    4. Kann IoBroker nicht mehr aufrufen
      Thomas Braun Most Active @Fuxsism last edited by
      @fuxsism sagte in Kann IoBroker nicht mehr aufrufen:
      dann neu auf der Konsole anmelden?
      Ja, und dann einen frischen Lauf von
      iob diag
        Fuxsism last edited by Homoran
        nach erneuter Anmeldung per Terminal:
        iobroker@iobroker:~ $ Connection to iobroker closed by remote host.
        Connection to iobroker closed.
        fuxism@MBP-von-Michael ~ % ssh iobroker@iobroker
        iobroker@iobroker's password:
        Linux iobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Sun Sep 22 13:11:31 2024
        Wi-Fi is currently blocked by rfkill.
        Use raspi-config to set the country before use.
        -bash: source: /home/iobroker/.iobroker/iobroker_completions: Kann die Datei nicht ausführen.
          wenn ich Job Diagnose starte kommt das:
          The state system.host.iobroker.versions.nodeNewestNext was not found!
          The state system.host.iobroker.versions.npmNewestNext was not found!
          The state system.host.iobroker.versions.nodeCurrent was not found!
            @fuxsism
            Man meldet sich ja auch nicht als user 'iobroker' sondern mit seinem richtigen Login an.
              Lob Diagnose sagt nun:
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model		: Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               13:13:36 up 1 min,  3 users,  load average: 4.90, 1.95, 0.72
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Sun 2024-09-22 13:13:37 CEST
                         Universal time: Sun 2024-09-22 11:13:37 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
              iobroker
              HOME=/home/iobroker
              *** Display-Server-Setup ***
              Display-Server: true
              Desktop:
              Terminal: 	tty
              Boot Target: 	graphical.target
              *** MEMORY ***
              Mem:            3.8G        1.6G        1.5G         35M        732M        2.1G
              Swap:            99M          0B         99M
              Total:          3.9G        1.6G        1.6G
              Active iob-Instances: 	18
                       3794 M total memory
                       1566 M used memory
                       1753 M active memory
                        379 M inactive memory
                       1495 M free memory
                         45 M buffer memory
                        687 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              top - 13:13:37 up 1 min,  3 users,  load average: 4.90, 1.95, 0.72
              Tasks: 216 total,   4 running, 212 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 28.0 us,  9.3 sy,  0.0 ni, 61.3 id,  0.0 wa,  0.0 hi,  1.3 si,  0.0 st
              MiB Mem :   3794.3 total,   1494.7 free,   1566.6 used,    733.0 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2117.1 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       29G  7.8G   20G  28% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  1.2M  758M   1% /run
              /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
              tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
              [sudo] password for iobroker:
              [Sun Sep 22 13:11:43 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8E:3F:E4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7e9f8956-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Sun Sep 22 13:11:44 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sun Sep 22 13:11:44 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sun Sep 22 13:11:47 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              Show mounted filesystems:
              TARGET                       SOURCE         FSTYPE          OPTIONS
              /                            /dev/mmcblk0p2 ext4            rw,noatime
              |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=1678472k,nr_inodes=419618,mode=755
              | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
              | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
              | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
              |-/proc                      proc           proc            rw,relatime
              | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
              |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
              | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
              | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
              | `-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
              |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
              | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
              | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
              | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
              |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              1.8G	/var/
              940M	/var/log
              937M	/var/log/journal/365fb86da8514c2a85a61e3d210b6795
              609M	/var/cache
              Archived and active journals take up 936.1M in the file system.
              /opt/iobroker/backups:
              22M	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              593M	/opt/iobroker/iobroker-data/
              520M	/opt/iobroker/iobroker-data/files
              441M	/opt/iobroker/iobroker-data/files/javascript.admin
              409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
              408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
              24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              14M	/opt/iobroker/iobroker-data/objects.jsonl
              14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
              8.8M	/opt/iobroker/iobroker-data/states.jsonl
              8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v20.17.0
              /usr/bin/node 		v20.17.0
              /usr/bin/npm 		10.8.2
              /usr/bin/npx 		10.8.2
              /usr/bin/corepack 	0.29.3
              nodejs:
                Installed: 20.17.0-1nodesource1
                Candidate: 20.17.0-1nodesource1
                Version table:
               *** 20.17.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u5 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller: 	6.0.11
              admin: 		7.1.2
              javascript: 	8.7.6
              nodejs modules from github: 	0
              Adapter State
                system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
              + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
              + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: ::
              + system.adapter.sonoff.1                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
              + system.adapter.sonoff.2                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
              + system.adapter.sonoff.3                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.2    , installed 7.1.2
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.22   , installed 3.0.22
              Adapter    "hue"          : 3.12.0   , installed 3.12.0
              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
              Adapter    "meross"       : 1.17.0   , installed 1.17.0
              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "shelly"       : 7.0.0    , installed 7.0.0
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
              Adapter    "tado"         : 0.5.6    , installed 0.5.6
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Objects and States
              Objects: 	6973
              States: 	5294
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       16293      1847/io.sonoff.2
              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       16270      1816/io.sonoff.1
              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       17209      1890/io.sonoff.3
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12991      575/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17699      543/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       15009      543/iobroker.js-con
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15459      542/cupsd
              tcp6       0      0 :::1883                 :::*                    LISTEN      1000       16215      1756/io.sonoff.0
              tcp6       0      0 :::8084                 :::*                    LISTEN      1000       19753      1959/io.socketio.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       16344      1944/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          12993      575/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15458      542/cupsd
              tcp6       0      0 :::51989                :::*                    LISTEN      1000       18665      1731/io.nuki-extend
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11223      382/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       18666      1763/io.shelly.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15475      458/dhcpcd
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       18626      1742/io.mihome-vacu
              udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       18664      1770/io.mihome-vacu
              udp        0      0 0.0.0.0:37206           0.0.0.0:*                           108        11225      382/avahi-daemon: r
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1858       599/cups-browsed
              udp6       0      0 :::5353                 :::*                                108        11224      382/avahi-daemon: r
              udp6       0      0 :::59394                :::*                                108        11226      382/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          1874       458/dhcpcd
              2024-09-22 13:13:24.008  - info: host.iobroker instance system.adapter.socketio.0 in version "6.7.1" started with pid 1959
              2024-09-22 13:13:24.176  - info: web.0 (1944) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
              2024-09-22 13:13:24.709  - info: web.0 (1944) socket.io server listening on port 8082
              2024-09-22 13:13:24.724  - info: web.0 (1944) http server listening on port 8082
              2024-09-22 13:13:28.006  - info: host.iobroker instance system.adapter.tado.0 in version "0.5.6" started with pid 1986
              2024-09-22 13:13:28.310  - info: socketio.0 (1959) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.11
              2024-09-22 13:13:28.461  - info: socketio.0 (1959) socket.io server listening on port 8084
              2024-09-22 13:13:30.609  - info: javascript.0 (1227) script.js.Hue_Push: missing update instructions for sensors.temperature.temperature_report
              2024-09-22 13:13:30.610  - info: javascript.0 (1227) script.js.Hue_Push: {"owner":{"rid":"0045d363-a198-4f59-a8b4-8281aac23ba4","rtype":"device"},"temperature":{"temperature":23.84,"temperature_report":{"changed":"2024-09-22T11:13:30.518Z","temperature":23.84}}}
              2024-09-22 13:13:32.547  - info: tado.0 (1986) starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.tado, node: v20.17.0, js-controller: 6.0.11
              2024-09-22 13:13:32.583  - info: tado.0 (1986) Started with JSON-Explorer version 0.1.16
              2024-09-22 13:13:33.300  - info: tado.0 (1986) Connected to Tado cloud, initialyzing...
              2024-09-22 13:13:40.226  - info: tado.0 (1986) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
              2024-09-22 13:13:44.435  - info: sonoff.1 (1816) Client [Bilderrahmen] connected with secret 1727003624426_6331
              2024-09-22 13:13:44.476  - info: sonoff.0 (1756) Client [Stecker Küche] connected with secret 1727003624466_4294
              2024-09-22 13:13:44.545  - info: sonoff.3 (1890) Client [Growzelt Venti] connected with secret 1727003624528_421
              2024-09-22 13:13:45.027  - info: sonoff.2 (1847) Client [Growzelt Licht] connected with secret 1727003625018_9545
              2024-09-22 13:14:03.236  - info: javascript.0 (1227) script.js.Hue_Push: missing update instructions for sensors.light.light_level_report
              2024-09-22 13:14:03.237  - info: javascript.0 (1227) script.js.Hue_Push: {"light":{"light_level":18515,"light_level_report":{"changed":"2024-09-22T11:14:03.139Z","light_level":18515}},"owner":{"rid":"f2e4a67a-b010-4fc1-be1b-5fa10a0b6594","rtype":"device"}}
              2024-09-22 13:14:06.049  - info: alexa2.0 (1690) Using cached smart home devices list from Sun Sep 22 2024 13:07:36 GMT+0200 (Mitteleuropäische Sommerzeit)
              2024-09-22 13:14:21.131  - info: alexa2.0 (1690) No smart home devices to query
              2024-09-22 13:14:22.587  - info: alexa2.0 (1690) Subscribing to states...
              2024-09-22 13:14:22.598  - info: alexa2.0 (1690) Deleting the following states: ["Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#enabled","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#delete","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.powerState","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity-reason","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#query","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#includeInAllQuery","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#enabled","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#delete","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.powerState","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity-reason","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#query","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#includeInAllQuery","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#enabled","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#delete","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.powerState","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity-reason","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#query","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#includeInAllQuery","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#enabled","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#delete","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.powerState","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity-reason","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#query","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#includeInAllQuery","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#enabled","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#delete","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.powerState","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity-reason","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#query","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#includeInAllQuery","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#enabled","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#delete","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.powerState","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity-reason","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#query","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#includeInAllQuery","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#enabled","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#delete","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.powerState","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity-reason","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#query","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#includeInAllQuery","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#enabled","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#delete","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.powerState","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity-reason","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#query","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#includeInAllQuery","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#enabled","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#delete","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.powerState","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.brightness","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity-reason","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#query","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#includeInAllQuery","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#enabled","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#delete","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.powerState","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.brightness","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity-reason","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#query","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#includeInAllQuery","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#enabled","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#delete","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.powerState","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity-reason","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#query","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#includeInAllQuery","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#enabled","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#delete","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.powerState","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity-reason","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#query","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#includeInAllQuery","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#enabled","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#delete","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.powerState","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity-reason","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#query","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#includeInAllQuery","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#enabled","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#delete","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.powerState","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity-reason","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#query","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#includeInAllQuery","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#enabled","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#delete","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.powerState","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity-reason","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#query","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#includeInAllQuery"]
              2024-09-22 13:14:24.390  - info: alexa2.0 (1690) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2024-09-22 13:14:36.945  - info: alexa2.0 (1690) Initialization Done ...
                MACH DAS AUS!!!!!!!!!!!!!!!!!!!!!!!
                Zum xten Mal:
                sudo systemctl set-default multi-user.target
                sudo reboot
                Dann mit deinem user anmelden, NICHT als iobroker.
                  Fuxsism @Thomas Braun last edited by
                  @thomas-braun said in Kann IoBroker nicht mehr aufrufen:
                  hab ich aus geschaltet und gerobotet....
                  ich glaube ehrlich gesagt der Biobroker ist mein user
                    Fuxsism @Fuxsism last edited by
                    @fuxsism said in Kann IoBroker nicht mehr aufrufen:
                    hab ich aus geschaltet und gerebootet....
                    ich glaube ehrlich gesagt der iobroker ist mein user
                    hab mich zumindest IMMER so angemeldet
                      Dann ist es auch schon IMMER falsch. Der 'iobroker' wird eigentlich vom iobroker-Installer als Systemuser angelegt und der Standarduser in die Gruppe 'iobroker' gepackt. Dann funktioniert das auch alles wie vorgesehen.
                      Kannst du ja bei der bald fälligen Neuinstallation von 'Raspberry OS Bookworm' dann besser machen.
                        okay werde ich versuchen...
                        wie geht es denn nun weiter?
                          @fuxsism
                          Display-Server aus?
                          Dann
                          iob start admin
                            Fuxsism @Thomas Braun last edited by Fuxsism
                            ja display server aus
                            und nach start admin lädt es auch direkt wieder!!!!
                            kann jetzt auf jeden fall wieder per Firefox drauf zugreifen.....
                            Danke!!!!!
                            Soll ich denn jetzt noch etwas machen?
                              Zeig mal abschließend die Zusammenfassung von
                              iob diag
                                			v.2024-05-22
                                         Icon name: computer
                                      Architecture: arm64
                                Installation: 		native
                                Kernel: 		aarch64
                                Userland: 		64 bit
                                Timezone: 		Europe/Berlin (CEST, +0200)
                                User-ID: 		1000
                                Display-Server: 	false
                                Boot Target: 		multi-user.target
                                Pending OS-Updates: 	0
                                Pending iob updates: 	0
                                Nodejs-Installation:
                                /usr/bin/npm 		10.8.2
                                /usr/bin/npx 		10.8.2
                                Recommended versions are nodejs 20.17.0 and npm 10.8.2
                                MEMORY:
                                Mem:            3.8G        1.2G        1.9G        1.0M        617M        2.5G
                                Swap:            99M          0B         99M
                                Total:          3.9G        1.2G        2.0G
                                Active iob-Instances: 	21
                                ioBroker Core: 		js-controller 		6.0.11
                                			admin 			7.1.2
                                ioBroker Status: 	iobroker is running on this host.
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                Objects: 		6979
                                States: 		5309
                                Size of iob-Database:
                                18M	/opt/iobroker/iobroker-data/objects.jsonl
                                4.7M	/opt/iobroker/iobroker-data/states.jsonl
                                  @fuxsism
                                  Jetzt passt es.
                                  In nächster Zeit eine NEUINSTALLATION von Raspberry OS Lite einplanen.
                                    okay... es scheint auch alles wieder gut und normal zu laufen!!!
                                    Vielen vielen Dank für die schnelle Hilfe!!!
                                    LG
                                    1391
