    4. Admin 6.2 jetzt im Stable
      JB72 last edited by
      @jb72 said in Admin 6.2 jetzt im Stable:
      iobroker upgrade admin --debug
      ich habe wieder Probleme mit dem Admin 😕
      Would you like to upgrade admin from @7.0.22 to @7.1.5 now? [(y)es, (n)o]: y
      Update admin from @7.0.22 to @7.1.5
      NPM version: 10.2.4
      Installing iobroker.admin@7.1.5... (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types
      npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue'
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-09-28T15_21_21_069Z-debug-0.log
      Try to solve ENOTEMPTY error automatically
      Could not handle ENOTEMPTY, because no deletable files were found
      npm ERR! errno -39
      host.iobroker Cannot install iobroker.admin@7.1.5: 217
      *****@iobroker:~$
      Was habe ich wieder verbrochen ? Irgendwie mag mich das Modul nicht.
        Thomas Braun Most Active @JB72 last edited by
        @jb72
        Jag den Fixer mal über das System.
        iob stop
        iob fix
        iob start
          JB72 last edited by
          Gesagt getan. Soll ich jetzt mal über die Konsole wieder iobroker upgrade admin --debug versuchen ?
            @jb72
            iob update
            iob upgrade all
            Und wie bist du da insgesamt unterwegs?
            Schau dir
            iob diag
            an.
              JB72 last edited by
              Nun ist alles up to date und läuft.
              Soll ich dir das Ergebnis von iob diag senden?
                @jb72
                Poste es hier in den Thread.
                  JB72 last edited by
                  ```bash
                  Skript v.2024-08-12
                  *** BASE SYSTEM ***
                     Static hostname: iobroker
                           Icon name: computer-vm
                             Chassis: vm
                      Virtualization: kvm
                    Operating System: Debian GNU/Linux 10 (buster)
                              Kernel: Linux 4.19.0-17-amd64
                        Architecture: x86-64
                  OS is similar to:
                  model name      : Common KVM processor
                  Docker          : false
                  Virtualization  : kvm
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   17:34:17 up  4:07,  2 users,  load average: 0.73, 1.30, 1.03
                  CPU threads: 4
                  *** Time and Time Zones ***
                                 Local time: Sat 2024-09-28 17:34:17 CEST
                             Universal time: Sat 2024-09-28 15:34:17 UTC
                                   RTC time: Sat 2024-09-28 15:34:18
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  jerry
                  HOME=/home/jerry
                  GROUPS=jerry cdrom floppy audio dip video plugdev netdev iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  *** Display-Server-Setup ***
                  Display-Server: false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:           3.9G        1.9G        879M        5.0M        1.2G        1.8G
                  Swap:          4.1G          0B        4.1G
                  Total:         8.0G        1.9G        5.0G
                  Active iob-Instances:   21
                           3946 M total memory
                           1853 M used memory
                           2206 M active memory
                            540 M inactive memory
                            879 M free memory
                            176 M buffer memory
                           1036 M swap cache
                           4093 M total swap
                              0 M used swap
                           4093 M free swap
                  top - 17:34:17 up  4:07,  2 users,  load average: 0.73, 1.30, 1.03
                  Tasks: 109 total,   1 running, 108 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  3.1 us,  0.0 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   3946.7 total,    879.5 free,   1853.7 used,   1213.5 buff/cache
                  MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   1807.5 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed. Pass --all to see loaded but inactive units, too.
                  To show all installed unit files use 'systemctl list-unit-files'.
                  *** FILESYSTEM ***
                  udev           devtmpfs  2.0G     0  2.0G   0% /dev
                  tmpfs          tmpfs     395M  5.4M  390M   2% /run
                  /dev/sda1      ext4       28G  8.0G   19G  31% /
                  tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
                  tmpfs          tmpfs     395M     0  395M   0% /run/user/1000
                  [Sat Sep 28 13:26:38 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                  [Sat Sep 28 13:26:39 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                  Show mounted filesystems:
                  TARGET        SOURCE    FSTYPE OPTIONS
                  /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
                  `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                  /var:
                  527M    /var/
                  352M    /var/cache
                  345M    /var/cache/apt
                  283M    /var/cache/apt/archives
                  157M    /var/lib
                        Users in the 'systemd-journal' group can see all messages. Pass -q to
                        turn off this notice.
                  No journal files were opened due to insufficient permissions.
                  /opt/iobroker/backups:
                  369M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  964M    /opt/iobroker/iobroker-data/
                  752M    /opt/iobroker/iobroker-data/files
                  441M    /opt/iobroker/iobroker-data/files/javascript.admin
                  409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
                  23M     /opt/iobroker/iobroker-data/objects.jsonl
                  14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4e69f5548c29ec11b12d6f7840c9ce8d-if00-port0
                  Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.19.1
                  /usr/bin/node           v18.19.1
                  /usr/bin/npm            10.2.4
                  /usr/bin/npx            10.2.4
                  /usr/bin/corepack       0.22.0
                  nodejs:
                    Installed: 18.19.1-1nodesource1
                    Candidate: 18.20.4-1nodesource1
                    Version table:
                       18.20.4-1nodesource1 600
                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                       18.20.3-1nodesource1 600
                       18.20.2-1nodesource1 600
                       18.20.1-1nodesource1 600
                       18.20.0-1nodesource1 600
                   *** 18.19.1-1nodesource1 600
                          100 /var/lib/dpkg/status
                       18.19.0-1nodesource1 600
                       18.18.2-1nodesource1 600
                       18.18.1-1nodesource1 600
                       18.18.0-1nodesource1 600
                       18.17.1-1nodesource1 600
                       18.17.0-1nodesource1 600
                       18.16.1-1nodesource1 600
                       18.16.0-1nodesource1 600
                       18.15.0-1nodesource1 600
                       18.14.2-1nodesource1 600
                       18.14.1-1nodesource1 600
                       18.14.0-1nodesource1 600
                       18.13.0-1nodesource1 600
                       18.12.0-1nodesource1 600
                       18.11.0-1nodesource1 600
                       18.10.0-1nodesource1 600
                       18.9.1-1nodesource1 600
                       18.9.0-1nodesource1 600
                       18.8.0-1nodesource1 600
                       18.7.0-1nodesource1 600
                       18.6.0-1nodesource1 600
                       18.5.0-1nodesource1 600
                       18.4.0-1nodesource1 600
                       18.3.0-1nodesource1 600
                       18.2.0-1nodesource1 600
                       18.1.0-1nodesource1 600
                       18.0.0-1nodesource1 600
                       10.24.0~dfsg-1~deb10u4 500
                          500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                       10.24.0~dfsg-1~deb10u1 500
                          500 http://deb.debian.org/debian buster/main amd64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  6.0.11
                  admin:          7.1.5
                  javascript:     8.7.6
                  nodejs modules from github:     0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                    system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                  + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
                    system.adapter.material.0               : material              : iobroker                                 - disabled
                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                    system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
                    system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
                    system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
                  + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                    system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                    system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 - disabled
                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4e69f5548c29ec11b12d6f7840c9ce8d-if00-port0
                  + instance is alive
                  ioBroker-Repositories
                  │ (index) │   name   │                           url                           │ auto upgrade │
                  │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                  │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                  Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                  Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                  Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                  Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                  Adapter    "homekit-controller": 0.5.10, installed 0.5.10
                  Adapter    "ical"         : 1.15.0   , installed 1.15.0
                  Adapter    "icons-material-png": 0.1.0, installed 0.1.1
                  Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                  Controller "js-controller": 6.0.11   , installed 6.0.11
                  Adapter    "material"     : 1.3.1    , installed 1.3.1
                  Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                  Adapter    "nina"         : 0.0.25   , installed 0.0.25
                  Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                  Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                  Adapter    "scenes"       : 3.2.1    , installed 3.2.1
                  Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                  Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                  Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                  Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                  Objects and States
                  Objects:        15593
                  States:         14227
                  Hit:1 http://security.debian.org/debian-security buster/updates InRelease
                  Hit:2 http://deb.debian.org/debian buster InRelease
                  Hit:3 http://deb.debian.org/debian buster-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 170
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       484178     25550/iobroker.js-c
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       484171     25550/iobroker.js-c
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11058      1/init
                  tcp        0      0 192.168.100.130:42001   0.0.0.0:*               LISTEN      1001       486131     25738/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14228      407/sshd
                  tcp        0      0 192.168.100.130:42010   0.0.0.0:*               LISTEN      1001       487221     26142/io.hm-rpc.1
                  tcp6       0      0 :::3500                 :::*                    LISTEN      1001       486385     26011/io.sonos.0
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          11067      1/init
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       494239     29711/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       488526     26346/io.web.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14230      407/sshd
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        14507      347/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       486915     25839/io.shelly.0
                  udp        0      0 0.0.0.0:34830           0.0.0.0:*                           1001       489012     26467/io.tradfri.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14145      370/dhclient
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11062      1/init
                  udp        0    768 0.0.0.0:53421           0.0.0.0:*                           1001       488523     26335/io.mihome-vac
                  udp        0      0 0.0.0.0:33284           0.0.0.0:*                           106        14509      347/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                106        14508      347/avahi-daemon: r
                  udp6       0      0 :::59459                :::*                                106        14510      347/avahi-daemon: r
                  udp6       0      0 :::111                  :::*                                0          11072      1/init
                  2024-09-28 17:31:16.071  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/3.png
                  2024-09-28 17:31:16.075  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol_desc with Bewölkt
                  2024-09-28 17:31:16.078  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol with 4
                  2024-09-28 17:31:16.082  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol_desc2 with Bedeckt
                  2024-09-28 17:31:16.088  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_speed with 10 km/h
                  2024-09-28 17:31:16.092  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_dir with N
                  2024-09-28 17:31:16.095  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_symbol with 9
                  2024-09-28 17:31:16.099  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_symbolB with 33
                  2024-09-28 17:31:16.105  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/33.png
                  2024-09-28 17:31:16.108  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_gusts with 25
                  2024-09-28 17:31:16.112  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.rain with 0 mm
                  2024-09-28 17:31:16.116  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.humidity with 86
                  2024-09-28 17:31:16.122  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.pressure with 1015 mb
                  2024-09-28 17:31:16.125  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.clouds with 63%
                  2024-09-28 17:31:16.129  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.snowline with 1800 m
                  2024-09-28 17:31:16.145  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.uv_index with 0
                  2024-09-28 17:31:16.148  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.windchill with 10
                  2024-09-28 17:31:16.152  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.sunshineDuration with 3.9299999999999997
                  2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) exit, all done
                  2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) timer killed
                  2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) Plugin sentry destroyed
                  2024-09-28 17:31:16.158  - info: daswetter.0 (29856) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2024-09-28 17:31:16.667  - info: daswetter.0 (29856) cleaned everything up...
                  2024-09-28 17:31:16.682  - info: host.iobroker instance system.adapter.daswetter.0 having pid 29856 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-09-28 17:31:18.598  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  iob diag has finished.
                  Press any key for a summary
                  Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Codierknecht
                    Codierknecht Developer Most Active @JB72 last edited by Codierknecht
                    @jb72
                    ... der Klassiker
                    Buster ist tot.
                    Das muss durch ein aktuelles Booworm ersetzt werden.
                    Also:
                    • Backup ziehen
                    • Neues OS rein
                    • aus Backup wiederherstellen
                      JB72 @Codierknecht last edited by
                      @codierknecht
                      Du meinst ich muss das Debian updaten?
                        @jb72 sagte in Admin 6.2 jetzt im Stable:
                        buster
                        Muss auf eine noch unterstützte Version gehoben werden. Debian 10 'Buster' ist schon geraume Zeit abgekündigt.
                        Setz den user 'jerry' in die Gruppe 'adm' rein.
                        sudo usermod -aG adm jerry
                        Kümmer dich besser um die Kiste. Updates müssen regelmäßig eingespielt werden.
                        • Codierknecht
                          Das kann man nicht updaten.
                          Das kannst Du nur neu installieren.
                            Thomas Braun Most Active @Codierknecht last edited by
                            @codierknecht
                            Das ist eine VM. Die kann man updaten. Ist nur wenig sinnvoll. Schneller und sicherer ist eine Neuinstallation von Debian 12 'Bookworm' aber allemal.
                            Das mit dem 'kann man nicht upgraden' bezieht sich auf einen Sprung auf Raspberry OS 12 'Bookworm'. Das wurde so umfangreich geändert, das bekommst du nicht unfallfrei stabil hin.
                              JB72 @Thomas Braun last edited by
                              @thomas-braun @Codierknecht
                              Ich danke euch beiden für die schnelle HIlfe. Thomas dir besonders, ist ja nicht das erste mal.
                              Spiele dann mal Updates ein und überlege wie es weiter geht. Will eigentlich weg von Proxmox und wieder
                              auf einen Raspi umsteigen. Das Handling finde ich das einfacher.
                              Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                                Aber nicht zu lange, buster ist noch nicht mal mehr im LTS drin:
                                Das ist nicht tot, das ist mausetot.
                                • Codierknecht
                                  Codierknecht Developer Most Active @Thomas Braun last edited by
                                  @thomas-braun sagte in Admin 6.2 jetzt im Stable:
                                  Das ist eine VM
                                  Wieder mal glatt übersehen 😞
                                  • Codierknecht
                                    So unterschiedlich sind da die Ansichten.
                                    Ich habe die verschiedenen Systeme (ioBroker, MariaDB, Grafana usw.) lieber schön sauber getrennt in einem jeweils eigenen LXC.
                                      JB72 @Codierknecht last edited by JB72
                                      @codierknecht
                                      Ich suche etwas einfaches. Proxmox ist auch schon outdated. Das Zeug tut ja satbil alles was man will und daher vergisst man die Kiste komplett .... schande über mich. Ich muss den Proxmox auch updaten, eigentlich alles. Die Raspberrymatic sowas in der Art wäre was für mich. Beruflich habe ich mit Windows zu tun, der exkurs in Linux ist immer ganz nett, aber ich kenne mich da einfach nicht gut genug aus.
                                      Habe schon von Unraid gehört, das kostet dann aber jährlich. Wie löst ihr das auch Proxmox?
                                      EDIT: Blöde Frage ich muss nur deine Signatur lesen: Proxmox.
                                      • Codierknecht
                                        Auch ein Windows will aktuell gehalten werden.
                                        Genau wie jedes Handy, Tablet und mittlerweile auch das Auto.
                                        Mit Unraid bin ich nur semi-zufrieden. Vielleicht wechsle ich da zu TrueNAS.
                                        Programmierer sind von Haus aus faul - sonst wären sie ja nicht Programmierer geworden.
                                        Also habe ich für mich entschieden, die Updates zu automatisieren.
                                        Das hört @Thomas-Braun vermutlich nicht gerne, aber da auch ich beruflich eher unter Windows unterwegs bin und Updates unter Linux eh nur durchwinken würde, kann ich den Kram auch gleich automatisch machen.
                                        185
                                        21194
