    4. Admin 6.2 jetzt im Stable
      Thomas Braun Most Active @JB72 last edited by
      @jb72
      iob update
      iob upgrade all
      Und wie bist du da insgesamt unterwegs?
      Schau dir
      iob diag
      an.
        JB72 last edited by
        Nun ist alles up to date und läuft.
        Soll ich dir das Ergebnis von iob diag senden?
          @jb72
          Poste es hier in den Thread.
            JB72 last edited by
            ```bash
            Skript v.2024-08-12
            *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer-vm
                       Chassis: vm
                Virtualization: kvm
              Operating System: Debian GNU/Linux 10 (buster)
                        Kernel: Linux 4.19.0-17-amd64
                  Architecture: x86-64
            OS is similar to:
            model name      : Common KVM processor
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             17:34:17 up  4:07,  2 users,  load average: 0.73, 1.30, 1.03
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Sat 2024-09-28 17:34:17 CEST
                       Universal time: Sat 2024-09-28 15:34:17 UTC
                             RTC time: Sat 2024-09-28 15:34:18
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            jerry
            HOME=/home/jerry
            GROUPS=jerry cdrom floppy audio dip video plugdev netdev iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           3.9G        1.9G        879M        5.0M        1.2G        1.8G
            Swap:          4.1G          0B        4.1G
            Total:         8.0G        1.9G        5.0G
            Active iob-Instances:   21
                     3946 M total memory
                     1853 M used memory
                     2206 M active memory
                      540 M inactive memory
                      879 M free memory
                      176 M buffer memory
                     1036 M swap cache
                     4093 M total swap
                        0 M used swap
                     4093 M free swap
            top - 17:34:17 up  4:07,  2 users,  load average: 0.73, 1.30, 1.03
            Tasks: 109 total,   1 running, 108 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  3.1 us,  0.0 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3946.7 total,    879.5 free,   1853.7 used,   1213.5 buff/cache
            MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   1807.5 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed. Pass --all to see loaded but inactive units, too.
            To show all installed unit files use 'systemctl list-unit-files'.
            *** FILESYSTEM ***
            udev           devtmpfs  2.0G     0  2.0G   0% /dev
            tmpfs          tmpfs     395M  5.4M  390M   2% /run
            /dev/sda1      ext4       28G  8.0G   19G  31% /
            tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
            tmpfs          tmpfs     395M     0  395M   0% /run/user/1000
            [Sat Sep 28 13:26:38 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Sat Sep 28 13:26:39 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            Show mounted filesystems:
            TARGET        SOURCE    FSTYPE OPTIONS
            /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
            `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
            /var:
            527M    /var/
            352M    /var/cache
            345M    /var/cache/apt
            283M    /var/cache/apt/archives
            157M    /var/lib
                  Users in the 'systemd-journal' group can see all messages. Pass -q to
                  turn off this notice.
            No journal files were opened due to insufficient permissions.
            /opt/iobroker/backups:
            369M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            964M    /opt/iobroker/iobroker-data/
            752M    /opt/iobroker/iobroker-data/files
            441M    /opt/iobroker/iobroker-data/files/javascript.admin
            409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
            23M     /opt/iobroker/iobroker-data/objects.jsonl
            14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
            USB-Devices by-id:
            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4e69f5548c29ec11b12d6f7840c9ce8d-if00-port0
            Your zigbee.0 COM-Port is matching 'by-id'. Very good!
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.1
            /usr/bin/node           v18.19.1
            /usr/bin/npm            10.2.4
            /usr/bin/npx            10.2.4
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.1-1nodesource1
              Candidate: 18.20.4-1nodesource1
              Version table:
                 18.20.4-1nodesource1 600
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                 18.20.3-1nodesource1 600
                 18.20.2-1nodesource1 600
                 18.20.1-1nodesource1 600
                 18.20.0-1nodesource1 600
             *** 18.19.1-1nodesource1 600
                    100 /var/lib/dpkg/status
                 18.19.0-1nodesource1 600
                 18.18.2-1nodesource1 600
                 18.18.1-1nodesource1 600
                 18.18.0-1nodesource1 600
                 18.17.1-1nodesource1 600
                 18.17.0-1nodesource1 600
                 18.16.1-1nodesource1 600
                 18.16.0-1nodesource1 600
                 18.15.0-1nodesource1 600
                 18.14.2-1nodesource1 600
                 18.14.1-1nodesource1 600
                 18.14.0-1nodesource1 600
                 18.13.0-1nodesource1 600
                 18.12.0-1nodesource1 600
                 18.11.0-1nodesource1 600
                 18.10.0-1nodesource1 600
                 18.9.1-1nodesource1 600
                 18.9.0-1nodesource1 600
                 18.8.0-1nodesource1 600
                 18.7.0-1nodesource1 600
                 18.6.0-1nodesource1 600
                 18.5.0-1nodesource1 600
                 18.4.0-1nodesource1 600
                 18.3.0-1nodesource1 600
                 18.2.0-1nodesource1 600
                 18.1.0-1nodesource1 600
                 18.0.0-1nodesource1 600
                 10.24.0~dfsg-1~deb10u4 500
                    500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                 10.24.0~dfsg-1~deb10u1 500
                    500 http://deb.debian.org/debian buster/main amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  6.0.11
            admin:          7.1.5
            javascript:     8.7.6
            nodejs modules from github:     0
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
              system.adapter.material.0               : material              : iobroker                                 - disabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
              system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
              system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
              system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
              system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 - disabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4e69f5548c29ec11b12d6f7840c9ce8d-if00-port0
            + instance is alive
            ioBroker-Repositories
            │ (index) │   name   │                           url                           │ auto upgrade │
            │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
            │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.1.5
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "backitup"     : 3.0.22   , installed 3.0.22
            Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
            Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
            Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
            Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
            Adapter    "homekit-controller": 0.5.10, installed 0.5.10
            Adapter    "ical"         : 1.15.0   , installed 1.15.0
            Adapter    "icons-material-png": 0.1.0, installed 0.1.1
            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
            Controller "js-controller": 6.0.11   , installed 6.0.11
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
            Adapter    "scenes"       : 3.2.1    , installed 3.2.1
            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "telegram"     : 3.9.0    , installed 3.9.0
            Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
            Objects and States
            Objects:        15593
            States:         14227
            Hit:1 http://security.debian.org/debian-security buster/updates InRelease
            Hit:2 http://deb.debian.org/debian buster InRelease
            Hit:3 http://deb.debian.org/debian buster-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 170
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       484178     25550/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       484171     25550/iobroker.js-c
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11058      1/init
            tcp        0      0 192.168.100.130:42001   0.0.0.0:*               LISTEN      1001       486131     25738/io.hm-rpc.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14228      407/sshd
            tcp        0      0 192.168.100.130:42010   0.0.0.0:*               LISTEN      1001       487221     26142/io.hm-rpc.1
            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       486385     26011/io.sonos.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          11067      1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       494239     29711/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       488526     26346/io.web.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14230      407/sshd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        14507      347/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       486915     25839/io.shelly.0
            udp        0      0 0.0.0.0:34830           0.0.0.0:*                           1001       489012     26467/io.tradfri.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14145      370/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11062      1/init
            udp        0    768 0.0.0.0:53421           0.0.0.0:*                           1001       488523     26335/io.mihome-vac
            udp        0      0 0.0.0.0:33284           0.0.0.0:*                           106        14509      347/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                106        14508      347/avahi-daemon: r
            udp6       0      0 :::59459                :::*                                106        14510      347/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          11072      1/init
            2024-09-28 17:31:16.071  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/3.png
            2024-09-28 17:31:16.075  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol_desc with Bewölkt
            2024-09-28 17:31:16.078  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol with 4
            2024-09-28 17:31:16.082  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.symbol_desc2 with Bedeckt
            2024-09-28 17:31:16.088  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_speed with 10 km/h
            2024-09-28 17:31:16.092  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_dir with N
            2024-09-28 17:31:16.095  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_symbol with 9
            2024-09-28 17:31:16.099  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_symbolB with 33
            2024-09-28 17:31:16.105  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/33.png
            2024-09-28 17:31:16.108  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.wind_gusts with 25
            2024-09-28 17:31:16.112  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.rain with 0 mm
            2024-09-28 17:31:16.116  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.humidity with 86
            2024-09-28 17:31:16.122  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.pressure with 1015 mb
            2024-09-28 17:31:16.125  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.clouds with 63%
            2024-09-28 17:31:16.129  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.snowline with 1800 m
            2024-09-28 17:31:16.145  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.uv_index with 0
            2024-09-28 17:31:16.148  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.Hour_8.windchill with 10
            2024-09-28 17:31:16.152  - debug: daswetter.0 (29856) insert NextHours2.Location_1.Day_5.sunshineDuration with 3.9299999999999997
            2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) exit, all done
            2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) timer killed
            2024-09-28 17:31:16.157  - debug: daswetter.0 (29856) Plugin sentry destroyed
            2024-09-28 17:31:16.158  - info: daswetter.0 (29856) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-09-28 17:31:16.667  - info: daswetter.0 (29856) cleaned everything up...
            2024-09-28 17:31:16.682  - info: host.iobroker instance system.adapter.daswetter.0 having pid 29856 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-09-28 17:31:18.598  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            iob diag has finished.
            Press any key for a summary
            Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
            • Codierknecht
              Codierknecht Developer Most Active @JB72 last edited by Codierknecht
              @jb72
              ... der Klassiker
              Buster ist tot.
              Das muss durch ein aktuelles Booworm ersetzt werden.
              Also:
              • Backup ziehen
              • Neues OS rein
              • aus Backup wiederherstellen
                JB72 @Codierknecht last edited by
                @codierknecht
                Du meinst ich muss das Debian updaten?
                  @jb72 sagte in Admin 6.2 jetzt im Stable:
                  buster
                  Muss auf eine noch unterstützte Version gehoben werden. Debian 10 'Buster' ist schon geraume Zeit abgekündigt.
                  Setz den user 'jerry' in die Gruppe 'adm' rein.
                  sudo usermod -aG adm jerry
                  Kümmer dich besser um die Kiste. Updates müssen regelmäßig eingespielt werden.
                  • Codierknecht
                    Das kann man nicht updaten.
                    Das kannst Du nur neu installieren.
                      Thomas Braun Most Active @Codierknecht last edited by
                      @codierknecht
                      Das ist eine VM. Die kann man updaten. Ist nur wenig sinnvoll. Schneller und sicherer ist eine Neuinstallation von Debian 12 'Bookworm' aber allemal.
                      Das mit dem 'kann man nicht upgraden' bezieht sich auf einen Sprung auf Raspberry OS 12 'Bookworm'. Das wurde so umfangreich geändert, das bekommst du nicht unfallfrei stabil hin.
                        JB72 @Thomas Braun last edited by
                        @thomas-braun @Codierknecht
                        Ich danke euch beiden für die schnelle HIlfe. Thomas dir besonders, ist ja nicht das erste mal.
                        Spiele dann mal Updates ein und überlege wie es weiter geht. Will eigentlich weg von Proxmox und wieder
                        auf einen Raspi umsteigen. Das Handling finde ich das einfacher.
                        Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                          Aber nicht zu lange, buster ist noch nicht mal mehr im LTS drin:
                          Das ist nicht tot, das ist mausetot.
                          • Codierknecht
                            Codierknecht Developer Most Active @Thomas Braun last edited by
                            @thomas-braun sagte in Admin 6.2 jetzt im Stable:
                            Das ist eine VM
                            Wieder mal glatt übersehen 😞
                            • Codierknecht
                              So unterschiedlich sind da die Ansichten.
                              Ich habe die verschiedenen Systeme (ioBroker, MariaDB, Grafana usw.) lieber schön sauber getrennt in einem jeweils eigenen LXC.
                                JB72 @Codierknecht last edited by JB72
                                @codierknecht
                                Ich suche etwas einfaches. Proxmox ist auch schon outdated. Das Zeug tut ja satbil alles was man will und daher vergisst man die Kiste komplett .... schande über mich. Ich muss den Proxmox auch updaten, eigentlich alles. Die Raspberrymatic sowas in der Art wäre was für mich. Beruflich habe ich mit Windows zu tun, der exkurs in Linux ist immer ganz nett, aber ich kenne mich da einfach nicht gut genug aus.
                                Habe schon von Unraid gehört, das kostet dann aber jährlich. Wie löst ihr das auch Proxmox?
                                EDIT: Blöde Frage ich muss nur deine Signatur lesen: Proxmox.
                                • Codierknecht
                                  Auch ein Windows will aktuell gehalten werden.
                                  Genau wie jedes Handy, Tablet und mittlerweile auch das Auto.
                                  Mit Unraid bin ich nur semi-zufrieden. Vielleicht wechsle ich da zu TrueNAS.
                                  Programmierer sind von Haus aus faul - sonst wären sie ja nicht Programmierer geworden.
                                  Also habe ich für mich entschieden, die Updates zu automatisieren.
                                  Das hört @Thomas-Braun vermutlich nicht gerne, aber da auch ich beruflich eher unter Windows unterwegs bin und Updates unter Linux eh nur durchwinken würde, kann ich den Kram auch gleich automatisch machen.
                                  185
                                  24599
