    4. js-controller Lucy (v7.0.0) Alpha Test
    • Gaspode
      Gaspode @sigi234 last edited by
      @sigi234 said in js-controller Lucy (v7.0.0) Alpha Test:
      Hallo, also der Windows Installer installiert diese Version nicht?
      Doch, natürlich. Im Expertenmodus das Häkchen bei "Nutze Alpha-Repo (@next)" setzen und es wird aktuell Version 7.0.0-alpha.0-20240926-91f9b082f angeboten. Warum fragst du?
      foxriver76 F 2 Replies Last reply Reply Quote 0
      • foxriver76
        foxriver76 Developer @Gaspode last edited by
        @gaspode Danke, ich ergänze das gerne im ersten Post, ich denke daher die Frage.
        S Rene55 3 Replies Last reply Reply Quote 2
          Shadowhunter23 @foxriver76 last edited by Shadowhunter23
          @foxriver76
          Backup System ist die Installation ohne Fehler durchgelaufen. System läuft jetzt für paar Minuten ohne Probleme.
            @foxriver76
            Produktiv läuft nicht , zurück mit Proxmox Backup.
            tobias@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next --omit=dev
            added 7 packages, and changed 17 packages in 11s
            307 packages are looking for funding
              run `npm fund` for details
            tobias@iobroker:/opt/iobroker$ iob start
            tobias@iobroker:/opt/iobroker$ iob logs --watch
            2024-09-26 17:13:52.080  - error: admin.0 (578389) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch        block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:13:52.080  - error: admin.0 (578389) unhandled promise rejection: callback is not a function
            2024-09-26 17:13:52.081  - error: admin.0 (578389) TypeError: callback is not a function
                at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:13:52.082  - error: admin.0 (578389) callback is not a function
            2024-09-26 17:13:52.588  - warn: admin.0 (578389) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:13:53.115  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:13:53.115  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:13:53.115  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:13:53.115  - error: host.iobroker instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:13:53.116  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
            2024-09-26 17:13:55.354  - info: host.iobroker instance system.adapter.email.0 in version "1.3.1" started with pid 578404
            2024-09-26 17:13:55.856  - error: email.0 (578404) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch        block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:13:55.857  - error: email.0 (578404) unhandled promise rejection: callback is not a function
            2024-09-26 17:13:55.858  - error: email.0 (578404) TypeError: callback is not a function
                at runNextTicks (node:internal/process/task_queues:60:5)
                at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:13:55.859  - error: email.0 (578404) callback is not a function
            2024-09-26 17:13:56.366  - warn: email.0 (578404) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:13:56.890  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:13:56.891  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:13:56.891  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:13:56.891  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:13:56.891  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:13:56.891  - error: host.iobroker instance system.adapter.email.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:13:56.891  - info: host.iobroker Restart adapter system.adapter.email.0 because enabled
            2024-09-26 17:13:59.363  - info: host.iobroker instance system.adapter.influxdb.0 in version "4.0.2" started with pid 578419
            2024-09-26 17:13:59.955  - error: influxdb.0 (578419) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:13:59.955  - error: influxdb.0 (578419) unhandled promise rejection: callback is not a function
            2024-09-26 17:13:59.956  - error: influxdb.0 (578419) TypeError: callback is not a function
            2024-09-26 17:13:59.957  - error: influxdb.0 (578419) callback is not a function
            2024-09-26 17:14:00.007  - info: influxdb.0 (578419) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v20.17.0, js-controller: 7.0.0-a        lpha.0-20240926-91f9b082f
            2024-09-26 17:14:00.964  - warn: influxdb.0 (578419) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:01.488  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:01.488  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:01.489  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:01.489  - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:01.489  - info: host.iobroker Restart adapter system.adapter.influxdb.0 because enabled
            2024-09-26 17:14:03.363  - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 578434
            2024-09-26 17:14:07.387  - info: host.iobroker instance system.adapter.pushover.0 in version "4.1.0" started with pid 578450
            2024-09-26 17:14:07.931  - error: pushover.0 (578450) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:07.932  - error: pushover.0 (578450) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:07.933  - error: pushover.0 (578450) TypeError: callback is not a function
            2024-09-26 17:14:07.933  - error: pushover.0 (578450) callback is not a function
            2024-09-26 17:14:08.442  - warn: pushover.0 (578450) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:08.964  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:08.965  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:08.965  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:08.965  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:08.965  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:08.965  - error: host.iobroker instance system.adapter.pushover.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:08.965  - info: host.iobroker Restart adapter system.adapter.pushover.0 because enabled
            2024-09-26 17:14:11.361  - info: host.iobroker instance system.adapter.pushover.1 in version "4.1.0" started with pid 578465
            2024-09-26 17:14:11.852  - error: pushover.1 (578465) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:11.852  - error: pushover.1 (578465) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:11.854  - error: pushover.1 (578465) TypeError: callback is not a function
            2024-09-26 17:14:11.854  - error: pushover.1 (578465) callback is not a function
            2024-09-26 17:14:12.361  - warn: pushover.1 (578465) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:12.884  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:12.884  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:12.884  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:12.885  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:12.885  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:12.885  - error: host.iobroker instance system.adapter.pushover.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:12.885  - info: host.iobroker Restart adapter system.adapter.pushover.1 because enabled
            2024-09-26 17:14:15.366  - info: host.iobroker instance system.adapter.pushover.2 in version "4.1.0" started with pid 578480
            2024-09-26 17:14:15.865  - error: pushover.2 (578480) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:15.865  - error: pushover.2 (578480) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:15.867  - error: pushover.2 (578480) TypeError: callback is not a function
            2024-09-26 17:14:15.867  - error: pushover.2 (578480) callback is not a function
            2024-09-26 17:14:15.921  - info: pushover.2 (578480) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v20.17.0, js-controller: 7.0.0-a        lpha.0-20240926-91f9b082f
            2024-09-26 17:14:16.374  - info: pushover.2 (578480) terminating
            2024-09-26 17:14:16.375  - warn: pushover.2 (578480) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:16.897  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:16.898  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:16.898  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:16.898  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:16.898  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:16.898  - error: host.iobroker instance system.adapter.pushover.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:16.898  - info: host.iobroker Restart adapter system.adapter.pushover.2 because enabled
            2024-09-26 17:14:19.362  - info: host.iobroker instance system.adapter.telegram.0 in version "3.9.0" started with pid 578495
            2024-09-26 17:14:19.988  - error: telegram.0 (578495) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:19.989  - error: telegram.0 (578495) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:19.990  - error: telegram.0 (578495) TypeError: callback is not a function
            2024-09-26 17:14:19.990  - error: telegram.0 (578495) callback is not a function
            2024-09-26 17:14:20.498  - warn: telegram.0 (578495) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:21.021  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:21.022  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:21.022  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:21.022  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:21.022  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:21.022  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:21.022  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
            2024-09-26 17:14:22.132  - info: host.iobroker instance system.adapter.telegram.0 in version "3.9.0" started with pid 578510
            2024-09-26 17:14:22.824  - error: telegram.0 (578510) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:22.825  - error: telegram.0 (578510) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:22.826  - error: telegram.0 (578510) TypeError: callback is not a function
            2024-09-26 17:14:22.826  - error: telegram.0 (578510) callback is not a function
            2024-09-26 17:14:23.226  - info: host.iobroker instance system.adapter.admin.0 in version "7.1.5" started with pid 578540
            2024-09-26 17:14:23.334  - warn: telegram.0 (578510) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:23.356  - info: host.iobroker instance system.adapter.telegram.1 in version "3.9.0" started with pid 578547
            2024-09-26 17:14:23.875  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:23.876  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:23.876  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:23.876  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:23.876  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
            2024-09-26 17:14:24.064  - error: admin.0 (578540) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch        block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:24.065  - error: admin.0 (578540) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:24.066  - error: admin.0 (578540) TypeError: callback is not a function
            2024-09-26 17:14:24.066  - error: admin.0 (578540) callback is not a function
            2024-09-26 17:14:24.119  - error: telegram.1 (578547) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:24.120  - error: telegram.1 (578547) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:24.121  - error: telegram.1 (578547) TypeError: callback is not a function
            2024-09-26 17:14:24.121  - error: telegram.1 (578547) callback is not a function
            2024-09-26 17:14:24.573  - warn: admin.0 (578540) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:24.628  - warn: telegram.1 (578547) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:24.988  - info: host.iobroker instance system.adapter.telegram.0 in version "3.9.0" started with pid 578600
            2024-09-26 17:14:25.098  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:25.098  - error: host.iobroker Caught by controller[0]: TypeError: callback is not a function
            2024-09-26 17:14:25.098  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:25.098  - error: host.iobroker instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:25.098  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
            2024-09-26 17:14:25.161  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:25.161  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:25.161  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:25.161  - error: host.iobroker instance system.adapter.telegram.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:25.161  - info: host.iobroker Restart adapter system.adapter.telegram.1 because enabled
            2024-09-26 17:14:25.654  - error: telegram.0 (578600) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:25.654  - error: telegram.0 (578600) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:25.656  - error: telegram.0 (578600) TypeError: callback is not a function
            2024-09-26 17:14:25.656  - error: telegram.0 (578600) callback is not a function
            2024-09-26 17:14:26.162  - warn: telegram.0 (578600) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:26.265  - info: host.iobroker instance system.adapter.telegram.1 in version "3.9.0" started with pid 578615
            2024-09-26 17:14:26.692  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:26.693  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:26.693  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:26.693  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:26.693  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:26.693  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:26.693  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
            2024-09-26 17:14:26.693  - warn: host.iobroker Do not restart adapter system.adapter.telegram.0 because restart loop detected
            2024-09-26 17:14:26.926  - error: telegram.1 (578615) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:26.926  - error: telegram.1 (578615) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:26.927  - error: telegram.1 (578615) TypeError: callback is not a function
            2024-09-26 17:14:26.928  - error: telegram.1 (578615) callback is not a function
            2024-09-26 17:14:27.084  - info: host.iobroker instance system.adapter.email.0 in version "1.3.1" started with pid 578644
            2024-09-26 17:14:27.352  - info: host.iobroker instance system.adapter.telegram.2 in version "3.9.0" started with pid 578652
            2024-09-26 17:14:27.436  - warn: telegram.1 (578615) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:27.635  - error: email.0 (578644) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch        block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:27.636  - error: email.0 (578644) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:27.638  - error: email.0 (578644) TypeError: callback is not a function
            2024-09-26 17:14:27.638  - error: email.0 (578644) callback is not a function
            2024-09-26 17:14:27.970  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:27.970  - error: host.iobroker Caught by controller[0]: TypeError: callback is not a function
            2024-09-26 17:14:27.970  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:27.970  - error: host.iobroker Caught by controller[0]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:27.970  - error: host.iobroker Caught by controller[0]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:27.970  - error: host.iobroker instance system.adapter.telegram.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:27.970  - info: host.iobroker Restart adapter system.adapter.telegram.1 because enabled
            2024-09-26 17:14:28.078  - error: telegram.2 (578652) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:28.079  - error: telegram.2 (578652) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:28.080  - error: telegram.2 (578652) TypeError: callback is not a function
            2024-09-26 17:14:28.080  - error: telegram.2 (578652) callback is not a function
            2024-09-26 17:14:28.147  - warn: email.0 (578644) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:28.161  - info: telegram.2 (578652) starting. Version 3.9.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v20.17.0, js-controller: 7.0.0-a        lpha.0-20240926-91f9b082f
            2024-09-26 17:14:28.588  - info: telegram.2 (578652) terminating
            2024-09-26 17:14:28.589  - warn: telegram.2 (578652) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:28.669  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:28.669  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:28.669  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:28.670  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:28.670  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:28.670  - error: host.iobroker instance system.adapter.email.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:28.670  - info: host.iobroker Restart adapter system.adapter.email.0 because enabled
            2024-09-26 17:14:29.077  - info: host.iobroker instance system.adapter.telegram.1 in version "3.9.0" started with pid 578689
            2024-09-26 17:14:29.113  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:29.113  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:29.113  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:29.113  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:29.113  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:29.113  - error: host.iobroker instance system.adapter.telegram.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:29.113  - info: host.iobroker Restart adapter system.adapter.telegram.2 because enabled
            2024-09-26 17:14:29.737  - error: telegram.1 (578689) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:29.738  - error: telegram.1 (578689) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:29.740  - error: telegram.1 (578689) TypeError: callback is not a function
            2024-09-26 17:14:29.740  - error: telegram.1 (578689) callback is not a function
            2024-09-26 17:14:30.224  - info: host.iobroker instance system.adapter.telegram.2 in version "3.9.0" started with pid 578704
            2024-09-26 17:14:30.248  - warn: telegram.1 (578689) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:30.776  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:30.776  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:30.776  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:30.776  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:30.776  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:30.776  - error: host.iobroker instance system.adapter.telegram.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:30.777  - info: host.iobroker Restart adapter system.adapter.telegram.1 because enabled
            2024-09-26 17:14:30.777  - warn: host.iobroker Do not restart adapter system.adapter.telegram.1 because restart loop detected
            2024-09-26 17:14:30.854  - error: telegram.2 (578704) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:30.854  - error: telegram.2 (578704) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:30.856  - error: telegram.2 (578704) TypeError: callback is not a function
            2024-09-26 17:14:30.856  - error: telegram.2 (578704) callback is not a function
            2024-09-26 17:14:30.922  - info: telegram.2 (578704) starting. Version 3.9.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v20.17.0, js-controller: 7.0.0-a        lpha.0-20240926-91f9b082f
            2024-09-26 17:14:31.361  - info: host.iobroker instance system.adapter.alexa2.0 in version "3.26.5" started with pid 578719
            2024-09-26 17:14:31.363  - info: telegram.2 (578704) terminating
            2024-09-26 17:14:31.365  - warn: telegram.2 (578704) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:31.607  - info: host.iobroker instance system.adapter.influxdb.0 in version "4.0.2" started with pid 578726
            2024-09-26 17:14:31.902  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:31.903  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:31.903  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:31.903  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:31.903  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:31.903  - error: host.iobroker instance system.adapter.telegram.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:31.904  - info: host.iobroker Restart adapter system.adapter.telegram.2 because enabled
            2024-09-26 17:14:31.969  - error: alexa2.0 (578719) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catc        h block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:31.970  - error: alexa2.0 (578719) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:31.971  - error: alexa2.0 (578719) TypeError: callback is not a function
            2024-09-26 17:14:31.971  - error: alexa2.0 (578719) callback is not a function
            2024-09-26 17:14:32.221  - error: influxdb.0 (578726) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:32.222  - error: influxdb.0 (578726) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:32.224  - error: influxdb.0 (578726) TypeError: callback is not a function
            2024-09-26 17:14:32.224  - error: influxdb.0 (578726) callback is not a function
            2024-09-26 17:14:32.281  - info: influxdb.0 (578726) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v20.17.0, js-controller: 7.0.0-a        lpha.0-20240926-91f9b082f
            2024-09-26 17:14:32.479  - warn: alexa2.0 (578719) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:33.009  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:33.009  - error: host.iobroker Caught by controller[0]: TypeError: callback is not a function
            2024-09-26 17:14:33.009  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:33.009  - error: host.iobroker instance system.adapter.alexa2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:33.009  - info: host.iobroker Restart adapter system.adapter.alexa2.0 because enabled
            2024-09-26 17:14:33.013  - info: host.iobroker instance system.adapter.telegram.2 in version "3.9.0" started with pid 578749
            2024-09-26 17:14:33.231  - warn: influxdb.0 (578726) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:33.670  - error: telegram.2 (578749) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:33.670  - error: telegram.2 (578749) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:33.672  - error: telegram.2 (578749) TypeError: callback is not a function
            2024-09-26 17:14:33.672  - error: telegram.2 (578749) callback is not a function
            2024-09-26 17:14:33.732  - info: telegram.2 (578749) starting. Version 3.9.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v20.17.0, js-controller: 7.0.0-a        lpha.0-20240926-91f9b082f
            2024-09-26 17:14:33.764  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:33.764  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:33.764  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:33.764  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:33.764  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:33.764  - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:33.764  - info: host.iobroker Restart adapter system.adapter.influxdb.0 because enabled
            2024-09-26 17:14:34.179  - info: telegram.2 (578749) terminating
            2024-09-26 17:14:34.180  - warn: telegram.2 (578749) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:34.704  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:34.704  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:34.704  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:34.704  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:34.704  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:34.705  - error: host.iobroker instance system.adapter.telegram.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:34.705  - info: host.iobroker Restart adapter system.adapter.telegram.2 because enabled
            2024-09-26 17:14:34.705  - warn: host.iobroker Do not restart adapter system.adapter.telegram.2 because restart loop detected
            2024-09-26 17:14:35.358  - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.25" started with pid 578764
            2024-09-26 17:14:35.858  - error: backitup.0 (578764) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:35.858  - error: backitup.0 (578764) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:35.860  - error: backitup.0 (578764) TypeError: callback is not a function
            2024-09-26 17:14:35.860  - error: backitup.0 (578764) callback is not a function
            2024-09-26 17:14:35.921  - info: backitup.0 (578764) starting. Version 3.0.25 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 7.0.0-        alpha.0-20240926-91f9b082f
            2024-09-26 17:14:36.368  - info: backitup.0 (578764) terminating
            2024-09-26 17:14:36.369  - warn: backitup.0 (578764) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:36.892  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:36.892  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:36.892  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:36.892  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:36.892  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:36.892  - error: host.iobroker instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:36.892  - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
            2024-09-26 17:14:39.089  - info: host.iobroker instance system.adapter.pushover.0 in version "4.1.0" started with pid 578779
            2024-09-26 17:14:39.392  - info: host.iobroker instance system.adapter.chromecast.0 in version "3.4.1" started with pid 578790
            2024-09-26 17:14:39.632  - error: pushover.0 (578779) Unhandled promise rejection. This error originated either by throwing inside of an async function without a ca        tch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:39.633  - error: pushover.0 (578779) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:39.634  - error: pushover.0 (578779) TypeError: callback is not a function
            2024-09-26 17:14:39.634  - error: pushover.0 (578779) callback is not a function
            2024-09-26 17:14:39.969  - error: chromecast.0 (578790) Unhandled promise rejection. This error originated either by throwing inside of an async function without a        catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:39.970  - error: chromecast.0 (578790) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:39.972  - error: chromecast.0 (578790) TypeError: callback is not a function
            2024-09-26 17:14:39.972  - error: chromecast.0 (578790) callback is not a function
            2024-09-26 17:14:40.141  - warn: pushover.0 (578779) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:40.664  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:40.664  - error: host.iobroker Caught by controller[0]: TypeError: callback is not a function
            2024-09-26 17:14:40.664  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:40.664  - error: host.iobroker instance system.adapter.pushover.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:40.664  - info: host.iobroker Restart adapter system.adapter.pushover.0 because enabled
            2024-09-26 17:14:41.004  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block,        or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:41.004  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:41.004  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:41.004  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:41.005  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:41.005  - error: host.iobroker instance system.adapter.chromecast.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:41.005  - info: host.iobroker Restart adapter system.adapter.chromecast.0 because enabled
            2024-09-26 17:14:42.995  - info: host.iobroker instance system.adapter.pushover.1 in version "4.1.0" started with pid 578809
            2024-09-26 17:14:43.363  - info: host.iobroker instance system.adapter.cloud.0 in version "5.0.1" started with pid 578820
            2024-09-26 17:14:43.524  - error: pushover.1 (578809) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:43.525  - error: pushover.1 (578809) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:43.528  - error: pushover.1 (578809) TypeError: callback is not a function
            2024-09-26 17:14:43.528  - error: pushover.1 (578809) callback is not a function
            2024-09-26 17:14:43.895  - error: cloud.0 (578820) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:43.896  - error: cloud.0 (578820) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:43.897  - error: cloud.0 (578820) TypeError: callback is not a function
            2024-09-26 17:14:43.897  - error: cloud.0 (578820) callback is not a function
            2024-09-26 17:14:43.949  - info: cloud.0 (578820) starting. Version 5.0.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
            2024-09-26 17:14:44.037  - warn: pushover.1 (578809) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:44.404  - info: cloud.0 (578820) terminating
            2024-09-26 17:14:44.405  - warn: cloud.0 (578820) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:44.562  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:44.562  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:44.562  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:44.562  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:44.562  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:44.562  - error: host.iobroker instance system.adapter.pushover.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:44.563  - info: host.iobroker Restart adapter system.adapter.pushover.1 because enabled
            2024-09-26 17:14:44.929  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:44.929  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:44.929  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:44.929  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:44.929  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:44.929  - error: host.iobroker instance system.adapter.cloud.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:44.929  - info: host.iobroker Restart adapter system.adapter.cloud.0 because enabled
            2024-09-26 17:14:47.024  - info: host.iobroker instance system.adapter.pushover.2 in version "4.1.0" started with pid 578839
            2024-09-26 17:14:47.384  - info: host.iobroker instance system.adapter.device-watcher.0 in version "2.12.1" started with pid 578850
            2024-09-26 17:14:47.561  - error: pushover.2 (578839) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:47.562  - error: pushover.2 (578839) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:47.565  - error: pushover.2 (578839) TypeError: callback is not a function
            2024-09-26 17:14:47.565  - error: pushover.2 (578839) callback is not a function
            2024-09-26 17:14:47.621  - info: pushover.2 (578839) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
            2024-09-26 17:14:47.924  - error: device-watcher.0 (578850) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:47.925  - error: device-watcher.0 (578850) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:47.926  - error: device-watcher.0 (578850) TypeError: callback is not a function
            2024-09-26 17:14:47.927  - error: device-watcher.0 (578850) callback is not a function
            2024-09-26 17:14:47.988  - info: device-watcher.0 (578850) starting. Version 2.12.1 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
            2024-09-26 17:14:48.073  - info: pushover.2 (578839) terminating
            2024-09-26 17:14:48.074  - warn: pushover.2 (578839) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:48.434  - info: device-watcher.0 (578850) terminating
            2024-09-26 17:14:48.435  - warn: device-watcher.0 (578850) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:48.597  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:48.597  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:48.597  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:48.597  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:48.597  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:48.597  - error: host.iobroker instance system.adapter.pushover.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:48.597  - info: host.iobroker Restart adapter system.adapter.pushover.2 because enabled
            2024-09-26 17:14:48.957  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:48.957  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:48.957  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:48.957  - error: host.iobroker instance system.adapter.device-watcher.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:48.957  - info: host.iobroker Restart adapter system.adapter.device-watcher.0 because enabled
            2024-09-26 17:14:51.381  - info: host.iobroker instance scheduled system.adapter.ical.0 0,30 * * * *
            2024-09-26 17:14:51.386  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 578869
            2024-09-26 17:14:51.923  - error: ical.0 (578869) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:51.924  - error: ical.0 (578869) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:51.926  - error: ical.0 (578869) TypeError: callback is not a function
            2024-09-26 17:14:51.926  - error: ical.0 (578869) callback is not a function
            2024-09-26 17:14:52.959  - error: host.iobroker instance system.adapter.ical.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:55.213  - info: host.iobroker instance system.adapter.admin.0 in version "7.1.5" started with pid 578884
            2024-09-26 17:14:55.375  - info: host.iobroker instance scheduled system.adapter.ical.1 0,30 * * * *
            2024-09-26 17:14:55.380  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 578891
            2024-09-26 17:14:55.934  - error: admin.0 (578884) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:55.935  - error: admin.0 (578884) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:55.936  - error: admin.0 (578884) TypeError: callback is not a function
            2024-09-26 17:14:55.936  - error: admin.0 (578884) callback is not a function
            2024-09-26 17:14:55.989  - error: ical.1 (578891) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:55.990  - error: ical.1 (578891) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:55.992  - error: ical.1 (578891) TypeError: callback is not a function
            2024-09-26 17:14:55.993  - error: ical.1 (578891) callback is not a function
            2024-09-26 17:14:56.446  - warn: admin.0 (578884) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:56.970  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:14:56.970  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:14:56.970  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:14:56.970  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:14:56.970  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:14:56.970  - error: host.iobroker instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:56.970  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
            2024-09-26 17:14:56.970  - warn: host.iobroker Do not restart adapter system.adapter.admin.0 because restart loop detected
            2024-09-26 17:14:57.028  - error: host.iobroker instance system.adapter.ical.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:14:58.779  - info: host.iobroker instance system.adapter.email.0 in version "1.3.1" started with pid 578914
            2024-09-26 17:14:59.269  - error: email.0 (578914) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:59.270  - error: email.0 (578914) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:59.271  - error: email.0 (578914) TypeError: callback is not a function
            2024-09-26 17:14:59.272  - error: email.0 (578914) callback is not a function
            2024-09-26 17:14:59.381  - info: host.iobroker instance system.adapter.mqtt.0 in version "6.1.2" started with pid 578929
            2024-09-26 17:14:59.778  - warn: email.0 (578914) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:14:59.899  - error: mqtt.0 (578929) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:14:59.899  - error: mqtt.0 (578929) unhandled promise rejection: callback is not a function
            2024-09-26 17:14:59.901  - error: mqtt.0 (578929) TypeError: callback is not a function
            2024-09-26 17:14:59.901  - error: mqtt.0 (578929) callback is not a function
            2024-09-26 17:15:00.302  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:15:00.302  - error: host.iobroker Caught by controller[0]: TypeError: callback is not a function
            2024-09-26 17:15:00.302  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:15:00.302  - error: host.iobroker Caught by controller[0]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:15:00.302  - error: host.iobroker Caught by controller[0]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:15:00.302  - error: host.iobroker instance system.adapter.email.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:15:00.302  - info: host.iobroker Restart adapter system.adapter.email.0 because enabled
            2024-09-26 17:15:00.302  - warn: host.iobroker Do not restart adapter system.adapter.email.0 because restart loop detected
            2024-09-26 17:15:00.409  - warn: mqtt.0 (578929) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:15:00.931  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:15:00.932  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:15:00.932  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:15:00.932  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:15:00.932  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:15:00.932  - error: host.iobroker instance system.adapter.mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:15:00.932  - info: host.iobroker Restart adapter system.adapter.mqtt.0 because enabled
            2024-09-26 17:15:03.120  - info: host.iobroker instance system.adapter.alexa2.0 in version "3.26.5" started with pid 578946
            2024-09-26 17:15:03.386  - info: host.iobroker instance system.adapter.netatmo.0 in version "3.1.0" started with pid 578953
            2024-09-26 17:15:03.657  - error: alexa2.0 (578946) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:15:03.658  - error: alexa2.0 (578946) unhandled promise rejection: callback is not a function
            2024-09-26 17:15:03.660  - error: alexa2.0 (578946) TypeError: callback is not a function
            2024-09-26 17:15:03.660  - error: alexa2.0 (578946) callback is not a function
            2024-09-26 17:15:03.888  - info: host.iobroker instance system.adapter.influxdb.0 in version "4.0.2" started with pid 578972
            2024-09-26 17:15:04.051  - error: netatmo.0 (578953) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:15:04.052  - error: netatmo.0 (578953) unhandled promise rejection: callback is not a function
            2024-09-26 17:15:04.054  - error: netatmo.0 (578953) TypeError: callback is not a function
            2024-09-26 17:15:04.054  - error: netatmo.0 (578953) callback is not a function
            2024-09-26 17:15:04.166  - warn: alexa2.0 (578946) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:15:04.473  - error: influxdb.0 (578972) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:15:04.474  - error: influxdb.0 (578972) unhandled promise rejection: callback is not a function
            2024-09-26 17:15:04.476  - error: influxdb.0 (578972) TypeError: callback is not a function
            2024-09-26 17:15:04.476  - error: influxdb.0 (578972) callback is not a function
            2024-09-26 17:15:04.526  - info: influxdb.0 (578972) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
            2024-09-26 17:15:04.563  - warn: netatmo.0 (578953) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:15:04.691  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:15:04.692  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:15:04.692  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:15:04.692  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:15:04.692  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:15:04.692  - error: host.iobroker instance system.adapter.alexa2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:15:04.692  - info: host.iobroker Restart adapter system.adapter.alexa2.0 because enabled
            2024-09-26 17:15:05.086  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:15:05.086  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:15:05.086  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:15:05.086  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:15:05.086  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:15:05.086  - error: host.iobroker instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:15:05.086  - info: host.iobroker Restart adapter system.adapter.netatmo.0 because enabled
            2024-09-26 17:15:05.483  - warn: influxdb.0 (578972) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:15:06.006  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:15:06.007  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:15:06.007  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:15:06.007  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:15:06.007  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:15:06.007  - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:15:06.007  - info: host.iobroker Restart adapter system.adapter.influxdb.0 because enabled
            2024-09-26 17:15:06.007  - warn: host.iobroker Do not restart adapter system.adapter.influxdb.0 because restart loop detected
            2024-09-26 17:15:07.023  - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.25" started with pid 578991
            2024-09-26 17:15:07.400  - info: host.iobroker instance system.adapter.notification-manager.0 in version "1.2.1" started with pid 579002
            2024-09-26 17:15:07.572  - error: backitup.0 (578991) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:15:07.573  - error: backitup.0 (578991) unhandled promise rejection: callback is not a function
            2024-09-26 17:15:07.574  - error: backitup.0 (578991) TypeError: callback is not a function
            2024-09-26 17:15:07.574  - error: backitup.0 (578991) callback is not a function
            2024-09-26 17:15:07.642  - info: backitup.0 (578991) starting. Version 3.0.25 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
            2024-09-26 17:15:07.831  - info: notification-manager.0 (579002) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.notification-manager, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
            2024-09-26 17:15:07.839  - info: notification-manager.0 (579002) Starting notification manager ...
            2024-09-26 17:15:07.850  - info: notification-manager.0 (579002) Send notification "system.restartLoop" to "telegram.0"
            2024-09-26 17:15:08.082  - info: backitup.0 (578991) terminating
            2024-09-26 17:15:08.083  - warn: backitup.0 (578991) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:15:08.606  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:15:08.607  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:15:08.607  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:15:08.607  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:15:08.607  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:15:08.607  - error: host.iobroker instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:15:08.607  - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
            2024-09-26 17:15:10.776  - info: host.iobroker instance system.adapter.pushover.0 in version "4.1.0" started with pid 579021
            2024-09-26 17:15:11.128  - info: host.iobroker instance system.adapter.chromecast.0 in version "3.4.1" started with pid 579032
            2024-09-26 17:15:11.378  - error: pushover.0 (579021) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:15:11.379  - error: pushover.0 (579021) unhandled promise rejection: callback is not a function
            2024-09-26 17:15:11.381  - error: pushover.0 (579021) TypeError: callback is not a function
            2024-09-26 17:15:11.381  - error: pushover.0 (579021) callback is not a function
            2024-09-26 17:15:11.400  - info: notification-manager.0 (579002) Send notification "system.restartLoop" to "telegram.0"
            2024-09-26 17:15:11.414  - info: host.iobroker instance system.adapter.nuki.0 in version "2.0.0" started with pid 579039
            2024-09-26 17:15:11.683  - error: chromecast.0 (579032) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-09-26 17:15:11.688  - info: notification-manager.0 (579002) Send notification "system.restartLoop" to "telegram.0"
            2024-09-26 17:15:11.684  - error: chromecast.0 (579032) unhandled promise rejection: callback is not a function
            2024-09-26 17:15:11.685  - error: chromecast.0 (579032) TypeError: callback is not a function
            2024-09-26 17:15:11.685  - error: chromecast.0 (579032) callback is not a function
            2024-09-26 17:15:11.892  - warn: pushover.0 (579021) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-09-26 17:15:11.996  - info: nuki.0 (579039) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.nuki, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
            2024-09-26 17:15:12.416  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:15:12.416  - error: host.iobroker Caught by controller[0]: TypeError: callback is not a function
            2024-09-26 17:15:12.416  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:15:12.416  - error: host.iobroker Caught by controller[0]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:15:12.416  - error: host.iobroker Caught by controller[0]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:15:12.416  - error: host.iobroker instance system.adapter.pushover.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:15:12.417  - info: host.iobroker Restart adapter system.adapter.pushover.0 because enabled
            2024-09-26 17:15:12.417  - warn: host.iobroker Do not restart adapter system.adapter.pushover.0 because restart loop detected
            2024-09-26 17:15:12.420  - info: notification-manager.0 (579002) Send notification "system.restartLoop" to "telegram.0"
            2024-09-26 17:15:12.717  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-09-26 17:15:12.717  - error: host.iobroker Caught by controller[1]: TypeError: callback is not a function
            2024-09-26 17:15:12.717  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
            2024-09-26 17:15:12.717  - error: host.iobroker Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2024-09-26 17:15:12.717  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
            2024-09-26 17:15:12.717  - error: host.iobroker instance system.adapter.chromecast.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-09-26 17:15:12.717  - info: host.iobroker Restart adapter system.adapter.chromecast.0 because enabled
            2024-09-26 17:15:12.853  - error: notification-manager.0 (579002) Error appeared while sending notification "system.restartLoop" to "telegram.0": Timeout exceeded
            2024-09-26 17:15:12.854  - error: notification-manager.0 (579002) Instance telegram.0 could not handle the notification for "system.restartLoop"
            • Rene55
              Rene55 @foxriver76 last edited by
              @foxriver76 Ist das richtig, dass beim Installieren via 'npm i iobroker.js-controller@next --omit=dev' sudo bemüht wird?
              Also installation ok, und Testumgebung läuft.
              S Thomas Braun 2 Replies Last reply Reply Quote 0
                Shadowhunter23 @Rene55 last edited by
                @rene55
                Stimmt war bei mir auch, hab ich vergessen zu erwähnen.
                  Thomas Braun Most Active @Rene55 last edited by Thomas Braun
                  @rene55
                  In dem Fall wird mittels
                  sudo -H -u iobroker
                  nicht in die Rolle des root sondern in das -Homeverzeichnis und in die Rolle des -users 'iobroker' gewechselt. Also alles korrekt.
                  • foxriver76
                    foxriver76 Developer @Shadowhunter23 last edited by foxriver76
                    @shadowhunter23 Könntest du da mal die Ausgabe zeigen von
                    npm ls @iobroker/plugin-sentry
                    und
                    npm ls @iobroker/plugin-base
                    jeweils im Verzeichnis /opt/iobroker ausgeführt
                    Der Fehler deutet stark daraufhin, dass da eine alte Version von @iobroker/plugin-base genutzt wird. Eventuell hat ein Paket diese inkorrekterweise als Dependency konfiguriert was dazu führt das eine falsche Version herangezogen wird.
                    S foxriver76 Thomas Braun 3 Replies Last reply Reply Quote 0
                      Shadowhunter23 @foxriver76 last edited by
                      @foxriver76
                      tobias@iobroker:~$ cd /opt/iobroker/                                                   tobias@iobroker:/opt/iobroker$ npm ls @iobroker/plugin-sentry
                      iobroker.inst@3.0.0 /opt/iobroker
                      +-- iobroker.js-controller@6.0.11
                      | +-- @iobroker/js-controller-adapter@6.0.11
                      | | `-- @iobroker/plugin-sentry@1.2.1 deduped
                      `-- iobroker.wireguard@1.6.4
                      tobias@iobroker:/opt/iobroker$ npm ls @iobroker/plugin-base
                      `-- iobroker.js-controller@6.0.11
                        | `-- @iobroker/plugin-base@1.2.1 deduped
                        +-- @iobroker/plugin-base@1.2.1
                      • foxriver76
                        foxriver76 Developer @foxriver76 last edited by
                        @foxriver76 Danke, der wireguard Adapter scheint der Übeltäter zu sein. Ich probiere das schnell zu fixen!
                          Thomas Braun Most Active @foxriver76 last edited by
                          @foxriver76
                          Hier soweit kein Aufflälligkeiten, System rennt:
                          ===================== ZUSAMMENFASSUNG =====================
                                                  v.2024-09-16
                           Static hostname: chet
                                 Icon name: computer
                          Operating System: Debian GNU/Linux trixie/sid
                                    Kernel: Linux 6.6.47+rpt-rpi-v8
                              Architecture: arm64
                          Installation:           native
                          Kernel:                 aarch64
                          Userland:               64 bit
                          Timezone:               Europe/Berlin (CEST, +0200)
                          User-ID:                1000
                          Display-Server:         false
                          Boot Target:            multi-user.target
                          Offene OS-Updates:      0
                          Offene iob updates:     0
                          Nodejs-Installation:
                          /usr/bin/nodejs         v22.9.0
                          /usr/bin/node           v22.9.0
                          /usr/bin/npm            10.8.3
                          /usr/bin/npx            10.8.3
                          /usr/bin/corepack       0.29.3
                          Empfohlene Versionen sind zurzeit nodejs 20.17.0 und npm 10.8.2
                          nodeJS ist korrekt installiert
                          MEMORY:
                          Mem:            8.2G        2.9G        1.2G        876K        4.2G        5.2G
                          Swap:           2.4G          0B        2.4G
                          Total:           10G        2.9G        3.6G
                          Active iob-Instances:   38
                          Upgrade policy: none
                          ioBroker Core:          js-controller           7.0.0-alpha.0-20240926-91f9b082f
                                                  admin                   7.1.5
                          Objects type: jsonl
                          States  type: jsonl
                          + system.adapter.admin.0                  : admin                 : chet                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.web.0                    : web                   : chet                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          Objects:                11221
                          States:                 8962
                          Size of iob-Database:
                          28M     /opt/iobroker/iobroker-data/objects.jsonl
                          4.9M    /opt/iobroker/iobroker-data/states.jsonl
                          Das Betriebssystem mit dem Codenamen 'trixie' ist eine Testversion! Es sollte nur zu Testzwecken eingesetzt werden!
                          =================== ENDE DER ZUSAMMENFASSUNG ====================
                            @foxriver76
                            Kein Stress, ich hab keine Eile!
                              peterfido last edited by
                              @foxriver76
                              Wenn ich Node-Red öffnen möchte, erscheint die falsche URL im Browser.
                              httpundefined://192.168.2.230:1880/
                              • foxriver76
                                foxriver76 Developer @peterfido last edited by
                                @peterfido sicher dass das mit Controller 6 nicht so war? Ich denke das ist eher Admin oder Adapter
                                P Negalein mcm1957 3 Replies Last reply Reply Quote 0
                                  @foxriver76 Ich habe für den Test 7.0.0.0 eine neue VM erstellt. Im Produktivsystem passt der rot eingekreiste Link,
                                    peterfido @foxriver76 last edited by peterfido
                                    @foxriver76
                                    Ich habe noch ein Testsystem (6.0.11), welches ich für das Proxmox-Speicher-Problem angelegt habe. Da habe ich mal eben Node-Red installiert und der Fehler tritt auch da auf.
                                    Also wohl ein Problem von Node-Red. Ich habe mal ein Issue geöffnet.
                                    • Negalein
                                      Negalein Global Moderator @foxriver76 last edited by
                                      @foxriver76 sagte in js-controller Lucy (v7.0.0) Alpha Test:
                                      Hat nichts mit Controller zu tun. Gibt es schon länger.
                                      • Armilar
                                        Armilar Most Active Forum Testing @foxriver76 last edited by
                                        @foxriver76
                                        Läuft bei mir ebenfalls - ohne Probleme
                                        • Feuersturm
                                          Feuersturm @foxriver76 last edited by
                                          @foxriver76 Upgrade von js-controller 6 auf 7 lief auf meinem Testsystem ohne Probleme 👏
                                          iob diag vom aktualisierten Testsystem
                                          Skript v.2024-08-12
                                          *** BASE SYSTEM ***
                                           Static hostname: ioB-Prod-Testsystem
                                                 Icon name: computer-container
                                                   Chassis: container
                                            Virtualization: lxc
                                          Operating System: Ubuntu 22.04.5 LTS
                                                    Kernel: Linux 6.5.13-1-pve
                                              Architecture: x86-64
                                          OS is similar to: debian
                                          model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
                                          Docker          : false
                                          Virtualization  : lxc
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          Systemuptime and Load:
                                           20:42:28 up 55 days,  6:44,  2 users,  load average: 2.94, 2.82, 3.09
                                          CPU threads: 4
                                          *** Time and Time Zones ***
                                                         Local time: Fri 2024-09-27 20:42:28 CEST
                                                     Universal time: Fri 2024-09-27 18:42:28 UTC
                                                           RTC time: n/a
                                                        NTP service: inactive
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          proxmox
                                          HOME=/home/proxmox
                                          GROUPS=proxmox sudo iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          GROUPS=iobroker tty dialout audio video plugdev
                                          *** Display-Server-Setup ***
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            8.0G        2.3G        2.6G        0.0K        3.1G        5.7G
                                          Swap:           2.0G         38M        2.0G
                                          Total:           10G        2.3G        4.6G
                                          Active iob-Instances:   31
                                                   8000 M total memory
                                                   2303 M used memory
                                                   2091 M active memory
                                                   2891 M inactive memory
                                                   2638 M free memory
                                                      0 M buffer memory
                                                   3058 M swap cache
                                                   2048 M total swap
                                                     38 M used swap
                                                   2009 M free swap
                                          top - 20:42:28 up 55 days,  6:44,  2 users,  load average: 3.43, 2.93, 3.12
                                          Tasks:  69 total,   3 running,  66 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 11.8 us, 27.9 sy,  0.0 ni, 60.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   8000.0 total,   2638.3 free,   2303.0 used,   3058.8 buff/cache
                                          MiB Swap:   2048.0 total,   2009.2 free,     38.8 used.   5697.0 avail Mem
                                          *** FAILED SERVICES ***
                                            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                                          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                                          LOAD   = Reflects whether the unit definition was properly loaded.
                                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                          SUB    = The low-level unit activation state, values depend on unit type.
                                          1 loaded units listed.
                                          *** FILESYSTEM ***
                                          Filesystem                          Type      Size  Used Avail Use% Mounted on
                                          /dev/mapper/data2-vm--6000--disk--0 ext4       40G   28G  9.4G  75% /
                                          none                                tmpfs     492K  4.0K  488K   1% /dev
                                          efivarfs                            efivarfs  128K   65K   59K  53% /sys/firmware/efi/efivars
                                          tmpfs                               tmpfs     7.7G     0  7.7G   0% /dev/shm
                                          tmpfs                               tmpfs     3.1G  172K  3.1G   1% /run
                                          tmpfs                               tmpfs     5.0M     0  5.0M   0% /run/lock
                                          tmpfs                               tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
                                          tmpfs                               tmpfs     1.6G     0  1.6G   0% /run/user/1001
                                          dmesg: read kernel buffer failed: Operation not permitted
                                          Show mounted filesystems:
                                          TARGET SOURCE                              FSTYPE OPTIONS
                                          /      /dev/mapper/data2-vm--6000--disk--0 ext4   rw,relatime,stripe=16
                                          /var:
                                          3.6G    /var/
                                          2.9G    /var/log/journal
                                          2.9G    /var/log
                                          2.6G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
                                          440M    /var/lib
                                          Archived and active journals take up 40.0M in the file system.
                                          /opt/iobroker/backups:
                                          2.9G    /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          2.9G    /opt/iobroker/iobroker-data/
                                          1.8G    /opt/iobroker/iobroker-data/files
                                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                          575M    /opt/iobroker/iobroker-data/sonosCache
                                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                          38M     /opt/iobroker/iobroker-data/objects.jsonl
                                          37M     /opt/iobroker/iobroker-data/files/radar-trap.admin/build/index.js.map
                                          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v20.17.0
                                          /usr/bin/node           v20.17.0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Installed: 20.17.0-1nodesource1
                                            Candidate: 20.17.0-1nodesource1
                                            Version table:
                                           *** 20.17.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                                  100 /var/lib/dpkg/status
                                               20.16.0-1nodesource1 1001
                                               20.15.1-1nodesource1 1001
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                               12.22.9~dfsg-1ubuntu3.6 500
                                                  500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                                  500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                                               12.22.9~dfsg-1ubuntu3 500
                                                  500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          admin:          7.1.5
                                          javascript:     8.8.3
                                          nodejs modules from github:     1
                                          | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : ioB-Prod-Testsystem                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.backitup.0               : backitup              : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.daswetter.0              : daswetter             : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.devices.0                : devices               : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.dwd.0                    : dwd                   : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.echarts.0                : echarts               : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.esphome.0                : esphome               : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.fritzbox.0               : fritzbox              : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.fullcalendar.0           : fullcalendar          : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : ioB-Prod-Testsystem                      -  enabled, port: 0
                                          + system.adapter.hm-rpc.1                 : hm-rpc                : ioB-Prod-Testsystem                      -  enabled, port: 0
                                          + system.adapter.hue.0                    : hue                   : ioB-Prod-Testsystem                      -  enabled, port: 443
                                            system.adapter.ical.0                   : ical                  : ioB-Prod-Testsystem                      - disabled
                                            system.adapter.ical.1                   : ical                  : ioB-Prod-Testsystem                      - disabled
                                            system.adapter.ical.2                   : ical                  : ioB-Prod-Testsystem                      - disabled
                                            system.adapter.ical.3                   : ical                  : ioB-Prod-Testsystem                      - disabled
                                            system.adapter.ical.4                   : ical                  : ioB-Prod-Testsystem                      - disabled
                                            system.adapter.ical.5                   : ical                  : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.icons-material-png.0     : icons-material-png    : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.influxdb.0               : influxdb              : ioB-Prod-Testsystem                      - disabled, port: 8086
                                            system.adapter.influxdb.1               : influxdb              : ioB-Prod-Testsystem                      - disabled, port: 8086
                                          + system.adapter.javascript.0             : javascript            : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.mqtt.0                   : mqtt                  : ioB-Prod-Testsystem                      - disabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.nina.0                   : nina                  : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.notification-manager.0   : notification-manager  : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.openweathermap.0         : openweathermap        : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.proxmox.0                : proxmox               : ioB-Prod-Testsystem                      -  enabled, port: 8006
                                          + system.adapter.radar-trap.0             : radar-trap            : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.rainbird.0               : rainbird              : ioB-Prod-Testsystem                      - disabled
                                          + system.adapter.samsung.0                : samsung               : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.scenes.0                 : scenes                : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.scheduler.0              : scheduler             : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.seq.0                    : seq                   : ioB-Prod-Testsystem                      - disabled, port: 5341
                                            system.adapter.shuttercontrol.0         : shuttercontrol        : ioB-Prod-Testsystem                      - disabled
                                          + system.adapter.simple-api.0             : simple-api            : ioB-Prod-Testsystem                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            system.adapter.socketio.0               : socketio              : ioB-Prod-Testsystem                      - disabled, port: 8084, bind: 192.168.178.54, run as: admin
                                          + system.adapter.sonos.0                  : sonos                 : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.spotify-premium.0        : spotify-premium       : ioB-Prod-Testsystem                      - disabled
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.telegram.0               : telegram              : ioB-Prod-Testsystem                      - disabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.tr-064.0                 : tr-064                : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.unifi.0                  : unifi                 : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.valloxmv.0               : valloxmv              : ioB-Prod-Testsystem                      - disabled, port: 80
                                            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.vis-2.0                  : vis-2                 : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-history.0            : vis-history           : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-justgage.0           : vis-justgage          : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-map.0                : vis-map               : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-metro.0              : vis-metro             : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioB-Prod-Testsystem                      -  enabled
                                            system.adapter.vis.0                    : vis                   : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.web.0                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8082, bind: 192.168.178.105, run as: admin
                                          + system.adapter.web.1                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                                          + system.adapter.worx.0                   : worx                  : ioB-Prod-Testsystem                      -  enabled
                                          + system.adapter.ws.0                     : ws                    : ioB-Prod-Testsystem                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): beta
                                          Installed ioBroker-Instances
                                          Used repository: beta
                                          Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                          Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                                          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                          Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
                                          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                                          Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
                                          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                          Adapter    "hue"          : 3.12.0   , installed 3.12.0
                                          Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                          Controller "js-controller": 6.0.11   , installed 7.0.0
                                          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                          Adapter    "nina"         : 0.0.26   , installed 0.0.26
                                          Adapter    "notification-manager": 1.2.1, installed 1.2.1
                                          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                                          Adapter    "radar-trap"   : 2.2.2    , installed 2.2.2
                                          Adapter    "rainbird"     : 1.0.1    , installed 1.0.1
                                          Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                          Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
                                          Adapter    "seq"          : 0.3.0    , installed 0.3.0
                                          Adapter    "shuttercontrol": 1.8.2   , installed 1.8.2
                                          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                                          Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
                                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                          Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
                                          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                                          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                                          Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                                          Adapter    "vis-2-widgets-jaeger-design": 1.3.1, installed 1.3.1
                                          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                          Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
                                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                                          Adapter    "web"          : 6.3.1    , installed 6.3.1
                                          Adapter    "worx"         : 3.1.0    , installed 3.1.0
                                          Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                          Objects and States
                                          Objects:        14704
                                          States:         12204
                                          Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
                                          Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                                          Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                                          Hit:4 https://apt.grafana.com stable InRelease
                                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          68633192   140/node
                                          tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       443174019  198874/python3
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       443154700  198216/iobroker.js-
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       443154198  198216/iobroker.js-
                                          tcp        0      0 192.168.178.105:8082    0.0.0.0:*               LISTEN      1000       443168107  198572/io.web.0
                                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          68635751   338/master
                                          tcp        0      0 192.168.178.105:2010    0.0.0.0:*               LISTEN      1000       443157045  198337/io.hm-rpc.0
                                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          68631545   1/init
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          68633957   156/sshd: /usr/sbin
                                          tcp        0      0 192.168.178.105:9292    0.0.0.0:*               LISTEN      1000       443161197  198470/io.hm-rpc.1
                                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        68632546   109/systemd-resolve
                                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          68635752   338/master
                                          tcp6       0      0 :::8089                 :::*                    LISTEN      1000       443171384  198744/io.web.1
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       443156586  198252/io.admin.0
                                          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       443170086  198673/io.simple-ap
                                          tcp6       0      0 :::8084                 :::*                    LISTEN      1000       443171328  198710/io.ws.0
                                          tcp6       0      0 :::111                  :::*                    LISTEN      0          68631547   1/init
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          68633959   156/sshd: /usr/sbin
                                          tcp6       0      0 :::3040                 :::*                    LISTEN      1000       443171930  198814/io.radar-tra
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      108        442967241  196375/grafana
                                          tcp6       0      0 :::3500                 :::*                    LISTEN      0          68633200   140/node
                                          tcp6       0      0 :::3501                 :::*                    LISTEN      1000       443162816  198489/io.sonos.0
                                          udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       443174031  198874/python3
                                          udp        0      0 192.168.178.105:5353    0.0.0.0:*                           1000       443174030  198874/python3
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       443174026  198874/python3
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       443170615  198699/io.esphome.0
                                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        68632545   109/systemd-resolve
                                          udp        0      0 192.168.178.105:68      0.0.0.0:*                           101        441373288  88/systemd-networkd
                                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          68631546   1/init
                                          udp6       0      0 :::111                  :::*                                0          68631548   1/init
                                            darkiop Most Active last edited by
                                            Guten Morgen, bisher keine Auffälligkeiten auf dem Testsystem. Installation lief unauffällig durch.
                                            Grüße und ein schönes Wochenende!
                                            alpha js-controller lucy tester
                                            14
                                            35
                                            4876
