen.
            Kann mir jemand ein Board empfehlen was definitiv funktioniert und zu einem annehmbaren Preis beschaffbar ist?
            EDIT: Achja, ich werde wohl relativ sicher eine externe Antenne brauchen - muss dafür immer gelötet werden?
            Und über einen Tip für ein zu meinem Zähler passenden 3D-Druck Gehäuse würde ich mich auch freuen. 🙂
            Danke,
            • ESP8266
              ESP8266 @final last edited by ESP8266
              @all, nur zur Info, mir ist vorgestern der ESP32 am Stromzähler abgeraucht. Nach gut drei Jahren hat er sich abgemeldet. Gott sei Dank hat er nur sein Gedächnis verloren. Neu geflasht und läuft wieder. Also kann sowas auch passieren.
              @final, für externe Antenne muss gelötet werden. Manche Händler bieten das an.
              Frag mal bei Makershop oder AZ-Delivery an. Sind eigentlich sehr vertrauenswürdig.
              Hatte damit noch nie Probleme und wenn einfach via E-Mail reklarmieren.
              Das Gehäuse kann aus Dosen, Papp- oder HT-Rohren gebastelt werden. Hier setzt die Krativität keine Grenzen. Bilder gibts hier on mass...
                final @ESP8266 last edited by
                @esp8266
                Ok, danke, mir gings erstmal nur um das "ob". SMD Löten kann ich in der Firma (machen lassen), das sollte nicht das Problem sein.
                Hab jetzt trotz der durchwachsenen Bewertungen was bestellt, muss dann am WE mal schauen wie es mit dem flashen funktioniert.
                Wo ich mir jetzt noch unsicher bin - hat das ESP32Cam board eine LED für die Kamera, oder braucht man zwingend externe Beleuchtung?
                • ESP8266
                  @final , das kommt auf dein Aufbau an. Ich verwende in der Wasseruhr ein Ring aus 12 oder 15 RGB Leds (gerade nicht im Kopf). Kommt auf den Durchmesser an. Beim Stromzähler nur eine LED ext.
                    @esp8266
                    Ok, also nur mit dem board wird das nix, ich muss extra beleuchten. Ok, dann schaue ich mal was ich dazu in der Doku finde - hatte irgendwie den Eindruck gewonnen dass das Board oder die Kamera zumindest eine LED hat.
                    • ESP8266
                      @final sagte in Wasserzähler - Version 2 - all-in-device:
                      @esp8266
                      Wodran machst du das fest? Ich habe geschrieben das es bei mir der Fall ist. Weil ich eine Glaswölbung habe und zuviel Reflektionen.
                      Das kann bei dir ganz anders sein. Kenn nicht mal deine Uhr. Ein Foto wäre hilfreich.
                      Meine Uhr:
                      Ohne ext. Antenne. Nur im StromZählerschrank mit. Da ich noch ein Shelly em3 verbaut habe, brauch ich den Zählerstand als Referenz. Damit die Werte nicht auseinander laufen.
                        @esp8266
                        Ok, vielleicht ein Mißverständnis. 🙂
                        Dann die direkte Frage: hat das Board oder die Cam irgendeine integrierte Beleuchtung? (Welche dann uU ausreichend sein könnte, oder auch nicht)
                        Ich hab ja noch keine Halterung, aber mein Keller mit dem Zähler ist normalerweise stockdunkel. Und wenn die Halterung eher eine Art Rohr über dem Zähler wird, dann ist es ja im Rohr auch dunkel.
                        Ich will ja nur wissen, ob ich eventuell keine Zusatzbeleuchtung brauche, oder mich jetzt schon mal nach was umsehen muss.
                        • ESP8266
                          @final , ich denke du hast die Wiki gelesen. Selbstverständlich sitzt auf dem Board ein hochleistungs LED Blitz. Auch in so einer Beschreibung sieht man das.
                            @esp8266
                            Dann hab ich wohl nicht gut genug gelesen, Asche auf mein Haupt! Dann steht ja einem Bastelwochenende nix mehr im Weg 😄
                            • ESP8266
                              @final ,
                              Bei Berrybase kann man ihn auch kaufen. Mit Adapterplatine. Zu billig würde ich eh nicht kaufen....Geiz macht arm. Wenn man nur Schrott kauft von so ominösen Verkäufern.
                              Ich habe in China 2 vertrauenswürdige Verkäufer. Wenn ich Zeit habe, bestelle ich dort. Dort bekomme ich auch die CC1101 Chips die funktionieren.
                                final @ESP8266 last edited by final
                                @Homoran
                                ich hatte weiter oben gesehen, dass du auch einen itron Zähler hast. Bist du bei deiner stylischen Tube geblieben, oder hast du dir ein 3D Druck Teil gemacht? Ich finde nämlich im thingiverse leider keinen itron Adapter...
                                Und - weißt du, wofür dieser bewegliche Plastikschieber da ist?
                                Anbei mal ein Foto von meinem Zähler.
                                ESP8266 2 Replies Last reply Reply Quote 0
                                • ESP8266
                                  @final , lange nicht geputzt.....😊
                                    @esp8266
                                    fürs menschliche Auge ausreichend sauber 😄
                                    • ESP8266
                                      @Homoran
                                      Wo weiter oben? Bei Seite 0 , 1000, 2000, 3000 oder dazwischen? Ich hätte es mir gerne angeschaut.
                                      Der Zähler hat doch ein M-Bus Anschluß. Warum dann so ein Aufwand?
                                      https://www.bellflowsystems.co.uk/de/flow-meters-by-application/water-flow-meters/mechanical-water-meters/itron-water-meters/itron-aquadis-rotary-piston-water-meter-range/itron-aquadis-brass-cold-water-meter.html
                                      Es gibt für den Zähler auf Thinkiverse nur ein Model mit einem Sensor für Impulszählung.
                                      https://www.thingiverse.com/thing:4146391
                                      Oder selbst Konstruieren...
                                        @esp8266
                                        schau mal im Bereich 1070 bis 1100, da sind einige Posts von homoran zum Thema Ziffernerkennung, und da kann man auch sehen, dass er fast den gleichen Zähler wie ich hat.
                                        M-Bus und Impulszählung sagt mir leider gar nichts.
                                        Im Datenblatt habe ich was von einem optionalen cyble Sensor gelesen, weiß aber nicht was das ist, und ob das Herstellerseitig nur vorbereitet ist oder so. Ist das das gleiche wie M-Bus?
                                        Dein Link führt zu einer Halterung für so einen Sensor, aber ich suche ja was für den ESP32.
                                        Würdest du sagen, wenn man die Wahl hat, dann lieber einen Impulszähler?
                                        • ESP8266
                                          @final , das kann ich dir alles nicht beantworten. Mein Zähler war auch nirgends dabei gewesen.
                                          Habe mir als Grundlage mehrere Ringe ausgedruckt. Der erste musste angepasst werden wegen der Klappe. Durchmesser muss auch stimmen. Der Kopf ist so geblieben. Dann habe ich mit den Ringen variert bis ich zum besten Ergebnis gekommen bin. LED´s noch rein geklebt und das Ergebnis sieht man ja.
                                          Also ist auch ein bischen Hirnschmalz von nöten....😊
                                          596ffdd8-4549-48aa-8c83-7db2b7feeeae-WhatsApp Bild 2024-09-21 um 12.28.26_8cd0d7b0.jpg
                                          Festgeklebt mit Tesa Pads. Geht sofort ab
                                          Gesamthöhe ca. 8,5cm. Vom unteren Rand des Gehäuses bis oberer Rand vom Deckel. Nicht vom ESP.
                                          Und....fast vergessen das Kunststoffgehäuse um die Uhr musste fixiert werden.
                                          Der Ableser hat noch nie verlangt, solche Aufbauten zu entfernen. Im Gegenteil er ist mit den Handyfotos zufrieden. Strom und Wasser.
                                          Appropo, ich würde für deine Uhr keine Probleme sehen.
                                          Auch sehe ich an deiner Uhr kein Schiebeschalter. Nur drei Halter für einen Aufsatz.
                                            @esp8266
                                            Jetzt fehlt mir doch glatt eine Micro SD Karte...
                                            Reichen 8GB? Dann bestelle ich schnell eine.
                                            Ich hab noch eine Verständnisfrage zum flashen mit dem web installer:
                                            Dort steht "keeping the flash button pressed while the reset button gets released".
                                            Wie bitte ist das denn gemeint?
                                            Ich hab links und rechts neben dem usb Anschluss je einen Button. Rechts steht rst, links sieht wie l00 aus.
                                            238
                                            3411
                                            2022779
