    4. Admin 6.2 jetzt im Stable
      JB72 last edited by
      Gesagt getan. Soll ich jetzt mal über die Konsole wieder iobroker upgrade admin --debug versuchen ?
        Thomas Braun Most Active @JB72 last edited by
        @jb72
        iob update
        iob upgrade all
        Und wie bist du da insgesamt unterwegs?
        Schau dir
        iob diag
        an.
          JB72 last edited by
          Nun ist alles up to date und läuft.
          Soll ich dir das Ergebnis von iob diag senden?
            @jb72
            Poste es hier in den Thread.
              JB72 last edited by
              ```bash
              Skript v.2024-08-12
              *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer-vm
                         Chassis: vm
                  Virtualization: kvm
                Operating System: Debian GNU/Linux 10 (buster)
                          Kernel: Linux 4.19.0-17-amd64
                    Architecture: x86-64
              OS is similar to:
              model name      : Common KVM processor
              Docker          : false
              Virtualization  : kvm
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               17:34:17 up  4:07,  2 users,  load average: 0.73, 1.30, 1.03
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Sat 2024-09-28 17:34:17 CEST
                         Universal time: Sat 2024-09-28 15:34:17 UTC
                               RTC time: Sat 2024-09-28 15:34:18
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              jerry
              HOME=/home/jerry
              GROUPS=jerry cdrom floppy audio dip video plugdev netdev iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev
              *** Display-Server-Setup ***
              Display-Server: false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:           3.9G        1.9G        879M        5.0M        1.2G        1.8G
              Swap:          4.1G          0B        4.1G
              Total:         8.0G        1.9G        5.0G
              Active iob-Instances:   21
                       3946 M total memory
                       1853 M used memory
                       2206 M active memory
                        540 M inactive memory
                        879 M free memory
                        176 M buffer memory
                       1036 M swap cache
                       4093 M total swap
                          0 M used swap
                       4093 M free swap
              top - 17:34:17 up  4:07,  2 users,  load average: 0.73, 1.30, 1.03
              Tasks: 109 total,   1 running, 108 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  3.1 us,  0.0 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3946.7 total,    879.5 free,   1853.7 used,   1213.5 buff/cache
              MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   1807.5 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed. Pass --all to see loaded but inactive units, too.
              To show all installed unit files use 'systemctl list-unit-files'.
              *** FILESYSTEM ***
              udev           devtmpfs  2.0G     0  2.0G   0% /dev
              tmpfs          tmpfs     395M  5.4M  390M   2% /run
              /dev/sda1      ext4       28G  8.0G   19G  31% /
              tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
              tmpfs          tmpfs     395M     0  395M   0% /run/user/1000
              [Sat Sep 28 13:26:38 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
              [Sat Sep 28 13:26:39 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
              Show mounted filesystems:
              TARGET        SOURCE    FSTYPE OPTIONS
              /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
              `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
              /var:
              527M    /var/
              352M    /var/cache
              345M    /var/cache/apt
              283M    /var/cache/apt/archives
              157M    /var/lib
                    Users in the 'systemd-journal' group can see all messages. Pass -q to
                    turn off this notice.
              No journal files were opened due to insufficient permissions.
              /opt/iobroker/backups:
              369M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              964M    /opt/iobroker/iobroker-data/
              752M    /opt/iobroker/iobroker-data/files
              441M    /opt/iobroker/iobroker-data/files/javascript.admin
              409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
              23M     /opt/iobroker/iobroker-data/objects.jsonl
              14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4e69f5548c29ec11b12d6f7840c9ce8d-if00-port0
              Your zigbee.0 COM-Port is matching 'by-id'. Very good!
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.1
              /usr/bin/node           v18.19.1
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.1-1nodesource1
                Candidate: 18.20.4-1nodesource1
                Version table:
                   18.20.4-1nodesource1 600
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                   18.20.3-1nodesource1 600
                   18.20.2-1nodesource1 600
                   18.20.1-1nodesource1 600
                   18.20.0-1nodesource1 600
               *** 18.19.1-1nodesource1 600
                      100 /var/lib/dpkg/status
                   18.19.0-1nodesource1 600
                   18.18.2-1nodesource1 600
                   18.18.1-1nodesource1 600
                   18.18.0-1nodesource1 600
                   18.17.1-1nodesource1 600
                   18.17.0-1nodesource1 600
                   18.16.1-1nodesource1 600
                   18.16.0-1nodesource1 600
                   18.15.0-1nodesource1 600
                   18.14.2-1nodesource1 600
                   18.14.1-1nodesource1 600
                   18.14.0-1nodesource1 600
                   18.13.0-1nodesource1 600
                   18.12.0-1nodesource1 600
                   18.11.0-1nodesource1 600
                   18.10.0-1nodesource1 600
                   18.9.1-1nodesource1 600
                   18.9.0-1nodesource1 600
                   18.8.0-1nodesource1 600
                   18.7.0-1nodesource1 600
                   18.6.0-1nodesource1 600
                   18.5.0-1nodesource1 600
                   18.4.0-1nodesource1 600
                   18.3.0-1nodesource1 600
                   18.2.0-1nodesource1 600
                   18.1.0-1nodesource1 600
                   18.0.0-1nodesource1 600
                   10.24.0~dfsg-1~deb10u4 500
                      500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                   10.24.0~dfsg-1~deb10u1 500
                      500 http://deb.debian.org/debian buster/main amd64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  6.0.11
              admin:          7.1.5
              javascript:     8.7.6
              nodejs modules from github:     0
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
              + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
                system.adapter.material.0               : material              : iobroker                                 - disabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
                system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
                system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
              + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 - disabled
              + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4e69f5548c29ec11b12d6f7840c9ce8d-if00-port0
              + instance is alive
              ioBroker-Repositories
              │ (index) │   name   │                           url                           │ auto upgrade │
              │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
              │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.22   , installed 3.0.22
              Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
              Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
              Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
              Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
              Adapter    "homekit-controller": 0.5.10, installed 0.5.10
              Adapter    "ical"         : 1.15.0   , installed 1.15.0
              Adapter    "icons-material-png": 0.1.0, installed 0.1.1
              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "material"     : 1.3.1    , installed 1.3.1
              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
              Adapter    "nina"         : 0.0.25   , installed 0.0.25
              Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
              Adapter    "sayit"        : 5.0.0    , installed 5.0.0
              Adapter    "scenes"       : 3.2.1    , installed 3.2.1
              Adapter    "shelly"       : 7.0.0    , installed 7.0.0
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
              Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Objects and States
              Objects:        15593
              States:         14227
              Hit:1 http://security.debian.org/debian-security buster/updates InRelease
              Hit:2 http://deb.debian.org/debian buster InRelease
              Hit:3 http://deb.debian.org/debian buster-updates InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 170
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       484178     25550/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       484171     25550/iobroker.js-c
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11058      1/init
              tcp        0      0 192.168.100.130:42001   0.0.0.0:*               LISTEN      1001       486131     25738/io.hm-rpc.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14228      407/sshd
              tcp        0      0 192.168.100.130:42010   0.0.0.0:*               LISTEN      1001       487221     26142/io.hm-rpc.1
              tcp6       0      0 :::3500                 :::*                    LISTEN      1001       486385     26011/io.sonos.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          11067      1/init
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       494239     29711/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       488526     26346/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          14230      407/sshd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        14507      347/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       486915     25839/io.shelly.0
              udp        0      0 0.0.0.0:34830           0.0.0.0:*                           1001       489012     26467/io.tradfri.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14145      370/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11062      1/init
              udp        0    768 0.0.0.0:53421           0.0.0.0:*                           1001       488523     26335/io.mihome-vac
              udp        0      0 0.0.0.0:33284           0.0.0.0:*                           106        14509      347/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                106        14508      347/avahi-daemon: r
              udp6       0      0 :::59459                :::*                                106        14510      347/avahi-daemon: r
              udp6       0      0 :::111                  :::*                                0          11072      1/init
              2024-09-28 17:31:16.071  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/3.png
              2024-09-28 17:31:16.075  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol_desc with Bewölkt
              2024-09-28 17:31:16.078  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol with 4
              2024-09-28 17:31:16.082  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol_desc2 with Bedeckt
              2024-09-28 17:31:16.088  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_speed with 10 km/h
              2024-09-28 17:31:16.092  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_dir with N
              2024-09-28 17:31:16.095  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_symbol with 9
              2024-09-28 17:31:16.099  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_symbolB with 33
              2024-09-28 17:31:16.105  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/33.png
              2024-09-28 17:31:16.108  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_gusts with 25
              2024-09-28 17:31:16.112  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.rain with 0 mm
              2024-09-28 17:31:16.116  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.humidity with 86
              2024-09-28 17:31:16.122  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.pressure with 1015 mb
              2024-09-28 17:31:16.125  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.clouds with 63%
              2024-09-28 17:31:16.129  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.snowline with 1800 m
              2024-09-28 17:31:16.145  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.uv_index with 0
              2024-09-28 17:31:16.148  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.windchill with 10
              2024-09-28 17:31:16.152  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.sunshineDuration with 3.9299999999999997
              2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) exit, all done
              2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) timer killed
              2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) Plugin sentry destroyed
              2024-09-28 17:31:16.158  - info: daswetter.0 (29856) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2024-09-28 17:31:16.667  - info: daswetter.0 (29856) cleaned everything up...
              2024-09-28 17:31:16.682  - info: host.iobroker instance system.adapter.daswetter.0 having pid 29856 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-09-28 17:31:18.598  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
              iob diag has finished.
              Press any key for a summary
              Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
              • Codierknecht
                Codierknecht Developer Most Active @JB72 last edited by Codierknecht
                @jb72
                ... der Klassiker
                Buster ist tot.
                Das muss durch ein aktuelles Booworm ersetzt werden.
                Also:
                • Backup ziehen
                • Neues OS rein
                • aus Backup wiederherstellen
                  JB72 @Codierknecht last edited by
                  @codierknecht
                  Du meinst ich muss das Debian updaten?
                    @jb72 sagte in Admin 6.2 jetzt im Stable:
                    buster
                    Muss auf eine noch unterstützte Version gehoben werden. Debian 10 'Buster' ist schon geraume Zeit abgekündigt.
                    Setz den user 'jerry' in die Gruppe 'adm' rein.
                    sudo usermod -aG adm jerry
                    Kümmer dich besser um die Kiste. Updates müssen regelmäßig eingespielt werden.
                    • Codierknecht
                      Das kann man nicht updaten.
                      Das kannst Du nur neu installieren.
                        Thomas Braun Most Active @Codierknecht last edited by
                        @codierknecht
                        Das ist eine VM. Die kann man updaten. Ist nur wenig sinnvoll. Schneller und sicherer ist eine Neuinstallation von Debian 12 'Bookworm' aber allemal.
                        Das mit dem 'kann man nicht upgraden' bezieht sich auf einen Sprung auf Raspberry OS 12 'Bookworm'. Das wurde so umfangreich geändert, das bekommst du nicht unfallfrei stabil hin.
                          JB72 @Thomas Braun last edited by
                          @thomas-braun @Codierknecht
                          Ich danke euch beiden für die schnelle HIlfe. Thomas dir besonders, ist ja nicht das erste mal.
                          Spiele dann mal Updates ein und überlege wie es weiter geht. Will eigentlich weg von Proxmox und wieder
                          auf einen Raspi umsteigen. Das Handling finde ich das einfacher.
                          Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                            Aber nicht zu lange, buster ist noch nicht mal mehr im LTS drin:
                            Das ist nicht tot, das ist mausetot.
                            • Codierknecht
                              Codierknecht Developer Most Active @Thomas Braun last edited by
                              @thomas-braun sagte in Admin 6.2 jetzt im Stable:
                              Das ist eine VM
                              Wieder mal glatt übersehen 😞
                              • Codierknecht
                                So unterschiedlich sind da die Ansichten.
                                Ich habe die verschiedenen Systeme (ioBroker, MariaDB, Grafana usw.) lieber schön sauber getrennt in einem jeweils eigenen LXC.
                                  JB72 @Codierknecht last edited by JB72
                                  @codierknecht
                                  Ich suche etwas einfaches. Proxmox ist auch schon outdated. Das Zeug tut ja satbil alles was man will und daher vergisst man die Kiste komplett .... schande über mich. Ich muss den Proxmox auch updaten, eigentlich alles. Die Raspberrymatic sowas in der Art wäre was für mich. Beruflich habe ich mit Windows zu tun, der exkurs in Linux ist immer ganz nett, aber ich kenne mich da einfach nicht gut genug aus.
                                  Habe schon von Unraid gehört, das kostet dann aber jährlich. Wie löst ihr das auch Proxmox?
                                  EDIT: Blöde Frage ich muss nur deine Signatur lesen: Proxmox.
                                  • Codierknecht
                                    Auch ein Windows will aktuell gehalten werden.
                                    Genau wie jedes Handy, Tablet und mittlerweile auch das Auto.
                                    Mit Unraid bin ich nur semi-zufrieden. Vielleicht wechsle ich da zu TrueNAS.
                                    Programmierer sind von Haus aus faul - sonst wären sie ja nicht Programmierer geworden.
                                    Also habe ich für mich entschieden, die Updates zu automatisieren.
                                    Das hört @Thomas-Braun vermutlich nicht gerne, aber da auch ich beruflich eher unter Windows unterwegs bin und Updates unter Linux eh nur durchwinken würde, kann ich den Kram auch gleich automatisch machen.
                                    185
                                    21194
