    4. Zigbee iobroker Error while opening serialport
      searcher57 @searcher57 last edited by
      @searcher57 said in Zigbee iobroker Error while opening serialport:
      00124b002e20c60a
      Soll ich 00124b002e20c60a in die Erweiterte Pan ID eintragen? Das hilft jedoch nicht.
        Thomas Braun Most Active @searcher57 last edited by
        @searcher57
        Möglicherweise musst du die Byte-Reihenfolge ändern. Vesuch mal
        0ac6202e004b1200
          searcher57 @Thomas Braun last edited by
          @thomas-braun said in Zigbee iobroker Error while opening serialport:
          0ac6202e004b1200
          Ist das nicht zum verzweifeln?
          Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
            @searcher57 sagte in Zigbee iobroker Error while opening serialport:
            Keine Ahnung. Im log steht bestimmt mehr als auf dem Screenshot.
              Entschuldige!
              zigbee.0
              	2024-09-26 17:32:58.453	error	Error herdsman start
              zigbee.0
              	2024-09-26 17:32:58.452	error	Failed to start Zigbee
              zigbee.0
              	2024-09-26 17:32:58.452	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
              zigbee.0
              	2024-09-26 17:32:58.392	info	Installed Version: iobroker.zigbee@1.10.3
              zigbee.0
              	2024-09-26 17:32:58.388	info	Starting Zigbee npm ...
              zigbee.0
              	2024-09-26 17:32:58.387	info	Try to reconnect. 1 attempts left
              zigbee.0
              	2024-09-26 17:32:48.386	error	Error herdsman start
              zigbee.0
              	2024-09-26 17:32:48.386	error	Failed to start Zigbee
              zigbee.0
              	2024-09-26 17:32:48.385	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
              zigbee.0
              	2024-09-26 17:32:47.998	info	Installed Version: iobroker.zigbee@1.10.3
              zigbee.0
              	2024-09-26 17:32:47.875	info	Starting Zigbee npm ...
              zigbee.0
              	2024-09-26 17:32:47.874	info	delete old Backup files. keep only last 10
              zigbee.0
              	2024-09-26 17:32:47.844	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
              zigbee.0
              	2024-09-26 17:32:15.117	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              zigbee.0
              	2024-09-26 17:32:15.115	error	zigbee.0 already running
              zigbee.0
              	2024-09-26 17:32:13.957	info	terminating
              zigbee.0
              	2024-09-26 17:32:13.589	info	debug devices set to []
              zigbee.0
              	2024-09-26 17:32:13.576	warn	Got terminate signal. Checking desired PID: 6063 vs own PID 5908
              zigbee.0
              	2024-09-26 17:32:13.561	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              zigbee.0
              	2024-09-26 17:32:13.561	info	terminating
              zigbee.0
              	2024-09-26 17:32:13.556	warn	Failed to stop zigbee during startup
              zigbee.0
              	2024-09-26 17:32:13.462	info	Zigbee: disabling joining new devices.
              zigbee.0
              	2024-09-26 17:32:13.455	info	cleaned everything up...
              zigbee.0
              	2024-09-26 17:32:13.453	warn	Got terminate signal. Checking desired PID: 0 vs own PID 5908
              zigbee.0
              	2024-09-26 17:28:00.952	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"0867d5d6b78ded11959b02f6b86ce6f8","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA10"}]
              zigbee.0
              	2024-09-26 17:28:00.882	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              zigbee.0
              	2024-09-26 17:27:02.232	error	Error herdsman start
              zigbee.0
              	2024-09-26 17:27:02.231	error	Failed to start Zigbee
              zigbee.0
              	2024-09-26 17:27:02.231	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
              zigbee.0
              	2024-09-26 17:27:02.174	info	Installed Version: iobroker.zigbee@1.10.3
              zigbee.0
              	2024-09-26 17:27:02.169	info	Starting Zigbee npm ...
              zigbee.0
              	2024-09-26 17:27:02.168	info	Try to reconnect. 1 attempts left
              zigbee.0
              	2024-09-26 17:26:52.167	error	Error herdsman start
              zigbee.0
              	2024-09-26 17:26:52.167	error	Failed to start Zigbee
              zigbee.0
              	2024-09-26 17:26:52.166	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
              zigbee.0
              	2024-09-26 17:26:51.790	info	Installed Version: iobroker.zigbee@1.10.3
              • Asgothian
                Asgothian Developer @searcher57 last edited by
                0ac6202e004b1200
                Frage: Hast du den Adapter händisch angehalten, 30 Sekunden gewartet, und dann wieder händisch gestartet, oder hast du bei laufendem Adapter die Datei geändert und dann auf "restart" gedrückt ?
                Der korrekte weg ist:
                • Adapter anhalten
                • Konfiguration starten, editieren, abspeichern
                • Adapter starten.
                die vom Adapter benötigten Bibliotheken brauchen teilweise etwas Zeit bis sie alle Ressourcen freigegeben haben. Mit einem einfachen "Restart" sind die dann oft noch blockiert.
                Ansonsten gilt das was @Thomas-Braun geschrieben hat - logs sagen 100%ig mehr als screenshots.
                Wichtig ist dabei auch die kompletten Logs zu posten - nicht nur die Fehlermeldungen und alles ab dem Start-Befehl aus dem Admin
                Die Log-Zeile mit der das anfängt sollte in Etwa so aussehen:
                2024-09-26 17:30:14.207  - info: zigbee.0 (4079) starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee#axiosTest) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.19
                A.
                  searcher57 @Asgothian last edited by
                  @asgothian said in Zigbee iobroker Error while opening serialport:
                  0ac6202e004b1200
                  • Adapter anhalten
                  • Adapter starten.
                  A.
                  Ok, wieder etwas dazu gelernt. Wo soll ich denn nochmal von vorn anfangen?
                    0ac6202e004b1200
                    • Adapter anhalten
                    • Adapter starten.
                    A.
                    Brauchst Du das?
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    	2024-09-26 17:26:51.667	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 17:26:51.667	info	delete old Backup files. keep only last 10
                    zigbee.0
                    	2024-09-26 17:26:51.637	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                    zigbee.0
                    	2024-09-26 17:26:45.914	info	terminating
                    zigbee.0
                    	2024-09-26 17:26:45.484	info	debug devices set to []
                    zigbee.0
                    	2024-09-26 17:26:45.473	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    	2024-09-26 17:26:45.472	info	terminating
                    zigbee.0
                    	2024-09-26 17:26:45.472	warn	Failed to stop zigbee during startup
                    zigbee.0
                    	2024-09-26 17:26:45.418	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    	2024-09-26 17:26:45.413	info	cleaned everything up...
                    zigbee.0
                    	2024-09-26 17:26:45.412	info	Got terminate signal TERMINATE_YOURSELF
                    zigbee.0
                    	2024-09-26 17:26:10.119	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"0867d5d6b78ded11959b02f6b86ce6f8","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA10"}]
                    zigbee.0
                    	2024-09-26 17:26:10.041	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                    zigbee.0
                    	2024-09-26 17:21:13.680	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 17:21:13.680	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 17:21:13.680	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                    zigbee.0
                    	2024-09-26 17:21:13.600	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 17:21:13.594	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 17:21:13.593	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    	2024-09-26 17:21:03.591	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 17:21:03.591	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 17:21:03.590	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0
                    	2024-09-26 17:21:03.206	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 17:21:03.078	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 17:21:03.077	info	delete old Backup files. keep only last 10
                    zigbee.0
                    	2024-09-26 17:21:03.045	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                    zigbee.0
                    	2024-09-26 17:20:30.245	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    zigbee.0
                    	2024-09-26 17:20:30.243	error	zigbee.0 already running
                    zigbee.0
                    	2024-09-26 17:20:29.104	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    	2024-09-26 17:20:29.103	info	terminating
                    zigbee.0
                    	2024-09-26 17:20:28.652	info	debug devices set to []
                    zigbee.0
                    	2024-09-26 17:20:28.649	warn	Got terminate signal. Checking desired PID: 5690 vs own PID 5674
                    zigbee.0
                    	2024-09-26 17:20:28.608	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    	2024-09-26 17:20:28.602	info	cleaned everything up...
                    zigbee.0
                    	2024-09-26 17:20:28.601	warn	Got terminate signal. Checking desired PID: 0 vs own PID 5674
                    zigbee.0
                    	2024-09-26 17:20:24.262	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 17:20:24.262	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 17:20:24.261	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0
                    	2024-09-26 17:20:23.875	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 17:20:23.748	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 17:20:23.747	info	delete old Backup files. keep only last 10
                    zigbee.0
                    	2024-09-26 17:20:23.717	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                    zigbee.0
                    	2024-09-26 17:20:17.955	info	terminating
                    zigbee.0
                    	2024-09-26 17:20:17.541	info	debug devices set to []
                    zigbee.0
                    	2024-09-26 17:20:17.528	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    	2024-09-26 17:20:17.527	info	terminating
                    zigbee.0
                    	2024-09-26 17:20:17.527	warn	Failed to stop zigbee during startup
                    zigbee.0
                    	2024-09-26 17:20:17.461	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    	2024-09-26 17:20:17.454	info	cleaned everything up...
                    zigbee.0
                    	2024-09-26 17:20:17.453	info	Got terminate signal TERMINATE_YOURSELF
                    zigbee.0
                    	2024-09-26 17:20:01.391	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"0867d5d6b78ded11959b02f6b86ce6f8","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA10"}]
                    zigbee.0
                    	2024-09-26 17:20:01.334	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                    zigbee.0
                    	2024-09-26 16:58:32.576	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 16:58:32.576	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 16:58:32.575	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                    zigbee.0
                    	2024-09-26 16:58:32.518	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 16:58:32.513	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 16:58:32.512	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    	2024-09-26 16:58:22.510	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 16:58:22.510	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 16:58:22.509	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0
                    	2024-09-26 16:58:22.127	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 16:58:22.002	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 16:58:22.001	info	delete old Backup files. keep only last 10
                    zigbee.0
                    	2024-09-26 16:58:21.967	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                    zigbee.0
                    	2024-09-26 16:57:49.189	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    zigbee.0
                    	2024-09-26 16:57:49.188	error	zigbee.0 already running
                    zigbee.0
                    	2024-09-26 16:57:48.104	info	terminating
                    zigbee.0
                    	2024-09-26 16:57:47.674	info	debug devices set to []
                    zigbee.0
                    	2024-09-26 16:57:47.671	warn	Got terminate signal. Checking desired PID: 5034 vs own PID 4605
                    zigbee.0
                    	2024-09-26 16:57:47.663	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    	2024-09-26 16:57:47.662	info	terminating
                    zigbee.0
                    	2024-09-26 16:57:47.662	warn	Failed to stop zigbee during startup
                    zigbee.0
                    	2024-09-26 16:57:47.608	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    	2024-09-26 16:57:47.602	info	cleaned everything up...
                    zigbee.0
                    	2024-09-26 16:57:47.601	warn	Got terminate signal. Checking desired PID: 0 vs own PID 4605
                    zigbee.0
                    	2024-09-26 16:43:06.720	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 16:43:06.720	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 16:43:06.719	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                    zigbee.0
                    	2024-09-26 16:43:06.638	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 16:43:06.632	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 16:43:06.631	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    	2024-09-26 16:42:56.629	error	Error herdsman start
                    zigbee.0
                    	2024-09-26 16:42:56.629	error	Failed to start Zigbee
                    zigbee.0
                    	2024-09-26 16:42:56.628	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                    zigbee.0
                    	2024-09-26 16:42:56.246	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    	2024-09-26 16:42:56.122	info	Starting Zigbee npm ...
                    zigbee.0
                    	2024-09-26 16:42:56.121	info	delete old Backup files. keep only last 10
                    zigbee.0
                    	2024-09-26 16:42:56.091	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.17.0, js-controller: 6.0.11
                    zigbee.0
                    	2024-09-26 16:42:50.336	info	terminating
                    zigbee.0
                    	2024-09-26 16:42:49.934	info	debug devices set to []
                    zigbee.0
                    	2024-09-26 16:42:49.910	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    	2024-09-26 16:42:49.909	info	terminating
                    zigbee.0
                    	2024-09-26 16:42:49.901	warn	Failed to stop zigbee during startup
                    zigbee.0
                    	2024-09-26 16:42:49.840	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    	2024-09-26 16:42:49.835	info	cleaned everything up...
                    zigbee.0
                    	2024-09-26 16:42:49.833	info	Got terminate signal TERMINATE_YOURSELF
                    zigbee.0
                    	2024-09-26 16:41:14.368	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"0867d5d6b78ded11959b02f6b86ce6f8","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA10"}]
                    zigbee.0
                    	2024-09-26 16:41:14.304	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                    zigbee.0
                    	2024-09-26 16:32:55.296	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"0867d5d6b78ded11959b02f6b86ce6f8","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA10"}]
                    zigbee.0
                    	2024-09-26 16:32:55.199	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                    zigbee.0
                    	2024-09-26 15:53:31.660	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"0867d5d6b78ded11959b02f6b86ce6f8","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA10"}]
                    zigbee.0
                    	2024-09-26 15:53:31.587	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                    • Asgothian
                      @searcher57 Solange wie du keine wichtigen Daten selber aus den Logs parsed hat sich bei mir der Folgende Weg als der einfachste ergeben:
                      • zigbee Adapter anhalten
                      • log löschen
                      • zigbee Adapter starten
                      • 30 Sekunden warten ob er grün wird, wenn nicht: Zigbee Adapter anhalten.
                      Ansonsten besteht die Konfiguration aus 4 Bestandteilen:
                      • PanID
                      • ExtPanID
                      • Kanal
                      • Transportschlüssel
                      Alle 4 stehen auch im nvbackup.json. Bitte manuell vergleichen:
                      "coordinator_ieee": "xxxxxxxxxxxxxxxx",
                      "pan_id": "xxxx",
                      "extended_pan_id": "xxxxxxxxxxxxxxxx",
                      "nwk_update_id": 0,
                      "security_level": 5,
                      "channel": xx,
                      "channel_mask": [
                        11
                      "network_key": {
                        "key": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                        "sequence_number": 0,
                        "frame_counter": 75301977
                      jeweils die mit X'en ausgex'ten Werte sind die die du vergleichen musst.
                      Wichtig dabei:
                      • pan_id ist in hex, die musst du in dezimal umrechnen um sie zu vergleichen / einzutragen
                      • Anpassen der nvbackup.json ist nicht unterstützt, du musst die Konfiguration deines Adapters anpassen.
                      A.
                        Wichtig dabei:
                        Wichtig dabei:
                        Sorry, aber das übersteigt meine Fähigkeiten. Die Ausgabe von den Daten habe ich oben angegeben.
                        • Asgothian
                          @searcher57 aber deine Konfiguration nicht.
                          Lt. nvbackup.json ist deine PanID 025a (das sind 602 dezimal)
                          alles andere kannst du 1:1 vergleichen
                          A.
                          S 3 Replies Last reply Reply Quote 0
                            A.
                            Das mit der PanID habe ich geändert, alles andere bekomme ich nicht hin.
                              A.
                              Hei!!! Deine Antwort hat zum Erfolg geführt!
                              Alles wieder vorhanden, incl. der Aktoren. Vielen Dank!👍 🙏 Kaum macht man es richig, schon funktioniert's!
                                A.
                                Jetzt aber noch folgendes Problem:
                                Wie verbinde ich die Aktoren?
                                S arteck 2 Replies Last reply Reply Quote 0
                                  A.
                                  Nachdem ich den Schaltaktor und den 4-fach Taster gelöscht habe, bekomme ich sie nicht mehr gekoppelt. Was mache ich falsch?
                                    A.
                                    In der Konsole erscheinen die Aktoren noch:
                                    pi@Raspi58GB:/opt/iobroker/iobroker-data/zigbee_0 $ ls -la        insgesamt 64
                                    drwxrwxr-x+ 2 iobroker iobroker 4096 26. Sep 20:35 .
                                    drwxrwxr-x+ 9 iobroker iobroker 4096 26. Sep 20:21 ..
                                    -rw-rw-r--+ 1 iobroker iobroker 1511 26. Sep 16:58 backup_2024_09_26-16_58_21.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 1511 26. Sep 17:20 backup_2024_09_26-17_20_23.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 1511 26. Sep 17:21 backup_2024_09_26-17_21_03.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 1511 26. Sep 17:26 backup_2024_09_26-17_26_51.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 1514 26. Sep 17:32 backup_2024_09_26-17_32_47.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 1511 26. Sep 19:32 backup_2024_09_26-19_32_52.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 1511 26. Sep 19:33 backup_2024_09_26-19_33_34.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker  885 26. Sep 20:14 backup_2024_09_26-20_14_14.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker  885 26. Sep 20:20 backup_2024_09_26-20_20_27.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker  885 26. Sep 20:28 backup_2024_09_26-20_28_45.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker  883 26. Sep 20:35 backup_2024_09_26-20_35_22.tar.gz
                                    -rw-rw-r--+ 1 iobroker iobroker   89 18. Sep 13:23 dev_names.json
                                    -rw-rw-r--+ 1 iobroker iobroker  768 18. Sep 13:23 nvbackup.json
                                    -rw-rw-r--+ 1 iobroker iobroker 2174 26. Sep 20:34 shepherd.db
                                    pi@Raspi58GB:/opt/iobroker/iobroker-data/zigbee_0 $ cat dev_names.json
                                      "f4b3b1fffeecb217": "4fach Taster",
                                      "70b3d52b600aa8c2": "Schreibtisch Steckdosen"
                                    }pi@Raspi58GB:/opt/iobroker/iobroker-data/zigbee_0 $
                                      Dolphn last edited by Dolphn
                                      Ich kann leider nicht direkt helfen, aber ich hatte das Problem ohne absichtliche Änderung (soweit ich weiß, nur Adapterupdates...) auch und habe lange gebraucht, bis ich Zigbee wieder drin hatte. Für alle, die ähnlich auf dem Schlauch stehen, vielleicht folgende Tipps:
                                      • Checkt die Ports durch und ggf. die Spannungsversorgung des Geräts. Mit sudo dmesg | grep tty lässt sich das in der Tat (mithilfe von ChatGPT) etwas auskundschaften
                                      • Probiert, sowohl das System, als auch die Treiber zu updaten. Bei mir hat unter Linux das schließlich zum Ziel geführt:
                                      $sudo rmmod cp210x
                                      $sudo modprobe cp210x
                                      Gerne mal Feedback geben.
                                        arteck Developer Most Active @searcher57 last edited by
                                        @searcher57 garnicht.. die verbinden sich selbst.. ist aber auch egal die Karte ist nur gimmick
                                        du bist zu hecktisch.. da komm ich nicht mit..
                                        also was jetzt.. geht koppeln oder nicht.. wenn nicht..
                                        adapter stop
                                        stick raus.....wartenbis 10 zählen
                                        stick wieder rein
                                        adapter start....warten......
                                        nochmal probieren
                                          searcher57 @arteck last edited by
                                          @arteck said in Zigbee iobroker Error while opening serialport:
                                          adapter stop
                                          stick wieder rein
                                          nochmal probieren
                                          du bist zu hecktisch.. da komm ich nicht mit.. ja, das ist einer meiner vielen schlechten Eigenschaften.
                                          Also es funktioniert auch beim 2. Versuch nach Deiner Anweisung nicht. Es ist lediglich noch der Stick zu erkennen, aber keine Geräte. Wie o.g. erscheinen sie aber in der Konsole. Soll ich das Verzeichnis "nvbackup.json" mal löschen? Oder hast Du einen anderen Vorschlag?
                                          S Asgothian 2 Replies Last reply Reply Quote 0
                                            searcher57 @Dolphn last edited by
                                            @dolphn said in Zigbee iobroker Error while opening serialport:
                                            $sudo rmmod cp210x
                                            Danke für Deine Hile! Aber das hat bei mir nichts gebracht.
                                            VG Rainer
                                            231
                                            42330
