    4. [Neuer Adapter] EuSec
      Adnim @Longbow last edited by
      @longbow
      also da nix von Hand löschen würde ich sagen.
      Ich glaube du hast da nen Update Stau im System; hau mal nen IOB Diag raus...
      • Longbow
        @adnim
        Mhh kann so was passieren...
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: iobroker-Final
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.2.16-3-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         17:18:05 up 14 days,  3:39,  3 users,  load average: 1.25, 1.22, 1.12
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Sat 2024-09-14 17:18:05 CEST
                   Universal time: Sat 2024-09-14 15:18:05 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        longbow
        HOME=/home/longbow
        GROUPS=longbow sudo users iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:             12G        5.5G        4.3G         90K        3.0G        7.4G
        Swap:           8.6G        126K        8.6G
        Total:           21G        5.5G         12G
        Active iob-Instances:   64
                12288 M total memory
                 5271 M used memory
                 1878 M active memory
                 5748 M inactive memory
                 4145 M free memory
                    0 M buffer memory
                 2871 M swap cache
                 8191 M total swap
                    0 M used swap
                 8191 M free swap
        top - 17:18:05 up 14 days,  3:39,  3 users,  load average: 1.25, 1.22, 1.12
        Tasks:  93 total,   2 running,  91 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  12288.0 total,   4142.8 free,   5273.9 used,   2871.3 buff/cache
        MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.   7014.1 avail Mem
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--240--disk--0 ext4       94G   14G   76G  16% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
        tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
        tmpfs                            tmpfs     3.2G  136K  3.2G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems:
        TARGET                                                  SOURCE                           FSTYPE     OPTIONS
        /                                                       /dev/mapper/pve-vm--240--disk--0 ext4       rw,relatime,stripe=16
        |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3251320k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
        | |-/run/user/1000                                      tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=1625656k,nr_inodes=406414,mode=700,uid=101000,gid=101000,inode64
        | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
        | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
        |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
        | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
        | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
        | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
        | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
        | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
        | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
        | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
        | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
        | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
        | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
        | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
        | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
        | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
        | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
          |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
          |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
          `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        4.3G    /var/
        3.5G    /var/log/journal/4482dacb35484bddab24b914a301d279
        3.5G    /var/log
        712M    /var/cache
        Archived and active journals take up 19.3M in the file system.
        /opt/iobroker/backups:
        518M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.9G    /opt/iobroker/iobroker-data/
        1.3G    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        130M    /opt/iobroker/iobroker-data/states.jsonl
        55M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.16.0-1nodesource1 600
             20.15.1-1nodesource1 600
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.0.23
        javascript:     8.7.6
        nodejs modules from github:     4
        +-- eufy-security-client@3.1.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#27e7c87d67810667022cf6cabb0c46ab1b818654)
        +-- iobroker.roborock@0.6.11 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#801511a70e1eeb3ae66f2608f9d6c86b8933e515)
        +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
        +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : iobroker-Final                           -  enabled
        + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alarm.0                  : alarm                 : iobroker-Final                           -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker-Final                           - disabled
        + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
          system.adapter.bidirectional-counter.0  : bidirectional-counter : iobroker-Final                           - disabled
          system.adapter.chromecast.0             : chromecast            : iobroker-Final                           - disabled
        + system.adapter.cloud.0                  : cloud                 : iobroker-Final                           -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker-Final                           -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : iobroker-Final                           -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
        + system.adapter.doorbird.0               : doorbird              : iobroker-Final                           -  enabled
          system.adapter.drag-indicator.0         : drag-indicator        : iobroker-Final                           - disabled
          system.adapter.dwd.0                    : dwd                   : iobroker-Final                           -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-Final                           -  enabled
          system.adapter.eventlist.0              : eventlist             : iobroker-Final                           - disabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker-Final                           -  enabled
          system.adapter.fullcalendar.0           : fullcalendar          : iobroker-Final                           - disabled
        + system.adapter.geofency.0               : geofency              : iobroker-Final                           -  enabled, port: 7999, bind: 0.0.0.0
        + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker-Final                           -  enabled
          system.adapter.hm-rega.1                : hm-rega               : iobroker-Final                           - disabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Final                           -  enabled, port: 18701
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-Final                           -  enabled, port: 12001
          system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-Final                           - disabled, port: 12001
        + system.adapter.homeconnect.0            : homeconnect           : iobroker-Final                           -  enabled
        + system.adapter.hue.0                    : hue                   : iobroker-Final                           -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : iobroker-Final                           -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Final                           - disabled
          system.adapter.icons-freepic.0          : icons-freepic         : iobroker-Final                           - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Final                           - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Final                           - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-Final                           - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Final                           - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Final                           - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Final                           - disabled
          system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker-Final                           - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Final                           - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker-Final                           -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker-Final                           -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker-Final                           -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
        + system.adapter.klf200.0                 : klf200                : iobroker-Final                           -  enabled
          system.adapter.lightcontrol.0           : lightcontrol          : iobroker-Final                           - disabled
          system.adapter.linkeddevices.0          : linkeddevices         : iobroker-Final                           - disabled
        + system.adapter.modbus.0                 : modbus                : iobroker-Final                           -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker-Final                           -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.myenergi.0               : myenergi              : iobroker-Final                           -  enabled
        + system.adapter.net-tools.0              : net-tools             : iobroker-Final                           -  enabled
        + system.adapter.netatmo.0                : netatmo               : iobroker-Final                           -  enabled
        + system.adapter.nina.0                   : nina                  : iobroker-Final                           -  enabled
        + system.adapter.notification-manager.0   : notification-manager  : iobroker-Final                           -  enabled
        + system.adapter.nuki-extended.0          : nuki-extended         : iobroker-Final                           -  enabled
        + system.adapter.onvif.0                  : onvif                 : iobroker-Final                           -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899, 888
          system.adapter.openweathermap.0         : openweathermap        : iobroker-Final                           -  enabled
        + system.adapter.operating-hours.0        : operating-hours       : iobroker-Final                           -  enabled
          system.adapter.ping.0                   : ping                  : iobroker-Final                           - disabled
          system.adapter.places.0                 : places                : iobroker-Final                           - disabled
        + system.adapter.pollenflug.0             : pollenflug            : iobroker-Final                           -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobroker-Final                           -  enabled, port: 8006
        + system.adapter.pushover.0               : pushover              : iobroker-Final                           -  enabled
        + system.adapter.reolink.0                : reolink               : iobroker-Final                           -  enabled
        + system.adapter.reolink.1                : reolink               : iobroker-Final                           -  enabled
        + system.adapter.reolink.2                : reolink               : iobroker-Final                           -  enabled
          system.adapter.robonect.0               : robonect              : iobroker-Final                           - disabled
        + system.adapter.roborock.0               : roborock              : iobroker-Final                           -  enabled
          system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker-Final                           - disabled, port: 8002
        + system.adapter.scenes.0                 : scenes                : iobroker-Final                           -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker-Final                           -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker-Final                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartgarden.0            : smartgarden           : iobroker-Final                           -  enabled
          system.adapter.smartthings.0            : smartthings           : iobroker-Final                           - disabled
          system.adapter.solaredge.0              : solaredge             : iobroker-Final                           -  enabled
          system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-Final                           -  enabled
        + system.adapter.sql.0                    : sql                   : iobroker-Final                           -  enabled
        + system.adapter.statistics.0             : statistics            : iobroker-Final                           -  enabled
        + system.adapter.systeminfo.0             : systeminfo            : iobroker-Final                           -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Final                           -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker-Final                           -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker-Final                           -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker-Final                           -  enabled
        + system.adapter.tuya.1                   : tuya                  : iobroker-Final                           -  enabled
        + system.adapter.tuya.2                   : tuya                  : iobroker-Final                           -  enabled
        + system.adapter.unifi.0                  : unifi                 : iobroker-Final                           -  enabled
        + system.adapter.upnp.0                   : upnp                  : iobroker-Final                           -  enabled
          system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-Final                           - disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker-Final                           - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-Final                           - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Final                           - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-Final                           -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-Final                           -  enabled
          system.adapter.vis-history.0            : vis-history           : iobroker-Final                           -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Final                           - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-Final                           - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-Final                           -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-Final                           - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker-Final                           - disabled
          system.adapter.vis-map.0                : vis-map               : iobroker-Final                           - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-Final                           - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-Final                           -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker-Final                           - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker-Final                           -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Final                           - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Final                           - disabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker-Final                           - disabled
          system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobroker-Final                           -  enabled
        + system.adapter.vw-connect.1             : vw-connect            : iobroker-Final                           -  enabled
        + system.adapter.weather-warnings.0       : weather-warnings      : iobroker-Final                           -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker-Final                           -  enabled
        + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.welcome.0                : welcome               : iobroker-Final                           -  enabled, port: 80, bind: 0.0.0.0, run as: admin
        + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker-Final                           -  enabled
        + system.adapter.wolf.0                   : wolf                  : iobroker-Final                           -  enabled, port: 12004, bind: 0.0.0.0
          system.adapter.yr.0                     : yr                    : iobroker-Final                           -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
        Adapter    "admin"        : 7.0.23   , installed 7.0.23
        Adapter    "alarm"        : 3.6.1    , installed 3.6.1
        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
        Adapter    "bidirectional-counter": 2.2.0, installed 2.2.0
        Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "doorbird"     : 1.7.0    , installed 1.7.0
        Adapter    "drag-indicator": 2.2.0   , installed 2.2.0
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "fullcalendar" : 2.4.2    , installed 2.4.2
        Adapter    "geofency"     : 1.2.4    , installed 1.2.4
        Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
        Adapter    "hue"          : 3.12.0   , installed 3.12.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "klf200"       : 1.2.0    , installed 1.2.0
        Adapter    "lightcontrol" : 0.8.0    , installed 0.8.0
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "notification-manager": 1.1.2, installed 1.1.2
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "operating-hours": 1.1.0  , installed 1.1.0
        Adapter    "places"       : 1.2.0    , installed 1.2.0
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "pushover"     : 4.1.0    , installed 3.0.6  [Updatable]
        Adapter    "reolink"      : 1.1.1    , installed 1.1.1
        Adapter    "robonect"     : 1.3.6    , installed 1.3.6
        Adapter    "roborock"     : 0.6.4    , installed 0.6.11
        Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
        Adapter    "scenes"       : 3.2.1    , installed 3.2.1
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "welcome"      : 0.3.0    , installed 0.3.0
        Adapter    "wolf"         : 1.7.0    , installed 1.7.0
        Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        58506
        States:         46276
        Hit:1 http://security.debian.org bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.240:18701   0.0.0.0:*               LISTEN      1001       512516892  381431/io.hm-rpc.0
        tcp        0      0 192.168.178.240:12001   0.0.0.0:*               LISTEN      1001       512517743  381442/io.hm-rpc.1
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          419981791  294/master
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       512511819  381099/iobroker.js-
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       512511824  381099/iobroker.js-
        tcp        0      0 0.0.0.0:8100            0.0.0.0:*               LISTEN      1001       512527792  382060/io.doorbird.
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       512521923  381635/io.shelly.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          419979059  1/systemd
        tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       512526179  381961/io.wolf.0
        tcp6       0      0 :::7906                 :::*                    LISTEN      1001       512521448  381244/io.roborock.
        tcp6       0      0 :::8000                 :::*                    LISTEN      1001       512547557  382879/io.upnp.0
        tcp6       0      0 :::7999                 :::*                    LISTEN      1001       512516041  381395/io.geofency.
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       513254766  387362/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       512512795  381117/io.admin.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       512539420  382911/io.simple-ap
        tcp6       0      0 :::8095                 :::*                    LISTEN      1001       512534319  382574/io.onvif.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          419981792  294/master
        tcp6       0      0 :::6824                 :::*                    LISTEN      1001       512521447  381244/io.roborock.
        tcp6       0      0 :::1984                 :::*                    LISTEN      1001       512520456  381571/go2rtc_linux
        tcp6       0      0 :::80                   :::*                    LISTEN      1001       512537054  382784/io.welcome.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          419979061  1/systemd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          419980077  1/systemd
        tcp6       0      0 :::8554                 :::*                    LISTEN      1001       512518925  381571/go2rtc_linux
        tcp6       0      0 :::8555                 :::*                    LISTEN      1001       512518926  381571/go2rtc_linux
        tcp6       0      0 :::51989                :::*                    LISTEN      1001       512525054  382028/io.nuki-exte
        udp        0      0 192.168.178.240:5353    0.0.0.0:*                           1001       512521215  381756/io.tr-064.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       512522784  381868/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       512522785  381868/io.tuya.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          419979060  1/systemd
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       512542779  382879/io.upnp.0
        udp        0      0 0.0.0.0:35611           0.0.0.0:*                           1001       512537584  382879/io.upnp.0
        udp6       0      0 :::111                  :::*                                0          419979062  1/systemd
        udp6       0      0 :::8555                 :::*                                1001       512560717  383682/go2rtc
        2024-09-14 17:15:26.014  - info: host.iobroker-Final instance system.adapter.daswetter.0 in version "3.1.16" started with pid 428529
        2024-09-14 17:15:26.657  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
        2024-09-14 17:15:26.677  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
        2024-09-14 17:15:26.688  - info: web.0 (387362) ==> Connected system.user.admin from ::ffff:192.168.178.38
        2024-09-14 17:15:26.884  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
        Copy text starting here:
                                v.2024-05-22
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    1
        Nodejs-Installation:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        Recommended versions are nodejs 20.17.0 and npm 10.8.2
        MEMORY:
        Mem:             12G        5.5G        4.4G         90K        3.0G        7.4G
        Total:           21G        5.5G         12G
        ioBroker Core:          js-controller           6.0.11
                                admin                   7.0.23
        Objects type: jsonl
        States  type: jsonl
        Objects:                58506
        States:                 46276
        Size of iob-Database:
        59M     /opt/iobroker/iobroker-data/objects.jsonl
        132M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
        longbow@iobroker-Final:~$
        • Longbow
          Kann mir keiner einen Tipp geben oder behilflich sein ?
            guitardoc @Longbow last edited by
            @longbow Der Security Client muss raus, den hast du dir bei irgendeinem Installationsversuch eingefangen:
            npm uninstall eufy-security-client
            • Longbow
              @guitardoc Danke, hat geklappt... der Adapter könnte installiert werden, nur leider werden meinen Cam, die Bilder angezeigt... spricht wie binde ich nun diese ein?
              G G 2 Replies Last reply Reply Quote 0
                @longbow Da kann ich dir leider nicht helfen, ich nutze den Adapter nur, um den Modus in Abhängigkeit von Anwesenheit und Tageszeit zu steuern.
                  GMJ @Longbow last edited by GMJ
                  @longbow
                  So gehts -> http://IP_BROKER:PORT_BROKER_VIS/eusec.0/T8030P0815/last_event/T8213P0815.jpg
                  In Vis in ein "Basic Image" in die URL
                  astuermer 1 Reply Last reply Reply Quote 0
                  • Longbow
                    @gmj Danke, das geht sehr gut.
                    Wie kann man das Live einfügen? Also aufrufen, bekommen?
                      @longbow
                      Kein Live Bild so einfach "da"
                      Nutze ich nicht.... denn man muss so wie ich das verstanden haben das Livebild starten (per datenpunkt triggern) dann gibt es einen Stream den man dann irgend wie einbinden könnte .... und danach den Stream wieder beenden. Sonst refresh Bild im widget in x ms einstellbar dann gibt es auktuelles wenn da.
                      • astuermer
                        astuermer @GMJ last edited by astuermer
                        @gmj sagte in [Neuer Adapter] EuSec:
                        @longbow
                        Da kommt bei mir leider nur das:
                        404
                        Oops! The page you're looking for can't be found. 😔
                        File /eusec.0/hier Pfad mit Dateiname.jpg not found
                        Update: Hat sich erledigt mit einem neuen Update. Was nachwievor nicht läuft, dass der Akkustand sich automatisch aktualisiert. Ich muss dazu jedesmal den Adapter neu starten.
                        • astuermer
                          astuermer last edited by
                          Was von Vorteil wäre: Timestamp pro Kamera.
                          Klar man kann es in der eufy App ins Bild integrieren, aber bei Tageslicht ist das nicht lesbar. Das wäre als Value pro Kamera toll 👍🏻
                            guitardoc last edited by guitardoc
                            @astuermer Bei mir liefert der eusec Adapter leider keine geänderten Werte in den Datenpunkten für motion_detected und person_detected. Die Datenpunkte stehen permanent auf false. Ich habe die Werte mal in SQL protokolliert - keine Änderung. Motion_detection steht aber auf true, Bewegungen werden in der app auch erkannt.
                            Hat jemand das gleiche Problem?
                            Fabio 1 Reply Last reply Reply Quote 0
                            • Fabio
                              Fabio @guitardoc last edited by
                              @guitardoc bekommst du auch Push aufs Handy?
                              Fabio
                                guitardoc @Fabio last edited by
                                @fabio Meinst du aus der App heraus? Da bekomme ich Mitteilungen ob Bewegung oder Person erkannt wurde.
                                • Fabio
                                  Fabio @guitardoc last edited by Fabio
                                  @guitardoc okay dann kann es daran nicht liegen. Adapter mal neu gestartet?
                                  Evtl. im Adapter mal auf interne Verbindungen stellen und nicht auf P2P.
                                    @fabio OK, hab mal umgestellt und neu gestartet, mal sehen, ob es funktioniert. Die Datenpunkte hängen also daran, dass man Nachrichten aus der App aufs Handy bekommt?
                                    • Fabio
                                      @guitardoc ja so war’s bei mir mal, hatte bei einer Kamera die Benachrichtigung deaktiviert da kam nix im Adapter an. Einfach mal testen.
                                      Grüße Fabio
                                        @fabio Nein, hat leider nicht funktioniert. Im Adapter kommt nichts an wenn ich die Nachricht der Bewegung auf dem Telefon habe. Seltsam. Hab auf interne Verbindungen umgestellt und neu gestartet - in der Datenbank steht weiterhin nur ein einziger Wert: false.
                                        • Fabio
                                          @guitardoc dann gehe zurück auf P2P und probiere noch mal. Du kannst die Station auch mal neu starten.
                                          Ansonten weiß ich nicht woran das liegen kann. Kannst du die Kamera über die vorhandenen Datenpunkte denn steuern?
                                          Evtl. bitte ein Issues erstellen im jeden Fall aber mit Log damit @bropat sehen kann woran es liegt.
                                          Fabio
                                            @fabio Ich habe die Lautstärke der Kamera mal testweise über den Datenpunkt gesteuert, das hat funktioniert. Hab den Adapter jetzt mal auf debug gesetzt, vielleicht kann man da schon was erkennen.
                                            1.0k
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            455677
