    3. Einsteigerfragen
    4. NUC-Proxmox-steigender Ram
      peterfido @marko67 last edited by
      @marko67 nach über fünf Stunden ist alles so, wie es sein soll.
      Wenn das Problem bei Dir bei einer frischen "nackten" Installation auftritt, muss irgendwas bei Deinem System anders sein.
        marko67 last edited by marko67
        @martinp
        iob stop ausgeführt. Ist mit 157 MB neu gestartet und nun wieder bei fast 1,5 GB steigend
        Anbei nochmals iob diag
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: ioB24
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.8.12-2-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         21:13:08 up  4:34,  2 users,  load average: 0.19, 0.27, 0.25
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Wed 2024-09-25 21:13:08 CEST
                   Universal time: Wed 2024-09-25 19:13:08 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        dirk
        HOME=/home/dirk
        GROUPS=dirk sudo users iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            7.4G        1.6G        5.4G        114K        373M        5.8G
        Swap:           536M          0B        536M
        Total:          7.9G        1.6G        5.9G
        Active iob-Instances:   3
                 7048 M total memory
                 1541 M used memory
                 1617 M active memory
                  238 M inactive memory
                 5149 M free memory
                    0 M buffer memory
                  356 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        top - 21:13:08 up  4:34,  2 users,  load average: 0.19, 0.27, 0.25
        Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7048.0 total,   5148.3 free,   1543.3 used,    356.6 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5504.7 avail Mem
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--110--disk--0 ext4      9.8G  2.2G  7.2G  24% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
        tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
        tmpfs                            tmpfs     3.2G  108K  3.2G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems:
        TARGET                                                  SOURCE                           FSTYPE     OPTIONS
        /                                                       /dev/mapper/pve-vm--110--disk--0 ext4       rw,relatime,stripe=16
        |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3260368k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
        | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
        | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
        |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
        | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
        | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
        | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
        | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
        | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
        | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
        | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
        | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
        | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8117136k,nr_inodes=2029284,mode=755,inode64
        | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
        | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
        | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
        | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
        | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
          |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
          |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
          `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        435M    /var/
        248M    /var/cache
        245M    /var/cache/apt
        169M    /var/cache/apt/archives
        146M    /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        1.6M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        85M     /opt/iobroker/iobroker-data/
        62M     /opt/iobroker/iobroker-data/files
        31M     /opt/iobroker/iobroker-data/files/backitup.admin
        31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
        9.8M    /opt/iobroker/iobroker-data/objects.jsonl
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
        5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
        5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.2
        javascript:     "javascript" not found
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioB24                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : ioB24                                    -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.2    , installed 7.1.2
        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Objects and States
        Objects:        124
        States:         88
        Hit:1 http://security.debian.org bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1055632    974/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1055625    974/iobroker.js-con
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          744091     318/master
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          742063     1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1055693    992/io.admin.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          744092     318/master
        tcp6       0      0 :::22                   :::*                    LISTEN      0          743832     1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          742065     1/init
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          742064     1/init
        udp6       0      0 :::111                  :::*                                0          742066     1/init
        2024-09-25 19:30:24.571  - info: backitup.0 (390) Terminated (NO_ERROR): Without reason
        2024-09-25 19:30:25.059  - info: backitup.0 (390) terminating
        2024-09-25 19:30:25.101  - info: host.ioB24 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2024-09-25 19:30:25.385  - info: host.ioB24 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2024-09-25 19:30:25.386  - info: host.ioB24 All instances are stopped.
        2024-09-25 19:30:25.567  - info: host.ioB24 terminated
        2024-09-25 19:39:53.260  - info: host.ioB24 iobroker.js-controller version 6.0.11 js-controller starting
        2024-09-25 19:39:53.264  - info: host.ioB24 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
        2024-09-25 19:39:53.264  - info: host.ioB24 hostname: ioB24, node: v20.17.0
        2024-09-25 19:39:53.265  - info: host.ioB24 ip addresses: 192.168.1.152 2a02:810c:1bf:f826:be24:11ff:fe42:4bab fe80::be24:11ff:fe42:4bab
        2024-09-25 19:39:53.858  - info: host.ioB24 connected to Objects and States
        2024-09-25 19:39:53.873  - info: host.ioB24 added notifications configuration of host
        2024-09-25 19:39:54.102  - info: host.ioB24 2 instances found
        2024-09-25 19:39:54.106  - info: host.ioB24 starting 2 instances
        2024-09-25 19:39:54.339  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeCurrent"
        2024-09-25 19:39:54.356  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewest"
        2024-09-25 19:39:54.360  - info: host.ioB24 Delete state "system.host.ioB24.versions.nodeNewestNext"
        2024-09-25 19:39:54.363  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmCurrent"
        2024-09-25 19:39:54.370  - info: host.ioB24 instance system.adapter.admin.0 in version "7.1.2" started with pid 992
        2024-09-25 19:39:54.374  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewest"
        2024-09-25 19:39:54.418  - info: host.ioB24 Delete state "system.host.ioB24.versions.npmNewestNext"
        2024-09-25 19:39:54.420  - info: host.ioB24 Some obsolete host states deleted.
        2024-09-25 19:39:58.307  - info: host.ioB24 instance system.adapter.backitup.0 in version "3.0.22" started with pid 1033
        2024-09-25 19:39:59.553  - info: backitup.0 (1033) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
        2024-09-25 19:39:59.587  - info: backitup.0 (1033) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                v.2024-05-22
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        Recommended versions are nodejs 20.17.0 and npm 10.8.2
        MEMORY:
        Mem:            7.4G        1.6G        5.4G        114K        373M        5.7G
        Swap:           536M          0B        536M
        ioBroker Core:          js-controller           6.0.11
                                admin                   7.1.2
        Objects type: jsonl
        States  type: jsonl
        Objects:                124
        States:                 88
        Size of iob-Database:
        5.4M    /opt/iobroker/iobroker-data/states.jsonl
        P crunchip 2 Replies Last reply Reply Quote 0
          @marko67
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: ioTest
            Virtualization: lxc
                    Kernel: Linux 6.8.12-1-pve
          model name      : 12th Gen Intel(R) Core(TM) i5-1240P
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           19:39:29 up  8:04,  3 users,  load average: 1.29, 1.43, 1.57
          CPU threads: 4
                         Local time: Wed 2024-09-25 19:39:29 UTC
                     Universal time: Wed 2024-09-25 19:39:29 UTC
                           RTC time: n/a
                          Time zone: Etc/UTC (UTC, +0000)
                    RTC in local TZ: no
          peter
          HOME=/home/peter
          GROUPS=peter sudo users iobroker
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.5G        797M        5.1G        139K        2.6G        7.7G
          Swap:             0B          0B          0B
          Total:          8.5G        797M        5.1G
          Active iob-Instances:   6
                   8096 M total memory
                    760 M used memory
                    792 M active memory
                   2297 M inactive memory
                   4896 M free memory
                      0 M buffer memory
                   2438 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          top - 19:39:30 up  8:04,  3 users,  load average: 1.51, 1.48, 1.58
          Tasks:  36 total,   1 running,  35 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8096.0 total,   4895.1 free,    762.3 used,   2438.6 buff/cache
          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7333.7 avail Mem
          1 loaded units listed.
          *** FILESYSTEM ***
          /dev/loop0     ext4       20G  3.2G   16G  17% /
          udev           devtmpfs   32G     0   32G   0% /dev/tty
          tmpfs          tmpfs      32G     0   32G   0% /dev/shm
          tmpfs          tmpfs      13G  132K   13G   1% /run
          tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/1000
          /                                                       /dev/loop0                     ext4       rw,relatime
          |-/run                                                  tmpfs                          tmpfs      rw,nosuid,nodev,size=13089324k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
          | |-/run/user/1000                                      tmpfs                          tmpfs      rw,nosuid,nodev,relatime,size=6544660k,nr_inodes=1636165,mode=700,uid=101000,gid=101000,inode64
          |-/dev                                                  none                           tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64| |-/dev/shm                                            tmpfs                          tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
          | |-/dev/full                                           udev[/full]                    devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
          | |-/dev/null                                           udev[/null]                    devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
          | |-/dev/random                                         udev[/random]                  devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
          | |-/dev/tty                                            udev[/tty]                     devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
          | |-/dev/urandom                                        udev[/urandom]                 devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
          | |-/dev/zero                                           udev[/zero]                    devtmpfs   rw,nosuid,relatime,size=32690008k,nr_inodes=8172502,mode=755,inode64
          /var:
          419M    /var/
          248M    /var/cache
          245M    /var/cache/apt
          146M    /var/lib
          4.0K    /opt/iobroker/backups/
          525M    /opt/iobroker/iobroker-data/
          503M    /opt/iobroker/iobroker-data/files
          441M    /opt/iobroker/iobroker-data/files/javascript.admin
          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          9.9M    /opt/iobroker/iobroker-data/objects.jsonl
          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.1.2
          javascript:     8.7.6
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run
          as: admin
          + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
          + system.adapter.discovery.0              : discovery             : ioTest                                   -  enabled
          + system.adapter.history.0                : history               : ioTest                                   -  enabled
          + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
          + instance is alive
          as: admin
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Objects and States
          Objects:        217
          States:         158
          Pending Updates: 0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       203631894  154/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       203631881  154/iobroker.js-con
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          203629897  324/master
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          203631661  1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          203629770  1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          203631663  1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       203656306  526/io.admin.0
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          203629898  324/master
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          203631777  87/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          203631662  1/init
          udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       203677868  385/io.discovery.0
          udp6       0      0 :::111                  :::*                                0          203631664  1/init
          2024-09-25 12:44:43.508  - info: admin.0 (526) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
          2024-09-25 13:16:34.592  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 13:21:12.611  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 13:21:13.292  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 13:26:16.181  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 13:26:16.903  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 13:33:01.954  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 13:42:08.890  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 13:42:12.205  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 14:28:19.717  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 14:30:59.723  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 17:58:14.049  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 18:02:04.070  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 18:02:26.241  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 18:02:37.756  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 18:13:53.085  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 18:13:57.028  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 18:28:33.016  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 18:28:38.116  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 18:43:11.126  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 18:48:25.001  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 19:17:26.663  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 19:17:30.918  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
          2024-09-25 19:28:25.578  - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
          2024-09-25 19:29:25.582  - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                  v.2024-05-22
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               64 bit
          Timezone:               Etc/UTC (UTC, +0000)
          User-ID:                1000
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Mem:            8.5G        799M        5.1G        139K        2.6G        7.7G
          Swap:             0B          0B          0B
          Total:          8.5G        799M        5.1G
                                  admin                   7.1.2
          Objects type: jsonl
          States  type: jsonl
          as: admin
          Objects:                217
          States:                 158
          5.7M    /opt/iobroker/iobroker-data/states.jsonl
            peterfido @peterfido last edited by
            @marko67 Dein Kernel ist aktueller.
            Den Proxmox-Host aktualisiere ich erst am Wochenende.
            • Codierknecht
              Codierknecht Developer Most Active @peterfido last edited by
              @peterfido
              Hab' auch Kernel 6.8.12-2-pve. Funzt problemlos und dümpelt nach frischer Installation um 320 MB rum.
              Skript v.2024-05-22
              *** BASE SYSTEM ***
               Static hostname: ioBroker-TEST
                Virtualization: lxc
              model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
               20:07:57 up  8:11,  2 users,  load average: 0.27, 0.19, 0.18
              CPU threads: 1
                             Local time: Wed 2024-09-25 20:07:57 UTC
                         Universal time: Wed 2024-09-25 20:07:57 UTC
                               RTC time: n/a
                        RTC in local TZ: no
              codierknecht
              HOME=/home/codierknecht
              GROUPS=codierknecht sudo users iobroker
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            2.1G        340M        972M        131K        834M        1.8G
              Swap:           2.1G        4.1K        2.1G
              Total:          4.3G        340M        3.1G
                       2048 M total memory
                        325 M used memory
                        471 M active memory
                        551 M inactive memory
                        927 M free memory
                          0 M buffer memory
                        795 M swap cache
                       2048 M total swap
                          0 M used swap
                       2047 M free swap
              top - 20:07:57 up  8:11,  2 users,  load average: 0.25, 0.19, 0.18
              Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
              MiB Mem :   2048.0 total,    925.5 free,    326.9 used,    795.7 buff/cache
              MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1721.1 avail Mem
              *** FILESYSTEM ***
              /dev/mapper/pve-vm--300--disk--0 ext4      7.8G  2.2G  5.3G  29% /
              tmpfs                            tmpfs     3.2G  124K  3.2G   1% /run
              /                                                       /dev/mapper/pve-vm--300--disk--0 ext4       rw,relatime,stripe=16
              |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3253060k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
              | `-/run/credentials/systemd-firstboot.service          ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
              | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
              | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
              | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
              | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
              | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
              | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8098764k,nr_inodes=2024691,mode=755,inode64
              /var:
              419M    /var/
              249M    /var/cache
              245M    /var/cache/apt
              146M    /var/lib
              79M     /opt/iobroker/iobroker-data/
              9.6M    /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          7.1.2
              Adapter State
              + system.adapter.admin.0                  : admin                 : ioBroker-TEST                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : ioBroker-TEST                            -  enabled
              + instance is alive
              Objects and States
              Objects:        124
              States:         89
              Pending Updates: 0
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          29808714   301/master
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29958647   10404/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29958642   10404/iobroker.js-c
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29957141   1/init
              tcp6       0      0 :::111                  :::*                    LISTEN      0          29957143   1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          29806168   1/init
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          29808715   301/master
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       29959052   10500/io.admin.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29806275   93/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          29957142   1/init
              udp        0      0 0.0.0.0:161             0.0.0.0:*                           0          30040554   10843/snmpd
              udp6       0      0 :::111                  :::*                                0          29957144   1/init
              2024-09-25 12:37:35.644  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 5 states of discovery
              2024-09-25 12:37:35.646  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 15 states of system.adapter.discovery
              2024-09-25 12:37:35.647  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 1 states (io.discovery.*) from states
              2024-09-25 12:37:35.653  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 16 states (system.adapter.discovery.*) from states
              2024-09-25 12:37:35.856  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Counted 1 objects of discovery
              2024-09-25 12:37:35.892  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST file discovery.admin deleted
              2024-09-25 12:37:35.894  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST object discovery deleted
              2024-09-25 12:37:35.898  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST object discovery.admin deleted
              2024-09-25 12:37:35.899  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Deleting 25 object(s).
              2024-09-25 12:37:35.933  - info: host.ioBroker-TEST object deleted system.adapter.discovery.0
              2024-09-25 12:37:35.935  - info: host.ioBroker-TEST stopInstance system.adapter.discovery.0 (force=false, process=true)
              2024-09-25 12:37:35.937  - info: host.ioBroker-TEST iobroker host.ioBroker-TEST Deleting 17 state(s).
              2024-09-25 12:37:35.938  - info: discovery.0 (10568) Got terminate signal TERMINATE_YOURSELF
              2024-09-25 12:37:35.938  - info: discovery.0 (10568) terminating
              2024-09-25 12:37:35.939  - info: discovery.0 (10568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-09-25 12:37:35.977  - info: host.ioBroker-TEST stopInstance system.adapter.discovery.0 send kill signal
              2024-09-25 12:37:36.442  - info: discovery.0 (10568) terminating
              2024-09-25 12:37:36.514  - info: host.ioBroker-TEST instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
              2024-09-25 12:37:36.514  - info: host.ioBroker-TEST Do not restart adapter system.adapter.discovery.0 because desired by instance
              2024-09-25 12:37:37.304  - info: host.ioBroker-TEST iobroker removed 42 packages in 1s
              2024-09-25 12:37:37.305  - info: host.ioBroker-TEST iobroker
              2024-09-25 12:37:37.306  - info: host.ioBroker-TEST iobroker 58 packages are looking for funding
              2024-09-25 12:37:37.307  - info: host.ioBroker-TEST iobroker   run `npm fund` for details
              2024-09-25 12:37:38.328  - info: host.ioBroker-TEST iobroker exit 0
              2024-09-25 12:42:43.671  - info: admin.0 (10500) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
                crunchip Forum Testing Most Active @marko67 last edited by crunchip
                @marko67 sagte in NUC-Proxmox-steigender Ram:
                und immer noch das Problem admin?
                schalt mal auf Experten Modus und zeig die Instanz(Ein/Ausgänge)
                und schalt den admin mal auf logstufe debug und zeig das log dazu
                Wie sieht es mit deinem Netzwerk aus? --> Wie ist die Frage gemeint?
                bin zwar kein Netzwerkspezialist, aber hast du vllt. irgend etwas spezielles eingerichtet (firewall, pihole... oder irgend etwas in der Richtung), sodass sich der admin zu tote läuft?
                bezogen auf
                024-09-24 18:40:37.012 - warn: admin.0 (10305) Repository cannot be read: Active repo - stable 2024-09-24 18:40:37.028 - warn: admin.0 (10305) Active repository "stable" cannot be read
                  marko67 @crunchip last edited by marko67
                  @crunchip said in NUC-Proxmox-steigender Ram:
                  Nein. Wie gesagt jede Einstellung beim erstellen des Containers und von ioB 1:1 aus der bebilderten Anleitung übernommen
                  2024-09-25 23:04:25.191 - debug: admin.0 (3465) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2024-09-25 23:04:25.210 - debug: admin.0 (3465) Objects client ready ... initialize now
                  2024-09-25 23:04:25.212 - debug: admin.0 (3465) Objects create System PubSub Client
                  2024-09-25 23:04:25.213 - debug: admin.0 (3465) Objects create User PubSub Client
                  2024-09-25 23:04:25.225 - debug: admin.0 (3465) Objects client initialize lua scripts
                  2024-09-25 23:04:25.232 - debug: admin.0 (3465) Objects connected to redis: 127.0.0.1:9001
                  2024-09-25 23:04:25.243 - debug: admin.0 (3465) Redis States: Use Redis connection: 127.0.0.1:9000
                  2024-09-25 23:04:25.247 - debug: admin.0 (3465) States create System PubSub Client
                  2024-09-25 23:04:25.248 - debug: admin.0 (3465) States create User PubSub Client
                  2024-09-25 23:04:25.254 - debug: admin.0 (3465) States connected to redis: 127.0.0.1:9000
                  2024-09-25 23:04:25.271 - debug: admin.0 (3465) Plugin sentry Initialize Plugin (enabled=true)
                  2024-09-25 23:04:25.498 - info: admin.0 (3465) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                  2024-09-25 23:04:25.526 - info: admin.0 (3465) requesting all objects
                  2024-09-25 23:04:25.996 - info: admin.0 (3465) received all objects
                  2024-09-25 23:04:26.005 - debug: admin.0 (3465) Secure connection not enabled - using http createServer
                  2024-09-25 23:04:26.235 - debug: admin.0 (3465) Next repo update on 9/28/2024, 7:41:16 PM
                  2024-09-25 23:04:26.257 - info: admin.0 (3465) socket.io server listening on port 8081
                  2024-09-25 23:04:26.259 - info: admin.0 (3465) http server listening on port 8081
                  2024-09-25 23:04:26.259 - info: admin.0 (3465) Use link "http://127.0.0.1:8081" to configure.
                  2024-09-25 23:04:28.999 - info: admin.0 (3465) ==> Connected system.user.admin from ::ffff:192.168.1.35
                  2024-09-25 23:04:29.011 - debug: admin.0 (3465) Subscribes: dummy
                  2024-09-25 23:04:29.013 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*
                  2024-09-25 23:04:29.013 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive
                  2024-09-25 23:04:29.014 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive
                  2024-09-25 23:04:29.014 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive
                  2024-09-25 23:04:29.015 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected
                  2024-09-25 23:04:29.015 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount
                  2024-09-25 23:04:29.016 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss
                  2024-09-25 23:04:29.016 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount
                  2024-09-25 23:04:29.017 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel
                  2024-09-25 23:04:29.017 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled
                  2024-09-25 23:04:29.018 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree
                  2024-09-25 23:04:29.018 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize
                  2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning
                  2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem
                  2024-09-25 23:04:29.019 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection
                  2024-09-25 23:04:29.020 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension
                  2024-09-25 23:04:29.020 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:04:29.064 - debug: admin.0 (3465) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                  2024-09-25 23:05:25.755 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.connected, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.755 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.inputCount, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.memRss, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.outputCount, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.756 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.logLevel, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.757 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.adapter.*.plugins.sentry.enabled, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.759 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskFree, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.760 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskSize, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.760 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.diskWarning, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.freemem, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, *.info.connection, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.761 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, *.info.extension, admin.0.info.newsFeed
                  2024-09-25 23:05:25.762 - debug: admin.0 (3465) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed
                  crunchip Codierknecht 2 Replies Last reply Reply Quote 0
                    Diese ganzen Meldungen dürften doch eigentlich gar nicht mehr auftauchen?
                    • Codierknecht
                      Codierknecht Developer Most Active @marko67 last edited by
                      @marko67
                      Seit wann ist denn von "Redis" die Rede?
                      M crunchip 2 Replies Last reply Reply Quote 0
                        @crunchip
                        Nein. Haben den Adapter gelöscht. 1x über ioB Adapter und dann mal über die Konsole. Meldung taucht immer wieder auf??
                          marko67 @Codierknecht last edited by
                          @codierknecht
                          Was meinst Du damit??
                            crunchip Forum Testing Most Active @Codierknecht last edited by crunchip
                            @codierknecht siehe Port 9000/9001, das ist die iobroker interne Redis Datenbank
                            https://www.iobroker.net/#de/documentation/config/redis.md
                            P Codierknecht 2 Replies Last reply Reply Quote 0
                              peterfido @crunchip last edited by peterfido
                              @marko67
                              DIE bebilderte Anleitung habe ich nicht gefunden.
                              Unter Proxmox nutze ich VMs.
                              Einen CT habe ich jetzt mal für diesen Test hier erstellt.
                              Dazu erstmal im Proxmox Host die aktuelle Debian 12 Vorlage heruntergeladen.
                              Dann auf erstelle CT klicken, das Template auswählen, 20GB Disk, 4 CPU Kerne in einem Sockel, 8 GB RAM, bei Netzwerk evtl. noch das VLAN setzen, DHCP an, starten.
                              Dann als root sudo installieren.
                              apt update
                              apt install sudo
                              apt install curl
                              adduser benutzername
                              usermod benutzername -aG sudo
                              exit
                              Dann als benutzername einloggen
                              sudo apt update
                              sudo apt install qemu-guest-agent
                              curl -sLf https://iobroker.net/install.sh | bash -
                              Das ist das Grundsystem, welches bei mir seit gestern testet.
                              Unter Objekte werden noch System freies RAM, RAM-Prozent und der Speicher vom admin in die History geloggt.
                              • Codierknecht
                                Codierknecht Developer Most Active @crunchip last edited by
                                @crunchip sagte in NUC-Proxmox-steigender Ram:
                                Da muss dann aber jemand auf Redis umgestellt haben.
                                In meinem Test-LXC taucht jedenfalls im Log kein "Redis" auf.
                                  @codierknecht sagte in NUC-Proxmox-steigender Ram:
                                  Das wurde schon glaub seit controller Version 3.3 eingeführt, nagel mich aber bitte nicht fest
                                    @crunchip
                                    Redis ist bei meinem Testsystem nicht aktiv.
                                    2024-09-25 10:57:57.542 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
                                    2024-09-25 10:57:57.543 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                    2024-09-25 10:57:57.543 - info: host.ioTest hostname: ioTest, node: v20.17.0
                                    2024-09-25 10:57:57.544 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
                                    2024-09-25 10:57:57.771 - info: host.ioTest connected to Objects and States
                                    2024-09-25 10:57:57.780 - info: host.ioTest Node.js version has changed from unknown to 20.17.0
                                    2024-09-25 10:57:57.786 - info: host.ioTest Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                    2024-09-25 10:57:57.786 - info: host.ioTest added notifications configuration of host
                                    2024-09-25 10:57:57.892 - info: host.ioTest 3 instances found
                                    2024-09-25 10:57:57.894 - info: host.ioTest starting 3 instances
                                    2024-09-25 10:57:57.906 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 10717
                                    2024-09-25 10:57:58.391 - info: admin.0 (10717) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 10:57:58.399 - info: admin.0 (10717) requesting all objects
                                    2024-09-25 10:57:58.434 - info: admin.0 (10717) received all objects
                                    2024-09-25 10:57:58.438 - info: admin.0 (10717) Request actual repository...
                                    2024-09-25 10:57:58.445 - info: host.ioTest Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                    2024-09-25 10:57:58.447 - info: admin.0 (10717) socket.io server listening on port 8081
                                    2024-09-25 10:57:58.447 - info: admin.0 (10717) http server listening on port 8081
                                    2024-09-25 10:57:58.448 - info: admin.0 (10717) Use link "http://127.0.0.1:8081" to configure.
                                    2024-09-25 10:57:58.549 - warn: admin.0 (10717) Repository cannot be read: Active repo - stable
                                    2024-09-25 10:57:58.556 - warn: admin.0 (10717) Active repository "stable" cannot be read
                                    2024-09-25 10:58:00.709 - info: admin.0 (10717) Repository received successfully.
                                    2024-09-25 10:58:01.977 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 10758
                                    2024-09-25 10:58:02.421 - info: backitup.0 (10758) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 10:58:02.435 - info: backitup.0 (10758) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                    2024-09-25 10:58:05.976 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 10773
                                    2024-09-25 10:58:06.372 - info: discovery.0 (10773) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 11:34:33.609 - info: admin.0 (10717) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 11:35:16.156 - info: backitup.0 (10758) cleaned everything up...
                                    2024-09-25 11:35:16.156 - info: admin.0 (10717) terminating http server on port 8081
                                    2024-09-25 11:35:16.155 - info: host.ioTest received SIGTERM
                                    2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2024-09-25 11:35:16.157 - info: host.ioTest stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2024-09-25 11:35:16.161 - info: admin.0 (10717) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-25 11:35:16.161 - info: backitup.0 (10758) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-25 11:35:16.161 - info: discovery.0 (10773) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-25 11:35:16.162 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
                                    2024-09-25 11:35:16.162 - info: discovery.0 (10773) terminating
                                    2024-09-25 11:35:16.161 - info: backitup.0 (10758) terminating
                                    2024-09-25 11:35:16.162 - info: backitup.0 (10758) Terminated (NO_ERROR): Without reason
                                    2024-09-25 11:35:16.162 - info: discovery.0 (10773) Terminated (NO_ERROR): Without reason
                                    2024-09-25 11:35:16.162 - info: admin.0 (10717) terminating
                                    2024-09-25 11:35:16.163 - info: host.ioTest stopInstance system.adapter.backitup.0 send kill signal
                                    2024-09-25 11:35:16.163 - info: host.ioTest stopInstance system.adapter.discovery.0 send kill signal
                                    2024-09-25 11:35:16.163 - info: admin.0 (10717) Terminated (NO_ERROR): Without reason
                                    2024-09-25 11:35:16.657 - info: discovery.0 (10773) terminating
                                    2024-09-25 11:35:16.658 - info: backitup.0 (10758) terminating
                                    2024-09-25 11:35:16.659 - info: admin.0 (10717) terminating
                                    2024-09-25 11:35:16.694 - info: host.ioTest instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                    2024-09-25 11:35:16.694 - info: host.ioTest instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                                    2024-09-25 11:35:16.735 - info: host.ioTest instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                    2024-09-25 11:35:16.735 - info: host.ioTest All instances are stopped.
                                    2024-09-25 11:35:16.779 - info: host.ioTest terminated
                                    2024-09-25 11:35:23.318 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
                                    2024-09-25 11:35:23.320 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                    2024-09-25 11:35:23.320 - info: host.ioTest hostname: ioTest, node: v20.17.0
                                    2024-09-25 11:35:23.320 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
                                    2024-09-25 11:35:23.606 - info: host.ioTest connected to Objects and States
                                    2024-09-25 11:35:23.612 - info: host.ioTest added notifications configuration of host
                                    2024-09-25 11:35:23.785 - info: host.ioTest 3 instances found
                                    2024-09-25 11:35:23.787 - info: host.ioTest starting 3 instances
                                    2024-09-25 11:35:23.836 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeCurrent"
                                    2024-09-25 11:35:23.934 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 329
                                    2024-09-25 11:35:23.972 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewest"
                                    2024-09-25 11:35:23.973 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewestNext"
                                    2024-09-25 11:35:23.975 - info: host.ioTest Delete state "system.host.ioTest.versions.npmCurrent"
                                    2024-09-25 11:35:23.977 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewest"
                                    2024-09-25 11:35:23.978 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewestNext"
                                    2024-09-25 11:35:23.979 - info: host.ioTest Some obsolete host states deleted.
                                    2024-09-25 11:35:24.476 - info: admin.0 (329) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 11:35:24.486 - info: admin.0 (329) requesting all objects
                                    2024-09-25 11:35:24.655 - info: admin.0 (329) received all objects
                                    2024-09-25 11:35:24.732 - info: admin.0 (329) socket.io server listening on port 8081
                                    2024-09-25 11:35:24.733 - info: admin.0 (329) http server listening on port 8081
                                    2024-09-25 11:35:24.733 - info: admin.0 (329) Use link "http://127.0.0.1:8081" to configure.
                                    2024-09-25 11:35:27.900 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 370
                                    2024-09-25 11:35:28.009 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 11:35:28.315 - info: backitup.0 (370) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 11:35:28.327 - info: backitup.0 (370) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                    2024-09-25 11:35:31.888 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 385
                                    2024-09-25 11:35:32.281 - info: discovery.0 (385) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 11:35:36.379 - info: admin.0 (329) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 11:35:36.698 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 11:38:43.322 - info: host.ioTest iobroker add javascript
                                    2024-09-25 11:38:43.887 - info: host.ioTest iobroker NPM version: 10.8.2
                                    2024-09-25 11:38:43.888 - info: host.ioTest iobroker Installing iobroker.javascript@8.7.6... (System call)
                                    2024-09-25 11:38:49.868 - info: host.ioTest iobroker
                                    2024-09-25 11:38:49.869 - info: host.ioTest iobroker added 16 packages in 6s72 packages are looking for funding run `npm fund` for details
                                    2024-09-25 11:38:49.881 - info: host.ioTest iobroker host.ioTest install adapter javascript
                                    2024-09-25 11:38:49.897 - info: host.ioTest iobroker upload [881] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                    2024-09-25 11:38:49.981 - info: host.ioTest iobroker upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js application/javascript
                                    2024-09-25 11:38:50.136 - info: host.ioTest iobroker upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_object.js google-blockly/own/blocks_object.js application/javascript
                                    2024-09-25 11:38:50.226 - info: host.ioTest iobroker upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/864.4c85ffd6.chunk.css static/css/864.4c85ffd6.chunk.css text/css
                                    2024-09-25 11:38:50.596 - info: host.ioTest iobroker upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/173.4e774f7f.chunk.js static/js/173.4e774f7f.chunk.js application/javascript
                                    2024-09-25 11:38:50.745 - info: host.ioTest iobroker upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/26.79c81b4e.chunk.js static/js/26.79c81b4e.chunk.js application/javascript
                                    2024-09-25 11:38:51.495 - info: host.ioTest iobroker upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/320.d9816b46.chunk.js.map static/js/320.d9816b46.chunk.js.map application/json
                                    2024-09-25 11:38:51.817 - info: host.ioTest iobroker upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.168f947c.chunk.js.map static/js/409.168f947c.chunk.js.map application/json
                                    2024-09-25 11:38:52.050 - info: host.ioTest iobroker upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/456.97a46315.chunk.js.LICENSE.txt static/js/456.97a46315.chunk.js.LICENSE.txt text/plain
                                    2024-09-25 11:38:52.655 - info: host.ioTest iobroker upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/61.913ccfa8.chunk.js.map static/js/61.913ccfa8.chunk.js.map application/json
                                    2024-09-25 11:38:53.181 - info: host.ioTest iobroker upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/709.88d87b7c.chunk.js.map static/js/709.88d87b7c.chunk.js.map application/json
                                    2024-09-25 11:38:53.457 - info: host.ioTest iobroker upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/826.76c09000.chunk.js.map static/js/826.76c09000.chunk.js.map application/json
                                    2024-09-25 11:38:53.957 - info: host.ioTest iobroker upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/880.e4029d50.chunk.js static/js/880.e4029d50.chunk.js application/javascript
                                    2024-09-25 11:38:54.341 - info: host.ioTest iobroker upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/961.02d44700.chunk.js.map static/js/961.02d44700.chunk.js.map application/json
                                    2024-09-25 11:38:54.428 - info: host.ioTest iobroker upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.720010c8.js static/js/main.720010c8.js application/javascript
                                    2024-09-25 11:38:54.517 - info: host.ioTest iobroker upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Cellar.7ec1b1803a2437c8b78c.svg static/media/Cellar.7ec1b1803a2437c8b78c.svg image/svg+xml
                                    2024-09-25 11:38:54.604 - info: host.ioTest iobroker upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Room.3c380ab767be35f904e1.svg static/media/Living Room.3c380ab767be35f904e1.svg image/svg+xml
                                    2024-09-25 11:38:54.623 - info: host.ioTest iobroker upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/People.12a7e9127e72f3259186.svg static/media/People.12a7e9127e72f3259186.svg image/svg+xml
                                    2024-09-25 11:38:54.641 - info: host.ioTest iobroker upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Security.1ec78971bd34efa950f8.svg static/media/Security.1ec78971bd34efa950f8.svg image/svg+xml
                                    2024-09-25 11:38:54.656 - info: host.ioTest iobroker upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Storeroom.7de4e6f3364554459b8a.svg static/media/Storeroom.7de4e6f3364554459b8a.svg image/svg+xml
                                    2024-09-25 11:38:54.674 - info: host.ioTest iobroker upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                    2024-09-25 11:38:54.690 - info: host.ioTest iobroker upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                    2024-09-25 11:38:54.706 - info: host.ioTest iobroker upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                    2024-09-25 11:38:54.729 - info: host.ioTest iobroker upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                    2024-09-25 11:38:54.768 - info: host.ioTest iobroker upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                    2024-09-25 11:38:54.770 - info: host.ioTest iobroker upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                    2024-09-25 11:38:54.773 - info: host.ioTest iobroker upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                    2024-09-25 11:38:54.775 - info: host.ioTest iobroker upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                    2024-09-25 11:38:54.778 - info: host.ioTest iobroker upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                    2024-09-25 11:38:54.780 - info: host.ioTest iobroker upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                    2024-09-25 11:38:54.790 - info: host.ioTest iobroker upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                    2024-09-25 11:38:54.793 - info: host.ioTest iobroker upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                    2024-09-25 11:38:54.797 - info: host.ioTest iobroker upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                    2024-09-25 11:38:54.800 - info: host.ioTest iobroker upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                    2024-09-25 11:38:54.814 - info: host.ioTest iobroker upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                    2024-09-25 11:38:54.817 - info: host.ioTest iobroker upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                    2024-09-25 11:38:54.819 - info: host.ioTest iobroker upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                    2024-09-25 11:38:54.821 - info: host.ioTest iobroker upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                    2024-09-25 11:38:54.866 - info: host.ioTest iobroker upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                    2024-09-25 11:38:54.871 - info: host.ioTest iobroker upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                    2024-09-25 11:38:54.875 - info: host.ioTest iobroker upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                                    2024-09-25 11:38:54.877 - info: host.ioTest iobroker upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                                    2024-09-25 11:38:54.879 - info: host.ioTest iobroker upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                                    2024-09-25 11:38:54.881 - info: host.ioTest iobroker upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                                    2024-09-25 11:38:54.883 - info: host.ioTest iobroker upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                                    2024-09-25 11:38:54.902 - info: host.ioTest iobroker host.ioTest object _design/script created/updated
                                    2024-09-25 11:38:54.903 - info: host.ioTest iobroker host.ioTest object script.js created/updated
                                    2024-09-25 11:38:54.904 - info: host.ioTest iobroker host.ioTest object script.js.common created/updated
                                    2024-09-25 11:38:54.904 - info: host.ioTest iobroker host.ioTest object script.js.global created/updated
                                    2024-09-25 11:38:54.906 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript created/updated
                                    2024-09-25 11:38:54.924 - info: host.ioTest iobroker host.ioTest create instance javascript
                                    2024-09-25 11:38:54.926 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.alive created
                                    2024-09-25 11:38:54.926 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.connected created
                                    2024-09-25 11:38:54.927 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.compactMode created
                                    2024-09-25 11:38:54.928 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.cpu created
                                    2024-09-25 11:38:54.929 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.cputime created
                                    2024-09-25 11:38:54.931 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memHeapUsed created
                                    2024-09-25 11:38:54.932 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memHeapTotal created
                                    2024-09-25 11:38:54.933 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.memRss created
                                    2024-09-25 11:38:54.934 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.uptime created
                                    2024-09-25 11:38:54.935 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.inputCount created
                                    2024-09-25 11:38:54.936 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.outputCount created
                                    2024-09-25 11:38:54.937 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.eventLoopLag created
                                    2024-09-25 11:38:54.938 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.sigKill created
                                    2024-09-25 11:38:54.942 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0.logLevel created
                                    2024-09-25 11:38:54.942 - info: host.ioTest iobroker host.ioTest object javascript.0.variables created
                                    2024-09-25 11:38:54.943 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.astro created
                                    2024-09-25 11:38:54.945 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.isDayTime created
                                    2024-09-25 11:38:54.946 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.isDaylightSaving created
                                    2024-09-25 11:38:54.946 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.dayTime created
                                    2024-09-25 11:38:54.947 - info: host.ioTest iobroker host.ioTest object javascript.0.variables.rulesTour created
                                    2024-09-25 11:38:54.948 - info: host.ioTest iobroker host.ioTest object javascript.0.debug created
                                    2024-09-25 11:38:54.949 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.to created
                                    2024-09-25 11:38:54.950 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.from created
                                    2024-09-25 11:38:54.951 - info: host.ioTest iobroker host.ioTest object javascript.0.debug.rules created
                                    2024-09-25 11:38:54.958 - info: host.ioTest iobroker host.ioTest object system.adapter.javascript.0 created
                                    2024-09-25 11:38:55.979 - info: host.ioTest iobroker exit 0
                                    2024-09-25 11:38:56.110 - info: host.ioTest iobroker add history
                                    2024-09-25 11:38:56.688 - info: host.ioTest iobroker NPM version: 10.8.2
                                    2024-09-25 11:38:56.688 - info: host.ioTest iobroker Installing iobroker.history@3.0.1... (System call)
                                    2024-09-25 11:38:58.072 - info: host.ioTest instance system.adapter.javascript.0 in version "8.7.6" started with pid 496
                                    2024-09-25 11:38:58.218 - info: host.ioTest iobroker
                                    2024-09-25 11:38:58.219 - info: host.ioTest iobroker added 1 package in 1s72 packages are looking for funding run `npm fund` for details
                                    2024-09-25 11:38:58.229 - info: host.ioTest iobroker host.ioTest install adapter history
                                    2024-09-25 11:38:58.242 - info: host.ioTest iobroker upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                                    2024-09-25 11:38:58.247 - info: host.ioTest iobroker upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    2024-09-25 11:38:58.249 - info: host.ioTest iobroker upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    2024-09-25 11:38:58.251 - info: host.ioTest iobroker upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    2024-09-25 11:38:58.253 - info: host.ioTest iobroker upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    2024-09-25 11:38:58.255 - info: host.ioTest iobroker upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    2024-09-25 11:38:58.257 - info: host.ioTest iobroker upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    2024-09-25 11:38:58.259 - info: host.ioTest iobroker upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    2024-09-25 11:38:58.261 - info: host.ioTest iobroker upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    2024-09-25 11:38:58.264 - info: host.ioTest iobroker upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    2024-09-25 11:38:58.267 - info: host.ioTest iobroker upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    2024-09-25 11:38:58.268 - info: host.ioTest iobroker upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                                    2024-09-25 11:38:58.270 - info: host.ioTest iobroker upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                                    2024-09-25 11:38:58.272 - info: host.ioTest iobroker upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                                    2024-09-25 11:38:58.282 - info: host.ioTest iobroker host.ioTest object system.adapter.history created/updated
                                    2024-09-25 11:38:58.291 - info: host.ioTest iobroker host.ioTest create instance history
                                    2024-09-25 11:38:58.294 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.alive created
                                    2024-09-25 11:38:58.295 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.connected created
                                    2024-09-25 11:38:58.297 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.compactMode created
                                    2024-09-25 11:38:58.298 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.cpu created
                                    2024-09-25 11:38:58.299 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.cputime created
                                    2024-09-25 11:38:58.300 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memHeapUsed created
                                    2024-09-25 11:38:58.302 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memHeapTotal created
                                    2024-09-25 11:38:58.303 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.memRss created
                                    2024-09-25 11:38:58.304 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.uptime created
                                    2024-09-25 11:38:58.305 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.inputCount created
                                    2024-09-25 11:38:58.306 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.outputCount created
                                    2024-09-25 11:38:58.308 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.eventLoopLag created
                                    2024-09-25 11:38:58.309 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.sigKill created
                                    2024-09-25 11:38:58.311 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0.logLevel created
                                    2024-09-25 11:38:58.312 - info: host.ioTest iobroker host.ioTest object system.adapter.history.0 created
                                    2024-09-25 11:38:58.707 - info: javascript.0 (496) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 11:38:58.742 - info: javascript.0 (496) requesting all states
                                    2024-09-25 11:38:58.743 - info: javascript.0 (496) requesting all objects
                                    2024-09-25 11:38:58.800 - info: javascript.0 (496) received all states
                                    2024-09-25 11:38:58.849 - info: javascript.0 (496) received all objects
                                    2024-09-25 11:38:59.322 - info: host.ioTest iobroker exit 0
                                    2024-09-25 11:39:10.927 - info: host.ioTest instance system.adapter.history.0 in version "3.0.1" started with pid 511
                                    2024-09-25 11:39:11.319 - info: history.0 (511) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 11:39:11.374 - info: history.0 (511) Set default history instance to "history.0"
                                    2024-09-25 11:39:15.959 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2024-09-25 11:39:15.963 - info: admin.0 (329) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-25 11:39:15.964 - info: admin.0 (329) terminating http server on port 8081
                                    2024-09-25 11:39:15.965 - info: admin.0 (329) terminating
                                    2024-09-25 11:39:15.966 - info: admin.0 (329) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-09-25 11:39:16.004 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
                                    2024-09-25 11:39:16.466 - info: admin.0 (329) terminating
                                    2024-09-25 11:39:16.482 - info: host.ioTest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-09-25 11:39:19.585 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 526
                                    2024-09-25 11:39:20.093 - info: admin.0 (526) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 11:39:20.105 - info: admin.0 (526) requesting all objects
                                    2024-09-25 11:39:20.289 - info: admin.0 (526) received all objects
                                    2024-09-25 11:39:20.363 - info: admin.0 (526) Secure socket.io server listening on port 8081
                                    2024-09-25 11:39:20.364 - info: admin.0 (526) https server listening on port 8081
                                    2024-09-25 11:39:20.364 - info: admin.0 (526) Use link "https://127.0.0.1:8081" to configure.
                                    2024-09-25 11:39:37.141 - info: admin.0 (526) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
                                    2024-09-25 11:39:48.042 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 11:40:17.163 - info: discovery.0 (385) Discovering devices with a HF-LPB100 chipset...
                                    2024-09-25 11:40:17.169 - info: discovery.0 (385) Discovering mDNS devices...
                                    2024-09-25 11:40:17.170 - info: discovery.0 (385) Discovering ping devices...
                                    2024-09-25 11:40:17.195 - info: discovery.0 (385) Discovering UPnP devices...
                                    2024-09-25 11:40:17.197 - info: discovery.0 (385) Discovering wifi-mi-light devices...
                                    2024-09-25 11:40:17.205 - warn: discovery.0 (385) tr-064.0 not installed
                                    2024-09-25 11:40:17.205 - info: discovery.0 (385) Done discovering tr064 devices. 0 packages received
                                    2024-09-25 11:40:18.697 - info: discovery.0 (385) Done discovering RESOL VBus devices. 0 packages received
                                    2024-09-25 11:40:19.198 - info: discovery.0 (385) Done discovering wifi-mi-light devices. 0 packages received
                                    2024-09-25 11:40:22.174 - info: discovery.0 (385) Done discovering SMA Speedwire devices. 0 packages received
                                    2024-09-25 11:40:22.174 - info: discovery.0 (385) Done discovering udp devices. 1 packages received
                                    2024-09-25 11:40:27.165 - info: discovery.0 (385) Done discovering HF-LPB100 devices. 0 packages received
                                    2024-09-25 11:40:30.509 - info: discovery.0 (385) Done discovering ping devices. 1 packages received
                                    2024-09-25 11:40:32.171 - info: discovery.0 (385) Done discovering mdns devices. 0 packages received
                                    2024-09-25 11:40:32.196 - info: discovery.0 (385) Done discovering upnp devices. 18 packages received
                                    2024-09-25 11:40:32.199 - info: discovery.0 (385) Found 4 addresses
                                    2024-09-25 11:40:49.408 - info: discovery.0 (385) Discovery finished. Found new or modified 7 instances
                                    2024-09-25 11:40:49.464 - info: discovery.0 (385) Discovery finished
                                    2024-09-25 11:44:05.124 - info: history.0 (511) enabled logging of system.host.ioTest.freemem, Alias=false, WriteNulls=true
                                    2024-09-25 11:44:31.505 - info: history.0 (511) enabled logging of system.host.ioTest.mem, Alias=false, WriteNulls=true
                                    2024-09-25 12:00:43.151 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 12:06:08.821 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 12:07:37.652 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 12:07:38.465 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 12:13:18.504 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 12:31:49.466 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 12:33:56.558 - info: history.0 (511) enabled logging of system.adapter.admin.0.memRss, Alias=false, WriteNulls=true
                                    2024-09-25 12:36:54.832 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 19:53:29.746 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 19:58:39.494 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 19:58:40.510 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 20:02:05.439 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 20:02:10.921 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 20:02:16.615 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 20:02:17.150 - info: admin.0 (526) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 20:02:44.103 - info: backitup.0 (370) cleaned everything up...
                                    2024-09-25 20:02:44.103 - info: host.ioTest received SIGTERM
                                    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.javascript.0 (force=false, process=true)
                                    2024-09-25 20:02:44.104 - info: host.ioTest stopInstance system.adapter.history.0 (force=false, process=true)
                                    2024-09-25 20:02:44.107 - info: discovery.0 (385) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-25 20:02:44.106 - info: javascript.0 (496) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-25 20:02:44.105 - info: admin.0 (526) terminating https server on port 8081
                                    2024-09-25 20:02:44.108 - info: javascript.0 (496) terminating
                                    2024-09-25 20:02:44.109 - info: javascript.0 (496) Terminated (NO_ERROR): Without reason
                                    2024-09-25 20:02:44.108 - info: backitup.0 (370) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-25 20:02:44.111 - info: admin.0 (526) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-25 20:02:44.110 - info: history.0 (511) terminating
                                    2024-09-25 20:02:44.112 - info: history.0 (511) Terminated (NO_ERROR): Without reason
                                    2024-09-25 20:02:44.113 - info: admin.0 (526) terminating
                                    2024-09-25 20:02:44.114 - info: admin.0 (526) Terminated (NO_ERROR): Without reason
                                    2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
                                    2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.backitup.0 send kill signal
                                    2024-09-25 20:02:44.147 - info: host.ioTest stopInstance system.adapter.discovery.0 send kill signal
                                    2024-09-25 20:02:44.148 - info: host.ioTest stopInstance system.adapter.javascript.0 send kill signal
                                    2024-09-25 20:02:44.150 - info: discovery.0 (385) terminating
                                    2024-09-25 20:02:44.151 - info: backitup.0 (370) terminating
                                    2024-09-25 20:02:44.151 - info: discovery.0 (385) Terminated (NO_ERROR): Without reason
                                    2024-09-25 20:02:44.151 - info: backitup.0 (370) Terminated (NO_ERROR): Without reason
                                    2024-09-25 20:02:44.573 - info: admin.0 (526) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 20:02:44.608 - info: javascript.0 (496) terminating
                                    2024-09-25 20:02:44.608 - info: backitup.0 (370) terminating
                                    2024-09-25 20:02:44.608 - info: discovery.0 (385) terminating
                                    2024-09-25 20:02:44.609 - info: admin.0 (526) terminating
                                    2024-09-25 20:02:44.634 - info: host.ioTest instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                                    2024-09-25 20:02:44.634 - info: host.ioTest instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                                    2024-09-25 20:02:44.638 - info: host.ioTest instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                    2024-09-25 20:02:44.666 - info: host.ioTest instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                                    2024-09-25 20:02:44.668 - info: host.ioTest instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                    2024-09-25 20:02:44.668 - info: host.ioTest All instances are stopped.
                                    2024-09-25 20:02:44.836 - info: host.ioTest terminated
                                    2024-09-25 20:02:46.206 - info: host.ioTest iobroker.js-controller version 6.0.11 js-controller starting
                                    2024-09-25 20:02:46.208 - info: host.ioTest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                    2024-09-25 20:02:46.208 - info: host.ioTest hostname: ioTest, node: v20.17.0
                                    2024-09-25 20:02:46.208 - info: host.ioTest ip addresses: 192.168.56.243 fe80::be24:11ff:fee6:705f
                                    2024-09-25 20:02:46.578 - info: host.ioTest connected to Objects and States
                                    2024-09-25 20:02:46.583 - info: host.ioTest added notifications configuration of host
                                    2024-09-25 20:02:46.727 - info: host.ioTest 5 instances found
                                    2024-09-25 20:02:46.729 - info: host.ioTest starting 5 instances
                                    2024-09-25 20:02:46.833 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeCurrent"
                                    2024-09-25 20:02:46.840 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewest"
                                    2024-09-25 20:02:46.848 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 4493
                                    2024-09-25 20:02:46.848 - info: host.ioTest Delete state "system.host.ioTest.versions.nodeNewestNext"
                                    2024-09-25 20:02:46.850 - info: host.ioTest Delete state "system.host.ioTest.versions.npmCurrent"
                                    2024-09-25 20:02:46.891 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewest"
                                    2024-09-25 20:02:46.892 - info: host.ioTest Delete state "system.host.ioTest.versions.npmNewestNext"
                                    2024-09-25 20:02:46.893 - info: host.ioTest Some obsolete host states deleted.
                                    2024-09-25 20:02:47.330 - info: admin.0 (4493) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 20:02:47.339 - info: admin.0 (4493) requesting all objects
                                    2024-09-25 20:02:47.505 - info: admin.0 (4493) received all objects
                                    2024-09-25 20:02:47.578 - info: admin.0 (4493) Secure socket.io server listening on port 8081
                                    2024-09-25 20:02:47.579 - info: admin.0 (4493) https server listening on port 8081
                                    2024-09-25 20:02:47.579 - info: admin.0 (4493) Use link "https://127.0.0.1:8081" to configure.
                                    2024-09-25 20:02:50.860 - info: host.ioTest instance system.adapter.javascript.0 in version "8.7.6" started with pid 4534
                                    2024-09-25 20:02:51.452 - info: javascript.0 (4534) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 20:02:51.491 - info: javascript.0 (4534) requesting all states
                                    2024-09-25 20:02:51.491 - info: javascript.0 (4534) requesting all objects
                                    2024-09-25 20:02:51.550 - info: javascript.0 (4534) received all states
                                    2024-09-25 20:02:51.598 - info: javascript.0 (4534) received all objects
                                    2024-09-25 20:02:51.682 - info: admin.0 (4493) failed connection to socket.io from ::ffff:192.168.56.21: Passport was not initialized
                                    2024-09-25 20:02:54.822 - info: host.ioTest instance system.adapter.history.0 in version "3.0.1" started with pid 4549
                                    2024-09-25 20:02:55.216 - info: history.0 (4549) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 20:02:55.267 - info: history.0 (4549) enabled logging of system.adapter.admin.0.memRss (Count=1), Alias=false
                                    2024-09-25 20:02:55.268 - info: history.0 (4549) enabled logging of system.host.ioTest.mem (Count=2), Alias=false
                                    2024-09-25 20:02:55.268 - info: history.0 (4549) enabled logging of system.host.ioTest.freemem (Count=3), Alias=false
                                    2024-09-25 20:02:58.825 - info: host.ioTest instance system.adapter.backitup.0 in version "3.0.22" started with pid 4564
                                    2024-09-25 20:02:59.241 - info: backitup.0 (4564) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 20:02:59.258 - info: backitup.0 (4564) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                    2024-09-25 20:03:02.822 - info: host.ioTest instance system.adapter.discovery.0 in version "5.0.0" started with pid 4579
                                    2024-09-25 20:03:03.220 - info: discovery.0 (4579) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-25 20:03:09.139 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 20:04:10.889 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 20:04:11.635 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 20:08:24.918 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 20:20:28.303 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 20:20:33.031 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 20:34:43.640 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 20:34:47.954 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 21:08:27.999 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 21:08:38.367 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                    2024-09-25 22:08:44.182 - info: admin.0 (4493) ==> Connected system.user.admin from ::ffff:192.168.56.21
                                    2024-09-25 22:09:09.131 - info: admin.0 (4493) <== Disconnect system.user.admin from ::ffff:192.168.56.21 admin
                                      crunchip Forum Testing Most Active @peterfido last edited by
                                      @peterfido wir reden hier auch nicht von einem Redis Server um von jsonl auf Redis um zu stellen., sondern von der internen DB.
                                      Iobroker wurde ab einer bestimmten Version optimiert und auf Redis umgestellt.
                                      Wie oben schon geschrieben, nicht sicher ab welcher Version das eingeführt wurde.
                                      • Codierknecht
                                        @crunchip
                                        Gerade gesehen, dass der Admin ja auf "Debug" steht. Darum sehe ich diese Einträge bei mir nicht.
                                        Dann brauche ich mich ja nicht zu wundern. Alles gut.
                                        Bleibt trotzdem ein Mysterium.
                                        Kann mir kaum vorstellen, dass es an ioBroker liegt. Das würde hier sonst dutzendfach aufschlagen.
                                        Irgendetwas ist an der Installation von Proxmox anders als bei allen anderen.
                                        Wobei ich zugeben muss, dass ich meines auch nicht stringent nach irgend einer Anleitung installiert habe. Bootfähigen Stick erzeugt und dann gestartet. Der Rest ist eigentlich selbsterklärend.
                                        crunchip M 2 Replies Last reply Reply Quote 0
                                          korrekt
                                          und extra chatgpt bemüht(zu faul zum suchen)😁
                                          Die Umstellung von der internen ioBroker-Datenbank auf Redis erfolgte mit der Einführung der Version 1.5.0 des ioBroker.js-Controllers, die am 16. September 2018 veröffentlicht wurde
                                          keine Ahnung, daher fragte ich ja nach dem syslog
                                            @crunchip
                                            okay, auf debug wird es aufgeführt.
                                            2024-09-26 06:42:42.326 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
                                            2024-09-26 06:42:42.330 - info: admin.0 (4493) Got terminate signal TERMINATE_YOURSELF
                                            2024-09-26 06:42:42.331 - info: admin.0 (4493) terminating https server on port 8081
                                            2024-09-26 06:42:42.332 - info: admin.0 (4493) terminating
                                            2024-09-26 06:42:42.332 - info: admin.0 (4493) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2024-09-26 06:42:42.371 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
                                            2024-09-26 06:42:42.833 - info: admin.0 (4493) terminating
                                            2024-09-26 06:42:42.859 - info: host.ioTest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-09-26 06:42:45.965 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 5251
                                            2024-09-26 06:42:46.371 - debug: admin.0 (5251) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                            2024-09-26 06:42:46.378 - debug: admin.0 (5251) Objects client ready ... initialize now
                                            2024-09-26 06:42:46.379 - debug: admin.0 (5251) Objects create System PubSub Client
                                            2024-09-26 06:42:46.379 - debug: admin.0 (5251) Objects create User PubSub Client
                                            2024-09-26 06:42:46.383 - debug: admin.0 (5251) Objects client initialize lua scripts
                                            2024-09-26 06:42:46.385 - debug: admin.0 (5251) Objects connected to redis: 127.0.0.1:9001
                                            2024-09-26 06:42:46.389 - debug: admin.0 (5251) Redis States: Use Redis connection: 127.0.0.1:9000
                                            2024-09-26 06:42:46.390 - debug: admin.0 (5251) States create System PubSub Client
                                            2024-09-26 06:42:46.390 - debug: admin.0 (5251) States create User PubSub Client
                                            2024-09-26 06:42:46.392 - debug: admin.0 (5251) States connected to redis: 127.0.0.1:9000
                                            2024-09-26 06:42:46.398 - debug: admin.0 (5251) Plugin sentry Initialize Plugin (enabled=true)
                                            2024-09-26 06:42:46.462 - info: admin.0 (5251) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                                            2024-09-26 06:42:46.472 - info: admin.0 (5251) requesting all objects
                                            peter@ioTest:~$ iob status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            peter@ioTest:~$
                                            137
                                            18500
