    4. Heidelberg Wallbox Energy Control und wbec
      Thomas Braun Most Active @daddy last edited by
      @daddy sagte in Heidelberg Wallbox Energy Control und wbec:
      Oder kann man das "reparieren"?
      Wie kommt man eigentlich auf die Idee nodejs per nvm zu 'installieren?
      rm -rf /home/dieter/.config/nvm/
      Lass die Finger von 'nvm', 'n' oder irgendwelchen anderen Tools, die am Paketmanager vorbei agieren.
        @daddy
        Zeig mal die Langfassung von
        iob diag
        Meist ist dann da noch mehr krumm.
        D 3 Replies Last reply Reply Quote 0
          daddy @Thomas Braun last edited by
          Moment, mache das von Windows aus über die Konsole.
            Skript v.2024-05-22
            *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.19-v8+
                  Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             22:33:54 up 41 min,  3 users,  load average: 1.26, 1.73, 1.54
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            ~ Under-voltage has occurred
            *** Time and Time Zones ***
                           Local time: Wed 2024-09-25 22:33:54 CEST
                       Universal time: Wed 2024-09-25 20:33:54 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            dieter
            HOME=/home/dieter
            GROUPS=dieter adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** Display-Server-Setup ***
            Display-Server: true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.8G        1.6G        533M         25M        1.6G        2.1G
            Swap:            99M          0B         99M
            Total:          3.9G        1.6G        633M
            Active iob-Instances:   15
                     3793 M total memory
                     1632 M used memory
                     1981 M active memory
                     1041 M inactive memory
                      533 M free memory
                       55 M buffer memory
                     1571 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 22:33:54 up 41 min,  3 users,  load average: 1.26, 1.73, 1.54
            Tasks: 218 total,   1 running, 217 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  1.4 us,  4.2 sy,  0.0 ni, 94.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3793.3 total,    533.4 free,   1632.8 used,   1627.2 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2059.8 avail Mem
            *** FAILED SERVICES ***
              UNIT                           LOAD   ACTIVE SUB    DESCRIPTION
            * home-dieter-fritzNAS.automount loaded failed failed home-dieter-fritzNAS.automount
            * unattended-upgrades.service    loaded failed failed Unattended Upgrades Shutdown
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            2 loaded units listed.
            *** FILESYSTEM ***
            Filesystem                                              Type      Size  Used Avail Use% Mounted on
            /dev/root                                               ext4       57G   15G   40G  27% /
            devtmpfs                                                devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs                                                   tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs                                                   tmpfs     759M  2.9M  756M   1% /run
            tmpfs                                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
            /dev/sda1                                               vfat      255M   31M  225M  13% /boot
            tmpfs                                                   tmpfs     380M   24K  380M   1% /run/user/1000
            //192.168.178.1/fritz.nas/Seagate_Expansion_Drive/FRITZ cifs      932G  259G  673G  28% /home/dieter/fritzNAS
            [Wed Sep 25 21:52:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1B:9C:FF vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=11a7a5ab-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Wed Sep 25 21:52:23 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
            [Wed Sep 25 21:52:23 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Wed Sep 25 21:52:27 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
            [Wed Sep 25 21:52:56 2024] ext4: Unknown parameter 'credentials'
            Show mounted filesystems:
            TARGET                       SOURCE                                                  FSTYPE          OPTIONS
            /                            /dev/sda2                                               ext4            rw,noatime
            |-/dev                       devtmpfs                                                devtmpfs        rw,relatime,size=1677960k,nr_inodes=419490,mode=755
            | |-/dev/shm                 tmpfs                                                   tmpfs           rw,nosuid,nodev
            | |-/dev/pts                 devpts                                                  devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
            | `-/dev/mqueue              mqueue                                                  mqueue          rw,nosuid,nodev,noexec,relatime
            |-/proc                      proc                                                    proc            rw,relatime
            | `-/proc/sys/fs/binfmt_misc systemd-1                                               autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
            |-/sys                       sysfs                                                   sysfs           rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/security     securityfs                                              securityfs      rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/cgroup           cgroup2                                                 cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
            | |-/sys/fs/pstore           pstore                                                  pstore          rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/bpf              bpf                                                     bpf             rw,nosuid,nodev,noexec,relatime,mode=700
            | |-/sys/kernel/debug        debugfs                                                 debugfs         rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/tracing      tracefs                                                 tracefs         rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/config       configfs                                                configfs        rw,nosuid,nodev,noexec,relatime
            | `-/sys/fs/fuse/connections fusectl                                                 fusectl         rw,nosuid,nodev,noexec,relatime
            |-/run                       tmpfs                                                   tmpfs           rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
            | |-/run/lock                tmpfs                                                   tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
            | |-/run/rpc_pipefs          sunrpc                                                  rpc_pipefs      rw,relatime
            | `-/run/user/1000           tmpfs                                                   tmpfs           rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
            |   `-/run/user/1000/gvfs    gvfsd-fuse                                              fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            |-/home/dieter/fritzNAS      //192.168.178.1/fritz.nas/Seagate_Expansion_Drive/FRITZ cifs            rw,relatime,vers=3.0,cache=strict,username=dieter,uid=1000,noforceuid,gid=1000,noforcegid,addr=192.168.178.1,file_mode=0755,dir_mode=0755,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
            `-/boot                      /dev/sda1                                               vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.6G    /var/
            1018M   /var/log
            1009M   /var/log/journal/30346a16c8bc4adf9aab575fba47f4b7
            274M    /var/cache
            Archived and active journals take up 1008.3M in the file system.
            /opt/iobroker/backups:
            46M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.9G    /opt/iobroker/iobroker-data/
            913M    /opt/iobroker/iobroker-data/history
            791M    /opt/iobroker/iobroker-data/files
            441M    /opt/iobroker/iobroker-data/files/javascript.admin
            409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            45M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
            19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
            19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v12.22.12
            /usr/local/bin/node             v18.16.0
            /usr/local/bin/npm              9.5.1
            /usr/local/bin/npx              9.5.1
            /usr/local/bin/corepack         0.17.0
            *** nodejs is NOT correctly installed ***
            nodejs:
              Installed: 12.22.12~dfsg-1~deb11u5
              Candidate: 20.17.0-1nodesource1
              Version table:
                 20.17.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
             *** 12.22.12~dfsg-1~deb11u5 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  6.0.11
            admin:          7.1.2
            javascript:     8.7.6
            nodejs modules from github:     1
            +-- iobroker.mystrom@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.mystrom.git#5c82d5d501ae7f423ca7332e3ac42c6b194e9a58)
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
            + system.adapter.bshb.0                   : bshb                  : raspberrypi                              -  enabled, compact disabled
              system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled, compact disabled
            + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
            + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled, compact disabled
            + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
            + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled, compact disabled
            + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
            + system.adapter.mystrom.0                : mystrom               : raspberrypi                              -  enabled, compact disabled
            + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.webui.0                  : webui                 : raspberrypi                              -  enabled
            + instance is alive
            ioBroker-Repositories
            │ (index) │   name   │                           url                           │ auto upgrade │
            │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
            │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.1.2    , installed 7.1.2
            Adapter    "backitup"     : 3.0.22   , installed 3.0.22
            Adapter    "bshb"         : 0.2.8    , installed 0.2.8
            Adapter    "email"        : 1.3.1    , installed 1.3.1
            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
            Controller "js-controller": 6.0.11   , installed 6.0.11
            Adapter    "modbus"       : 6.2.3    , installed 6.2.3
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "webui"        : 1.11.3   , installed 1.11.3
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        3454
            States:         6061
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 https://apt.grafana.com stable InRelease
            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          801        604/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16679      1197/smbd
            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16678      1197/smbd
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       18102      421/node-red
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      117        15363      586/mosquitto
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27404      3033/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27397      3033/iobroker.js-co
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15429      562/cupsd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15428      562/cupsd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          803        604/sshd: /usr/sbin
            tcp6       0      0 :::80                   :::*                    LISTEN      0          15401      641/apache2
            tcp6       0      0 :::139                  :::*                    LISTEN      0          16677      1197/smbd
            tcp6       0      0 :::445                  :::*                    LISTEN      0          16676      1197/smbd
            tcp6       0      0 :::1883                 :::*                    LISTEN      117        15364      586/mosquitto
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        964        574/influxd
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26530      3060/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       29964      3312/io.web.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14811      407/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       27645      3228/io.shelly.0
            udp        0      0 0.0.0.0:54941           0.0.0.0:*                           108        14813      407/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14976      481/dhcpcd
            udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16621      565/nmbd
            udp        0      0 192.168.178.201:137     0.0.0.0:*                           0          16620      565/nmbd
            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1839       565/nmbd
            udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16623      565/nmbd
            udp        0      0 192.168.178.201:138     0.0.0.0:*                           0          16622      565/nmbd
            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1840       565/nmbd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1850       714/cups-browsed
            udp6       0      0 :::5353                 :::*                                108        14812      407/avahi-daemon: r
            udp6       0      0 :::53748                :::*                                108        14814      407/avahi-daemon: r
            2024-09-25 22:21:44.589  - info: host.raspberrypi instance system.adapter.discovery.0 in version "5.0.0" started with pid 3242
            2024-09-25 22:21:45.029  - info: bshb.0 (3154) Detecting open doors/windows finished
            2024-09-25 22:21:45.030  - info: bshb.0 (3154) Start detecting climate schedules...
            2024-09-25 22:21:45.514  - info: rpi2.0 (3209) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.16.0, js-controller: 6.0.11
            2024-09-25 22:21:46.046  - info: bshb.0 (3154) Detecting climate schedules finished
            2024-09-25 22:21:46.048  - info: bshb.0 (3154) Subscribe to ioBroker states
            2024-09-25 22:21:46.052  - info: bshb.0 (3154) Listen to changes
            2024-09-25 22:21:47.769  - info: host.raspberrypi instance system.adapter.mystrom.0 in version "0.1.0" (non-npm: TA2k/ioBroker.mystrom#5c82d5d501ae7f423ca7332e3ac42c6b194e9a58) started with pid 3297
            2024-09-25 22:21:51.440  - info: shelly.0 (3228) starting. Version 7.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.16.0, js-controller: 6.0.11
            2024-09-25 22:21:51.627  - info: host.raspberrypi instance system.adapter.web.0 in version "6.2.5" started with pid 3312
            2024-09-25 22:21:52.114  - info: shelly.0 (3228) [firmwareUpdate] Auto-Update enabled - devices will be updated automatically
            2024-09-25 22:21:52.119  - info: shelly.0 (3228) Starting in CoAP mode. Listening on 0.0.0.0:5683
            2024-09-25 22:21:52.299  - info: discovery.0 (3242) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 6.0.11
            2024-09-25 22:21:52.583  - info: shelly.0 (3228) [CoAP Server] Listening for packets in the network
            2024-09-25 22:21:52.970  - info: mystrom.0 (3297) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.mystrom#5c82d5d501ae7f423ca7332e3ac42c6b194e9a58) in /opt/iobroker/node_modules/iobroker.mystrom, node: v18.16.0, js-controller: 6.0.11
            2024-09-25 22:21:56.317  - info: host.raspberrypi instance system.adapter.webui.0 in version "1.11.3" started with pid 3331
            2024-09-25 22:21:56.395  - info: mystrom.0 (3297) Set update interval for 083AF2A5B57C to 5
            2024-09-25 22:21:56.641  - info: mystrom.0 (3297) Set update interval for 083AF2A5FF28 to 5
            2024-09-25 22:21:57.795  - info: web.0 (3312) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 6.0.11
            2024-09-25 22:21:58.220  - info: web.0 (3312) socket.io server listening on port 8082
            2024-09-25 22:21:58.233  - info: web.0 (3312) http server listening on port 8082
            2024-09-25 22:21:59.810  - info: webui.0 (3331) starting. Version 1.11.3 in /opt/iobroker/node_modules/iobroker.webui, node: v18.16.0, js-controller: 6.0.11
            2024-09-25 22:21:59.845  - info: webui.0 (3331) dirName: /opt/iobroker/node_modules/iobroker.webui
            2024-09-25 22:21:59.995  - info: webui.0 (3331) adapter ready
            2024-09-25 22:22:00.893  - info: admin.0 (3060) ==> Connected system.user.admin from ::ffff:192.168.178.46
              Und hier noch die Kurzform
                                      v.2024-05-22
                       Icon name: computer
                    Architecture: arm64
              Installation:           native
              Kernel:                 aarch64
              Userland:               64 bit
              Timezone:               Europe/Berlin (CEST, +0200)
              User-ID:                1000
              Boot Target:            graphical.target
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:
              Recommended versions are nodejs 20.17.0 and npm 10.8.2
              Wrong installation path detected. This needs to be fixed.
              Please execute
              iobroker nodejs-update
              to fix these errors.
              MEMORY:
              Mem:            3.8G        1.6G        526M         25M        1.6G        2.1G
              Swap:            99M          0B         99M
              Total:          3.9G        1.6G        626M
              ioBroker Core:          js-controller           6.0.11
                                      admin                   7.1.2
              Objects type: jsonl
              States  type: jsonl
              Objects:                3454
              States:                 6061
              Size of iob-Database:
              8.4M    /opt/iobroker/iobroker-data/states.jsonl
                Ausschalten.
                sudo systemctl set-default multi-user.target
                Was stimmt mit den
                nicht?
                Offenbar falsche Optionen in der /etc/fstab drin.
                Du hast da mindestens drei Installationen von nodejs reingeprügelt.
                Führe
                ion nodejs-update 20
                aus.
                  konnte ich noch absetzen.
                  Jetzt habe ich auch noch Verbindungsprobleme. Komme weder über SSH noch über GUI rein.
                  Ich muss erstmal ins andere Gebäude den Raspi neu starten.
                  Ich will Dich aber nicht um Deinen Abend bringen.
                    Tja, Netzwerkfehler. Ich kann den Raspi momentan nicht mehr erreichen.
                    Hole den jetzt her und versuche es mit LAN, Monitor usw.
                    Ich melde mich dann morgen Abend hier wieder.
                    Danke und gute Nacht.
                      Guten Abend,
                      ich wollte noch eine Rückmeldung geben.
                      Das war nicht nur ein Netzwerkfehler. Ich benutze ein USB-Stick statt SD-Karte.
                      Dieser ist total ausgefallen, so dass eine Neuinstallation nötig war.
                      Habe jetzt eine "jungfräuliche" Installation auf USB-Stick und diesen gleich geklont.
                      Die iobroker Diagnose sieht jetzt so aus:
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: iobrokerpi
                             Icon name: computer
                                Kernel: Linux 6.6.47+rpt-rpi-v8
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       21:20:54 up 4 min,  2 users,  load average: 0.91, 0.78, 0.37
                      CPU threads: 4
                      Current issues:
                                     Local time: Thu 2024-09-26 21:20:54 CEST
                                 Universal time: Thu 2024-09-26 19:20:54 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      dieter
                      HOME=/home/dieter
                      GROUPS=dieter adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            4.0G        552M        3.2G        1.2M        318M        3.4G
                      Swap:           209M          0B        209M
                      Total:          4.2G        552M        3.4G
                      Active iob-Instances:   6
                               3790 M total memory
                                527 M used memory
                                597 M active memory
                                 82 M inactive memory
                               3027 M free memory
                                 24 M buffer memory
                                279 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      top - 21:20:54 up 4 min,  2 users,  load average: 0.91, 0.78, 0.37
                      Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 42.9 us, 28.6 sy,  0.0 ni, 28.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3791.0 total,   3026.5 free,    527.8 used,    303.5 buff/cache
                      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3263.2 avail Mem
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      udev           devtmpfs  1.6G     0  1.6G   0% /dev
                      tmpfs          tmpfs     380M  1.2M  378M   1% /run
                      /dev/sda2      ext4       29G  4.3G   23G  16% /
                      /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      [Thu Sep 26 21:16:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1B:9C:FF vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=aa7331f2-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                      [Thu Sep 26 21:16:30 2024] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                      [Thu Sep 26 21:16:32 2024] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1834
                      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                      |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1670656k,nr_inodes=417664,mode=755
                      |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=388200k,mode=755
                      | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=388196k,nr_inodes=97049,mode=700,uid=1000,gid=1000
                      `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      681M    /var/
                      207M    /var/cache
                      201M    /var/cache/apt
                      173M    /var/lib
                      141M    /var/lib/apt/lists
                      Archived and active journals take up 100.1M in the file system.
                      4.0K    /opt/iobroker/backups/
                      510M    /opt/iobroker/iobroker-data/
                      503M    /opt/iobroker/iobroker-data/files
                      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
                      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.279d2690.chunk.js.map
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      /usr/bin/nodejs         v20.17.0
                      /usr/bin/node           v20.17.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.29.3
                      nodejs:
                        Installed: 20.17.0-1nodesource1
                        Version table:
                       *** 20.17.0-1nodesource1 600
                           20.16.0-1nodesource1 600
                           20.15.1-1nodesource1 600
                           20.15.0-1nodesource1 600
                           20.14.0-1nodesource1 600
                           20.13.1-1nodesource1 600
                           20.13.0-1nodesource1 600
                           20.12.2-1nodesource1 600
                           20.12.1-1nodesource1 600
                           20.12.0-1nodesource1 600
                           20.11.1-1nodesource1 600
                           20.11.0-1nodesource1 600
                           20.10.0-1nodesource1 600
                           20.9.0-1nodesource1 600
                           20.8.1-1nodesource1 600
                           20.8.0-1nodesource1 600
                           20.7.0-1nodesource1 600
                           20.6.1-1nodesource1 600
                           20.6.0-1nodesource1 600
                           20.5.1-1nodesource1 600
                           20.5.0-1nodesource1 600
                           20.4.0-1nodesource1 600
                           20.3.1-1nodesource1 600
                           20.3.0-1nodesource1 600
                           20.2.0-1nodesource1 600
                           20.1.0-1nodesource1 600
                           20.0.0-1nodesource1 600
                           18.19.0+dfsg-6~deb12u2 500
                           18.19.0+dfsg-6~deb12u1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          7.1.2
                      javascript:     8.7.6
                      nodejs modules from github:     0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobrokerpi                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : iobrokerpi                               -  enabled
                      + system.adapter.discovery.0              : discovery             : iobrokerpi                               -  enabled
                      + system.adapter.history.0                : history               : iobrokerpi                               -  enabled
                      + system.adapter.javascript.0             : javascript            : iobrokerpi                               -  enabled
                      + instance is alive
                      Adapter    "admin"        : 7.1.5    , installed 7.1.2  [Updatable]
                      Objects and States
                      Objects:        219
                      States:         160
                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6412       672/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6407       672/iobroker.js-con
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6402       681/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       671        758/io.admin.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          6404       681/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        505        538/avahi-daemon: r
                      udp        0      0 0.0.0.0:47726           0.0.0.0:*                           104        507        538/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                104        506        538/avahi-daemon: r
                      udp6       0      0 fe80::72f9:c85e:592:546 :::*                                0          656        622/NetworkManager
                      udp6       0      0 :::60112                :::*                                104        508        538/avahi-daemon: r
                      2024-09-26 19:37:30.239  - info: host.iobrokerpi instance system.adapter.admin.0 in version "7.1.2" started with pid 758
                      2024-09-26 19:37:30.267  - info: host.iobrokerpi Delete state "system.host.iobrokerpi.versions.npmCurrent"
                      2024-09-26 19:37:30.276  - info: host.iobrokerpi Delete state "system.host.iobrokerpi.versions.npmNewest"
                      2024-09-26 19:37:30.283  - info: host.iobrokerpi Delete state "system.host.iobrokerpi.versions.npmNewestNext"
                      2024-09-26 19:37:30.292  - info: host.iobrokerpi Some obsolete host states deleted.
                      2024-09-26 19:37:34.127  - info: host.iobrokerpi instance system.adapter.javascript.0 in version "8.7.6" started with pid 770
                      2024-09-26 19:37:34.293  - info: admin.0 (758) starting. Version 7.1.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                      2024-09-26 19:37:34.347  - info: admin.0 (758) requesting all objects
                      2024-09-26 19:37:35.290  - info: admin.0 (758) received all objects
                      2024-09-26 19:37:36.343  - warn: admin.0 (758) Cannot update news: ETIMEDOUT
                      2024-09-26 19:37:36.382  - info: admin.0 (758) socket.io server listening on port 8081
                      2024-09-26 19:37:36.389  - info: admin.0 (758) http server listening on port 8081
                      2024-09-26 19:37:36.390  - info: admin.0 (758) Use link "http://127.0.0.1:8081" to configure.
                      2024-09-26 19:37:38.420  - info: host.iobrokerpi instance system.adapter.history.0 in version "3.0.1" started with pid 809
                      2024-09-26 19:37:39.283  - info: javascript.0 (770) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                      2024-09-26 19:37:40.348  - info: javascript.0 (770) requesting all states
                      2024-09-26 19:37:40.350  - info: javascript.0 (770) requesting all objects
                      2024-09-26 19:37:40.574  - info: javascript.0 (770) received all states
                      2024-09-26 19:37:40.785  - info: javascript.0 (770) received all objects
                      2024-09-26 19:37:41.306  - info: history.0 (809) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.17.0, js-controller: 6.0.11
                      2024-09-26 19:37:42.390  - info: host.iobrokerpi instance system.adapter.backitup.0 in version "3.0.22" started with pid 831
                      2024-09-26 19:37:44.638  - info: backitup.0 (831) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                      2024-09-26 19:37:45.411  - info: backitup.0 (831) [iobroker] backup will be activated at 02:48 every 1 day(s)
                      2024-09-26 19:37:46.174  - info: host.iobrokerpi instance system.adapter.discovery.0 in version "5.0.0" started with pid 846
                      2024-09-26 21:17:19.680  - info: discovery.0 (846) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                      Gibt es daran etwas auszusetzen?
                        Nö, schaut gut aus.
                        4646
