    4. Fehlermeldung beim Versuch ioBroker zu stoppen
    • hg6806
      hg6806 Most Active last edited by
      nach einer Neuinstallation von ioBroker auf einem RasPi4 wollte ich ein Backup restoren, doch beim Stoppen von ioBroker gab es folgende Fehlermeldung:
      pi@RasPi4-VNC:~ $ iobroker stop
      /usr/bin/iobroker: line 2: conditional binary operator expected
      /usr/bin/iobroker: line 2: syntax error near `*--allow-root*'
      /usr/bin/iobroker: line 2: `if [ "1000" = 0 ] && [[  != *--allow-root* ]]; then'
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @hg6806 last edited by
        @hg6806 vnc? Ordner usr/bin ? Was machst du da?
        Ro75
        • hg6806
          hg6806 Most Active @Ro75 last edited by
          @ro75
          Keine Ahnung, habe es ganz normal über folgenden Befehl installiert:
          curl -sLf https://iobroker.net/install.sh | bash -
          Wie immer eigentlich.
          Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
          • Ro75
            @hg6806 wie immer? Was für ein System, Details bitte
            Ro75
              Thomas Braun Most Active @hg6806 last edited by
              @hg6806
              Alles gut...
              cat /usr/bin/iobroker
              sagt?
              • hg6806
                hg6806 Most Active @Thomas Braun last edited by
                pi@RasPi4-VNC:~ $ cat /usr/bin/iobroker
                #!/usr/bin/bash
                echo -e "\n*** ioBroker is not supposed to be run as root. Sorry ***\nOnly a user that is member of iobroker group can execute ioBroker commands.\nPlease read the Documentation on how to set up such a user, if not done yet.\nOnly in very special cases you can run iobroker with --allow-root option.\nPlease note that this option may be disabled soon, so please change your setup accordingly now."
                exit;
                fi;
                if (( $# == 1 )) && ([ "$1" = "start" ] || [ "$1" = "stop" ] || [ "$1" = "restart" ]); then
                sudo systemctl $1 iobroker
                elif [ "$1" = "fix" ]; then
                curl -sL https://iobroker.net/fix.sh | bash -
                elif [ "$1" = "nodejs-update" ]; then
                sudo -u iobroker curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh && bash /home/iobroker/.nodejs-update.sh "$2"
                elif [ "$1" = "diag" ]; then
                  sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh | sudo -u iobroker tee /home/iobroker/iob_diag.log
                else
                sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                fi
                  Thomas Braun Most Active @hg6806 last edited by Thomas Braun
                  @hg6806
                  Änder mal die Zeile 3 ab:
                  if [ "$(id -u)" = 0 ] && [[ $* != *--allow-root* ]]; then
                  • hg6806
                    Wie und was denn ändern?
                    Und wieso habe ich jetzt hier überhaupt ein Problem?
                    Das hat doch sonst immer geklappt?
                      @hg6806 sagte in Fehlermeldung beim Versuch ioBroker zu stoppen:
                      Steht doch da. Im Grunde aus der 1000 ein $(id -u) machen.
                      Heute ist neuer Code für iob diag, iob nodejs-update und den Installer hochgeladen worden. Die Passage, die da jetzt bei dir Probleme bereitet sollte eigentlich auch anders aussehen.
                      • hg6806
                        Sorry, bin kein Linuxer. Nochmal die Frage wie ich was ändern soll. Welche Datei und wie?
                          @hg6806
                          Alternativ kannst du auch die Zeilen 3-6 komplett löschen.
                          • hg6806
                            Aus der Datei /usr/bin/bash oder wie?
                              @hg6806
                              Die Datei /usr/bin/iobroker bzw. deren Linktarget /opt/iobroker/iobroker mit dem Editor deiner Wahl bearbeiten.
                              sudo -H -u iobrokoer nano  /usr/bin/iobroker
                              wäre eine Möglichkeit.
                              • hg6806
                                Noch immer Fehler.
                                pi@RasPi4-VNC:~ $ iob stop
                                /usr/bin/iob: line 2: conditional binary operator expected
                                /usr/bin/iob: line 2: syntax error near `*--allow-root*'
                                /usr/bin/iob: line 2: `if [ "$(id -u)" = 0 ] && [[  != *--allow-root* ]]; then'
                                  Noch immer Fehler.
                                  Ja, da fehlt noch ein $* vor dem !=
                                  Die korrekte Zeile muss lauten:
                                  • hg6806
                                    Hat endlich geklappt, allerdings kann ich kein Restore ausführen zumindest passiert nichts:
                                    pi@RasPi4-VNC:~ $ cd /opt/iobroker
                                    pi@RasPi4-VNC:/opt/iobroker $ iob restore 0
                                      @hg6806
                                      Den user 'pi' hast du aus- und wieder eingeloggt?
                                      • hg6806
                                        Neu gebootet, das Gleiche
                                        pi@RasPi4-VNC:/opt/iobroker $ iob stop
                                          @hg6806 Liegt denn überhaupt ein backup in /opt/iobroker/backups?
                                          • hg6806
                                            pi@RasPi4-VNC:/opt/iobroker/backups $ dir
                                            2024_09_08-16_33_32_backupiobroker.tar.gz
                                            1658
