    4. Error in GUI!
    Error in GUI!
      thorkillar last edited by thorkillar
      Guten Abend liebe Gemeinschaft,
      ich habe seit dem letzten Update ein paar Probleme, wo ich nicht genau weis, wie ich sie beheben soll.
      Ich bekomme seit dem 20.09. folgende Fehlermeldung im Admin:
      If in the second line you will see at :3000/static/js/main.chunk.js:36903 and not the normal file name,
      please try to reproduce an error with opened browser console. In this case the special "map" files will be loaded and the developers can see the real name of functions and files.
      Minified React error #31; visit https://reactjs.org/docs/error-decoder.html?invariant=31&args[]=%5Bobject%20Error%5D for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
      Error: Minified React error #31; visit https://reactjs.org/docs/error-decoder.html?invariant=31&args[]=%5Bobject%20Error%5D for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
          at va (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:49950)
          at e (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:54963)
          at ko (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:73156)
          at xi (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:122082)
          at bs (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:109361)
          at vs (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:109289)
          at gs (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:109152)
          at as (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:105932)
          at ls (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:104483)
          at S (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:131248)
          at MessagePort.T (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:131782)
      Leider weiß ich jetzt nicht, was ich machen kann. Der Admin schmiert mir immer innerhalb von ein paar Sekunden ab.
      Das Problem tritt erst auf, seit dem ich ein paar Updates durchgeführt habe und Node-Red installiert hatte.
      Updates:
      backitup 3.0.19 →3.0.22
      daswetter 3.1.15 →3.1.16
      discovery 4.5.0 →5.0.0
      pushover 3.0.6 →4.1.0
      admin 7.0.23 => 7.1.2
      Successfully upgraded admin to version 7.1.2
      $ iobroker add node-red --host iobroker
      NPM version: 10.8.1
      Installing iobroker.node-red@5.2.1... (System call)
      In der Console wird zeitgleich folgender Fehler ausgeworfen:
      Invalid group id "g00005" in widget "w00403"
      Invalid group id "g00005" in widget "w00404"
      Invalid group id "g00005" in widget "w00405"
      Invalid group id "g00005" in widget "w00406"
      Invalid group id "g00005" in widget "w00425"
      Invalid group id "g00005" in widget "w00393"
      Invalid group id "g00005" in widget "w00394"
      Invalid group id "g00005" in widget "w00395"
      Invalid group id "g00005" in widget "w00396"
      Invalid group id "g00005" in widget "w00397"
      Invalid group id "undefined" in widget "w01131"
      Invalid group id "undefined" in widget "w01133"
      Invalid group id "undefined" in widget "w01134"
      Invalid group id "undefined" in widget "w01220"
      Invalid group id "undefined" in widget "w01221"
      Invalid group id "undefined" in widget "w01222"
      Könnt Ihr mir sagen, was ich tun kann?
      • Codierknecht
        Codierknecht Developer Most Active @thorkillar last edited by Codierknecht
        @thorkillar sagte in Error in GUI!:
        Du könntest mal die Langfassung von
        iob diag
        zeigen.
          thorkillar @Codierknecht last edited by thorkillar
          @codierknecht
          Sorry, so langsam sollte ich das ja wissen 🙂
          Skript v.2024-05-22
          *** BASE SYSTEM ***
          Hardware Vendor : Synology Inc.
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v9.1.2
          Virtualization  : Docker
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           18:07:44 up 165 days,  9:44,  0 user,  load average: 4.85, 4.67, 5.37
          CPU threads: 4
          *** Time and Time Zones ***
          Mon Sep 23 16:07:44 UTC 2024
          Mon Sep 23 18:07:44 CEST 2024
          CEST +0200
          Etc/UTC
          *** Users and Groups ***
          User that called 'iob diag':
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:             16G        9.6G        2.3G        382M        5.6G        7.1G
          Swap:            12G        5.5G        6.7G
          Total:           28G         15G        9.0G
          Active iob-Instances:   39
                  15966 M total memory
                   9159 M used memory
                   4779 M active memory
                   5447 M inactive memory
                   2200 M free memory
                     20 M buffer memory
                   5277 M swap cache
                  11627 M total swap
                   5236 M used swap
                   6391 M free swap
          top - 18:07:45 up 165 days,  9:44,  0 user,  load average: 4.78, 4.66, 5.36
          Tasks:  47 total,   5 running,  42 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 66.7 us, 33.3 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  15966.7 total,   2198.9 free,   9161.8 used,   5298.1 buff/cache
          MiB Swap:  11627.9 total,   6391.7 free,   5236.2 used.   6804.9 avail Mem
          *** FILESYSTEM ***
          Filesystem             Type   Size  Used Avail Use% Mounted on
          /dev/mapper/cachedev_0 btrfs   34T   27T  6.8T  80% /
          tmpfs                  tmpfs   64M     0   64M   0% /dev
          tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
          shm                    tmpfs   64M     0   64M   0% /dev/shm
          /dev/mapper/cachedev_0 btrfs   34T   27T  6.8T  80% /opt/iobroker
          /dev/mapper/cachedev_0 btrfs   34T   27T  6.8T  80% /etc/hosts
          tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/acpi
          tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/scsi
          tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/firmware
          Show mounted filesystems:
          TARGET                           SOURCE        FSTYPE OPTIONS
          /                                /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/4a23f0115e1c1f32770ab54ec1422dff1390d4fbbd0f37c1c194a4cfc44caa54]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=57211,subvol=/@syno/@docker/btrfs/subvolumes/4a23f0115e1c1f32770ab54ec1422dff1390d4fbbd0f37c1c194a4cfc44caa54
          |-/proc                          proc        proc   rw,nosuid,nodev,noexec,relatime
          | |-/proc/bus                    proc[/bus]        proc   ro,relatime
          | |-/proc/fs                     proc[/fs]        proc   ro,relatime
          | |-/proc/irq                    proc[/irq]        proc   ro,relatime
          | |-/proc/sys                    proc[/sys]        proc   ro,relatime
          | |-/proc/sysrq-trigger          proc[/sysrq-trigger]        proc   ro,relatime
          | |-/proc/acpi                   tmpfs        tmpfs  ro,relatime
          | |-/proc/kcore                  tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
          | |-/proc/keys                   tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
          | |-/proc/timer_list             tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
          | |-/proc/sched_debug            tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
          | `-/proc/scsi                   tmpfs        tmpfs  ro,relatime
          |-/dev                           tmpfs        tmpfs  rw,nosuid,size=65536k,mode=755
          | |-/dev/pts                     devpts        devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
          | |-/dev/mqueue                  mqueue        mqueue rw,nosuid,nodev,noexec,relatime
          | `-/dev/shm                     shm        tmpfs  rw,nosuid,nodev,noexec,relatime,size=65536k
          |-/sys                           sysfs        sysfs  ro,nosuid,nodev,noexec,relatime
          | |-/sys/firmware                tmpfs        tmpfs  ro,relatime
          | `-/sys/fs/cgroup               tmpfs        tmpfs  rw,nosuid,nodev,noexec,relatime,mode=755
          |   |-/sys/fs/cgroup/systemd     cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd
          |   |-/sys/fs/cgroup/synomonitor cgroup[/system.slice/pkg-Docker-dockerd.service]        cgroup ro,nosuid,nodev,noexec,relatime,name=synomonitor
          |   |-/sys/fs/cgroup/blkio       cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,blkio
          |   |-/sys/fs/cgroup/memory      cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,memory
          |   |-/sys/fs/cgroup/devices     cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,devices
          |   |-/sys/fs/cgroup/cpuacct     cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,cpuacct
          |   |-/sys/fs/cgroup/cpuset      cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,cpuset
          |   |-/sys/fs/cgroup/cpu         cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,cpu
          |   `-/sys/fs/cgroup/freezer     cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,freezer
          |-/opt/iobroker                  /dev/mapper/cachedev_0[/@syno/docker/iob24/prod]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=1750,subvol=/@syno/docker/iob24/prod
          |-/etc/resolv.conf               /dev/mapper/cachedev_0[/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/resolv.conf
          |-/etc/hostname                  /dev/mapper/cachedev_0[/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/hostname
          `-/etc/hosts                     /dev/mapper/cachedev_0[/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/hosts
          /var:
          34M     /var/
          32M     /var/lib
          19M     /var/lib/apt/lists
          19M     /var/lib/apt
          13M     /var/lib/dpkg
          /opt/iobroker/backups:
          2.9G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          2.5G    /opt/iobroker/iobroker-data/
          1.1G    /opt/iobroker/iobroker-data/files
          765M    /opt/iobroker/iobroker-data/history
          441M    /opt/iobroker/iobroker-data/files/javascript.admin
          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          123M    /opt/iobroker/iobroker-data/objects.jsonl
          116M    /opt/iobroker/iobroker-data/states.jsonl
          65M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-09-20-scripts.zip
          45M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-06-25-scripts.zip
          43M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-04-29-scripts.zip
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.3
          /usr/bin/node           v18.20.3
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          /usr/bin/corepack       0.28.0
          nodejs:
            Installed: 18.20.3-1nodesource1
            Candidate: 18.20.4-1nodesource1
            Version table:
               18.20.4-1nodesource1 1001
                 1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           *** 18.20.3-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.20.2-1nodesource1 1001
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.11
          admin:          7.1.2
          javascript:     8.7.6
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
          + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
            system.adapter.emby.0                   : emby                  : iobroker                                 - disabled
            system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
          + system.adapter.fb-checkpresence.1       : fb-checkpresence      : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.2       : fb-checkpresence      : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.3       : fb-checkpresence      : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.4       : fb-checkpresence      : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
          + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
          + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 80
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
            system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
            system.adapter.meteoalarm.0             : meteoalarm            : iobroker                                 -  enabled
          + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
          + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
            system.adapter.odl.0                    : odl                   : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled
            system.adapter.tibberlink.1             : tibberlink            : iobroker                                 - disabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.webuntis.0               : webuntis              : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          │ (index) │   name   │                           url                           │ auto upgrade │
          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.2    , installed 7.1.2
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.22   , installed 3.0.22
          Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
          Adapter    "bring"        : 1.8.4    , installed 1.8.4
          Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
          Adapter    "emby"         : 1.2.0    , installed 1.2.0
          Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
          Adapter    "fullcalendar" : 2.4.2    , installed 2.4.2
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
          Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
          Adapter    "hue"          : 3.12.0   , installed 3.12.0
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.11   , installed 6.0.11
          Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
          Adapter    "logparser"    : 2.2.2    , installed 2.2.2
          Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
          Adapter    "nina"         : 0.0.25   , installed 0.0.25
          Adapter    "nuki"         : 2.0.0    , installed 2.0.0
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "odl"          : 3.0.1    , installed 3.0.1
          Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "telegram-menu": 2.0.0    , installed 2.0.0
          Adapter    "tibberlink"   : 3.4.8    , installed 3.4.8
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        60827
          States:         51137
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 33
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3815200672 -
          tcp        0      0 192.168.0.34:12010      0.0.0.0:*               LISTEN      1001       3815218166 -
          tcp        0      0 192.168.0.34:9292       0.0.0.0:*               LISTEN      1001       3815229505 -
          tcp        0      0 192.168.0.34:18701      0.0.0.0:*               LISTEN      1001       3835159089 -
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3880989456 -
          tcp        0      0 192.168.0.34:12001      0.0.0.0:*               LISTEN      1001       3815216805 -
          tcp        0      0 127.0.0.11:37379        0.0.0.0:*               LISTEN      0          3815190854 -
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3815207997 -
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3815213131 -
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3815240144 -
          tcp6       0      0 :::3000                 :::*                    LISTEN      1001       3815318907 -
          udp        0      0 127.0.0.11:41346        0.0.0.0:*                           0          3815190853 -
          2024-09-23 18:07:52.401  - warn: javascript.0 (251)     at Fenster_und_T_C3_BCren (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:306:3648)
          2024-09-23 18:07:52.401  - warn: javascript.0 (251)     at processTicksAndRejections (node:internal/process/task_queues:95:5)
          2024-09-23 18:07:52.401  - warn: javascript.0 (251)     at New_Start_Zeile1 (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:29:8789)
          2024-09-23 18:07:52.401  - warn: javascript.0 (251)     at Object.<anonymous> (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:514:3)
          2024-09-23 18:08:00.024  - warn: javascript.0 (251) script.js.Prozesse.BVG-Live: request blockly block is deprecated - please use "http (GET)" instead
          2024-09-23 18:08:00.098  - warn: javascript.0 (251) script.js.Prozesse.BVG-Live-new: request blockly block is deprecated - please use "http (GET)" instead
          2024-09-23 18:08:10.023  - info: javascript.0 (251) script.js.Prozesse.Display.Tablet.Kalender.Kalender-Auslesen-Live: 📅TerminENDE: Training / 0 Stunden und 37 Min. / https://www.spielerplus.de/training/view?id=54362896
          2024-09-23 18:08:43.940  - warn: javascript.0 (251) script.js.Prozesse.Skriptübergreifende_Programme.Servicemeldungen_auslesen_und_weiter_verarbeiten: Servicemeldungen: 4
          2024-09-23 18:08:43.940  - warn: javascript.0 (251) script.js.Prozesse.Skriptübergreifende_Programme.Servicemeldungen_auslesen_und_weiter_verarbeiten: Korrigierte Servicemeldungen: 4
          2024-09-23 18:08:43.944  - warn: javascript.0 (251) getState "nuki-extended.0.smartlocks.zuhause.state.batteryChargeState" not found (3)
          2024-09-23 18:08:43.945  - warn: javascript.0 (251)     at Fenster_und_T_C3_BCren (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:306:3648)
          2024-09-23 18:08:43.945  - warn: javascript.0 (251)     at processTicksAndRejections (node:internal/process/task_queues:95:5)
          2024-09-23 18:08:43.945  - warn: javascript.0 (251)     at New_Start_Zeile1 (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:29:8789)
          2024-09-23 18:08:43.946  - warn: javascript.0 (251)     at START_1_2_3_new (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:21:3)
          2024-09-23 18:08:43.946  - warn: javascript.0 (251)     at Object.<anonymous> (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:408:3)
          2024-09-23 18:08:43.968  - warn: javascript.0 (251) getState "nuki-extended.0.smartlocks.zuhause.state.batteryChargeState" not found (3)
          2024-09-23 18:08:43.969  - warn: javascript.0 (251)     at Fenster_und_T_C3_BCren (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:306:3648)
          2024-09-23 18:08:43.969  - warn: javascript.0 (251)     at New_Start_Zeile1 (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:29:8789)
          2024-09-23 18:08:43.969  - warn: javascript.0 (251)     at START_1_2_3_new (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:21:3)
          2024-09-23 18:08:43.969  - warn: javascript.0 (251)     at Object.<anonymous> (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:408:3)
          2024-09-23 18:08:43.971  - warn: javascript.0 (251) getState "nuki-extended.0.smartlocks.zuhause.state.batteryChargeState" not found (3)
          2024-09-23 18:08:43.972  - warn: javascript.0 (251)     at Fenster_und_T_C3_BCren (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:306:3648)
          2024-09-23 18:08:43.972  - warn: javascript.0 (251)     at New_Start_Zeile1 (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:29:8789)
          2024-09-23 18:08:43.972  - warn: javascript.0 (251)     at START_1_2_3_new (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:21:3)
          2024-09-23 18:08:43.972  - warn: javascript.0 (251)     at Object.<anonymous> (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:429:3)
                                  v.2024-05-22
          model name      : Intel(R) Atom(TM) CPU C3538 @ 2.10GHz
          Kernel          : x86_64
          Userland        : amd64
          Docker          : v9.1.2
          Installation:           Docker
          Kernel:                 x86_64
          Userland:               64 bit
          Timezone:               CEST +0200
          User-ID:                0
          Pending OS-Updates:     33
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          Recommended versions are nodejs 20.17.0 and npm 10.8.2
          MEMORY:
          Mem:             16G         10G        1.6G        383M        5.6G        6.6G
          Swap:            12G        5.5G        6.7G
          Total:           28G         15G        8.4G
          ioBroker Core:          js-controller           6.0.11
                                  admin                   7.1.2
          Objects type: jsonl
          States  type: jsonl
          Objects:                60827
          States:                 51137
          Size of iob-Database:
          120M    /opt/iobroker/iobroker-data/states.jsonl
            crunchip Forum Testing Most Active @thorkillar last edited by crunchip
            Solltest mal deine Blockly's überarbeiten
            Docker : v9.1.2
            Gibt's mittlerweile v10 incl. Nodejs v20
            Eventuell mal zurück auf 7.1.1 gehen oder aus dem Latest die v7. 1.3 fischen
            Edit:
            Ggf hilft auch ein iob upload all
            S T Yoda 3 Replies Last reply Reply Quote 0
              stenmic @crunchip last edited by
              ich hatte diese Fehlermeldung gestern auch einmal.
              Bei mir sollte eigentlich alles auf neustem Stand sein.
                thorkillar @crunchip last edited by
                @crunchip Danke Dir.
                Die Blocklys überarbeite ich. (leider fehlt die Zeit)
                Docker werde ich am WE auf V10 updaten.
                iob upload all => hat bei mir leider nicht geholfen.
                Zum Glück tritt der Fehler nur sporadisch auf.
                eventuell mal zurück auf 7.1.1 => Habe ich durchgeführt.
                Melde mich, ob der Fehler wieder auftritt.
                DANKE
                • Yoda
                  Yoda @crunchip last edited by
                  @crunchip ich habe das Problem mit der GUI ebenfalls - sporadisch.
                  Rasspi update habe ich grade zuvor gemacht, Problem besteht aber immer noch
                  Liegt es an der Admin Version des Adapters?
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.6.47+rpt-rpi-v8
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.2
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                   09:34:03 up 8 min,  2 users,  load average: 1.44, 2.44, 1.42
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                                 Local time: Wed 2024-09-25 09:34:04 CEST
                             Universal time: Wed 2024-09-25 07:34:04 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            4.0G        2.2G        1.3G        1.2M        581M        1.8G
                  Swap:           209M          0B        209M
                  Total:          4.2G        2.2G        1.5G
                  Active iob-Instances:   30
                           3791 M total memory
                           2078 M used memory
                           2111 M active memory
                            320 M inactive memory
                           1234 M free memory
                             56 M buffer memory
                            498 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  top - 09:34:04 up 8 min,  2 users,  load average: 1.44, 2.44, 1.42
                  Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 57.1 id,  0.0 wa,  0.0 hi, 14.3 si,  0.0 st
                  MiB Mem :   3792.0 total,   1232.5 free,   2079.3 used,    554.6 buff/cache
                  MiB Swap:    200.0 total,    200.0 free,      0.0 used.   1712.7 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     380M  1.2M  379M   1% /run
                  /dev/mmcblk0p2 ext4       59G   11G   45G  19% /
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                  /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [Wed Sep 25 09:25:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.ena                                        ble_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B2:75:50 vc_mem.mem_base=0x3ec00                                        000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a6320af0-02 rootfstype=ext4 fsck.repair=yes root                                        wait cfg80211.ieee80211_regdom=DE
                  [Wed Sep 25 09:25:30 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mod                                        e. Quota mode: none.
                  [Wed Sep 25 09:25:31 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                  /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                  |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,me                                        mory_recursiveprot
                  | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                  | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                  | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
                  |-/proc                                                 proc           proc        rw,relatime
                  | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5                                        ,maxproto=5,direct,pipe_ino=644
                  |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                  |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671168k,nr_inodes=41                                        7792,mode=755
                  | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmx                                        mode=000
                  | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
                  | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
                  |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388300k,                                        mode=755
                  | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                  | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
                  | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388296k,nr_inod                                        es=97074,mode=700,uid=1000,gid=1000
                  `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=43                                        7,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  934M    /var/
                  355M    /var/log/journal/9cad1102edaf418c8a35375ebd8c4778
                  355M    /var/log
                  209M    /var/cache
                  Archived and active journals take up 354.0M in the file system.
                  383M    /opt/iobroker/backups/
                  1.3G    /opt/iobroker/iobroker-data/
                  408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  65M     /opt/iobroker/iobroker-data/objects.jsonl
                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2153973-if00
                  /usr/bin/nodejs         v20.17.0
                  /usr/bin/node           v20.17.0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.3
                  nodejs:
                    Installed: 20.17.0-1nodesource1
                    Candidate: 20.17.0-1nodesource1
                    Version table:
                   *** 20.17.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          7.1.2
                  javascript:     8.7.6
                  nodejs modules from github:     1
                  +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#9c4635239c7                                        b9321601dcf0fcdd8677a55a8b13f)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8                                        081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                  + system.adapter.cloud.3                  : cloud                 : raspberrypi                              -  enabled
                    system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                  + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                  + system.adapter.email.1                  : email                 : raspberrypi                              -  enabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                    system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                  + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                  + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                  + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 4                                        43
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                    system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
                    system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1                                        886, bind: 0.0.0.0
                  + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 8                                        0, 7575, 8000, 8080, 8081, 8899
                  + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
                  + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1                                        882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8                                        087, bind: 0.0.0.0, run as: admin
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                  + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8                                        443, bind: 0.0.0.0
                  + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                    system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              - disabled
                    system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              - disabled
                  + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                    system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                    system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                    system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                    system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                    system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                    system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8                                        082, bind: 0.0.0.0, run as: admin
                  + system.adapter.zendure-solarflow.0      : zendure-solarflow     : raspberrypi                              -  enabled
                  + instance is alive
                  Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                  Adapter    "email"        : 1.3.1    , installed 1.3.1
                  Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                  Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                  Adapter    "hmip"         : 1.23.3   , installed 1.23.3
                  Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                  Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                  Adapter    "scenes"       : 3.2.1    , installed 3.2.1
                  Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                  Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                  Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                  Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
                  Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                  Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                  Adapter    "zendure-solarflow": 1.8.5, installed 1.8.5
                  Objects and States
                  Objects:        42738
                  States:         40264
                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       8406       992/io.mqtt.0
                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       8405       992/io.mqtt.0
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7764       999/io.shelly.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7311       674/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5503       674/iobroker.js-con
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7264       681/sshd: /usr/sbin
                  tcp6       0      0 :::8095                 :::*                    LISTEN      1001       6121       1119/io.onvif.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       8553       1149/io.simple-api.
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3039       808/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7788       1224/io.web.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          7266       681/sshd: /usr/sbin
                  udp        0      0 192.168.178.119:5353    0.0.0.0:*                           1001       6626       1010/io.tr-064.0
                  udp        0      0 192.168.178.118:5353    0.0.0.0:*                           1001       6625       1010/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6170       537/avahi-daemon: r
                  udp        0      0 0.0.0.0:56598           0.0.0.0:*                           1001       14582      922/io.broadlink2.0
                  udp        0      0 0.0.0.0:55300           0.0.0.0:*                           1001       7524       922/io.broadlink2.0
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5969       1017/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5970       1017/io.tuya.0
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       7521       922/io.broadlink2.0
                  udp        0      0 0.0.0.0:47873           0.0.0.0:*                           104        6172       537/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                104        6171       537/avahi-daemon: r
                  udp6       0      0 :::45355                :::*                                104        6173       537/avahi-daemon: r
                  udp6       0      0 fe80::a516:5605:ab6:546 :::*                                0          6320       616/NetworkManager
                  udp6       0      0 fe80::359:efc:16c4::546 :::*                                0          7299       616/NetworkManager
                    crunchip Forum Testing Most Active @Yoda last edited by
                    @yoda sagte in Error in GUI!:
                    Möglicherweise
                    M Yoda 2 Replies Last reply Reply Quote 0
                      MartyBr @crunchip last edited by
                      @crunchip Ich habe das Problem mit einem Update auf die 7.1.3 behoben.
                      Der Rest ist Stabile.
                        MartyBr @MartyBr last edited by
                        @martybr
                        Noch eine Erklärung zum vorlaufenden Post:
                        Das Problem betraf Safari auf meinem Mac. Mit Google Chrome auf dem Mac hatte ich das Problem nicht. Das Update vom Admin auf die 7.1.3 behob das Problem mit Safari.
                        • Yoda
                          @crunchip ich habe grade das update der Admin Version auf 7.1.5 durchgeführt, mal schauen ....
                          habe nun die Seite einige male neu geladen, bisher keinen Fehler.
                            MartyBr @Yoda last edited by
                            @yoda
                            Die 7.1.5 läuft bei mir auch in Safari und Chrome auf dem Mac. Keine Login-Probleme .
                              thorkillar @thorkillar last edited by
                              @crunchip
                              Hi, jetzt funktioniert es.
                              Update des Admin Adapters hat geholfen.
                              835
