    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Zigbee Paulmann Aussenleuchte Azalera bringt nur "?"
      arteck Developer Most Active @hanand last edited by
      @hanand bitte überarbeiten den Beitrag nochmal...
      da fehelen die Screenshots
      iob diag ist hier unwichtig...
      hast mal geschaut ob das Gerät auch auf zigbee2mqtt unterstützt wird.. ich vermute nein
        hanand @arteck last edited by
        @arteck
        Danke für die Hinweise... Habe noch nicht viel Anfragen hier Forum gestartet,, Habe meist alles irgendwie hinbekommen. Hier der Screenshot:Bildschirmfoto vom 2024-09-14 10-40-28.png
        Und dann nochmal die Ausgabe im Debugmodus des Adapters :
        Received Zigbee message from '0x00158d00086f88b1', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4632,"imageType":4364,"fileVersion":1}' from endpoint 1 with groupID 0
        zigbee.0
        	2024-09-14 10:43:32.410	debug	Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":19,"_dateCode":"20190515","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":268,"inputClusters":[0,4,3,6,8,5,768,4096],"outputClusters":[25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"zclVersion":3}}},"deviceIeeeAddress":"0x00158d00086f88b1","deviceNetworkAddress":45122,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d00086f88b1"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x00158d00086f88b1","deviceNetworkAddress":45122,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x00158d00086f88b1"}}],"_hardwareVersion":16,"_ieeeAddr":"0x00158d00086f88b1","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1726303412408,"_manufacturerID":4632,"_manufacturerName":"Paulmann Licht GmbH","_modelID":"CCT-I","_networkAddress":45122,"_powerSource":"DC Source","_softwareBuildID":"1400-0001","_stackVersion":1,"_type":"Router","_zclVersion":3,"_linkquality":36,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"mapped":null,"name":"0x00158d00086f88b1"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":19,"_dateCode":"20190515","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":268,"inputClusters":[0,4,3,6,8,5,768,4096],"outputClusters":[25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"zclVersion":3}}},"deviceIeeeAddress":"0x00158d00086f88b1","deviceNetworkAddress":45122,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d00086f88b1"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x00158d00086f88b1","deviceNetworkAddress":45122,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x00158d00086f88b1"}}],"_hardwareVersion":16,"_ieeeAddr":"0x00158d00086f88b1","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1726303412408,"_manufacturerID":4632,"_manufacturerName":"Paulmann Licht GmbH","_modelID":"CCT-I","_networkAddress":45122,"_powerSource":"DC Source","_softwareBuildID":"1400-0001","_stackVersion":1,"_type":"Router","_zclVersion":3,"_linkquality":36,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4632,"imageType":4364,"fileVersion":1},"linkquality":36,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":38,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
        Ich hoffe das reicht erst mal..
        Und schon mal vielen Dank
          @arteck
          hier das Produkt, wenn das von Interesse ist?
          https://de.paulmann.com/p/led-aussenwandleuchte-smart-home-zigbee-3.0-azalena-bewegungsmelder-mit-hochfrequenz-sensor-insektenfreundlich-ip44-250x97mm-tunable-warm-8-5w-700lm-230v-anthrazit-kunststoff-aluminium/94842
          mit zigbee2mqtt habe mich mich bislang noch nicht beschäftigt... werde mal schaue habe aber diesbezüglich nichts gelesen
          Vielen Dank (tolle Sache was hier läuft!!!!!)
          V H 2 Replies Last reply Reply Quote 0
          • V
            Verblizz @hanand last edited by
            @hanand
            Wird offiziell nicht unterstützt, steht nicht in der Liste...
            Zigbee2MQTT-supportet Devices
              hanand @Verblizz last edited by
              @verblizz
              Habe mich trotzdem mal mit zigbee2mqtt befasst und das Gerät gekoppelt: Mit dem gleichen Ergebnis wie mit dem Zigbee AdapterBildschirmfoto vom 2024-09-14 16-44-25.png
              Gib es da gar keine Chance, dass das Gerät mal verwendbar ist?
              Vielen Dank schon mal!!
                hanand @hanand last edited by
                @hanand
                Habe mich mal intensiver mit dem Webinterface von zigbee2mqtt befasst ,,, und siehe da bei "Details" ist die Leuchte bedienbar. Jetzt muss ich nur mal sehen, wie ich das Ganze in meine aktive Umgebung bauen kann.
                Vielleicht gib es ja doch noch eine Idee aus dem Forum, wie sich das Ganze ggf. in den Standard integrieren lässt.
                Vielen Dank und bis bald
                • V
                  @hanand
                  Auf deinem Bild steht doch im Adapter, dass die Leuchte nicht unterstützt wird. Dahinter ist sogar ein Link, der es Dir weiterhelfen sollte, denke ich zumindest.
                  Ich muss gestehen, dass ich, bevor ich Zigbee-Devices kaufe, nachsehe, ob diese überhaupt unterstützt werden...Deshalb habe ich noch nie um solche Unterstützung beim Developer bitten müssen...🤷‍♂️
                    na das ist mal wieder ein dolles Ding.. Leuchte mit intergrierten BWM
                    zeigmal die Cluster bitte
                    H 2 Replies Last reply Reply Quote 1
                      @arteck
                      Sorry, war paar Tage unterwegs im Kommkunikationsnirwana 🙂 deshalb Antwort erst jetzt.
                      Zunächst noch eine kurze Erklärung meiner Unbedarftheit bezüglich Zigbee: Ich hatte dienstlich (jetzt Rentner) über 30 Jahre mit industriellen Kommuniktionsprotokollen zu tun und hatte bei den nicht proprietären, (also genormte Modbus, OPC UA, IEC 60870 usw.) es immer irgendwie geschafft Geräte in die Prozessautoamtion zu integrieren.
                      Mit der Homeautomation habe ich vor über 10 Jahren erst mit FHEM, später mit IObroker alles was das Haus an Schnittstellen zu bieten hat, zum laufen gebracht. Mir war es einfach nicht klar, dass so ein "Lämpchen" Probleme machen könnte. Ich hoffe ihr seht mir das nach?
                      Jetzt der gewünschte Screenshot, in der Hoffnung, dass der weiter hilft Bildschirmfoto vom 2024-09-20 14-00-56.png
                      Ich habe auch schon versucht mit Paulmann (immerhin deutsche Fa.) Kontakt aufzunehmen. Leider bislang ohne Erfolg. Welche Zigbee spezifische Frage könnte ich denen stellen?
                      Egal was rauskommt. Schon mal vielen Dank
                        @arteck Ich möchte hier nochmal den "letzten Stand der Ermittlungen" bekanntgeben:
                        1. Habe ich von Paulmann eine Antwort bezüglich meiner Anfrage erhalten. Diese läuft darauf hinaus, dass es keine Datenpunkte (Einstellungsmöglichkeiten) mehr gibt, als über zigbee2mqtt dargestellt werden.
                        2. Habe ich den zigbee2mqtt Adapter in meiner Testumgebung installiert und alle Datenpunkte, welche auch das Webinterface von Zigbee2mqtt darstellt gefunden.. alles scheint da auch mit direkten Zugriff auf die Leuchte zu funktionierenBildschirmfoto vom 2024-09-20 16-56-11.png Bildschirmfoto vom 2024-09-23 10-56-31.png
                        3. Danach habe ich eine Fernbedienung von Paulmann angelernt mit dem zigbee2mqtt Ergebnis:Bildschirmfoto vom 2024-09-23 10-58-09.png Bildschirmfoto vom 2024-09-23 10-58-29.png
                          Auch hier werden eine Masse DAtenpunkte (Objekte) im IOBrokerAdapter angelegt, welche auch funktionieren:Bildschirmfoto vom 2024-09-23 11-00-40.png
                        Also aus jetziger Sicht kann ich sagen, dass wahrscheinlich (werde alles versuchen noch in meine aktive Umgebung mit besserem Coordinator zu integrieren) so funktioniert wie ich mir das vorgestellt habe, trotz fehlender direkter Unterstützung durch zigbee2mqtt.
                        Abschließend möchte ich nochmal kundtun, dass ich absolut begeistert bin von den Möglichkeiten welche iobroker bietet. Dem Forum danke für die Tips. Diese habe auf alle Fälle wieder gereicht um das zu erreichen was ich wollte.
                        1.2k
                        zigbee paulmann fragezeichen
                        627
