    4. Kann IoBroker nicht mehr aufrufen
      Thomas Braun Most Active @Fuxsism last edited by Thomas Braun
      @fuxsism
      This system needs to be REBOOTED!
      Mach das!
      sudo systemctl set-default multi-user.target
      iob stop
      sudo reboot
        Fuxsism @Thomas Braun last edited by
        hab ich gemacht...
        dann neu auf der Konsole anmelden?
          @fuxsism sagte in Kann IoBroker nicht mehr aufrufen:
          Ja, und dann einen frischen Lauf von
          iob diag
            Fuxsism last edited by Homoran
            nach erneuter Anmeldung per Terminal:
            iobroker@iobroker:~ $ Connection to iobroker closed by remote host.
            Connection to iobroker closed.
            fuxism@MBP-von-Michael ~ % ssh iobroker@iobroker
            iobroker@iobroker's password:
            Linux iobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Sun Sep 22 13:11:31 2024
            Wi-Fi is currently blocked by rfkill.
            Use raspi-config to set the country before use.
            -bash: source: /home/iobroker/.iobroker/iobroker_completions: Kann die Datei nicht ausführen.
              wenn ich Job Diagnose starte kommt das:
              The state system.host.iobroker.versions.nodeNewestNext was not found!
              The state system.host.iobroker.versions.npmNewestNext was not found!
              The state system.host.iobroker.versions.nodeCurrent was not found!
                @fuxsism
                Man meldet sich ja auch nicht als user 'iobroker' sondern mit seinem richtigen Login an.
                  Lob Diagnose sagt nun:
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                     Static hostname: iobroker
                           Icon name: computer
                    Operating System: Debian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  Model		: Raspberry Pi 4 Model B Rev 1.2
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   13:13:36 up 1 min,  3 users,  load average: 4.90, 1.95, 0.72
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Sun 2024-09-22 13:13:37 CEST
                             Universal time: Sun 2024-09-22 11:13:37 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
                  iobroker
                  HOME=/home/iobroker
                  *** Display-Server-Setup ***
                  Display-Server: true
                  Desktop:
                  Terminal: 	tty
                  Boot Target: 	graphical.target
                  *** MEMORY ***
                  Mem:            3.8G        1.6G        1.5G         35M        732M        2.1G
                  Swap:            99M          0B         99M
                  Total:          3.9G        1.6G        1.6G
                  Active iob-Instances: 	18
                           3794 M total memory
                           1566 M used memory
                           1753 M active memory
                            379 M inactive memory
                           1495 M free memory
                             45 M buffer memory
                            687 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  top - 13:13:37 up 1 min,  3 users,  load average: 4.90, 1.95, 0.72
                  Tasks: 216 total,   4 running, 212 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 28.0 us,  9.3 sy,  0.0 ni, 61.3 id,  0.0 wa,  0.0 hi,  1.3 si,  0.0 st
                  MiB Mem :   3794.3 total,   1494.7 free,   1566.6 used,    733.0 buff/cache
                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2117.1 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4       29G  7.8G   20G  28% /
                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                  tmpfs          tmpfs     759M  1.2M  758M   1% /run
                  /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                  tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                  [sudo] password for iobroker:
                  [Sun Sep 22 13:11:43 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8E:3F:E4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7e9f8956-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Sun Sep 22 13:11:44 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Sun Sep 22 13:11:44 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Sun Sep 22 13:11:47 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  Show mounted filesystems:
                  TARGET                       SOURCE         FSTYPE          OPTIONS
                  /                            /dev/mmcblk0p2 ext4            rw,noatime
                  |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=1678472k,nr_inodes=419618,mode=755
                  | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
                  | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                  | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
                  |-/proc                      proc           proc            rw,relatime
                  | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                  |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                  | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                  | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
                  | `-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
                  |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
                  | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
                  | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
                  | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
                  |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                  `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.8G	/var/
                  940M	/var/log
                  937M	/var/log/journal/365fb86da8514c2a85a61e3d210b6795
                  609M	/var/cache
                  Archived and active journals take up 936.1M in the file system.
                  /opt/iobroker/backups:
                  22M	/opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  593M	/opt/iobroker/iobroker-data/
                  520M	/opt/iobroker/iobroker-data/files
                  441M	/opt/iobroker/iobroker-data/files/javascript.admin
                  409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                  408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  14M	/opt/iobroker/iobroker-data/objects.jsonl
                  14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                  8.8M	/opt/iobroker/iobroker-data/states.jsonl
                  8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs 	v20.17.0
                  /usr/bin/node 		v20.17.0
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  /usr/bin/corepack 	0.29.3
                  nodejs:
                    Installed: 20.17.0-1nodesource1
                    Candidate: 20.17.0-1nodesource1
                    Version table:
                   *** 20.17.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                          100 /var/lib/dpkg/status
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       12.22.12~dfsg-1~deb11u5 500
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller: 	6.0.11
                  admin: 		7.1.2
                  javascript: 	8.7.6
                  nodejs modules from github: 	0
                  Adapter State
                    system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                  + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                  + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                  + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                  + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: ::
                  + system.adapter.sonoff.1                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                  + system.adapter.sonoff.2                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                  + system.adapter.sonoff.3                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                    system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 7.1.2    , installed 7.1.2
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                  Adapter    "hue"          : 3.12.0   , installed 3.12.0
                  Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                  Controller "js-controller": 6.0.11   , installed 6.0.11
                  Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                  Adapter    "meross"       : 1.17.0   , installed 1.17.0
                  Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                  Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                  Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                  Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                  Adapter    "tado"         : 0.5.6    , installed 0.5.6
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Objects and States
                  Objects: 	6973
                  States: 	5294
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       16293      1847/io.sonoff.2
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       16270      1816/io.sonoff.1
                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       17209      1890/io.sonoff.3
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12991      575/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17699      543/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       15009      543/iobroker.js-con
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15459      542/cupsd
                  tcp6       0      0 :::1883                 :::*                    LISTEN      1000       16215      1756/io.sonoff.0
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1000       19753      1959/io.socketio.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       16344      1944/io.web.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          12993      575/sshd: /usr/sbin
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15458      542/cupsd
                  tcp6       0      0 :::51989                :::*                    LISTEN      1000       18665      1731/io.nuki-extend
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11223      382/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       18666      1763/io.shelly.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15475      458/dhcpcd
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       18626      1742/io.mihome-vacu
                  udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       18664      1770/io.mihome-vacu
                  udp        0      0 0.0.0.0:37206           0.0.0.0:*                           108        11225      382/avahi-daemon: r
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1858       599/cups-browsed
                  udp6       0      0 :::5353                 :::*                                108        11224      382/avahi-daemon: r
                  udp6       0      0 :::59394                :::*                                108        11226      382/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          1874       458/dhcpcd
                  2024-09-22 13:13:24.008  - info: host.iobroker instance system.adapter.socketio.0 in version "6.7.1" started with pid 1959
                  2024-09-22 13:13:24.176  - info: web.0 (1944) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
                  2024-09-22 13:13:24.709  - info: web.0 (1944) socket.io server listening on port 8082
                  2024-09-22 13:13:24.724  - info: web.0 (1944) http server listening on port 8082
                  2024-09-22 13:13:28.006  - info: host.iobroker instance system.adapter.tado.0 in version "0.5.6" started with pid 1986
                  2024-09-22 13:13:28.310  - info: socketio.0 (1959) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.11
                  2024-09-22 13:13:28.461  - info: socketio.0 (1959) socket.io server listening on port 8084
                  2024-09-22 13:13:30.609  - info: javascript.0 (1227) script.js.Hue_Push: missing update instructions for sensors.temperature.temperature_report
                  2024-09-22 13:13:30.610  - info: javascript.0 (1227) script.js.Hue_Push: {"owner":{"rid":"0045d363-a198-4f59-a8b4-8281aac23ba4","rtype":"device"},"temperature":{"temperature":23.84,"temperature_report":{"changed":"2024-09-22T11:13:30.518Z","temperature":23.84}}}
                  2024-09-22 13:13:32.547  - info: tado.0 (1986) starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.tado, node: v20.17.0, js-controller: 6.0.11
                  2024-09-22 13:13:32.583  - info: tado.0 (1986) Started with JSON-Explorer version 0.1.16
                  2024-09-22 13:13:33.300  - info: tado.0 (1986) Connected to Tado cloud, initialyzing...
                  2024-09-22 13:13:40.226  - info: tado.0 (1986) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
                  2024-09-22 13:13:44.435  - info: sonoff.1 (1816) Client [Bilderrahmen] connected with secret 1727003624426_6331
                  2024-09-22 13:13:44.476  - info: sonoff.0 (1756) Client [Stecker Küche] connected with secret 1727003624466_4294
                  2024-09-22 13:13:44.545  - info: sonoff.3 (1890) Client [Growzelt Venti] connected with secret 1727003624528_421
                  2024-09-22 13:13:45.027  - info: sonoff.2 (1847) Client [Growzelt Licht] connected with secret 1727003625018_9545
                  2024-09-22 13:14:03.236  - info: javascript.0 (1227) script.js.Hue_Push: missing update instructions for sensors.light.light_level_report
                  2024-09-22 13:14:03.237  - info: javascript.0 (1227) script.js.Hue_Push: {"light":{"light_level":18515,"light_level_report":{"changed":"2024-09-22T11:14:03.139Z","light_level":18515}},"owner":{"rid":"f2e4a67a-b010-4fc1-be1b-5fa10a0b6594","rtype":"device"}}
                  2024-09-22 13:14:06.049  - info: alexa2.0 (1690) Using cached smart home devices list from Sun Sep 22 2024 13:07:36 GMT+0200 (Mitteleuropäische Sommerzeit)
                  2024-09-22 13:14:21.131  - info: alexa2.0 (1690) No smart home devices to query
                  2024-09-22 13:14:22.587  - info: alexa2.0 (1690) Subscribing to states...
                  2024-09-22 13:14:22.598  - info: alexa2.0 (1690) Deleting the following states: ["Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#enabled","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#delete","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.powerState","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity-reason","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#query","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#includeInAllQuery","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#enabled","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#delete","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.powerState","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity-reason","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#query","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#includeInAllQuery","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#enabled","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#delete","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.powerState","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity-reason","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#query","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#includeInAllQuery","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#enabled","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#delete","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.powerState","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity-reason","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#query","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#includeInAllQuery","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#enabled","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#delete","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.powerState","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity-reason","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#query","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#includeInAllQuery","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#enabled","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#delete","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.powerState","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity-reason","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#query","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#includeInAllQuery","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#enabled","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#delete","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.powerState","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity-reason","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#query","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#includeInAllQuery","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#enabled","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#delete","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.powerState","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity-reason","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#query","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#includeInAllQuery","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#enabled","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#delete","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.powerState","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.brightness","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity-reason","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#query","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#includeInAllQuery","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#enabled","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#delete","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.powerState","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.brightness","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity-reason","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#query","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#includeInAllQuery","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#enabled","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#delete","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.powerState","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity-reason","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#query","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#includeInAllQuery","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#enabled","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#delete","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.powerState","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity-reason","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#query","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#includeInAllQuery","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#enabled","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#delete","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.powerState","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity-reason","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#query","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#includeInAllQuery","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#enabled","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#delete","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.powerState","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity-reason","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#query","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#includeInAllQuery","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#enabled","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#delete","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.powerState","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity-reason","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#query","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#includeInAllQuery"]
                  2024-09-22 13:14:24.390  - info: alexa2.0 (1690) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2024-09-22 13:14:36.945  - info: alexa2.0 (1690) Initialization Done ...
                    MACH DAS AUS!!!!!!!!!!!!!!!!!!!!!!!
                    Zum xten Mal:
                    sudo reboot
                    Dann mit deinem user anmelden, NICHT als iobroker.
                      @thomas-braun said in Kann IoBroker nicht mehr aufrufen:
                      hab ich aus geschaltet und gerobotet....
                      ich glaube ehrlich gesagt der Biobroker ist mein user
                        Fuxsism @Fuxsism last edited by
                        @fuxsism said in Kann IoBroker nicht mehr aufrufen:
                        hab ich aus geschaltet und gerebootet....
                        ich glaube ehrlich gesagt der iobroker ist mein user
                        hab mich zumindest IMMER so angemeldet
                          Dann ist es auch schon IMMER falsch. Der 'iobroker' wird eigentlich vom iobroker-Installer als Systemuser angelegt und der Standarduser in die Gruppe 'iobroker' gepackt. Dann funktioniert das auch alles wie vorgesehen.
                          Kannst du ja bei der bald fälligen Neuinstallation von 'Raspberry OS Bookworm' dann besser machen.
                            okay werde ich versuchen...
                            wie geht es denn nun weiter?
                              @fuxsism
                              Display-Server aus?
                              Dann
                              iob start admin
                                Fuxsism @Thomas Braun last edited by Fuxsism
                                ja display server aus
                                und nach start admin lädt es auch direkt wieder!!!!
                                kann jetzt auf jeden fall wieder per Firefox drauf zugreifen.....
                                Danke!!!!!
                                Soll ich denn jetzt noch etwas machen?
                                  Zeig mal abschließend die Zusammenfassung von
                                  iob diag
                                    			v.2024-05-22
                                             Icon name: computer
                                          Architecture: arm64
                                    Installation: 		native
                                    Kernel: 		aarch64
                                    Userland: 		64 bit
                                    Timezone: 		Europe/Berlin (CEST, +0200)
                                    User-ID: 		1000
                                    Display-Server: 	false
                                    Boot Target: 		multi-user.target
                                    Pending OS-Updates: 	0
                                    Pending iob updates: 	0
                                    Nodejs-Installation:
                                    /usr/bin/npm 		10.8.2
                                    /usr/bin/npx 		10.8.2
                                    Recommended versions are nodejs 20.17.0 and npm 10.8.2
                                    MEMORY:
                                    Mem:            3.8G        1.2G        1.9G        1.0M        617M        2.5G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        1.2G        2.0G
                                    Active iob-Instances: 	21
                                    ioBroker Core: 		js-controller 		6.0.11
                                    			admin 			7.1.2
                                    ioBroker Status: 	iobroker is running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    Objects: 		6979
                                    States: 		5309
                                    Size of iob-Database:
                                    18M	/opt/iobroker/iobroker-data/objects.jsonl
                                    4.7M	/opt/iobroker/iobroker-data/states.jsonl
                                      @fuxsism
                                      Jetzt passt es.
                                      In nächster Zeit eine NEUINSTALLATION von Raspberry OS Lite einplanen.
                                        okay... es scheint auch alles wieder gut und normal zu laufen!!!
                                        Vielen vielen Dank für die schnelle Hilfe!!!
                                        LG
                                        1391
