    3. Einsteigerfragen
    4. NUC-Proxmox-steigender Ram
      peterfido @crunchip last edited by peterfido
      @crunchip
      okay, auf debug wird es aufgeführt.
      2024-09-26 06:42:42.326 - info: host.ioTest stopInstance system.adapter.admin.0 (force=false, process=true)
      2024-09-26 06:42:42.330 - info: admin.0 (4493) Got terminate signal TERMINATE_YOURSELF
      2024-09-26 06:42:42.331 - info: admin.0 (4493) terminating https server on port 8081
      2024-09-26 06:42:42.332 - info: admin.0 (4493) terminating
      2024-09-26 06:42:42.332 - info: admin.0 (4493) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-09-26 06:42:42.371 - info: host.ioTest stopInstance system.adapter.admin.0 send kill signal
      2024-09-26 06:42:42.833 - info: admin.0 (4493) terminating
      2024-09-26 06:42:42.859 - info: host.ioTest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-09-26 06:42:45.965 - info: host.ioTest instance system.adapter.admin.0 in version "7.1.2" started with pid 5251
      2024-09-26 06:42:46.371 - debug: admin.0 (5251) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-09-26 06:42:46.378 - debug: admin.0 (5251) Objects client ready ... initialize now
      2024-09-26 06:42:46.379 - debug: admin.0 (5251) Objects create System PubSub Client
      2024-09-26 06:42:46.379 - debug: admin.0 (5251) Objects create User PubSub Client
      2024-09-26 06:42:46.383 - debug: admin.0 (5251) Objects client initialize lua scripts
      2024-09-26 06:42:46.385 - debug: admin.0 (5251) Objects connected to redis: 127.0.0.1:9001
      2024-09-26 06:42:46.389 - debug: admin.0 (5251) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-09-26 06:42:46.390 - debug: admin.0 (5251) States create System PubSub Client
      2024-09-26 06:42:46.390 - debug: admin.0 (5251) States create User PubSub Client
      2024-09-26 06:42:46.392 - debug: admin.0 (5251) States connected to redis: 127.0.0.1:9000
      2024-09-26 06:42:46.398 - debug: admin.0 (5251) Plugin sentry Initialize Plugin (enabled=true)
      2024-09-26 06:42:46.462 - info: admin.0 (5251) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
      2024-09-26 06:42:46.472 - info: admin.0 (5251) requesting all objects
      peter@ioTest:~$ iob status
      Objects type: jsonl
      States  type: jsonl
      peter@ioTest:~$
        crunchip Forum Testing Most Active @peterfido last edited by
        @peterfido sagte in NUC-Proxmox-steigender Ram:
        DIE bebilderte Anleitung habe ich nicht gefunden.
        diese Dreiecke sind aufklappbar
        @marko67 sagte in NUC-Proxmox-steigender Ram:
        Haben den Adapter gelöscht. 1x über ioB Adapter und dann mal über die Konsole. Meldung taucht immer wieder auf??
        seltsam
        kannst du testweise einen neuen LXC erstellen, diesmal aber ein ubuntu template nehmen und mal nur eine reine Installation, ohne irgend etwas einzurichten oder zu löschen, nach der iobroker Installation
        • MartinP
          MartinP @marko67 last edited by MartinP
          Mein Problem ist, dass der RAM bis auf 100% hoch läuft und dann auch andere Container einfrieren. So war es auf dem vorherigen System.
          Hier mal der RAM Verbrauch nach knapp 3 Stunden
          1. Wenn man ein sicheres System haben will, darf man in Summe nur so viel RAM auf die Container verteilen, wie Proxmox bereitstellen kann ...
            Hast Du ein System mit 8 GB RAM und drei Containern, sollte man nicht mehr als ca 7,5 GB auf die drei Container verteilen, also z.B. 2,5 + 2,5 + 2,5
            Verteilt man mehr, als vorhanden ist auf die Container, gibt es die von Dir beobachteten Symptome, wenn einer der Container amok läuft, und ausnutzt, was ihm zusteht.
          2. Meine Frage war, wie sich das RAM verhält, WÄHREND der iobroker durch "iob stop" gestoppt ist.
            Sinkt die "Memory usage" wieder?
            Auf den ursprünglichen Stand vor dem ersten Start des iob?
          crunchip M 2 Replies Last reply Reply Quote 0
            crunchip Forum Testing Most Active @MartinP last edited by
            @martinp laut seiner Aussage hat er doch 16GB Gesamt
            8Gb für iobroker und 2weitere LXC mit 1 und 2 GB Ram, sollte in Summe dann ja passen
            @martinp sagte in NUC-Proxmox-steigender Ram:
            ja, hat er oben doch schon gezeigt
            • MartinP
              MartinP last edited by MartinP
              iob stop ausgeführt. Ist mit 157 MB neu gestartet und nun wieder bei fast 1,5 GB steigend
              Sorry, hatte nur die grafische Auswertung beachtet, und da keinen Abfall der RAM-Nutzung durch IOB gesehen
              Ist "Nesting" im Lxc-Container aktiviert?
              Und hier die Netzwerk-Einstellungen des Containers:
              Da habe ich gegenüber der Fritzbox getrickst ...
                marko67 @Codierknecht last edited by
                @codierknecht
                Genau so habe ich es gemacht. Da kann man ja eigentlich nichts falsch machen. Habe es mit der bebilderten Anleitung verglichen und 1:1 genau so gemacht.
                  marko67 @crunchip last edited by marko67
                  @crunchip
                  Mach ich
                  Erledigt:
                  Nach über 2 Std.
                    marko67 @MartinP last edited by
                    @martinp
                    Das neue System (Hardware / neuer NUC) hat 16 GB Speicher.
                    der 1. Container iob hat 8GB der 2. iob-Test hat 4 GB
                    Sinkt die "Memory usage" wieder? --> Ja!! Ich gl. ich hatte davon einen Screenshot bereits gepostet.
                      @martinp
                      Ist "Nesting" im Lxc-Container aktiviert? --> Ja
                      • MartinP
                        @marko67 und bei der statisch zugewiesenen 192.168.1.152 spuckt kein anderes Device in die Suppe? Lieg die Adresse im Range, den Dein Router per DHCP vergibt?
                          @martinp
                          Fritz.Box sagt nein. Kein anderes Gerät mit gleicher IP. Range geht bis 200.
                          Alle meine SH Geräte haben statische Nummern. --> Betreibe parallel seit 13 Jahren FHEM.
                          Bisher lief alles sehr gut parallel (seit ca. 8 Jahren)
                            Chrunchy @marko67 last edited by
                            Feste IPs sind kein Problem, allerdings sollte diese immer außerhalb der IP-Range des DHCP-Servers liegen. GGf. den Bereich des DHCP verkleiner.
                              crunchip Forum Testing Most Active @marko67 last edited by
                              @marko67 dann gehen mir langsam die Ideen aus
                              • Dr. Bakterius
                                Dr. Bakterius Most Active last edited by Dr. Bakterius
                                Hat jemand von Euch in den letzten Tagen einen neuen LXC aufgesetzt mit aktueller Software und ioB?? Nur um mal den Gegentest zu machen.
                                Nun habe auch ich einen neuen LXC auf meinem Proxmox 8.2.6 aufgesetzt (Mini-PC mit einem n100 und 32 GB RAM). Und zwar mit dem aktuellen debian Template debian-12-standard_12.7-1_amd64.tar.zst.
                                Die weitere Vorgangsweise genau wie in der Anleitung durchgeführt. Nur den javascript-Adapter mit dem Assistenten installiert. Sonst nichts weiter installiert oder gelöscht.
                                Nach etwa einer Stunde bin ich stabil bei etwa 670 MB RAM-Belegung. top sagt noch:
                                top - 16:51:30 up 55 min,  1 user,  load average: 0.42, 0.47, 0.53
                                Tasks:  21 total,   1 running,  20 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  8.1 us,  2.4 sy,  0.0 ni, 88.2 id,  0.3 wa,  0.0 hi,  0.8 si,  0.0 st
                                MiB Mem :   8192.0 total,   4706.1 free,    671.2 used,   2814.7 buff/cache
                                MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7520.8 avail Mem
                                Edit: Nach über 3 Stunden 720 MB Auslastung - davon hat der Admin 145 MB.
                                • MartinP
                                  MartinP @Dr. Bakterius last edited by
                                  @dr-bakterius Im stable Repository wird aktuell admin 7.1.5 zum Aktualisieren angeboten ...
                                  In den Releasenotes des Update Fensters aber keine Hinweise, dass ein Speicherleck gefixt wurde...
                                  • Dr. Bakterius
                                    Dr. Bakterius Most Active @MartinP last edited by
                                    Vermutlich weil es keines gibt.
                                    Ich habe auf meinem Produktivsystem gestern das Admin-Update installiert - keine Änderung feststellbar was den RAM-Bedarf angeht. Und auch bei der vorherigen Version keine Auffälligkeiten. Jetzt nach knapp 21 Stunden bin ich bei 765 MB. Also nur moderat gestiegen was völlig normal ist. Das ist offensichtlich ein Problem das nur @marko67 betrifft und mit ziemlicher Sicherheit nichts mit ioBroker zu tun hat.
                                      marko67 @Dr. Bakterius last edited by
                                      @dr-bakterius @MartinP
                                      Nach dem Hinweis auf die IP (spuckt ein anderes Gerät in die Suppe) habe ich festgestellt, dass ioB relativ viel Traffic produziert.
                                      Da kam mir eine Einstellung im Admin Adapter in den Sinn. Nicht https und Passwort sondern "Prüfen ob aus dem Internet erreichbar"
                                      Weiß jemand wofür das ist?
                                      • Dr. Bakterius
                                        Dr. Bakterius Most Active @marko67 last edited by
                                        Das ist eine Sicherheitseinstellung. Wenn das Feld nicht angehakt ist, wirst du eine Warnung erhalten wenn der ioBroker von außen erreichbar und somit angreifbar ist weil ein Port offen ist. Für Leute die wissen was sie tun, kann man diese Warnungen abdrehen.
                                        Wenigstens verstehe ich das so. Und diese Einstellung hat sicher nichts mit deinem Problem zu tun. Hast du offene Ports?
                                          @dr-bakterius
                                          Ich habe einen offenen Port für mein OpenVPN auf einem 2. NUC (dieser soll von dem jetzigen abgelöst werden).
                                          Folgendes habe ich festgestellt als ich den Hacken gesetzt habe:
                                          Ohne Hacken... RAM steigt:
                                          Mit Hacken ... RAM und Traffic fällt direkt
                                          Das gleiche Verhalten konnte ich auf allen 3 Testcontainern reproduzieren. Test ioB24 (Container1) läuft seit 29 Stunden ruhig mit 300 MB
                                          Meister Mopper Dr. Bakterius 2 Replies Last reply Reply Quote 0
                                          • Meister Mopper
                                            Meister Mopper @marko67 last edited by
                                            Dann probier doch mal https für den Adapter (da gibt es den Haken gar nicht), so läuft's bei mir, und es gibt über den Monat ein weitgehend konstantes Bild.
                                            137
                                            18501
