    4. Fehlermeldung beim Versuch ioBroker zu stoppen
    • Ro75
      Ro75 @hg6806 last edited by
      @hg6806 vnc? Ordner usr/bin ? Was machst du da?
      Ro75
      • hg6806
        hg6806 Most Active @Ro75 last edited by
        @ro75
        Keine Ahnung, habe es ganz normal über folgenden Befehl installiert:
        curl -sLf https://iobroker.net/install.sh | bash -
        Wie immer eigentlich.
        Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
        • Ro75
          @hg6806 wie immer? Was für ein System, Details bitte
          Ro75
            Thomas Braun Most Active @hg6806 last edited by
            @hg6806
            Alles gut...
            cat /usr/bin/iobroker
            sagt?
            • hg6806
              hg6806 Most Active @Thomas Braun last edited by
              pi@RasPi4-VNC:~ $ cat /usr/bin/iobroker
              #!/usr/bin/bash
              if [ "1000" = 0 ] && [[  != *--allow-root* ]]; then
              echo -e "\n*** ioBroker is not supposed to be run as root. Sorry ***\nOnly a user that is member of iobroker group can execute ioBroker commands.\nPlease read the Documentation on how to set up such a user, if not done yet.\nOnly in very special cases you can run iobroker with --allow-root option.\nPlease note that this option may be disabled soon, so please change your setup accordingly now."
              exit;
              fi;
              if (( $# == 1 )) && ([ "$1" = "start" ] || [ "$1" = "stop" ] || [ "$1" = "restart" ]); then
              sudo systemctl $1 iobroker
              elif [ "$1" = "fix" ]; then
              curl -sL https://iobroker.net/fix.sh | bash -
              elif [ "$1" = "nodejs-update" ]; then
              sudo -u iobroker curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh && bash /home/iobroker/.nodejs-update.sh "$2"
              elif [ "$1" = "diag" ]; then
                sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh | sudo -u iobroker tee /home/iobroker/iob_diag.log
              else
              sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
              fi
                Thomas Braun Most Active @hg6806 last edited by Thomas Braun
                @hg6806
                Änder mal die Zeile 3 ab:
                if [ "$(id -u)" = 0 ] && [[ $* != *--allow-root* ]]; then
                • hg6806
                  Wie und was denn ändern?
                  Und wieso habe ich jetzt hier überhaupt ein Problem?
                  Das hat doch sonst immer geklappt?
                    @hg6806 sagte in Fehlermeldung beim Versuch ioBroker zu stoppen:
                    Steht doch da. Im Grunde aus der 1000 ein $(id -u) machen.
                    Heute ist neuer Code für iob diag, iob nodejs-update und den Installer hochgeladen worden. Die Passage, die da jetzt bei dir Probleme bereitet sollte eigentlich auch anders aussehen.
                    • hg6806
                      Sorry, bin kein Linuxer. Nochmal die Frage wie ich was ändern soll. Welche Datei und wie?
                        @hg6806
                        Alternativ kannst du auch die Zeilen 3-6 komplett löschen.
                        • hg6806
                          Aus der Datei /usr/bin/bash oder wie?
                            @hg6806
                            Die Datei /usr/bin/iobroker bzw. deren Linktarget /opt/iobroker/iobroker mit dem Editor deiner Wahl bearbeiten.
                            sudo -H -u iobrokoer nano  /usr/bin/iobroker
                            wäre eine Möglichkeit.
                            • hg6806
                              Noch immer Fehler.
                              pi@RasPi4-VNC:~ $ iob stop
                              /usr/bin/iob: line 2: conditional binary operator expected
                              /usr/bin/iob: line 2: syntax error near `*--allow-root*'
                              /usr/bin/iob: line 2: `if [ "$(id -u)" = 0 ] && [[  != *--allow-root* ]]; then'
                                Noch immer Fehler.
                                Ja, da fehlt noch ein $* vor dem !=
                                Die korrekte Zeile muss lauten:
                                • hg6806
                                  Hat endlich geklappt, allerdings kann ich kein Restore ausführen zumindest passiert nichts:
                                  pi@RasPi4-VNC:~ $ cd /opt/iobroker
                                  pi@RasPi4-VNC:/opt/iobroker $ iob restore 0
                                    @hg6806
                                    Den user 'pi' hast du aus- und wieder eingeloggt?
                                    • hg6806
                                      Neu gebootet, das Gleiche
                                      pi@RasPi4-VNC:/opt/iobroker $ iob stop
                                        @hg6806 Liegt denn überhaupt ein backup in /opt/iobroker/backups?
                                        • hg6806
                                          pi@RasPi4-VNC:/opt/iobroker/backups $ dir
                                          2024_09_08-16_33_32_backupiobroker.tar.gz
                                            @hg6806
                                            ls -la /opt/iobroker/backups
                                            damit man die Rechte sieht.
                                            1657
